ATA 186 CUCM version 11
johnsnave1
is the ATA 186 supported on CUCM version 11? If not, which similar product is supported?
Many thanks, John.
Brandon Buffin
According to the following link, the ATA 186 was compatible with 10.x, but was not tested or guaranteed full support - http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/compat/10_x/cucm_b_compatibility-matrix-cucm-imp-10x.html#CUCM_RF_C0D1197F_00
The compatibility matrix for 11.x does not specifically mention the 186. However, it is not listed in the deprecated phone models section. There is also this note:
"Unless they are specified in the "Deprecated Phone Models" list, phone models that are End of Software Maintenance will continue to be supported on the latest Unified Communications Manager releases. However, they will not take advantage of any new Unified Communications Manager or firmware features associated with that release."
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/compat/11_x/cucm_b_cucm-imp-compatibility-matrix-11x.html#CUCM_TP_CD8082BB_00
So, it appears that it is supported, but has not been fully tested.
Brandon
13 Replies 13
Brandon Buffin
Brandon
Hi Guys,
I've just upgraded/migrated a customer from 6.1.3 to 11.5, and everything has worked except the ATA186s. I cannot get them to register with CUCM. I've tried forcing the TFTP to the new server, but it still fails.
Current version of ATA is 2.14, and the version in device defaults is 3.2.4. I have tried to reinstall the cop file for this, but get the error saying it's not compatible with this version.
Has anyone actually got one working on 11.5 yet?
Glyn
Glyn,
It's possible you're running into this bug:
https://quickview.cloudapps.cisco.com/quickview/bug/CSCsd44357
Take a look at the following post for a couple of options to work around the issue:
https://supportforums.cisco.com/document/12432201/manual-firmware-upgrade-ata-186
Brandon
Top man Brandon. Luckily I had the old cluster running 6.1.3 still powered up. Put the latest firmware on it, swung the ATAs over, let them upgrade, swung them back to the new cluster and all working.
Thanks...you saved my bacon.
johnsnave1
Many thanks Brandon, this is pretty well what I found but was not too confident.
Thanks again.
Gordon Ross
Level 9
Level 9
The ATA 186 works very nicely under CUCM 11.0. The current equivalent product to the ATA186 is the ATA190.
GTG
Please rate all helpful posts.
Many thanks Gordon - good news.
Gordon,
What firmware version are your ATA's running? Getting prepared for a CUCM 8x to 11x upgrade and looking over all my loaded firmware.
Current - 3.2.3 - ATA030203SCCP051201A
Latest - 3.2.4 - ATA030204SCCP090202A
Thanks!
Joey
I'm running ATA030204SCCP090202A
GTG
fcmvieira
Hi, Is the ATA 186 is supported on cucm 12 ?
Yes, as stated before, only devices that show as deprecated devices on the 11.5 and 12.0 RN have been removed from the drop-down.
java
if this helps, please rate
Mohamed Haneefa
Hi Kennett
Am facing the same which you had discussed above.
CUCM was migrated from 6.5 to 11.5, all phones are working fine in 11.5, except ATA 186 for fax service.
Current version of ATA-186 in 6.5 is  ATA030204SCCP090202A , but  it is registered as unknown in 11.5
let me know about the firmware which you had uploaded in 6.5 for ATA 186 ...
appreciated your response in this regards
Mohamed Haneefa
Hi Kennett
