IP Telephony and Phones
Labels
Hi,   What are the difference between these voicemail PIN settings in CUC -Cisco Unity Connection ? -Locked by Administrator -User Cannot Change -User must change on the next Sign-in -Does not expire    When are we using each?   Thank you.
MaryGrace by Level 1
  • 1491 Views
  • 3 replies
Inbound Call PSTN>>>CUBE>>>CUCM (Sub1and Sub2 in DC1, Sub3 and Sub4 in DC2) INVITE comes into cube from carrier CUBE sends invite to Sub1....no response CUBE sends invite to Sub1....no response   I then set a DP to send calls to Sub3 and Sub4 INVITE ...
I have a 8845 phone with a line that is cfw to voicemail using CUCM 11.5.  The MWI for the line does not show unless you take the line off of forward.  My 7841 phone will indicate a voicemail while CFW is in place, but not the 8845?  Not talking the ...
AT by Level 1
  • 656 Views
  • 2 replies
Anyone do TFTP file encryption with SRST and have any caveats or items that didn't work as expected.    Added bonus if you can tell me exactly what is exchanged between Phones and SRST so they can register. They clearly don't send the XML file to the...
When a caller is placed into the native queue you do not hear the initial announcement or MOH.  The queue works correctly, just don't hear any prompts.  This did work during initial setup, but stopped for some reason.  Has not been put into productio...
AT by Level 1
  • 625 Views
  • 2 replies
I need to know the design requirements involved while designing solutions to the client based on the number of users. i.e., Design of IP telephony requirement for 10, 20, 30, 40, 50, ........ different users. Like which router, Switch, IP Phone, Voic...
SYEDIRFAN by Level 1
  • 348 Views
  • 1 replies
