ATA 190
I have issue with ATA 190
Fax device can send but cannot receive any massage
the issue with incoming
Note:the normal incoming call is fine
Mohammed al Baqari
VIP Advisor VIP Advisor
VIP Advisor
Is it CME or CUCM deployment. ?
Try fax pass-through on the gateway and see if it works
CUCM
Do you have any logs ? The voice router, is it a CUBE or a TDM termination ? Do you receive any errors on the fax machine ?
Nipun Singh Raghav
"We cannot solve our problems with the same thinking we used when we created them"
Sreekanth Narayanan
It would be helpful if you could provide a call flow of this fax call, like
PSTN ---- pri ---- GW --- sip --- CUCM --- sip --- ATA190.
Please also provide us the configuration of the dial-peer on your gateway. Based on this information we will be able to tell you if the config is perfect for fax.
Recognize Your Peers
