12-11-2013 02:57 PM - edited 03-16-2019 08:49 PM
With Justin Dew
Welcome to the Cisco Support Community Ask the Expert conversation. This is an opportunity to learn and ask questions about integrating Cisco Unity Connection into your environment and troubleshooting the many features that are available with the Cisco Unity Connection voicemail solution .
Cisco Unity Connection is a voicemail and unified messaging platform with a comprehensive feature set and is based on the Linux unified communications operating system. With Cisco Unity Connection, you can access and manage voice messages in variety of ways, using your email inbox, web browser, the Cisco Jabber messaging integration platform, Cisco Unified IP Phone, smartphone, tablet, and more. Cisco expert Justin Dew will cover and answer all of your questions about Cisco Unity Connection.
Justin Dew is currently a member of the Applications TAC team in RTP NC. His area of expertise is in Cisco Unity connection and Cisco Unity. Justin has had six years of experience troubleshooting and working with voice products, including unified communications, Cisco Unity, presence, and Jabber in the TAC organization. He graduated with a bachelor's degree in electrical and computer engineering from Georgia Tech and has achieved certifications in CCVP and as a Domino administrator and Cisco Unity specialist.
Remember to use the rating system to let Justin know if you have received an adequate response.
Justin might not be able to answer each question due to the volume expected during this event. Remember that you can continue the conversation in Collaboration, Voice and Video, sub-community, IP Telephony discussion forum shortly after the event. This event lasts through December 20, 2013. Visit this forum often to view responses to your questions and the questions of other community members.
12-15-2013 07:28 PM
Hi Justin,
we are using UCXN 9.x
Is there any way we can configure multiple personal greetings like busy, No Answer ?
regds,
aman
12-16-2013 04:33 AM
Aman,
Yes. You have the option to configure the following personal greetings in UC 9.x:
Alternate
Busy
Internal
Closed
Standard
Holiday
These can be configured from the Unity connection administration page under the specific users profile by selecting Greetings or through the user interface accessible via the address http://
Hope this helps.
12-18-2013 09:38 AM
Actually ive tried installing with diferent teh CD and making other ISO and always brings back the same error!!
just one question how do i dump the diagnostics?
12-18-2013 09:42 AM
Hello Alonzo,
If it's virtualized environment you can use the following link:
http://docwiki.cisco.com/wiki/How_to_Dump_Install_Logs_to_the_Serial_Port_of_the_Virtual_Machine
-Regards
DA\|*D
12-18-2013 10:22 AM
Thanks this is teh dump it gave me
12-18-2013 10:28 AM
Yeah its up there its 1.3 MB
12-18-2013 10:46 AM
Here is the last page of the install log, hope you can help me!!!!!
Thanks so much
Tue Dec 17 13:49:13 CST 2013 + sudo -u cucluster ssh cuc-sub ' sh -lc '\''source /opt/cisco/connection/lib/install/profile && dbaccess' 'unitydyndb'\'''
Tue Dec 17 13:49:13 CST 2013 Database selected.
Tue Dec 17 13:49:13 CST 2013 Table truncated.
Tue Dec 17 13:49:13 CST 2013 Database closed.
Tue Dec 17 13:49:13 CST 2013 + set -e
Tue Dec 17 13:49:13 CST 2013 + [[ -n yes ]]
Tue Dec 17 13:49:13 CST 2013 + target_exec /opt/cisco/connection/lib/config-modules/dbscripts/repl-helper define_replication
Tue Dec 17 13:49:13 CST 2013 + sudo -u cucluster ssh cuc-sub ' sh -lc '\''source /opt/cisco/connection/lib/install/profile && /opt/cisco/connection/lib/config-modules/dbscripts/repl-helper' 'define_replication'\'''
Tue Dec 17 13:49:14 CST 2013 + command=define_replication
Tue Dec 17 13:49:14 CST 2013 + shift
Tue Dec 17 13:49:14 CST 2013 + grep -qs 'define_replication()' /opt/cisco/connection/lib/replication.profile
Tue Dec 17 13:49:14 CST 2013 + set +x
Tue Dec 17 13:49:14 CST 2013 + define_replication
Tue Dec 17 13:49:14 CST 2013 + define_servers
Tue Dec 17 13:49:14 CST 2013 + local 'define_server_opts=-A /var/opt/cisco/connection/spool/ats/'
Tue Dec 17 13:49:14 CST 2013 + sudo_informix cdr define server -A /var/opt/cisco/connection/spool/ats/ -c g_ciscounity_pub -I g_ciscounity_pub
Tue Dec 17 13:49:14 CST 2013 + [[ cucluster != \i\n\f\o\r\m\i\x ]]
Tue Dec 17 13:49:14 CST 2013 + sudo -u informix cdr define server -A /var/opt/cisco/connection/spool/ats/ -c g_ciscounity_pub -I g_ciscounity_pub
Tue Dec 17 13:52:34 CST 2013 command failed -- fatal server error (100)
Tue Dec 17 13:52:34 CST 2013 + LOADDBRC=100
Tue Dec 17 13:52:34 CST 2013 + '[' 100 -ne 0 ']'
Tue Dec 17 13:52:34 CST 2013 + echo 'loaddb.sh return code was 100'
Tue Dec 17 13:52:34 CST 2013 loaddb.sh return code was 100
Tue Dec 17 13:52:34 CST 2013 + exit 1
Tue Dec 17 13:52:34 CST 2013 /opt/cisco/connection/lib/install/post.d/06_load-database had an exit code of 1
12-18-2013 11:24 AM
Alonzo,
Looks like you are most likely hitting the following defect:
you will need to open a tac case so the workaround can be performed by a TAC engineer.
Hope this helps.
12-18-2013 11:31 AM
Did you where able to see the files?? if not i extracted them and i can send them to you on ZIP,
The thing is i cant open a case becouse i dont have a support contract the partner of cisco how sell them gave us that provilage do you know how can i work that around??
thanks a lot
12-18-2013 11:44 AM
I was able to find the defect from the install log portion you posted.
As for the fix the only other way without tac support would be to upgrade to the UC version that does not encounter this defect. Then the subscriber should install without failure.
12-18-2013 11:13 AM
Alonzo,
It had not fully loaded for me, thanks for the confirmation. After checking the file all i see is unreadable characters, did you make sure to create a new file:
"When you're ready to actually dump the log files, attach a new, empty file to the serial port by editing settings of the VM while the machine is running. You do not have to power down the VM to change the file attached to the serial port. "
DA\|*D
12-18-2013 12:53 PM
Great thanks for everything!!!!!!
12-16-2013 02:46 AM
Hi Justin-
Would you care to weigh in on SCCP vs. SIP and which is the recommended protocol in current versions? There seems to be a bit of a religion around SCCP but having done a few SIP integrations now, it seems like the easier/cleaner choice. I am curious to hear TAC's stance on this one. I am aware of the supervised transfer MoH limitation with SIP. Are there others?
On a related note, are you aware of any limitations with DIGEST Authentication? I had to turn it off after testing it because peripheral features such as Message Notifications and I believe MWIs weren't working consistantly.
12-16-2013 04:48 AM
Hi Justin,
thanks for reply.
One more query : is it possible to have a personalised recorded message which can be activated/de-activated by user as and when required?
please let me know the steps.
regds,
aman
