Ask the Expert: Cisco Unified Border Element (UBE) Enterprise
ciscomoderator
Community Manager
Community Manager
With Robin Cai
Welcome to the Cisco Support Community Ask the Expert conversation. This is an opportunity to and ask questions about how to design and troubleshoot Cisco Unified Border Element  (UBE)  for the enterprise with Cisco expert Robin Cai.  You can ask questions on how UBE works in different call scenarios, including normal calls, hold/resume, call transfer, call forwarding, as well as best practices.
Robin Cai is a senior customer support engineer in the Cisco Technical Assistance Center in Sydney. His current role includes configuring, troubleshooting and designing Cisco Unified Border Element Enterprise and Service Provider,  voice gateways, and Cisco Unified Communications Manager. He has  in-depth knowledge of Cisco and industry signaling protocols. He has more than 11 years of experience working in the telecommunication industry. Previously at Cisco he was a senior software test engineer at the China Research & Development Centre in Shanghai. Before joining Cisco, he worked for UTStarcom as a field support engineer and for Huawei Technologies as a software development engineer. Cai holds a bachelor's degree in computer science from Nanjing University of Science & Technology. He also holds CCIE certification (#26037) in Voice and Routing & Switching.
Remember to use the rating system to let Robin know if you have received an adequate response to your technical support question.
Robin might not be able to answer each question due to the volume expected during this event. Remember that you can continue the conversation on the  Collaboration, Voice and Video sub-community discussion forum shortly after the event.   This event lasts through December 21, 2012. Visit this support forum often to view responses to your questions and the questions of other Cisco Support Community members.
37 Replies 37
Hi Robin
I just upload file to ftp URL. The file name is "Cisco_TAC_Debugs.rar".
Thx
Fei
Hi Fei,
Thanks for providing the debug logs.
In the failed calls, it's seen once one of the extensions (8607,8615,8617 or 9600) answers the phone, CME just releases the call. If look into the logs, the ccapi level triggers the disconnect. It seems CME is trying to get transcoder invovled, somehow it can not reserve transcoder resource, however we are not very sure due to lack of more ccap details.
I would like to suggest you try the following:
- change dial-peer 102 config:
  dial-peer voice 102 voip
    dtmf-relay sip-notify rtp-nte
- try another test call. if it fails, collect following debugs:
  debug ccsip message
  debug voip ccapi all
  debug voip vtsp all
- use the same sip trunk and call one extension (e.g.8615) directly, and see if it fails or not.
  collect the above debug
Actually in this case the issue is related to CME, instead of CUBE functions/features. The scope of this discussion is with regards to configuring and troubleshooting CUBE. You may have to post this in the proper forum "Cisco IP Telephony Forum": https://supportforums.cisco.com/community/netpro/collaboration-voice-video/ip-telephony . We will discuss this futher in new post there.
Thanks and regards,
Robin
And thank you very much for the help
aaa session-id common
clock timezone EET 2
clock summer-time EEST recurring last Sun Mar 3:00 last Sun Oct 4:00
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
dot11 syslog
ip source-route
ip cef
ip dhcp database static.txt
no ip domain lookup
ip domain name lgcom.net
ip name-server 192.168.0.198
ip name-server 10.224.50.168
ip name-server 10.224.37.34
no ipv6 cef
isdn switch-type primary-net5
voice call send-alert
voice call convert-discpi-to-prog
voice rtp send-recv
voice service pots
voice service voip
dtmf-interworking rtp-nte
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol none
no fax-relay sg3-to-g3
h323
  call preserve
sip
  registrar server
  localhost dns:bbtb.cyta.com.cy
   outbound-proxy dns:sbg.bbtb.cyta.com.cy
  no update-callerid
  early-offer forced
voice class codec 2
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729br8
codec preference 4 g729r8
voice class h323 1
  h225 timeout tcp establish 6
voice translation-rule 1
rule 1 /.*\(....\)/ /\1/
voice translation-rule 3
rule 1 /20/ //
rule 2 /9/ //
voice translation-rule 4
rule 1 /\+/ /900/
rule 2 /^\(9\)\(.......$\)/ /99\2/
rule 3 /^\(2\)\(.......$\)/ /92\2/
rule 4 /^0/ /90/
rule 5 /^1/ /9001/
rule 6 /^3/ /9003/
rule 7 /^4/ /9004/
rule 8 /^5/ /9005/
rule 9 /^6/ /9006/
rule 10 /^7/ /9007/
rule 11 /^8/ /9008/
rule 12 /^9/ /9009/
rule 13 /^2/ /9002/
voice translation-rule 5
rule 2 // /2232/
voice translation-rule 9999
rule 1 /22324086/ /1256/
rule 2 /^\+357/ //
voice translation-profile SIP_Incoming
translate called 1
voice translation-profile SIP_Outgoing
translate calling 5
translate called 3
voice translation-profile profile_Chrysostomos
translate calling 4
voice-card 0
dspfarm
dsp services dspfarm
application
service ccm http://192.168.1.242:8080/ccmivr/pages/IVRMainpage.vxml
crypto pki trustpoint TP-self-signed-3171557675
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3171557675
revocation-check none
rsakeypair TP-self-signed-3171557675
crypto pki certificate chain TP-self-signed-3171557675
certificate self-signed 01
  3082024A 308201B3 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33313731 35353736 3735301E 170D3036 31313130 30363337
  32385A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 31373135
  35373637 3530819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100F399 A01909BF 4DCD080F 8823F44B 89830C1E 00317309 C87706C4 C37D12C5
  B2219A9E B188BA75 8CFA7720 05558DAF 26DA06BE 3DEEA993 B4E2F5B6 0166448C
  1C95AB98 7940B959 E049468E 71D4DB8D A70201F9 198212C2 05D59D71 21FA5F25
  9FF18DE3 73D6F33D 0CA170AD D91DAD06 6593CD47 A5D58487 73055F20 AB642BF2
  83110203 010001A3 72307030 0F060355 1D130101 FF040530 030101FF 301D0603
  551D1104 16301482 124C4F47 50524947 572E6C67 636F6D2E 6E657430 1F060355
  1D230418 30168014 C28ADE8C 5FFE68C8 5C819F4A FD8B4533 3F1F9FF3 301D0603
  551D0E04 160414C2 8ADE8C5F FE68C85C 819F4AFD 8B45333F 1F9FF330 0D06092A
  864886F7 0D010104 05000381 8100297C D2B4B669 82B07E54 31EA7BF1 EFEE6817
  D7D4DEC7 9CCC8AC8 E9AD7249 62A464F1 D83026F2 1E1E7275 AA012EB3 2FE4AE89
  042261FC 7B99B336 4292214E AF854736 C9C4B87D 1C257FAA 8D4D38AF 7CFB37F6
  5DF20BA4 B9524911 5F017D3A 27D9F158 42372043 851E5690 E3986213 A77D03A3
  790D2FDC 2E9FEAD2 129F7261 3C7E
        quit
username lgcomadmin privilege 15 password 7 00401C000D0E5D514E
archive
log config
  hidekeys
controller E1 0/0/0
pri-group timeslots 1-31
description CONNECTION TO PSTN
ip ssh version 2
translation-rule 2
Rule 1 1000 1297
Rule 8 1222 1300
Rule 9 1200 1300
Rule 10 1010 1300
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0/0$
ip address 192.168.1.246 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip h323-id PSTN_GATEWAY
h323-gateway voip bind srcaddr 192.168.1.246
interface FastEthernet0/1
description **SIP TRUNK WITH CYTA**
ip address 10.249.13.130 255.255.255.252
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
no logging event link-status
isdn timer T310 60000
isdn incoming-voice voice
isdn sending-complete
isdn outgoing display-ie
no cdp enable
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.1.254
ip route 10.224.37.32 255.255.255.240 10.249.13.129
ip route 10.224.37.34 255.255.255.255 10.249.13.129
ip route 10.224.42.64 255.255.255.192 10.249.13.129
ip route 10.224.42.160 255.255.255.224 10.249.13.129
ip route 10.224.42.164 255.255.255.255 10.249.13.129
ip route 10.224.50.160 255.255.255.240 10.249.13.129
ip route 10.224.50.168 255.255.255.255 10.249.13.129
ip route 10.224.52.32 255.255.255.224 10.249.13.129
ip route 10.224.52.192 255.255.255.248 10.249.13.129
ip route 10.224.52.200 255.255.255.248 10.249.13.129
ip route 10.249.0.0 255.255.0.0 10.249.13.129
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
logging trap warnings
logging 10.0.0.63
logging 192.168.20.7
voice-port 0/0/0:15
translation-profile incoming profile_Chrysostomos
translate called 2
echo-cancel coverage 32
cptone CY
bearer-cap Speech
mgcp fax t38 ecm
sccp local FastEthernet0/0
sccp ccm 192.168.1.242 identifier 1 version 7.0
sccp ccm 192.168.1.241 identifier 2 version 7.0
sccp ip precedence 3
sccp
sccp ccm group 1
bind interface FastEthernet0/0
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 3 register MTP_GW
associate profile 2 register ConferenceBR
associate profile 1 register PSTN_GATEWAY
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 2
associate application SCCP
dspfarm profile 2 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 1
dspfarm profile 3 mtp
codec g711alaw
maximum sessions hardware 3
maximum sessions software 10
dial-peer voice 2000 voip
description **TO CUCM2**
destination-pattern 1...
monitor probe icmp-ping
voice-class codec 2
voice-class h323 1
session target ipv4:192.168.1.241
dtmf-relay h245-alphanumeric
fax-relay ecm disable
fax rate 9600
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
no vad
dial-peer voice 1000 voip
description **TO CUCM1**
preference 5
voice-class codec 2
voice-class h323 1
session target ipv4:192.168.1.242
fax rate 9600
no vad
dial-peer voice 23456 voip
dial-peer voice 13 pots
incoming called-number .
direct-inward-dial
dial-peer voice 20 pots
destination-pattern 9T
progress_ind alert enable 8
port 0/0/0:15
no sip-register
dial-peer voice 5 pots
description **FOR GREECE CALLING CY NUMBERS**
preference 7
destination-pattern 8T
fax rate voice
direct-inward-dial
port 0/0/0:15
no sip-register
dial-peer voice 123456 pots
service ccm
incoming called-number 1257
direct-inward-dial
dial-peer voice 888 voip
description **SIP Trunk to CYTA OUTGOING**
translation-profile incoming SIP_Incoming
translation-profile outgoing SIP_Outgoing
destination-pattern 20T
voice-class codec 2
voice-class sip dtmf-relay force rtp-nte
session protocol sipv2
session target sip-server
dtmf-relay rtp-nte
no vad
dial-peer voice 889 voip
description **SIP Trunk to CUCM**
destination-pattern 4...
voice-class codec 2
session target ipv4:192.168.1.242:5060
dtmf-relay rtp-nte
no vad
no dial-peer outbound status-check pots
sip-ua
credentials username 22324086 password 1234 realm bbtb.cyta.com.cy
authentication username 22324086@bbtb.cyta.com.cy password 1234
no remote-party-id
retry invite 2
retry register 3
retry options 2
timers expires 60000
timers connect 100
timers register 1000
mwi-server ipv4:192.168.1.247 expires 86400 port 5060 transport tcp unsolicited
registrar dns:bbtb.cyta.com.cy expires 110
sip-server dns:bbtb.cyta.com.cy
host-registrar
DEBUGS FOR INCOMING CALL
Below is the debug:
Calling number: 99658392 (mobile number)
Called Number: 22324086(Number for SIP Trunk)
Our network is:192.168.1.0
ISP network: 10.224.0.0,10.249.0.0
You can see that the Incoming Dial-peer=888 , then its translated to 4086 and the outgoing dial peer is 889
The call never going to ipphone and the disconnect code is
SIP/2.0 487 Request terminated
Below is the debug:
LOGPRIGW#
008324: Dec 12 22:27:44.870 EET: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:22324086@10.249.13.130:5060 SIP/2.0
Max-Forwards: 8
Via: SIP/2.0/UDP 10.224.42.164:5060;branch=z9hG4bKtsqwbyt6ovs6vqzdhibnn7nnu
To: "22324086 22324086" <>22324086@bbtb.cyta.com.cy>;cscf
From: <>99658392@fmc.cyta.com.cy;user=phone>;tag=h7g4Esbg_410375357-1355344068456-
Call-ID: BW222748456121212534124537@10.224.50.81
CSeq: 140943285 INVITE
Contact:
Record-Route: <10.224.42.164>
Min-Se: 600
P-Asserted-Identity: <>+35799658392@fmc.cyta.com.cy;user=phone>
P-Called-Party-ID: <>22324086@bbtb.cyta.com.cy>
Privacy: none
Session-Expires: 1800
Content-Type: application/sdp
Content-Length: 229
P-Early-Media: supported
Allow: ACK, BYE, CANCEL, INVITE, OPTIONS, PRACK, REFER, NOTIFY, UPDATE, INFO
Accept: application/media_control+xml
Accept: application/sdp
Accept: application/x-broadworks-call-center+xml
Accept: multipart/mixed
v=0
o=BroadWorks 48920004 1 IN IP4 10.224.42.164
s=-
c=IN IP4 10.224.42.72
t=0 0
m=audio 11602 RTP/AVP 8 18 96 99
a=rtpmap:96 AMR/8000
a=fmtp:96 octet-align=1
a=rtpmap:99 telephone-event/8000
a=fmtp:99 0-15
a=ptime:20
008325: Dec 12 22:27:44.874 EET: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=22324086, Called Number=22324086, Peer Info Type=DIALPEER_INFO_SPEECH
008326: Dec 12 22:27:44.874 EET: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=22324086
008327: Dec 12 22:27:44.874 EET: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
008328: Dec 12 22:27:44.874 EET: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
008329: Dec 12 22:27:44.874 EET: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=99658392, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
008330: Dec 12 22:27:44.878 EET: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=NO_MATCH(-1) After All Match Rules Attempt
008331: Dec 12 22:27:44.878 EET: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
008332: Dec 12 22:27:44.878 EET: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
008333: Dec 12 22:27:44.878 EET: //-1/3871D7318033/DPM/dpAssociateIncomingPeerCore:
   Calling Number=99658392, Called Number=22324086, Voice-Interface=0x0,
008334: Dec 12 22:27:44.878 EET: //-1/3871D7318033/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=888
008335: Dec 12 22:27:44.898 EET: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Wed, 12 Dec 2012 20:27:44 GMT
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
008336: Dec 12 22:27:44.898 EET: //-1/3871D7318033/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=4086, Peer Info Type=DIALPEER_INFO_SPEECH
008337: Dec 12 22:27:44.898 EET: //-1/3871D7318033/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=4086
008338: Dec 12 22:27:44.898 EET: //-1/3871D7318033/DPM/dpMatchPeersCore:
   Result=Success(0) after DP_MATCH_DEST
008339: Dec 12 22:27:44.898 EET: //-1/3871D7318033/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=889
008340: Dec 12 22:27:44.898 EET: //-1/3871D7318033/DPM/dpMatchPeersCore:
008341: Dec 12 22:27:44.898 EET: //-1/3871D7318033/DPM/dpMatchPeersCore:
008342: Dec 12 22:27:44.898 EET: //-1/3871D7318033/DPM/dpMatchPeersCore:
008343: Dec 12 22:27:44.898 EET: //-1/3871D7318033/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
008344: Dec 12 22:27:44.902 EET: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=4086, Called Number=4086, Peer Info Type=DIALPEER_INFO_SPEECH
008345: Dec 12 22:27:44.902 EET: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
008346: Dec 12 22:27:44.902 EET: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
008347: Dec 12 22:27:44.902 EET: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
008348: Dec 12 22:27:44.902 EET: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=4086, Called Number=, Voice-Interface=0x0,
008349: Dec 12 22:27:44.902 EET: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=889
008350: Dec 12 22:27:44.902 EET: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
LOGPRIGW#oice-Interface=0x0,
008351: Dec 12 22:27:44.902 EET: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
008352: Dec 12 22:27:44.902 EET: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
008353: Dec 12 22:27:44.902 EET: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
008354: Dec 12 22:27:44.902 EET: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
008355: Dec 12 22:27:44.902 EET: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
008356: Dec 12 22:27:44.906 EET: //-1/3871D7318033/DPM/dpMatchPeersCore:
008357: Dec 12 22:27:44.906 EET: //-1/3871D7318033/DPM/dpMatchPeersCore:
008358: Dec 12 22:27:44.906 EET: //-1/3871D7318033/DPM/dpMatchPeersCore:
008359: Dec 12 22:27:44.906 EET: //-1/3871D7318033/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
008360: Dec 12 22:27:44.918 EET: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:4086@192.168.1.242:5060 SIP/2.0
Via: SIP/2.0/UDP 10.249.13.130:5060;branch=z9hG4bK15DA1077
From: <>99658392@bbtb.cyta.com.cy>;tag=3A1A6BD8-2C5
To: <4086>
Call-ID: 387755C9-43D111E2-8039AF93-DEB466BD@bbtb.cyta.com.cy
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  600
Cisco-Guid: 946984753-1137775074-2150870931-3736364733
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1355344064
Contact: <99658392>
Expires: 60
Max-Forwards: 7
Content-Disposition: session;handling=required
Content-Length: 286
v=0
o=CiscoSystemsSIP-GW-UserAgent 5966 9817 IN IP4 10.249.13.130
s=SIP Call
c=IN IP4 10.249.13.130
t=0 0
m=audio 16796 RTP/AVP 8 18 101
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=yes
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
008361: Dec 12 22:27:44.970 EET: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
To: <4086>;tag=h7g4Esbg_1400776517-1355344068565
CSeq: 101 INVITE
Contact:
Content-Length: 224
Session: Media
P-Early-Media: sendonly
v=0
o=BroadWorks 48920006 1 IN IP4 10.224.42.164
s=-
c=IN IP4 10.224.42.69
t=0 0
m=audio 11266 RTP/AVP 8 101
a=fmtp:101 0-15
a=ptime:20
008362: Dec 12 22:27:44.982 EET: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: "22324086 22324086" <>22324086@bbtb.cyta.com.cy>;cscf;tag=3A1A6C18-FDD
Contact: <10.249.13.130:5060>
Supported: sdp-anat
Content-Length: 247
v=0
o=CiscoSystemsSIP-GW-UserAgent 8960 8290 IN IP4 10.249.13.130
s=SIP Call
t=0 0
m=audio 19190 RTP/AVP 8 99
a=fmtp:99 0-16
a=ptime:20
LOGPRIGW#
008363: Dec 12 22:28:16.990 EET: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CANCEL sip:22324086@10.249.13.130:5060 SIP/2.0
Max-Forwards: 8
CSeq: 140943285 CANCEL
Contact:
Content-Length: 0
008364: Dec 12 22:28:16.994 EET: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Wed, 12 Dec 2012 20:28:16 GMT
Content-Length: 0
008365: Dec 12 22:28:17.002 EET: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CANCEL sip:4086@192.168.1.242:5060 SIP/2.0
To: <4086>
CSeq: 101 CANCEL
Max-Forwards: 70
Timestamp: 1355344096
Reason: Q.850;cause=16
Content-Length: 0
008366: Dec 12 22:28:17.002 EET: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 487 Request Cancelled
Content-Length: 0
008367: Dec 12 22:28:17.010 EET: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 CANCEL
Content-Length: 0
008368: Dec 12 22:28:17.018 EET: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=4..., Called Number=, Voice-Interface=0x0,
008369: Dec 12 22:28:17.018 EET: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
008370: Dec 12 22:28:17.022 EET: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:22324086@10.249.13.130:5060 SIP/2.0
Max-Forwards: 70
To: "22324086 22324086" <>22324086@bbtb.cyta.com.cy>;tag=3A1A6C18-FDD;cscf
CSeq: 140943285 ACK
Content-Length: 0
008371: Dec 12 22:28:17.034 EET: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=20T, Called Number=, Voice-Interface=0x0,
008372: Dec 12 22:28:17.034 EET: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=888
008373: Dec 12 22:28:17.038 EET: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 101 INVITE
Content-Length: 0
008374: Dec 12 22:28:17.042 EET: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
LOGPRIGW#ACK sip:4086@192.168.1.242:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
LOGPRIGW#
008375: Dec 12 22:28:23.570 EET: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 8
Via: SIP/2.0/UDP 10.224.42.164:5060;branch=z9hG4bKjptooko81vswrjjwhzgb24vq2
From: <>99658392@fmc.cyta.com.cy;user=phone>;tag=h7g4Esbg_504750097-1355344107157-
Call-ID: BW222827157121212-908102060@10.224.50.81
CSeq: 140962635 INVITE
Contact:
Min-Se: 600
Privacy: none
Content-Length: 229
v=0
o=BroadWorks 48920042 1 IN IP4 10.224.42.164
s=-
t=0 0
m=audio 11604 RTP/AVP 8 18 96 99
a=fmtp:99 0-15
a=ptime:20
008376: Dec 12 22:28:23.574 EET: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
008377: Dec 12 22:28:23.574 EET: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
008378: Dec 12 22:28:23.574 EET: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
008379: Dec 12 22:28:23.574 EET: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
008380: Dec 12 22:28:23.578 EET: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
008381: Dec 12 22:28:23.578 EET: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
008382: Dec 12 22:28:23.578 EET: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
008383: Dec 12 22:28:23.578 EET: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
008384: Dec 12 22:28:23.578 EET: //-1/4F82EE56803A/DPM/dpAssociateIncomingPeerCore:
008385: Dec 12 22:28:23.582 EET: //-1/4F82EE56803A/DPM/dpAssociateIncomingPeerCore:
008386: Dec 12 22:28:23.594 EET: //-1/4F82EE56803A/DPM/dpMatchPeersCore:
008387: Dec 12 22:28:23.594 EET: //-1/4F82EE56803A/DPM/dpMatchPeersCore:
008388: Dec 12 22:28:23.594 EET: //-1/4F82EE56803A/DPM/dpMatchPeersCore:
008389: Dec 12 22:28:23.594 EET: //-1/4F82EE56803A/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
008390: Dec 12 22:28:23.594 EET: //-1/4F82EE56803A/DPM/dpMatchPeersCore:
008391: Dec 12 22:28:23.594 EET: //-1/4F82EE56803A/DPM/dpMatchPeersCore:
008392: Dec 12 22:28:23.594 EET: //-1/4F82EE56803A/DPM/dpMatchPeersCore:
008393: Dec 12 22:28:23.594 EET: //-1/4F82EE56803A/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
008394: Dec 12 22:28:23.594 EET: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
008395: Dec 12 22:28:23.594 EET: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
008396: Dec 12 22:28:23.598 EET: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
008397: Dec 12 22:28:23.598 EET: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
008398: Dec 12 22:28:23.598 EET: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
008399: Dec 12 22:28:23.598 EET: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
008400: Dec 12 22:28:23.598 EET: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
008401: Dec 12 22:28:23.598 EET: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
008402: Dec 12 22:28:23.598 EET: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
008403: Dec 12 22:28:23.598 EET: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
008404: Dec 12 22:28:23.598 EET: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
008405: Dec 12 22:28:23.598 EET: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
008406: Dec 12 22:28:23.602 EET: //-1/4F82EE56803A/DPM/dpMatchPeersCore:
008407: Dec 12 22:28:23.602 EET: //-1/4F82EE56803A/DPM/dpMatchPeersCore:
008408: Dec 12 22:28:23.602 EET: //-1/4F82EE56803A/DPM/dpMatchPeersCore:
008409: Dec 12 22:28:23.602 EET: //-1/4F82EE56803A/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
008410: Dec 12 22:28:23.618 EET: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
LOGPRIGW#@fmc.cyta.com.cy;user=phone>;tag=h7g4Esbg_504750097-1355344107157-
Date: Wed, 12 Dec 2012 20:28:23 GMT
Content-Length: 0
008411: Dec 12 22:28:23.618 EET: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.249.13.130:5060;branch=z9hG4bK15DB1BBE
From: <>99658392@bbtb.cyta.com.cy>;tag=3A1B0300-239F
To: <4086>
Call-ID: 4F87D02E-43D111E2-8040AF93-DEB466BD@bbtb.cyta.com.cy
Min-SE:  600
Cisco-Guid: 1333980758-1137775074-2151329683-3736364733
CSeq: 101 INVITE
Timestamp: 1355344103
Contact: <99658392>
Expires: 60
Max-Forwards: 7
Content-Length: 286
v=0
o=CiscoSystemsSIP-GW-UserAgent 3435 9459 IN IP4 10.249.13.130
s=SIP Call
t=0 0
m=audio 16632 RTP/AVP 8 18 101
a=fmtp:101 0-15
008412: Dec 12 22:28:23.702 EET: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <4086>;tag=h7g4Esbg_175677672-1355344107296
CSeq: 101 INVITE
Contact:
Content-Length: 224
Session: Media
v=0
o=BroadWorks 48920044 1 IN IP4 10.224.42.164
s=-
c=IN IP4 10.224.42.70
t=0 0
m=audio 11512 RTP/AVP 8 101
a=fmtp:101 0-15
a=ptime:20
008413: Dec 12 22:28:23.714 EET: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: "22324086 22324086" <>22324086@bbtb.cyta.com.cy>;cscf;tag=3A1B0364-1764
Supported: sdp-anat
Content-Length: 247
v=0
o=CiscoSystemsSIP-GW-UserAgent 7893 5489 IN IP4 10.249.13.130
s=SIP Call
t=0 0
m=audio 19192 RTP/AVP 8 99
a=fmtp:99 0-16
a=ptime:20
LOGPRIGW#
LOGPRIGW#
008414: Dec 12 22:28:52.142 EET: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:bbtb.cyta.com.cy:5060 SIP/2.0
Via: SIP/2.0/UDP 10.249.13.130:5060;branch=z9hG4bK15DC227D
From: <>22324086@bbtb.cyta.com.cy>;tag=3A1B7274-5B8
To: <>22324086@bbtb.cyta.com.cy>
Date: Wed, 12 Dec 2012 20:28:52 GMT
Call-ID: 96CBBE78-3F8011E2-A62CAF93-DEB466BD
Max-Forwards: 70
Timestamp: 1355344132
CSeq: 5525 REGISTER
Contact: <22324086>
Expires:  110
Content-Length: 0
008415: Dec 12 22:28:52.150 EET: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
LOGPRIGW#SIP/2.0 200 OK
CSeq: 5525 REGISTER
Contact: <22324086>;expires=110
Expires: 110
P-Associated-Uri: <>22324086@bbtb.cyta.com.cy>
Path: <10.224.42.164>
Content-Length: 0
LOGPRIGW#
008416: Dec 12 22:29:13.841 EET: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 101 INVITE
Content-Length: 0
008417: Dec 12 22:29:13.845 EET: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
008418: Dec 12 22:29:13.857 EET: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
008419: Dec 12 22:29:13.857 EET: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
008420: Dec 12 22:29:13.861 EET: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 500 Internal Server Error
Content-Length: 0
008421: Dec 12 22:29:13.869 EET: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
To: "22324086 22324086" <>22324086@bbtb.cyta.com.cy>;tag=3A1B0364-1764;cscf
CSeq: 140962635 ACK
Content-Length: 0
008422: Dec 12 22:29:13.881 EET: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
LOGPRIGW#
008423: Dec 12 22:29:13.881 EET: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
LOGPRIGW#
LOGPRIGW#
LOGPRIGW#
LOGPRIGW#
LOGPRIGW#
LOGPRIGW#un all
All possible debugging has been turned off
LOGPRIGW#
LOGPRIGW#ter
LOGPRIGW#terminal no mon
LOGPRIGW#terminal no monitor
LOGPRIGW#
LOGPRIGW#
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
Hi Chrysostomos,
Thanks for providing the debug log and config. It looks like the call is being sent out via the public address, so the sip agent which receives it may not be the CUCM, please refer to the following INVITE:
Sent:
To: <4086>
In order to force CUBE send call to CUCM properly, it's needed to specify the source interface under dial-peer 889 as below:
voice-class sip  bind control source-interface FastEthernet0/0
voice-class sip  bind media source-interface FastEthernet0/0
Please try this and let me know if it helps or not. If the issue persists, please send me "show version" output as well as debug of "debug ccsip message" and "debug voip ccapi inout".
Thanks and regards,
Robin
Not sure what IOS your CUBE is running.
Thank you for the answer
The current version that i have does not have bind commands under dial peer
Suggested version?
LOGPRIGW#show  version
Cisco IOS Software, 2800 Software (C2800NM-IPVOICEK9-M), Version 12.4(24)T8, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Sun 09-Sep-12 04:01 by prod_rel_team
ROM: System Bootstrap, Version 12.4(1r) [hqluong 1r], RELEASE SOFTWARE (fc1)
LOGPRIGW uptime is 1 week, 5 days, 2 hours, 12 minutes
System returned to ROM by reload at 15:38:24 EET Sat Dec 1 2012
System restarted at 15:41:04 EET Sat Dec 1 2012
System image file is "flash:c2800nm-ipvoicek9-mz.124-24.T8.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2811 (revision 53.51) with 249856K/12288K bytes of memory.
Processor board ID FCZ102070CZ
2 FastEthernet interfaces
31 Serial interfaces
1 Channelized/Clear E1/PRI port
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
LOGPRIGW#
Hi Chrysostomos,
Thanks for your update.
I would suggest to use c2800nm-ipvoicek9-mz.15.1(4)M4 or M5. Please try and let me know the result.
Robin
Hi Robin
Unfortunatelly the Same results
Now it looks ok the trace but we have again the same results
Via: SIP/2.0/UDP 192.168.1.246:5060;branch=z9hG4bK1B2502
voice-class codec 2
dtmf-relay rtp-nte
no vad
Max-Forwards: 8
Via: SIP/2.0/UDP 10.224.42.164:5060;branch=z9hG4bKp9rkm5vm4tu8hyutmwkutro23
From: <>99561400@fmc.cyta.com.cy;user=phone>;tag=h7g4Esbg_685420512-1355487921101-
Call-ID: BW142521101141212-2024609247@10.224.50.81
CSeq: 212869607 INVITE
Contact:
Min-Se: 600
P-Asserted-Identity: <>+35799561400@fmc.cyta.com.cy;user=phone>
Privacy: none
Content-Length: 229
v=0
o=BroadWorks 50138993 1 IN IP4 10.224.42.164
s=-
t=0 0
m=audio 21880 RTP/AVP 8 18 96 99
a=fmtp:99 0-15
a=ptime:20
000114: Dec 14 14:25:16.206 EET: //183/267E613880D7/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Fri, 14 Dec 2012 12:25:16 GMT
Content-Length: 0
000115: Dec 14 14:25:16.206 EET: //184/267E613880D7/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <4086>
Call-ID: 2682A6E9-452011E2-80DDA2D7-EF8FFC1@bbtb.cyta.com.cy
Min-SE:  1800
Cisco-Guid: 0645816632-1159729634-2161615575-0251199425
CSeq: 101 INVITE
Timestamp: 1355487916
Contact: <99561400>
Expires: 60
Max-Forwards: 7
Content-Length: 286
v=0
o=CiscoSystemsSIP-GW-UserAgent 8518 6473 IN IP4 192.168.1.246
s=SIP Call
c=IN IP4 192.168.1.246
t=0 0
m=audio 16586 RTP/AVP 8 18 101
a=fmtp:101 0-15
000116: Dec 14 14:25:16.698 EET: //184/267E613880D7/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <4086>
Min-SE:  1800
LOGPRIGW(config-dial-peer)#, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Contact: <99561400>
Expires: 60
Max-Forwards: 7
Content-Length: 286
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
000117: Dec 14 14:25:17.698 EET: //184/267E613880D7/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <4086>
Date: Fri, 14 Dec 2012 12:25:17 GMT
Min-SE:  1800
CSeq: 101 INVITE
Timestamp: 1355487917
Contact: <99561400>
Expires: 60
Max-Forwards: 7
Content-Length: 286
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
000118: Dec 14 14:25:19.714 EET: //183/267E613880D7/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 404 Not Found
To: "22324086 22324086" <>22324086@bbtb.cyta.com.cy>;cscf;tag=1E9F4C-F00
Reason: Q.850;cause=3
Content-Length: 0
000119: Dec 14 14:25:19.722 EET: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
To: "22324086 22324086" <>22324086@bbtb.cyta.com.cy>;tag=1E9F4C-F00;cscf
CSeq: 212869607 ACK
Content-Length: 0
Chrys,
Just to add to this discussion..
I noticed that there were 3 invites sent to CUCM, but the CUBE never got any response back from CUCM..
Finally CUBE sends a 404 not found and the cause code is 3 which means "no route to the destination"
Sent:
Content-Length: 0
You need to check that the CUBE has ip connectivity to the CUCM. You also need to check that your sip trunk from CUCM to CUBE has got the correct IP address of the CUBE.
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
Aokanlawon, thank you for helping answer the questions.
As you have pointed out, there is no response from CUCM for SIP INVITE due to connectivity isuse.
Chrys, to further check this, firstly check if CUBE can ping CUCM or not, then check if it can ping from the specific interface.
ping 192.168.1.242
ping 192.168.1.242 source 192.168.1.246
Also make sure if CUCM has sip service running and sip trunk configured properly.
Robin
yenlung
Hello Robin,
This is my customer scenairo.
There is 2 company using a same CUCM.
The CUCM is located in a shared Network where both Company could access.
However, between the 2 Company, there is no end to end connectivity between them.
For them to call each other via IP, can a CUBE helps to resolve this?
How should it be configured?
thanks
Yen Lung
Hi Yen Lung,
Thanks for your question.
In your case, what we need is an entity like MTP which can reach two seperate networks and bridge the RTP media streams.
Probabily adding a CUBE is the easiest way to achieve it. One CUBE is added in the shared network like CUCM and it will be reached by two companies. Thus the network diagram of calls between two companies would be:
Assume the extensions in company A and company B do not overlap. Some configuration you need to add on CUCM is as below:
1) add a sip trunk which pointing to CUBE's ip address in the shared network;
2) adjust the dialplan to route the call via sip trunk (CUBE) when phone A calls phone B, vise versa;
3) make sure the CSS of sip trunk's "Inbound Calls" can reach all extensions from company A and B.
Configuration on CUBE is simply, you just need to use dial-peers and route all calls to CUCM extensions back to CUCM.
Please let me know if you have any questions.
Robin
nanosynth
How do I enable SEND-RECEIVE SDP IN MID CALL INVITE?  CUCM7---SIP----2811CUBE----SIP---ITSP
I need to have this enabled in CUCM7. I see it's a function available in CUCM 8.6 GUI in the SIP trunk config, but not in CUCM7? . My call transfers are having one way audio issues. My SIP provider said to try to enable this fuction. How do I do it in CUCM7 or on my 2811 CUBE running c2800nm-adventerprisek9_ivs-mz.124-22.YB5
Thanks you very much!
Hi Nanosynth,
The option "Send send-receive SDP in mid-call INVITE" doesn't exist in CUCM7, so there is no way to enable it in CUCM7.
However even without this option the one way audio is able to be resolved by changing some parameter or applying sip profile on CUBE if needed.
In this case the running image has less features, so I would highly recommend to upgrade to 151-4.M5 first. If the issue is still there, please send me the "show tech" output as well as following debug logs:
debug ccsip message
I will help you further investigate if I get the infor requested above.
Thanks and regards,
Robin
Thank you for the quick response. I have c2800nm-adventerprisek9_ivs-mz.151-4.M4 (Thats the closest I can get to what you suggested), so I will load that and see if I can resolve my issues at my 2811 acting as CUBE.
Ayodeji Okanlawon
Hi Robin,
Recently I had an issue with re-invites and updates over a sip trunk routing calls to a uccx server. The re-invites were stopped using an MTP on the sip trunk. My question is what does mtp do here that stops the re-invite and why does it not stop the update.
Sent from Cisco Technical Support Android App
