03-20-2013 09:16 AM - edited 03-16-2019 04:21 PM
Hi Guys,
My Customer have a solution with CUCM 8.6.2 and is having the following problem: When the user to do the call for PSTN (using FXO interface), the user side B (called) pickup the call, but, the audio start only after 15 seconds. The user that is in the site A hear the user site B speaking, but, the audio for both only start 15 seconds after. Any have Idea about this? I suspected about the codec, but, and didn´t found error.
Wilson
03-20-2013 10:08 AM
it is weird one. is it happenned for all phones or at specific type ?
regards
Anas
03-20-2013 10:20 AM
Hi Anas,
The problem is aleatory and occur with any user and any IP Phone, but, only when the call is did for PSTN.
Wilson
03-20-2013 10:35 AM
try this debug while simulating the issue
debug voip ccapi inout
Also plz confirm no routing nor security issue could exist here
Haitham
03-20-2013 11:08 AM
Hi Haithan,
Hi tryied attach the log, but, I didn´t found the option. Follow the logs below:
Calling Number - cisco-ani=1811032010
Called Number - dest=00151833669800
Wed Mar 20 09:07:35 2013: <191>160919: .Mar 20 09:07:33: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode:
Wed Mar 20 09:07:35 2013: <191>160920: ccAppShutdownMode: remove it from the queue
Wed Mar 20 09:07:52 2013: <190>160921: .Mar 20 09:07:50: %IPPHONE-6-UNREGISTER_NORMAL: ephone-8:SEP002699441EB7 IP:10.229.64.43 Socket:5 DeviceType:Phone has unregistered normally.
Wed Mar 20 09:09:32 2013: <190>160922: .Mar 20 09:09:30: %IPPHONE-6-REGISTER_NEW: ephone-11:SEP002699441929 IP:10.229.64.33 Socket:5 DeviceType:Phone has registered.
Wed Mar 20 09:09:47 2013: <191>160923: .Mar 20 09:09:46: //-1/E3FCE46DB3A5/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:09:47 2013: <191>160924: cc_api_call_setup_ind_common:
Wed Mar 20 09:09:47 2013: <191>160925: cisco-username=
Wed Mar 20 09:09:47 2013: <191>160926: ----- ccCallInfo IE subfields -----
Wed Mar 20 09:09:47 2013: <191>160927: cisco-ani=1811032013
Wed Mar 20 09:09:47 2013: <191>160928: cisco-anitype=0
Wed Mar 20 09:09:47 2013: <191>160929: cisco-aniplan=0
Wed Mar 20 09:09:47 2013: <191>160930: cisco-anipi=0
Wed Mar 20 09:09:47 2013: <191>160931: cisco-anisi=0
Wed Mar 20 09:09:47 2013: <191>160932: dest=
Wed Mar 20 09:09:47 2013: <191>160933: cisco-desttype=0
Wed Mar 20 09:09:47 2013: <191>160934: cisco-destplan=0
Wed Mar 20 09:09:47 2013: <191>160935: cisco-rdie=FFFFFFFF
Wed Mar 20 09:09:47 2013: <191>160936: cisco-rdn=
Wed Mar 20 09:09:47 2013: <191>160937: cisco-lastrdn=
Wed Mar 20 09:09:47 2013: <191>160938: cisco-rdntype=0
Wed Mar 20 09:09:47 2013: <191>160939: cisco-rdnplan=0
Wed Mar 20 09:09:47 2013: <191>160940: cisco-rdnpi=0
Wed Mar 20 09:09:47 2013: <191>160941: cisco-rdnsi=0
Wed Mar 20 09:09:47 2013: <191>160942: cisco-redirectreason=0 fwd_final_type =0
Wed Mar 20 09:09:47 2013: <191>160943: final_redirectNumber =
Wed Mar 20 09:09:47 2013: <191>160944: hunt_group_timeout =0
Wed Mar 20 09:09:47 2013: <191>160945:
Wed Mar 20 09:09:47 2013: <191>160946: .Mar 20 09:09:46: //-1/E3FCE46DB3A5/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:09:47 2013: <191>160947:
Wed Mar 20 09:09:47 2013: <191>160948: Interface=0x4B805B90, Call Info(
Wed Mar 20 09:09:47 2013: <191>160949: Calling Number=1811032013,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:09:47 2013: <191>160950: Called Number=(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:09:47 2013: <191>160951: Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Wed Mar 20 09:09:47 2013: <191>160952: Incoming Dial-peer=20015, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Wed Mar 20 09:09:47 2013: <191>160953: Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:09:47 2013: <191>160954: .Mar 20 09:09:46: //-1/E3FCE46DB3A5/CCAPI/ccCheckClipClir:
Wed Mar 20 09:09:47 2013: <191>160955: In: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:09:47 2013: <191>160956: .Mar 20 09:09:46: //-1/E3FCE46DB3A5/CCAPI/ccCheckClipClir:
Wed Mar 20 09:09:47 2013: <191>160957: Out: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:09:47 2013: <191>160958: .Mar 20 09:09:46: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:09:47 2013: <191>160959:
Wed Mar 20 09:09:47 2013: <191>160960: .Mar 20 09:09:46: :cc_get_feature_vsa malloc success
Wed Mar 20 09:09:47 2013: <191>160961: .Mar 20 09:09:46: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:09:47 2013: <191>160962:
Wed Mar 20 09:09:47 2013: <191>160963: .Mar 20 09:09:46: cc_get_feature_vsa count is 1
Wed Mar 20 09:09:47 2013: <191>160964: .Mar 20 09:09:46: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:09:47 2013: <191>160965:
Wed Mar 20 09:09:47 2013: <191>160966: .Mar 20 09:09:46: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203248360,feature_id:8130
Wed Mar 20 09:09:47 2013: <191>160967: .Mar 20 09:09:46: //8130/E3FCE46DB3A5/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:09:47 2013: <191>160968:
Wed Mar 20 09:09:47 2013: <191>160969: Set Up Event Sent;
Wed Mar 20 09:09:47 2013: <191>160970: Call Info(Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:09:47 2013: <191>160971: Called Number=(TON=Unknown, NPI=Unknown))
Wed Mar 20 09:09:47 2013: <191>160974: .Mar 20 09:09:46: //8130/E3FCE46DB3A5/CCAPI/ccCallSetContext:
Wed Mar 20 09:09:47 2013: <191>160975: Context=0x4BA6C148
Wed Mar 20 09:09:47 2013: <191>160976: .Mar 20 09:09:46: //8130/E3FCE46DB3A5/CCAPI/cc_process_call_setup_ind:
Wed Mar 20 09:09:47 2013: <191>160977: >>>>CCAPI handed cid 8130 with tag 20015 to app "_ManagedAppProcess_Default"
Wed Mar 20 09:09:47 2013: <191>160978: .Mar 20 09:09:46: //8130/E3FCE46DB3A5/CCAPI/ccCallSetupAck:
Wed Mar 20 09:09:47 2013: <191>160979: Call Id=8130
Wed Mar 20 09:09:47 2013: <191>160980: .Mar 20 09:09:46: //8130/E3FCE46DB3A5/CCAPI/cc_api_set_transfer_info:
Wed Mar 20 09:09:47 2013: <191>160981:
Wed Mar 20 09:09:47 2013: <191>160985: Tone Direction=Network, Params=0x0, Call Id=8130
Wed Mar 20 09:09:47 2013: <191>160986: .Mar 20 09:09:46: //8130/E3FCE46DB3A5/CCAPI/ccSetDigitTimeouts:
Wed Mar 20 09:09:47 2013: <191>160987: Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
Wed Mar 20 09:09:47 2013: <191>160988: .Mar 20 09:09:46: //8130/E3FCE46DB3A5/CCAPI/ccSetDigitTimeouts:
Wed Mar 20 09:09:48 2013: <191>160994: Enabled=TRUE, Call Id=8130
Wed Mar 20 09:09:48 2013: <191>160995: .Mar 20 09:09:46: //8130/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:09:48 2013: <191>160996: (vdbPtr=0x4B805B90, callID=0x1FC2, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Wed Mar 20 09:09:48 2013: <191>160997: .Mar 20 09:09:46: //8130/E3FCE46DB3A5/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:09:48 2013: <191>160998: Enabled=TRUE, Disposition=0x0, Interface=0x4B805B90, Call Id=8130
Wed Mar 20 09:09:48 2013: <191>160999: .Mar 20 09:09:46: //8130/E3FCE46DB3A5/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:09:48 2013: <191>161000: Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=8000(ms))
Wed Mar 20 09:09:50 2013: <191>161001: .Mar 20 09:09:49: //8130/E3FCE46DB3A5/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:09:50 2013: <191>161002: Cause Value=16, Interface=0x4B805B90, Call Id=8130
Wed Mar 20 09:09:50 2013: <191>161003: .Mar 20 09:09:49: //8130/E3FCE46DB3A5/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:09:50 2013: <191>161004: Call Entry(Responsed=FALSE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:09:50 2013: <191>161005: .Mar 20 09:09:49: //8130/E3FCE46DB3A5/CCAPI/ccCallDisconnect:
Wed Mar 20 09:09:50 2013: <191>161006: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:09:50 2013: <191>161007: .Mar 20 09:09:49: //8130/E3FCE46DB3A5/CCAPI/ccCallDisconnect:
Wed Mar 20 09:09:50 2013: <191>161008: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:09:50 2013: <191>161009: .Mar 20 09:09:49: //8130/E3FCE46DB3A5/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:09:50 2013: <191>161010: Transfer Number Is Null
Wed Mar 20 09:09:51 2013: <191>161011: .Mar 20 09:09:49: //8130/E3FCE46DB3A5/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:09:51 2013: <191>161012: Disposition=0, Interface=0x4B805B90, Tag=0x0, Call Id=8130,
Wed Mar 20 09:09:51 2013: <191>161013: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:09:51 2013: <191>161014: .Mar 20 09:09:49: //8130/E3FCE46DB3A5/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:09:51 2013: <191>161015: Call Disconnect Event Sent
Wed Mar 20 09:09:51 2013: <191>161016: .Mar 20 09:09:49: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:09:51 2013: <191>161017:
Wed Mar 20 09:09:51 2013: <191>161018: .Mar 20 09:09:49: :cc_free_feature_vsa freeing 47B81CE0
Wed Mar 20 09:09:51 2013: <191>161019: .Mar 20 09:09:49: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:09:51 2013: <191>161020:
Wed Mar 20 09:09:51 2013: <191>161021: .Mar 20 09:09:49: vsacount in free is 0
Wed Mar 20 09:10:17 2013: <191>161022: .Mar 20 09:10:16: //-1/F5B82C11B3A9/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:10:17 2013: <191>161023: cc_api_call_setup_ind_common:
Wed Mar 20 09:10:17 2013: <191>161024: cisco-username=
Wed Mar 20 09:10:17 2013: <191>161025: ----- ccCallInfo IE subfields -----
Wed Mar 20 09:10:17 2013: <191>161026: cisco-ani=1811032013
Wed Mar 20 09:10:17 2013: <191>161027: cisco-anitype=0
Wed Mar 20 09:10:17 2013: <191>161028: cisco-aniplan=0
Wed Mar 20 09:10:17 2013: <191>161029: cisco-anipi=0
Wed Mar 20 09:10:17 2013: <191>161030: cisco-anisi=0
Wed Mar 20 09:10:17 2013: <191>161031: dest=
Wed Mar 20 09:10:17 2013: <191>161032: cisco-desttype=0
Wed Mar 20 09:10:17 2013: <191>161033: cisco-destplan=0
Wed Mar 20 09:10:17 2013: <191>161034: cisco-rdie=FFFFFFFF
Wed Mar 20 09:10:17 2013: <191>161035: cisco-rdn=
Wed Mar 20 09:10:17 2013: <191>161036: cisco-lastrdn=
Wed Mar 20 09:10:17 2013: <191>161037: cisco-rdntype=0
Wed Mar 20 09:10:17 2013: <191>161038: cisco-rdnplan=0
Wed Mar 20 09:10:17 2013: <191>161039: cisco-rdnpi=0
Wed Mar 20 09:10:17 2013: <191>161040: cisco-rdnsi=0
Wed Mar 20 09:10:17 2013: <191>161041: cisco-redirectreason=0 fwd_final_type =0
Wed Mar 20 09:10:17 2013: <191>161042: final_redirectNumber =
Wed Mar 20 09:10:17 2013: <191>161043: hunt_group_timeout =0
Wed Mar 20 09:10:17 2013: <191>161044:
Wed Mar 20 09:10:17 2013: <191>161045: .Mar 20 09:10:16: //-1/F5B82C11B3A9/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:10:17 2013: <191>161046:
Wed Mar 20 09:10:17 2013: <191>161047: Interface=0x4B805B90, Call Info(
Wed Mar 20 09:10:17 2013: <191>161048: Calling Number=1811032013,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:10:17 2013: <191>161049: Called Number=(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:10:17 2013: <191>161050: Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Wed Mar 20 09:10:17 2013: <191>161051: Incoming Dial-peer=20015, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Wed Mar 20 09:10:17 2013: <191>161052: Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:10:17 2013: <191>161053: .Mar 20 09:10:16: //-1/F5B82C11B3A9/CCAPI/ccCheckClipClir:
Wed Mar 20 09:10:17 2013: <191>161054: In: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:10:17 2013: <191>161055: .Mar 20 09:10:16: //-1/F5B82C11B3A9/CCAPI/ccCheckClipClir:
Wed Mar 20 09:10:17 2013: <191>161056: Out: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:10:17 2013: <191>161057: .Mar 20 09:10:16: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:10:17 2013: <191>161058:
Wed Mar 20 09:10:17 2013: <191>161059: .Mar 20 09:10:16: :cc_get_feature_vsa malloc success
Wed Mar 20 09:10:17 2013: <191>161060: .Mar 20 09:10:16: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:10:17 2013: <191>161061:
Wed Mar 20 09:10:17 2013: <191>161062: .Mar 20 09:10:16: cc_get_feature_vsa count is 1
Wed Mar 20 09:10:17 2013: <191>161063: .Mar 20 09:10:16: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:10:17 2013: <191>161064:
Wed Mar 20 09:10:17 2013: <191>161065: .Mar 20 09:10:16: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203248360,feature_id:8131
Wed Mar 20 09:10:17 2013: <191>161066: .Mar 20 09:10:16: //8131/F5B82C11B3A9/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:10:17 2013: <191>161067:
Wed Mar 20 09:10:17 2013: <191>161068: Set Up Event Sent;
Wed Mar 20 09:10:17 2013: <191>161069: Call Info(Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:10:17 2013: <191>161070: Called Number=(TON=Unknown, NPI=Unknown))
Wed Mar 20 09:10:17 2013: <191>161071: .Mar 20 09:10:16: //8131/F5B82C11B3A9/CCAPI/cc_process_call_setup_ind:
Wed Mar 20 09:10:17 2013: <191>161072: Event=0x4982FA50
Wed Mar 20 09:10:17 2013: <191>161090: (callID=0x1FC3, digit_event=0x1, enable=TRUE, consume=FALSE)
Wed Mar 20 09:10:17 2013: <191>161091: .Mar 20 09:10:16: //8131/F5B82C11B3A9/CCAPI/ccCallReportDigits:
Wed Mar 20 09:10:17 2013: <191>161092:
Wed Mar 20 09:10:18 2013: <191>161093: Enabled=TRUE, Call Id=8131
Wed Mar 20 09:10:18 2013: <191>161094: .Mar 20 09:10:16: //8131/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:10:18 2013: <191>161095: (vdbPtr=0x4B805B90, callID=0x1FC3, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Wed Mar 20 09:10:18 2013: <191>161096: .Mar 20 09:10:16: //8131/F5B82C11B3A9/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:10:18 2013: <191>161097: Enabled=TRUE, Disposition=0x0, Interface=0x4B805B90, Call Id=8131
Wed Mar 20 09:10:18 2013: <191>161098: .Mar 20 09:10:16: //8131/F5B82C11B3A9/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:10:18 2013: <191>161099: Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=8000(ms))
Wed Mar 20 09:10:26 2013: <191>161100: .Mar 20 09:10:25: //8131/F5B82C11B3A9/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:10:26 2013: <191>161101: Cause Value=16, Interface=0x4B805B90, Call Id=8131
Wed Mar 20 09:10:26 2013: <191>161102: .Mar 20 09:10:25: //8131/F5B82C11B3A9/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:10:26 2013: <191>161103: Call Entry(Responsed=FALSE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:10:26 2013: <191>161104: .Mar 20 09:10:25: //8131/F5B82C11B3A9/CCAPI/ccCallDisconnect:
Wed Mar 20 09:10:26 2013: <191>161105: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:10:26 2013: <191>161106: .Mar 20 09:10:25: //8131/F5B82C11B3A9/CCAPI/ccCallDisconnect:
Wed Mar 20 09:10:26 2013: <191>161107: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:10:26 2013: <191>161108: .Mar 20 09:10:25: //8131/F5B82C11B3A9/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:10:26 2013: <191>161109: Transfer Number Is Null
Wed Mar 20 09:10:27 2013: <191>161110: .Mar 20 09:10:25: //8131/F5B82C11B3A9/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:10:27 2013: <191>161111: Disposition=0, Interface=0x4B805B90, Tag=0x0, Call Id=8131,
Wed Mar 20 09:10:27 2013: <191>161112: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:10:27 2013: <191>161113: .Mar 20 09:10:25: //8131/F5B82C11B3A9/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:10:27 2013: <191>161114: Call Disconnect Event Sent
Wed Mar 20 09:10:27 2013: <191>161115: .Mar 20 09:10:25: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:10:27 2013: <191>161116:
Wed Mar 20 09:10:27 2013: <191>161117: .Mar 20 09:10:25: :cc_free_feature_vsa freeing 47B81CE0
Wed Mar 20 09:10:27 2013: <191>161118: .Mar 20 09:10:25: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:10:27 2013: <191>161119:
Wed Mar 20 09:10:27 2013: <191>161120: .Mar 20 09:10:25: vsacount in free is 0
Wed Mar 20 09:10:28 2013: <191>161121: .Mar 20 09:10:27: //-1/FC6BE765B3AD/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:10:28 2013: <191>161122: cc_api_call_setup_ind_common:
Wed Mar 20 09:10:28 2013: <191>161123: cisco-username=
Wed Mar 20 09:10:28 2013: <191>161124: ----- ccCallInfo IE subfields -----
Wed Mar 20 09:10:28 2013: <191>161125: cisco-ani=1811032013
Wed Mar 20 09:10:28 2013: <191>161126: cisco-anitype=0
Wed Mar 20 09:10:28 2013: <191>161127: cisco-aniplan=0
Wed Mar 20 09:10:28 2013: <191>161128: cisco-anipi=0
Wed Mar 20 09:10:28 2013: <191>161129: cisco-anisi=0
Wed Mar 20 09:10:28 2013: <191>161130: dest=
Wed Mar 20 09:10:28 2013: <191>161131: cisco-desttype=0
Wed Mar 20 09:10:28 2013: <191>161132: cisco-destplan=0
Wed Mar 20 09:10:28 2013: <191>161133: cisco-rdie=FFFFFFFF
Wed Mar 20 09:10:28 2013: <191>161134: cisco-rdn=
Wed Mar 20 09:10:28 2013: <191>161135: cisco-lastrdn=
Wed Mar 20 09:10:28 2013: <191>161136: cisco-rdntype=0
Wed Mar 20 09:10:28 2013: <191>161137: cisco-rdnplan=0
Wed Mar 20 09:10:28 2013: <191>161138: cisco-rdnpi=0
Wed Mar 20 09:10:28 2013: <191>161139: cisco-rdnsi=0
Wed Mar 20 09:10:28 2013: <191>161140: cisco-redirectreason=0 fwd_final_type =0
Wed Mar 20 09:10:28 2013: <191>161141: final_redirectNumber =
Wed Mar 20 09:10:28 2013: <191>161142: hunt_group_timeout =0
Wed Mar 20 09:10:28 2013: <191>161143:
Wed Mar 20 09:10:28 2013: <191>161144: .Mar 20 09:10:27: //-1/FC6BE765B3AD/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:10:28 2013: <191>161145:
Wed Mar 20 09:10:28 2013: <191>161146: Interface=0x4B805B90, Call Info(
Wed Mar 20 09:10:28 2013: <191>161147: Calling Number=1811032013,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:10:28 2013: <191>161148: Called Number=(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:10:28 2013: <191>161149: Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Wed Mar 20 09:10:28 2013: <191>161150: Incoming Dial-peer=20015, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Wed Mar 20 09:10:28 2013: <191>161151: Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:10:28 2013: <191>161152: .Mar 20 09:10:27: //-1/FC6BE765B3AD/CCAPI/ccCheckClipClir:
Wed Mar 20 09:10:28 2013: <191>161153: In: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:10:28 2013: <191>161154: .Mar 20 09:10:27: //-1/FC6BE765B3AD/CCAPI/ccCheckClipClir:
Wed Mar 20 09:10:28 2013: <191>161155: Out: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:10:28 2013: <191>161156: .Mar 20 09:10:27: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:10:28 2013: <191>161157:
Wed Mar 20 09:10:28 2013: <191>161158: .Mar 20 09:10:27: :cc_get_feature_vsa malloc success
Wed Mar 20 09:10:28 2013: <191>161159: .Mar 20 09:10:27: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:10:28 2013: <191>161160:
Wed Mar 20 09:10:28 2013: <191>161161: .Mar 20 09:10:27: cc_get_feature_vsa count is 1
Wed Mar 20 09:10:28 2013: <191>161162: .Mar 20 09:10:27: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:10:28 2013: <191>161163:
Wed Mar 20 09:10:28 2013: <191>161164: .Mar 20 09:10:27: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203326024,feature_id:8132
Wed Mar 20 09:10:28 2013: <191>161165: .Mar 20 09:10:27: //8132/FC6BE765B3AD/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:10:28 2013: <191>161166:
Wed Mar 20 09:10:28 2013: <191>161168: Call Info(Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:10:28 2013: <191>161169: Called Number=(TON=Unknown, NPI=Unknown))
Wed Mar 20 09:10:28 2013: <191>161172: .Mar 20 09:10:27: //8132/FC6BE765B3AD/CCAPI/ccCallSetContext:
Wed Mar 20 09:10:28 2013: <191>161173: Context=0x4BA67528
Wed Mar 20 09:10:28 2013: <191>161181: .Mar 20 09:10:27: //8132/FC6BE765B3AD/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:10:28 2013: <191>161182: Stop Tone On Digit=TRUE, Tone=Dial Tone,
Wed Mar 20 09:10:28 2013: <191>161183: Tone Direction=Network, Params=0x0, Call Id=8132
Wed Mar 20 09:10:28 2013: <191>161184: .Mar 20 09:10:27: //8132/FC6BE765B3AD/CCAPI/ccSetDigitTimeouts:
Wed Mar 20 09:10:29 2013: <191>161192: Enabled=TRUE, Call Id=8132
Wed Mar 20 09:10:29 2013: <191>161193: .Mar 20 09:10:27: //8132/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:10:29 2013: <191>161194: (vdbPtr=0x4B805B90, callID=0x1FC4, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Wed Mar 20 09:10:29 2013: <191>161195: .Mar 20 09:10:27: //8132/FC6BE765B3AD/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:10:29 2013: <191>161196: Enabled=TRUE, Disposition=0x0, Interface=0x4B805B90, Call Id=8132
Wed Mar 20 09:10:29 2013: <191>161197: .Mar 20 09:10:27: //8132/FC6BE765B3AD/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:10:29 2013: <191>161198: Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=8000(ms))
Wed Mar 20 09:10:38 2013: <191>161199: .Mar 20 09:10:37: //8132/FC6BE765B3AD/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:10:38 2013: <191>161200: Cause Value=16, Interface=0x4B805B90, Call Id=8132
Wed Mar 20 09:10:38 2013: <191>161201: .Mar 20 09:10:37: //8132/FC6BE765B3AD/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:10:38 2013: <191>161202: Call Entry(Responsed=FALSE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:10:38 2013: <191>161203: .Mar 20 09:10:37: //8132/FC6BE765B3AD/CCAPI/ccCallDisconnect:
Wed Mar 20 09:10:38 2013: <191>161204: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:10:38 2013: <191>161205: .Mar 20 09:10:37: //8132/FC6BE765B3AD/CCAPI/ccCallDisconnect:
Wed Mar 20 09:10:38 2013: <191>161206: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:10:38 2013: <191>161207: .Mar 20 09:10:37: //8132/FC6BE765B3AD/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:10:38 2013: <191>161208: Transfer Number Is Null
Wed Mar 20 09:10:39 2013: <191>161209: .Mar 20 09:10:37: //8132/FC6BE765B3AD/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:10:39 2013: <191>161210: Disposition=0, Interface=0x4B805B90, Tag=0x0, Call Id=8132,
Wed Mar 20 09:10:39 2013: <191>161211: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:10:39 2013: <191>161212: .Mar 20 09:10:37: //8132/FC6BE765B3AD/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:10:39 2013: <191>161213: Call Disconnect Event Sent
Wed Mar 20 09:10:39 2013: <191>161214: .Mar 20 09:10:37: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:10:39 2013: <191>161215:
Wed Mar 20 09:10:39 2013: <191>161216: .Mar 20 09:10:37: :cc_free_feature_vsa freeing 47B94C40
Wed Mar 20 09:10:39 2013: <191>161217: .Mar 20 09:10:37: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:10:39 2013: <191>161218:
Wed Mar 20 09:10:39 2013: <191>161219: .Mar 20 09:10:37: vsacount in free is 0
Wed Mar 20 09:10:40 2013: <191>161220: .Mar 20 09:10:39: //-1/035C1122B3B1/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:10:40 2013: <191>161221: cc_api_call_setup_ind_common:
Wed Mar 20 09:10:40 2013: <191>161222: cisco-username=
Wed Mar 20 09:10:40 2013: <191>161223: ----- ccCallInfo IE subfields -----
Wed Mar 20 09:10:40 2013: <191>161224: cisco-ani=1811032013
Wed Mar 20 09:10:40 2013: <191>161225: cisco-anitype=0
Wed Mar 20 09:10:40 2013: <191>161226: cisco-aniplan=0
Wed Mar 20 09:10:40 2013: <191>161227: cisco-anipi=0
Wed Mar 20 09:10:40 2013: <191>161228: cisco-anisi=0
Wed Mar 20 09:10:40 2013: <191>161229: dest=
Wed Mar 20 09:10:40 2013: <191>161230: cisco-desttype=0
Wed Mar 20 09:10:40 2013: <191>161231: cisco-destplan=0
Wed Mar 20 09:10:40 2013: <191>161232: cisco-rdie=FFFFFFFF
Wed Mar 20 09:10:40 2013: <191>161233: cisco-rdn=
Wed Mar 20 09:10:40 2013: <191>161234: cisco-lastrdn=
Wed Mar 20 09:10:40 2013: <191>161235: cisco-rdntype=0
Wed Mar 20 09:10:40 2013: <191>161236: cisco-rdnplan=0
Wed Mar 20 09:10:40 2013: <191>161237: cisco-rdnpi=0
Wed Mar 20 09:10:40 2013: <191>161238: cisco-rdnsi=0
Wed Mar 20 09:10:40 2013: <191>161239: cisco-redirectreason=0 fwd_final_type =0
Wed Mar 20 09:10:40 2013: <191>161240: final_redirectNumber =
Wed Mar 20 09:10:40 2013: <191>161241: hunt_group_timeout =0
Wed Mar 20 09:10:40 2013: <191>161242:
Wed Mar 20 09:10:40 2013: <191>161243: .Mar 20 09:10:39: //-1/035C1122B3B1/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:10:40 2013: <191>161244:
Wed Mar 20 09:10:40 2013: <191>161245: Interface=0x4B805B90, Call Info(
Wed Mar 20 09:10:40 2013: <191>161246: Calling Number=1811032013,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:10:40 2013: <191>161247: Called Number=(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:10:40 2013: <191>161248: Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Wed Mar 20 09:10:40 2013: <191>161249: Incoming Dial-peer=20015, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Wed Mar 20 09:10:40 2013: <191>161250: Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:10:40 2013: <191>161251: .Mar 20 09:10:39: //-1/035C1122B3B1/CCAPI/ccCheckClipClir:
Wed Mar 20 09:10:40 2013: <191>161252: In: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:10:40 2013: <191>161253: .Mar 20 09:10:39: //-1/035C1122B3B1/CCAPI/ccCheckClipClir:
Wed Mar 20 09:10:40 2013: <191>161254: Out: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:10:40 2013: <191>161255: .Mar 20 09:10:39: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:10:40 2013: <191>161256:
Wed Mar 20 09:10:40 2013: <191>161257: .Mar 20 09:10:39: :cc_get_feature_vsa malloc success
Wed Mar 20 09:10:40 2013: <191>161258: .Mar 20 09:10:39: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:10:40 2013: <191>161259:
Wed Mar 20 09:10:40 2013: <191>161260: .Mar 20 09:10:39: cc_get_feature_vsa count is 1
Wed Mar 20 09:10:40 2013: <191>161261: .Mar 20 09:10:39: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:10:40 2013: <191>161262:
Wed Mar 20 09:10:40 2013: <191>161263: .Mar 20 09:10:39: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203248360,feature_id:8133
Wed Mar 20 09:10:40 2013: <191>161264: .Mar 20 09:10:39: //8133/035C1122B3B1/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:10:40 2013: <191>161265:
Wed Mar 20 09:10:40 2013: <191>161266: Set Up Event Sent;
Wed Mar 20 09:10:40 2013: <191>161267: Call Info(Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:10:40 2013: <191>161270: Event=0x4982FA50
Wed Mar 20 09:10:40 2013: <191>161274: >>>>CCAPI handed cid 8133 with tag 20015 to app "_ManagedAppProcess_Default"
Wed Mar 20 09:10:40 2013: <191>161275: .Mar 20 09:10:39: //8133/035C1122B3B1/CCAPI/ccCallSetupAck:
Wed Mar 20 09:10:40 2013: <191>161276: Call Id=8133
Wed Mar 20 09:10:40 2013: <191>161280: .Mar 20 09:10:39: //8133/035C1122B3B1/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:10:40 2013: <191>161289: .Mar 20 09:10:39: //8133/035C1122B3B1/CCAPI/ccCallReportDigits:
Wed Mar 20 09:10:40 2013: <191>161290:
Wed Mar 20 09:10:41 2013: <191>161291: Enabled=TRUE, Call Id=8133
Wed Mar 20 09:10:41 2013: <191>161292: .Mar 20 09:10:39: //8133/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:10:41 2013: <191>161293: (vdbPtr=0x4B805B90, callID=0x1FC5, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Wed Mar 20 09:10:41 2013: <191>161294: .Mar 20 09:10:39: //8133/035C1122B3B1/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:10:41 2013: <191>161295: Enabled=TRUE, Disposition=0x0, Interface=0x4B805B90, Call Id=8133
Wed Mar 20 09:10:41 2013: <191>161296: .Mar 20 09:10:39: //8133/035C1122B3B1/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:10:41 2013: <191>161297: Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=8000(ms))
Wed Mar 20 09:10:45 2013: <191>161298: .Mar 20 09:10:43: //8133/035C1122B3B1/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:10:45 2013: <191>161299: Cause Value=16, Interface=0x4B805B90, Call Id=8133
Wed Mar 20 09:10:45 2013: <191>161300: .Mar 20 09:10:43: //8133/035C1122B3B1/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:10:45 2013: <191>161301: Call Entry(Responsed=FALSE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:10:45 2013: <191>161302: .Mar 20 09:10:43: //8133/035C1122B3B1/CCAPI/ccCallDisconnect:
Wed Mar 20 09:10:45 2013: <191>161303: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:10:45 2013: <191>161304: .Mar 20 09:10:43: //8133/035C1122B3B1/CCAPI/ccCallDisconnect:
Wed Mar 20 09:10:45 2013: <191>161305: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:10:45 2013: <191>161306: .Mar 20 09:10:43: //8133/035C1122B3B1/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:10:45 2013: <191>161307: Transfer Number Is Null
Wed Mar 20 09:10:46 2013: <191>161308: .Mar 20 09:10:43: //8133/035C1122B3B1/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:10:46 2013: <191>161309: Disposition=0, Interface=0x4B805B90, Tag=0x0, Call Id=8133,
Wed Mar 20 09:10:46 2013: <191>161310: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:10:46 2013: <191>161311: .Mar 20 09:10:43: //8133/035C1122B3B1/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:10:46 2013: <191>161312: Call Disconnect Event Sent
Wed Mar 20 09:10:46 2013: <191>161313: .Mar 20 09:10:43: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:10:46 2013: <191>161314:
Wed Mar 20 09:10:46 2013: <191>161315: .Mar 20 09:10:43: :cc_free_feature_vsa freeing 47B81CE0
Wed Mar 20 09:10:46 2013: <191>161316: .Mar 20 09:10:43: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:10:46 2013: <191>161317:
Wed Mar 20 09:10:46 2013: <191>161318: .Mar 20 09:10:43: vsacount in free is 0
Wed Mar 20 09:10:50 2013: <191>161319: .Mar 20 09:10:49: //-1/097909D5B3B5/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:10:50 2013: <191>161320: cc_api_call_setup_ind_common:
Wed Mar 20 09:10:50 2013: <191>161321: cisco-username=
Wed Mar 20 09:10:50 2013: <191>161322: ----- ccCallInfo IE subfields -----
Wed Mar 20 09:10:50 2013: <191>161323: cisco-ani=1811032013
Wed Mar 20 09:10:50 2013: <191>161324: cisco-anitype=0
Wed Mar 20 09:10:50 2013: <191>161325: cisco-aniplan=0
Wed Mar 20 09:10:50 2013: <191>161326: cisco-anipi=0
Wed Mar 20 09:10:50 2013: <191>161327: cisco-anisi=0
Wed Mar 20 09:10:50 2013: <191>161328: dest=
Wed Mar 20 09:10:50 2013: <191>161329: cisco-desttype=0
Wed Mar 20 09:10:50 2013: <191>161330: cisco-destplan=0
Wed Mar 20 09:10:50 2013: <191>161331: cisco-rdie=FFFFFFFF
Wed Mar 20 09:10:50 2013: <191>161332: cisco-rdn=
Wed Mar 20 09:10:50 2013: <191>161333: cisco-lastrdn=
Wed Mar 20 09:10:50 2013: <191>161334: cisco-rdntype=0
Wed Mar 20 09:10:50 2013: <191>161335: cisco-rdnplan=0
Wed Mar 20 09:10:50 2013: <191>161336: cisco-rdnpi=0
Wed Mar 20 09:10:50 2013: <191>161337: cisco-rdnsi=0
Wed Mar 20 09:10:50 2013: <191>161338: cisco-redirectreason=0 fwd_final_type =0
Wed Mar 20 09:10:50 2013: <191>161339: final_redirectNumber =
Wed Mar 20 09:10:50 2013: <191>161340: hunt_group_timeout =0
Wed Mar 20 09:10:50 2013: <191>161341:
Wed Mar 20 09:10:50 2013: <191>161342: .Mar 20 09:10:49: //-1/097909D5B3B5/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:10:50 2013: <191>161343:
Wed Mar 20 09:10:50 2013: <191>161344: Interface=0x4B805B90, Call Info(
Wed Mar 20 09:10:50 2013: <191>161345: Calling Number=1811032013,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:10:50 2013: <191>161346: Called Number=(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:10:50 2013: <191>161347: Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Wed Mar 20 09:10:50 2013: <191>161348: Incoming Dial-peer=20015, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Wed Mar 20 09:10:50 2013: <191>161349: Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:10:50 2013: <191>161350: .Mar 20 09:10:49: //-1/097909D5B3B5/CCAPI/ccCheckClipClir:
Wed Mar 20 09:10:50 2013: <191>161351: In: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:10:50 2013: <191>161352: .Mar 20 09:10:49: //-1/097909D5B3B5/CCAPI/ccCheckClipClir:
Wed Mar 20 09:10:50 2013: <191>161353: Out: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:10:50 2013: <191>161354: .Mar 20 09:10:49: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:10:50 2013: <191>161355:
Wed Mar 20 09:10:50 2013: <191>161356: .Mar 20 09:10:49: :cc_get_feature_vsa malloc success
Wed Mar 20 09:10:50 2013: <191>161357: .Mar 20 09:10:49: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:10:50 2013: <191>161358:
Wed Mar 20 09:10:50 2013: <191>161359: .Mar 20 09:10:49: cc_get_feature_vsa count is 1
Wed Mar 20 09:10:50 2013: <191>161360: .Mar 20 09:10:49: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:10:50 2013: <191>161361:
Wed Mar 20 09:10:50 2013: <191>161362: .Mar 20 09:10:49: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203326024,feature_id:8134
Wed Mar 20 09:10:50 2013: <191>161363: .Mar 20 09:10:49: //8134/097909D5B3B5/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:10:50 2013: <191>161364:
Wed Mar 20 09:10:50 2013: <191>161365: Set Up Event Sent;
Wed Mar 20 09:10:50 2013: <191>161366: Call Info(Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:10:50 2013: <191>161367: Called Number=(TON=Unknown, NPI=Unknown))
Wed Mar 20 09:10:50 2013: <191>161368: .Mar 20 09:10:49: //8134/097909D5B3B5/CCAPI/cc_process_call_setup_ind:
Wed Mar 20 09:10:50 2013: <191>161369: Event=0x4982FA50
Wed Mar 20 09:10:50 2013: <191>161370: .Mar 20 09:10:49: //8134/097909D5B3B5/CCAPI/ccCallSetContext:
Wed Mar 20 09:10:50 2013: <191>161371: Context=0x4BA792A0
Wed Mar 20 09:10:50 2013: <191>161372: .Mar 20 09:10:49: //8134/097909D5B3B5/CCAPI/cc_process_call_setup_ind:
Wed Mar 20 09:10:50 2013: <191>161373: >>>>CCAPI handed cid 8134 with tag 20015 to app "_ManagedAppProcess_Default"
Wed Mar 20 09:10:50 2013: <191>161374: .Mar 20 09:10:49: //8134/097909D5B3B5/CCAPI/ccCallSetupAck:
Wed Mar 20 09:10:50 2013: <191>161375: Call Id=8134
Wed Mar 20 09:10:50 2013: <191>161376: .Mar 20 09:10:49: //8134/097909D5B3B5/CCAPI/cc_api_set_transfer_info:
Wed Mar 20 09:10:50 2013: <191>161381: Tone Direction=Network, Params=0x0, Call Id=8134
Wed Mar 20 09:10:50 2013: <191>161382: .Mar 20 09:10:49: //8134/097909D5B3B5/CCAPI/ccSetDigitTimeouts:
Wed Mar 20 09:10:50 2013: <191>161384: .Mar 20 09:10:49: //8134/097909D5B3B5/CCAPI/ccSetDigitTimeouts:
Wed Mar 20 09:10:50 2013: <191>161387: (callID=0x1FC6, digit_event=0x1, enable=TRUE, consume=FALSE)
Wed Mar 20 09:10:50 2013: <191>161390: Enabled=TRUE, Call Id=8134
Wed Mar 20 09:10:50 2013: <191>161391: .Mar 20 09:10:49: //8134/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:10:50 2013: <191>161392: (vdbPtr=0x4B805B90, callID=0x1FC6, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Wed Mar 20 09:10:50 2013: <191>161393: .Mar 20 09:10:49: //8134/097909D5B3B5/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:10:50 2013: <191>161394: Enabled=TRUE, Disposition=0x0, Interface=0x4B805B90, Call Id=8134
Wed Mar 20 09:10:50 2013: <191>161395: .Mar 20 09:10:49: //8134/097909D5B3B5/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:10:50 2013: <191>161396: Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=8000(ms))
Wed Mar 20 09:10:50 2013: <191>161397: .Mar 20 09:10:49: //8134/097909D5B3B5/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:10:50 2013: <191>161398: Cause Value=16, Interface=0x4B805B90, Call Id=8134
Wed Mar 20 09:10:50 2013: <191>161399: .Mar 20 09:10:49: //8134/097909D5B3B5/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:10:50 2013: <191>161400: Call Entry(Responsed=FALSE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:10:50 2013: <191>161401: .Mar 20 09:10:49: //8134/097909D5B3B5/CCAPI/ccCallDisconnect:
Wed Mar 20 09:10:50 2013: <191>161402: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:10:50 2013: <191>161403: .Mar 20 09:10:49: //8134/097909D5B3B5/CCAPI/ccCallDisconnect:
Wed Mar 20 09:10:50 2013: <191>161404: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:10:50 2013: <191>161405: .Mar 20 09:10:49: //8134/097909D5B3B5/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:10:50 2013: <191>161406: Transfer Number Is Null
Wed Mar 20 09:10:50 2013: <191>161407: .Mar 20 09:10:49: //8134/097909D5B3B5/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:10:50 2013: <191>161408:
Wed Mar 20 09:10:51 2013: <191>161409: Disposition=0, Interface=0x4B805B90, Tag=0x0, Call Id=8134,
Wed Mar 20 09:10:51 2013: <191>161410: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:10:51 2013: <191>161411: .Mar 20 09:10:49: //8134/097909D5B3B5/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:10:51 2013: <191>161412: Call Disconnect Event Sent
Wed Mar 20 09:10:51 2013: <191>161413: .Mar 20 09:10:49: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:10:51 2013: <191>161414:
Wed Mar 20 09:10:51 2013: <191>161415: .Mar 20 09:10:49: :cc_free_feature_vsa freeing 47B94C40
Wed Mar 20 09:10:51 2013: <191>161416: .Mar 20 09:10:49: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:10:51 2013: <191>161417:
Wed Mar 20 09:10:51 2013: <191>161418: .Mar 20 09:10:49: vsacount in free is 0
Wed Mar 20 09:10:52 2013: <191>161419: .Mar 20 09:10:51: //-1/0A8328ABB3B9/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:10:52 2013: <191>161420: cc_api_call_setup_ind_common:
Wed Mar 20 09:10:52 2013: <191>161421: cisco-username=
Wed Mar 20 09:10:52 2013: <191>161422: ----- ccCallInfo IE subfields -----
Wed Mar 20 09:10:52 2013: <191>161423: cisco-ani=1811032013
Wed Mar 20 09:10:52 2013: <191>161424: cisco-anitype=0
Wed Mar 20 09:10:52 2013: <191>161425: cisco-aniplan=0
Wed Mar 20 09:10:52 2013: <191>161426: cisco-anipi=0
Wed Mar 20 09:10:52 2013: <191>161427: cisco-anisi=0
Wed Mar 20 09:10:52 2013: <191>161428: dest=
Wed Mar 20 09:10:52 2013: <191>161429: cisco-desttype=0
Wed Mar 20 09:10:52 2013: <191>161430: cisco-destplan=0
Wed Mar 20 09:10:52 2013: <191>161431: cisco-rdie=FFFFFFFF
Wed Mar 20 09:10:52 2013: <191>161432: cisco-rdn=
Wed Mar 20 09:10:52 2013: <191>161433: cisco-lastrdn=
Wed Mar 20 09:10:52 2013: <191>161434: cisco-rdntype=0
Wed Mar 20 09:10:52 2013: <191>161435: cisco-rdnplan=0
Wed Mar 20 09:10:52 2013: <191>161436: cisco-rdnpi=0
Wed Mar 20 09:10:52 2013: <191>161437: cisco-rdnsi=0
Wed Mar 20 09:10:52 2013: <191>161438: cisco-redirectreason=0 fwd_final_type =0
Wed Mar 20 09:10:52 2013: <191>161439: final_redirectNumber =
Wed Mar 20 09:10:52 2013: <191>161440: hunt_group_timeout =0
Wed Mar 20 09:10:52 2013: <191>161441:
Wed Mar 20 09:10:52 2013: <191>161442: .Mar 20 09:10:51: //-1/0A8328ABB3B9/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:10:52 2013: <191>161443:
Wed Mar 20 09:10:52 2013: <191>161444: Interface=0x4B805B90, Call Info(
Wed Mar 20 09:10:52 2013: <191>161445: Calling Number=1811032013,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:10:52 2013: <191>161446: Called Number=(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:10:52 2013: <191>161447: Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Wed Mar 20 09:10:52 2013: <191>161448: Incoming Dial-peer=20015, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Wed Mar 20 09:10:52 2013: <191>161449: Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:10:52 2013: <191>161450: .Mar 20 09:10:51: //-1/0A8328ABB3B9/CCAPI/ccCheckClipClir:
Wed Mar 20 09:10:52 2013: <191>161451: In: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:10:52 2013: <191>161452: .Mar 20 09:10:51: //-1/0A8328ABB3B9/CCAPI/ccCheckClipClir:
Wed Mar 20 09:10:52 2013: <191>161453: Out: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:10:52 2013: <191>161454: .Mar 20 09:10:51: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:10:52 2013: <191>161455:
Wed Mar 20 09:10:52 2013: <191>161456: .Mar 20 09:10:51: :cc_get_feature_vsa malloc success
Wed Mar 20 09:10:52 2013: <191>161457: .Mar 20 09:10:51: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:10:52 2013: <191>161458:
Wed Mar 20 09:10:52 2013: <191>161459: .Mar 20 09:10:51: cc_get_feature_vsa count is 1
Wed Mar 20 09:10:52 2013: <191>161460: .Mar 20 09:10:51: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:10:52 2013: <191>161461:
Wed Mar 20 09:10:52 2013: <191>161462: .Mar 20 09:10:51: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203248360,feature_id:8135
Wed Mar 20 09:10:52 2013: <191>161463: .Mar 20 09:10:51: //8135/0A8328ABB3B9/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:10:52 2013: <191>161464:
Wed Mar 20 09:10:52 2013: <191>161465: Set Up Event Sent;
Wed Mar 20 09:10:52 2013: <191>161470: .Mar 20 09:10:51: //8135/0A8328ABB3B9/CCAPI/ccCallSetContext:
Wed Mar 20 09:10:52 2013: <191>161474: .Mar 20 09:10:51: //8135/0A8328ABB3B9/CCAPI/ccCallSetupAck:
Wed Mar 20 09:10:52 2013: <191>161479: .Mar 20 09:10:51: //8135/0A8328ABB3B9/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:10:53 2013: <191>161490: Enabled=TRUE, Call Id=8135
Wed Mar 20 09:10:53 2013: <191>161491: .Mar 20 09:10:51: //8135/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:10:53 2013: <191>161492: (vdbPtr=0x4B805B90, callID=0x1FC7, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Wed Mar 20 09:10:53 2013: <191>161493: .Mar 20 09:10:51: //8135/0A8328ABB3B9/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:10:53 2013: <191>161494: Enabled=TRUE, Disposition=0x0, Interface=0x4B805B90, Call Id=8135
Wed Mar 20 09:10:53 2013: <191>161495: .Mar 20 09:10:51: //8135/0A8328ABB3B9/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:10:53 2013: <191>161496: Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=8000(ms))
Wed Mar 20 09:11:05 2013: <191>161497: .Mar 20 09:11:04: //8135/0A8328ABB3B9/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:11:05 2013: <191>161498: Cause Value=16, Interface=0x4B805B90, Call Id=8135
Wed Mar 20 09:11:05 2013: <191>161499: .Mar 20 09:11:04: //8135/0A8328ABB3B9/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:11:05 2013: <191>161500: Call Entry(Responsed=FALSE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:11:05 2013: <191>161501: .Mar 20 09:11:04: //8135/0A8328ABB3B9/CCAPI/ccCallDisconnect:
Wed Mar 20 09:11:05 2013: <191>161502: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:11:05 2013: <191>161503: .Mar 20 09:11:04: //8135/0A8328ABB3B9/CCAPI/ccCallDisconnect:
Wed Mar 20 09:11:05 2013: <191>161504: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:11:05 2013: <191>161505: .Mar 20 09:11:04: //8135/0A8328ABB3B9/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:11:05 2013: <191>161506: Transfer Number Is Null
Wed Mar 20 09:11:06 2013: <191>161507: .Mar 20 09:11:04: //8135/0A8328ABB3B9/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:11:06 2013: <191>161508: Disposition=0, Interface=0x4B805B90, Tag=0x0, Call Id=8135,
Wed Mar 20 09:11:06 2013: <191>161509: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:11:06 2013: <191>161510: .Mar 20 09:11:04: //8135/0A8328ABB3B9/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:11:06 2013: <191>161511: Call Disconnect Event Sent
Wed Mar 20 09:11:06 2013: <191>161512: .Mar 20 09:11:04: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:11:06 2013: <191>161513:
Wed Mar 20 09:11:06 2013: <191>161514: .Mar 20 09:11:04: :cc_free_feature_vsa freeing 47B81CE0
Wed Mar 20 09:11:06 2013: <191>161515: .Mar 20 09:11:04: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:11:06 2013: <191>161516:
Wed Mar 20 09:11:06 2013: <191>161517: .Mar 20 09:11:04: vsacount in free is 0
Wed Mar 20 09:11:06 2013: <191>161518: .Mar 20 09:11:05: //-1/130B09BAB3BD/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:11:06 2013: <191>161519: cc_api_call_setup_ind_common:
Wed Mar 20 09:11:06 2013: <191>161520: cisco-username=
Wed Mar 20 09:11:06 2013: <191>161521:
Wed Mar 20 09:11:06 2013: <191>161522: ----- ccCallInfo IE subfields -----
Wed Mar 20 09:11:06 2013: <191>161523: cisco-ani=1811032013
Wed Mar 20 09:11:06 2013: <191>161524: cisco-anitype=0
Wed Mar 20 09:11:06 2013: <191>161525: cisco-aniplan=0
Wed Mar 20 09:11:06 2013: <191>161526: cisco-anipi=0
Wed Mar 20 09:11:06 2013: <191>161527: cisco-anisi=0
Wed Mar 20 09:11:06 2013: <191>161528: dest=
Wed Mar 20 09:11:06 2013: <191>161529: cisco-desttype=0
Wed Mar 20 09:11:06 2013: <191>161530: cisco-destplan=0
Wed Mar 20 09:11:06 2013: <191>161531: cisco-rdie=FFFFFFFF
Wed Mar 20 09:11:06 2013: <191>161532: cisco-rdn=
Wed Mar 20 09:11:06 2013: <191>161533: cisco-lastrdn=
Wed Mar 20 09:11:06 2013: <191>161534: cisco-rdntype=0
Wed Mar 20 09:11:06 2013: <191>161535: cisco-rdnplan=0
Wed Mar 20 09:11:06 2013: <191>161536: cisco-rdnpi=0
Wed Mar 20 09:11:06 2013: <191>161537: cisco-rdnsi=0
Wed Mar 20 09:11:06 2013: <191>161538: cisco-redirectreason=0 fwd_final_type =0
Wed Mar 20 09:11:06 2013: <191>161539: final_redirectNumber =
Wed Mar 20 09:11:06 2013: <191>161540: hunt_group_timeout =0
Wed Mar 20 09:11:06 2013: <191>161541:
Wed Mar 20 09:11:06 2013: <191>161542: .Mar 20 09:11:05: //-1/130B09BAB3BD/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:11:06 2013: <191>161543:
Wed Mar 20 09:11:06 2013: <191>161544: Interface=0x4B805B90, Call Info(
Wed Mar 20 09:11:06 2013: <191>161545: Calling Number=1811032013,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:11:06 2013: <191>161546: Called Number=(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:11:06 2013: <191>161547: Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Wed Mar 20 09:11:06 2013: <191>161548: Incoming Dial-peer=20015, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Wed Mar 20 09:11:06 2013: <191>161549: Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:11:06 2013: <191>161550: .Mar 20 09:11:05: //-1/130B09BAB3BD/CCAPI/ccCheckClipClir:
Wed Mar 20 09:11:06 2013: <191>161551: In: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:11:06 2013: <191>161554: .Mar 20 09:11:05: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:11:06 2013: <191>161556: .Mar 20 09:11:05: :cc_get_feature_vsa malloc success
Wed Mar 20 09:11:06 2013: <191>161558:
Wed Mar 20 09:11:06 2013: <191>161561:
Wed Mar 20 09:11:06 2013: <191>161564:
Wed Mar 20 09:11:06 2013: <191>161567: Called Number=(TON=Unknown, NPI=Unknown))
Wed Mar 20 09:11:06 2013: <191>161568: .Mar 20 09:11:05: //8136/130B09BAB3BD/CCAPI/cc_process_call_setup_ind:
Wed Mar 20 09:11:06 2013: <191>161569: Event=0x4982FA50
Wed Mar 20 09:11:06 2013: <191>161570: .Mar 20 09:11:05: //8136/130B09BAB3BD/CCAPI/ccCallSetContext:
Wed Mar 20 09:11:06 2013: <191>161571: Context=0x4BA6FA60
Wed Mar 20 09:11:06 2013: <191>161574: .Mar 20 09:11:05: //8136/130B09BAB3BD/CCAPI/ccCallSetupAck:
Wed Mar 20 09:11:06 2013: <191>161577:
Wed Mar 20 09:11:06 2013: <191>161581: Tone Direction=Network, Params=0x0, Call Id=8136
Wed Mar 20 09:11:07 2013: <191>161590: Enabled=TRUE, Call Id=8136
Wed Mar 20 09:11:07 2013: <191>161591: .Mar 20 09:11:05: //8136/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:07 2013: <191>161592: (vdbPtr=0x4B805B90, callID=0x1FC8, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Wed Mar 20 09:11:07 2013: <191>161593: .Mar 20 09:11:05: //8136/130B09BAB3BD/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:07 2013: <191>161594: Enabled=TRUE, Disposition=0x0, Interface=0x4B805B90, Call Id=8136
Wed Mar 20 09:11:07 2013: <191>161595: .Mar 20 09:11:05: //8136/130B09BAB3BD/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:07 2013: <191>161596: Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=8000(ms))
Wed Mar 20 09:11:09 2013: <191>161597: .Mar 20 09:11:08: //8136/130B09BAB3BD/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:11:09 2013: <191>161598: Cause Value=16, Interface=0x4B805B90, Call Id=8136
Wed Mar 20 09:11:09 2013: <191>161599: .Mar 20 09:11:08: //8136/130B09BAB3BD/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:11:09 2013: <191>161600: Call Entry(Responsed=FALSE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:11:09 2013: <191>161601: .Mar 20 09:11:08: //8136/130B09BAB3BD/CCAPI/ccCallDisconnect:
Wed Mar 20 09:11:09 2013: <191>161602: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:11:09 2013: <191>161603: .Mar 20 09:11:08: //8136/130B09BAB3BD/CCAPI/ccCallDisconnect:
Wed Mar 20 09:11:09 2013: <191>161604: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:11:09 2013: <191>161605: .Mar 20 09:11:08: //8136/130B09BAB3BD/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:11:09 2013: <191>161606: Transfer Number Is Null
Wed Mar 20 09:11:10 2013: <191>161607: .Mar 20 09:11:08: //8136/130B09BAB3BD/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:11:10 2013: <191>161608: Disposition=0, Interface=0x4B805B90, Tag=0x0, Call Id=8136,
Wed Mar 20 09:11:10 2013: <191>161609: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:11:10 2013: <191>161610: .Mar 20 09:11:08: //8136/130B09BAB3BD/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:11:10 2013: <191>161611: Call Disconnect Event Sent
Wed Mar 20 09:11:10 2013: <191>161612: .Mar 20 09:11:08: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:11:10 2013: <191>161613:
Wed Mar 20 09:11:10 2013: <191>161614: .Mar 20 09:11:08: :cc_free_feature_vsa freeing 47B94C40
Wed Mar 20 09:11:10 2013: <191>161615: .Mar 20 09:11:08: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:11:10 2013: <191>161616:
Wed Mar 20 09:11:10 2013: <191>161617: .Mar 20 09:11:08: vsacount in free is 0
Wed Mar 20 09:11:10 2013: <191>161618: .Mar 20 09:11:09: //-1/155F5D54B3C1/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:11:10 2013: <191>161619: cc_api_call_setup_ind_common:
Wed Mar 20 09:11:10 2013: <191>161620: cisco-username=
Wed Mar 20 09:11:10 2013: <191>161621:
Wed Mar 20 09:11:10 2013: <191>161622: ----- ccCallInfo IE subfields -----
Wed Mar 20 09:11:10 2013: <191>161623: cisco-ani=1811032013
Wed Mar 20 09:11:10 2013: <191>161624: cisco-anitype=0
Wed Mar 20 09:11:10 2013: <191>161625: cisco-aniplan=0
Wed Mar 20 09:11:10 2013: <191>161626: cisco-anipi=0
Wed Mar 20 09:11:10 2013: <191>161627: cisco-anisi=0
Wed Mar 20 09:11:10 2013: <191>161628: dest=
Wed Mar 20 09:11:10 2013: <191>161629: cisco-desttype=0
Wed Mar 20 09:11:10 2013: <191>161630: cisco-destplan=0
Wed Mar 20 09:11:10 2013: <191>161631: cisco-rdie=FFFFFFFF
Wed Mar 20 09:11:10 2013: <191>161632: cisco-rdn=
Wed Mar 20 09:11:10 2013: <191>161633: cisco-lastrdn=
Wed Mar 20 09:11:10 2013: <191>161634: cisco-rdntype=0
Wed Mar 20 09:11:10 2013: <191>161635: cisco-rdnplan=0
Wed Mar 20 09:11:10 2013: <191>161636: cisco-rdnpi=0
Wed Mar 20 09:11:10 2013: <191>161637: cisco-rdnsi=0
Wed Mar 20 09:11:10 2013: <191>161638: cisco-redirectreason=0 fwd_final_type =0
Wed Mar 20 09:11:10 2013: <191>161639: final_redirectNumber =
Wed Mar 20 09:11:10 2013: <191>161640: hunt_group_timeout =0
Wed Mar 20 09:11:10 2013: <191>161641:
Wed Mar 20 09:11:10 2013: <191>161642: .Mar 20 09:11:09: //-1/155F5D54B3C1/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:11:10 2013: <191>161643:
Wed Mar 20 09:11:10 2013: <191>161644: Interface=0x4B805B90, Call Info(
Wed Mar 20 09:11:10 2013: <191>161645: Calling Number=1811032013,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:11:10 2013: <191>161646: Called Number=(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:11:10 2013: <191>161647: Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Wed Mar 20 09:11:10 2013: <191>161648: Incoming Dial-peer=20015, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Wed Mar 20 09:11:10 2013: <191>161649: Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:11:10 2013: <191>161650: .Mar 20 09:11:09: //-1/155F5D54B3C1/CCAPI/ccCheckClipClir:
Wed Mar 20 09:11:10 2013: <191>161651: In: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:11:10 2013: <191>161652: .Mar 20 09:11:09: //-1/155F5D54B3C1/CCAPI/ccCheckClipClir:
Wed Mar 20 09:11:10 2013: <191>161653: Out: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:11:10 2013: <191>161655:
Wed Mar 20 09:11:10 2013: <191>161658:
Wed Mar 20 09:11:10 2013: <191>161661:
Wed Mar 20 09:11:10 2013: <191>161663: .Mar 20 09:11:09: //8137/155F5D54B3C1/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:11:10 2013: <191>161667: Called Number=(TON=Unknown, NPI=Unknown))
Wed Mar 20 09:11:10 2013: <191>161669: Event=0x4982FA50
Wed Mar 20 09:11:10 2013: <191>161671: Context=0x4BA69B38
Wed Mar 20 09:11:10 2013: <191>161672: .Mar 20 09:11:09: //8137/155F5D54B3C1/CCAPI/cc_process_call_setup_ind:
Wed Mar 20 09:11:10 2013: <191>161675: Call Id=8137
Wed Mar 20 09:11:10 2013: <191>161677:
Wed Mar 20 09:11:10 2013: <191>161679: .Mar 20 09:11:09: //8137/155F5D54B3C1/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:11:10 2013: <191>161683: Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
Wed Mar 20 09:11:10 2013: <191>161686: .Mar 20 09:11:09: //8137/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
Wed Mar 20 09:11:11 2013: <191>161690: Enabled=TRUE, Call Id=8137
Wed Mar 20 09:11:11 2013: <191>161691: .Mar 20 09:11:09: //8137/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:11 2013: <191>161692: (vdbPtr=0x4B805B90, callID=0x1FC9, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Wed Mar 20 09:11:11 2013: <191>161693: .Mar 20 09:11:09: //8137/155F5D54B3C1/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:11 2013: <191>161694: Enabled=TRUE, Disposition=0x0, Interface=0x4B805B90, Call Id=8137
Wed Mar 20 09:11:11 2013: <191>161695: .Mar 20 09:11:09: //8137/155F5D54B3C1/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:11 2013: <191>161696: Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=8000(ms))
Wed Mar 20 09:11:14 2013: <191>161697: .Mar 20 09:11:12: //8137/155F5D54B3C1/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:11:14 2013: <191>161698: Cause Value=16, Interface=0x4B805B90, Call Id=8137
Wed Mar 20 09:11:14 2013: <191>161699: .Mar 20 09:11:12: //8137/155F5D54B3C1/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:11:14 2013: <191>161700: Call Entry(Responsed=FALSE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:11:14 2013: <191>161701: .Mar 20 09:11:12: //8137/155F5D54B3C1/CCAPI/ccCallDisconnect:
Wed Mar 20 09:11:14 2013: <191>161702: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:11:14 2013: <191>161703: .Mar 20 09:11:12: //8137/155F5D54B3C1/CCAPI/ccCallDisconnect:
Wed Mar 20 09:11:14 2013: <191>161704: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:11:14 2013: <191>161705: .Mar 20 09:11:12: //8137/155F5D54B3C1/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:11:14 2013: <191>161706: Transfer Number Is Null
Wed Mar 20 09:11:14 2013: <191>161707: .Mar 20 09:11:12: //8137/155F5D54B3C1/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:11:14 2013: <191>161708: Disposition=0, Interface=0x4B805B90, Tag=0x0, Call Id=8137,
Wed Mar 20 09:11:14 2013: <191>161709: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:11:14 2013: <191>161710: .Mar 20 09:11:12: //8137/155F5D54B3C1/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:11:14 2013: <191>161711: Call Disconnect Event Sent
Wed Mar 20 09:11:14 2013: <191>161712: .Mar 20 09:11:12: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:11:14 2013: <191>161713:
Wed Mar 20 09:11:14 2013: <191>161714: .Mar 20 09:11:12: :cc_free_feature_vsa freeing 47B81CE0
Wed Mar 20 09:11:14 2013: <191>161715: .Mar 20 09:11:12: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:11:14 2013: <191>161716:
Wed Mar 20 09:11:14 2013: <191>161717: .Mar 20 09:11:12: vsacount in free is 0
Wed Mar 20 09:11:14 2013: <191>161718: .Mar 20 09:11:13: //-1/17F46303B3C5/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:11:14 2013: <191>161719: cc_api_call_setup_ind_common:
Wed Mar 20 09:11:14 2013: <191>161720: cisco-username=
Wed Mar 20 09:11:14 2013: <191>161721:
Wed Mar 20 09:11:14 2013: <191>161722: ----- ccCallInfo IE subfields -----
Wed Mar 20 09:11:14 2013: <191>161723: cisco-ani=1811032013
Wed Mar 20 09:11:14 2013: <191>161724: cisco-anitype=0
Wed Mar 20 09:11:14 2013: <191>161725: cisco-aniplan=0
Wed Mar 20 09:11:14 2013: <191>161726: cisco-anipi=0
Wed Mar 20 09:11:14 2013: <191>161727: cisco-anisi=0
Wed Mar 20 09:11:14 2013: <191>161728: dest=
Wed Mar 20 09:11:14 2013: <191>161729: cisco-desttype=0
Wed Mar 20 09:11:14 2013: <191>161730: cisco-destplan=0
Wed Mar 20 09:11:14 2013: <191>161731: cisco-rdie=FFFFFFFF
Wed Mar 20 09:11:14 2013: <191>161732: cisco-rdn=
Wed Mar 20 09:11:14 2013: <191>161733: cisco-lastrdn=
Wed Mar 20 09:11:14 2013: <191>161734: cisco-rdntype=0
Wed Mar 20 09:11:14 2013: <191>161735: cisco-rdnplan=0
Wed Mar 20 09:11:14 2013: <191>161736: cisco-rdnpi=0
Wed Mar 20 09:11:14 2013: <191>161737: cisco-rdnsi=0
Wed Mar 20 09:11:14 2013: <191>161738: cisco-redirectreason=0 fwd_final_type =0
Wed Mar 20 09:11:14 2013: <191>161739: final_redirectNumber =
Wed Mar 20 09:11:14 2013: <191>161740: hunt_group_timeout =0
Wed Mar 20 09:11:14 2013: <191>161741:
Wed Mar 20 09:11:14 2013: <191>161742: .Mar 20 09:11:13: //-1/17F46303B3C5/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:11:14 2013: <191>161743:
Wed Mar 20 09:11:14 2013: <191>161744: Interface=0x4B805B90, Call Info(
Wed Mar 20 09:11:14 2013: <191>161745: Calling Number=1811032013,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:11:14 2013: <191>161746: Called Number=(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:11:14 2013: <191>161747: Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Wed Mar 20 09:11:14 2013: <191>161748: Incoming Dial-peer=20015, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Wed Mar 20 09:11:14 2013: <191>161749: Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:11:14 2013: <191>161750: .Mar 20 09:11:13: //-1/17F46303B3C5/CCAPI/ccCheckClipClir:
Wed Mar 20 09:11:14 2013: <191>161751: In: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:11:14 2013: <191>161752: .Mar 20 09:11:13: //-1/17F46303B3C5/CCAPI/ccCheckClipClir:
Wed Mar 20 09:11:14 2013: <191>161753: Out: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:11:14 2013: <191>161755:
Wed Mar 20 09:11:14 2013: <191>161756: .Mar 20 09:11:13: :cc_get_feature_vsa malloc success
Wed Mar 20 09:11:14 2013: <191>161759: .Mar 20 09:11:13: cc_get_feature_vsa count is 1
Wed Mar 20 09:11:14 2013: <191>161761:
Wed Mar 20 09:11:14 2013: <191>161765: Set Up Event Sent;
Wed Mar 20 09:11:14 2013: <191>161767: Called Number=(TON=Unknown, NPI=Unknown))
Wed Mar 20 09:11:14 2013: <191>161769: Event=0x4982FA50
Wed Mar 20 09:11:14 2013: <191>161773: >>>>CCAPI handed cid 8138 with tag 20015 to app "_ManagedAppProcess_Default"
Wed Mar 20 09:11:14 2013: <191>161775: Call Id=8138
Wed Mar 20 09:11:14 2013: <191>161777:
Wed Mar 20 09:11:14 2013: <191>161781: Tone Direction=Network, Params=0x0, Call Id=8138
Wed Mar 20 09:11:15 2013: <191>161790: Enabled=TRUE, Call Id=8138
Wed Mar 20 09:11:15 2013: <191>161791: .Mar 20 09:11:13: //8138/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:15 2013: <191>161792: (vdbPtr=0x4B805B90, callID=0x1FCA, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Wed Mar 20 09:11:15 2013: <191>161793: .Mar 20 09:11:13: //8138/17F46303B3C5/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:15 2013: <191>161794: Enabled=TRUE, Disposition=0x0, Interface=0x4B805B90, Call Id=8138
Wed Mar 20 09:11:15 2013: <191>161795: .Mar 20 09:11:13: //8138/17F46303B3C5/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:15 2013: <191>161796: Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=8000(ms))
Wed Mar 20 09:11:16 2013: <191>161797: .Mar 20 09:11:14: //8138/17F46303B3C5/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:11:16 2013: <191>161798: Cause Value=16, Interface=0x4B805B90, Call Id=8138
Wed Mar 20 09:11:16 2013: <191>161799: .Mar 20 09:11:14: //8138/17F46303B3C5/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:11:16 2013: <191>161800: Call Entry(Responsed=FALSE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:11:16 2013: <191>161801: .Mar 20 09:11:14: //8138/17F46303B3C5/CCAPI/ccCallDisconnect:
Wed Mar 20 09:11:16 2013: <191>161802: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:11:16 2013: <191>161803: .Mar 20 09:11:14: //8138/17F46303B3C5/CCAPI/ccCallDisconnect:
Wed Mar 20 09:11:16 2013: <191>161804: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:11:16 2013: <191>161805: .Mar 20 09:11:14: //8138/17F46303B3C5/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:11:16 2013: <191>161806: Transfer Number Is Null
Wed Mar 20 09:11:17 2013: <191>161807: .Mar 20 09:11:14: //8138/17F46303B3C5/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:11:17 2013: <191>161808: Disposition=0, Interface=0x4B805B90, Tag=0x0, Call Id=8138,
Wed Mar 20 09:11:17 2013: <191>161809: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:11:17 2013: <191>161810: .Mar 20 09:11:14: //8138/17F46303B3C5/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:11:17 2013: <191>161811: Call Disconnect Event Sent
Wed Mar 20 09:11:17 2013: <191>161812: .Mar 20 09:11:14: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:11:17 2013: <191>161813:
Wed Mar 20 09:11:17 2013: <191>161814: .Mar 20 09:11:14: :cc_free_feature_vsa freeing 47B94C40
Wed Mar 20 09:11:17 2013: <191>161815: .Mar 20 09:11:14: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:11:17 2013: <191>161816:
Wed Mar 20 09:11:17 2013: <191>161817: .Mar 20 09:11:14: vsacount in free is 0
Wed Mar 20 09:11:19 2013: <191>161818: .Mar 20 09:11:18: //-1/1A91F618B3C9/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:11:19 2013: <191>161819: cc_api_call_setup_ind_common:
Wed Mar 20 09:11:19 2013: <191>161820: cisco-username=
Wed Mar 20 09:11:19 2013: <191>161821: ----- ccCallInfo IE subfields -----
Wed Mar 20 09:11:19 2013: <191>161822: cisco-ani=1811032013
Wed Mar 20 09:11:19 2013: <191>161823: cisco-anitype=0
Wed Mar 20 09:11:19 2013: <191>161824: cisco-aniplan=0
Wed Mar 20 09:11:19 2013: <191>161825: cisco-anipi=0
Wed Mar 20 09:11:19 2013: <191>161826: cisco-anisi=0
Wed Mar 20 09:11:19 2013: <191>161827: dest=
Wed Mar 20 09:11:19 2013: <191>161828: cisco-desttype=0
Wed Mar 20 09:11:19 2013: <191>161829: cisco-destplan=0
Wed Mar 20 09:11:19 2013: <191>161830: cisco-rdie=FFFFFFFF
Wed Mar 20 09:11:19 2013: <191>161831: cisco-rdn=
Wed Mar 20 09:11:19 2013: <191>161832: cisco-lastrdn=
Wed Mar 20 09:11:19 2013: <191>161833: cisco-rdntype=0
Wed Mar 20 09:11:19 2013: <191>161834: cisco-rdnplan=0
Wed Mar 20 09:11:19 2013: <191>161835: cisco-rdnpi=0
Wed Mar 20 09:11:19 2013: <191>161836: cisco-rdnsi=0
Wed Mar 20 09:11:19 2013: <191>161837: cisco-redirectreason=0 fwd_final_type =0
Wed Mar 20 09:11:19 2013: <191>161838: final_redirectNumber =
Wed Mar 20 09:11:19 2013: <191>161839: hunt_group_timeout =0
Wed Mar 20 09:11:19 2013: <191>161840:
Wed Mar 20 09:11:19 2013: <191>161841: .Mar 20 09:11:18: //-1/1A91F618B3C9/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:11:19 2013: <191>161842:
Wed Mar 20 09:11:19 2013: <191>161843: Interface=0x4B805B90, Call Info(
Wed Mar 20 09:11:19 2013: <191>161844: Calling Number=1811032013,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:11:19 2013: <191>161845: Called Number=(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:11:19 2013: <191>161846: Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Wed Mar 20 09:11:19 2013: <191>161847: Incoming Dial-peer=20015, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Wed Mar 20 09:11:19 2013: <191>161848: Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:11:19 2013: <191>161849: .Mar 20 09:11:18: //-1/1A91F618B3C9/CCAPI/ccCheckClipClir:
Wed Mar 20 09:11:19 2013: <191>161850: In: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:11:19 2013: <191>161851: .Mar 20 09:11:18: //-1/1A91F618B3C9/CCAPI/ccCheckClipClir:
Wed Mar 20 09:11:19 2013: <191>161852: Out: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:11:19 2013: <191>161853: .Mar 20 09:11:18: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:11:19 2013: <191>161854:
Wed Mar 20 09:11:19 2013: <191>161855: .Mar 20 09:11:18: :cc_get_feature_vsa malloc success
Wed Mar 20 09:11:19 2013: <191>161856: .Mar 20 09:11:18: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:11:19 2013: <191>161857:
Wed Mar 20 09:11:19 2013: <191>161858: .Mar 20 09:11:18: cc_get_feature_vsa count is 1
Wed Mar 20 09:11:19 2013: <191>161859: .Mar 20 09:11:18: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:11:19 2013: <191>161860:
Wed Mar 20 09:11:19 2013: <191>161861: .Mar 20 09:11:18: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203248360,feature_id:8139
Wed Mar 20 09:11:19 2013: <191>161862: .Mar 20 09:11:18: //8139/1A91F618B3C9/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:11:19 2013: <191>161863:
Wed Mar 20 09:11:19 2013: <191>161864: Set Up Event Sent;
Wed Mar 20 09:11:19 2013: <191>161866: Called Number=(TON=Unknown, NPI=Unknown))
Wed Mar 20 09:11:19 2013: <191>161870: Context=0x4BA6E758
Wed Mar 20 09:11:19 2013: <191>161878: .Mar 20 09:11:18: //8139/1A91F618B3C9/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:11:19 2013: <191>161879: Stop Tone On Digit=TRUE, Tone=Dial Tone,
Wed Mar 20 09:11:19 2013: <191>161888:
Wed Mar 20 09:11:19 2013: <191>161889: Enabled=TRUE, Call Id=8139
Wed Mar 20 09:11:19 2013: <191>161890: .Mar 20 09:11:18: //8139/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:19 2013: <191>161891: (vdbPtr=0x4B805B90, callID=0x1FCB, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Wed Mar 20 09:11:19 2013: <191>161892: .Mar 20 09:11:18: //8139/1A91F618B3C9/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:19 2013: <191>161897:
Wed Mar 20 09:11:19 2013: <191>161898: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:19 2013: <191>161899: Source Call Id=8139, Digit=0, DigitBeginFlags=0x0,
Wed Mar 20 09:11:19 2013: <191>161900: Rtp Timestamp=0x56EA0, Rtp Expiration=0x0
Wed Mar 20 09:11:19 2013: <191>161901: .Mar 20 09:11:18: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:19 2013: <191>161902: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:19 2013: <191>161903: Source Call Id=8139, Digit=0, Duration=100,
Wed Mar 20 09:11:19 2013: <191>161904: Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:11:19 2013: <191>161905: .Mar 20 09:11:18: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:19 2013: <191>161906: Call Entry(Handoff Depth=0)
Wed Mar 20 09:11:19 2013: <191>161907: .Mar 20 09:11:18: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:11:19 2013: <191>161908:
Wed Mar 20 09:11:19 2013: <191>161909: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:19 2013: <191>161910: Source Call Id=8139, Digit=3, DigitBeginFlags=0x0,
Wed Mar 20 09:11:19 2013: <191>161911: Rtp Timestamp=0x5EBA0, Rtp Expiration=0x0
Wed Mar 20 09:11:19 2013: <191>161912: .Mar 20 09:11:18: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:19 2013: <191>161913: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:19 2013: <191>161914: Source Call Id=8139, Digit=3, Duration=100,
Wed Mar 20 09:11:19 2013: <191>161915: Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:11:19 2013: <191>161916: .Mar 20 09:11:18: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:19 2013: <191>161917: Call Entry(Handoff Depth=0)
Wed Mar 20 09:11:19 2013: <191>161918: .Mar 20 09:11:18: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:11:19 2013: <191>161919:
Wed Mar 20 09:11:19 2013: <191>161920: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:19 2013: <191>161921: Source Call Id=8139, Digit=3, DigitBeginFlags=0x0,
Wed Mar 20 09:11:19 2013: <191>161922: Rtp Timestamp=0x668A0, Rtp Expiration=0x0
Wed Mar 20 09:11:19 2013: <191>161923: .Mar 20 09:11:18: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:19 2013: <191>161924: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:19 2013: <191>161925: Source Call Id=8139, Digit=3, Duration=100,
Wed Mar 20 09:11:19 2013: <191>161926: Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:11:19 2013: <191>161927: .Mar 20 09:11:18: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:19 2013: <191>161928: Call Entry(Handoff Depth=0)
Wed Mar 20 09:11:19 2013: <191>161929: .Mar 20 09:11:18: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:11:19 2013: <191>161930:
Wed Mar 20 09:11:19 2013: <191>161931: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:19 2013: <191>161932: Source Call Id=8139, Digit=2, DigitBeginFlags=0x0,
Wed Mar 20 09:11:19 2013: <191>161933: Rtp Timestamp=0x6E5A0, Rtp Expiration=0x0
Wed Mar 20 09:11:19 2013: <191>161934: .Mar 20 09:11:18: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:19 2013: <191>161935: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:19 2013: <191>161936: Source Call Id=8139, Digit=2, Duration=100,
Wed Mar 20 09:11:19 2013: <191>161937: Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:11:19 2013: <191>161938: .Mar 20 09:11:18: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:19 2013: <191>161939: Call Entry(Handoff Depth=0)
Wed Mar 20 09:11:19 2013: <191>161940: .Mar 20 09:11:18: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:11:19 2013: <191>161941:
Wed Mar 20 09:11:20 2013: <191>161942: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:20 2013: <191>161943: Source Call Id=8139, Digit=4, DigitBeginFlags=0x0,
Wed Mar 20 09:11:20 2013: <191>161944: Rtp Timestamp=0x762A0, Rtp Expiration=0x0
Wed Mar 20 09:11:20 2013: <191>161945: .Mar 20 09:11:18: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:20 2013: <191>161946: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:20 2013: <191>161947: Source Call Id=8139, Digit=4, Duration=100,
Wed Mar 20 09:11:20 2013: <191>161948: Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:11:20 2013: <191>161949: .Mar 20 09:11:18: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:20 2013: <191>161950: Call Entry(Handoff Depth=0)
Wed Mar 20 09:11:20 2013: <191>161951: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:11:20 2013: <191>161952:
Wed Mar 20 09:11:20 2013: <191>161953: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:20 2013: <191>161954: Source Call Id=8139, Digit=1, DigitBeginFlags=0x0,
Wed Mar 20 09:11:20 2013: <191>161955: Rtp Timestamp=0x7DFA0, Rtp Expiration=0x0
Wed Mar 20 09:11:20 2013: <191>161956: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:20 2013: <191>161957: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:20 2013: <191>161958: Source Call Id=8139, Digit=1, Duration=100,
Wed Mar 20 09:11:20 2013: <191>161959: Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:11:20 2013: <191>161960: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:20 2013: <191>161961: Call Entry(Handoff Depth=0)
Wed Mar 20 09:11:20 2013: <191>161962: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:11:20 2013: <191>161963:
Wed Mar 20 09:11:20 2013: <191>161964: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:20 2013: <191>161965: Source Call Id=8139, Digit=5, DigitBeginFlags=0x0,
Wed Mar 20 09:11:20 2013: <191>161966: Rtp Timestamp=0x85CA0, Rtp Expiration=0x0
Wed Mar 20 09:11:20 2013: <191>161967: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:20 2013: <191>161968: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:20 2013: <191>161969: Source Call Id=8139, Digit=5, Duration=100,
Wed Mar 20 09:11:20 2013: <191>161970: Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:11:20 2013: <191>161971: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:20 2013: <191>161972: Call Entry(Handoff Depth=0)
Wed Mar 20 09:11:20 2013: <191>161973: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:11:20 2013: <191>161974:
Wed Mar 20 09:11:20 2013: <191>161975: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:20 2013: <191>161976: Source Call Id=8139, Digit=4, DigitBeginFlags=0x0,
Wed Mar 20 09:11:20 2013: <191>161977: Rtp Timestamp=0x8D9A0, Rtp Expiration=0x0
Wed Mar 20 09:11:20 2013: <191>161978: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:20 2013: <191>161979: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:20 2013: <191>161980: Source Call Id=8139, Digit=4, Duration=100,
Wed Mar 20 09:11:20 2013: <191>161981: Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:11:20 2013: <191>161982: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:20 2013: <191>161983: Call Entry(Handoff Depth=0)
Wed Mar 20 09:11:20 2013: <191>161984: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:11:20 2013: <191>161985:
Wed Mar 20 09:11:20 2013: <191>161986: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:20 2013: <191>161987: Source Call Id=8139, Digit=2, DigitBeginFlags=0x0,
Wed Mar 20 09:11:20 2013: <191>161988: Rtp Timestamp=0x956A0, Rtp Expiration=0x0
Wed Mar 20 09:11:20 2013: <191>161989: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:20 2013: <191>161990: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:20 2013: <191>161991: Source Call Id=8139, Digit=2, Duration=100,
Wed Mar 20 09:11:20 2013: <191>161992: Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:11:20 2013: <191>161993: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:20 2013: <191>161994: Call Entry(Handoff Depth=0)
Wed Mar 20 09:11:20 2013: <191>161995: .Mar 20 09:11:19: //8139/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
Wed Mar 20 09:11:20 2013: <191>161996: (callID=0x1FCB, digit_event=0x0, enable=FALSE, consume=FALSE)
Wed Mar 20 09:11:20 2013: <191>161997: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/ccCallReportDigits:
Wed Mar 20 09:11:20 2013: <191>161998: Enabled=TRUE, Call Id=8139
Wed Mar 20 09:11:20 2013: <191>161999: .Mar 20 09:11:19: //8139/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:20 2013: <191>162000: (vdbPtr=0x4B805B90, callID=0x1FCB, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Wed Mar 20 09:11:20 2013: <191>162001: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:20 2013: <191>162002: Enabled=TRUE, Disposition=0x0, Interface=0x4B805B90, Call Id=8139
Wed Mar 20 09:11:20 2013: <191>162003: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:20 2013: <191>162004: Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=8000(ms))
Wed Mar 20 09:11:20 2013: <191>162005: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/ccCallProceeding:
Wed Mar 20 09:11:20 2013: <191>162006: Progress Indication=NULL(0)
Wed Mar 20 09:11:20 2013: <191>162007: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:11:20 2013: <191>162008: Destination=, Calling IE Present=TRUE, Mode=0,
Wed Mar 20 09:11:20 2013: <191>162009: Outgoing Dial-peer=2, Params=0x4BA759D8, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Wed Mar 20 09:11:20 2013: <191>162010: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/ccCheckClipClir:
Wed Mar 20 09:11:20 2013: <191>162011: In: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:11:20 2013: <191>162012: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/ccCheckClipClir:
Wed Mar 20 09:11:20 2013: <191>162013: Out: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:11:20 2013: <191>162014: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:11:20 2013: <191>162022: Guid=1A91F618-908E-11E2-B3C9-DE08FC69A21F, Outgoing Dial-peer=2
Wed Mar 20 09:11:20 2013: <191>162023: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:11:20 2013: <191>162024: ccCallSetupRequest:
Wed Mar 20 09:11:20 2013: <191>162029: cisco-aniplan=0
Wed Mar 20 09:11:20 2013: <191>162030:
Wed Mar 20 09:11:20 2013: <191>162032: cisco-anisi=0
Wed Mar 20 09:11:20 2013: <191>162035: cisco-destplan=0
Wed Mar 20 09:11:20 2013: <191>162046:
Wed Mar 20 09:11:20 2013: <191>162047: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:11:20 2013: <191>162048:
Wed Mar 20 09:11:20 2013: <191>162049: Interface=0x4987DFD8, Interface Type=6, Destination=, Mode=0x0,
Wed Mar 20 09:11:20 2013: <191>162054: .Mar 20 09:11:19: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:11:20 2013: <191>162056: .Mar 20 09:11:19: :cc_get_feature_vsa malloc success
Wed Mar 20 09:11:20 2013: <191>162057: .Mar 20 09:11:19: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:11:21 2013: <191>162059: .Mar 20 09:11:19: cc_get_feature_vsa count is 2
Wed Mar 20 09:11:21 2013: <191>162060: .Mar 20 09:11:19: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:11:21 2013: <191>162061:
Wed Mar 20 09:11:21 2013: <191>162062: .Mar 20 09:11:19: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203248136,feature_id:8140
Wed Mar 20 09:11:21 2013: <191>162063: .Mar 20 09:11:19: //8140/1A91F618B3C9/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:11:21 2013: <191>162064: SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Wed Mar 20 09:11:21 2013: <191>162065: .Mar 20 09:11:19: //8140/1A91F618B3C9/CCAPI/ccCallSetContext:
Wed Mar 20 09:11:21 2013: <191>162066: Context=0x4BA75988
Wed Mar 20 09:11:21 2013: <191>162067: .Mar 20 09:11:19: //8139/1A91F618B3C9/CCAPI/ccSaveDialpeerTag:
Wed Mar 20 09:11:21 2013: <191>162068: Outgoing Dial-peer=2
Wed Mar 20 09:11:21 2013: <191>162069: .Mar 20 09:11:19: //8140/1A91F618B3C9/CCAPI/cc_api_call_proceeding:
Wed Mar 20 09:11:21 2013: <191>162070: Interface=0x4987DFD8, Progress Indication=NULL(0)
Wed Mar 20 09:11:23 2013: <191>162071: .Mar 20 09:11:22: //8140/1A91F618B3C9/CCAPI/cc_api_call_cut_progress:
Wed Mar 20 09:11:23 2013: <191>162072: Interface=0x4987DFD8, Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2),
Wed Mar 20 09:11:23 2013: <191>162073: Cause Value=0
Wed Mar 20 09:11:23 2013: <191>162074: .Mar 20 09:11:22: //8140/1A91F618B3C9/CCAPI/cc_api_call_cut_progress:
Wed Mar 20 09:11:23 2013: <191>162075: Call Entry(Responsed=TRUE)
Wed Mar 20 09:11:23 2013: <191>162076: .Mar 20 09:11:22: //8139/1A91F618B3C9/CCAPI/ccCallCutProgress:
Wed Mar 20 09:11:23 2013: <191>162077: Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=0
Wed Mar 20 09:11:23 2013: <191>162078: Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
Wed Mar 20 09:11:23 2013: <191>162079: .Mar 20 09:11:22: //8139/1A91F618B3C9/CCAPI/ccCallCutProgress:
Wed Mar 20 09:11:23 2013: <191>162080: Call Entry(Responsed=TRUE)
Wed Mar 20 09:11:23 2013: <191>162081: .Mar 20 09:11:22: //8139/1A91F618B3C9/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:11:23 2013: <191>162082:
Wed Mar 20 09:11:23 2013: <191>162083: Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:11:23 2013: <191>162084: Tone Direction=Network, Params=0x0, Call Id=8139
Wed Mar 20 09:11:23 2013: <191>162085: .Mar 20 09:11:22: //8139/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:11:23 2013: <191>162086: (confID=0x4BB021E8, callID1=0x1FCB, callID2=0x1FCC, tag=0x0)
Wed Mar 20 09:11:23 2013: <191>162087: .Mar 20 09:11:22: //8139/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:11:23 2013: <191>162088: (confID=0x4BB021E8, callID1=0x1FCB, gcid=1A91F618-908E11E2-B3C9DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:11:23 2013: <191>162089: .Mar 20 09:11:22: //8140/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:11:23 2013: <191>162090: (confID=0x4BB021E8, callID2=0x1FCC, gcid=1A91F618-908E11E2-B3C9DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:11:23 2013: <191>162091: .Mar 20 09:11:22: //8139/1A91F618B3C9/CCAPI/ccConferenceCreate:
Wed Mar 20 09:11:23 2013: <191>162092: Conference Id=0x4BB021E8, Call Id1=8139, Call Id2=8140, Tag=0x0
Wed Mar 20 09:11:23 2013: <191>162093: .Mar 20 09:11:22: //8139/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:11:23 2013: <191>162094: Conference Id=0xE53, Source Interface=0x4B805B90, Source Call Id=8139,
Wed Mar 20 09:11:23 2013: <191>162095: Destination Call Id=8140, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:11:23 2013: <191>162096: .Mar 20 09:11:22: //8140/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:11:23 2013: <191>162097: Conference Id=0xE53, Source Interface=0x4987DFD8, Source Call Id=8140,
Wed Mar 20 09:11:23 2013: <191>162098: Destination Call Id=8139, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:11:23 2013: <191>162099: .Mar 20 09:11:22: //8139/1A91F618B3C9/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:11:23 2013: <191>162100: Conference Id=0xE53, Source Interface=0x4987DFD8, Source Call Id=8140,
Wed Mar 20 09:11:23 2013: <191>162101: Destination Call Id=8139, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:11:23 2013: <191>162102: .Mar 20 09:11:22: //8139/1A91F618B3C9/CCAPI/ccConferenceCreate:
Wed Mar 20 09:11:23 2013: <191>162103:
Wed Mar 20 09:11:23 2013: <191>162104: Call Entry(Conference Id=0xE53, Destination Call Id=8140)
Wed Mar 20 09:11:23 2013: <191>162105: .Mar 20 09:11:22: //8140/1A91F618B3C9/CCAPI/ccConferenceCreate:
Wed Mar 20 09:11:23 2013: <191>162106: Call Entry(Conference Id=0xE53, Destination Call Id=8139)
Wed Mar 20 09:11:23 2013: <191>162107: .Mar 20 09:11:22: //8139/1A91F618B3C9/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:11:23 2013: <191>162108: Destination Interface=0x4987DFD8, Destination Call Id=8140, Source Call Id=8139,
Wed Mar 20 09:11:23 2013: <191>162111: .Mar 20 09:11:22: //8139/1A91F618B3C9/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:11:23 2013: <191>162112: Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:11:23 2013: <191>162120: Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:11:23 2013: <191>162131: Conference Id=0xE53, Call Id1=8139, Call Id2=8140
Wed Mar 20 09:11:23 2013: <191>162132: .Mar 20 09:11:22: //8139/1A91F618B3C9/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:11:24 2013: <191>162138: Feature Type=25, Call Id=8139
Wed Mar 20 09:11:24 2013: <191>162139: .Mar 20 09:11:22: //8140/1A91F618B3C9/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:11:24 2013: <191>162140: Call Id=8140
Wed Mar 20 09:11:24 2013: <191>162141: .Mar 20 09:11:22: //8140/1A91F618B3C9/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:11:24 2013: <191>162142: Call Entry(Context=0x4BA75988)
Wed Mar 20 09:11:26 2013: <191>162143: .Mar 20 09:11:25: //8139/1A91F618B3C9/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:11:26 2013: <191>162144: Cause Value=16, Interface=0x4B805B90, Call Id=8139
Wed Mar 20 09:11:26 2013: <191>162145: .Mar 20 09:11:25: //8139/1A91F618B3C9/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:11:26 2013: <191>162146: Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:11:26 2013: <191>162147: .Mar 20 09:11:25: //8139/1A91F618B3C9/CCAPI/ccConferenceDestroy:
Wed Mar 20 09:11:26 2013: <191>162148: Conference Id=0xE53, Tag=0x0
Wed Mar 20 09:11:26 2013: <191>162149: .Mar 20 09:11:25: //8139/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:11:26 2013: <191>162150: Conference Id=0xE53, Source Interface=0x4B805B90, Source Call Id=8139,
Wed Mar 20 09:11:26 2013: <191>162151: Destination Call Id=8140, Disposition=0x0, Tag=0x0
Wed Mar 20 09:11:26 2013: <191>162152: .Mar 20 09:11:25: //8140/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:11:26 2013: <191>162153:
Wed Mar 20 09:11:26 2013: <191>162154: Conference Id=0xE53, Source Interface=0x4987DFD8, Source Call Id=8140,
Wed Mar 20 09:11:26 2013: <191>162155: Destination Call Id=8139, Disposition=0x0, Tag=0x0
Wed Mar 20 09:11:26 2013: <191>162156: .Mar 20 09:11:25: //8139/1A91F618B3C9/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:11:26 2013: <191>162157: Conference Id=0xE53, Source Interface=0x4987DFD8, Source Call Id=8140,
Wed Mar 20 09:11:26 2013: <191>162158: Destination Call Id=8139, Disposition=0x0, Tag=0x0
Wed Mar 20 09:11:26 2013: <191>162159: .Mar 20 09:11:25: //8140/1A91F618B3C9/CCAPI/ccCallDisconnect:
Wed Mar 20 09:11:26 2013: <191>162160: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Wed Mar 20 09:11:26 2013: <191>162161: .Mar 20 09:11:25: //8140/1A91F618B3C9/CCAPI/ccCallDisconnect:
Wed Mar 20 09:11:26 2013: <191>162162: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:11:26 2013: <191>162163: .Mar 20 09:11:25: //8140/1A91F618B3C9/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:11:26 2013: <191>162164:
Wed Mar 20 09:11:26 2013: <191>162165: Transfer Number Is Null
Wed Mar 20 09:11:26 2013: <191>162166: .Mar 20 09:11:25: //8139/1A91F618B3C9/CCAPI/ccCallDisconnect:
Wed Mar 20 09:11:26 2013: <191>162167: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:11:26 2013: <191>162168: .Mar 20 09:11:25: //8139/1A91F618B3C9/CCAPI/ccCallDisconnect:
Wed Mar 20 09:11:26 2013: <191>162169: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:11:26 2013: <191>162170: .Mar 20 09:11:25: //8139/1A91F618B3C9/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:11:26 2013: <191>162171: Transfer Number Is Null
Wed Mar 20 09:11:26 2013: <191>162172: .Mar 20 09:11:25: //8139/1A91F618B3C9/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:11:26 2013: <191>162173: Disposition=0, Interface=0x4B805B90, Tag=0x0, Call Id=8139,
Wed Mar 20 09:11:26 2013: <191>162174: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:11:26 2013: <191>162175: .Mar 20 09:11:25: //8139/1A91F618B3C9/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:11:26 2013: <191>162176: Call Disconnect Event Sent
Wed Mar 20 09:11:26 2013: <191>162177: .Mar 20 09:11:25: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:11:26 2013: <191>162179: .Mar 20 09:11:25: :cc_free_feature_vsa freeing 47B81CE0
Wed Mar 20 09:11:26 2013: <191>162180: .Mar 20 09:11:25: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:11:26 2013: <191>162183: .Mar 20 09:11:25: //8140/1A91F618B3C9/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:11:26 2013: <191>162186: .Mar 20 09:11:25: //8140/1A91F618B3C9/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:11:26 2013: <191>162187: Call Disconnect Event Sent
Wed Mar 20 09:11:27 2013: <191>162188: .Mar 20 09:11:25: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:11:27 2013: <191>162189:
Wed Mar 20 09:11:27 2013: <191>162190: .Mar 20 09:11:25: :cc_free_feature_vsa freeing 47B81C00
Wed Mar 20 09:11:27 2013: <191>162191: .Mar 20 09:11:25: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:11:27 2013: <191>162192:
Wed Mar 20 09:11:27 2013: <191>162193: .Mar 20 09:11:25: vsacount in free is 0
Wed Mar 20 09:11:28 2013: <191>162194: .Mar 20 09:11:26: //-1/1FDC5A81B3CE/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:11:28 2013: <191>162195: cc_api_call_setup_ind_common:
Wed Mar 20 09:11:28 2013: <191>162196: cisco-username=
Wed Mar 20 09:11:28 2013: <191>162197: ----- ccCallInfo IE subfields -----
Wed Mar 20 09:11:28 2013: <191>162198: cisco-ani=1811032013
Wed Mar 20 09:11:28 2013: <191>162199: cisco-anitype=0
Wed Mar 20 09:11:28 2013: <191>162200: cisco-aniplan=0
Wed Mar 20 09:11:28 2013: <191>162201: cisco-anipi=0
Wed Mar 20 09:11:28 2013: <191>162202: cisco-anisi=0
Wed Mar 20 09:11:28 2013: <191>162203: dest=
Wed Mar 20 09:11:28 2013: <191>162204: cisco-desttype=0
Wed Mar 20 09:11:28 2013: <191>162205: cisco-destplan=0
Wed Mar 20 09:11:28 2013: <191>162206: cisco-rdie=FFFFFFFF
Wed Mar 20 09:11:28 2013: <191>162207: cisco-rdn=
Wed Mar 20 09:11:28 2013: <191>162208: cisco-lastrdn=
Wed Mar 20 09:11:28 2013: <191>162209: cisco-rdntype=0
Wed Mar 20 09:11:28 2013: <191>162210: cisco-rdnplan=0
Wed Mar 20 09:11:28 2013: <191>162211: cisco-rdnpi=0
Wed Mar 20 09:11:28 2013: <191>162212: cisco-rdnsi=0
Wed Mar 20 09:11:28 2013: <191>162213: cisco-redirectreason=0 fwd_final_type =0
Wed Mar 20 09:11:28 2013: <191>162214: final_redirectNumber =
Wed Mar 20 09:11:28 2013: <191>162215: hunt_group_timeout =0
Wed Mar 20 09:11:28 2013: <191>162216:
Wed Mar 20 09:11:28 2013: <191>162217: .Mar 20 09:11:26: //-1/1FDC5A81B3CE/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:11:28 2013: <191>162218:
Wed Mar 20 09:11:28 2013: <191>162219: Interface=0x4B805B90, Call Info(
Wed Mar 20 09:11:28 2013: <191>162220: Calling Number=1811032013,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:11:28 2013: <191>162221: Called Number=(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:11:28 2013: <191>162222: Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Wed Mar 20 09:11:28 2013: <191>162223: Incoming Dial-peer=20015, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Wed Mar 20 09:11:28 2013: <191>162224: Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:11:28 2013: <191>162225: .Mar 20 09:11:26: //-1/1FDC5A81B3CE/CCAPI/ccCheckClipClir:
Wed Mar 20 09:11:28 2013: <191>162226: In: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:11:28 2013: <191>162227: .Mar 20 09:11:26: //-1/1FDC5A81B3CE/CCAPI/ccCheckClipClir:
Wed Mar 20 09:11:28 2013: <191>162228: Out: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:11:28 2013: <191>162229: .Mar 20 09:11:26: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:11:28 2013: <191>162230:
Wed Mar 20 09:11:28 2013: <191>162231: .Mar 20 09:11:26: :cc_get_feature_vsa malloc success
Wed Mar 20 09:11:28 2013: <191>162232: .Mar 20 09:11:26: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:11:28 2013: <191>162233:
Wed Mar 20 09:11:28 2013: <191>162234: .Mar 20 09:11:26: cc_get_feature_vsa count is 1
Wed Mar 20 09:11:28 2013: <191>162235: .Mar 20 09:11:26: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:11:28 2013: <191>162236:
Wed Mar 20 09:11:28 2013: <191>162237: .Mar 20 09:11:26: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203326024,feature_id:8141
Wed Mar 20 09:11:28 2013: <191>162238: .Mar 20 09:11:26: //8141/1FDC5A81B3CE/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:11:28 2013: <191>162239:
Wed Mar 20 09:11:28 2013: <191>162240: Set Up Event Sent;
Wed Mar 20 09:11:28 2013: <191>162241: Call Info(Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:11:28 2013: <191>162243: .Mar 20 09:11:26: //8141/1FDC5A81B3CE/CCAPI/cc_process_call_setup_ind:
Wed Mar 20 09:11:28 2013: <191>162244: Event=0x4982C828
Wed Mar 20 09:11:28 2013: <191>162254: .Mar 20 09:11:26: //8141/1FDC5A81B3CE/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:11:28 2013: <191>162255: Stop Tone On Digit=TRUE, Tone=Dial Tone,
Wed Mar 20 09:11:28 2013: <191>162256: Tone Direction=Network, Params=0x0, Call Id=8141
Wed Mar 20 09:11:28 2013: <191>162257: .Mar 20 09:11:26: //8141/1FDC5A81B3CE/CCAPI/ccSetDigitTimeouts:
Wed Mar 20 09:11:29 2013: <191>162265: Enabled=TRUE, Call Id=8141
Wed Mar 20 09:11:29 2013: <191>162266: .Mar 20 09:11:26: //8141/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:29 2013: <191>162267: (vdbPtr=0x4B805B90, callID=0x1FCD, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Wed Mar 20 09:11:29 2013: <191>162268: .Mar 20 09:11:26: //8141/1FDC5A81B3CE/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:29 2013: <191>162269: Enabled=TRUE, Disposition=0x0, Interface=0x4B805B90, Call Id=8141
Wed Mar 20 09:11:29 2013: <191>162270: .Mar 20 09:11:26: //8141/1FDC5A81B3CE/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:29 2013: <191>162271: Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=8000(ms))
Wed Mar 20 09:11:29 2013: <191>162272: .Mar 20 09:11:28: //8141/1FDC5A81B3CE/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:11:29 2013: <191>162273: Cause Value=16, Interface=0x4B805B90, Call Id=8141
Wed Mar 20 09:11:29 2013: <191>162274: .Mar 20 09:11:28: //8141/1FDC5A81B3CE/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:11:29 2013: <191>162275: Call Entry(Responsed=FALSE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:11:29 2013: <191>162276: .Mar 20 09:11:28: //8141/1FDC5A81B3CE/CCAPI/ccCallDisconnect:
Wed Mar 20 09:11:29 2013: <191>162277: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:11:29 2013: <191>162278: .Mar 20 09:11:28: //8141/1FDC5A81B3CE/CCAPI/ccCallDisconnect:
Wed Mar 20 09:11:29 2013: <191>162279: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:11:29 2013: <191>162280: .Mar 20 09:11:28: //8141/1FDC5A81B3CE/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:11:29 2013: <191>162281: Transfer Number Is Null
Wed Mar 20 09:11:30 2013: <191>162282: .Mar 20 09:11:28: //8141/1FDC5A81B3CE/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:11:30 2013: <191>162283: Disposition=0, Interface=0x4B805B90, Tag=0x0, Call Id=8141,
Wed Mar 20 09:11:30 2013: <191>162284: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:11:30 2013: <191>162285: .Mar 20 09:11:28: //8141/1FDC5A81B3CE/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:11:30 2013: <191>162286: Call Disconnect Event Sent
Wed Mar 20 09:11:30 2013: <191>162287: .Mar 20 09:11:28: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:11:30 2013: <191>162288:
Wed Mar 20 09:11:30 2013: <191>162289: .Mar 20 09:11:28: :cc_free_feature_vsa freeing 47B94C40
Wed Mar 20 09:11:30 2013: <191>162290: .Mar 20 09:11:28: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:11:30 2013: <191>162291:
Wed Mar 20 09:11:30 2013: <191>162292: .Mar 20 09:11:28: vsacount in free is 0
Wed Mar 20 09:11:36 2013: <191>162293: .Mar 20 09:11:35: //-1/2529CD1EB3D2/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:11:36 2013: <191>162294: cc_api_call_setup_ind_common:
Wed Mar 20 09:11:36 2013: <191>162295: cisco-username=
Wed Mar 20 09:11:36 2013: <191>162296: ----- ccCallInfo IE subfields -----
Wed Mar 20 09:11:36 2013: <191>162297: cisco-ani=1811032013
Wed Mar 20 09:11:36 2013: <191>162298: cisco-anitype=0
Wed Mar 20 09:11:36 2013: <191>162299: cisco-aniplan=0
Wed Mar 20 09:11:36 2013: <191>162300: cisco-anipi=0
Wed Mar 20 09:11:36 2013: <191>162301: cisco-anisi=0
Wed Mar 20 09:11:36 2013: <191>162302: dest=
Wed Mar 20 09:11:36 2013: <191>162303: cisco-desttype=0
Wed Mar 20 09:11:36 2013: <191>162304: cisco-destplan=0
Wed Mar 20 09:11:36 2013: <191>162305: cisco-rdie=FFFFFFFF
Wed Mar 20 09:11:36 2013: <191>162306: cisco-rdn=
Wed Mar 20 09:11:36 2013: <191>162307: cisco-lastrdn=
Wed Mar 20 09:11:36 2013: <191>162308: cisco-rdntype=0
Wed Mar 20 09:11:36 2013: <191>162309: cisco-rdnplan=0
Wed Mar 20 09:11:36 2013: <191>162310: cisco-rdnpi=0
Wed Mar 20 09:11:36 2013: <191>162311: cisco-rdnsi=0
Wed Mar 20 09:11:36 2013: <191>162312: cisco-redirectreason=0 fwd_final_type =0
Wed Mar 20 09:11:36 2013: <191>162313: final_redirectNumber =
Wed Mar 20 09:11:37 2013: <191>162314: hunt_group_timeout =0
Wed Mar 20 09:11:37 2013: <191>162315:
Wed Mar 20 09:11:37 2013: <191>162316: .Mar 20 09:11:35: //-1/2529CD1EB3D2/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:11:37 2013: <191>162317:
Wed Mar 20 09:11:37 2013: <191>162318: Interface=0x4B805B90, Call Info(
Wed Mar 20 09:11:37 2013: <191>162319: Calling Number=1811032013,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:11:37 2013: <191>162320: Called Number=(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:11:37 2013: <191>162321: Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Wed Mar 20 09:11:37 2013: <191>162322: Incoming Dial-peer=20015, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Wed Mar 20 09:11:37 2013: <191>162323: Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:11:37 2013: <191>162324: .Mar 20 09:11:35: //-1/2529CD1EB3D2/CCAPI/ccCheckClipClir:
Wed Mar 20 09:11:37 2013: <191>162325: In: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:11:37 2013: <191>162326: .Mar 20 09:11:35: //-1/2529CD1EB3D2/CCAPI/ccCheckClipClir:
Wed Mar 20 09:11:37 2013: <191>162327: Out: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:11:37 2013: <191>162328: .Mar 20 09:11:35: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:11:37 2013: <191>162329:
Wed Mar 20 09:11:37 2013: <191>162330: .Mar 20 09:11:35: :cc_get_feature_vsa malloc success
Wed Mar 20 09:11:37 2013: <191>162331: .Mar 20 09:11:35: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:11:37 2013: <191>162332:
Wed Mar 20 09:11:37 2013: <191>162333: .Mar 20 09:11:35: cc_get_feature_vsa count is 1
Wed Mar 20 09:11:37 2013: <191>162334: .Mar 20 09:11:35: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:11:37 2013: <191>162335:
Wed Mar 20 09:11:37 2013: <191>162336: .Mar 20 09:11:35: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203248360,feature_id:8142
Wed Mar 20 09:11:37 2013: <191>162337: .Mar 20 09:11:35: //8142/2529CD1EB3D2/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:11:37 2013: <191>162338:
Wed Mar 20 09:11:37 2013: <191>162339: Set Up Event Sent;
Wed Mar 20 09:11:37 2013: <191>162340: Call Info(Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:11:37 2013: <191>162343: Event=0x4982C828
Wed Mar 20 09:11:37 2013: <191>162344: .Mar 20 09:11:35: //8142/2529CD1EB3D2/CCAPI/ccCallSetContext:
Wed Mar 20 09:11:37 2013: <191>162349: Call Id=8142
Wed Mar 20 09:11:37 2013: <191>162350: .Mar 20 09:11:35: //8142/2529CD1EB3D2/CCAPI/cc_api_set_transfer_info:
Wed Mar 20 09:11:37 2013: <191>162351:
Wed Mar 20 09:11:37 2013: <191>162352: Transfer Number=, Transfer Reason=0x0
Wed Mar 20 09:11:37 2013: <191>162353: .Mar 20 09:11:35: //8142/2529CD1EB3D2/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:11:37 2013: <191>162361: (callID=0x1FCE, digit_event=0x1, enable=TRUE, consume=FALSE)
Wed Mar 20 09:11:37 2013: <191>162362: .Mar 20 09:11:35: //8142/2529CD1EB3D2/CCAPI/ccCallReportDigits:
Wed Mar 20 09:11:37 2013: <191>162363:
Wed Mar 20 09:11:37 2013: <191>162364: Enabled=TRUE, Call Id=8142
Wed Mar 20 09:11:37 2013: <191>162365: .Mar 20 09:11:35: //8142/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:37 2013: <191>162366: (vdbPtr=0x4B805B90, callID=0x1FCE, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Wed Mar 20 09:11:37 2013: <191>162367: .Mar 20 09:11:35: //8142/2529CD1EB3D2/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:37 2013: <191>162368: Enabled=TRUE, Disposition=0x0, Interface=0x4B805B90, Call Id=8142
Wed Mar 20 09:11:37 2013: <191>162369: .Mar 20 09:11:35: //8142/2529CD1EB3D2/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:37 2013: <191>162370: Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=8000(ms))
Wed Mar 20 09:11:39 2013: <191>162371: .Mar 20 09:11:38: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:11:39 2013: <191>162372: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:39 2013: <191>162373: Source Call Id=8142, Digit=0, DigitBeginFlags=0x0,
Wed Mar 20 09:11:39 2013: <191>162374: Rtp Timestamp=0xE4C28, Rtp Expiration=0x0
Wed Mar 20 09:11:39 2013: <191>162375: .Mar 20 09:11:38: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:39 2013: <191>162376: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:39 2013: <191>162377: Source Call Id=8142, Digit=0, Duration=100,
Wed Mar 20 09:11:39 2013: <191>162378: Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:11:39 2013: <191>162379: .Mar 20 09:11:38: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:39 2013: <191>162380: Call Entry(Handoff Depth=0)
Wed Mar 20 09:11:39 2013: <191>162381: .Mar 20 09:11:38: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:11:39 2013: <191>162382:
Wed Mar 20 09:11:40 2013: <191>162383: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:40 2013: <191>162384: Source Call Id=8142, Digit=3, DigitBeginFlags=0x0,
Wed Mar 20 09:11:40 2013: <191>162385: Rtp Timestamp=0xEC928, Rtp Expiration=0x0
Wed Mar 20 09:11:40 2013: <191>162386: .Mar 20 09:11:38: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:40 2013: <191>162387: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:40 2013: <191>162388: Source Call Id=8142, Digit=3, Duration=100,
Wed Mar 20 09:11:40 2013: <191>162389: Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:11:40 2013: <191>162390: .Mar 20 09:11:38: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:40 2013: <191>162391: Call Entry(Handoff Depth=0)
Wed Mar 20 09:11:40 2013: <191>162392: .Mar 20 09:11:38: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:11:40 2013: <191>162393:
Wed Mar 20 09:11:40 2013: <191>162394: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:40 2013: <191>162395: Source Call Id=8142, Digit=3, DigitBeginFlags=0x0,
Wed Mar 20 09:11:40 2013: <191>162396: Rtp Timestamp=0xF4628, Rtp Expiration=0x0
Wed Mar 20 09:11:40 2013: <191>162397: .Mar 20 09:11:38: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:40 2013: <191>162398: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:40 2013: <191>162399: Source Call Id=8142, Digit=3, Duration=100,
Wed Mar 20 09:11:40 2013: <191>162400: Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:11:40 2013: <191>162401: .Mar 20 09:11:38: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:40 2013: <191>162402: Call Entry(Handoff Depth=0)
Wed Mar 20 09:11:40 2013: <191>162403: .Mar 20 09:11:39: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:11:40 2013: <191>162404:
Wed Mar 20 09:11:40 2013: <191>162405: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:40 2013: <191>162406: Source Call Id=8142, Digit=2, DigitBeginFlags=0x0,
Wed Mar 20 09:11:40 2013: <191>162407: Rtp Timestamp=0xFC328, Rtp Expiration=0x0
Wed Mar 20 09:11:40 2013: <191>162408: .Mar 20 09:11:39: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:40 2013: <191>162409: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:40 2013: <191>162410: Source Call Id=8142, Digit=2, Duration=100,
Wed Mar 20 09:11:40 2013: <191>162411: Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:11:40 2013: <191>162412: .Mar 20 09:11:39: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:40 2013: <191>162413: Call Entry(Handoff Depth=0)
Wed Mar 20 09:11:40 2013: <191>162414: .Mar 20 09:11:39: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:11:40 2013: <191>162415:
Wed Mar 20 09:11:40 2013: <191>162416: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:40 2013: <191>162417: Source Call Id=8142, Digit=4, DigitBeginFlags=0x0,
Wed Mar 20 09:11:40 2013: <191>162418: Rtp Timestamp=0x104028, Rtp Expiration=0x0
Wed Mar 20 09:11:40 2013: <191>162419: .Mar 20 09:11:39: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:40 2013: <191>162420: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:40 2013: <191>162421: Source Call Id=8142, Digit=4, Duration=100,
Wed Mar 20 09:11:40 2013: <191>162422: Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:11:40 2013: <191>162423: .Mar 20 09:11:39: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:40 2013: <191>162424: Call Entry(Handoff Depth=0)
Wed Mar 20 09:11:40 2013: <191>162425: .Mar 20 09:11:39: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:11:40 2013: <191>162426:
Wed Mar 20 09:11:41 2013: <191>162427: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:41 2013: <191>162428: Source Call Id=8142, Digit=1, DigitBeginFlags=0x0,
Wed Mar 20 09:11:41 2013: <191>162429: Rtp Timestamp=0x10BD28, Rtp Expiration=0x0
Wed Mar 20 09:11:41 2013: <191>162430: .Mar 20 09:11:39: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:41 2013: <191>162431: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:41 2013: <191>162432: Source Call Id=8142, Digit=1, Duration=100,
Wed Mar 20 09:11:41 2013: <191>162433: Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:11:41 2013: <191>162434: .Mar 20 09:11:39: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:41 2013: <191>162435: Call Entry(Handoff Depth=0)
Wed Mar 20 09:11:41 2013: <191>162436: .Mar 20 09:11:40: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:11:41 2013: <191>162437:
Wed Mar 20 09:11:41 2013: <191>162438: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:41 2013: <191>162439: Source Call Id=8142, Digit=5, DigitBeginFlags=0x0,
Wed Mar 20 09:11:41 2013: <191>162440: Rtp Timestamp=0x113A28, Rtp Expiration=0x0
Wed Mar 20 09:11:41 2013: <191>162441: .Mar 20 09:11:40: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:41 2013: <191>162442: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:41 2013: <191>162443: Source Call Id=8142, Digit=5, Duration=100,
Wed Mar 20 09:11:41 2013: <191>162444: Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:11:41 2013: <191>162445: .Mar 20 09:11:40: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:41 2013: <191>162446: Call Entry(Handoff Depth=0)
Wed Mar 20 09:11:41 2013: <191>162447: .Mar 20 09:11:40: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:11:41 2013: <191>162448:
Wed Mar 20 09:11:41 2013: <191>162449: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:41 2013: <191>162450: Source Call Id=8142, Digit=4, DigitBeginFlags=0x0,
Wed Mar 20 09:11:41 2013: <191>162451: Rtp Timestamp=0x11B728, Rtp Expiration=0x0
Wed Mar 20 09:11:41 2013: <191>162452: .Mar 20 09:11:40: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:41 2013: <191>162453: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:41 2013: <191>162454: Source Call Id=8142, Digit=4, Duration=100,
Wed Mar 20 09:11:41 2013: <191>162455: Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:11:41 2013: <191>162456: .Mar 20 09:11:40: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:41 2013: <191>162457: Call Entry(Handoff Depth=0)
Wed Mar 20 09:11:41 2013: <191>162458: .Mar 20 09:11:40: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:11:41 2013: <191>162459:
Wed Mar 20 09:11:41 2013: <191>162460: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:41 2013: <191>162461: Source Call Id=8142, Digit=1, DigitBeginFlags=0x0,
Wed Mar 20 09:11:41 2013: <191>162462: Rtp Timestamp=0x123428, Rtp Expiration=0x0
Wed Mar 20 09:11:41 2013: <191>162463: .Mar 20 09:11:40: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:41 2013: <191>162464: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:11:41 2013: <191>162465: Source Call Id=8142, Digit=1, Duration=100,
Wed Mar 20 09:11:41 2013: <191>162466: Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:11:41 2013: <191>162467: .Mar 20 09:11:40: //8142/2529CD1EB3D2/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:11:41 2013: <191>162468: Call Entry(Handoff Depth=0)
Wed Mar 20 09:11:41 2013: <191>162469: .Mar 20 09:11:40: //8142/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
Wed Mar 20 09:11:41 2013: <191>162470: (callID=0x1FCE, digit_event=0x0, enable=FALSE, consume=FALSE)
Wed Mar 20 09:11:41 2013: <191>162471: .Mar 20 09:11:40: //8142/2529CD1EB3D2/CCAPI/ccCallReportDigits:
Wed Mar 20 09:11:41 2013: <191>162472: Enabled=TRUE, Call Id=8142
Wed Mar 20 09:11:41 2013: <191>162473: .Mar 20 09:11:40: //8142/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:41 2013: <191>162474: (vdbPtr=0x4B805B90, callID=0x1FCE, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Wed Mar 20 09:11:41 2013: <191>162475: .Mar 20 09:11:40: //8142/2529CD1EB3D2/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:41 2013: <191>162476: Enabled=TRUE, Disposition=0x0, Interface=0x4B805B90, Call Id=8142
Wed Mar 20 09:11:41 2013: <191>162477: .Mar 20 09:11:40: //8142/2529CD1EB3D2/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:11:41 2013: <191>162478: Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=8000(ms))
Wed Mar 20 09:11:41 2013: <191>162479: .Mar 20 09:11:40: //8142/2529CD1EB3D2/CCAPI/ccCallProceeding:
Wed Mar 20 09:11:41 2013: <191>162480: Progress Indication=NULL(0)
Wed Mar 20 09:11:41 2013: <191>162481: .Mar 20 09:11:40: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Wed Mar 20 09:11:41 2013: <191>162482: Try with the demoted called number 033241541
Wed Mar 20 09:11:41 2013: <191>162483: .Mar 20 09:11:40: //8142/2529CD1EB3D2/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:11:41 2013: <191>162484: Destination=, Calling IE Present=TRUE, Mode=0,
Wed Mar 20 09:11:41 2013: <191>162485: Outgoing Dial-peer=50, Params=0x4BA70DB8, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Wed Mar 20 09:11:41 2013: <191>162486: .Mar 20 09:11:40: //8142/2529CD1EB3D2/CCAPI/ccCheckClipClir:
Wed Mar 20 09:11:41 2013: <191>162487: In: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:11:41 2013: <191>162488: .Mar 20 09:11:40: //8142/2529CD1EB3D2/CCAPI/ccCheckClipClir:
Wed Mar 20 09:11:41 2013: <191>162489: Out: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:11:41 2013: <191>162492: .Mar 20 09:11:40: //8142/2529CD1EB3D2/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:11:41 2013: <191>162493: Calling Number=1811032013(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:11:41 2013: <191>162497: Guid=2529CD1E-908E-11E2-B3D2-DE08FC69A21F, Outgoing Dial-peer=50
Wed Mar 20 09:11:41 2013: <191>162499: ccCallSetupRequest:
Wed Mar 20 09:11:41 2013: <191>162500: cisco-username=
Wed Mar 20 09:11:41 2013: <191>162501: ----- ccCallInfo IE subfields -----
Wed Mar 20 09:11:41 2013: <191>162504: cisco-anitype=0
Wed Mar 20 09:11:41 2013: <191>162506: cisco-anipi=0
Wed Mar 20 09:11:41 2013: <191>162509: cisco-desttype=0
Wed Mar 20 09:11:41 2013: <191>162519: final_redirectNumber =
Wed Mar 20 09:11:41 2013: <191>162520: hunt_group_timeout =0
Wed Mar 20 09:11:41 2013: <191>162521:
Wed Mar 20 09:11:41 2013: <191>162522: .Mar 20 09:11:40: //8142/2529CD1EB3D2/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:11:41 2013: <191>162526: Called Number=033241541(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Wed Mar 20 09:11:41 2013: <191>162531: .Mar 20 09:11:40: :cc_get_feature_vsa malloc success
Wed Mar 20 09:11:41 2013: <191>162532: .Mar 20 09:11:40: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:11:42 2013: <191>162534: .Mar 20 09:11:40: cc_get_feature_vsa count is 2
Wed Mar 20 09:11:42 2013: <191>162535: .Mar 20 09:11:40: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:11:42 2013: <191>162536:
Wed Mar 20 09:11:42 2013: <191>162537: .Mar 20 09:11:40: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203248136,feature_id:8143
Wed Mar 20 09:11:42 2013: <191>162538: .Mar 20 09:11:40: //8143/2529CD1EB3D2/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:11:42 2013: <191>162539: SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Wed Mar 20 09:11:42 2013: <191>162540: .Mar 20 09:11:40: //8143/2529CD1EB3D2/CCAPI/ccCallSetContext:
Wed Mar 20 09:11:42 2013: <191>162541: Context=0x4BA70D68
Wed Mar 20 09:11:42 2013: <191>162542: .Mar 20 09:11:40: //8142/2529CD1EB3D2/CCAPI/ccSaveDialpeerTag:
Wed Mar 20 09:11:42 2013: <191>162543: Outgoing Dial-peer=50
Wed Mar 20 09:11:42 2013: <191>162544: .Mar 20 09:11:40: //8143/2529CD1EB3D2/CCAPI/cc_api_call_proceeding:
Wed Mar 20 09:11:42 2013: <191>162545: Interface=0x498845E0, Progress Indication=NULL(0)
Wed Mar 20 09:11:44 2013: <191>162546: .Mar 20 09:11:43: //8143/2529CD1EB3D2/CCAPI/cc_api_call_cut_progress:
Wed Mar 20 09:11:44 2013: <191>162547: Interface=0x498845E0, Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2),
Wed Mar 20 09:11:44 2013: <191>162548: Cause Value=0
Wed Mar 20 09:11:44 2013: <191>162549: .Mar 20 09:11:43: //8143/2529CD1EB3D2/CCAPI/cc_api_call_cut_progress:
Wed Mar 20 09:11:44 2013: <191>162550: Call Entry(Responsed=TRUE)
Wed Mar 20 09:11:44 2013: <191>162551: .Mar 20 09:11:43: //8142/2529CD1EB3D2/CCAPI/ccCallCutProgress:
Wed Mar 20 09:11:44 2013: <191>162552: Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=0
Wed Mar 20 09:11:44 2013: <191>162553: Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
Wed Mar 20 09:11:44 2013: <191>162554: .Mar 20 09:11:43: //8142/2529CD1EB3D2/CCAPI/ccCallCutProgress:
Wed Mar 20 09:11:44 2013: <191>162555: Call Entry(Responsed=TRUE)
Wed Mar 20 09:11:44 2013: <191>162556: .Mar 20 09:11:43: //8142/2529CD1EB3D2/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:11:44 2013: <191>162557:
Wed Mar 20 09:11:44 2013: <191>162558: Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:11:44 2013: <191>162559: Tone Direction=Network, Params=0x0, Call Id=8142
Wed Mar 20 09:11:44 2013: <191>162560: .Mar 20 09:11:43: //8142/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:11:44 2013: <191>162561: (confID=0x4BB01FA8, callID1=0x1FCE, callID2=0x1FCF, tag=0x0)
Wed Mar 20 09:11:44 2013: <191>162562: .Mar 20 09:11:43: //8142/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:11:44 2013: <191>162563: (confID=0x4BB01FA8, callID1=0x1FCE, gcid=2529CD1E-908E11E2-B3D2DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:11:44 2013: <191>162564: .Mar 20 09:11:43: //8143/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:11:44 2013: <191>162565: (confID=0x4BB01FA8, callID2=0x1FCF, gcid=2529CD1E-908E11E2-B3D2DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:11:44 2013: <191>162566: .Mar 20 09:11:43: //8142/2529CD1EB3D2/CCAPI/ccConferenceCreate:
Wed Mar 20 09:11:44 2013: <191>162567: Conference Id=0x4BB01FA8, Call Id1=8142, Call Id2=8143, Tag=0x0
Wed Mar 20 09:11:44 2013: <191>162568: .Mar 20 09:11:43: //8142/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:11:44 2013: <191>162569: Conference Id=0xE54, Source Interface=0x4B805B90, Source Call Id=8142,
Wed Mar 20 09:11:44 2013: <191>162570: Destination Call Id=8143, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:11:44 2013: <191>162571: .Mar 20 09:11:43: //8143/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:11:44 2013: <191>162572: Conference Id=0xE54, Source Interface=0x498845E0, Source Call Id=8143,
Wed Mar 20 09:11:44 2013: <191>162573: Destination Call Id=8142, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:11:44 2013: <191>162574: .Mar 20 09:11:43: //8142/2529CD1EB3D2/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:11:44 2013: <191>162575: Conference Id=0xE54, Source Interface=0x498845E0, Source Call Id=8143,
Wed Mar 20 09:11:44 2013: <191>162576: Destination Call Id=8142, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:11:44 2013: <191>162577: .Mar 20 09:11:43: //8142/2529CD1EB3D2/CCAPI/ccConferenceCreate:
Wed Mar 20 09:11:44 2013: <191>162578:
Wed Mar 20 09:11:44 2013: <191>162579: Call Entry(Conference Id=0xE54, Destination Call Id=8143)
Wed Mar 20 09:11:44 2013: <191>162580: .Mar 20 09:11:43: //8143/2529CD1EB3D2/CCAPI/ccConferenceCreate:
Wed Mar 20 09:11:44 2013: <191>162581: Call Entry(Conference Id=0xE54, Destination Call Id=8142)
Wed Mar 20 09:11:44 2013: <191>162582: .Mar 20 09:11:43: //8142/2529CD1EB3D2/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:11:44 2013: <191>162583: Destination Interface=0x498845E0, Destination Call Id=8143, Source Call Id=8142,
Wed Mar 20 09:11:44 2013: <191>162586: .Mar 20 09:11:43: //8142/2529CD1EB3D2/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:11:44 2013: <191>162587: Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:11:44 2013: <191>162588: Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:11:44 2013: <191>162589: .Mar 20 09:11:43: //8143/2529CD1EB3D2/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:11:44 2013: <191>162590:
Wed Mar 20 09:11:44 2013: <191>162591: Destination Interface=0x4B805B90, Destination Call Id=8142, Source Call Id=8143,
Wed Mar 20 09:11:44 2013: <191>162592: Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
Wed Mar 20 09:11:44 2013: <191>162593: Modem=0x2, Codec Bytes=160, Signal Type=2)
Wed Mar 20 09:11:44 2013: <191>162604: Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=5124)
Wed Mar 20 09:11:44 2013: <191>162605: .Mar 20 09:11:43: //8142/2529CD1EB3D2/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:11:44 2013: <191>162622: Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Wed Mar 20 09:11:44 2013: <191>162623: .Mar 20 09:11:43: //8142/2529CD1EB3D2/CCAPI/ccCallConnect:
Wed Mar 20 09:11:44 2013: <191>162624: Progress Indication=DESTINATION IS NON ISDN(2), Data Bitmask=0x1
Wed Mar 20 09:11:45 2013: <191>162625: .Mar 20 09:11:43: //8142/2529CD1EB3D2/CCAPI/ccCallConnect:
Wed Mar 20 09:11:45 2013: <191>162626: Call Entry(Connected=TRUE, Responsed=TRUE)
Wed Mar 20 09:11:45 2013: <191>162627: .Mar 20 09:11:43: //8142/2529CD1EB3D2/CCAPI/ccCallFeature:
Wed Mar 20 09:11:45 2013: <191>162628: Feature Type=25, Call Id=8142
Wed Mar 20 09:12:06 2013: <191>162629: .Mar 20 09:12:04: //-1/80F45E604006/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:12:06 2013: <191>162630: cc_api_call_setup_ind_common:
Wed Mar 20 09:12:06 2013: <191>162631: cisco-username=PF-Assis-Margarida
Wed Mar 20 09:12:06 2013: <191>162632: ----- ccCallInfo IE subfields -----
Wed Mar 20 09:12:06 2013: <191>162633: cisco-ani=1811032010
Wed Mar 20 09:12:06 2013: <191>162634: cisco-anitype=0
Wed Mar 20 09:12:06 2013: <191>162635: cisco-aniplan=0
Wed Mar 20 09:12:06 2013: <191>162636: cisco-anipi=0
Wed Mar 20 09:12:06 2013: <191>162637: cisco-anisi=1
Wed Mar 20 09:12:06 2013: <191>162638: dest=00151833669800
Wed Mar 20 09:12:06 2013: <191>162639: cisco-desttype=0
Wed Mar 20 09:12:06 2013: <191>162640: cisco-destplan=0
Wed Mar 20 09:12:06 2013: <191>162641: cisco-rdie=FFFFFFFF
Wed Mar 20 09:12:06 2013: <191>162642: cisco-rdn=
Wed Mar 20 09:12:06 2013: <191>162643: cisco-lastrdn=
Wed Mar 20 09:12:06 2013: <191>162644: cisco-rdntype=-1
Wed Mar 20 09:12:06 2013: <191>162645: cisco-rdnplan=-1
Wed Mar 20 09:12:06 2013: <191>162646: cisco-rdnpi=-1
Wed Mar 20 09:12:06 2013: <191>162647: cisco-rdnsi=-1
Wed Mar 20 09:12:06 2013: <191>162648: cisco-redirectreason=-1 fwd_final_type =0
Wed Mar 20 09:12:06 2013: <191>162649: final_redirectNumber =
Wed Mar 20 09:12:06 2013: <191>162650: hunt_group_timeout =0
Wed Mar 20 09:12:06 2013: <191>162651:
Wed Mar 20 09:12:06 2013: <191>162652: .Mar 20 09:12:04: //-1/80F45E604006/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:12:06 2013: <191>162653:
Wed Mar 20 09:12:06 2013: <191>162654: Interface=0x48A4F728, Call Info(
Wed Mar 20 09:12:06 2013: <191>162655: Calling Number=1811032010,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Wed Mar 20 09:12:06 2013: <191>162656: Called Number=00151833669800(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:12:06 2013: <191>162657: Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Wed Mar 20 09:12:06 2013: <191>162658: Incoming Dial-peer=200, Progress Indication=NULL(0), Calling IE Present=TRUE,
Wed Mar 20 09:12:06 2013: <191>162659: Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=8144
Wed Mar 20 09:12:06 2013: <191>162660: .Mar 20 09:12:04: //-1/80F45E604006/CCAPI/ccCheckClipClir:
Wed Mar 20 09:12:06 2013: <191>162661: In: Calling Number=1811032010(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Wed Mar 20 09:12:06 2013: <191>162662: .Mar 20 09:12:04: //-1/80F45E604006/CCAPI/ccCheckClipClir:
Wed Mar 20 09:12:06 2013: <191>162663: Out: Calling Number=1811032010(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Wed Mar 20 09:12:06 2013: <191>162664: .Mar 20 09:12:04: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:12:06 2013: <191>162665:
Wed Mar 20 09:12:06 2013: <191>162666: .Mar 20 09:12:04: :cc_get_feature_vsa malloc success
Wed Mar 20 09:12:06 2013: <191>162667: .Mar 20 09:12:04: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:12:06 2013: <191>162668:
Wed Mar 20 09:12:06 2013: <191>162669: .Mar 20 09:12:04: cc_get_feature_vsa count is 3
Wed Mar 20 09:12:06 2013: <191>162670: .Mar 20 09:12:04: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:12:06 2013: <191>162671:
Wed Mar 20 09:12:06 2013: <191>162672: .Mar 20 09:12:04: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203247912,feature_id:8144
Wed Mar 20 09:12:06 2013: <191>162673: .Mar 20 09:12:04: //8144/80F45E604006/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:12:06 2013: <191>162674:
Wed Mar 20 09:12:06 2013: <191>162675: Set Up Event Sent;
Wed Mar 20 09:12:06 2013: <191>162676: Call Info(Calling Number=1811032010(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Wed Mar 20 09:12:06 2013: <191>162677: Called Number=00151833669800(TON=Unknown, NPI=Unknown))
Wed Mar 20 09:12:06 2013: <191>162678: .Mar 20 09:12:04: //8144/80F45E604006/CCAPI/cc_process_call_setup_ind:
Wed Mar 20 09:12:06 2013: <191>162689: Try with the demoted called number 00151833669800
Wed Mar 20 09:12:06 2013: <191>162690: .Mar 20 09:12:04: //8144/80F45E604006/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:12:06 2013: <191>162691: Destination=, Calling IE Present=TRUE, Mode=0,
Wed Mar 20 09:12:06 2013: <191>162692: Outgoing Dial-peer=5, Params=0x4BA68880, Progress Indication=NULL(0)
Wed Mar 20 09:12:06 2013: <191>162705: Guid=80F45E60-96A7-9114-4006-E1040AE54028, Outgoing Dial-peer=5
Wed Mar 20 09:12:06 2013: <191>162706: .Mar 20 09:12:04: //8144/80F45E604006/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:12:06 2013: <191>162709: ----- ccCallInfo IE subfields -----
Wed Mar 20 09:12:06 2013: <191>162710: cisco-ani=1811032010
Wed Mar 20 09:12:06 2013: <191>162713: cisco-anipi=0
Wed Mar 20 09:12:06 2013: <191>162716: cisco-desttype=0
Wed Mar 20 09:12:06 2013: <191>162723: cisco-rdnpi=-1
Wed Mar 20 09:12:06 2013: <191>162724: cisco-rdnsi=-1
Wed Mar 20 09:12:06 2013: <191>162726: final_redirectNumber =
Wed Mar 20 09:12:06 2013: <191>162728:
Wed Mar 20 09:12:07 2013: <191>162741: .Mar 20 09:12:04: cc_get_feature_vsa count is 4
Wed Mar 20 09:12:07 2013: <191>162742: .Mar 20 09:12:04: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:12:07 2013: <191>162743:
Wed Mar 20 09:12:07 2013: <191>162744: .Mar 20 09:12:04: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203247688,feature_id:8145
Wed Mar 20 09:12:07 2013: <191>162745: .Mar 20 09:12:04: //8145/80F45E604006/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:12:07 2013: <191>162746: SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Wed Mar 20 09:12:07 2013: <191>162747: .Mar 20 09:12:04: //8145/80F45E604006/CCAPI/ccCallSetContext:
Wed Mar 20 09:12:07 2013: <191>162748: Context=0x4BA68830
Wed Mar 20 09:12:07 2013: <191>162749: .Mar 20 09:12:04: //8144/80F45E604006/CCAPI/ccSaveDialpeerTag:
Wed Mar 20 09:12:07 2013: <191>162750: Outgoing Dial-peer=5
Wed Mar 20 09:12:07 2013: <191>162751: .Mar 20 09:12:04: //8145/80F45E604006/CCAPI/cc_api_call_proceeding:
Wed Mar 20 09:12:07 2013: <191>162752: Interface=0x4987DFD8, Progress Indication=NULL(0)
Wed Mar 20 09:12:10 2013: <191>162753: .Mar 20 09:12:08: //8145/80F45E604006/CCAPI/cc_api_call_cut_progress:
Wed Mar 20 09:12:10 2013: <191>162754: Interface=0x4987DFD8, Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2),
Wed Mar 20 09:12:10 2013: <191>162755: Cause Value=0
Wed Mar 20 09:12:10 2013: <191>162756: .Mar 20 09:12:08: //8145/80F45E604006/CCAPI/cc_api_call_cut_progress:
Wed Mar 20 09:12:10 2013: <191>162757: Call Entry(Responsed=TRUE)
Wed Mar 20 09:12:10 2013: <191>162758: .Mar 20 09:12:08: //8144/80F45E604006/CCAPI/ccCallCutProgress:
Wed Mar 20 09:12:10 2013: <191>162759: Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=0
Wed Mar 20 09:12:10 2013: <191>162760: Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
Wed Mar 20 09:12:10 2013: <191>162761: .Mar 20 09:12:08: //8144/80F45E604006/CCAPI/ccCallCutProgress:
Wed Mar 20 09:12:10 2013: <191>162762: Call Entry(Responsed=TRUE)
Wed Mar 20 09:12:10 2013: <191>162763: .Mar 20 09:12:08: //8145/80F45E604006/CCAPI/cc_api_get_called_ccm_detected:
Wed Mar 20 09:12:10 2013: <191>162764: CallInfo(ccm detected=0)
Wed Mar 20 09:12:10 2013: <191>162765: .Mar 20 09:12:08: //8144/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:12:10 2013: <191>162766: (confID=0x4BB02110, callID1=0x1FD0, callID2=0x1FD1, tag=0x0)
Wed Mar 20 09:12:10 2013: <191>162767: .Mar 20 09:12:08: //8144/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:12:10 2013: <191>162768: (confID=0x4BB02110, callID1=0x1FD0, gcid=0-0-0-0, tag=0x0)
Wed Mar 20 09:12:10 2013: <191>162769: .Mar 20 09:12:08: //8145/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:12:10 2013: <191>162770: (confID=0x4BB02110, callID2=0x1FD1, gcid=0-0-0-0, tag=0x0)
Wed Mar 20 09:12:10 2013: <191>162771: .Mar 20 09:12:08: //8144/80F45E604006/CCAPI/ccConferenceCreate:
Wed Mar 20 09:12:10 2013: <191>162772: Conference Id=0x4BB02110, Call Id1=8144, Call Id2=8145, Tag=0x0
Wed Mar 20 09:12:10 2013: <191>162773: .Mar 20 09:12:08: //8144/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Wed Mar 20 09:12:10 2013: <191>162774:
Wed Mar 20 09:12:10 2013: <191>162775: .Mar 20 09:12:08: cc_api_get_xcode_stream : 4534
Wed Mar 20 09:12:10 2013: <191>162776: .Mar 20 09:12:08: //8144/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:12:10 2013: <191>162777: Conference Id=0xE55, Source Interface=0x48A4F728, Source Call Id=8144,
Wed Mar 20 09:12:10 2013: <191>162778: Destination Call Id=8145, Disposition=0x0, Tag=0x0
Wed Mar 20 09:12:10 2013: <191>162779: .Mar 20 09:12:08: //8145/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:12:10 2013: <191>162780: Conference Id=0xE55, Source Interface=0x4987DFD8, Source Call Id=8145,
Wed Mar 20 09:12:10 2013: <191>162781: Destination Call Id=8144, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:12:10 2013: <191>162782: .Mar 20 09:12:08: //8144/80F45E604006/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:12:10 2013: <191>162783: Conference Id=0xE55, Source Interface=0x4987DFD8, Source Call Id=8145,
Wed Mar 20 09:12:10 2013: <191>162784: Destination Call Id=8144, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:12:10 2013: <191>162785: .Mar 20 09:12:08: //8144/80F45E604006/CCAPI/ccConferenceCreate:
Wed Mar 20 09:12:10 2013: <191>162786:
Wed Mar 20 09:12:10 2013: <191>162787: Call Entry(Conference Id=0xE55, Destination Call Id=8145)
Wed Mar 20 09:12:10 2013: <191>162788: .Mar 20 09:12:08: //8145/80F45E604006/CCAPI/ccConferenceCreate:
Wed Mar 20 09:12:10 2013: <191>162789: Call Entry(Conference Id=0xE55, Destination Call Id=8144)
Wed Mar 20 09:12:10 2013: <191>162790: .Mar 20 09:12:08: //8145/80F45E604006/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:12:10 2013: <191>162799: Conference Id=0xE55, Call Id1=8144, Call Id2=8145
Wed Mar 20 09:12:10 2013: <191>162800: .Mar 20 09:12:08: //8144/80F45E604006/CCAPI/ccCallNotify:
Wed Mar 20 09:12:10 2013: <191>162801: Data Bitmask=0x7, Call Id=8144
Wed Mar 20 09:12:10 2013: <191>162802: .Mar 20 09:12:08: //8145/80F45E604006/CCAPI/cc_api_get_called_ccm_detected:
Wed Mar 20 09:12:10 2013: <191>162803: CallInfo(ccm detected=0)
Wed Mar 20 09:12:10 2013: <191>162804: .Mar 20 09:12:09: //8144/80F45E604006/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:12:10 2013: <191>162805: Destination Interface=0x4987DFD8, Destination Call Id=8145, Source Call Id=8144,
Wed Mar 20 09:12:10 2013: <191>162806: Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:12:10 2013: <191>162807: Modem=0x2, Codec Bytes=160, Signal Type=2)
Wed Mar 20 09:12:10 2013: <191>162808: .Mar 20 09:12:09: //8144/80F45E604006/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:12:10 2013: <191>162809: Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:12:10 2013: <191>162810: Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:12:10 2013: <191>162811: .Mar 20 09:12:09: //8144/80F45E604006/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:12:10 2013: <191>162812: Destination Interface=0x4987DFD8, Destination Call Id=8145, Source Call Id=8144,
Wed Mar 20 09:12:10 2013: <191>162813: Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:12:10 2013: <191>162814: Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=7077)
Wed Mar 20 09:12:10 2013: <191>162815: .Mar 20 09:12:09: //8145/80F45E604006/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:12:10 2013: <191>162816: Destination Interface=0x48A4F728, Destination Call Id=8144, Source Call Id=8145,
Wed Mar 20 09:12:10 2013: <191>162817: Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:12:10 2013: <191>162818: Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=7077)
Wed Mar 20 09:12:10 2013: <191>162819: .Mar 20 09:12:09: //8145/80F45E604006/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:12:10 2013: <191>162820: Call Id=8145
Wed Mar 20 09:12:11 2013: <191>162821: .Mar 20 09:12:09: //8145/80F45E604006/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:12:11 2013: <191>162822: Call Entry(Context=0x4BA68830)
Wed Mar 20 09:12:24 2013: <191>162823: .Mar 20 09:12:23: //8145/80F45E604006/CCAPI/cc_api_call_connected:
Wed Mar 20 09:12:24 2013: <191>162824: Interface=0x4987DFD8, Data Bitmask=0x1, Progress Indication=DESTINATION IS NON ISDN(2),
Wed Mar 20 09:12:24 2013: <191>162825: Connection Handle=0
Wed Mar 20 09:12:24 2013: <191>162826: .Mar 20 09:12:23: //8145/80F45E604006/CCAPI/cc_api_call_connected:
Wed Mar 20 09:12:24 2013: <191>162827: Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Wed Mar 20 09:12:24 2013: <191>162828: .Mar 20 09:12:23: //8144/80F45E604006/CCAPI/ccCallConnect:
Wed Mar 20 09:12:24 2013: <191>162829: Progress Indication=DESTINATION IS NON ISDN(2), Data Bitmask=0x1
Wed Mar 20 09:12:24 2013: <191>162830: .Mar 20 09:12:23: //8145/80F45E604006/CCAPI/cc_api_get_called_ccm_detected:
Wed Mar 20 09:12:24 2013: <191>162831: CallInfo(ccm detected=0)
Wed Mar 20 09:12:24 2013: <191>162832: .Mar 20 09:12:23: //8144/80F45E604006/CCAPI/ccCallConnect:
Wed Mar 20 09:12:24 2013: <191>162833: Call Entry(Connected=TRUE, Responsed=TRUE)
Wed Mar 20 09:12:25 2013: <191>162834: .Mar 20 09:12:23: //8144/80F45E604006/CCAPI/ccCallNotify:
Wed Mar 20 09:12:25 2013: <191>162835: Data Bitmask=0x7, Call Id=8144
Wed Mar 20 09:12:25 2013: <191>162836: .Mar 20 09:12:23: //8145/80F45E604006/CCAPI/cc_api_get_called_ccm_detected:
Wed Mar 20 09:12:25 2013: <191>162837: CallInfo(ccm detected=0)
Wed Mar 20 09:13:06 2013: <191>162838: .Mar 20 09:13:05: //8142/2529CD1EB3D2/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:13:06 2013: <191>162839: Cause Value=16, Interface=0x4B805B90, Call Id=8142
Wed Mar 20 09:13:06 2013: <191>162861: .Mar 20 09:13:05: //8143/2529CD1EB3D2/CCAPI/ccCallDisconnect:
Wed Mar 20 09:13:06 2013: <191>162840: .Mar 20 09:13:05: //8142/2529CD1EB3D2/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:13:06 2013: <191>162841: Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:13:06 2013: <191>162842: .Mar 20 09:13:05: //8142/2529CD1EB3D2/CCAPI/ccConferenceDestroy:
Wed Mar 20 09:13:06 2013: <191>162843: Conference Id=0xE54, Tag=0x0
Wed Mar 20 09:13:06 2013: <191>162844: .Mar 20 09:13:05: //8142/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:13:06 2013: <191>162845: Conference Id=0xE54, Source Interface=0x4B805B90, Source Call Id=8142,
Wed Mar 20 09:13:06 2013: <191>162846: Destination Call Id=8143, Disposition=0x0, Tag=0x0
Wed Mar 20 09:13:06 2013: <191>162847: .Mar 20 09:13:05: //8143/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:13:06 2013: <191>162848:
Wed Mar 20 09:13:06 2013: <191>162862: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Wed Mar 20 09:13:06 2013: <191>162849: Conference Id=0xE54, Source Interface=0x498845E0, Source Call Id=8143,
Wed Mar 20 09:13:06 2013: <191>162863: .Mar 20 09:13:05: //8143/2529CD1EB3D2/CCAPI/ccCallDisconnect:
Wed Mar 20 09:13:06 2013: <191>162850: Destination Call Id=8142, Disposition=0x0, Tag=0x0
Wed Mar 20 09:13:06 2013: <191>162851: .Mar 20 09:13:05: //8142/2529CD1EB3D2/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:13:06 2013: <191>162852: Conference Id=0xE54, Source Interface=0x498845E0, Source Call Id=8143,
Wed Mar 20 09:13:06 2013: <191>162864: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:13:06 2013: <191>162853: Destination Call Id=8142, Disposition=0x0, Tag=0x0
Wed Mar 20 09:13:06 2013: <191>162854: .Mar 20 09:13:05: //8142/2529CD1EB3D2/CCAPI/ccCallDisconnect:
Wed Mar 20 09:13:06 2013: <191>162865: .Mar 20 09:13:05: //8143/2529CD1EB3D2/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:13:06 2013: <191>162855: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:13:06 2013: <191>162856: .Mar 20 09:13:05: //8142/2529CD1EB3D2/CCAPI/ccCallDisconnect:
Wed Mar 20 09:13:06 2013: <191>162866: Transfer Number Is Null
Wed Mar 20 09:13:06 2013: <191>162857: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:13:06 2013: <191>162867: .Mar 20 09:13:05: //8142/2529CD1EB3D2/CCAPI/cc_api_call_feature:
Wed Mar 20 09:13:06 2013: <191>162868: Feature Type=6, Interface=0x4B805B90, Call Id=8142
Wed Mar 20 09:13:06 2013: <191>162858: .Mar 20 09:13:05: //8142/2529CD1EB3D2/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:13:06 2013: <191>162859:
Wed Mar 20 09:13:06 2013: <191>162860: Transfer Number Is Null
Wed Mar 20 09:13:06 2013: <191>162869: .Mar 20 09:13:05: //8142/2529CD1EB3D2/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:13:06 2013: <191>162870:
Wed Mar 20 09:13:06 2013: <191>162871: Disposition=0, Interface=0x4B805B90, Tag=0x0, Call Id=8142,
Wed Mar 20 09:13:06 2013: <191>162872: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:13:06 2013: <191>162873: .Mar 20 09:13:05: //8142/2529CD1EB3D2/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:13:06 2013: <191>162874: Call Disconnect Event Sent
Wed Mar 20 09:13:06 2013: <191>162875: .Mar 20 09:13:05: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:13:06 2013: <191>162876:
Wed Mar 20 09:13:06 2013: <191>162877: .Mar 20 09:13:05: :cc_free_feature_vsa freeing 47B81CE0
Wed Mar 20 09:13:06 2013: <191>162878: .Mar 20 09:13:05: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:13:06 2013: <191>162879:
Wed Mar 20 09:13:06 2013: <191>162880: .Mar 20 09:13:05: vsacount in free is 3
Wed Mar 20 09:13:06 2013: <191>162881: .Mar 20 09:13:05: //8143/2529CD1EB3D2/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:13:06 2013: <191>162882: Disposition=0, Interface=0x498845E0, Tag=0x0, Call Id=8143,
Wed Mar 20 09:13:06 2013: <191>162883: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:13:07 2013: <191>162884: .Mar 20 09:13:05: //8143/2529CD1EB3D2/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:13:07 2013: <191>162885: Call Disconnect Event Sent
Wed Mar 20 09:13:07 2013: <191>162886: .Mar 20 09:13:05: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:13:07 2013: <191>162887:
Wed Mar 20 09:13:07 2013: <191>162888: .Mar 20 09:13:05: :cc_free_feature_vsa freeing 47B81C00
Wed Mar 20 09:13:07 2013: <191>162889: .Mar 20 09:13:05: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:13:07 2013: <191>162890:
Wed Mar 20 09:13:07 2013: <191>162891: .Mar 20 09:13:05: vsacount in free is 2
Wed Mar 20 09:14:45 2013: <191>162892: .Mar 20 09:14:44: //-1/9561D059B3D9/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:14:45 2013: <191>162893: cc_api_call_setup_ind_common:
Wed Mar 20 09:14:45 2013: <191>162894: cisco-username=
Wed Mar 20 09:14:45 2013: <191>162895: ----- ccCallInfo IE subfields -----
Wed Mar 20 09:14:45 2013: <191>162896: cisco-ani=
Wed Mar 20 09:14:45 2013: <191>162897: cisco-anitype=0
Wed Mar 20 09:14:45 2013: <191>162898: cisco-aniplan=0
Wed Mar 20 09:14:45 2013: <191>162899: cisco-anipi=0
Wed Mar 20 09:14:45 2013: <191>162900: cisco-anisi=0
Wed Mar 20 09:14:45 2013: <191>162901: dest=1811032099
Wed Mar 20 09:14:45 2013: <191>162902: cisco-desttype=0
Wed Mar 20 09:14:45 2013: <191>162903: cisco-destplan=0
Wed Mar 20 09:14:45 2013: <191>162904: cisco-rdie=FFFFFFFF
Wed Mar 20 09:14:45 2013: <191>162905: cisco-rdn=
Wed Mar 20 09:14:45 2013: <191>162906: cisco-lastrdn=
Wed Mar 20 09:14:45 2013: <191>162907: cisco-rdntype=0
Wed Mar 20 09:14:45 2013: <191>162908: cisco-rdnplan=0
Wed Mar 20 09:14:45 2013: <191>162909: cisco-rdnpi=0
Wed Mar 20 09:14:45 2013: <191>162910: cisco-rdnsi=0
Wed Mar 20 09:14:45 2013: <191>162911: cisco-redirectreason=0 fwd_final_type =0
Wed Mar 20 09:14:45 2013: <191>162912: final_redirectNumber =
Wed Mar 20 09:14:45 2013: <191>162913: hunt_group_timeout =0
Wed Mar 20 09:14:45 2013: <191>162914:
Wed Mar 20 09:14:45 2013: <191>162915: .Mar 20 09:14:44: //-1/9561D059B3D9/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:14:45 2013: <191>162916:
Wed Mar 20 09:14:45 2013: <191>162917: Interface=0x4987FF98, Call Info(
Wed Mar 20 09:14:45 2013: <191>162918: Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:14:45 2013: <191>162919: Called Number=1811032099(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:14:45 2013: <191>162920: Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
Wed Mar 20 09:14:45 2013: <191>162921: Incoming Dial-peer=18, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
Wed Mar 20 09:14:45 2013: <191>162922: Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:14:45 2013: <191>162923: .Mar 20 09:14:44: //-1/9561D059B3D9/CCAPI/ccCheckClipClir:
Wed Mar 20 09:14:45 2013: <191>162924: In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:14:45 2013: <191>162925: .Mar 20 09:14:44: //-1/9561D059B3D9/CCAPI/ccCheckClipClir:
Wed Mar 20 09:14:45 2013: <191>162926: Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:14:45 2013: <191>162927: .Mar 20 09:14:44: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:14:45 2013: <191>162928:
Wed Mar 20 09:14:45 2013: <191>162929: .Mar 20 09:14:44: :cc_get_feature_vsa malloc success
Wed Mar 20 09:14:45 2013: <191>162930: .Mar 20 09:14:44: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:14:45 2013: <191>162931:
Wed Mar 20 09:14:45 2013: <191>162932: .Mar 20 09:14:44: cc_get_feature_vsa count is 3
Wed Mar 20 09:14:45 2013: <191>162933: .Mar 20 09:14:44: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:14:45 2013: <191>162934:
Wed Mar 20 09:14:45 2013: <191>162935: .Mar 20 09:14:44: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203248136,feature_id:8146
Wed Mar 20 09:14:45 2013: <191>162936: .Mar 20 09:14:44: //8146/9561D059B3D9/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:14:45 2013: <191>162937:
Wed Mar 20 09:14:45 2013: <191>162938: Set Up Event Sent;
Wed Mar 20 09:14:45 2013: <191>162939: Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:14:45 2013: <191>162941: .Mar 20 09:14:44: //8146/9561D059B3D9/CCAPI/cc_process_call_setup_ind:
Wed Mar 20 09:14:45 2013: <191>162945: .Mar 20 09:14:44: //8146/9561D059B3D9/CCAPI/ccCallSetContext:
Wed Mar 20 09:14:45 2013: <191>162946: Context=0x4BA7CBB8
Wed Mar 20 09:14:45 2013: <191>162947: .Mar 20 09:14:44: //8146/9561D059B3D9/CCAPI/cc_process_call_setup_ind:
Wed Mar 20 09:14:45 2013: <191>162948: >>>>CCAPI handed cid 8146 with tag 18 to app "_ManagedAppProcess_Default"
Wed Mar 20 09:14:45 2013: <191>162952: .Mar 20 09:14:44: //8146/9561D059B3D9/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:14:45 2013: <191>162963: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:14:45 2013: <191>162964: Called Number=1811032099(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:14:45 2013: <191>162965: Redirect Number=, Display Info=Linha_3322-5220
Wed Mar 20 09:14:45 2013: <191>162966: Account Number=, Final Destination Flag=TRUE,
Wed Mar 20 09:14:45 2013: <191>162970: cisco-username=
Wed Mar 20 09:14:45 2013: <191>162972: cisco-ani=
Wed Mar 20 09:14:45 2013: <191>162976:
Wed Mar 20 09:14:45 2013: <191>162978: dest=1811032099
Wed Mar 20 09:14:45 2013: <191>162982: cisco-rdn=
Wed Mar 20 09:14:45 2013: <191>162989: final_redirectNumber =
Wed Mar 20 09:14:45 2013: <191>162990: hunt_group_timeout =0
Wed Mar 20 09:14:45 2013: <191>163004: .Mar 20 09:14:44: cc_get_feature_vsa count is 4
Wed Mar 20 09:14:45 2013: <191>163005: .Mar 20 09:14:44: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:14:45 2013: <191>163006:
Wed Mar 20 09:14:45 2013: <191>163007: .Mar 20 09:14:44: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203248360,feature_id:8147
Wed Mar 20 09:14:45 2013: <191>163008: .Mar 20 09:14:44: //8147/9561D059B3D9/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:14:45 2013: <191>163009: SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Wed Mar 20 09:14:45 2013: <191>163010: .Mar 20 09:14:44: //8147/9561D059B3D9/CCAPI/ccCallSetContext:
Wed Mar 20 09:14:45 2013: <191>163011: Context=0x4BA6AE40
Wed Mar 20 09:14:45 2013: <191>163012: .Mar 20 09:14:44: //8146/9561D059B3D9/CCAPI/ccSaveDialpeerTag:
Wed Mar 20 09:14:45 2013: <191>163013: Outgoing Dial-peer=3000
Wed Mar 20 09:14:45 2013: <191>163014: .Mar 20 09:14:44: //8147/9561D059B3D9/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:14:45 2013: <191>163015: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:14:45 2013: <191>163016: .Mar 20 09:14:44: //8147/9561D059B3D9/CCAPI/cc_api_call_proceeding:
Wed Mar 20 09:14:45 2013: <191>163017: Interface=0x48A4F728, Progress Indication=NULL(0)
Wed Mar 20 09:14:45 2013: <191>163018: .Mar 20 09:14:44: //8147/9561D059B3D9/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:14:45 2013: <191>163019: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:14:45 2013: <191>163020: .Mar 20 09:14:44: //8147/9561D059B3D9/CCAPI/cc_api_set_delay_xport:
Wed Mar 20 09:14:45 2013: <191>163021: CallInfo(delay xport=TRUE)
Wed Mar 20 09:14:45 2013: <191>163022: .Mar 20 09:14:44: //8147/9561D059B3D9/CCAPI/cc_api_call_alert:
Wed Mar 20 09:14:45 2013: <191>163023: Interface=0x48A4F728, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:14:45 2013: <191>163024: .Mar 20 09:14:44: //8147/9561D059B3D9/CCAPI/cc_api_call_alert:
Wed Mar 20 09:14:45 2013: <191>163025: Call Entry(Retry Count=0, Responsed=TRUE)
Wed Mar 20 09:14:45 2013: <191>163026: .Mar 20 09:14:44: //8146/9561D059B3D9/CCAPI/ccCallAlert:
Wed Mar 20 09:14:45 2013: <191>163027:
Wed Mar 20 09:14:45 2013: <191>163028: Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:14:45 2013: <191>163029: .Mar 20 09:14:44: //8146/9561D059B3D9/CCAPI/ccCallAlert:
Wed Mar 20 09:14:45 2013: <191>163030: Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Wed Mar 20 09:14:45 2013: <191>163031: .Mar 20 09:14:44: //8147/9561D059B3D9/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:14:45 2013: <191>163032: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:14:45 2013: <191>163033: .Mar 20 09:14:44: //8147/9561D059B3D9/CCAPI/cc_api_call_notify:
Wed Mar 20 09:14:45 2013: <191>163034: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8147
Wed Mar 20 09:14:45 2013: <191>163035: .Mar 20 09:14:44: //8147/9561D059B3D9/CCAPI/ccIsInfoRingback:
Wed Mar 20 09:14:45 2013: <191>163036: Returning dpRingBack=0
Wed Mar 20 09:14:45 2013: <191>163037: .Mar 20 09:14:44: //8147/9561D059B3D9/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:14:45 2013: <191>163038: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:14:45 2013: <191>163039: .Mar 20 09:14:44: //8147/9561D059B3D9/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:14:45 2013: <191>163040: CallInfo(ccm detected=TRUE)
Wed Mar 20 09:14:45 2013: <191>163041: .Mar 20 09:14:44: //8146/9561D059B3D9/CCAPI/ccCallNotify:
Wed Mar 20 09:14:45 2013: <191>163042: Data Bitmask=0x5, Call Id=8146
Wed Mar 20 09:14:45 2013: <191>163043: .Mar 20 09:14:44: //8147/9561D059B3D9/CCAPI/cc_api_call_connected:
Wed Mar 20 09:14:45 2013: <191>163044: Interface=0x48A4F728, Data Bitmask=0x0, Progress Indication=NULL(0),
Wed Mar 20 09:14:45 2013: <191>163045: Connection Handle=0
Wed Mar 20 09:14:45 2013: <191>163046: .Mar 20 09:14:44: //8147/9561D059B3D9/CCAPI/cc_api_call_connected:
Wed Mar 20 09:14:45 2013: <191>163047: Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Wed Mar 20 09:14:45 2013: <191>163048: .Mar 20 09:14:44: //8147/9561D059B3D9/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:14:45 2013: <191>163049: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:14:45 2013: <191>163050: .Mar 20 09:14:44: //8147/9561D059B3D9/CCAPI/cc_api_call_notify:
Wed Mar 20 09:14:45 2013: <191>163051:
Wed Mar 20 09:14:45 2013: <191>163052: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8147
Wed Mar 20 09:14:45 2013: <191>163053: .Mar 20 09:14:44: //8146/9561D059B3D9/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:14:45 2013: <191>163054: Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:14:45 2013: <191>163055: Tone Direction=Network, Params=0x0, Call Id=8146
Wed Mar 20 09:14:45 2013: <191>163056: .Mar 20 09:14:44: //8146/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:14:45 2013: <191>163057: (confID=0x4BB01FF0, callID1=0x1FD2, callID2=0x1FD3, tag=0x0)
Wed Mar 20 09:14:45 2013: <191>163058: .Mar 20 09:14:44: //8146/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:14:45 2013: <191>163059: (confID=0x4BB01FF0, callID1=0x1FD2, gcid=9561D059-908E11E2-B3D9DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:14:45 2013: <191>163060: .Mar 20 09:14:44: //8147/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:14:45 2013: <191>163061: (confID=0x4BB01FF0, callID2=0x1FD3, gcid=9561D059-908E11E2-B3D9DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:14:45 2013: <191>163062: .Mar 20 09:14:44: //8146/9561D059B3D9/CCAPI/ccConferenceCreate:
Wed Mar 20 09:14:45 2013: <191>163063: Conference Id=0x4BB01FF0, Call Id1=8146, Call Id2=8147, Tag=0x0
Wed Mar 20 09:14:45 2013: <191>163064: .Mar 20 09:14:44: //8146/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:14:45 2013: <191>163065: Conference Id=0xE56, Source Interface=0x4987FF98, Source Call Id=8146,
Wed Mar 20 09:14:45 2013: <191>163066: Destination Call Id=8147, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:14:45 2013: <191>163067: .Mar 20 09:14:44: //8147/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Wed Mar 20 09:14:45 2013: <191>163068:
Wed Mar 20 09:14:45 2013: <191>163069: .Mar 20 09:14:44: cc_api_get_xcode_stream : 4534
Wed Mar 20 09:14:45 2013: <191>163070: .Mar 20 09:14:44: //8147/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:14:45 2013: <191>163071: Conference Id=0xE56, Source Interface=0x48A4F728, Source Call Id=8147,
Wed Mar 20 09:14:45 2013: <191>163072: Destination Call Id=8146, Disposition=0x0, Tag=0x0
Wed Mar 20 09:14:45 2013: <191>163073: .Mar 20 09:14:44: //8146/9561D059B3D9/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:14:45 2013: <191>163074: Conference Id=0xE56, Source Interface=0x48A4F728, Source Call Id=8147,
Wed Mar 20 09:14:45 2013: <191>163075: Destination Call Id=8146, Disposition=0x0, Tag=0x0
Wed Mar 20 09:14:45 2013: <191>163076: .Mar 20 09:14:44: //8146/9561D059B3D9/CCAPI/ccConferenceCreate:
Wed Mar 20 09:14:45 2013: <191>163082: Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
Wed Mar 20 09:14:45 2013: <191>163090: Destination Interface=0x4987FF98, Destination Call Id=8146, Source Call Id=8147,
Wed Mar 20 09:14:45 2013: <191>163091: Caps(Codec=0x4, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:14:45 2013: <191>163101: .Mar 20 09:14:44: //8146/9561D059B3D9/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:14:45 2013: <191>163104: Modem=ON(0x2), Codec Bytes=20, Signal Type=2, Seq Num Start=3343)
Wed Mar 20 09:14:45 2013: <191>163105: .Mar 20 09:14:44: //8147/9561D059B3D9/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:14:45 2013: <191>163106: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:14:45 2013: <191>163110: Data Bitmask=0x5, Call Id=8146
Wed Mar 20 09:14:45 2013: <191>163111: .Mar 20 09:14:44: //8146/9561D059B3D9/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:14:45 2013: <191>163112: Call Id=8146
Wed Mar 20 09:14:45 2013: <191>163113: .Mar 20 09:14:44: //8146/9561D059B3D9/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:14:45 2013: <191>163116: Progress Indication=NULL(0), Data Bitmask=0x0
Wed Mar 20 09:14:45 2013: <191>163117: .Mar 20 09:14:44: //8146/9561D059B3D9/CCAPI/ccCallConnect:
Wed Mar 20 09:14:45 2013: <191>163118:
Wed Mar 20 09:14:46 2013: <191>163119: Call Entry(Connected=TRUE, Responsed=TRUE)
Wed Mar 20 09:14:56 2013: <191>163120: .Mar 20 09:14:55: //8147/9561D059B3D9/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:14:56 2013: <191>163121: Interface=0x0, Call Id=8147
Wed Mar 20 09:14:56 2013: <191>163122: .Mar 20 09:14:55: //8147/9561D059B3D9/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:14:56 2013: <191>163123: Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:14:56 2013: <191>163124: .Mar 20 09:14:55: //8147/9561D059B3D9/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:14:56 2013: <191>163125: Interface=0x48A4F728, Signal Indication=NOT PRESENT(255)
Wed Mar 20 09:14:56 2013: <191>163126: .Mar 20 09:14:55: //8146/9561D059B3D9/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:14:56 2013: <191>163127: Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:14:56 2013: <191>163128: Tone Direction=Network, Params=0x0, Call Id=8146
Wed Mar 20 09:14:56 2013: <191>163129: .Mar 20 09:14:55: //8147/9561D059B3D9/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:14:56 2013: <191>163130: Interface=0x48A4F728, Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:14:56 2013: <191>163131: .Mar 20 09:14:55: //8146/9561D059B3D9/CCAPI/ccCallUserInfo:
Wed Mar 20 09:14:56 2013: <191>163132: Call Id=8146
Wed Mar 20 09:14:56 2013: <191>163133: .Mar 20 09:14:55: //8146/9561D059B3D9/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:14:56 2013: <191>163134: Stop Tone On Digit=FALSE, Tone=Ring Back,
Wed Mar 20 09:14:56 2013: <191>163135: Tone Direction=Network, Params=0x0, Call Id=8146
Wed Mar 20 09:14:56 2013: <191>163136: .Mar 20 09:14:55: //8147/9561D059B3D9/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:14:56 2013: <191>163137: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:14:56 2013: <191>163138: .Mar 20 09:14:55: //8147/9561D059B3D9/CCAPI/cc_api_call_notify:
Wed Mar 20 09:14:56 2013: <191>163139: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8147
Wed Mar 20 09:14:56 2013: <191>163140: .Mar 20 09:14:55: //8147/9561D059B3D9/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:14:56 2013: <191>163141: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:14:57 2013: <191>163142: .Mar 20 09:14:55: //8147/9561D059B3D9/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:14:57 2013: <191>163143: CallInfo(ccm detected=TRUE)
Wed Mar 20 09:14:57 2013: <191>163144: .Mar 20 09:14:55: //8146/9561D059B3D9/CCAPI/ccCallNotify:
Wed Mar 20 09:14:57 2013: <191>163145: Data Bitmask=0x5, Call Id=8146
Wed Mar 20 09:15:03 2013: <191>163146: .Mar 20 09:15:02: //8147/9561D059B3D9/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:15:03 2013: <191>163147: Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:15:03 2013: <191>163148: .Mar 20 09:15:02: //8147/9561D059B3D9/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:15:03 2013: <191>163149: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:15:03 2013: <191>163150: .Mar 20 09:15:02: //8147/9561D059B3D9/CCAPI/cc_api_call_notify:
Wed Mar 20 09:15:03 2013: <191>163151: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8147
Wed Mar 20 09:15:03 2013: <191>163152: .Mar 20 09:15:02: //8146/9561D059B3D9/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:15:04 2013: <191>163153: Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:15:04 2013: <191>163154: Tone Direction=Network, Params=0x0, Call Id=8146
Wed Mar 20 09:15:04 2013: <191>163155: .Mar 20 09:15:02: //8147/9561D059B3D9/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:15:04 2013: <191>163156: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:15:04 2013: <191>163157: .Mar 20 09:15:02: //8147/9561D059B3D9/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:15:04 2013: <191>163158: CallInfo(ccm detected=TRUE)
Wed Mar 20 09:15:04 2013: <191>163159: .Mar 20 09:15:02: //8146/9561D059B3D9/CCAPI/ccCallNotify:
Wed Mar 20 09:15:04 2013: <191>163160: Data Bitmask=0x5, Call Id=8146
Wed Mar 20 09:15:04 2013: <191>163161: .Mar 20 09:15:02: //8147/9561D059B3D9/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:15:04 2013: <191>163162: Destination Interface=0x4987FF98, Destination Call Id=8146, Source Call Id=8147,
Wed Mar 20 09:15:04 2013: <191>163163: Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:15:04 2013: <191>163164: Modem=0x2, Codec Bytes=160, Signal Type=2)
Wed Mar 20 09:15:04 2013: <191>163165: .Mar 20 09:15:02: //8147/9561D059B3D9/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:15:04 2013: <191>163166: Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:15:04 2013: <191>163167: Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:15:04 2013: <191>163168: .Mar 20 09:15:02: //8147/9561D059B3D9/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:15:04 2013: <191>163169:
Wed Mar 20 09:15:04 2013: <191>163170: Destination Interface=0x4987FF98, Destination Call Id=8146, Source Call Id=8147,
Wed Mar 20 09:15:04 2013: <191>163171: Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:15:04 2013: <191>163172: Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=3506)
Wed Mar 20 09:15:04 2013: <191>163173: .Mar 20 09:15:02: //8146/9561D059B3D9/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:15:04 2013: <191>163174: Destination Interface=0x48A4F728, Destination Call Id=8147, Source Call Id=8146,
Wed Mar 20 09:15:04 2013: <191>163175: Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:15:04 2013: <191>163176: Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=3506)
Wed Mar 20 09:15:04 2013: <191>163177: .Mar 20 09:15:02: //8146/9561D059B3D9/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:15:04 2013: <191>163178: Call Id=8146
Wed Mar 20 09:15:04 2013: <191>163179: .Mar 20 09:15:02: //8146/9561D059B3D9/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:15:04 2013: <191>163180:
Wed Mar 20 09:15:05 2013: <191>163181: Call Entry(Context=0x4BA7CBB8)
Wed Mar 20 09:15:39 2013: <191>163182: .Mar 20 09:15:38: //-1/B5F97BB2B3DE/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:15:39 2013: <191>163184: cisco-username=
Wed Mar 20 09:15:39 2013: <191>163183: cc_api_call_setup_ind_common:
Wed Mar 20 09:15:39 2013: <191>163185: ----- ccCallInfo IE subfields -----
Wed Mar 20 09:15:39 2013: <191>163186: cisco-ani=
Wed Mar 20 09:15:39 2013: <191>163187: cisco-anitype=0
Wed Mar 20 09:15:39 2013: <191>163188: cisco-aniplan=0
Wed Mar 20 09:15:39 2013: <191>163189: cisco-anipi=0
Wed Mar 20 09:15:39 2013: <191>163190: cisco-anisi=0
Wed Mar 20 09:15:39 2013: <191>163191: dest=1811032099
Wed Mar 20 09:15:39 2013: <191>163192: cisco-desttype=0
Wed Mar 20 09:15:39 2013: <191>163193: cisco-destplan=0
Wed Mar 20 09:15:39 2013: <191>163194: cisco-rdie=FFFFFFFF
Wed Mar 20 09:15:39 2013: <191>163195: cisco-rdn=
Wed Mar 20 09:15:39 2013: <191>163196: cisco-lastrdn=
Wed Mar 20 09:15:39 2013: <191>163197: cisco-rdntype=0
Wed Mar 20 09:15:39 2013: <191>163198: cisco-rdnplan=0
Wed Mar 20 09:15:39 2013: <191>163199: cisco-rdnpi=0
Wed Mar 20 09:15:39 2013: <191>163200: cisco-rdnsi=0
Wed Mar 20 09:15:39 2013: <191>163201: cisco-redirectreason=0 fwd_final_type =0
Wed Mar 20 09:15:39 2013: <191>163202: final_redirectNumber =
Wed Mar 20 09:15:39 2013: <191>163203: hunt_group_timeout =0
Wed Mar 20 09:15:39 2013: <191>163204:
Wed Mar 20 09:15:39 2013: <191>163205: .Mar 20 09:15:38: //-1/B5F97BB2B3DE/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:15:39 2013: <191>163206:
Wed Mar 20 09:15:39 2013: <191>163207: Interface=0x498845E0, Call Info(
Wed Mar 20 09:15:39 2013: <191>163208: Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:15:39 2013: <191>163209: Called Number=1811032099(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:15:39 2013: <191>163210: Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
Wed Mar 20 09:15:39 2013: <191>163211: Incoming Dial-peer=50, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
Wed Mar 20 09:15:39 2013: <191>163212: Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:15:39 2013: <191>163213: .Mar 20 09:15:38: //-1/B5F97BB2B3DE/CCAPI/ccCheckClipClir:
Wed Mar 20 09:15:39 2013: <191>163214: In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:15:39 2013: <191>163215: .Mar 20 09:15:38: //-1/B5F97BB2B3DE/CCAPI/ccCheckClipClir:
Wed Mar 20 09:15:39 2013: <191>163216: Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:15:39 2013: <191>163217: .Mar 20 09:15:38: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:15:39 2013: <191>163218:
Wed Mar 20 09:15:39 2013: <191>163219: .Mar 20 09:15:38: :cc_get_feature_vsa malloc success
Wed Mar 20 09:15:39 2013: <191>163220: .Mar 20 09:15:38: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:15:39 2013: <191>163221:
Wed Mar 20 09:15:39 2013: <191>163222: .Mar 20 09:15:38: cc_get_feature_vsa count is 5
Wed Mar 20 09:15:39 2013: <191>163223: .Mar 20 09:15:38: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:15:39 2013: <191>163224:
Wed Mar 20 09:15:39 2013: <191>163225: .Mar 20 09:15:38: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203247464,feature_id:8148
Wed Mar 20 09:15:39 2013: <191>163226: .Mar 20 09:15:38: //8148/B5F97BB2B3DE/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:15:39 2013: <191>163227:
Wed Mar 20 09:15:40 2013: <191>163228: Set Up Event Sent;
Wed Mar 20 09:15:40 2013: <191>163229: Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:15:40 2013: <191>163230: Called Number=1811032099(TON=Unknown, NPI=Unknown))
Wed Mar 20 09:15:40 2013: <191>163231: .Mar 20 09:15:38: //8148/B5F97BB2B3DE/CCAPI/cc_process_call_setup_ind:
Wed Mar 20 09:15:40 2013: <191>163232: Event=0x4982C828
Wed Mar 20 09:15:40 2013: <191>163240:
Wed Mar 20 09:15:40 2013: <191>163241: Progress Indication=NULL(0)
Wed Mar 20 09:15:40 2013: <191>163243: Destination=, Calling IE Present=FALSE, Mode=0,
Wed Mar 20 09:15:40 2013: <191>163257: Guid=B5F97BB2-908E-11E2-B3DE-DE08FC69A21F, Outgoing Dial-peer=3000
Wed Mar 20 09:15:40 2013: <191>163258: .Mar 20 09:15:38: //8148/B5F97BB2B3DE/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:15:40 2013: <191>163261: ----- ccCallInfo IE subfields -----
Wed Mar 20 09:15:40 2013: <191>163264: cisco-aniplan=0
Wed Mar 20 09:15:40 2013: <191>163268: dest=1811032099
Wed Mar 20 09:15:40 2013: <191>163269: cisco-desttype=0
Wed Mar 20 09:15:40 2013: <191>163277: cisco-rdnsi=0
Wed Mar 20 09:15:40 2013: <191>163279: final_redirectNumber =
Wed Mar 20 09:15:40 2013: <191>163281:
Wed Mar 20 09:15:40 2013: <191>163294: .Mar 20 09:15:38: cc_get_feature_vsa count is 6
Wed Mar 20 09:15:40 2013: <191>163295: .Mar 20 09:15:38: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:15:40 2013: <191>163296:
Wed Mar 20 09:15:40 2013: <191>163297: .Mar 20 09:15:38: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203247240,feature_id:8149
Wed Mar 20 09:15:40 2013: <191>163298: .Mar 20 09:15:38: //8149/B5F97BB2B3DE/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:15:40 2013: <191>163299: SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Wed Mar 20 09:15:40 2013: <191>163300: .Mar 20 09:15:38: //8149/B5F97BB2B3DE/CCAPI/ccCallSetContext:
Wed Mar 20 09:15:40 2013: <191>163301: Context=0x4BA7A5A8
Wed Mar 20 09:15:40 2013: <191>163302: .Mar 20 09:15:38: //8148/B5F97BB2B3DE/CCAPI/ccSaveDialpeerTag:
Wed Mar 20 09:15:40 2013: <191>163303: Outgoing Dial-peer=3000
Wed Mar 20 09:15:40 2013: <191>163304: .Mar 20 09:15:38: //8149/B5F97BB2B3DE/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:15:40 2013: <191>163305: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:15:40 2013: <191>163306: .Mar 20 09:15:38: //8149/B5F97BB2B3DE/CCAPI/cc_api_call_proceeding:
Wed Mar 20 09:15:40 2013: <191>163307: Interface=0x48A4F728, Progress Indication=NULL(0)
Wed Mar 20 09:15:40 2013: <191>163308: .Mar 20 09:15:38: //8149/B5F97BB2B3DE/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:15:40 2013: <191>163309: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:15:40 2013: <191>163310: .Mar 20 09:15:38: //8149/B5F97BB2B3DE/CCAPI/cc_api_set_delay_xport:
Wed Mar 20 09:15:40 2013: <191>163311: CallInfo(delay xport=TRUE)
Wed Mar 20 09:15:40 2013: <191>163312: .Mar 20 09:15:38: //8149/B5F97BB2B3DE/CCAPI/cc_api_call_alert:
Wed Mar 20 09:15:40 2013: <191>163313: Interface=0x48A4F728, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:15:40 2013: <191>163314: .Mar 20 09:15:38: //8149/B5F97BB2B3DE/CCAPI/cc_api_call_alert:
Wed Mar 20 09:15:40 2013: <191>163315: Call Entry(Retry Count=0, Responsed=TRUE)
Wed Mar 20 09:15:40 2013: <191>163316: .Mar 20 09:15:38: //8148/B5F97BB2B3DE/CCAPI/ccCallAlert:
Wed Mar 20 09:15:40 2013: <191>163317:
Wed Mar 20 09:15:40 2013: <191>163318: Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:15:40 2013: <191>163319: .Mar 20 09:15:38: //8148/B5F97BB2B3DE/CCAPI/ccCallAlert:
Wed Mar 20 09:15:40 2013: <191>163320: Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Wed Mar 20 09:15:40 2013: <191>163321: .Mar 20 09:15:39: //8149/B5F97BB2B3DE/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:15:40 2013: <191>163322: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:15:40 2013: <191>163323: .Mar 20 09:15:39: //8149/B5F97BB2B3DE/CCAPI/cc_api_call_notify:
Wed Mar 20 09:15:40 2013: <191>163324: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8149
Wed Mar 20 09:15:40 2013: <191>163325: .Mar 20 09:15:39: //8149/B5F97BB2B3DE/CCAPI/ccIsInfoRingback:
Wed Mar 20 09:15:40 2013: <191>163326: Returning dpRingBack=0
Wed Mar 20 09:15:40 2013: <191>163327: .Mar 20 09:15:39: //8149/B5F97BB2B3DE/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:15:40 2013: <191>163328: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:15:40 2013: <191>163329: .Mar 20 09:15:39: //8149/B5F97BB2B3DE/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:15:40 2013: <191>163330: CallInfo(ccm detected=TRUE)
Wed Mar 20 09:15:40 2013: <191>163331: .Mar 20 09:15:39: //8148/B5F97BB2B3DE/CCAPI/ccCallNotify:
Wed Mar 20 09:15:40 2013: <191>163332: Data Bitmask=0x5, Call Id=8148
Wed Mar 20 09:15:40 2013: <191>163333: .Mar 20 09:15:39: //8149/B5F97BB2B3DE/CCAPI/cc_api_call_connected:
Wed Mar 20 09:15:40 2013: <191>163334: Interface=0x48A4F728, Data Bitmask=0x0, Progress Indication=NULL(0),
Wed Mar 20 09:15:40 2013: <191>163335: Connection Handle=0
Wed Mar 20 09:15:40 2013: <191>163336: .Mar 20 09:15:39: //8149/B5F97BB2B3DE/CCAPI/cc_api_call_connected:
Wed Mar 20 09:15:40 2013: <191>163337: Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Wed Mar 20 09:15:40 2013: <191>163338: .Mar 20 09:15:39: //8149/B5F97BB2B3DE/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:15:40 2013: <191>163339: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:15:40 2013: <191>163340: .Mar 20 09:15:39: //8149/B5F97BB2B3DE/CCAPI/cc_api_call_notify:
Wed Mar 20 09:15:40 2013: <191>163341:
Wed Mar 20 09:15:40 2013: <191>163342: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8149
Wed Mar 20 09:15:40 2013: <191>163343: .Mar 20 09:15:39: //8148/B5F97BB2B3DE/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:15:40 2013: <191>163344: Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:15:40 2013: <191>163345: Tone Direction=Network, Params=0x0, Call Id=8148
Wed Mar 20 09:15:40 2013: <191>163346: .Mar 20 09:15:39: //8148/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:15:40 2013: <191>163347: (confID=0x4BB01DF8, callID1=0x1FD4, callID2=0x1FD5, tag=0x0)
Wed Mar 20 09:15:40 2013: <191>163348: .Mar 20 09:15:39: //8148/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:15:40 2013: <191>163349: (confID=0x4BB01DF8, callID1=0x1FD4, gcid=B5F97BB2-908E11E2-B3DEDE08-FC69A21F, tag=0x0)
Wed Mar 20 09:15:40 2013: <191>163350: .Mar 20 09:15:39: //8149/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:15:40 2013: <191>163351: (confID=0x4BB01DF8, callID2=0x1FD5, gcid=B5F97BB2-908E11E2-B3DEDE08-FC69A21F, tag=0x0)
Wed Mar 20 09:15:40 2013: <191>163352: .Mar 20 09:15:39: //8148/B5F97BB2B3DE/CCAPI/ccConferenceCreate:
Wed Mar 20 09:15:40 2013: <191>163353: Conference Id=0x4BB01DF8, Call Id1=8148, Call Id2=8149, Tag=0x0
Wed Mar 20 09:15:40 2013: <191>163354: .Mar 20 09:15:39: //8148/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:15:40 2013: <191>163355: Conference Id=0xE57, Source Interface=0x498845E0, Source Call Id=8148,
Wed Mar 20 09:15:40 2013: <191>163356: Destination Call Id=8149, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:15:40 2013: <191>163357: .Mar 20 09:15:39: //8149/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Wed Mar 20 09:15:40 2013: <191>163358:
Wed Mar 20 09:15:40 2013: <191>163359: .Mar 20 09:15:39: cc_api_get_xcode_stream : 4534
Wed Mar 20 09:15:40 2013: <191>163360: .Mar 20 09:15:39: //8149/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:15:40 2013: <191>163361: Conference Id=0xE57, Source Interface=0x48A4F728, Source Call Id=8149,
Wed Mar 20 09:15:40 2013: <191>163362: Destination Call Id=8148, Disposition=0x0, Tag=0x0
Wed Mar 20 09:15:40 2013: <191>163363: .Mar 20 09:15:39: //8148/B5F97BB2B3DE/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:15:40 2013: <191>163364: Conference Id=0xE57, Source Interface=0x48A4F728, Source Call Id=8149,
Wed Mar 20 09:15:40 2013: <191>163365: Destination Call Id=8148, Disposition=0x0, Tag=0x0
Wed Mar 20 09:15:40 2013: <191>163366: .Mar 20 09:15:39: //8148/B5F97BB2B3DE/CCAPI/ccConferenceCreate:
Wed Mar 20 09:15:40 2013: <191>163369: Call Entry(Conference Id=0xE57, Destination Call Id=8148)
Wed Mar 20 09:15:40 2013: <191>163370: .Mar 20 09:15:39: //8148/B5F97BB2B3DE/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:15:40 2013: <191>163383: .Mar 20 09:15:39: //8149/B5F97BB2B3DE/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:15:40 2013: <191>163384:
Wed Mar 20 09:15:40 2013: <191>163385: Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:15:40 2013: <191>163389: Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:15:40 2013: <191>163391: .Mar 20 09:15:39: //8148/B5F97BB2B3DE/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:15:40 2013: <191>163392: Destination Interface=0x48A4F728, Destination Call Id=8149, Source Call Id=8148,
Wed Mar 20 09:15:40 2013: <191>163393: Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:15:40 2013: <191>163394: Modem=ON(0x2), Codec Bytes=20, Signal Type=2, Seq Num Start=5309)
Wed Mar 20 09:15:40 2013: <191>163404: Call Entry(Context=0x4BA76C90)
Wed Mar 20 09:15:40 2013: <191>163408:
Wed Mar 20 09:15:41 2013: <191>163409: Call Entry(Connected=TRUE, Responsed=TRUE)
Wed Mar 20 09:15:44 2013: <190>163410: .Mar 20 09:15:42: %IPPHONE-6-UNREGISTER_NORMAL: ephone-11:SEP002699441929 IP:10.229.64.33 Socket:5 DeviceType:Phone has unregistered normally.
Wed Mar 20 09:15:51 2013: <191>163411: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:15:51 2013: <191>163412: Interface=0x0, Call Id=8149
Wed Mar 20 09:15:51 2013: <191>163413: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:15:51 2013: <191>163414: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:15:51 2013: <191>163415: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_call_notify:
Wed Mar 20 09:15:51 2013: <191>163416: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8149
Wed Mar 20 09:15:51 2013: <191>163417: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:15:51 2013: <191>163418: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:15:51 2013: <191>163419: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:15:51 2013: <191>163420: CallInfo(ccm detected=TRUE)
Wed Mar 20 09:15:51 2013: <191>163421: .Mar 20 09:15:50: //8148/B5F97BB2B3DE/CCAPI/ccCallNotify:
Wed Mar 20 09:15:51 2013: <191>163422: Data Bitmask=0x5, Call Id=8148
Wed Mar 20 09:15:51 2013: <191>163423: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:15:51 2013: <191>163424: Destination Interface=0x498845E0, Destination Call Id=8148, Source Call Id=8149,
Wed Mar 20 09:15:51 2013: <191>163425: Caps(Codec=0x4, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:15:51 2013: <191>163426: Modem=0x2, Codec Bytes=20, Signal Type=2)
Wed Mar 20 09:15:51 2013: <191>163427: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:15:51 2013: <191>163428: Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:15:51 2013: <191>163429: Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:15:51 2013: <191>163430: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:15:51 2013: <191>163431:
Wed Mar 20 09:15:51 2013: <191>163432: Destination Interface=0x498845E0, Destination Call Id=8148, Source Call Id=8149,
Wed Mar 20 09:15:51 2013: <191>163433: Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:15:51 2013: <191>163434: Modem=ON(0x2), Codec Bytes=20, Signal Type=2, Seq Num Start=5476)
Wed Mar 20 09:15:51 2013: <191>163435: .Mar 20 09:15:50: //8148/B5F97BB2B3DE/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:15:51 2013: <191>163436: Destination Interface=0x48A4F728, Destination Call Id=8149, Source Call Id=8148,
Wed Mar 20 09:15:51 2013: <191>163437: Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:15:51 2013: <191>163438: Modem=ON(0x2), Codec Bytes=20, Signal Type=2, Seq Num Start=5476)
Wed Mar 20 09:15:51 2013: <191>163439: .Mar 20 09:15:50: //8148/B5F97BB2B3DE/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:15:51 2013: <191>163440: Call Id=8148
Wed Mar 20 09:15:51 2013: <191>163441: .Mar 20 09:15:50: //8148/B5F97BB2B3DE/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:15:51 2013: <191>163442:
Wed Mar 20 09:15:51 2013: <191>163443: Call Entry(Context=0x4BA76C90)
Wed Mar 20 09:15:51 2013: <191>163444: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:15:51 2013: <191>163445: Interface=0x0, Call Id=8149
Wed Mar 20 09:15:51 2013: <191>163446: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:15:51 2013: <191>163447: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:15:51 2013: <191>163448: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_call_notify:
Wed Mar 20 09:15:51 2013: <191>163449: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8149
Wed Mar 20 09:15:51 2013: <191>163450: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:15:51 2013: <191>163451: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:15:51 2013: <191>163452: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:15:51 2013: <191>163453: CallInfo(ccm detected=TRUE)
Wed Mar 20 09:15:51 2013: <191>163454: .Mar 20 09:15:50: //8148/B5F97BB2B3DE/CCAPI/ccCallNotify:
Wed Mar 20 09:15:51 2013: <191>163455:
Wed Mar 20 09:15:51 2013: <191>163456: Data Bitmask=0x5, Call Id=8148
Wed Mar 20 09:15:51 2013: <191>163457: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:15:51 2013: <191>163458: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:15:51 2013: <191>163459: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_call_notify:
Wed Mar 20 09:15:51 2013: <191>163460: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8149
Wed Mar 20 09:15:51 2013: <191>163461: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:15:51 2013: <191>163462: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:15:51 2013: <191>163463: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:15:51 2013: <191>163464: CallInfo(ccm detected=TRUE)
Wed Mar 20 09:15:51 2013: <191>163465: .Mar 20 09:15:50: //8148/B5F97BB2B3DE/CCAPI/ccCallNotify:
Wed Mar 20 09:15:51 2013: <191>163466: Data Bitmask=0x5, Call Id=8148
Wed Mar 20 09:15:51 2013: <191>163467: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:15:51 2013: <191>163468:
Wed Mar 20 09:15:51 2013: <191>163469: Interface=0x0, Call Id=8149
Wed Mar 20 09:15:51 2013: <191>163470: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:15:51 2013: <191>163471: Cause Value=16, Interface=0x48A4F728, Call Id=8149
Wed Mar 20 09:15:51 2013: <191>163472: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:15:51 2013: <191>163473: Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:15:51 2013: <191>163474: .Mar 20 09:15:50: //8148/B5F97BB2B3DE/CCAPI/ccConferenceDestroy:
Wed Mar 20 09:15:51 2013: <191>163475: Conference Id=0xE57, Tag=0x0
Wed Mar 20 09:15:51 2013: <191>163476: .Mar 20 09:15:50: //8148/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:15:51 2013: <191>163477: Conference Id=0xE57, Source Interface=0x498845E0, Source Call Id=8148,
Wed Mar 20 09:15:51 2013: <191>163478: Destination Call Id=8149, Disposition=0x0, Tag=0x0
Wed Mar 20 09:15:51 2013: <191>163479: .Mar 20 09:15:50: //8149/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:15:51 2013: <191>163480:
Wed Mar 20 09:15:51 2013: <191>163481: Conference Id=0xE57, Source Interface=0x48A4F728, Source Call Id=8149,
Wed Mar 20 09:15:51 2013: <191>163482: Destination Call Id=8148, Disposition=0x0, Tag=0x0
Wed Mar 20 09:15:51 2013: <191>163483: .Mar 20 09:15:50: //8148/B5F97BB2B3DE/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:15:51 2013: <191>163484: Conference Id=0xE57, Source Interface=0x48A4F728, Source Call Id=8149,
Wed Mar 20 09:15:51 2013: <191>163485: Destination Call Id=8148, Disposition=0x0, Tag=0x0
Wed Mar 20 09:15:51 2013: <191>163486: .Mar 20 09:15:50: //8148/B5F97BB2B3DE/CCAPI/ccCallDisconnect:
Wed Mar 20 09:15:51 2013: <191>163487: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Wed Mar 20 09:15:51 2013: <191>163488: .Mar 20 09:15:50: //8148/B5F97BB2B3DE/CCAPI/ccCallDisconnect:
Wed Mar 20 09:15:51 2013: <191>163489: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:15:51 2013: <191>163490: .Mar 20 09:15:50: //8148/B5F97BB2B3DE/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:15:51 2013: <191>163491:
Wed Mar 20 09:15:51 2013: <191>163492: Transfer Number Is Null
Wed Mar 20 09:15:51 2013: <191>163493: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/ccCallDisconnect:
Wed Mar 20 09:15:51 2013: <191>163494: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:15:51 2013: <191>163495: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/ccCallDisconnect:
Wed Mar 20 09:15:51 2013: <191>163496: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:15:51 2013: <191>163497: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:15:51 2013: <191>163498: Transfer Number Is Null
Wed Mar 20 09:15:51 2013: <191>163499: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:15:51 2013: <191>163500: Transfer Number Is Null
Wed Mar 20 09:15:51 2013: <191>163501: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:15:51 2013: <191>163502:
Wed Mar 20 09:15:51 2013: <191>163503: Disposition=0, Interface=0x48A4F728, Tag=0x0, Call Id=8149,
Wed Mar 20 09:15:51 2013: <191>163504: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:15:51 2013: <191>163505: .Mar 20 09:15:50: //8149/B5F97BB2B3DE/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:15:51 2013: <191>163506: Call Disconnect Event Sent
Wed Mar 20 09:15:51 2013: <191>163507: .Mar 20 09:15:50: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:15:51 2013: <191>163508:
Wed Mar 20 09:15:51 2013: <191>163509: .Mar 20 09:15:50: :cc_free_feature_vsa freeing 47B81880
Wed Mar 20 09:15:51 2013: <191>163510: .Mar 20 09:15:50: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:15:51 2013: <191>163511:
Wed Mar 20 09:15:51 2013: <191>163512: .Mar 20 09:15:50: vsacount in free is 5
Wed Mar 20 09:15:51 2013: <191>163513: .Mar 20 09:15:50: //8148/B5F97BB2B3DE/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:15:51 2013: <191>163514: Disposition=0, Interface=0x498845E0, Tag=0x0, Call Id=8148,
Wed Mar 20 09:15:51 2013: <191>163515: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:15:52 2013: <191>163516: .Mar 20 09:15:50: //8148/B5F97BB2B3DE/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:15:52 2013: <191>163517: Call Disconnect Event Sent
Wed Mar 20 09:15:52 2013: <191>163518: .Mar 20 09:15:50: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:15:52 2013: <191>163519:
Wed Mar 20 09:15:52 2013: <191>163520: .Mar 20 09:15:50: :cc_free_feature_vsa freeing 47B81960
Wed Mar 20 09:15:52 2013: <191>163521: .Mar 20 09:15:50: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:15:52 2013: <191>163522:
Wed Mar 20 09:15:52 2013: <191>163523: .Mar 20 09:15:50: vsacount in free is 4
Wed Mar 20 09:16:46 2013: <191>163524: .Mar 20 09:16:45: //8144/80F45E604006/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:16:46 2013: <191>163525: Cause Value=16, Interface=0x48A4F728, Call Id=8144
Wed Mar 20 09:16:46 2013: <191>163526: .Mar 20 09:16:45: //8144/80F45E604006/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:16:46 2013: <191>163527: Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:16:46 2013: <191>163528: .Mar 20 09:16:45: //8144/80F45E604006/CCAPI/ccConferenceDestroy:
Wed Mar 20 09:16:46 2013: <191>163529: Conference Id=0xE55, Tag=0x0
Wed Mar 20 09:16:46 2013: <191>163530: .Mar 20 09:16:45: //8144/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:16:46 2013: <191>163531: Conference Id=0xE55, Source Interface=0x48A4F728, Source Call Id=8144,
Wed Mar 20 09:16:46 2013: <191>163532: Destination Call Id=8145, Disposition=0x0, Tag=0x0
Wed Mar 20 09:16:46 2013: <191>163533: .Mar 20 09:16:45: //8145/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:16:46 2013: <191>163534:
Wed Mar 20 09:16:46 2013: <191>163535: Conference Id=0xE55, Source Interface=0x4987DFD8, Source Call Id=8145,
Wed Mar 20 09:16:46 2013: <191>163536: Destination Call Id=8144, Disposition=0x0, Tag=0x0
Wed Mar 20 09:16:46 2013: <191>163537: .Mar 20 09:16:45: //8144/80F45E604006/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:16:46 2013: <191>163538: Conference Id=0xE55, Source Interface=0x4987DFD8, Source Call Id=8145,
Wed Mar 20 09:16:46 2013: <191>163539: Destination Call Id=8144, Disposition=0x0, Tag=0x0
Wed Mar 20 09:16:46 2013: <191>163540: .Mar 20 09:16:45: //8144/80F45E604006/CCAPI/ccCallDisconnect:
Wed Mar 20 09:16:46 2013: <191>163541: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:16:46 2013: <191>163542: .Mar 20 09:16:45: //8144/80F45E604006/CCAPI/ccCallDisconnect:
Wed Mar 20 09:16:46 2013: <191>163543: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:16:46 2013: <191>163544: .Mar 20 09:16:45: //8144/80F45E604006/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:16:46 2013: <191>163545:
Wed Mar 20 09:16:46 2013: <191>163546: Transfer Number Is Null
Wed Mar 20 09:16:46 2013: <191>163547: .Mar 20 09:16:45: //8145/80F45E604006/CCAPI/ccCallDisconnect:
Wed Mar 20 09:16:46 2013: <191>163548: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Wed Mar 20 09:16:46 2013: <191>163549: .Mar 20 09:16:45: //8145/80F45E604006/CCAPI/ccCallDisconnect:
Wed Mar 20 09:16:46 2013: <191>163550: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:16:46 2013: <191>163551: .Mar 20 09:16:45: //8145/80F45E604006/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:16:46 2013: <191>163552: Transfer Number Is Null
Wed Mar 20 09:16:46 2013: <191>163553: .Mar 20 09:16:45: //8144/80F45E604006/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:16:46 2013: <191>163554: Transfer Number Is Null
Wed Mar 20 09:16:46 2013: <191>163555: .Mar 20 09:16:45: //8144/80F45E604006/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:16:46 2013: <191>163556:
Wed Mar 20 09:16:46 2013: <191>163557: Disposition=0, Interface=0x48A4F728, Tag=0x0, Call Id=8144,
Wed Mar 20 09:16:46 2013: <191>163558: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:16:46 2013: <191>163559: .Mar 20 09:16:45: //8144/80F45E604006/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:16:46 2013: <191>163560: Call Disconnect Event Sent
Wed Mar 20 09:16:46 2013: <191>163561: .Mar 20 09:16:45: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:16:46 2013: <191>163562:
Wed Mar 20 09:16:46 2013: <191>163563: .Mar 20 09:16:45: :cc_free_feature_vsa freeing 47B81B20
Wed Mar 20 09:16:46 2013: <191>163564: .Mar 20 09:16:45: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:16:46 2013: <191>163565:
Wed Mar 20 09:16:46 2013: <191>163566: .Mar 20 09:16:45: vsacount in free is 3
Wed Mar 20 09:16:46 2013: <191>163567: .Mar 20 09:16:45: //8145/80F45E604006/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:16:46 2013: <191>163568: Disposition=0, Interface=0x4987DFD8, Tag=0x0, Call Id=8145,
Wed Mar 20 09:16:46 2013: <191>163569: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:16:47 2013: <191>163570: .Mar 20 09:16:45: //8145/80F45E604006/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:16:47 2013: <191>163571: Call Disconnect Event Sent
Wed Mar 20 09:16:47 2013: <191>163572: .Mar 20 09:16:45: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:16:47 2013: <191>163573:
Wed Mar 20 09:16:47 2013: <191>163574: .Mar 20 09:16:45: :cc_free_feature_vsa freeing 47B81A40
Wed Mar 20 09:16:47 2013: <191>163575: .Mar 20 09:16:45: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:16:47 2013: <191>163576:
Wed Mar 20 09:16:47 2013: <191>163577: .Mar 20 09:16:45: vsacount in free is 2
Wed Mar 20 09:17:02 2013: <191>163578: .Mar 20 09:17:01: //8147/9561D059B3D9/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:17:02 2013: <191>163579: Cause Value=16, Interface=0x48A4F728, Call Id=8147
Wed Mar 20 09:17:02 2013: <191>163580: .Mar 20 09:17:01: //8147/9561D059B3D9/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:17:02 2013: <191>163581: Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:17:02 2013: <191>163582: .Mar 20 09:17:01: //8146/9561D059B3D9/CCAPI/ccConferenceDestroy:
Wed Mar 20 09:17:02 2013: <191>163583: Conference Id=0xE56, Tag=0x0
Wed Mar 20 09:17:02 2013: <191>163584: .Mar 20 09:17:01: //8146/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:17:02 2013: <191>163585: Conference Id=0xE56, Source Interface=0x4987FF98, Source Call Id=8146,
Wed Mar 20 09:17:02 2013: <191>163586: Destination Call Id=8147, Disposition=0x0, Tag=0x0
Wed Mar 20 09:17:02 2013: <191>163587: .Mar 20 09:17:01: //8147/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:17:02 2013: <191>163588:
Wed Mar 20 09:17:02 2013: <191>163589: Conference Id=0xE56, Source Interface=0x48A4F728, Source Call Id=8147,
Wed Mar 20 09:17:02 2013: <191>163590: Destination Call Id=8146, Disposition=0x0, Tag=0x0
Wed Mar 20 09:17:02 2013: <191>163591: .Mar 20 09:17:01: //8146/9561D059B3D9/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:17:02 2013: <191>163592: Conference Id=0xE56, Source Interface=0x48A4F728, Source Call Id=8147,
Wed Mar 20 09:17:02 2013: <191>163593: Destination Call Id=8146, Disposition=0x0, Tag=0x0
Wed Mar 20 09:17:03 2013: <191>163594: .Mar 20 09:17:01: //8146/9561D059B3D9/CCAPI/ccCallDisconnect:
Wed Mar 20 09:17:03 2013: <191>163595: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Wed Mar 20 09:17:03 2013: <191>163596: .Mar 20 09:17:01: //8146/9561D059B3D9/CCAPI/ccCallDisconnect:
Wed Mar 20 09:17:03 2013: <191>163597: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:17:03 2013: <191>163598: .Mar 20 09:17:01: //8146/9561D059B3D9/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:17:03 2013: <191>163599:
Wed Mar 20 09:17:03 2013: <191>163600: Transfer Number Is Null
Wed Mar 20 09:17:03 2013: <191>163601: .Mar 20 09:17:01: //8147/9561D059B3D9/CCAPI/ccCallDisconnect:
Wed Mar 20 09:17:03 2013: <191>163602: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:17:03 2013: <191>163603: .Mar 20 09:17:01: //8147/9561D059B3D9/CCAPI/ccCallDisconnect:
Wed Mar 20 09:17:03 2013: <191>163604: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:17:03 2013: <191>163605: .Mar 20 09:17:01: //8147/9561D059B3D9/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:17:03 2013: <191>163606: Transfer Number Is Null
Wed Mar 20 09:17:03 2013: <191>163607: .Mar 20 09:17:01: //8147/9561D059B3D9/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:17:03 2013: <191>163608: Transfer Number Is Null
Wed Mar 20 09:17:03 2013: <191>163609: .Mar 20 09:17:01: //8147/9561D059B3D9/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:17:03 2013: <191>163610:
Wed Mar 20 09:17:03 2013: <191>163611: Disposition=0, Interface=0x48A4F728, Tag=0x0, Call Id=8147,
Wed Mar 20 09:17:03 2013: <191>163612: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:17:03 2013: <191>163613: .Mar 20 09:17:01: //8147/9561D059B3D9/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:17:03 2013: <191>163614: Call Disconnect Event Sent
Wed Mar 20 09:17:03 2013: <191>163615: .Mar 20 09:17:01: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:17:03 2013: <191>163616:
Wed Mar 20 09:17:03 2013: <191>163617: .Mar 20 09:17:01: :cc_free_feature_vsa freeing 47B81CE0
Wed Mar 20 09:17:03 2013: <191>163618: .Mar 20 09:17:01: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:17:03 2013: <191>163619:
Wed Mar 20 09:17:03 2013: <191>163620: .Mar 20 09:17:01: vsacount in free is 1
Wed Mar 20 09:17:03 2013: <191>163621: .Mar 20 09:17:01: //8146/9561D059B3D9/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:17:03 2013: <191>163622: Disposition=0, Interface=0x4987FF98, Tag=0x0, Call Id=8146,
Wed Mar 20 09:17:03 2013: <191>163623: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:17:03 2013: <191>163624: .Mar 20 09:17:01: //8146/9561D059B3D9/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:17:03 2013: <191>163625: Call Disconnect Event Sent
Wed Mar 20 09:17:03 2013: <191>163626: .Mar 20 09:17:01: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:17:03 2013: <191>163627:
Wed Mar 20 09:17:03 2013: <191>163628: .Mar 20 09:17:01: :cc_free_feature_vsa freeing 47B81C00
Wed Mar 20 09:17:03 2013: <191>163629: .Mar 20 09:17:01: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:17:03 2013: <191>163630:
Wed Mar 20 09:17:03 2013: <191>163631: .Mar 20 09:17:01: vsacount in free is 0
Wed Mar 20 09:17:12 2013: <191>163632: .Mar 20 09:17:10: //-1/ECF034A4B3E3/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:17:12 2013: <191>163633: cc_api_call_setup_ind_common:
Wed Mar 20 09:17:12 2013: <191>163634: cisco-username=
Wed Mar 20 09:17:12 2013: <191>163635: ----- ccCallInfo IE subfields -----
Wed Mar 20 09:17:12 2013: <191>163636: cisco-ani=
Wed Mar 20 09:17:12 2013: <191>163637: cisco-anitype=0
Wed Mar 20 09:17:12 2013: <191>163638: cisco-aniplan=0
Wed Mar 20 09:17:12 2013: <191>163639: cisco-anipi=0
Wed Mar 20 09:17:12 2013: <191>163640: cisco-anisi=0
Wed Mar 20 09:17:12 2013: <191>163641: dest=1811032099
Wed Mar 20 09:17:12 2013: <191>163642: cisco-desttype=0
Wed Mar 20 09:17:12 2013: <191>163643: cisco-destplan=0
Wed Mar 20 09:17:12 2013: <191>163644: cisco-rdie=FFFFFFFF
Wed Mar 20 09:17:12 2013: <191>163645: cisco-rdn=
Wed Mar 20 09:17:12 2013: <191>163646: cisco-lastrdn=
Wed Mar 20 09:17:12 2013: <191>163647: cisco-rdntype=0
Wed Mar 20 09:17:12 2013: <191>163648: cisco-rdnplan=0
Wed Mar 20 09:17:12 2013: <191>163649: cisco-rdnpi=0
Wed Mar 20 09:17:12 2013: <191>163650: cisco-rdnsi=0
Wed Mar 20 09:17:12 2013: <191>163651: cisco-redirectreason=0 fwd_final_type =0
Wed Mar 20 09:17:12 2013: <191>163652: final_redirectNumber =
Wed Mar 20 09:17:12 2013: <191>163653: hunt_group_timeout =0
Wed Mar 20 09:17:12 2013: <191>163654:
Wed Mar 20 09:17:12 2013: <191>163655: .Mar 20 09:17:10: //-1/ECF034A4B3E3/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:17:12 2013: <191>163656:
Wed Mar 20 09:17:12 2013: <191>163657: Interface=0x498845E0, Call Info(
Wed Mar 20 09:17:12 2013: <191>163658: Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:17:12 2013: <191>163659: Called Number=1811032099(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:17:12 2013: <191>163660: Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
Wed Mar 20 09:17:12 2013: <191>163661: Incoming Dial-peer=50, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
Wed Mar 20 09:17:12 2013: <191>163662: Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:17:12 2013: <191>163663: .Mar 20 09:17:10: //-1/ECF034A4B3E3/CCAPI/ccCheckClipClir:
Wed Mar 20 09:17:12 2013: <191>163664: In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:17:12 2013: <191>163665: .Mar 20 09:17:10: //-1/ECF034A4B3E3/CCAPI/ccCheckClipClir:
Wed Mar 20 09:17:12 2013: <191>163666: Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:17:12 2013: <191>163667: .Mar 20 09:17:10: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:17:12 2013: <191>163668:
Wed Mar 20 09:17:12 2013: <191>163669: .Mar 20 09:17:10: :cc_get_feature_vsa malloc success
Wed Mar 20 09:17:12 2013: <191>163670: .Mar 20 09:17:10: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:17:12 2013: <191>163671:
Wed Mar 20 09:17:12 2013: <191>163672: .Mar 20 09:17:10: cc_get_feature_vsa count is 1
Wed Mar 20 09:17:12 2013: <191>163673: .Mar 20 09:17:10: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:17:12 2013: <191>163674:
Wed Mar 20 09:17:12 2013: <191>163675: .Mar 20 09:17:10: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203325536,feature_id:8150
Wed Mar 20 09:17:12 2013: <191>163676: .Mar 20 09:17:10: //8150/ECF034A4B3E3/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:17:12 2013: <191>163677:
Wed Mar 20 09:17:12 2013: <191>163678: Set Up Event Sent;
Wed Mar 20 09:17:12 2013: <191>163680: Called Number=1811032099(TON=Unknown, NPI=Unknown))
Wed Mar 20 09:17:12 2013: <191>163682: Event=0x4982D230
Wed Mar 20 09:17:12 2013: <191>163683: .Mar 20 09:17:10: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Wed Mar 20 09:17:12 2013: <191>163687: .Mar 20 09:17:10: //8150/ECF034A4B3E3/CCAPI/cc_process_call_setup_ind:
Wed Mar 20 09:17:12 2013: <191>163689: .Mar 20 09:17:10: //8150/ECF034A4B3E3/CCAPI/ccCallProceeding:
Wed Mar 20 09:17:12 2013: <191>163690:
Wed Mar 20 09:17:12 2013: <191>163691: Progress Indication=NULL(0)
Wed Mar 20 09:17:12 2013: <191>163692: .Mar 20 09:17:10: //8150/ECF034A4B3E3/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:17:12 2013: <191>163696: In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:17:12 2013: <191>163697: .Mar 20 09:17:10: //8150/ECF034A4B3E3/CCAPI/ccCheckClipClir:
Wed Mar 20 09:17:12 2013: <191>163709: ccCallSetupRequest:
Wed Mar 20 09:17:12 2013: <191>163711: ----- ccCallInfo IE subfields -----
Wed Mar 20 09:17:12 2013: <191>163713: cisco-anitype=0
Wed Mar 20 09:17:12 2013: <191>163715: cisco-anipi=0
Wed Mar 20 09:17:12 2013: <191>163719: cisco-desttype=0
Wed Mar 20 09:17:12 2013: <191>163724: cisco-rdntype=0
Wed Mar 20 09:17:12 2013: <191>163728: cisco-redirectreason=0 fwd_final_type =0
Wed Mar 20 09:17:12 2013: <191>163731:
Wed Mar 20 09:17:12 2013: <191>163744: .Mar 20 09:17:10: cc_get_feature_vsa count is 2
Wed Mar 20 09:17:12 2013: <191>163745: .Mar 20 09:17:10: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:17:12 2013: <191>163746:
Wed Mar 20 09:17:12 2013: <191>163747: .Mar 20 09:17:10: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203325312,feature_id:8151
Wed Mar 20 09:17:12 2013: <191>163748: .Mar 20 09:17:10: //8151/ECF034A4B3E3/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:17:12 2013: <191>163749: SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Wed Mar 20 09:17:12 2013: <191>163750: .Mar 20 09:17:10: //8151/ECF034A4B3E3/CCAPI/ccCallSetContext:
Wed Mar 20 09:17:12 2013: <191>163751: Context=0x4BA6D450
Wed Mar 20 09:17:12 2013: <191>163752: .Mar 20 09:17:10: //8150/ECF034A4B3E3/CCAPI/ccSaveDialpeerTag:
Wed Mar 20 09:17:12 2013: <191>163753: Outgoing Dial-peer=3000
Wed Mar 20 09:17:12 2013: <191>163754: .Mar 20 09:17:11: //8151/ECF034A4B3E3/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:17:12 2013: <191>163755: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:17:12 2013: <191>163756: .Mar 20 09:17:11: //8151/ECF034A4B3E3/CCAPI/cc_api_call_proceeding:
Wed Mar 20 09:17:12 2013: <191>163757: Interface=0x48A4F728, Progress Indication=NULL(0)
Wed Mar 20 09:17:12 2013: <191>163758: .Mar 20 09:17:11: //8151/ECF034A4B3E3/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:17:12 2013: <191>163759: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:17:12 2013: <191>163760: .Mar 20 09:17:11: //8151/ECF034A4B3E3/CCAPI/cc_api_set_delay_xport:
Wed Mar 20 09:17:12 2013: <191>163761: CallInfo(delay xport=TRUE)
Wed Mar 20 09:17:12 2013: <191>163762: .Mar 20 09:17:11: //8151/ECF034A4B3E3/CCAPI/cc_api_call_alert:
Wed Mar 20 09:17:12 2013: <191>163763: Interface=0x48A4F728, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:17:12 2013: <191>163764: .Mar 20 09:17:11: //8151/ECF034A4B3E3/CCAPI/cc_api_call_alert:
Wed Mar 20 09:17:12 2013: <191>163765: Call Entry(Retry Count=0, Responsed=TRUE)
Wed Mar 20 09:17:12 2013: <191>163766: .Mar 20 09:17:11: //8150/ECF034A4B3E3/CCAPI/ccCallAlert:
Wed Mar 20 09:17:12 2013: <191>163767:
Wed Mar 20 09:17:12 2013: <191>163768: Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:17:12 2013: <191>163769: .Mar 20 09:17:11: //8150/ECF034A4B3E3/CCAPI/ccCallAlert:
Wed Mar 20 09:17:12 2013: <191>163770: Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Wed Mar 20 09:17:12 2013: <191>163771: .Mar 20 09:17:11: //8151/ECF034A4B3E3/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:17:12 2013: <191>163772: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:17:12 2013: <191>163773: .Mar 20 09:17:11: //8151/ECF034A4B3E3/CCAPI/cc_api_call_notify:
Wed Mar 20 09:17:12 2013: <191>163774: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8151
Wed Mar 20 09:17:12 2013: <191>163775: .Mar 20 09:17:11: //8151/ECF034A4B3E3/CCAPI/ccIsInfoRingback:
Wed Mar 20 09:17:12 2013: <191>163776: Returning dpRingBack=0
Wed Mar 20 09:17:12 2013: <191>163777: .Mar 20 09:17:11: //8151/ECF034A4B3E3/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:17:12 2013: <191>163778: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:17:12 2013: <191>163779: .Mar 20 09:17:11: //8151/ECF034A4B3E3/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:17:12 2013: <191>163780: CallInfo(ccm detected=TRUE)
Wed Mar 20 09:17:12 2013: <191>163781: .Mar 20 09:17:11: //8150/ECF034A4B3E3/CCAPI/ccCallNotify:
Wed Mar 20 09:17:12 2013: <191>163782: Data Bitmask=0x5, Call Id=8150
Wed Mar 20 09:17:12 2013: <191>163783: .Mar 20 09:17:11: //8151/ECF034A4B3E3/CCAPI/cc_api_call_connected:
Wed Mar 20 09:17:12 2013: <191>163784: Interface=0x48A4F728, Data Bitmask=0x0, Progress Indication=NULL(0),
Wed Mar 20 09:17:12 2013: <191>163785: Connection Handle=0
Wed Mar 20 09:17:12 2013: <191>163786: .Mar 20 09:17:11: //8151/ECF034A4B3E3/CCAPI/cc_api_call_connected:
Wed Mar 20 09:17:12 2013: <191>163787: Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Wed Mar 20 09:17:12 2013: <191>163788: .Mar 20 09:17:11: //8151/ECF034A4B3E3/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:17:12 2013: <191>163789: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:17:12 2013: <191>163790: .Mar 20 09:17:11: //8151/ECF034A4B3E3/CCAPI/cc_api_call_notify:
Wed Mar 20 09:17:12 2013: <191>163791:
Wed Mar 20 09:17:12 2013: <191>163792: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8151
Wed Mar 20 09:17:12 2013: <191>163793: .Mar 20 09:17:11: //8150/ECF034A4B3E3/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:17:12 2013: <191>163794: Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:17:12 2013: <191>163795: Tone Direction=Network, Params=0x0, Call Id=8150
Wed Mar 20 09:17:12 2013: <191>163796: .Mar 20 09:17:11: //8150/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:17:12 2013: <191>163797: (confID=0x4BB02080, callID1=0x1FD6, callID2=0x1FD7, tag=0x0)
Wed Mar 20 09:17:12 2013: <191>163798: .Mar 20 09:17:11: //8150/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:17:12 2013: <191>163799: (confID=0x4BB02080, callID1=0x1FD6, gcid=ECF034A4-908E11E2-B3E3DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:17:12 2013: <191>163800: .Mar 20 09:17:11: //8151/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:17:12 2013: <191>163801: (confID=0x4BB02080, callID2=0x1FD7, gcid=ECF034A4-908E11E2-B3E3DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:17:12 2013: <191>163802: .Mar 20 09:17:11: //8150/ECF034A4B3E3/CCAPI/ccConferenceCreate:
Wed Mar 20 09:17:12 2013: <191>163803: Conference Id=0x4BB02080, Call Id1=8150, Call Id2=8151, Tag=0x0
Wed Mar 20 09:17:12 2013: <191>163804: .Mar 20 09:17:11: //8150/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:17:12 2013: <191>163805: Conference Id=0xE58, Source Interface=0x498845E0, Source Call Id=8150,
Wed Mar 20 09:17:12 2013: <191>163806: Destination Call Id=8151, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:17:12 2013: <191>163807: .Mar 20 09:17:11: //8151/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Wed Mar 20 09:17:12 2013: <191>163808:
Wed Mar 20 09:17:12 2013: <191>163809: .Mar 20 09:17:11: cc_api_get_xcode_stream : 4534
Wed Mar 20 09:17:12 2013: <191>163810: .Mar 20 09:17:11: //8151/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:17:12 2013: <191>163811: Conference Id=0xE58, Source Interface=0x48A4F728, Source Call Id=8151,
Wed Mar 20 09:17:12 2013: <191>163812: Destination Call Id=8150, Disposition=0x0, Tag=0x0
Wed Mar 20 09:17:12 2013: <191>163813: .Mar 20 09:17:11: //8150/ECF034A4B3E3/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:17:12 2013: <191>163814: Conference Id=0xE58, Source Interface=0x48A4F728, Source Call Id=8151,
Wed Mar 20 09:17:12 2013: <191>163816: .Mar 20 09:17:11: //8150/ECF034A4B3E3/CCAPI/ccConferenceCreate:
Wed Mar 20 09:17:12 2013: <191>163818: .Mar 20 09:17:11: //8151/ECF034A4B3E3/CCAPI/ccConferenceCreate:
Wed Mar 20 09:17:12 2013: <191>163820: .Mar 20 09:17:11: //8150/ECF034A4B3E3/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:17:12 2013: <191>163821: Destination Interface=0x48A4F728, Destination Call Id=8151, Source Call Id=8150,
Wed Mar 20 09:17:12 2013: <191>163824: .Mar 20 09:17:11: //8150/ECF034A4B3E3/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:17:12 2013: <191>163825: Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:17:12 2013: <191>163826: Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:17:12 2013: <191>163827: .Mar 20 09:17:11: //8150/ECF034A4B3E3/CCAPI/cc_process_notify_bridge_done:
Wed Mar 20 09:17:12 2013: <191>163828: Conference Id=0xE58, Call Id1=8150, Call Id2=8151
Wed Mar 20 09:17:12 2013: <191>163832: Modem=0x2, Codec Bytes=20, Signal Type=2)
Wed Mar 20 09:17:12 2013: <191>163839: Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:17:12 2013: <191>163844: Modem=ON(0x2), Codec Bytes=20, Signal Type=2, Seq Num Start=5597)
Wed Mar 20 09:17:12 2013: <191>163845: .Mar 20 09:17:11: //8151/ECF034A4B3E3/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:17:12 2013: <191>163846: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:17:12 2013: <191>163847: .Mar 20 09:17:11: //8151/ECF034A4B3E3/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:17:12 2013: <191>163858:
Wed Mar 20 09:17:13 2013: <191>163859: Call Entry(Connected=TRUE, Responsed=TRUE)
Wed Mar 20 09:17:23 2013: <191>163860: .Mar 20 09:17:22: //8151/ECF034A4B3E3/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:17:23 2013: <191>163861: Interface=0x0, Call Id=8151
Wed Mar 20 09:17:23 2013: <191>163862: .Mar 20 09:17:22: //8151/ECF034A4B3E3/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:17:23 2013: <191>163863: Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:17:23 2013: <191>163864: .Mar 20 09:17:22: //8150/ECF034A4B3E3/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:17:23 2013: <191>163865: Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:17:23 2013: <191>163866: Tone Direction=Network, Params=0x0, Call Id=8150
Wed Mar 20 09:17:23 2013: <191>163867: .Mar 20 09:17:22: //8151/ECF034A4B3E3/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:17:23 2013: <191>163868: Interface=0x48A4F728, Signal Indication=NOT PRESENT(255)
Wed Mar 20 09:17:23 2013: <191>163869: .Mar 20 09:17:22: //8151/ECF034A4B3E3/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:17:23 2013: <191>163870: Interface=0x48A4F728, Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:17:23 2013: <191>163871: .Mar 20 09:17:22: //8150/ECF034A4B3E3/CCAPI/ccCallUserInfo:
Wed Mar 20 09:17:23 2013: <191>163872: Call Id=8150
Wed Mar 20 09:17:23 2013: <191>163873: .Mar 20 09:17:22: //8150/ECF034A4B3E3/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:17:23 2013: <191>163874: Stop Tone On Digit=FALSE, Tone=Ring Back,
Wed Mar 20 09:17:23 2013: <191>163875: Tone Direction=Network, Params=0x0, Call Id=8150
Wed Mar 20 09:17:23 2013: <191>163876: .Mar 20 09:17:22: //8151/ECF034A4B3E3/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:17:23 2013: <191>163877: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:17:23 2013: <191>163878: .Mar 20 09:17:22: //8151/ECF034A4B3E3/CCAPI/cc_api_call_notify:
Wed Mar 20 09:17:23 2013: <191>163879: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8151
Wed Mar 20 09:17:23 2013: <191>163880: .Mar 20 09:17:22: //8151/ECF034A4B3E3/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:17:23 2013: <191>163881: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:17:24 2013: <191>163882: .Mar 20 09:17:22: //8151/ECF034A4B3E3/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:17:24 2013: <191>163883: CallInfo(ccm detected=TRUE)
Wed Mar 20 09:17:24 2013: <191>163884: .Mar 20 09:17:22: //8150/ECF034A4B3E3/CCAPI/ccCallNotify:
Wed Mar 20 09:17:24 2013: <191>163885: Data Bitmask=0x5, Call Id=8150
Wed Mar 20 09:17:39 2013: <191>163886: .Mar 20 09:17:38: //8151/ECF034A4B3E3/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:17:39 2013: <191>163887: Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:17:39 2013: <191>163888: .Mar 20 09:17:38: //8151/ECF034A4B3E3/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:17:39 2013: <191>163889: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:17:39 2013: <191>163890: .Mar 20 09:17:38: //8151/ECF034A4B3E3/CCAPI/cc_api_call_notify:
Wed Mar 20 09:17:39 2013: <191>163891: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8151
Wed Mar 20 09:17:39 2013: <191>163892: .Mar 20 09:17:38: //8150/ECF034A4B3E3/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:17:39 2013: <191>163893: Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:17:39 2013: <191>163894: Tone Direction=Network, Params=0x0, Call Id=8150
Wed Mar 20 09:17:39 2013: <191>163895: .Mar 20 09:17:38: //8151/ECF034A4B3E3/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:17:39 2013: <191>163896: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:17:39 2013: <191>163897: .Mar 20 09:17:38: //8151/ECF034A4B3E3/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:17:39 2013: <191>163898: CallInfo(ccm detected=TRUE)
Wed Mar 20 09:17:39 2013: <191>163899: .Mar 20 09:17:38: //8150/ECF034A4B3E3/CCAPI/ccCallNotify:
Wed Mar 20 09:17:39 2013: <191>163900: Data Bitmask=0x5, Call Id=8150
Wed Mar 20 09:17:39 2013: <191>163901: .Mar 20 09:17:38: //8151/ECF034A4B3E3/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:17:39 2013: <191>163902: Destination Interface=0x498845E0, Destination Call Id=8150, Source Call Id=8151,
Wed Mar 20 09:17:39 2013: <191>163903: Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:17:39 2013: <191>163904: Modem=0x2, Codec Bytes=160, Signal Type=2)
Wed Mar 20 09:17:39 2013: <191>163905: .Mar 20 09:17:38: //8151/ECF034A4B3E3/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:17:39 2013: <191>163906: Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:17:39 2013: <191>163907: Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:17:39 2013: <191>163908: .Mar 20 09:17:38: //8151/ECF034A4B3E3/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:17:39 2013: <191>163909:
Wed Mar 20 09:17:39 2013: <191>163910: Destination Interface=0x498845E0, Destination Call Id=8150, Source Call Id=8151,
Wed Mar 20 09:17:39 2013: <191>163911: Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:17:39 2013: <191>163912: Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=5649)
Wed Mar 20 09:17:39 2013: <191>163913: .Mar 20 09:17:38: //8150/ECF034A4B3E3/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:17:39 2013: <191>163914: Destination Interface=0x48A4F728, Destination Call Id=8151, Source Call Id=8150,
Wed Mar 20 09:17:39 2013: <191>163915: Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:17:39 2013: <191>163916: Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=5649)
Wed Mar 20 09:17:39 2013: <191>163917: .Mar 20 09:17:38: //8150/ECF034A4B3E3/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:17:39 2013: <191>163918: Call Id=8150
Wed Mar 20 09:17:39 2013: <191>163919: .Mar 20 09:17:38: //8150/ECF034A4B3E3/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:17:39 2013: <191>163920:
Wed Mar 20 09:17:40 2013: <191>163921: Call Entry(Context=0x4BA6C148)
Wed Mar 20 09:18:13 2013: <191>163922: .Mar 20 09:18:12: //-1/1157400AB3E8/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:18:13 2013: <191>163923: cc_api_call_setup_ind_common:
Wed Mar 20 09:18:13 2013: <191>163924: cisco-username=
Wed Mar 20 09:18:13 2013: <191>163925: ----- ccCallInfo IE subfields -----
Wed Mar 20 09:18:13 2013: <191>163926: cisco-ani=
Wed Mar 20 09:18:13 2013: <191>163927: cisco-anitype=0
Wed Mar 20 09:18:13 2013: <191>163928: cisco-aniplan=0
Wed Mar 20 09:18:13 2013: <191>163929: cisco-anipi=0
Wed Mar 20 09:18:13 2013: <191>163930: cisco-anisi=0
Wed Mar 20 09:18:13 2013: <191>163931: dest=1811032099
Wed Mar 20 09:18:13 2013: <191>163932: cisco-desttype=0
Wed Mar 20 09:18:13 2013: <191>163933: cisco-destplan=0
Wed Mar 20 09:18:13 2013: <191>163934: cisco-rdie=FFFFFFFF
Wed Mar 20 09:18:13 2013: <191>163935: cisco-rdn=
Wed Mar 20 09:18:13 2013: <191>163936: cisco-lastrdn=
Wed Mar 20 09:18:13 2013: <191>163937: cisco-rdntype=0
Wed Mar 20 09:18:13 2013: <191>163938: cisco-rdnplan=0
Wed Mar 20 09:18:13 2013: <191>163939: cisco-rdnpi=0
Wed Mar 20 09:18:13 2013: <191>163940: cisco-rdnsi=0
Wed Mar 20 09:18:13 2013: <191>163941: cisco-redirectreason=0 fwd_final_type =0
Wed Mar 20 09:18:13 2013: <191>163942: final_redirectNumber =
Wed Mar 20 09:18:13 2013: <191>163943: hunt_group_timeout =0
Wed Mar 20 09:18:13 2013: <191>163944:
Wed Mar 20 09:18:13 2013: <191>163945: .Mar 20 09:18:12: //-1/1157400AB3E8/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:18:13 2013: <191>163946:
Wed Mar 20 09:18:13 2013: <191>163947: Interface=0x4987FF98, Call Info(
Wed Mar 20 09:18:13 2013: <191>163948: Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:18:13 2013: <191>163949: Called Number=1811032099(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:18:13 2013: <191>163950: Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
Wed Mar 20 09:18:13 2013: <191>163951: Incoming Dial-peer=18, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
Wed Mar 20 09:18:13 2013: <191>163952: Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:18:13 2013: <191>163953: .Mar 20 09:18:12: //-1/1157400AB3E8/CCAPI/ccCheckClipClir:
Wed Mar 20 09:18:13 2013: <191>163954: In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:18:13 2013: <191>163955: .Mar 20 09:18:12: //-1/1157400AB3E8/CCAPI/ccCheckClipClir:
Wed Mar 20 09:18:13 2013: <191>163956: Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:18:13 2013: <191>163957: .Mar 20 09:18:12: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:18:13 2013: <191>163958:
Wed Mar 20 09:18:13 2013: <191>163959: .Mar 20 09:18:12: :cc_get_feature_vsa malloc success
Wed Mar 20 09:18:13 2013: <191>163960: .Mar 20 09:18:12: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:18:13 2013: <191>163961:
Wed Mar 20 09:18:13 2013: <191>163962: .Mar 20 09:18:12: cc_get_feature_vsa count is 3
Wed Mar 20 09:18:13 2013: <191>163963: .Mar 20 09:18:12: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:18:13 2013: <191>163964:
Wed Mar 20 09:18:13 2013: <191>163965: .Mar 20 09:18:12: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203325088,feature_id:8152
Wed Mar 20 09:18:13 2013: <191>163966: .Mar 20 09:18:12: //8152/1157400AB3E8/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:18:13 2013: <191>163967:
Wed Mar 20 09:18:13 2013: <191>163968: Set Up Event Sent;
Wed Mar 20 09:18:13 2013: <191>163969: Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:18:13 2013: <191>163970: Called Number=1811032099(TON=Unknown, NPI=Unknown))
Wed Mar 20 09:18:13 2013: <191>163972: Event=0x4982C828
Wed Mar 20 09:18:13 2013: <191>163973: .Mar 20 09:18:12: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Wed Mar 20 09:18:13 2013: <191>163980:
Wed Mar 20 09:18:13 2013: <191>163981: Progress Indication=NULL(0)
Wed Mar 20 09:18:13 2013: <191>163992: .Mar 20 09:18:12: //8152/1157400AB3E8/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:18:13 2013: <191>163993: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:18:13 2013: <191>163994: Called Number=1811032099(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:18:13 2013: <191>163997: Guid=1157400A-908F-11E2-B3E8-DE08FC69A21F, Outgoing Dial-peer=3000
Wed Mar 20 09:18:13 2013: <191>164002: cisco-ani=
Wed Mar 20 09:18:13 2013: <191>164007: cisco-anisi=0
Wed Mar 20 09:18:13 2013: <191>164008: dest=1811032099
Wed Mar 20 09:18:13 2013: <191>164011: cisco-rdie=FFFFFFFF
Wed Mar 20 09:18:13 2013: <191>164013: cisco-lastrdn=
Wed Mar 20 09:18:13 2013: <191>164015: cisco-rdnplan=0
Wed Mar 20 09:18:13 2013: <191>164019: final_redirectNumber =
Wed Mar 20 09:18:13 2013: <191>164021:
Wed Mar 20 09:18:13 2013: <191>164034: .Mar 20 09:18:12: cc_get_feature_vsa count is 4
Wed Mar 20 09:18:13 2013: <191>164035: .Mar 20 09:18:12: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:18:13 2013: <191>164036:
Wed Mar 20 09:18:13 2013: <191>164037: .Mar 20 09:18:12: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203324864,feature_id:8153
Wed Mar 20 09:18:13 2013: <191>164038: .Mar 20 09:18:12: //8153/1157400AB3E8/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:18:13 2013: <191>164039: SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Wed Mar 20 09:18:13 2013: <191>164040: .Mar 20 09:18:12: //8153/1157400AB3E8/CCAPI/ccCallSetContext:
Wed Mar 20 09:18:13 2013: <191>164041: Context=0x4BA72070
Wed Mar 20 09:18:13 2013: <191>164042: .Mar 20 09:18:12: //8152/1157400AB3E8/CCAPI/ccSaveDialpeerTag:
Wed Mar 20 09:18:13 2013: <191>164043: Outgoing Dial-peer=3000
Wed Mar 20 09:18:13 2013: <191>164044: .Mar 20 09:18:12: //8153/1157400AB3E8/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:18:13 2013: <191>164045: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:18:13 2013: <191>164046: .Mar 20 09:18:12: //8153/1157400AB3E8/CCAPI/cc_api_call_proceeding:
Wed Mar 20 09:18:13 2013: <191>164047: Interface=0x48A4F728, Progress Indication=NULL(0)
Wed Mar 20 09:18:13 2013: <191>164048: .Mar 20 09:18:12: //8153/1157400AB3E8/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:18:13 2013: <191>164049: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:18:13 2013: <191>164050: .Mar 20 09:18:12: //8153/1157400AB3E8/CCAPI/cc_api_set_delay_xport:
Wed Mar 20 09:18:13 2013: <191>164051: CallInfo(delay xport=TRUE)
Wed Mar 20 09:18:13 2013: <191>164052: .Mar 20 09:18:12: //8153/1157400AB3E8/CCAPI/cc_api_call_alert:
Wed Mar 20 09:18:13 2013: <191>164053: Interface=0x48A4F728, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:18:13 2013: <191>164054: .Mar 20 09:18:12: //8153/1157400AB3E8/CCAPI/cc_api_call_alert:
Wed Mar 20 09:18:13 2013: <191>164055: Call Entry(Retry Count=0, Responsed=TRUE)
Wed Mar 20 09:18:13 2013: <191>164056: .Mar 20 09:18:12: //8152/1157400AB3E8/CCAPI/ccCallAlert:
Wed Mar 20 09:18:13 2013: <191>164057:
Wed Mar 20 09:18:13 2013: <191>164058: Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:18:13 2013: <191>164059: .Mar 20 09:18:12: //8152/1157400AB3E8/CCAPI/ccCallAlert:
Wed Mar 20 09:18:13 2013: <191>164060: Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Wed Mar 20 09:18:13 2013: <191>164061: .Mar 20 09:18:12: //8153/1157400AB3E8/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:18:13 2013: <191>164062: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:18:13 2013: <191>164063: .Mar 20 09:18:12: //8153/1157400AB3E8/CCAPI/cc_api_call_notify:
Wed Mar 20 09:18:13 2013: <191>164064: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8153
Wed Mar 20 09:18:13 2013: <191>164065: .Mar 20 09:18:12: //8153/1157400AB3E8/CCAPI/ccIsInfoRingback:
Wed Mar 20 09:18:13 2013: <191>164066: Returning dpRingBack=0
Wed Mar 20 09:18:13 2013: <191>164067: .Mar 20 09:18:12: //8153/1157400AB3E8/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:18:13 2013: <191>164068: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:18:13 2013: <191>164069: .Mar 20 09:18:12: //8153/1157400AB3E8/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:18:13 2013: <191>164070: CallInfo(ccm detected=TRUE)
Wed Mar 20 09:18:13 2013: <191>164071: .Mar 20 09:18:12: //8152/1157400AB3E8/CCAPI/ccCallNotify:
Wed Mar 20 09:18:13 2013: <191>164072: Data Bitmask=0x5, Call Id=8152
Wed Mar 20 09:18:13 2013: <191>164073: .Mar 20 09:18:12: //8153/1157400AB3E8/CCAPI/cc_api_call_connected:
Wed Mar 20 09:18:13 2013: <191>164074: Interface=0x48A4F728, Data Bitmask=0x0, Progress Indication=NULL(0),
Wed Mar 20 09:18:13 2013: <191>164075: Connection Handle=0
Wed Mar 20 09:18:13 2013: <191>164076: .Mar 20 09:18:12: //8153/1157400AB3E8/CCAPI/cc_api_call_connected:
Wed Mar 20 09:18:13 2013: <191>164077: Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Wed Mar 20 09:18:13 2013: <191>164078: .Mar 20 09:18:12: //8153/1157400AB3E8/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:18:13 2013: <191>164079: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:18:13 2013: <191>164080: .Mar 20 09:18:12: //8153/1157400AB3E8/CCAPI/cc_api_call_notify:
Wed Mar 20 09:18:13 2013: <191>164081:
Wed Mar 20 09:18:13 2013: <191>164082: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8153
Wed Mar 20 09:18:13 2013: <191>164083: .Mar 20 09:18:12: //8152/1157400AB3E8/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:18:13 2013: <191>164084: Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:18:13 2013: <191>164085: Tone Direction=Network, Params=0x0, Call Id=8152
Wed Mar 20 09:18:13 2013: <191>164086: .Mar 20 09:18:12: //8152/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:18:13 2013: <191>164087: (confID=0x4BB01F60, callID1=0x1FD8, callID2=0x1FD9, tag=0x0)
Wed Mar 20 09:18:13 2013: <191>164088: .Mar 20 09:18:12: //8152/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:18:13 2013: <191>164089: (confID=0x4BB01F60, callID1=0x1FD8, gcid=1157400A-908F11E2-B3E8DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:18:13 2013: <191>164090: .Mar 20 09:18:12: //8153/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:18:13 2013: <191>164091: (confID=0x4BB01F60, callID2=0x1FD9, gcid=1157400A-908F11E2-B3E8DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:18:13 2013: <191>164092: .Mar 20 09:18:12: //8152/1157400AB3E8/CCAPI/ccConferenceCreate:
Wed Mar 20 09:18:13 2013: <191>164093: Conference Id=0x4BB01F60, Call Id1=8152, Call Id2=8153, Tag=0x0
Wed Mar 20 09:18:13 2013: <191>164094: .Mar 20 09:18:12: //8152/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:18:13 2013: <191>164095: Conference Id=0xE59, Source Interface=0x4987FF98, Source Call Id=8152,
Wed Mar 20 09:18:13 2013: <191>164096: Destination Call Id=8153, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:18:13 2013: <191>164097: .Mar 20 09:18:12: //8153/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Wed Mar 20 09:18:13 2013: <191>164098:
Wed Mar 20 09:18:13 2013: <191>164099: .Mar 20 09:18:12: cc_api_get_xcode_stream : 4534
Wed Mar 20 09:18:13 2013: <191>164100: .Mar 20 09:18:12: //8153/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:18:13 2013: <191>164101: Conference Id=0xE59, Source Interface=0x48A4F728, Source Call Id=8153,
Wed Mar 20 09:18:13 2013: <191>164102: Destination Call Id=8152, Disposition=0x0, Tag=0x0
Wed Mar 20 09:18:13 2013: <191>164103: .Mar 20 09:18:12: //8152/1157400AB3E8/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:18:13 2013: <191>164104: Conference Id=0xE59, Source Interface=0x48A4F728, Source Call Id=8153,
Wed Mar 20 09:18:13 2013: <191>164105: Destination Call Id=8152, Disposition=0x0, Tag=0x0
Wed Mar 20 09:18:13 2013: <191>164107: Call Entry(Conference Id=0xE59, Destination Call Id=8153)
Wed Mar 20 09:18:13 2013: <191>164109: Call Entry(Conference Id=0xE59, Destination Call Id=8152)
Wed Mar 20 09:18:13 2013: <191>164112: Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
Wed Mar 20 09:18:13 2013: <191>164116: Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:18:13 2013: <191>164117: .Mar 20 09:18:12: //8152/1157400AB3E8/CCAPI/cc_process_notify_bridge_done:
Wed Mar 20 09:18:13 2013: <191>164124:
Wed Mar 20 09:18:13 2013: <191>164129: Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:18:13 2013: <191>164143: .Mar 20 09:18:12: //8152/1157400AB3E8/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:18:13 2013: <191>164144: Call Entry(Context=0x4BA67528)
Wed Mar 20 09:18:13 2013: <191>164148:
Wed Mar 20 09:18:14 2013: <191>164149: Call Entry(Connected=TRUE, Responsed=TRUE)
Wed Mar 20 09:18:24 2013: <191>164150: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:18:24 2013: <191>164151: Interface=0x0, Call Id=8153
Wed Mar 20 09:18:24 2013: <191>164152: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:18:24 2013: <191>164153: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:18:24 2013: <191>164154: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_call_notify:
Wed Mar 20 09:18:24 2013: <191>164155: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8153
Wed Mar 20 09:18:24 2013: <191>164156: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:18:24 2013: <191>164157: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:18:24 2013: <191>164158: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:18:24 2013: <191>164159: CallInfo(ccm detected=TRUE)
Wed Mar 20 09:18:24 2013: <191>164160: .Mar 20 09:18:23: //8152/1157400AB3E8/CCAPI/ccCallNotify:
Wed Mar 20 09:18:24 2013: <191>164161: Data Bitmask=0x5, Call Id=8152
Wed Mar 20 09:18:24 2013: <191>164162: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:18:24 2013: <191>164163: Destination Interface=0x4987FF98, Destination Call Id=8152, Source Call Id=8153,
Wed Mar 20 09:18:24 2013: <191>164164: Caps(Codec=0x4, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:18:24 2013: <191>164165: Modem=0x2, Codec Bytes=20, Signal Type=2)
Wed Mar 20 09:18:24 2013: <191>164166: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:18:24 2013: <191>164167: Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:18:24 2013: <191>164168: Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:18:24 2013: <191>164169: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:18:24 2013: <191>164170:
Wed Mar 20 09:18:24 2013: <191>164171: Destination Interface=0x4987FF98, Destination Call Id=8152, Source Call Id=8153,
Wed Mar 20 09:18:24 2013: <191>164172: Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:18:24 2013: <191>164173: Modem=ON(0x2), Codec Bytes=20, Signal Type=2, Seq Num Start=172)
Wed Mar 20 09:18:24 2013: <191>164174: .Mar 20 09:18:23: //8152/1157400AB3E8/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:18:24 2013: <191>164175: Destination Interface=0x48A4F728, Destination Call Id=8153, Source Call Id=8152,
Wed Mar 20 09:18:24 2013: <191>164176: Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:18:24 2013: <191>164177: Modem=ON(0x2), Codec Bytes=20, Signal Type=2, Seq Num Start=172)
Wed Mar 20 09:18:24 2013: <191>164178: .Mar 20 09:18:23: //8152/1157400AB3E8/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:18:24 2013: <191>164179: Call Id=8152
Wed Mar 20 09:18:24 2013: <191>164180: .Mar 20 09:18:23: //8152/1157400AB3E8/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:18:24 2013: <191>164181:
Wed Mar 20 09:18:25 2013: <191>164182: Call Entry(Context=0x4BA67528)
Wed Mar 20 09:18:25 2013: <191>164183: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:18:25 2013: <191>164184: Interface=0x0, Call Id=8153
Wed Mar 20 09:18:25 2013: <191>164185: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:18:25 2013: <191>164186: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:18:25 2013: <191>164187: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_call_notify:
Wed Mar 20 09:18:25 2013: <191>164188: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8153
Wed Mar 20 09:18:25 2013: <191>164189: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:18:25 2013: <191>164190: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:18:25 2013: <191>164191: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:18:25 2013: <191>164192: CallInfo(ccm detected=TRUE)
Wed Mar 20 09:18:25 2013: <191>164193: .Mar 20 09:18:23: //8152/1157400AB3E8/CCAPI/ccCallNotify:
Wed Mar 20 09:18:25 2013: <191>164194:
Wed Mar 20 09:18:25 2013: <191>164195: Data Bitmask=0x5, Call Id=8152
Wed Mar 20 09:18:25 2013: <191>164196: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:18:25 2013: <191>164197: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:18:25 2013: <191>164198: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_call_notify:
Wed Mar 20 09:18:25 2013: <191>164199: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8153
Wed Mar 20 09:18:25 2013: <191>164200: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:18:25 2013: <191>164201: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:18:25 2013: <191>164202: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:18:25 2013: <191>164203: CallInfo(ccm detected=TRUE)
Wed Mar 20 09:18:25 2013: <191>164204: .Mar 20 09:18:23: //8152/1157400AB3E8/CCAPI/ccCallNotify:
Wed Mar 20 09:18:25 2013: <191>164205: Data Bitmask=0x5, Call Id=8152
Wed Mar 20 09:18:25 2013: <191>164206: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:18:25 2013: <191>164207:
Wed Mar 20 09:18:25 2013: <191>164208: Interface=0x0, Call Id=8153
Wed Mar 20 09:18:25 2013: <191>164209: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:18:25 2013: <191>164210: Cause Value=16, Interface=0x48A4F728, Call Id=8153
Wed Mar 20 09:18:25 2013: <191>164211: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:18:25 2013: <191>164212: Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:18:25 2013: <191>164213: .Mar 20 09:18:23: //8152/1157400AB3E8/CCAPI/ccConferenceDestroy:
Wed Mar 20 09:18:25 2013: <191>164214: Conference Id=0xE59, Tag=0x0
Wed Mar 20 09:18:25 2013: <191>164215: .Mar 20 09:18:23: //8152/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:18:25 2013: <191>164216: Conference Id=0xE59, Source Interface=0x4987FF98, Source Call Id=8152,
Wed Mar 20 09:18:25 2013: <191>164217: Destination Call Id=8153, Disposition=0x0, Tag=0x0
Wed Mar 20 09:18:25 2013: <191>164218: .Mar 20 09:18:23: //8153/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:18:25 2013: <191>164219:
Wed Mar 20 09:18:25 2013: <191>164220: Conference Id=0xE59, Source Interface=0x48A4F728, Source Call Id=8153,
Wed Mar 20 09:18:25 2013: <191>164221: Destination Call Id=8152, Disposition=0x0, Tag=0x0
Wed Mar 20 09:18:25 2013: <191>164222: .Mar 20 09:18:23: //8152/1157400AB3E8/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:18:25 2013: <191>164223: Conference Id=0xE59, Source Interface=0x48A4F728, Source Call Id=8153,
Wed Mar 20 09:18:25 2013: <191>164224: Destination Call Id=8152, Disposition=0x0, Tag=0x0
Wed Mar 20 09:18:25 2013: <191>164225: .Mar 20 09:18:23: //8152/1157400AB3E8/CCAPI/ccCallDisconnect:
Wed Mar 20 09:18:25 2013: <191>164226: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Wed Mar 20 09:18:25 2013: <191>164227: .Mar 20 09:18:23: //8152/1157400AB3E8/CCAPI/ccCallDisconnect:
Wed Mar 20 09:18:25 2013: <191>164228: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:18:25 2013: <191>164229: .Mar 20 09:18:23: //8152/1157400AB3E8/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:18:25 2013: <191>164230:
Wed Mar 20 09:18:25 2013: <191>164231: Transfer Number Is Null
Wed Mar 20 09:18:25 2013: <191>164232: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/ccCallDisconnect:
Wed Mar 20 09:18:25 2013: <191>164233: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:18:25 2013: <191>164234: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/ccCallDisconnect:
Wed Mar 20 09:18:25 2013: <191>164235: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:18:25 2013: <191>164236: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:18:25 2013: <191>164237: Transfer Number Is Null
Wed Mar 20 09:18:25 2013: <191>164238: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:18:25 2013: <191>164239: Transfer Number Is Null
Wed Mar 20 09:18:25 2013: <191>164240: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:18:25 2013: <191>164241:
Wed Mar 20 09:18:25 2013: <191>164242: Disposition=0, Interface=0x48A4F728, Tag=0x0, Call Id=8153,
Wed Mar 20 09:18:25 2013: <191>164243: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:18:25 2013: <191>164244: .Mar 20 09:18:23: //8153/1157400AB3E8/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:18:25 2013: <191>164245: Call Disconnect Event Sent
Wed Mar 20 09:18:25 2013: <191>164246: .Mar 20 09:18:23: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:18:25 2013: <191>164247:
Wed Mar 20 09:18:25 2013: <191>164248: .Mar 20 09:18:23: :cc_free_feature_vsa freeing 47B947B8
Wed Mar 20 09:18:25 2013: <191>164249: .Mar 20 09:18:23: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:18:25 2013: <191>164250:
Wed Mar 20 09:18:25 2013: <191>164251: .Mar 20 09:18:23: vsacount in free is 3
Wed Mar 20 09:18:25 2013: <191>164252: .Mar 20 09:18:23: //8152/1157400AB3E8/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:18:25 2013: <191>164253: Disposition=0, Interface=0x4987FF98, Tag=0x0, Call Id=8152,
Wed Mar 20 09:18:25 2013: <191>164254: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:18:26 2013: <191>164255: .Mar 20 09:18:23: //8152/1157400AB3E8/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:18:26 2013: <191>164256: Call Disconnect Event Sent
Wed Mar 20 09:18:26 2013: <191>164257: .Mar 20 09:18:23: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:18:26 2013: <191>164258:
Wed Mar 20 09:18:26 2013: <191>164259: .Mar 20 09:18:23: :cc_free_feature_vsa freeing 47B94898
Wed Mar 20 09:18:26 2013: <191>164260: .Mar 20 09:18:23: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:18:26 2013: <191>164261:
Wed Mar 20 09:18:26 2013: <191>164262: .Mar 20 09:18:23: vsacount in free is 2
Wed Mar 20 09:19:07 2013: <191>164263: .Mar 20 09:19:06: //8151/ECF034A4B3E3/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:19:07 2013: <191>164264: Cause Value=16, Interface=0x48A4F728, Call Id=8151
Wed Mar 20 09:19:07 2013: <191>164265: .Mar 20 09:19:06: //8151/ECF034A4B3E3/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:19:07 2013: <191>164266: Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:19:07 2013: <191>164267: .Mar 20 09:19:06: //8150/ECF034A4B3E3/CCAPI/ccConferenceDestroy:
Wed Mar 20 09:19:07 2013: <191>164268: Conference Id=0xE58, Tag=0x0
Wed Mar 20 09:19:07 2013: <191>164269: .Mar 20 09:19:06: //8150/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:19:07 2013: <191>164270: Conference Id=0xE58, Source Interface=0x498845E0, Source Call Id=8150,
Wed Mar 20 09:19:07 2013: <191>164271: Destination Call Id=8151, Disposition=0x0, Tag=0x0
Wed Mar 20 09:19:07 2013: <191>164272: .Mar 20 09:19:06: //8151/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:19:07 2013: <191>164273:
Wed Mar 20 09:19:07 2013: <191>164274: Conference Id=0xE58, Source Interface=0x48A4F728, Source Call Id=8151,
Wed Mar 20 09:19:07 2013: <191>164275: Destination Call Id=8150, Disposition=0x0, Tag=0x0
Wed Mar 20 09:19:07 2013: <191>164276: .Mar 20 09:19:06: //8150/ECF034A4B3E3/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:19:07 2013: <191>164277: Conference Id=0xE58, Source Interface=0x48A4F728, Source Call Id=8151,
Wed Mar 20 09:19:07 2013: <191>164278: Destination Call Id=8150, Disposition=0x0, Tag=0x0
Wed Mar 20 09:19:07 2013: <191>164279: .Mar 20 09:19:06: //8150/ECF034A4B3E3/CCAPI/ccCallDisconnect:
Wed Mar 20 09:19:07 2013: <191>164280: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Wed Mar 20 09:19:07 2013: <191>164281: .Mar 20 09:19:06: //8150/ECF034A4B3E3/CCAPI/ccCallDisconnect:
Wed Mar 20 09:19:07 2013: <191>164282: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:19:07 2013: <191>164283: .Mar 20 09:19:06: //8150/ECF034A4B3E3/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:19:07 2013: <191>164284:
Wed Mar 20 09:19:07 2013: <191>164285: Transfer Number Is Null
Wed Mar 20 09:19:07 2013: <191>164286: .Mar 20 09:19:06: //8151/ECF034A4B3E3/CCAPI/ccCallDisconnect:
Wed Mar 20 09:19:07 2013: <191>164287: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:19:07 2013: <191>164288: .Mar 20 09:19:06: //8151/ECF034A4B3E3/CCAPI/ccCallDisconnect:
Wed Mar 20 09:19:07 2013: <191>164289: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:19:07 2013: <191>164290: .Mar 20 09:19:06: //8151/ECF034A4B3E3/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:19:07 2013: <191>164291: Transfer Number Is Null
Wed Mar 20 09:19:07 2013: <191>164292: .Mar 20 09:19:06: //8151/ECF034A4B3E3/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:19:07 2013: <191>164293: Transfer Number Is Null
Wed Mar 20 09:19:07 2013: <191>164294: .Mar 20 09:19:06: //8151/ECF034A4B3E3/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:19:07 2013: <191>164295:
Wed Mar 20 09:19:07 2013: <191>164296: Disposition=0, Interface=0x48A4F728, Tag=0x0, Call Id=8151,
Wed Mar 20 09:19:07 2013: <191>164297: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:19:07 2013: <191>164298: .Mar 20 09:19:06: //8151/ECF034A4B3E3/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:19:07 2013: <191>164299: Call Disconnect Event Sent
Wed Mar 20 09:19:07 2013: <191>164300: .Mar 20 09:19:06: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:19:07 2013: <191>164301:
Wed Mar 20 09:19:07 2013: <191>164302: .Mar 20 09:19:06: :cc_free_feature_vsa freeing 47B94978
Wed Mar 20 09:19:07 2013: <191>164303: .Mar 20 09:19:06: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:19:07 2013: <191>164304:
Wed Mar 20 09:19:07 2013: <191>164305: .Mar 20 09:19:06: vsacount in free is 1
Wed Mar 20 09:19:07 2013: <191>164306: .Mar 20 09:19:06: //8150/ECF034A4B3E3/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:19:07 2013: <191>164307: Disposition=0, Interface=0x498845E0, Tag=0x0, Call Id=8150,
Wed Mar 20 09:19:07 2013: <191>164308: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:19:08 2013: <191>164309: .Mar 20 09:19:06: //8150/ECF034A4B3E3/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:19:08 2013: <191>164310: Call Disconnect Event Sent
Wed Mar 20 09:19:08 2013: <191>164311: .Mar 20 09:19:06: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:19:08 2013: <191>164312:
Wed Mar 20 09:19:08 2013: <191>164313: .Mar 20 09:19:06: :cc_free_feature_vsa freeing 47B94A58
Wed Mar 20 09:19:08 2013: <191>164314: .Mar 20 09:19:06: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:19:08 2013: <191>164315:
Wed Mar 20 09:19:08 2013: <191>164316: .Mar 20 09:19:06: vsacount in free is 0
Wed Mar 20 09:19:51 2013: <191>164317: .Mar 20 09:19:50: //-1/4C22D265B3ED/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:19:51 2013: <191>164320: ----- ccCallInfo IE subfields -----
Wed Mar 20 09:19:51 2013: <191>164321: cisco-ani=
Wed Mar 20 09:19:51 2013: <191>164322: cisco-anitype=0
Wed Mar 20 09:19:51 2013: <191>164318: cc_api_call_setup_ind_common:
Wed Mar 20 09:19:51 2013: <191>164323: cisco-aniplan=0
Wed Mar 20 09:19:51 2013: <191>164324: cisco-anipi=0
Wed Mar 20 09:19:51 2013: <191>164319: cisco-username=
Wed Mar 20 09:19:51 2013: <191>164325: cisco-anisi=0
Wed Mar 20 09:19:51 2013: <191>164326: dest=1811032099
Wed Mar 20 09:19:51 2013: <191>164327: cisco-desttype=0
Wed Mar 20 09:19:51 2013: <191>164328: cisco-destplan=0
Wed Mar 20 09:19:51 2013: <191>164329: cisco-rdie=FFFFFFFF
Wed Mar 20 09:19:51 2013: <191>164330: cisco-rdn=
Wed Mar 20 09:19:51 2013: <191>164331: cisco-lastrdn=
Wed Mar 20 09:19:51 2013: <191>164332: cisco-rdntype=0
Wed Mar 20 09:19:51 2013: <191>164333: cisco-rdnplan=0
Wed Mar 20 09:19:51 2013: <191>164334: cisco-rdnpi=0
Wed Mar 20 09:19:51 2013: <191>164335: cisco-rdnsi=0
Wed Mar 20 09:19:51 2013: <191>164336: cisco-redirectreason=0 fwd_final_type =0
Wed Mar 20 09:19:51 2013: <191>164337: final_redirectNumber =
Wed Mar 20 09:19:51 2013: <191>164338: hunt_group_timeout =0
Wed Mar 20 09:19:51 2013: <191>164339:
Wed Mar 20 09:19:51 2013: <191>164340: .Mar 20 09:19:50: //-1/4C22D265B3ED/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:19:51 2013: <191>164341:
Wed Mar 20 09:19:51 2013: <191>164342: Interface=0x498845E0, Call Info(
Wed Mar 20 09:19:51 2013: <191>164343: Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:19:51 2013: <191>164344: Called Number=1811032099(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:19:51 2013: <191>164345: Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
Wed Mar 20 09:19:51 2013: <191>164346: Incoming Dial-peer=50, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
Wed Mar 20 09:19:51 2013: <191>164347: Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:19:51 2013: <191>164348: .Mar 20 09:19:50: //-1/4C22D265B3ED/CCAPI/ccCheckClipClir:
Wed Mar 20 09:19:51 2013: <191>164349: In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:19:51 2013: <191>164350: .Mar 20 09:19:50: //-1/4C22D265B3ED/CCAPI/ccCheckClipClir:
Wed Mar 20 09:19:51 2013: <191>164351: Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:19:51 2013: <191>164352: .Mar 20 09:19:50: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:19:51 2013: <191>164353:
Wed Mar 20 09:19:51 2013: <191>164354: .Mar 20 09:19:50: :cc_get_feature_vsa malloc success
Wed Mar 20 09:19:51 2013: <191>164355: .Mar 20 09:19:50: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:19:51 2013: <191>164356:
Wed Mar 20 09:19:51 2013: <191>164357: .Mar 20 09:19:50: cc_get_feature_vsa count is 1
Wed Mar 20 09:19:51 2013: <191>164358: .Mar 20 09:19:50: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:19:51 2013: <191>164359:
Wed Mar 20 09:19:51 2013: <191>164360: .Mar 20 09:19:50: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203322344,feature_id:8154
Wed Mar 20 09:19:51 2013: <191>164361: .Mar 20 09:19:50: //8154/4C22D265B3ED/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:19:51 2013: <191>164362:
Wed Mar 20 09:19:51 2013: <191>164363: Set Up Event Sent;
Wed Mar 20 09:19:51 2013: <191>164364: Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:19:51 2013: <191>164365: Called Number=1811032099(TON=Unknown, NPI=Unknown))
Wed Mar 20 09:19:51 2013: <191>164368: .Mar 20 09:19:50: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Wed Mar 20 09:19:51 2013: <191>164376: Progress Indication=NULL(0)
Wed Mar 20 09:19:51 2013: <191>164385:
Wed Mar 20 09:19:51 2013: <191>164386: Destination Pattern=1811032099, Called Number=1811032099, Digit Strip=FALSE
Wed Mar 20 09:19:51 2013: <191>164387: .Mar 20 09:19:50: //8154/4C22D265B3ED/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:19:51 2013: <191>164388: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:19:51 2013: <191>164394: ccCallSetupRequest:
Wed Mar 20 09:19:51 2013: <191>164398: cisco-anitype=0
Wed Mar 20 09:19:51 2013: <191>164399: cisco-aniplan=0
Wed Mar 20 09:19:51 2013: <191>164401:
Wed Mar 20 09:19:51 2013: <191>164404: cisco-desttype=0
Wed Mar 20 09:19:51 2013: <191>164412: cisco-rdnsi=0
Wed Mar 20 09:19:51 2013: <191>164413: cisco-redirectreason=0 fwd_final_type =0
Wed Mar 20 09:19:51 2013: <191>164416:
Wed Mar 20 09:19:51 2013: <191>164429: .Mar 20 09:19:50: cc_get_feature_vsa count is 2
Wed Mar 20 09:19:51 2013: <191>164430: .Mar 20 09:19:50: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:19:51 2013: <191>164431:
Wed Mar 20 09:19:51 2013: <191>164432: .Mar 20 09:19:50: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203322120,feature_id:8155
Wed Mar 20 09:19:51 2013: <191>164433: .Mar 20 09:19:50: //8155/4C22D265B3ED/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:19:51 2013: <191>164434: SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Wed Mar 20 09:19:51 2013: <191>164435: .Mar 20 09:19:50: //8155/4C22D265B3ED/CCAPI/ccCallSetContext:
Wed Mar 20 09:19:51 2013: <191>164436: Context=0x4BA73378
Wed Mar 20 09:19:51 2013: <191>164437: .Mar 20 09:19:50: //8154/4C22D265B3ED/CCAPI/ccSaveDialpeerTag:
Wed Mar 20 09:19:51 2013: <191>164438: Outgoing Dial-peer=3000
Wed Mar 20 09:19:51 2013: <191>164439: .Mar 20 09:19:50: //8155/4C22D265B3ED/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:19:51 2013: <191>164440: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:19:51 2013: <191>164441: .Mar 20 09:19:50: //8155/4C22D265B3ED/CCAPI/cc_api_call_proceeding:
Wed Mar 20 09:19:51 2013: <191>164442: Interface=0x48A4F728, Progress Indication=NULL(0)
Wed Mar 20 09:19:51 2013: <191>164443: .Mar 20 09:19:50: //8155/4C22D265B3ED/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:19:51 2013: <191>164444: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:19:51 2013: <191>164445: .Mar 20 09:19:50: //8155/4C22D265B3ED/CCAPI/cc_api_set_delay_xport:
Wed Mar 20 09:19:51 2013: <191>164446: CallInfo(delay xport=TRUE)
Wed Mar 20 09:19:51 2013: <191>164447: .Mar 20 09:19:50: //8155/4C22D265B3ED/CCAPI/cc_api_call_alert:
Wed Mar 20 09:19:51 2013: <191>164448: Interface=0x48A4F728, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:19:51 2013: <191>164449: .Mar 20 09:19:50: //8155/4C22D265B3ED/CCAPI/cc_api_call_alert:
Wed Mar 20 09:19:51 2013: <191>164450: Call Entry(Retry Count=0, Responsed=TRUE)
Wed Mar 20 09:19:51 2013: <191>164451: .Mar 20 09:19:50: //8154/4C22D265B3ED/CCAPI/ccCallAlert:
Wed Mar 20 09:19:51 2013: <191>164452:
Wed Mar 20 09:19:52 2013: <191>164453: Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:19:52 2013: <191>164454: .Mar 20 09:19:50: //8154/4C22D265B3ED/CCAPI/ccCallAlert:
Wed Mar 20 09:19:52 2013: <191>164455: Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Wed Mar 20 09:19:52 2013: <191>164456: .Mar 20 09:19:50: //8155/4C22D265B3ED/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:19:52 2013: <191>164457: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:19:52 2013: <191>164458: .Mar 20 09:19:50: //8155/4C22D265B3ED/CCAPI/cc_api_call_notify:
Wed Mar 20 09:19:52 2013: <191>164459: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8155
Wed Mar 20 09:19:52 2013: <191>164460: .Mar 20 09:19:50: //8155/4C22D265B3ED/CCAPI/ccIsInfoRingback:
Wed Mar 20 09:19:52 2013: <191>164461: Returning dpRingBack=0
Wed Mar 20 09:19:52 2013: <191>164462: .Mar 20 09:19:50: //8155/4C22D265B3ED/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:19:52 2013: <191>164463: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:19:52 2013: <191>164464: .Mar 20 09:19:50: //8155/4C22D265B3ED/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:19:52 2013: <191>164465: CallInfo(ccm detected=TRUE)
Wed Mar 20 09:19:52 2013: <191>164466: .Mar 20 09:19:50: //8154/4C22D265B3ED/CCAPI/ccCallNotify:
Wed Mar 20 09:19:52 2013: <191>164467: Data Bitmask=0x5, Call Id=8154
Wed Mar 20 09:19:52 2013: <191>164468: .Mar 20 09:19:51: //8155/4C22D265B3ED/CCAPI/cc_api_call_connected:
Wed Mar 20 09:19:52 2013: <191>164469: Interface=0x48A4F728, Data Bitmask=0x0, Progress Indication=NULL(0),
Wed Mar 20 09:19:52 2013: <191>164470: Connection Handle=0
Wed Mar 20 09:19:52 2013: <191>164471: .Mar 20 09:19:51: //8155/4C22D265B3ED/CCAPI/cc_api_call_connected:
Wed Mar 20 09:19:52 2013: <191>164472: Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Wed Mar 20 09:19:52 2013: <191>164473: .Mar 20 09:19:51: //8155/4C22D265B3ED/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:19:52 2013: <191>164474: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:19:52 2013: <191>164475: .Mar 20 09:19:51: //8155/4C22D265B3ED/CCAPI/cc_api_call_notify:
Wed Mar 20 09:19:52 2013: <191>164476:
Wed Mar 20 09:19:52 2013: <191>164477: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8155
Wed Mar 20 09:19:52 2013: <191>164478: .Mar 20 09:19:51: //8154/4C22D265B3ED/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:19:52 2013: <191>164479: Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:19:52 2013: <191>164480: Tone Direction=Network, Params=0x0, Call Id=8154
Wed Mar 20 09:19:52 2013: <191>164481: .Mar 20 09:19:51: //8154/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:19:52 2013: <191>164482: (confID=0x4BB02158, callID1=0x1FDA, callID2=0x1FDB, tag=0x0)
Wed Mar 20 09:19:52 2013: <191>164483: .Mar 20 09:19:51: //8154/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:19:52 2013: <191>164484: (confID=0x4BB02158, callID1=0x1FDA, gcid=4C22D265-908F11E2-B3EDDE08-FC69A21F, tag=0x0)
Wed Mar 20 09:19:52 2013: <191>164485: .Mar 20 09:19:51: //8155/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:19:52 2013: <191>164486: (confID=0x4BB02158, callID2=0x1FDB, gcid=4C22D265-908F11E2-B3EDDE08-FC69A21F, tag=0x0)
Wed Mar 20 09:19:52 2013: <191>164487: .Mar 20 09:19:51: //8154/4C22D265B3ED/CCAPI/ccConferenceCreate:
Wed Mar 20 09:19:52 2013: <191>164488: Conference Id=0x4BB02158, Call Id1=8154, Call Id2=8155, Tag=0x0
Wed Mar 20 09:19:52 2013: <191>164489: .Mar 20 09:19:51: //8154/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:19:52 2013: <191>164490: Conference Id=0xE5A, Source Interface=0x498845E0, Source Call Id=8154,
Wed Mar 20 09:19:52 2013: <191>164491: Destination Call Id=8155, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:19:52 2013: <191>164492: .Mar 20 09:19:51: //8155/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Wed Mar 20 09:19:52 2013: <191>164493:
Wed Mar 20 09:19:52 2013: <191>164494: .Mar 20 09:19:51: cc_api_get_xcode_stream : 4534
Wed Mar 20 09:19:52 2013: <191>164495: .Mar 20 09:19:51: //8155/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:19:52 2013: <191>164496: Conference Id=0xE5A, Source Interface=0x48A4F728, Source Call Id=8155,
Wed Mar 20 09:19:52 2013: <191>164497: Destination Call Id=8154, Disposition=0x0, Tag=0x0
Wed Mar 20 09:19:52 2013: <191>164500: Destination Call Id=8154, Disposition=0x0, Tag=0x0
Wed Mar 20 09:19:52 2013: <191>164502: Call Entry(Conference Id=0xE5A, Destination Call Id=8155)
Wed Mar 20 09:19:52 2013: <191>164503: .Mar 20 09:19:51: //8155/4C22D265B3ED/CCAPI/ccConferenceCreate:
Wed Mar 20 09:19:52 2013: <191>164504: Call Entry(Conference Id=0xE5A, Destination Call Id=8154)
Wed Mar 20 09:19:52 2013: <191>164506: Destination Interface=0x48A4F728, Destination Call Id=8155, Source Call Id=8154,
Wed Mar 20 09:19:52 2013: <191>164514: .Mar 20 09:19:51: //8155/4C22D265B3ED/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:19:52 2013: <191>164523: Destination Interface=0x498845E0, Destination Call Id=8154, Source Call Id=8155,
Wed Mar 20 09:19:52 2013: <191>164529: Modem=ON(0x2), Codec Bytes=20, Signal Type=2, Seq Num Start=5320)
Wed Mar 20 09:19:52 2013: <191>164530: .Mar 20 09:19:51: //8155/4C22D265B3ED/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:19:52 2013: <191>164531: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:19:52 2013: <191>164532: .Mar 20 09:19:51: //8155/4C22D265B3ED/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:19:52 2013: <191>164533: CallInfo(ccm detected=TRUE)
Wed Mar 20 09:19:52 2013: <191>164535: Data Bitmask=0x5, Call Id=8154
Wed Mar 20 09:19:52 2013: <191>164536: .Mar 20 09:19:51: //8154/4C22D265B3ED/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:19:52 2013: <191>164537: Call Id=8154
Wed Mar 20 09:19:52 2013: <191>164538: .Mar 20 09:19:51: //8154/4C22D265B3ED/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:19:52 2013: <191>164543:
Wed Mar 20 09:19:53 2013: <191>164544: Call Entry(Connected=TRUE, Responsed=TRUE)
Wed Mar 20 09:20:03 2013: <191>164545: .Mar 20 09:20:02: //8155/4C22D265B3ED/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:20:03 2013: <191>164546: Interface=0x0, Call Id=8155
Wed Mar 20 09:20:03 2013: <191>164547: .Mar 20 09:20:02: //8155/4C22D265B3ED/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:20:03 2013: <191>164548: Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:20:03 2013: <191>164549: .Mar 20 09:20:02: //8155/4C22D265B3ED/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:20:03 2013: <191>164550: Interface=0x48A4F728, Signal Indication=NOT PRESENT(255)
Wed Mar 20 09:20:03 2013: <191>164551: .Mar 20 09:20:02: //8154/4C22D265B3ED/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:20:03 2013: <191>164552: Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:20:03 2013: <191>164553: Tone Direction=Network, Params=0x0, Call Id=8154
Wed Mar 20 09:20:03 2013: <191>164554: .Mar 20 09:20:02: //8155/4C22D265B3ED/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:20:03 2013: <191>164555: Interface=0x48A4F728, Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:20:03 2013: <191>164556: .Mar 20 09:20:02: //8154/4C22D265B3ED/CCAPI/ccCallUserInfo:
Wed Mar 20 09:20:03 2013: <191>164557: Call Id=8154
Wed Mar 20 09:20:03 2013: <191>164558: .Mar 20 09:20:02: //8154/4C22D265B3ED/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:20:03 2013: <191>164559: Stop Tone On Digit=FALSE, Tone=Ring Back,
Wed Mar 20 09:20:03 2013: <191>164560: Tone Direction=Network, Params=0x0, Call Id=8154
Wed Mar 20 09:20:03 2013: <191>164561: .Mar 20 09:20:02: //8155/4C22D265B3ED/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:20:03 2013: <191>164562: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:20:03 2013: <191>164563: .Mar 20 09:20:02: //8155/4C22D265B3ED/CCAPI/cc_api_call_notify:
Wed Mar 20 09:20:03 2013: <191>164564: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8155
Wed Mar 20 09:20:03 2013: <191>164565: .Mar 20 09:20:02: //8155/4C22D265B3ED/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:20:03 2013: <191>164566: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:20:04 2013: <191>164567: .Mar 20 09:20:02: //8155/4C22D265B3ED/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:20:04 2013: <191>164568: CallInfo(ccm detected=TRUE)
Wed Mar 20 09:20:04 2013: <191>164569: .Mar 20 09:20:02: //8154/4C22D265B3ED/CCAPI/ccCallNotify:
Wed Mar 20 09:20:04 2013: <191>164570: Data Bitmask=0x5, Call Id=8154
Wed Mar 20 09:20:18 2013: <191>164571: .Mar 20 09:20:17: //8155/4C22D265B3ED/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:20:18 2013: <191>164572: Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:20:18 2013: <191>164573: .Mar 20 09:20:17: //8155/4C22D265B3ED/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:20:18 2013: <191>164574: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:20:18 2013: <191>164575: .Mar 20 09:20:17: //8155/4C22D265B3ED/CCAPI/cc_api_call_notify:
Wed Mar 20 09:20:18 2013: <191>164576: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8155
Wed Mar 20 09:20:18 2013: <191>164577: .Mar 20 09:20:17: //8154/4C22D265B3ED/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:20:18 2013: <191>164578: Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:20:18 2013: <191>164579: Tone Direction=Network, Params=0x0, Call Id=8154
Wed Mar 20 09:20:18 2013: <191>164580: .Mar 20 09:20:17: //8155/4C22D265B3ED/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:20:18 2013: <191>164581: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:20:18 2013: <191>164582: .Mar 20 09:20:17: //8155/4C22D265B3ED/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:20:18 2013: <191>164583: CallInfo(ccm detected=TRUE)
Wed Mar 20 09:20:18 2013: <191>164584: .Mar 20 09:20:17: //8154/4C22D265B3ED/CCAPI/ccCallNotify:
Wed Mar 20 09:20:18 2013: <191>164585: Data Bitmask=0x5, Call Id=8154
Wed Mar 20 09:20:18 2013: <191>164586: .Mar 20 09:20:17: //8155/4C22D265B3ED/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:20:18 2013: <191>164587: Destination Interface=0x498845E0, Destination Call Id=8154, Source Call Id=8155,
Wed Mar 20 09:20:18 2013: <191>164588: Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:20:18 2013: <191>164589: Modem=0x2, Codec Bytes=160, Signal Type=2)
Wed Mar 20 09:20:18 2013: <191>164590: .Mar 20 09:20:17: //8155/4C22D265B3ED/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:20:18 2013: <191>164591: Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:20:18 2013: <191>164592: Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:20:18 2013: <191>164593: .Mar 20 09:20:17: //8155/4C22D265B3ED/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:20:18 2013: <191>164594:
Wed Mar 20 09:20:18 2013: <191>164595: Destination Interface=0x498845E0, Destination Call Id=8154, Source Call Id=8155,
Wed Mar 20 09:20:18 2013: <191>164596: Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:20:18 2013: <191>164597: Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=5364)
Wed Mar 20 09:20:18 2013: <191>164598: .Mar 20 09:20:17: //8154/4C22D265B3ED/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:20:18 2013: <191>164599: Destination Interface=0x48A4F728, Destination Call Id=8155, Source Call Id=8154,
Wed Mar 20 09:20:18 2013: <191>164600: Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:20:18 2013: <191>164601: Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=5364)
Wed Mar 20 09:20:18 2013: <191>164602: .Mar 20 09:20:17: //8154/4C22D265B3ED/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:20:18 2013: <191>164603: Call Id=8154
Wed Mar 20 09:20:18 2013: <191>164604: .Mar 20 09:20:17: //8154/4C22D265B3ED/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:20:18 2013: <191>164605:
Wed Mar 20 09:20:19 2013: <191>164606: Call Entry(Context=0x4BA792A0)
Wed Mar 20 09:20:50 2013: <191>164607: .Mar 20 09:20:49: //8155/4C22D265B3ED/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:20:50 2013: <191>164608: Interface=0x0, Call Id=8155
Wed Mar 20 09:20:50 2013: <191>164609: .Mar 20 09:20:49: //8155/4C22D265B3ED/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:20:50 2013: <191>164610: Destination Interface=0x498845E0, Destination Call Id=8154, Source Call Id=8155,
Wed Mar 20 09:20:50 2013: <191>164611: Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:20:50 2013: <191>164612: Modem=0x2, Codec Bytes=160, Signal Type=2)
Wed Mar 20 09:20:50 2013: <191>164613: .Mar 20 09:20:49: //8155/4C22D265B3ED/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:20:50 2013: <191>164614: Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:20:50 2013: <191>164615: Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:20:50 2013: <191>164616: .Mar 20 09:20:49: //8155/4C22D265B3ED/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:20:50 2013: <191>164617:
Wed Mar 20 09:20:50 2013: <191>164618: Destination Interface=0x498845E0, Destination Call Id=8154, Source Call Id=8155,
Wed Mar 20 09:20:50 2013: <191>164619: Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:20:50 2013: <191>164620: Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=5988)
Wed Mar 20 09:20:50 2013: <191>164621: .Mar 20 09:20:49: //8154/4C22D265B3ED/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:20:50 2013: <191>164622: Destination Interface=0x48A4F728, Destination Call Id=8155, Source Call Id=8154,
Wed Mar 20 09:20:50 2013: <191>164623: Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:20:50 2013: <191>164624: Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=5988)
Wed Mar 20 09:20:50 2013: <191>164625: .Mar 20 09:20:49: //8154/4C22D265B3ED/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:20:50 2013: <191>164626: Call Id=8154
Wed Mar 20 09:20:50 2013: <191>164627: .Mar 20 09:20:49: //8154/4C22D265B3ED/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:20:50 2013: <191>164628:
Wed Mar 20 09:20:51 2013: <191>164629: Call Entry(Context=0x4BA792A0)
Wed Mar 20 09:20:54 2013: <191>164630: .Mar 20 09:20:52: //8155/4C22D265B3ED/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:20:54 2013: <191>164631: Interface=0x0, Call Id=8155
Wed Mar 20 09:20:54 2013: <191>164632: .Mar 20 09:20:52: //8155/4C22D265B3ED/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:20:54 2013: <191>164633: Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:20:54 2013: <191>164634: .Mar 20 09:20:52: //8154/4C22D265B3ED/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:20:54 2013: <191>164635: Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:20:54 2013: <191>164636: Tone Direction=Network, Params=0x0, Call Id=8154
Wed Mar 20 09:20:54 2013: <191>164637: .Mar 20 09:20:52: //8155/4C22D265B3ED/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:20:54 2013: <191>164638: Interface=0x48A4F728, Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:20:54 2013: <191>164639: .Mar 20 09:20:52: //8155/4C22D265B3ED/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:20:54 2013: <191>164640: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:20:55 2013: <191>164641: .Mar 20 09:20:52: //8155/4C22D265B3ED/CCAPI/cc_api_call_notify:
Wed Mar 20 09:20:55 2013: <191>164642: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8155
Wed Mar 20 09:20:55 2013: <191>164643: .Mar 20 09:20:52: //8154/4C22D265B3ED/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:20:55 2013: <191>164644: Stop Tone On Digit=FALSE, Tone=Ring Back,
Wed Mar 20 09:20:55 2013: <191>164645: Tone Direction=Network, Params=0x0, Call Id=8154
Wed Mar 20 09:20:55 2013: <191>164646: .Mar 20 09:20:52: //8155/4C22D265B3ED/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:20:55 2013: <191>164647: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:20:55 2013: <191>164648: .Mar 20 09:20:52: //8155/4C22D265B3ED/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:20:55 2013: <191>164649: CallInfo(ccm detected=TRUE)
Wed Mar 20 09:20:55 2013: <191>164650: .Mar 20 09:20:52: //8154/4C22D265B3ED/CCAPI/ccCallNotify:
Wed Mar 20 09:20:55 2013: <191>164651: Data Bitmask=0x5, Call Id=8154
Wed Mar 20 09:21:00 2013: <191>164652: .Mar 20 09:20:59: //8155/4C22D265B3ED/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:21:00 2013: <191>164653: Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:21:00 2013: <191>164654: .Mar 20 09:20:59: //8155/4C22D265B3ED/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:21:00 2013: <191>164655: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:21:00 2013: <191>164656: .Mar 20 09:20:59: //8155/4C22D265B3ED/CCAPI/cc_api_call_notify:
Wed Mar 20 09:21:00 2013: <191>164657: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8155
Wed Mar 20 09:21:00 2013: <191>164658: .Mar 20 09:20:59: //8154/4C22D265B3ED/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:21:00 2013: <191>164659: Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:21:00 2013: <191>164660: Tone Direction=Network, Params=0x0, Call Id=8154
Wed Mar 20 09:21:00 2013: <191>164661: .Mar 20 09:20:59: //8155/4C22D265B3ED/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:21:00 2013: <191>164662: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:21:00 2013: <191>164663: .Mar 20 09:20:59: //8155/4C22D265B3ED/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:21:00 2013: <191>164664: CallInfo(ccm detected=TRUE)
Wed Mar 20 09:21:00 2013: <191>164665: .Mar 20 09:20:59: //8154/4C22D265B3ED/CCAPI/ccCallNotify:
Wed Mar 20 09:21:00 2013: <191>164666: Data Bitmask=0x5, Call Id=8154
Wed Mar 20 09:21:00 2013: <191>164667: .Mar 20 09:20:59: //8155/4C22D265B3ED/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:21:00 2013: <191>164668: Destination Interface=0x498845E0, Destination Call Id=8154, Source Call Id=8155,
Wed Mar 20 09:21:00 2013: <191>164669: Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:21:00 2013: <191>164670: Modem=0x2, Codec Bytes=160, Signal Type=2)
Wed Mar 20 09:21:00 2013: <191>164671: .Mar 20 09:20:59: //8155/4C22D265B3ED/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:21:00 2013: <191>164672: Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:21:00 2013: <191>164673: Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:21:00 2013: <191>164674: .Mar 20 09:20:59: //8155/4C22D265B3ED/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:21:00 2013: <191>164675:
Wed Mar 20 09:21:00 2013: <191>164676: Destination Interface=0x498845E0, Destination Call Id=8154, Source Call Id=8155,
Wed Mar 20 09:21:00 2013: <191>164677: Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:21:00 2013: <191>164678: Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=6101)
Wed Mar 20 09:21:00 2013: <191>164679: .Mar 20 09:20:59: //8154/4C22D265B3ED/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:21:00 2013: <191>164680: Destination Interface=0x48A4F728, Destination Call Id=8155, Source Call Id=8154,
Wed Mar 20 09:21:00 2013: <191>164681: Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:21:00 2013: <191>164682: Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=6101)
Wed Mar 20 09:21:00 2013: <191>164683: .Mar 20 09:20:59: //8154/4C22D265B3ED/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:21:00 2013: <191>164684: Call Id=8154
Wed Mar 20 09:21:00 2013: <191>164685: .Mar 20 09:20:59: //8154/4C22D265B3ED/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:21:00 2013: <191>164686:
Wed Mar 20 09:21:01 2013: <191>164687: Call Entry(Context=0x4BA792A0)
Wed Mar 20 09:21:56 2013: <191>164688: .Mar 20 09:21:55: //8155/4C22D265B3ED/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:21:56 2013: <191>164689: Interface=0x0, Call Id=8155
Wed Mar 20 09:21:56 2013: <191>164690: .Mar 20 09:21:55: //8155/4C22D265B3ED/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:21:56 2013: <191>164691: Cause Value=16, Interface=0x48A4F728, Call Id=8155
Wed Mar 20 09:21:56 2013: <191>164692: .Mar 20 09:21:55: //8155/4C22D265B3ED/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:21:56 2013: <191>164693: Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:21:56 2013: <191>164694: .Mar 20 09:21:55: //8154/4C22D265B3ED/CCAPI/ccConferenceDestroy:
Wed Mar 20 09:21:56 2013: <191>164695: Conference Id=0xE5A, Tag=0x0
Wed Mar 20 09:21:56 2013: <191>164696: .Mar 20 09:21:55: //8154/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:21:56 2013: <191>164697: Conference Id=0xE5A, Source Interface=0x498845E0, Source Call Id=8154,
Wed Mar 20 09:21:56 2013: <191>164698: Destination Call Id=8155, Disposition=0x0, Tag=0x0
Wed Mar 20 09:21:56 2013: <191>164699: .Mar 20 09:21:55: //8155/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:21:56 2013: <191>164700: Conference Id=0xE5A, Source Interface=0x48A4F728, Source Call Id=8155,
Wed Mar 20 09:21:56 2013: <191>164701: Destination Call Id=8154, Disposition=0x0, Tag=0x0
Wed Mar 20 09:21:56 2013: <191>164702: .Mar 20 09:21:55: //8154/4C22D265B3ED/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:21:56 2013: <191>164703: Conference Id=0xE5A, Source Interface=0x48A4F728, Source Call Id=8155,
Wed Mar 20 09:21:56 2013: <191>164704: Destination Call Id=8154, Disposition=0x0, Tag=0x0
Wed Mar 20 09:21:56 2013: <191>164705: .Mar 20 09:21:55: //8154/4C22D265B3ED/CCAPI/ccCallDisconnect:
Wed Mar 20 09:21:56 2013: <191>164706: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Wed Mar 20 09:21:56 2013: <191>164707: .Mar 20 09:21:55: //8154/4C22D265B3ED/CCAPI/ccCallDisconnect:
Wed Mar 20 09:21:56 2013: <191>164708: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:21:56 2013: <191>164709: .Mar 20 09:21:55: //8154/4C22D265B3ED/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:21:56 2013: <191>164710: Transfer Number Is Null
Wed Mar 20 09:21:56 2013: <191>164711: .Mar 20 09:21:55: //8155/4C22D265B3ED/CCAPI/ccCallDisconnect:
Wed Mar 20 09:21:56 2013: <191>164712: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:21:56 2013: <191>164713: .Mar 20 09:21:55: //8155/4C22D265B3ED/CCAPI/ccCallDisconnect:
Wed Mar 20 09:21:56 2013: <191>164714: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:21:56 2013: <191>164715: .Mar 20 09:21:55: //8155/4C22D265B3ED/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:21:56 2013: <191>164716: Transfer Number Is Null
Wed Mar 20 09:21:56 2013: <191>164717: .Mar 20 09:21:55: //8155/4C22D265B3ED/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:21:56 2013: <191>164718: Transfer Number Is Null
Wed Mar 20 09:21:56 2013: <191>164719: .Mar 20 09:21:55: //8155/4C22D265B3ED/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:21:56 2013: <191>164720:
Wed Mar 20 09:21:56 2013: <191>164721: Disposition=0, Interface=0x48A4F728, Tag=0x0, Call Id=8155,
Wed Mar 20 09:21:56 2013: <191>164722: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:21:56 2013: <191>164723: .Mar 20 09:21:55: //8155/4C22D265B3ED/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:21:56 2013: <191>164724: Call Disconnect Event Sent
Wed Mar 20 09:21:56 2013: <191>164725: .Mar 20 09:21:55: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:21:56 2013: <191>164726:
Wed Mar 20 09:21:56 2013: <191>164727: .Mar 20 09:21:55: :cc_free_feature_vsa freeing 47B93D00
Wed Mar 20 09:21:56 2013: <191>164728: .Mar 20 09:21:55: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:21:56 2013: <191>164729:
Wed Mar 20 09:21:56 2013: <191>164730: .Mar 20 09:21:55: vsacount in free is 1
Wed Mar 20 09:21:56 2013: <191>164731: .Mar 20 09:21:55: //8154/4C22D265B3ED/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:21:56 2013: <191>164732: Disposition=0, Interface=0x498845E0, Tag=0x0, Call Id=8154,
Wed Mar 20 09:21:56 2013: <191>164733: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:21:57 2013: <191>164734: .Mar 20 09:21:55: //8154/4C22D265B3ED/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:21:57 2013: <191>164735: Call Disconnect Event Sent
Wed Mar 20 09:21:57 2013: <191>164736: .Mar 20 09:21:55: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:21:57 2013: <191>164737:
Wed Mar 20 09:21:57 2013: <191>164738: .Mar 20 09:21:55: :cc_free_feature_vsa freeing 47B93DE0
Wed Mar 20 09:21:57 2013: <191>164739: .Mar 20 09:21:55: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:21:57 2013: <191>164740:
Wed Mar 20 09:21:57 2013: <191>164741: .Mar 20 09:21:55: vsacount in free is 0
Wed Mar 20 09:23:15 2013: <191>164744: cisco-username=
Wed Mar 20 09:23:15 2013: <191>164742: .Mar 20 09:23:14: //-1/C58B2C38B3F2/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:23:15 2013: <191>164743: cc_api_call_setup_ind_common:
Wed Mar 20 09:23:15 2013: <191>164745: ----- ccCallInfo IE subfields -----
Wed Mar 20 09:23:15 2013: <191>164746: cisco-ani=
Wed Mar 20 09:23:15 2013: <191>164747: cisco-anitype=0
Wed Mar 20 09:23:15 2013: <191>164748: cisco-aniplan=0
Wed Mar 20 09:23:15 2013: <191>164749: cisco-anipi=0
Wed Mar 20 09:23:15 2013: <191>164750: cisco-anisi=0
Wed Mar 20 09:23:15 2013: <191>164751: dest=1811032099
Wed Mar 20 09:23:15 2013: <191>164752: cisco-desttype=0
Wed Mar 20 09:23:15 2013: <191>164753: cisco-destplan=0
Wed Mar 20 09:23:15 2013: <191>164754: cisco-rdie=FFFFFFFF
Wed Mar 20 09:23:15 2013: <191>164755: cisco-rdn=
Wed Mar 20 09:23:15 2013: <191>164756: cisco-lastrdn=
Wed Mar 20 09:23:15 2013: <191>164757: cisco-rdntype=0
Wed Mar 20 09:23:15 2013: <191>164758: cisco-rdnplan=0
Wed Mar 20 09:23:15 2013: <191>164759: cisco-rdnpi=0
Wed Mar 20 09:23:15 2013: <191>164760: cisco-rdnsi=0
Wed Mar 20 09:23:15 2013: <191>164761: cisco-redirectreason=0 fwd_final_type =0
Wed Mar 20 09:23:15 2013: <191>164762: final_redirectNumber =
Wed Mar 20 09:23:15 2013: <191>164763: hunt_group_timeout =0
Wed Mar 20 09:23:15 2013: <191>164764:
Wed Mar 20 09:23:15 2013: <191>164765: .Mar 20 09:23:14: //-1/C58B2C38B3F2/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:23:15 2013: <191>164766:
Wed Mar 20 09:23:15 2013: <191>164767: Interface=0x4987FF98, Call Info(
Wed Mar 20 09:23:15 2013: <191>164768: Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:23:15 2013: <191>164769: Called Number=1811032099(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:23:15 2013: <191>164770: Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
Wed Mar 20 09:23:15 2013: <191>164771: Incoming Dial-peer=18, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
Wed Mar 20 09:23:15 2013: <191>164772: Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:23:15 2013: <191>164773: .Mar 20 09:23:14: //-1/C58B2C38B3F2/CCAPI/ccCheckClipClir:
Wed Mar 20 09:23:15 2013: <191>164774: In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:23:15 2013: <191>164775: .Mar 20 09:23:14: //-1/C58B2C38B3F2/CCAPI/ccCheckClipClir:
Wed Mar 20 09:23:15 2013: <191>164776: Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:23:15 2013: <191>164777: .Mar 20 09:23:14: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:23:15 2013: <191>164778:
Wed Mar 20 09:23:15 2013: <191>164779: .Mar 20 09:23:14: :cc_get_feature_vsa malloc success
Wed Mar 20 09:23:15 2013: <191>164780: .Mar 20 09:23:14: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:23:15 2013: <191>164781:
Wed Mar 20 09:23:15 2013: <191>164782: .Mar 20 09:23:14: cc_get_feature_vsa count is 1
Wed Mar 20 09:23:15 2013: <191>164783: .Mar 20 09:23:14: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:23:15 2013: <191>164784:
Wed Mar 20 09:23:15 2013: <191>164785: .Mar 20 09:23:14: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203322344,feature_id:8156
Wed Mar 20 09:23:15 2013: <191>164786: .Mar 20 09:23:14: //8156/C58B2C38B3F2/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:23:15 2013: <191>164787:
Wed Mar 20 09:23:15 2013: <191>164788: Set Up Event Sent;
Wed Mar 20 09:23:15 2013: <191>164789: Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:23:15 2013: <191>164792: Event=0x4982D230
Wed Mar 20 09:23:15 2013: <191>164796: Context=0x4BA6FA60
Wed Mar 20 09:23:15 2013: <191>164797: .Mar 20 09:23:14: //8156/C58B2C38B3F2/CCAPI/cc_process_call_setup_ind:
Wed Mar 20 09:23:15 2013: <191>164798: >>>>CCAPI handed cid 8156 with tag 18 to app "_ManagedAppProcess_Default"
Wed Mar 20 09:23:15 2013: <191>164799: .Mar 20 09:23:14: //8156/C58B2C38B3F2/CCAPI/ccCallProceeding:
Wed Mar 20 09:23:15 2013: <191>164800:
Wed Mar 20 09:23:15 2013: <191>164808: Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:23:15 2013: <191>164809: .Mar 20 09:23:14: //8156/C58B2C38B3F2/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:23:15 2013: <191>164810:
Wed Mar 20 09:23:15 2013: <191>164821: ----- ccCallInfo IE subfields -----
Wed Mar 20 09:23:15 2013: <191>164824: cisco-aniplan=0
Wed Mar 20 09:23:15 2013: <191>164827: cisco-anisi=0
Wed Mar 20 09:23:15 2013: <191>164831: cisco-rdie=FFFFFFFF
Wed Mar 20 09:23:15 2013: <191>164836: cisco-rdnpi=0
Wed Mar 20 09:23:15 2013: <191>164838: cisco-redirectreason=0 fwd_final_type =0
Wed Mar 20 09:23:15 2013: <191>164854: .Mar 20 09:23:14: cc_get_feature_vsa count is 2
Wed Mar 20 09:23:15 2013: <191>164855: .Mar 20 09:23:14: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:23:15 2013: <191>164856:
Wed Mar 20 09:23:15 2013: <191>164857: .Mar 20 09:23:14: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203322120,feature_id:8157
Wed Mar 20 09:23:15 2013: <191>164858: .Mar 20 09:23:14: //8157/C58B2C38B3F2/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:23:15 2013: <191>164859: SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Wed Mar 20 09:23:15 2013: <191>164860: .Mar 20 09:23:14: //8157/C58B2C38B3F2/CCAPI/ccCallSetContext:
Wed Mar 20 09:23:15 2013: <191>164861: Context=0x4BA69B38
Wed Mar 20 09:23:15 2013: <191>164862: .Mar 20 09:23:14: //8156/C58B2C38B3F2/CCAPI/ccSaveDialpeerTag:
Wed Mar 20 09:23:15 2013: <191>164863: Outgoing Dial-peer=3000
Wed Mar 20 09:23:15 2013: <191>164864: .Mar 20 09:23:14: //8157/C58B2C38B3F2/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:23:15 2013: <191>164865: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:23:15 2013: <191>164866: .Mar 20 09:23:14: //8157/C58B2C38B3F2/CCAPI/cc_api_call_proceeding:
Wed Mar 20 09:23:15 2013: <191>164867: Interface=0x48A4F728, Progress Indication=NULL(0)
Wed Mar 20 09:23:15 2013: <191>164868: .Mar 20 09:23:14: //8157/C58B2C38B3F2/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:23:15 2013: <191>164869: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:23:15 2013: <191>164870: .Mar 20 09:23:14: //8157/C58B2C38B3F2/CCAPI/cc_api_set_delay_xport:
Wed Mar 20 09:23:15 2013: <191>164871: CallInfo(delay xport=TRUE)
Wed Mar 20 09:23:15 2013: <191>164872: .Mar 20 09:23:14: //8157/C58B2C38B3F2/CCAPI/cc_api_call_alert:
Wed Mar 20 09:23:15 2013: <191>164873: Interface=0x48A4F728, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:23:15 2013: <191>164874: .Mar 20 09:23:14: //8157/C58B2C38B3F2/CCAPI/cc_api_call_alert:
Wed Mar 20 09:23:15 2013: <191>164875: Call Entry(Retry Count=0, Responsed=TRUE)
Wed Mar 20 09:23:15 2013: <191>164876: .Mar 20 09:23:14: //8156/C58B2C38B3F2/CCAPI/ccCallAlert:
Wed Mar 20 09:23:15 2013: <191>164877:
Wed Mar 20 09:23:15 2013: <191>164878: Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:23:15 2013: <191>164879: .Mar 20 09:23:14: //8156/C58B2C38B3F2/CCAPI/ccCallAlert:
Wed Mar 20 09:23:15 2013: <191>164880: Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Wed Mar 20 09:23:15 2013: <191>164881: .Mar 20 09:23:14: //8157/C58B2C38B3F2/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:23:15 2013: <191>164882: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:23:15 2013: <191>164883: .Mar 20 09:23:14: //8157/C58B2C38B3F2/CCAPI/cc_api_call_notify:
Wed Mar 20 09:23:15 2013: <191>164884: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8157
Wed Mar 20 09:23:15 2013: <191>164885: .Mar 20 09:23:14: //8157/C58B2C38B3F2/CCAPI/ccIsInfoRingback:
Wed Mar 20 09:23:15 2013: <191>164886: Returning dpRingBack=0
Wed Mar 20 09:23:15 2013: <191>164887: .Mar 20 09:23:14: //8157/C58B2C38B3F2/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:23:15 2013: <191>164888: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:23:15 2013: <191>164889: .Mar 20 09:23:14: //8157/C58B2C38B3F2/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:23:15 2013: <191>164890: CallInfo(ccm detected=TRUE)
Wed Mar 20 09:23:15 2013: <191>164891: .Mar 20 09:23:14: //8156/C58B2C38B3F2/CCAPI/ccCallNotify:
Wed Mar 20 09:23:15 2013: <191>164892: Data Bitmask=0x5, Call Id=8156
Wed Mar 20 09:23:15 2013: <191>164893: .Mar 20 09:23:14: //8157/C58B2C38B3F2/CCAPI/cc_api_call_connected:
Wed Mar 20 09:23:15 2013: <191>164894: Interface=0x48A4F728, Data Bitmask=0x0, Progress Indication=NULL(0),
Wed Mar 20 09:23:15 2013: <191>164895: Connection Handle=0
Wed Mar 20 09:23:15 2013: <191>164896: .Mar 20 09:23:14: //8157/C58B2C38B3F2/CCAPI/cc_api_call_connected:
Wed Mar 20 09:23:15 2013: <191>164897: Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Wed Mar 20 09:23:15 2013: <191>164898: .Mar 20 09:23:14: //8157/C58B2C38B3F2/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:23:15 2013: <191>164899: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:23:15 2013: <191>164900: .Mar 20 09:23:14: //8157/C58B2C38B3F2/CCAPI/cc_api_call_notify:
Wed Mar 20 09:23:15 2013: <191>164901:
Wed Mar 20 09:23:15 2013: <191>164902: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8157
Wed Mar 20 09:23:15 2013: <191>164903: .Mar 20 09:23:14: //8156/C58B2C38B3F2/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:23:15 2013: <191>164904: Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:23:15 2013: <191>164905: Tone Direction=Network, Params=0x0, Call Id=8156
Wed Mar 20 09:23:15 2013: <191>164906: .Mar 20 09:23:14: //8156/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:23:15 2013: <191>164907: (confID=0x4BB01D68, callID1=0x1FDC, callID2=0x1FDD, tag=0x0)
Wed Mar 20 09:23:15 2013: <191>164908: .Mar 20 09:23:14: //8156/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:23:15 2013: <191>164909: (confID=0x4BB01D68, callID1=0x1FDC, gcid=C58B2C38-908F11E2-B3F2DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:23:15 2013: <191>164910: .Mar 20 09:23:14: //8157/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:23:15 2013: <191>164911: (confID=0x4BB01D68, callID2=0x1FDD, gcid=C58B2C38-908F11E2-B3F2DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:23:16 2013: <191>164912: .Mar 20 09:23:14: //8156/C58B2C38B3F2/CCAPI/ccConferenceCreate:
Wed Mar 20 09:23:16 2013: <191>164913: Conference Id=0x4BB01D68, Call Id1=8156, Call Id2=8157, Tag=0x0
Wed Mar 20 09:23:16 2013: <191>164914: .Mar 20 09:23:14: //8156/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:23:16 2013: <191>164915: Conference Id=0xE5B, Source Interface=0x4987FF98, Source Call Id=8156,
Wed Mar 20 09:23:16 2013: <191>164916: Destination Call Id=8157, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:23:16 2013: <191>164917: .Mar 20 09:23:14: //8157/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Wed Mar 20 09:23:16 2013: <191>164918:
Wed Mar 20 09:23:16 2013: <191>164919: .Mar 20 09:23:14: cc_api_get_xcode_stream : 4534
Wed Mar 20 09:23:16 2013: <191>164920: .Mar 20 09:23:14: //8157/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:23:16 2013: <191>164921: Conference Id=0xE5B, Source Interface=0x48A4F728, Source Call Id=8157,
Wed Mar 20 09:23:16 2013: <191>164922: Destination Call Id=8156, Disposition=0x0, Tag=0x0
Wed Mar 20 09:23:16 2013: <191>164923: .Mar 20 09:23:14: //8156/C58B2C38B3F2/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:23:16 2013: <191>164924: Conference Id=0xE5B, Source Interface=0x48A4F728, Source Call Id=8157,
Wed Mar 20 09:23:16 2013: <191>164926: .Mar 20 09:23:14: //8156/C58B2C38B3F2/CCAPI/ccConferenceCreate:
Wed Mar 20 09:23:16 2013: <191>164928: .Mar 20 09:23:14: //8157/C58B2C38B3F2/CCAPI/ccConferenceCreate:
Wed Mar 20 09:23:16 2013: <191>164929: Call Entry(Conference Id=0xE5B, Destination Call Id=8156)
Wed Mar 20 09:23:16 2013: <191>164931: Destination Interface=0x48A4F728, Destination Call Id=8157, Source Call Id=8156,
Wed Mar 20 09:23:16 2013: <191>164932: Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
Wed Mar 20 09:23:16 2013: <191>164940: Destination Interface=0x4987FF98, Destination Call Id=8156, Source Call Id=8157,
Wed Mar 20 09:23:16 2013: <191>164950: Modem=ON(0x2), Codec Bytes=20, Signal Type=2, Seq Num Start=5687)
Wed Mar 20 09:23:16 2013: <191>164951: .Mar 20 09:23:14: //8156/C58B2C38B3F2/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:23:16 2013: <191>164952: Destination Interface=0x48A4F728, Destination Call Id=8157, Source Call Id=8156,
Wed Mar 20 09:23:16 2013: <191>164953: Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:23:16 2013: <191>164966: Progress Indication=NULL(0), Data Bitmask=0x0
Wed Mar 20 09:23:16 2013: <191>164967: .Mar 20 09:23:14: //8156/C58B2C38B3F2/CCAPI/ccCallConnect:
Wed Mar 20 09:23:16 2013: <191>164968:
Wed Mar 20 09:23:16 2013: <191>164969: Call Entry(Connected=TRUE, Responsed=TRUE)
Wed Mar 20 09:23:27 2013: <191>164970: .Mar 20 09:23:25: //8157/C58B2C38B3F2/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:23:27 2013: <191>164971: Interface=0x0, Call Id=8157
Wed Mar 20 09:23:27 2013: <191>164972: .Mar 20 09:23:25: //8157/C58B2C38B3F2/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:23:27 2013: <191>164973: Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:23:27 2013: <191>164974: .Mar 20 09:23:25: //8157/C58B2C38B3F2/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:23:27 2013: <191>164975: Interface=0x48A4F728, Signal Indication=NOT PRESENT(255)
Wed Mar 20 09:23:27 2013: <191>164976: .Mar 20 09:23:25: //8156/C58B2C38B3F2/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:23:27 2013: <191>164977: Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:23:27 2013: <191>164978: Tone Direction=Network, Params=0x0, Call Id=8156
Wed Mar 20 09:23:27 2013: <191>164979: .Mar 20 09:23:25: //8157/C58B2C38B3F2/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:23:27 2013: <191>164980: Interface=0x48A4F728, Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:23:27 2013: <191>164981: .Mar 20 09:23:25: //8156/C58B2C38B3F2/CCAPI/ccCallUserInfo:
Wed Mar 20 09:23:27 2013: <191>164982: Call Id=8156
Wed Mar 20 09:23:27 2013: <191>164983: .Mar 20 09:23:25: //8156/C58B2C38B3F2/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:23:27 2013: <191>164984: Stop Tone On Digit=FALSE, Tone=Ring Back,
Wed Mar 20 09:23:27 2013: <191>164985: Tone Direction=Network, Params=0x0, Call Id=8156
Wed Mar 20 09:23:27 2013: <191>164986: .Mar 20 09:23:25: //8157/C58B2C38B3F2/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:23:27 2013: <191>164987: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:23:27 2013: <191>164988: .Mar 20 09:23:25: //8157/C58B2C38B3F2/CCAPI/cc_api_call_notify:
Wed Mar 20 09:23:27 2013: <191>164989: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8157
Wed Mar 20 09:23:27 2013: <191>164990: .Mar 20 09:23:25: //8157/C58B2C38B3F2/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:23:27 2013: <191>164991: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:23:28 2013: <191>164992: .Mar 20 09:23:25: //8157/C58B2C38B3F2/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:23:28 2013: <191>164993: CallInfo(ccm detected=TRUE)
Wed Mar 20 09:23:28 2013: <191>164994: .Mar 20 09:23:25: //8156/C58B2C38B3F2/CCAPI/ccCallNotify:
Wed Mar 20 09:23:28 2013: <191>164995: Data Bitmask=0x5, Call Id=8156
Wed Mar 20 09:23:33 2013: <191>164996: .Mar 20 09:23:32: //8157/C58B2C38B3F2/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:23:33 2013: <191>164997: Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:23:33 2013: <191>164998: .Mar 20 09:23:32: //8157/C58B2C38B3F2/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:23:33 2013: <191>164999: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:23:33 2013: <191>165000: .Mar 20 09:23:32: //8157/C58B2C38B3F2/CCAPI/cc_api_call_notify:
Wed Mar 20 09:23:33 2013: <191>165001: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8157
Wed Mar 20 09:23:33 2013: <191>165002: .Mar 20 09:23:32: //8156/C58B2C38B3F2/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:23:33 2013: <191>165003: Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:23:33 2013: <191>165004: Tone Direction=Network, Params=0x0, Call Id=8156
Wed Mar 20 09:23:33 2013: <191>165005: .Mar 20 09:23:32: //8157/C58B2C38B3F2/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:23:33 2013: <191>165006: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:23:33 2013: <191>165007: .Mar 20 09:23:32: //8157/C58B2C38B3F2/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:23:33 2013: <191>165008: CallInfo(ccm detected=TRUE)
Wed Mar 20 09:23:33 2013: <191>165009: .Mar 20 09:23:32: //8156/C58B2C38B3F2/CCAPI/ccCallNotify:
Wed Mar 20 09:23:33 2013: <191>165010: Data Bitmask=0x5, Call Id=8156
Wed Mar 20 09:23:33 2013: <191>165011: .Mar 20 09:23:32: //8157/C58B2C38B3F2/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:23:33 2013: <191>165012: Destination Interface=0x4987FF98, Destination Call Id=8156, Source Call Id=8157,
Wed Mar 20 09:23:33 2013: <191>165013: Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:23:33 2013: <191>165014: Modem=0x2, Codec Bytes=160, Signal Type=2)
Wed Mar 20 09:23:33 2013: <191>165015: .Mar 20 09:23:32: //8157/C58B2C38B3F2/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:23:33 2013: <191>165016: Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:23:33 2013: <191>165017: Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:23:33 2013: <191>165018: .Mar 20 09:23:32: //8157/C58B2C38B3F2/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:23:33 2013: <191>165019:
Wed Mar 20 09:23:33 2013: <191>165020: Destination Interface=0x4987FF98, Destination Call Id=8156, Source Call Id=8157,
Wed Mar 20 09:23:33 2013: <191>165021: Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:23:33 2013: <191>165022: Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=5785)
Wed Mar 20 09:23:33 2013: <191>165023: .Mar 20 09:23:32: //8156/C58B2C38B3F2/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:23:33 2013: <191>165024: Destination Interface=0x48A4F728, Destination Call Id=8157, Source Call Id=8156,
Wed Mar 20 09:23:33 2013: <191>165025: Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:23:33 2013: <191>165026: Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=5785)
Wed Mar 20 09:23:33 2013: <191>165027: .Mar 20 09:23:32: //8156/C58B2C38B3F2/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:23:33 2013: <191>165028: Call Id=8156
Wed Mar 20 09:23:33 2013: <191>165029: .Mar 20 09:23:32: //8156/C58B2C38B3F2/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:23:33 2013: <191>165030:
Wed Mar 20 09:23:34 2013: <191>165031: Call Entry(Context=0x4BA6FA60)
Wed Mar 20 09:24:02 2013: <191>165032: .Mar 20 09:24:00: //8157/C58B2C38B3F2/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:24:02 2013: <191>165033: Interface=0x0, Call Id=8157
Wed Mar 20 09:24:02 2013: <191>165034: .Mar 20 09:24:01: //8157/C58B2C38B3F2/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:24:02 2013: <191>165035: Destination Interface=0x4987FF98, Destination Call Id=8156, Source Call Id=8157,
Wed Mar 20 09:24:02 2013: <191>165036: Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:24:02 2013: <191>165037: Modem=0x2, Codec Bytes=160, Signal Type=2)
Wed Mar 20 09:24:02 2013: <191>165038: .Mar 20 09:24:01: //8157/C58B2C38B3F2/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:24:02 2013: <191>165039: Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:24:02 2013: <191>165040: Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:24:02 2013: <191>165041: .Mar 20 09:24:01: //8157/C58B2C38B3F2/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:24:02 2013: <191>165042:
Wed Mar 20 09:24:02 2013: <191>165043: Destination Interface=0x4987FF98, Destination Call Id=8156, Source Call Id=8157,
Wed Mar 20 09:24:02 2013: <191>165044: Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:24:02 2013: <191>165045: Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=6388)
Wed Mar 20 09:24:02 2013: <191>165046: .Mar 20 09:24:01: //8156/C58B2C38B3F2/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:24:02 2013: <191>165047: Destination Interface=0x48A4F728, Destination Call Id=8157, Source Call Id=8156,
Wed Mar 20 09:24:02 2013: <191>165048: Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:24:02 2013: <191>165049: Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=6388)
Wed Mar 20 09:24:02 2013: <191>165050: .Mar 20 09:24:01: //8156/C58B2C38B3F2/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:24:02 2013: <191>165051: Call Id=8156
Wed Mar 20 09:24:02 2013: <191>165052: .Mar 20 09:24:01: //8156/C58B2C38B3F2/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:24:02 2013: <191>165053:
Wed Mar 20 09:24:03 2013: <191>165054: Call Entry(Context=0x4BA6FA60)
Wed Mar 20 09:24:05 2013: <191>165055: .Mar 20 09:24:04: //8157/C58B2C38B3F2/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:24:05 2013: <191>165056: Interface=0x0, Call Id=8157
Wed Mar 20 09:24:05 2013: <191>165057: .Mar 20 09:24:04: //8157/C58B2C38B3F2/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:24:05 2013: <191>165058: Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:24:05 2013: <191>165059: .Mar 20 09:24:04: //8156/C58B2C38B3F2/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:24:05 2013: <191>165060: Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:24:05 2013: <191>165061: Tone Direction=Network, Params=0x0, Call Id=8156
Wed Mar 20 09:24:05 2013: <191>165062: .Mar 20 09:24:04: //8157/C58B2C38B3F2/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:24:05 2013: <191>165063: Interface=0x48A4F728, Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:24:05 2013: <191>165064: .Mar 20 09:24:04: //8157/C58B2C38B3F2/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:24:05 2013: <191>165065: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:24:06 2013: <191>165066: .Mar 20 09:24:04: //8157/C58B2C38B3F2/CCAPI/cc_api_call_notify:
Wed Mar 20 09:24:06 2013: <191>165067: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8157
Wed Mar 20 09:24:06 2013: <191>165068: .Mar 20 09:24:04: //8156/C58B2C38B3F2/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:24:06 2013: <191>165069: Stop Tone On Digit=FALSE, Tone=Ring Back,
Wed Mar 20 09:24:06 2013: <191>165070: Tone Direction=Network, Params=0x0, Call Id=8156
Wed Mar 20 09:24:06 2013: <191>165071: .Mar 20 09:24:04: //8157/C58B2C38B3F2/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:24:06 2013: <191>165072: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:24:06 2013: <191>165073: .Mar 20 09:24:04: //8157/C58B2C38B3F2/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:24:06 2013: <191>165074: CallInfo(ccm detected=TRUE)
Wed Mar 20 09:24:06 2013: <191>165075: .Mar 20 09:24:04: //8156/C58B2C38B3F2/CCAPI/ccCallNotify:
Wed Mar 20 09:24:06 2013: <191>165076: Data Bitmask=0x5, Call Id=8156
Wed Mar 20 09:24:17 2013: <191>165077: .Mar 20 09:24:16: //8157/C58B2C38B3F2/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:24:17 2013: <191>165078: Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:24:17 2013: <191>165079: .Mar 20 09:24:16: //8157/C58B2C38B3F2/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:24:17 2013: <191>165080: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:24:17 2013: <191>165081: .Mar 20 09:24:16: //8157/C58B2C38B3F2/CCAPI/cc_api_call_notify:
Wed Mar 20 09:24:17 2013: <191>165082: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8157
Wed Mar 20 09:24:17 2013: <191>165083: .Mar 20 09:24:16: //8156/C58B2C38B3F2/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:24:17 2013: <191>165084: Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:24:17 2013: <191>165085: Tone Direction=Network, Params=0x0, Call Id=8156
Wed Mar 20 09:24:17 2013: <191>165086: .Mar 20 09:24:16: //8157/C58B2C38B3F2/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:24:17 2013: <191>165087: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:24:17 2013: <191>165088: .Mar 20 09:24:16: //8157/C58B2C38B3F2/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:24:17 2013: <191>165089: CallInfo(ccm detected=TRUE)
Wed Mar 20 09:24:17 2013: <191>165090: .Mar 20 09:24:16: //8156/C58B2C38B3F2/CCAPI/ccCallNotify:
Wed Mar 20 09:24:17 2013: <191>165091: Data Bitmask=0x5, Call Id=8156
Wed Mar 20 09:24:17 2013: <191>165092: .Mar 20 09:24:16: //8157/C58B2C38B3F2/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:24:17 2013: <191>165093: Destination Interface=0x4987FF98, Destination Call Id=8156, Source Call Id=8157,
Wed Mar 20 09:24:17 2013: <191>165094: Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:24:17 2013: <191>165095: Modem=0x2, Codec Bytes=160, Signal Type=2)
Wed Mar 20 09:24:17 2013: <191>165096: .Mar 20 09:24:16: //8157/C58B2C38B3F2/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:24:17 2013: <191>165097: Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:24:17 2013: <191>165098: Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:24:17 2013: <191>165099: .Mar 20 09:24:16: //8157/C58B2C38B3F2/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:24:17 2013: <191>165100:
Wed Mar 20 09:24:17 2013: <191>165101: Destination Interface=0x4987FF98, Destination Call Id=8156, Source Call Id=8157,
Wed Mar 20 09:24:17 2013: <191>165102: Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:24:17 2013: <191>165103: Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=6501)
Wed Mar 20 09:24:17 2013: <191>165104: .Mar 20 09:24:16: //8156/C58B2C38B3F2/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:24:17 2013: <191>165105: Destination Interface=0x48A4F728, Destination Call Id=8157, Source Call Id=8156,
Wed Mar 20 09:24:17 2013: <191>165106: Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:24:17 2013: <191>165107: Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=6501)
Wed Mar 20 09:24:17 2013: <191>165108: .Mar 20 09:24:16: //8156/C58B2C38B3F2/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:24:17 2013: <191>165109: Call Id=8156
Wed Mar 20 09:24:17 2013: <191>165110: .Mar 20 09:24:16: //8156/C58B2C38B3F2/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:24:17 2013: <191>165111:
Wed Mar 20 09:24:18 2013: <191>165112: Call Entry(Context=0x4BA6FA60)
Wed Mar 20 09:24:45 2013: <191>165113: .Mar 20 09:24:44: //8157/C58B2C38B3F2/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:24:45 2013: <191>165114: Interface=0x0, Call Id=8157
Wed Mar 20 09:24:45 2013: <191>165115: .Mar 20 09:24:44: //8157/C58B2C38B3F2/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:24:45 2013: <191>165116: Cause Value=16, Interface=0x48A4F728, Call Id=8157
Wed Mar 20 09:24:45 2013: <191>165117: .Mar 20 09:24:44: //8157/C58B2C38B3F2/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:24:45 2013: <191>165118: Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:24:45 2013: <191>165119: .Mar 20 09:24:44: //8156/C58B2C38B3F2/CCAPI/ccConferenceDestroy:
Wed Mar 20 09:24:45 2013: <191>165120: Conference Id=0xE5B, Tag=0x0
Wed Mar 20 09:24:45 2013: <191>165121: .Mar 20 09:24:44: //8156/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:24:45 2013: <191>165122: Conference Id=0xE5B, Source Interface=0x4987FF98, Source Call Id=8156,
Wed Mar 20 09:24:45 2013: <191>165123: Destination Call Id=8157, Disposition=0x0, Tag=0x0
Wed Mar 20 09:24:45 2013: <191>165124: .Mar 20 09:24:44: //8157/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:24:45 2013: <191>165125: Conference Id=0xE5B, Source Interface=0x48A4F728, Source Call Id=8157,
Wed Mar 20 09:24:45 2013: <191>165126: Destination Call Id=8156, Disposition=0x0, Tag=0x0
Wed Mar 20 09:24:45 2013: <191>165127: .Mar 20 09:24:44: //8156/C58B2C38B3F2/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:24:45 2013: <191>165128: Conference Id=0xE5B, Source Interface=0x48A4F728, Source Call Id=8157,
Wed Mar 20 09:24:45 2013: <191>165129: Destination Call Id=8156, Disposition=0x0, Tag=0x0
Wed Mar 20 09:24:45 2013: <191>165130: .Mar 20 09:24:44: //8156/C58B2C38B3F2/CCAPI/ccCallDisconnect:
Wed Mar 20 09:24:45 2013: <191>165131: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Wed Mar 20 09:24:45 2013: <191>165132: .Mar 20 09:24:44: //8156/C58B2C38B3F2/CCAPI/ccCallDisconnect:
Wed Mar 20 09:24:45 2013: <191>165133: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:24:45 2013: <191>165134: .Mar 20 09:24:44: //8156/C58B2C38B3F2/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:24:45 2013: <191>165135: Transfer Number Is Null
Wed Mar 20 09:24:45 2013: <191>165136: .Mar 20 09:24:44: //8157/C58B2C38B3F2/CCAPI/ccCallDisconnect:
Wed Mar 20 09:24:45 2013: <191>165137: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:24:45 2013: <191>165138: .Mar 20 09:24:44: //8157/C58B2C38B3F2/CCAPI/ccCallDisconnect:
Wed Mar 20 09:24:45 2013: <191>165139: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:24:45 2013: <191>165140: .Mar 20 09:24:44: //8157/C58B2C38B3F2/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:24:45 2013: <191>165141: Transfer Number Is Null
Wed Mar 20 09:24:45 2013: <191>165142: .Mar 20 09:24:44: //8157/C58B2C38B3F2/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:24:45 2013: <191>165143: Transfer Number Is Null
Wed Mar 20 09:24:45 2013: <191>165144: .Mar 20 09:24:44: //8157/C58B2C38B3F2/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:24:45 2013: <191>165145:
Wed Mar 20 09:24:45 2013: <191>165146: Disposition=0, Interface=0x48A4F728, Tag=0x0, Call Id=8157,
Wed Mar 20 09:24:45 2013: <191>165147: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:24:45 2013: <191>165148: .Mar 20 09:24:44: //8157/C58B2C38B3F2/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:24:45 2013: <191>165149: Call Disconnect Event Sent
Wed Mar 20 09:24:45 2013: <191>165150: .Mar 20 09:24:44: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:24:45 2013: <191>165151:
Wed Mar 20 09:24:45 2013: <191>165152: .Mar 20 09:24:44: :cc_free_feature_vsa freeing 47B93D00
Wed Mar 20 09:24:45 2013: <191>165153: .Mar 20 09:24:44: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:24:45 2013: <191>165154:
Wed Mar 20 09:24:45 2013: <191>165155: .Mar 20 09:24:44: vsacount in free is 1
Wed Mar 20 09:24:45 2013: <191>165156: .Mar 20 09:24:44: //8156/C58B2C38B3F2/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:24:45 2013: <191>165157: Disposition=0, Interface=0x4987FF98, Tag=0x0, Call Id=8156,
Wed Mar 20 09:24:45 2013: <191>165158: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:24:46 2013: <191>165159: .Mar 20 09:24:44: //8156/C58B2C38B3F2/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:24:46 2013: <191>165160: Call Disconnect Event Sent
Wed Mar 20 09:24:46 2013: <191>165161: .Mar 20 09:24:44: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:24:46 2013: <191>165162:
Wed Mar 20 09:24:46 2013: <191>165163: .Mar 20 09:24:44: :cc_free_feature_vsa freeing 47B93DE0
Wed Mar 20 09:24:46 2013: <191>165164: .Mar 20 09:24:44: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:24:46 2013: <191>165165:
Wed Mar 20 09:24:46 2013: <191>165166: .Mar 20 09:24:44: vsacount in free is 0
Wed Mar 20 09:25:02 2013: <190>165167: .Mar 20 09:25:00: %IPPHONE-6-REGISTER_NEW: ephone-7:SEP002699442108 IP:10.229.64.50 Socket:5 DeviceType:Phone has registered.
Wed Mar 20 09:25:35 2013: <191>165168: .Mar 20 09:25:34: //-1/008F92424106/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:25:35 2013: <191>165169: cc_api_call_setup_ind_common:
Wed Mar 20 09:25:35 2013: <191>165170: cisco-username=PF-Assis-Margarida
Wed Mar 20 09:25:35 2013: <191>165171: ----- ccCallInfo IE subfields -----
Wed Mar 20 09:25:35 2013: <191>165172: cisco-ani=1811032010
Wed Mar 20 09:25:35 2013: <191>165173: cisco-anitype=0
Wed Mar 20 09:25:35 2013: <191>165174: cisco-aniplan=0
Wed Mar 20 09:25:35 2013: <191>165175: cisco-anipi=0
Wed Mar 20 09:25:35 2013: <191>165176: cisco-anisi=1
Wed Mar 20 09:25:35 2013: <191>165177: dest=033222776
Wed Mar 20 09:25:35 2013: <191>165178: cisco-desttype=0
Wed Mar 20 09:25:35 2013: <191>165179: cisco-destplan=0
Wed Mar 20 09:25:35 2013: <191>165180: cisco-rdie=FFFFFFFF
Wed Mar 20 09:25:35 2013: <191>165181: cisco-rdn=
Wed Mar 20 09:25:35 2013: <191>165182: cisco-lastrdn=
Wed Mar 20 09:25:35 2013: <191>165183: cisco-rdntype=-1
Wed Mar 20 09:25:35 2013: <191>165184: cisco-rdnplan=-1
Wed Mar 20 09:25:35 2013: <191>165185: cisco-rdnpi=-1
Wed Mar 20 09:25:35 2013: <191>165186: cisco-rdnsi=-1
Wed Mar 20 09:25:35 2013: <191>165187: cisco-redirectreason=-1 fwd_final_type =0
Wed Mar 20 09:25:35 2013: <191>165188: final_redirectNumber =
Wed Mar 20 09:25:35 2013: <191>165189: hunt_group_timeout =0
Wed Mar 20 09:25:35 2013: <191>165190:
Wed Mar 20 09:25:35 2013: <191>165191: .Mar 20 09:25:34: //-1/008F92424106/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:25:35 2013: <191>165192:
Wed Mar 20 09:25:35 2013: <191>165193: Interface=0x48A4F728, Call Info(
Wed Mar 20 09:25:35 2013: <191>165194: Calling Number=1811032010,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Wed Mar 20 09:25:35 2013: <191>165195: Called Number=033222776(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:25:35 2013: <191>165196: Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Wed Mar 20 09:25:35 2013: <191>165197: Incoming Dial-peer=200, Progress Indication=NULL(0), Calling IE Present=TRUE,
Wed Mar 20 09:25:35 2013: <191>165198: Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=8158
Wed Mar 20 09:25:35 2013: <191>165199: .Mar 20 09:25:34: //-1/008F92424106/CCAPI/ccCheckClipClir:
Wed Mar 20 09:25:35 2013: <191>165200: In: Calling Number=1811032010(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Wed Mar 20 09:25:35 2013: <191>165201: .Mar 20 09:25:34: //-1/008F92424106/CCAPI/ccCheckClipClir:
Wed Mar 20 09:25:35 2013: <191>165202: Out: Calling Number=1811032010(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Wed Mar 20 09:25:35 2013: <191>165203: .Mar 20 09:25:34: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:25:35 2013: <191>165204:
Wed Mar 20 09:25:35 2013: <191>165205: .Mar 20 09:25:34: :cc_get_feature_vsa malloc success
Wed Mar 20 09:25:35 2013: <191>165206: .Mar 20 09:25:34: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:25:35 2013: <191>165207:
Wed Mar 20 09:25:35 2013: <191>165208: .Mar 20 09:25:34: cc_get_feature_vsa count is 1
Wed Mar 20 09:25:35 2013: <191>165209: .Mar 20 09:25:34: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:25:35 2013: <191>165210:
Wed Mar 20 09:25:35 2013: <191>165211: .Mar 20 09:25:34: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203248360,feature_id:8158
Wed Mar 20 09:25:35 2013: <191>165212: .Mar 20 09:25:34: //8158/008F92424106/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:25:35 2013: <191>165213:
Wed Mar 20 09:25:35 2013: <191>165215: Call Info(Calling Number=1811032010(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Wed Mar 20 09:25:35 2013: <191>165217: .Mar 20 09:25:34: //8158/008F92424106/CCAPI/cc_process_call_setup_ind:
Wed Mar 20 09:25:35 2013: <191>165221: .Mar 20 09:25:34: //8158/008F92424106/CCAPI/ccCallSetContext:
Wed Mar 20 09:25:35 2013: <191>165226: Progress Indication=NULL(0)
Wed Mar 20 09:25:35 2013: <191>165227: .Mar 20 09:25:34: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Wed Mar 20 09:25:35 2013: <191>165235:
Wed Mar 20 09:25:35 2013: <191>165236: Out: Calling Number=1811032010(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Wed Mar 20 09:25:35 2013: <191>165237: .Mar 20 09:25:34: //8158/008F92424106/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:25:35 2013: <191>165238: Destination Pattern=0[2-5]......., Called Number=033222776, Digit Strip=TRUE
Wed Mar 20 09:25:35 2013: <191>165239: .Mar 20 09:25:34: //8158/008F92424106/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:25:35 2013: <191>165250: cisco-anitype=0
Wed Mar 20 09:25:35 2013: <191>165251: cisco-aniplan=0
Wed Mar 20 09:25:35 2013: <191>165254: dest=033222776
Wed Mar 20 09:25:35 2013: <191>165257: cisco-rdie=FFFFFFFF
Wed Mar 20 09:25:35 2013: <191>165258: cisco-rdn=
Wed Mar 20 09:25:35 2013: <191>165264: cisco-redirectreason=-1 fwd_final_type =0
Wed Mar 20 09:25:35 2013: <191>165266: hunt_group_timeout =0
Wed Mar 20 09:25:35 2013: <191>165267:
Wed Mar 20 09:25:36 2013: <191>165280: .Mar 20 09:25:34: cc_get_feature_vsa count is 2
Wed Mar 20 09:25:36 2013: <191>165281: .Mar 20 09:25:34: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:25:36 2013: <191>165282:
Wed Mar 20 09:25:36 2013: <191>165283: .Mar 20 09:25:34: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203248136,feature_id:8159
Wed Mar 20 09:25:36 2013: <191>165284: .Mar 20 09:25:34: //8159/008F92424106/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:25:36 2013: <191>165285: SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Wed Mar 20 09:25:36 2013: <191>165286: .Mar 20 09:25:34: //8159/008F92424106/CCAPI/ccCallSetContext:
Wed Mar 20 09:25:36 2013: <191>165287: Context=0x4BA6E758
Wed Mar 20 09:25:36 2013: <191>165288: .Mar 20 09:25:34: //8158/008F92424106/CCAPI/ccSaveDialpeerTag:
Wed Mar 20 09:25:36 2013: <191>165289: Outgoing Dial-peer=18
Wed Mar 20 09:25:36 2013: <191>165290: .Mar 20 09:25:34: //8159/008F92424106/CCAPI/cc_api_call_proceeding:
Wed Mar 20 09:25:36 2013: <191>165291: Interface=0x4987FF98, Progress Indication=NULL(0)
Wed Mar 20 09:25:38 2013: <191>165292: .Mar 20 09:25:37: //8159/008F92424106/CCAPI/cc_api_call_cut_progress:
Wed Mar 20 09:25:38 2013: <191>165293: Interface=0x4987FF98, Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2),
Wed Mar 20 09:25:38 2013: <191>165294: Cause Value=0
Wed Mar 20 09:25:38 2013: <191>165295: .Mar 20 09:25:37: //8159/008F92424106/CCAPI/cc_api_call_cut_progress:
Wed Mar 20 09:25:38 2013: <191>165296: Call Entry(Responsed=TRUE)
Wed Mar 20 09:25:38 2013: <191>165297: .Mar 20 09:25:37: //8158/008F92424106/CCAPI/ccCallCutProgress:
Wed Mar 20 09:25:38 2013: <191>165298: Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=0
Wed Mar 20 09:25:38 2013: <191>165299: Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
Wed Mar 20 09:25:38 2013: <191>165300: .Mar 20 09:25:37: //8158/008F92424106/CCAPI/ccCallCutProgress:
Wed Mar 20 09:25:38 2013: <191>165301: Call Entry(Responsed=TRUE)
Wed Mar 20 09:25:38 2013: <191>165302: .Mar 20 09:25:37: //8159/008F92424106/CCAPI/cc_api_get_called_ccm_detected:
Wed Mar 20 09:25:38 2013: <191>165303: CallInfo(ccm detected=0)
Wed Mar 20 09:25:38 2013: <191>165304: .Mar 20 09:25:37: //8158/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:25:38 2013: <191>165305: (confID=0x4BB020C8, callID1=0x1FDE, callID2=0x1FDF, tag=0x0)
Wed Mar 20 09:25:38 2013: <191>165306: .Mar 20 09:25:37: //8158/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:25:38 2013: <191>165307: (confID=0x4BB020C8, callID1=0x1FDE, gcid=0-0-0-0, tag=0x0)
Wed Mar 20 09:25:38 2013: <191>165308: .Mar 20 09:25:37: //8159/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:25:38 2013: <191>165309: (confID=0x4BB020C8, callID2=0x1FDF, gcid=0-0-0-0, tag=0x0)
Wed Mar 20 09:25:38 2013: <191>165310: .Mar 20 09:25:37: //8158/008F92424106/CCAPI/ccConferenceCreate:
Wed Mar 20 09:25:38 2013: <191>165311: Conference Id=0x4BB020C8, Call Id1=8158, Call Id2=8159, Tag=0x0
Wed Mar 20 09:25:38 2013: <191>165312: .Mar 20 09:25:37: //8158/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Wed Mar 20 09:25:38 2013: <191>165313:
Wed Mar 20 09:25:38 2013: <191>165314: .Mar 20 09:25:37: cc_api_get_xcode_stream : 4534
Wed Mar 20 09:25:38 2013: <191>165315: .Mar 20 09:25:37: //8158/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:25:38 2013: <191>165316: Conference Id=0xE5C, Source Interface=0x48A4F728, Source Call Id=8158,
Wed Mar 20 09:25:38 2013: <191>165317: Destination Call Id=8159, Disposition=0x0, Tag=0x0
Wed Mar 20 09:25:38 2013: <191>165318: .Mar 20 09:25:37: //8159/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:25:38 2013: <191>165319: Conference Id=0xE5C, Source Interface=0x4987FF98, Source Call Id=8159,
Wed Mar 20 09:25:38 2013: <191>165320: Destination Call Id=8158, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:25:38 2013: <191>165321: .Mar 20 09:25:37: //8158/008F92424106/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:25:38 2013: <191>165322: Conference Id=0xE5C, Source Interface=0x4987FF98, Source Call Id=8159,
Wed Mar 20 09:25:38 2013: <191>165323: Destination Call Id=8158, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:25:38 2013: <191>165324: .Mar 20 09:25:37: //8158/008F92424106/CCAPI/ccConferenceCreate:
Wed Mar 20 09:25:38 2013: <191>165325:
Wed Mar 20 09:25:38 2013: <191>165326: Call Entry(Conference Id=0xE5C, Destination Call Id=8159)
Wed Mar 20 09:25:38 2013: <191>165327: .Mar 20 09:25:37: //8159/008F92424106/CCAPI/ccConferenceCreate:
Wed Mar 20 09:25:38 2013: <191>165328: Call Entry(Conference Id=0xE5C, Destination Call Id=8158)
Wed Mar 20 09:25:38 2013: <191>165338: Conference Id=0xE5C, Call Id1=8158, Call Id2=8159
Wed Mar 20 09:25:38 2013: <191>165339: .Mar 20 09:25:37: //8158/008F92424106/CCAPI/ccCallNotify:
Wed Mar 20 09:25:38 2013: <191>165340: Data Bitmask=0x7, Call Id=8158
Wed Mar 20 09:25:38 2013: <191>165341: .Mar 20 09:25:37: //8159/008F92424106/CCAPI/cc_api_get_called_ccm_detected:
Wed Mar 20 09:25:38 2013: <191>165342: CallInfo(ccm detected=0)
Wed Mar 20 09:25:38 2013: <191>165343: .Mar 20 09:25:37: //8158/008F92424106/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:25:38 2013: <191>165344: Destination Interface=0x4987FF98, Destination Call Id=8159, Source Call Id=8158,
Wed Mar 20 09:25:38 2013: <191>165345: Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:25:38 2013: <191>165346: Modem=0x2, Codec Bytes=160, Signal Type=2)
Wed Mar 20 09:25:38 2013: <191>165347: .Mar 20 09:25:37: //8158/008F92424106/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:25:38 2013: <191>165348: Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:25:38 2013: <191>165349: Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:25:38 2013: <191>165350: .Mar 20 09:25:37: //8158/008F92424106/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:25:38 2013: <191>165351: Destination Interface=0x4987FF98, Destination Call Id=8159, Source Call Id=8158,
Wed Mar 20 09:25:38 2013: <191>165352: Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:25:38 2013: <191>165353: Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=8026)
Wed Mar 20 09:25:38 2013: <191>165354: .Mar 20 09:25:37: //8159/008F92424106/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:25:38 2013: <191>165355: Destination Interface=0x48A4F728, Destination Call Id=8158, Source Call Id=8159,
Wed Mar 20 09:25:38 2013: <191>165356: Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:25:38 2013: <191>165357: Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=8026)
Wed Mar 20 09:25:38 2013: <191>165358: .Mar 20 09:25:37: //8159/008F92424106/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:25:38 2013: <191>165359: Call Id=8159
Wed Mar 20 09:25:38 2013: <191>165360: .Mar 20 09:25:37: //8159/008F92424106/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:25:38 2013: <191>165361: Call Entry(Context=0x4BA6E758)
Wed Mar 20 09:25:38 2013: <191>165362: .Mar 20 09:25:37: //8159/008F92424106/CCAPI/cc_api_call_connected:
Wed Mar 20 09:25:38 2013: <191>165363: Interface=0x4987FF98, Data Bitmask=0x1, Progress Indication=DESTINATION IS NON ISDN(2),
Wed Mar 20 09:25:38 2013: <191>165364: Connection Handle=0
Wed Mar 20 09:25:38 2013: <191>165365: .Mar 20 09:25:37: //8159/008F92424106/CCAPI/cc_api_call_connected:
Wed Mar 20 09:25:38 2013: <191>165366: Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Wed Mar 20 09:25:38 2013: <191>165367: .Mar 20 09:25:37: //8158/008F92424106/CCAPI/ccCallConnect:
Wed Mar 20 09:25:38 2013: <191>165368: Progress Indication=DESTINATION IS NON ISDN(2), Data Bitmask=0x1
Wed Mar 20 09:25:38 2013: <191>165369: .Mar 20 09:25:37: //8159/008F92424106/CCAPI/cc_api_get_called_ccm_detected:
Wed Mar 20 09:25:38 2013: <191>165370: CallInfo(ccm detected=0)
Wed Mar 20 09:25:39 2013: <191>165371: .Mar 20 09:25:37: //8158/008F92424106/CCAPI/ccCallConnect:
Wed Mar 20 09:25:39 2013: <191>165372: Call Entry(Connected=TRUE, Responsed=TRUE)
Wed Mar 20 09:25:39 2013: <191>165373: .Mar 20 09:25:37: //8158/008F92424106/CCAPI/ccCallNotify:
Wed Mar 20 09:25:39 2013: <191>165374: Data Bitmask=0x7, Call Id=8158
Wed Mar 20 09:25:39 2013: <191>165375: .Mar 20 09:25:37: //8159/008F92424106/CCAPI/cc_api_get_called_ccm_detected:
Wed Mar 20 09:25:39 2013: <191>165376: CallInfo(ccm detected=0)
Wed Mar 20 09:26:23 2013: <191>165378: cc_api_call_setup_ind_common:
Wed Mar 20 09:26:23 2013: <191>165377: .Mar 20 09:26:21: //-1/355ACD39B3F9/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:26:23 2013: <191>165379: cisco-username=
Wed Mar 20 09:26:23 2013: <191>165380: ----- ccCallInfo IE subfields -----
Wed Mar 20 09:26:23 2013: <191>165381: cisco-ani=
Wed Mar 20 09:26:23 2013: <191>165382: cisco-anitype=0
Wed Mar 20 09:26:23 2013: <191>165383: cisco-aniplan=0
Wed Mar 20 09:26:23 2013: <191>165384: cisco-anipi=0
Wed Mar 20 09:26:23 2013: <191>165385: cisco-anisi=0
Wed Mar 20 09:26:23 2013: <191>165386: dest=1811032099
Wed Mar 20 09:26:23 2013: <191>165387: cisco-desttype=0
Wed Mar 20 09:26:23 2013: <191>165388: cisco-destplan=0
Wed Mar 20 09:26:23 2013: <191>165389: cisco-rdie=FFFFFFFF
Wed Mar 20 09:26:23 2013: <191>165390: cisco-rdn=
Wed Mar 20 09:26:23 2013: <191>165391: cisco-lastrdn=
Wed Mar 20 09:26:23 2013: <191>165392: cisco-rdntype=0
Wed Mar 20 09:26:23 2013: <191>165393: cisco-rdnplan=0
Wed Mar 20 09:26:23 2013: <191>165394: cisco-rdnpi=0
Wed Mar 20 09:26:23 2013: <191>165395: cisco-rdnsi=0
Wed Mar 20 09:26:23 2013: <191>165396: cisco-redirectreason=0 fwd_final_type =0
Wed Mar 20 09:26:23 2013: <191>165397: final_redirectNumber =
Wed Mar 20 09:26:23 2013: <191>165398: hunt_group_timeout =0
Wed Mar 20 09:26:23 2013: <191>165399:
Wed Mar 20 09:26:23 2013: <191>165400: .Mar 20 09:26:21: //-1/355ACD39B3F9/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:26:23 2013: <191>165401:
Wed Mar 20 09:26:23 2013: <191>165402: Interface=0x498845E0, Call Info(
Wed Mar 20 09:26:23 2013: <191>165403: Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:26:23 2013: <191>165404: Called Number=1811032099(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:26:23 2013: <191>165405: Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
Wed Mar 20 09:26:23 2013: <191>165406: Incoming Dial-peer=50, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
Wed Mar 20 09:26:23 2013: <191>165407: Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:26:23 2013: <191>165408: .Mar 20 09:26:21: //-1/355ACD39B3F9/CCAPI/ccCheckClipClir:
Wed Mar 20 09:26:23 2013: <191>165409: In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:26:23 2013: <191>165410: .Mar 20 09:26:21: //-1/355ACD39B3F9/CCAPI/ccCheckClipClir:
Wed Mar 20 09:26:23 2013: <191>165411: Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:26:23 2013: <191>165412: .Mar 20 09:26:21: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:26:23 2013: <191>165413:
Wed Mar 20 09:26:23 2013: <191>165414: .Mar 20 09:26:21: :cc_get_feature_vsa malloc success
Wed Mar 20 09:26:23 2013: <191>165415: .Mar 20 09:26:21: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:26:23 2013: <191>165416:
Wed Mar 20 09:26:23 2013: <191>165417: .Mar 20 09:26:21: cc_get_feature_vsa count is 3
Wed Mar 20 09:26:23 2013: <191>165418: .Mar 20 09:26:21: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:26:23 2013: <191>165419:
Wed Mar 20 09:26:23 2013: <191>165420: .Mar 20 09:26:21: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203247912,feature_id:8160
Wed Mar 20 09:26:23 2013: <191>165421: .Mar 20 09:26:21: //8160/355ACD39B3F9/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:26:23 2013: <191>165422:
Wed Mar 20 09:26:23 2013: <191>165423: Set Up Event Sent;
Wed Mar 20 09:26:23 2013: <191>165424: Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:26:23 2013: <191>165428: .Mar 20 09:26:21: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Wed Mar 20 09:26:23 2013: <191>165432: .Mar 20 09:26:21: //8160/355ACD39B3F9/CCAPI/cc_process_call_setup_ind:
Wed Mar 20 09:26:23 2013: <191>165433: >>>>CCAPI handed cid 8160 with tag 50 to app "_ManagedAppProcess_Default"
Wed Mar 20 09:26:23 2013: <191>165437: .Mar 20 09:26:21: //8160/355ACD39B3F9/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:26:23 2013: <191>165448: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:26:23 2013: <191>165449: Called Number=1811032099(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:26:23 2013: <191>165450: Redirect Number=, Display Info=Linha_3325-1786
Wed Mar 20 09:26:23 2013: <191>165451: Account Number=, Final Destination Flag=TRUE,
Wed Mar 20 09:26:23 2013: <191>165452: Guid=355ACD39-9090-11E2-B3F9-DE08FC69A21F, Outgoing Dial-peer=3000
Wed Mar 20 09:26:23 2013: <191>165457: cisco-ani=
Wed Mar 20 09:26:23 2013: <191>165460: cisco-anipi=0
Wed Mar 20 09:26:23 2013: <191>165462: cisco-anisi=0
Wed Mar 20 09:26:23 2013: <191>165466: cisco-rdie=FFFFFFFF
Wed Mar 20 09:26:23 2013: <191>165472: cisco-rdnsi=0
Wed Mar 20 09:26:23 2013: <191>165473: cisco-redirectreason=0 fwd_final_type =0
Wed Mar 20 09:26:23 2013: <191>165476:
Wed Mar 20 09:26:23 2013: <191>165489: .Mar 20 09:26:21: cc_get_feature_vsa count is 4
Wed Mar 20 09:26:23 2013: <191>165490: .Mar 20 09:26:21: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:26:23 2013: <191>165491:
Wed Mar 20 09:26:23 2013: <191>165492: .Mar 20 09:26:21: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203247688,feature_id:8161
Wed Mar 20 09:26:23 2013: <191>165493: .Mar 20 09:26:21: //8161/355ACD39B3F9/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:26:23 2013: <191>165494: SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Wed Mar 20 09:26:23 2013: <191>165495: .Mar 20 09:26:21: //8161/355ACD39B3F9/CCAPI/ccCallSetContext:
Wed Mar 20 09:26:23 2013: <191>165496: Context=0x4BA66220
Wed Mar 20 09:26:23 2013: <191>165497: .Mar 20 09:26:21: //8160/355ACD39B3F9/CCAPI/ccSaveDialpeerTag:
Wed Mar 20 09:26:23 2013: <191>165498: Outgoing Dial-peer=3000
Wed Mar 20 09:26:23 2013: <191>165499: .Mar 20 09:26:22: //8161/355ACD39B3F9/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:26:23 2013: <191>165500: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:26:23 2013: <191>165501: .Mar 20 09:26:22: //8161/355ACD39B3F9/CCAPI/cc_api_call_proceeding:
Wed Mar 20 09:26:23 2013: <191>165502: Interface=0x48A4F728, Progress Indication=NULL(0)
Wed Mar 20 09:26:23 2013: <191>165503: .Mar 20 09:26:22: //8161/355ACD39B3F9/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:26:23 2013: <191>165504: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:26:23 2013: <191>165505: .Mar 20 09:26:22: //8161/355ACD39B3F9/CCAPI/cc_api_set_delay_xport:
Wed Mar 20 09:26:23 2013: <191>165506: CallInfo(delay xport=TRUE)
Wed Mar 20 09:26:23 2013: <191>165507: .Mar 20 09:26:22: //8161/355ACD39B3F9/CCAPI/cc_api_call_alert:
Wed Mar 20 09:26:23 2013: <191>165508: Interface=0x48A4F728, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:26:23 2013: <191>165509: .Mar 20 09:26:22: //8161/355ACD39B3F9/CCAPI/cc_api_call_alert:
Wed Mar 20 09:26:23 2013: <191>165510: Call Entry(Retry Count=0, Responsed=TRUE)
Wed Mar 20 09:26:23 2013: <191>165511: .Mar 20 09:26:22: //8160/355ACD39B3F9/CCAPI/ccCallAlert:
Wed Mar 20 09:26:23 2013: <191>165512:
Wed Mar 20 09:26:23 2013: <191>165513: Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:26:23 2013: <191>165514: .Mar 20 09:26:22: //8160/355ACD39B3F9/CCAPI/ccCallAlert:
Wed Mar 20 09:26:23 2013: <191>165515: Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Wed Mar 20 09:26:23 2013: <191>165516: .Mar 20 09:26:22: //8161/355ACD39B3F9/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:26:23 2013: <191>165517: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:26:23 2013: <191>165518: .Mar 20 09:26:22: //8161/355ACD39B3F9/CCAPI/cc_api_call_notify:
Wed Mar 20 09:26:23 2013: <191>165519: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8161
Wed Mar 20 09:26:23 2013: <191>165520: .Mar 20 09:26:22: //8161/355ACD39B3F9/CCAPI/ccIsInfoRingback:
Wed Mar 20 09:26:23 2013: <191>165521: Returning dpRingBack=0
Wed Mar 20 09:26:23 2013: <191>165522: .Mar 20 09:26:22: //8161/355ACD39B3F9/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:26:23 2013: <191>165523: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:26:23 2013: <191>165524: .Mar 20 09:26:22: //8161/355ACD39B3F9/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:26:23 2013: <191>165525: CallInfo(ccm detected=TRUE)
Wed Mar 20 09:26:23 2013: <191>165526: .Mar 20 09:26:22: //8160/355ACD39B3F9/CCAPI/ccCallNotify:
Wed Mar 20 09:26:23 2013: <191>165527: Data Bitmask=0x5, Call Id=8160
Wed Mar 20 09:26:23 2013: <191>165528: .Mar 20 09:26:22: //8161/355ACD39B3F9/CCAPI/cc_api_call_connected:
Wed Mar 20 09:26:23 2013: <191>165529: Interface=0x48A4F728, Data Bitmask=0x0, Progress Indication=NULL(0),
Wed Mar 20 09:26:23 2013: <191>165530: Connection Handle=0
Wed Mar 20 09:26:23 2013: <191>165531: .Mar 20 09:26:22: //8161/355ACD39B3F9/CCAPI/cc_api_call_connected:
Wed Mar 20 09:26:23 2013: <191>165532: Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Wed Mar 20 09:26:23 2013: <191>165533: .Mar 20 09:26:22: //8161/355ACD39B3F9/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:26:23 2013: <191>165534: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:26:23 2013: <191>165535: .Mar 20 09:26:22: //8161/355ACD39B3F9/CCAPI/cc_api_call_notify:
Wed Mar 20 09:26:23 2013: <191>165536:
Wed Mar 20 09:26:23 2013: <191>165537: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8161
Wed Mar 20 09:26:23 2013: <191>165538: .Mar 20 09:26:22: //8160/355ACD39B3F9/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:26:23 2013: <191>165539: Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:26:23 2013: <191>165540: Tone Direction=Network, Params=0x0, Call Id=8160
Wed Mar 20 09:26:23 2013: <191>165541: .Mar 20 09:26:22: //8160/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:26:23 2013: <191>165542: (confID=0x4BB01CD8, callID1=0x1FE0, callID2=0x1FE1, tag=0x0)
Wed Mar 20 09:26:23 2013: <191>165543: .Mar 20 09:26:22: //8160/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:26:23 2013: <191>165544: (confID=0x4BB01CD8, callID1=0x1FE0, gcid=355ACD39-909011E2-B3F9DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:26:23 2013: <191>165545: .Mar 20 09:26:22: //8161/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:26:23 2013: <191>165546: (confID=0x4BB01CD8, callID2=0x1FE1, gcid=355ACD39-909011E2-B3F9DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:26:23 2013: <191>165547: .Mar 20 09:26:22: //8160/355ACD39B3F9/CCAPI/ccConferenceCreate:
Wed Mar 20 09:26:23 2013: <191>165548: Conference Id=0x4BB01CD8, Call Id1=8160, Call Id2=8161, Tag=0x0
Wed Mar 20 09:26:23 2013: <191>165549: .Mar 20 09:26:22: //8160/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:26:23 2013: <191>165550: Conference Id=0xE5D, Source Interface=0x498845E0, Source Call Id=8160,
Wed Mar 20 09:26:23 2013: <191>165551: Destination Call Id=8161, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:26:23 2013: <191>165552: .Mar 20 09:26:22: //8161/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Wed Mar 20 09:26:23 2013: <191>165553:
Wed Mar 20 09:26:23 2013: <191>165554: .Mar 20 09:26:22: cc_api_get_xcode_stream : 4534
Wed Mar 20 09:26:23 2013: <191>165555: .Mar 20 09:26:22: //8161/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:26:23 2013: <191>165556: Conference Id=0xE5D, Source Interface=0x48A4F728, Source Call Id=8161,
Wed Mar 20 09:26:23 2013: <191>165557: Destination Call Id=8160, Disposition=0x0, Tag=0x0
Wed Mar 20 09:26:23 2013: <191>165558: .Mar 20 09:26:22: //8160/355ACD39B3F9/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:26:23 2013: <191>165559: Conference Id=0xE5D, Source Interface=0x48A4F728, Source Call Id=8161,
Wed Mar 20 09:26:23 2013: <191>165560: Destination Call Id=8160, Disposition=0x0, Tag=0x0
Wed Mar 20 09:26:23 2013: <191>165561: .Mar 20 09:26:22: //8160/355ACD39B3F9/CCAPI/ccConferenceCreate:
Wed Mar 20 09:26:23 2013: <191>165563: .Mar 20 09:26:22: //8161/355ACD39B3F9/CCAPI/ccConferenceCreate:
Wed Mar 20 09:26:23 2013: <191>165564: Call Entry(Conference Id=0xE5D, Destination Call Id=8160)
Wed Mar 20 09:26:23 2013: <191>165568: Modem=0x2, Codec Bytes=20, Signal Type=3)
Wed Mar 20 09:26:23 2013: <191>165569: .Mar 20 09:26:22: //8160/355ACD39B3F9/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:26:23 2013: <191>165580: Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:26:23 2013: <191>165581: Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:26:23 2013: <191>165582: .Mar 20 09:26:22: //8161/355ACD39B3F9/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:26:23 2013: <191>165583: Destination Interface=0x498845E0, Destination Call Id=8160, Source Call Id=8161,
Wed Mar 20 09:26:23 2013: <191>165584: Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:26:23 2013: <191>165594: .Mar 20 09:26:22: //8160/355ACD39B3F9/CCAPI/ccCallNotify:
Wed Mar 20 09:26:23 2013: <191>165595: Data Bitmask=0x5, Call Id=8160
Wed Mar 20 09:26:23 2013: <191>165598: .Mar 20 09:26:22: //8160/355ACD39B3F9/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:26:23 2013: <191>165599: Call Entry(Context=0x4BA75988)
Wed Mar 20 09:26:23 2013: <191>165600: .Mar 20 09:26:22: //8160/355ACD39B3F9/CCAPI/ccCallConnect:
Wed Mar 20 09:26:23 2013: <191>165603:
Wed Mar 20 09:26:24 2013: <191>165604: Call Entry(Connected=TRUE, Responsed=TRUE)
Wed Mar 20 09:26:34 2013: <191>165605: .Mar 20 09:26:33: //8161/355ACD39B3F9/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:26:34 2013: <191>165606: Interface=0x0, Call Id=8161
Wed Mar 20 09:26:34 2013: <191>165607: .Mar 20 09:26:33: //8161/355ACD39B3F9/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:26:34 2013: <191>165608: Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:26:34 2013: <191>165609: .Mar 20 09:26:33: //8161/355ACD39B3F9/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:26:34 2013: <191>165610: Interface=0x48A4F728, Signal Indication=NOT PRESENT(255)
Wed Mar 20 09:26:34 2013: <191>165611: .Mar 20 09:26:33: //8160/355ACD39B3F9/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:26:34 2013: <191>165612: Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:26:34 2013: <191>165613: Tone Direction=Network, Params=0x0, Call Id=8160
Wed Mar 20 09:26:34 2013: <191>165614: .Mar 20 09:26:33: //8161/355ACD39B3F9/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:26:34 2013: <191>165615: Interface=0x48A4F728, Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:26:34 2013: <191>165616: .Mar 20 09:26:33: //8160/355ACD39B3F9/CCAPI/ccCallUserInfo:
Wed Mar 20 09:26:34 2013: <191>165617: Call Id=8160
Wed Mar 20 09:26:34 2013: <191>165618: .Mar 20 09:26:33: //8160/355ACD39B3F9/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:26:34 2013: <191>165619: Stop Tone On Digit=FALSE, Tone=Ring Back,
Wed Mar 20 09:26:34 2013: <191>165620: Tone Direction=Network, Params=0x0, Call Id=8160
Wed Mar 20 09:26:34 2013: <191>165621: .Mar 20 09:26:33: //8161/355ACD39B3F9/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:26:34 2013: <191>165622: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:26:34 2013: <191>165623: .Mar 20 09:26:33: //8161/355ACD39B3F9/CCAPI/cc_api_call_notify:
Wed Mar 20 09:26:34 2013: <191>165624: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8161
Wed Mar 20 09:26:34 2013: <191>165625: .Mar 20 09:26:33: //8161/355ACD39B3F9/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:26:34 2013: <191>165626: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:26:35 2013: <191>165627: .Mar 20 09:26:33: //8161/355ACD39B3F9/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:26:35 2013: <191>165628: CallInfo(ccm detected=TRUE)
Wed Mar 20 09:26:35 2013: <191>165629: .Mar 20 09:26:33: //8160/355ACD39B3F9/CCAPI/ccCallNotify:
Wed Mar 20 09:26:35 2013: <191>165630: Data Bitmask=0x5, Call Id=8160
Wed Mar 20 09:26:45 2013: <191>165631: .Mar 20 09:26:44: //8161/355ACD39B3F9/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:26:45 2013: <191>165632: Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:26:45 2013: <191>165633: .Mar 20 09:26:44: //8161/355ACD39B3F9/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:26:45 2013: <191>165634: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:26:45 2013: <191>165635: .Mar 20 09:26:44: //8161/355ACD39B3F9/CCAPI/cc_api_call_notify:
Wed Mar 20 09:26:45 2013: <191>165636: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8161
Wed Mar 20 09:26:45 2013: <191>165637: .Mar 20 09:26:44: //8160/355ACD39B3F9/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:26:45 2013: <191>165638: Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:26:45 2013: <191>165639: Tone Direction=Network, Params=0x0, Call Id=8160
Wed Mar 20 09:26:45 2013: <191>165640: .Mar 20 09:26:44: //8161/355ACD39B3F9/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:26:45 2013: <191>165641: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:26:45 2013: <191>165642: .Mar 20 09:26:44: //8161/355ACD39B3F9/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:26:45 2013: <191>165643: CallInfo(ccm detected=TRUE)
Wed Mar 20 09:26:45 2013: <191>165644: .Mar 20 09:26:44: //8160/355ACD39B3F9/CCAPI/ccCallNotify:
Wed Mar 20 09:26:45 2013: <191>165645: Data Bitmask=0x5, Call Id=8160
Wed Mar 20 09:26:45 2013: <191>165646: .Mar 20 09:26:44: //8161/355ACD39B3F9/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:26:45 2013: <191>165647: Destination Interface=0x498845E0, Destination Call Id=8160, Source Call Id=8161,
Wed Mar 20 09:26:45 2013: <191>165648: Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:26:45 2013: <191>165649: Modem=0x2, Codec Bytes=160, Signal Type=2)
Wed Mar 20 09:26:45 2013: <191>165650: .Mar 20 09:26:44: //8161/355ACD39B3F9/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:26:45 2013: <191>165651: Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:26:45 2013: <191>165652: Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:26:45 2013: <191>165653: .Mar 20 09:26:44: //8161/355ACD39B3F9/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:26:45 2013: <191>165654:
Wed Mar 20 09:26:45 2013: <191>165655: Destination Interface=0x498845E0, Destination Call Id=8160, Source Call Id=8161,
Wed Mar 20 09:26:45 2013: <191>165656: Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:26:45 2013: <191>165657: Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=507)
Wed Mar 20 09:26:45 2013: <191>165658: .Mar 20 09:26:44: //8160/355ACD39B3F9/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:26:45 2013: <191>165659: Destination Interface=0x48A4F728, Destination Call Id=8161, Source Call Id=8160,
Wed Mar 20 09:26:45 2013: <191>165660: Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:26:45 2013: <191>165661: Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=507)
Wed Mar 20 09:26:45 2013: <191>165662: .Mar 20 09:26:44: //8160/355ACD39B3F9/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:26:45 2013: <191>165663: Call Id=8160
Wed Mar 20 09:26:45 2013: <191>165664: .Mar 20 09:26:44: //8160/355ACD39B3F9/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:26:45 2013: <191>165665:
Wed Mar 20 09:26:46 2013: <191>165666: Call Entry(Context=0x4BA75988)
Wed Mar 20 09:26:55 2013: <191>165667: .Mar 20 09:26:54: //8158/008F92424106/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:26:55 2013: <191>165668: Cause Value=16, Interface=0x48A4F728, Call Id=8158
Wed Mar 20 09:26:55 2013: <191>165669: .Mar 20 09:26:54: //8158/008F92424106/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:26:55 2013: <191>165670: Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:26:55 2013: <191>165671: .Mar 20 09:26:54: //8158/008F92424106/CCAPI/ccConferenceDestroy:
Wed Mar 20 09:26:55 2013: <191>165672: Conference Id=0xE5C, Tag=0x0
Wed Mar 20 09:26:55 2013: <191>165673: .Mar 20 09:26:54: //8158/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:26:55 2013: <191>165674: Conference Id=0xE5C, Source Interface=0x48A4F728, Source Call Id=8158,
Wed Mar 20 09:26:55 2013: <191>165675: Destination Call Id=8159, Disposition=0x0, Tag=0x0
Wed Mar 20 09:26:55 2013: <191>165676: .Mar 20 09:26:54: //8159/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:26:55 2013: <191>165677:
Wed Mar 20 09:26:55 2013: <191>165678: Conference Id=0xE5C, Source Interface=0x4987FF98, Source Call Id=8159,
Wed Mar 20 09:26:55 2013: <191>165679: Destination Call Id=8158, Disposition=0x0, Tag=0x0
Wed Mar 20 09:26:55 2013: <191>165680: .Mar 20 09:26:54: //8158/008F92424106/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:26:55 2013: <191>165681: Conference Id=0xE5C, Source Interface=0x4987FF98, Source Call Id=8159,
Wed Mar 20 09:26:55 2013: <191>165682: Destination Call Id=8158, Disposition=0x0, Tag=0x0
Wed Mar 20 09:26:55 2013: <191>165683: .Mar 20 09:26:54: //8158/008F92424106/CCAPI/ccCallDisconnect:
Wed Mar 20 09:26:55 2013: <191>165684: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:26:55 2013: <191>165685: .Mar 20 09:26:54: //8158/008F92424106/CCAPI/ccCallDisconnect:
Wed Mar 20 09:26:55 2013: <191>165686: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:26:55 2013: <191>165687: .Mar 20 09:26:54: //8158/008F92424106/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:26:55 2013: <191>165688:
Wed Mar 20 09:26:55 2013: <191>165689: Transfer Number Is Null
Wed Mar 20 09:26:55 2013: <191>165690: .Mar 20 09:26:54: //8159/008F92424106/CCAPI/ccCallDisconnect:
Wed Mar 20 09:26:55 2013: <191>165691: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Wed Mar 20 09:26:55 2013: <191>165692: .Mar 20 09:26:54: //8159/008F92424106/CCAPI/ccCallDisconnect:
Wed Mar 20 09:26:55 2013: <191>165693: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:26:55 2013: <191>165694: .Mar 20 09:26:54: //8159/008F92424106/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:26:55 2013: <191>165695: Transfer Number Is Null
Wed Mar 20 09:26:55 2013: <191>165696: .Mar 20 09:26:54: //8158/008F92424106/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:26:55 2013: <191>165697: Transfer Number Is Null
Wed Mar 20 09:26:55 2013: <191>165698: .Mar 20 09:26:54: //8158/008F92424106/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:26:55 2013: <191>165699:
Wed Mar 20 09:26:55 2013: <191>165700: Disposition=0, Interface=0x48A4F728, Tag=0x0, Call Id=8158,
Wed Mar 20 09:26:55 2013: <191>165701: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:26:55 2013: <191>165702: .Mar 20 09:26:54: //8158/008F92424106/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:26:55 2013: <191>165703: Call Disconnect Event Sent
Wed Mar 20 09:26:55 2013: <191>165704: .Mar 20 09:26:54: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:26:55 2013: <191>165705:
Wed Mar 20 09:26:55 2013: <191>165706: .Mar 20 09:26:54: :cc_free_feature_vsa freeing 47B81CE0
Wed Mar 20 09:26:55 2013: <191>165707: .Mar 20 09:26:54: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:26:55 2013: <191>165708:
Wed Mar 20 09:26:55 2013: <191>165709: .Mar 20 09:26:54: vsacount in free is 3
Wed Mar 20 09:26:55 2013: <191>165710: .Mar 20 09:26:54: //8159/008F92424106/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:26:55 2013: <191>165711: Disposition=0, Interface=0x4987FF98, Tag=0x0, Call Id=8159,
Wed Mar 20 09:26:55 2013: <191>165712: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:26:56 2013: <191>165713: .Mar 20 09:26:54: //8159/008F92424106/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:26:56 2013: <191>165714: Call Disconnect Event Sent
Wed Mar 20 09:26:56 2013: <191>165715: .Mar 20 09:26:54: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:26:56 2013: <191>165716:
Wed Mar 20 09:26:56 2013: <191>165717: .Mar 20 09:26:54: :cc_free_feature_vsa freeing 47B81C00
Wed Mar 20 09:26:56 2013: <191>165718: .Mar 20 09:26:54: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:26:56 2013: <191>165719:
Wed Mar 20 09:26:56 2013: <191>165720: .Mar 20 09:26:54: vsacount in free is 2
Wed Mar 20 09:27:30 2013: <191>165721: .Mar 20 09:27:29: //8161/355ACD39B3F9/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:27:30 2013: <191>165722: Cause Value=16, Interface=0x48A4F728, Call Id=8161
Wed Mar 20 09:27:30 2013: <191>165723: .Mar 20 09:27:29: //8161/355ACD39B3F9/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:27:30 2013: <191>165724: Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:27:30 2013: <191>165725: .Mar 20 09:27:29: //8160/355ACD39B3F9/CCAPI/ccConferenceDestroy:
Wed Mar 20 09:27:30 2013: <191>165726: Conference Id=0xE5D, Tag=0x0
Wed Mar 20 09:27:30 2013: <191>165727: .Mar 20 09:27:29: //8160/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:27:30 2013: <191>165728: Conference Id=0xE5D, Source Interface=0x498845E0, Source Call Id=8160,
Wed Mar 20 09:27:30 2013: <191>165729: Destination Call Id=8161, Disposition=0x0, Tag=0x0
Wed Mar 20 09:27:30 2013: <191>165730: .Mar 20 09:27:29: //8161/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:27:30 2013: <191>165731:
Wed Mar 20 09:27:30 2013: <191>165732: Conference Id=0xE5D, Source Interface=0x48A4F728, Source Call Id=8161,
Wed Mar 20 09:27:30 2013: <191>165733: Destination Call Id=8160, Disposition=0x0, Tag=0x0
Wed Mar 20 09:27:30 2013: <191>165734: .Mar 20 09:27:29: //8160/355ACD39B3F9/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:27:30 2013: <191>165735: Conference Id=0xE5D, Source Interface=0x48A4F728, Source Call Id=8161,
Wed Mar 20 09:27:30 2013: <191>165736: Destination Call Id=8160, Disposition=0x0, Tag=0x0
Wed Mar 20 09:27:30 2013: <191>165737: .Mar 20 09:27:29: //8160/355ACD39B3F9/CCAPI/ccCallDisconnect:
Wed Mar 20 09:27:30 2013: <191>165738: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Wed Mar 20 09:27:30 2013: <191>165739: .Mar 20 09:27:29: //8160/355ACD39B3F9/CCAPI/ccCallDisconnect:
Wed Mar 20 09:27:30 2013: <191>165740: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:27:30 2013: <191>165741: .Mar 20 09:27:29: //8160/355ACD39B3F9/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:27:30 2013: <191>165742:
Wed Mar 20 09:27:30 2013: <191>165743: Transfer Number Is Null
Wed Mar 20 09:27:30 2013: <191>165744: .Mar 20 09:27:29: //8161/355ACD39B3F9/CCAPI/ccCallDisconnect:
Wed Mar 20 09:27:30 2013: <191>165745: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:27:30 2013: <191>165746: .Mar 20 09:27:29: //8161/355ACD39B3F9/CCAPI/ccCallDisconnect:
Wed Mar 20 09:27:30 2013: <191>165747: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:27:30 2013: <191>165748: .Mar 20 09:27:29: //8161/355ACD39B3F9/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:27:30 2013: <191>165749: Transfer Number Is Null
Wed Mar 20 09:27:30 2013: <191>165750: .Mar 20 09:27:29: //8161/355ACD39B3F9/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:27:30 2013: <191>165751: Transfer Number Is Null
Wed Mar 20 09:27:30 2013: <191>165752: .Mar 20 09:27:29: //8161/355ACD39B3F9/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:27:30 2013: <191>165753:
Wed Mar 20 09:27:30 2013: <191>165754: Disposition=0, Interface=0x48A4F728, Tag=0x0, Call Id=8161,
Wed Mar 20 09:27:30 2013: <191>165755: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:27:30 2013: <191>165756: .Mar 20 09:27:29: //8161/355ACD39B3F9/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:27:30 2013: <191>165757: Call Disconnect Event Sent
Wed Mar 20 09:27:30 2013: <191>165758: .Mar 20 09:27:29: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:27:30 2013: <191>165759:
Wed Mar 20 09:27:30 2013: <191>165760: .Mar 20 09:27:29: :cc_free_feature_vsa freeing 47B81A40
Wed Mar 20 09:27:30 2013: <191>165761: .Mar 20 09:27:29: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:27:30 2013: <191>165762:
Wed Mar 20 09:27:30 2013: <191>165763: .Mar 20 09:27:29: vsacount in free is 1
Wed Mar 20 09:27:30 2013: <191>165764: .Mar 20 09:27:29: //8160/355ACD39B3F9/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:27:30 2013: <191>165765: Disposition=0, Interface=0x498845E0, Tag=0x0, Call Id=8160,
Wed Mar 20 09:27:30 2013: <191>165766: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:27:31 2013: <191>165767: .Mar 20 09:27:29: //8160/355ACD39B3F9/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:27:31 2013: <191>165768: Call Disconnect Event Sent
Wed Mar 20 09:27:31 2013: <191>165769: .Mar 20 09:27:29: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:27:31 2013: <191>165770:
Wed Mar 20 09:27:31 2013: <191>165771: .Mar 20 09:27:29: :cc_free_feature_vsa freeing 47B81B20
Wed Mar 20 09:27:31 2013: <191>165772: .Mar 20 09:27:29: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:27:31 2013: <191>165773:
Wed Mar 20 09:27:31 2013: <191>165774: .Mar 20 09:27:29: vsacount in free is 0
Wed Mar 20 09:27:54 2013: <190>165775: .Mar 20 09:27:52: %IPPHONE-6-UNREGISTER_NORMAL: ephone-7:SEP002699442108 IP:10.229.64.50 Socket:5 DeviceType:Phone has unregistered normally.
Wed Mar 20 09:28:18 2013: <191>165776: .Mar 20 09:28:16: //-1/8062BAA34206/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:28:18 2013: <191>165777: cc_api_call_setup_ind_common:
Wed Mar 20 09:28:18 2013: <191>165778: cisco-username=PF-Assis-Margarida
Wed Mar 20 09:28:18 2013: <191>165779: ----- ccCallInfo IE subfields -----
Wed Mar 20 09:28:18 2013: <191>165780: cisco-ani=1811032010
Wed Mar 20 09:28:18 2013: <191>165781: cisco-anitype=0
Wed Mar 20 09:28:18 2013: <191>165782: cisco-aniplan=0
Wed Mar 20 09:28:18 2013: <191>165783: cisco-anipi=0
Wed Mar 20 09:28:18 2013: <191>165784: cisco-anisi=1
Wed Mar 20 09:28:18 2013: <191>165785: dest=033225465
Wed Mar 20 09:28:18 2013: <191>165786: cisco-desttype=0
Wed Mar 20 09:28:18 2013: <191>165787: cisco-destplan=0
Wed Mar 20 09:28:18 2013: <191>165788: cisco-rdie=FFFFFFFF
Wed Mar 20 09:28:18 2013: <191>165789: cisco-rdn=
Wed Mar 20 09:28:18 2013: <191>165790: cisco-lastrdn=
Wed Mar 20 09:28:18 2013: <191>165791: cisco-rdntype=-1
Wed Mar 20 09:28:18 2013: <191>165792: cisco-rdnplan=-1
Wed Mar 20 09:28:18 2013: <191>165793: cisco-rdnpi=-1
Wed Mar 20 09:28:18 2013: <191>165794: cisco-rdnsi=-1
Wed Mar 20 09:28:18 2013: <191>165795: cisco-redirectreason=-1 fwd_final_type =0
Wed Mar 20 09:28:18 2013: <191>165796: final_redirectNumber =
Wed Mar 20 09:28:18 2013: <191>165797: hunt_group_timeout =0
Wed Mar 20 09:28:18 2013: <191>165798:
Wed Mar 20 09:28:18 2013: <191>165799: .Mar 20 09:28:16: //-1/8062BAA34206/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:28:18 2013: <191>165800:
Wed Mar 20 09:28:18 2013: <191>165801: Interface=0x48A4F728, Call Info(
Wed Mar 20 09:28:18 2013: <191>165802: Calling Number=1811032010,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Wed Mar 20 09:28:18 2013: <191>165803: Called Number=033225465(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:28:18 2013: <191>165804: Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Wed Mar 20 09:28:18 2013: <191>165805: Incoming Dial-peer=200, Progress Indication=NULL(0), Calling IE Present=TRUE,
Wed Mar 20 09:28:18 2013: <191>165806: Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=8162
Wed Mar 20 09:28:18 2013: <191>165807: .Mar 20 09:28:16: //-1/8062BAA34206/CCAPI/ccCheckClipClir:
Wed Mar 20 09:28:18 2013: <191>165808: In: Calling Number=1811032010(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Wed Mar 20 09:28:18 2013: <191>165809: .Mar 20 09:28:16: //-1/8062BAA34206/CCAPI/ccCheckClipClir:
Wed Mar 20 09:28:18 2013: <191>165810: Out: Calling Number=1811032010(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Wed Mar 20 09:28:18 2013: <191>165811: .Mar 20 09:28:16: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:28:18 2013: <191>165812:
Wed Mar 20 09:28:18 2013: <191>165813: .Mar 20 09:28:16: :cc_get_feature_vsa malloc success
Wed Mar 20 09:28:18 2013: <191>165814: .Mar 20 09:28:16: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:28:18 2013: <191>165815:
Wed Mar 20 09:28:18 2013: <191>165816: .Mar 20 09:28:16: cc_get_feature_vsa count is 1
Wed Mar 20 09:28:18 2013: <191>165817: .Mar 20 09:28:16: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:28:18 2013: <191>165818:
Wed Mar 20 09:28:18 2013: <191>165819: .Mar 20 09:28:16: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203322344,feature_id:8162
Wed Mar 20 09:28:18 2013: <191>165820: .Mar 20 09:28:16: //8162/8062BAA34206/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:28:18 2013: <191>165821:
Wed Mar 20 09:28:18 2013: <191>165822: Set Up Event Sent;
Wed Mar 20 09:28:18 2013: <191>165824: Called Number=033225465(TON=Unknown, NPI=Unknown))
Wed Mar 20 09:28:18 2013: <191>165828: Try with the demoted called number 033225465
Wed Mar 20 09:28:18 2013: <191>165832: >>>>CCAPI handed cid 8162 with tag 200 to app "_ManagedAppProcess_Default"
Wed Mar 20 09:28:18 2013: <191>165833: .Mar 20 09:28:16: //8162/8062BAA34206/CCAPI/ccCallProceeding:
Wed Mar 20 09:28:18 2013: <191>165838: .Mar 20 09:28:16: //8162/8062BAA34206/CCAPI/ccCheckClipClir:
Wed Mar 20 09:28:18 2013: <191>165839: In: Calling Number=1811032010(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Wed Mar 20 09:28:18 2013: <191>165840: .Mar 20 09:28:16: //8162/8062BAA34206/CCAPI/ccCheckClipClir:
Wed Mar 20 09:28:18 2013: <191>165841: Out: Calling Number=1811032010(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Wed Mar 20 09:28:18 2013: <191>165842: .Mar 20 09:28:16: //8162/8062BAA34206/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:28:18 2013: <191>165843:
Wed Mar 20 09:28:18 2013: <191>165855: cisco-ani=1811032010
Wed Mar 20 09:28:18 2013: <191>165856: cisco-anitype=0
Wed Mar 20 09:28:18 2013: <191>165857:
Wed Mar 20 09:28:18 2013: <191>165860: cisco-anisi=1
Wed Mar 20 09:28:18 2013: <191>165862: cisco-desttype=0
Wed Mar 20 09:28:18 2013: <191>165863: cisco-destplan=0
Wed Mar 20 09:28:18 2013: <191>165866: cisco-lastrdn=
Wed Mar 20 09:28:18 2013: <191>165871: cisco-redirectreason=-1 fwd_final_type =0
Wed Mar 20 09:28:18 2013: <191>165875: .Mar 20 09:28:16: //8162/8062BAA34206/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:28:19 2013: <191>165887: .Mar 20 09:28:16: cc_get_feature_vsa count is 2
Wed Mar 20 09:28:19 2013: <191>165888: .Mar 20 09:28:16: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:28:19 2013: <191>165889:
Wed Mar 20 09:28:19 2013: <191>165890: .Mar 20 09:28:16: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203322120,feature_id:8163
Wed Mar 20 09:28:19 2013: <191>165891: .Mar 20 09:28:16: //8163/8062BAA34206/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:28:19 2013: <191>165892: SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Wed Mar 20 09:28:19 2013: <191>165893: .Mar 20 09:28:16: //8163/8062BAA34206/CCAPI/ccCallSetContext:
Wed Mar 20 09:28:19 2013: <191>165894: Context=0x4BA70D68
Wed Mar 20 09:28:19 2013: <191>165895: .Mar 20 09:28:16: //8162/8062BAA34206/CCAPI/ccSaveDialpeerTag:
Wed Mar 20 09:28:19 2013: <191>165896: Outgoing Dial-peer=18
Wed Mar 20 09:28:19 2013: <191>165897: .Mar 20 09:28:16: //8163/8062BAA34206/CCAPI/cc_api_call_proceeding:
Wed Mar 20 09:28:19 2013: <191>165898: Interface=0x4987FF98, Progress Indication=NULL(0)
Wed Mar 20 09:28:20 2013: <191>165899: .Mar 20 09:28:19: //8163/8062BAA34206/CCAPI/cc_api_call_cut_progress:
Wed Mar 20 09:28:20 2013: <191>165900: Interface=0x4987FF98, Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2),
Wed Mar 20 09:28:20 2013: <191>165901: Cause Value=0
Wed Mar 20 09:28:20 2013: <191>165902: .Mar 20 09:28:19: //8163/8062BAA34206/CCAPI/cc_api_call_cut_progress:
Wed Mar 20 09:28:20 2013: <191>165903: Call Entry(Responsed=TRUE)
Wed Mar 20 09:28:20 2013: <191>165904: .Mar 20 09:28:19: //8162/8062BAA34206/CCAPI/ccCallCutProgress:
Wed Mar 20 09:28:20 2013: <191>165905: Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=0
Wed Mar 20 09:28:20 2013: <191>165906: Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
Wed Mar 20 09:28:20 2013: <191>165907: .Mar 20 09:28:19: //8162/8062BAA34206/CCAPI/ccCallCutProgress:
Wed Mar 20 09:28:20 2013: <191>165908: Call Entry(Responsed=TRUE)
Wed Mar 20 09:28:20 2013: <191>165909: .Mar 20 09:28:19: //8163/8062BAA34206/CCAPI/cc_api_get_called_ccm_detected:
Wed Mar 20 09:28:20 2013: <191>165910: CallInfo(ccm detected=0)
Wed Mar 20 09:28:20 2013: <191>165911: .Mar 20 09:28:19: //8162/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:28:20 2013: <191>165912: (confID=0x4BB01E40, callID1=0x1FE2, callID2=0x1FE3, tag=0x0)
Wed Mar 20 09:28:21 2013: <191>165913: .Mar 20 09:28:19: //8162/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:28:21 2013: <191>165914: (confID=0x4BB01E40, callID1=0x1FE2, gcid=0-0-0-0, tag=0x0)
Wed Mar 20 09:28:21 2013: <191>165915: .Mar 20 09:28:19: //8163/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:28:21 2013: <191>165916: (confID=0x4BB01E40, callID2=0x1FE3, gcid=0-0-0-0, tag=0x0)
Wed Mar 20 09:28:21 2013: <191>165917: .Mar 20 09:28:19: //8162/8062BAA34206/CCAPI/ccConferenceCreate:
Wed Mar 20 09:28:21 2013: <191>165918: Conference Id=0x4BB01E40, Call Id1=8162, Call Id2=8163, Tag=0x0
Wed Mar 20 09:28:21 2013: <191>165919: .Mar 20 09:28:19: //8162/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Wed Mar 20 09:28:21 2013: <191>165920:
Wed Mar 20 09:28:21 2013: <191>165921: .Mar 20 09:28:19: cc_api_get_xcode_stream : 4534
Wed Mar 20 09:28:21 2013: <191>165922: .Mar 20 09:28:19: //8162/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:28:21 2013: <191>165923: Conference Id=0xE5E, Source Interface=0x48A4F728, Source Call Id=8162,
Wed Mar 20 09:28:21 2013: <191>165924: Destination Call Id=8163, Disposition=0x0, Tag=0x0
Wed Mar 20 09:28:21 2013: <191>165925: .Mar 20 09:28:19: //8163/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:28:21 2013: <191>165926: Conference Id=0xE5E, Source Interface=0x4987FF98, Source Call Id=8163,
Wed Mar 20 09:28:21 2013: <191>165927: Destination Call Id=8162, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:28:21 2013: <191>165928: .Mar 20 09:28:19: //8162/8062BAA34206/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:28:21 2013: <191>165929: Conference Id=0xE5E, Source Interface=0x4987FF98, Source Call Id=8163,
Wed Mar 20 09:28:21 2013: <191>165930: Destination Call Id=8162, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:28:21 2013: <191>165931: .Mar 20 09:28:19: //8162/8062BAA34206/CCAPI/ccConferenceCreate:
Wed Mar 20 09:28:21 2013: <191>165932:
Wed Mar 20 09:28:21 2013: <191>165933: Call Entry(Conference Id=0xE5E, Destination Call Id=8163)
Wed Mar 20 09:28:21 2013: <191>165934: .Mar 20 09:28:19: //8163/8062BAA34206/CCAPI/ccConferenceCreate:
Wed Mar 20 09:28:21 2013: <191>165935: Call Entry(Conference Id=0xE5E, Destination Call Id=8162)
Wed Mar 20 09:28:21 2013: <191>165945: Conference Id=0xE5E, Call Id1=8162, Call Id2=8163
Wed Mar 20 09:28:21 2013: <191>165946: .Mar 20 09:28:19: //8162/8062BAA34206/CCAPI/ccCallNotify:
Wed Mar 20 09:28:21 2013: <191>165947: Data Bitmask=0x7, Call Id=8162
Wed Mar 20 09:28:21 2013: <191>165948: .Mar 20 09:28:19: //8163/8062BAA34206/CCAPI/cc_api_get_called_ccm_detected:
Wed Mar 20 09:28:21 2013: <191>165949: CallInfo(ccm detected=0)
Wed Mar 20 09:28:21 2013: <191>165950: .Mar 20 09:28:19: //8162/8062BAA34206/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:28:21 2013: <191>165951: Destination Interface=0x4987FF98, Destination Call Id=8163, Source Call Id=8162,
Wed Mar 20 09:28:21 2013: <191>165952: Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:28:21 2013: <191>165953: Modem=0x2, Codec Bytes=160, Signal Type=2)
Wed Mar 20 09:28:21 2013: <191>165954: .Mar 20 09:28:19: //8162/8062BAA34206/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:28:21 2013: <191>165955: Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:28:21 2013: <191>165956: Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:28:21 2013: <191>165957: .Mar 20 09:28:19: //8162/8062BAA34206/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:28:21 2013: <191>165958: Destination Interface=0x4987FF98, Destination Call Id=8163, Source Call Id=8162,
Wed Mar 20 09:28:21 2013: <191>165959: Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:28:21 2013: <191>165960: Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=4671)
Wed Mar 20 09:28:21 2013: <191>165961: .Mar 20 09:28:19: //8163/8062BAA34206/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:28:21 2013: <191>165962: Destination Interface=0x48A4F728, Destination Call Id=8162, Source Call Id=8163,
Wed Mar 20 09:28:21 2013: <191>165963: Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:28:21 2013: <191>165964: Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=4671)
Wed Mar 20 09:28:21 2013: <191>165965: .Mar 20 09:28:19: //8163/8062BAA34206/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:28:21 2013: <191>165966: Call Id=8163
Wed Mar 20 09:28:21 2013: <191>165967: .Mar 20 09:28:19: //8163/8062BAA34206/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:28:21 2013: <191>165968: Call Entry(Context=0x4BA70D68)
Wed Mar 20 09:28:21 2013: <191>165969: .Mar 20 09:28:19: //8163/8062BAA34206/CCAPI/cc_api_call_connected:
Wed Mar 20 09:28:21 2013: <191>165970: Interface=0x4987FF98, Data Bitmask=0x1, Progress Indication=DESTINATION IS NON ISDN(2),
Wed Mar 20 09:28:21 2013: <191>165971: Connection Handle=0
Wed Mar 20 09:28:21 2013: <191>165972: .Mar 20 09:28:19: //8163/8062BAA34206/CCAPI/cc_api_call_connected:
Wed Mar 20 09:28:21 2013: <191>165973: Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Wed Mar 20 09:28:21 2013: <191>165974: .Mar 20 09:28:19: //8162/8062BAA34206/CCAPI/ccCallConnect:
Wed Mar 20 09:28:21 2013: <191>165975: Progress Indication=DESTINATION IS NON ISDN(2), Data Bitmask=0x1
Wed Mar 20 09:28:21 2013: <191>165976: .Mar 20 09:28:19: //8163/8062BAA34206/CCAPI/cc_api_get_called_ccm_detected:
Wed Mar 20 09:28:21 2013: <191>165977: CallInfo(ccm detected=0)
Wed Mar 20 09:28:22 2013: <191>165978: .Mar 20 09:28:19: //8162/8062BAA34206/CCAPI/ccCallConnect:
Wed Mar 20 09:28:22 2013: <191>165979: Call Entry(Connected=TRUE, Responsed=TRUE)
Wed Mar 20 09:28:22 2013: <191>165980: .Mar 20 09:28:19: //8162/8062BAA34206/CCAPI/ccCallNotify:
Wed Mar 20 09:28:22 2013: <191>165981: Data Bitmask=0x7, Call Id=8162
Wed Mar 20 09:28:22 2013: <191>165982: .Mar 20 09:28:19: //8163/8062BAA34206/CCAPI/cc_api_get_called_ccm_detected:
Wed Mar 20 09:28:22 2013: <191>165983: CallInfo(ccm detected=0)
Wed Mar 20 09:28:39 2013: <191>165984: .Mar 20 09:28:38: //-1/867FF001B400/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:28:39 2013: <191>165985: cc_api_call_setup_ind_common:
Wed Mar 20 09:28:39 2013: <191>165986: cisco-username=
Wed Mar 20 09:28:39 2013: <191>165987: ----- ccCallInfo IE subfields -----
Wed Mar 20 09:28:39 2013: <191>165988: cisco-ani=
Wed Mar 20 09:28:39 2013: <191>165989: cisco-anitype=0
Wed Mar 20 09:28:39 2013: <191>165990: cisco-aniplan=0
Wed Mar 20 09:28:39 2013: <191>165991: cisco-anipi=0
Wed Mar 20 09:28:39 2013: <191>165992: cisco-anisi=0
Wed Mar 20 09:28:39 2013: <191>165993: dest=1811032099
Wed Mar 20 09:28:39 2013: <191>165994: cisco-desttype=0
Wed Mar 20 09:28:39 2013: <191>165995: cisco-destplan=0
Wed Mar 20 09:28:39 2013: <191>165996: cisco-rdie=FFFFFFFF
Wed Mar 20 09:28:39 2013: <191>165997: cisco-rdn=
Wed Mar 20 09:28:39 2013: <191>165998: cisco-lastrdn=
Wed Mar 20 09:28:39 2013: <191>165999: cisco-rdntype=0
Wed Mar 20 09:28:39 2013: <191>166000: cisco-rdnplan=0
Wed Mar 20 09:28:39 2013: <191>166001: cisco-rdnpi=0
Wed Mar 20 09:28:39 2013: <191>166002: cisco-rdnsi=0
Wed Mar 20 09:28:39 2013: <191>166003: cisco-redirectreason=0 fwd_final_type =0
Wed Mar 20 09:28:39 2013: <191>166004: final_redirectNumber =
Wed Mar 20 09:28:39 2013: <191>166005: hunt_group_timeout =0
Wed Mar 20 09:28:39 2013: <191>166006:
Wed Mar 20 09:28:39 2013: <191>166007: .Mar 20 09:28:38: //-1/867FF001B400/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:28:39 2013: <191>166008:
Wed Mar 20 09:28:39 2013: <191>166009: Interface=0x498845E0, Call Info(
Wed Mar 20 09:28:39 2013: <191>166010: Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:28:39 2013: <191>166011: Called Number=1811032099(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:28:39 2013: <191>166012: Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
Wed Mar 20 09:28:39 2013: <191>166013: Incoming Dial-peer=50, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
Wed Mar 20 09:28:39 2013: <191>166014: Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:28:39 2013: <191>166015: .Mar 20 09:28:38: //-1/867FF001B400/CCAPI/ccCheckClipClir:
Wed Mar 20 09:28:39 2013: <191>166016: In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:28:39 2013: <191>166017: .Mar 20 09:28:38: //-1/867FF001B400/CCAPI/ccCheckClipClir:
Wed Mar 20 09:28:39 2013: <191>166018: Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:28:39 2013: <191>166019: .Mar 20 09:28:38: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:28:39 2013: <191>166020:
Wed Mar 20 09:28:39 2013: <191>166021: .Mar 20 09:28:38: :cc_get_feature_vsa malloc success
Wed Mar 20 09:28:39 2013: <191>166022: .Mar 20 09:28:38: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:28:39 2013: <191>166023:
Wed Mar 20 09:28:39 2013: <191>166024: .Mar 20 09:28:38: cc_get_feature_vsa count is 3
Wed Mar 20 09:28:39 2013: <191>166025: .Mar 20 09:28:38: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:28:39 2013: <191>166026:
Wed Mar 20 09:28:39 2013: <191>166027: .Mar 20 09:28:38: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203321896,feature_id:8164
Wed Mar 20 09:28:39 2013: <191>166028: .Mar 20 09:28:38: //8164/867FF001B400/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:28:39 2013: <191>166029:
Wed Mar 20 09:28:39 2013: <191>166030: Set Up Event Sent;
Wed Mar 20 09:28:39 2013: <191>166032: Called Number=1811032099(TON=Unknown, NPI=Unknown))
Wed Mar 20 09:28:39 2013: <191>166036: Try with the demoted called number 1811032099
Wed Mar 20 09:28:39 2013: <191>166042:
Wed Mar 20 09:28:39 2013: <191>166043: Progress Indication=NULL(0)
Wed Mar 20 09:28:39 2013: <191>166044: .Mar 20 09:28:38: //8164/867FF001B400/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:28:39 2013: <191>166053: Destination Pattern=1811032099, Called Number=1811032099, Digit Strip=FALSE
Wed Mar 20 09:28:39 2013: <191>166054: .Mar 20 09:28:38: //8164/867FF001B400/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:28:39 2013: <191>166055: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:28:39 2013: <191>166056: Called Number=1811032099(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:28:39 2013: <191>166057: Redirect Number=, Display Info=Linha_3325-1786
Wed Mar 20 09:28:39 2013: <191>166058: Account Number=, Final Destination Flag=TRUE,
Wed Mar 20 09:28:39 2013: <191>166059: Guid=867FF001-9090-11E2-B400-DE08FC69A21F, Outgoing Dial-peer=3000
Wed Mar 20 09:28:39 2013: <191>166067: cisco-anipi=0
Wed Mar 20 09:28:39 2013: <191>166069: cisco-anisi=0
Wed Mar 20 09:28:39 2013: <191>166073: cisco-rdie=FFFFFFFF
Wed Mar 20 09:28:39 2013: <191>166081: final_redirectNumber =
Wed Mar 20 09:28:39 2013: <191>166082: hunt_group_timeout =0
Wed Mar 20 09:28:39 2013: <191>166096: .Mar 20 09:28:38: cc_get_feature_vsa count is 4
Wed Mar 20 09:28:39 2013: <191>166097: .Mar 20 09:28:38: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:28:39 2013: <191>166098:
Wed Mar 20 09:28:39 2013: <191>166099: .Mar 20 09:28:38: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203321672,feature_id:8165
Wed Mar 20 09:28:39 2013: <191>166100: .Mar 20 09:28:38: //8165/867FF001B400/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:28:39 2013: <191>166101: SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Wed Mar 20 09:28:39 2013: <191>166102: .Mar 20 09:28:38: //8165/867FF001B400/CCAPI/ccCallSetContext:
Wed Mar 20 09:28:39 2013: <191>166103: Context=0x4BA76C90
Wed Mar 20 09:28:39 2013: <191>166104: .Mar 20 09:28:38: //8164/867FF001B400/CCAPI/ccSaveDialpeerTag:
Wed Mar 20 09:28:39 2013: <191>166105: Outgoing Dial-peer=3000
Wed Mar 20 09:28:39 2013: <191>166106: .Mar 20 09:28:38: //8165/867FF001B400/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:28:39 2013: <191>166107: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:28:39 2013: <191>166108: .Mar 20 09:28:38: //8165/867FF001B400/CCAPI/cc_api_call_proceeding:
Wed Mar 20 09:28:39 2013: <191>166109: Interface=0x48A4F728, Progress Indication=NULL(0)
Wed Mar 20 09:28:39 2013: <191>166110: .Mar 20 09:28:38: //8165/867FF001B400/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:28:39 2013: <191>166111: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:28:39 2013: <191>166112: .Mar 20 09:28:38: //8165/867FF001B400/CCAPI/cc_api_set_delay_xport:
Wed Mar 20 09:28:39 2013: <191>166113: CallInfo(delay xport=TRUE)
Wed Mar 20 09:28:39 2013: <191>166114: .Mar 20 09:28:38: //8165/867FF001B400/CCAPI/cc_api_call_alert:
Wed Mar 20 09:28:39 2013: <191>166115: Interface=0x48A4F728, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:28:39 2013: <191>166116: .Mar 20 09:28:38: //8165/867FF001B400/CCAPI/cc_api_call_alert:
Wed Mar 20 09:28:39 2013: <191>166117: Call Entry(Retry Count=0, Responsed=TRUE)
Wed Mar 20 09:28:39 2013: <191>166118: .Mar 20 09:28:38: //8164/867FF001B400/CCAPI/ccCallAlert:
Wed Mar 20 09:28:39 2013: <191>166119:
Wed Mar 20 09:28:39 2013: <191>166120: Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:28:39 2013: <191>166121: .Mar 20 09:28:38: //8164/867FF001B400/CCAPI/ccCallAlert:
Wed Mar 20 09:28:39 2013: <191>166122: Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Wed Mar 20 09:28:39 2013: <191>166123: .Mar 20 09:28:38: //8165/867FF001B400/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:28:39 2013: <191>166124: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:28:39 2013: <191>166125: .Mar 20 09:28:38: //8165/867FF001B400/CCAPI/cc_api_call_notify:
Wed Mar 20 09:28:39 2013: <191>166126: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8165
Wed Mar 20 09:28:39 2013: <191>166127: .Mar 20 09:28:38: //8165/867FF001B400/CCAPI/ccIsInfoRingback:
Wed Mar 20 09:28:39 2013: <191>166128: Returning dpRingBack=0
Wed Mar 20 09:28:39 2013: <191>166129: .Mar 20 09:28:38: //8165/867FF001B400/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:28:39 2013: <191>166130: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:28:39 2013: <191>166131: .Mar 20 09:28:38: //8165/867FF001B400/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:28:39 2013: <191>166132: CallInfo(ccm detected=TRUE)
Wed Mar 20 09:28:39 2013: <191>166133: .Mar 20 09:28:38: //8164/867FF001B400/CCAPI/ccCallNotify:
Wed Mar 20 09:28:39 2013: <191>166134: Data Bitmask=0x5, Call Id=8164
Wed Mar 20 09:28:39 2013: <191>166135: .Mar 20 09:28:38: //8165/867FF001B400/CCAPI/cc_api_call_connected:
Wed Mar 20 09:28:39 2013: <191>166136: Interface=0x48A4F728, Data Bitmask=0x0, Progress Indication=NULL(0),
Wed Mar 20 09:28:39 2013: <191>166137: Connection Handle=0
Wed Mar 20 09:28:39 2013: <191>166138: .Mar 20 09:28:38: //8165/867FF001B400/CCAPI/cc_api_call_connected:
Wed Mar 20 09:28:39 2013: <191>166139: Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Wed Mar 20 09:28:39 2013: <191>166140: .Mar 20 09:28:38: //8165/867FF001B400/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:28:39 2013: <191>166141: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:28:39 2013: <191>166142: .Mar 20 09:28:38: //8165/867FF001B400/CCAPI/cc_api_call_notify:
Wed Mar 20 09:28:39 2013: <191>166143:
Wed Mar 20 09:28:39 2013: <191>166144: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8165
Wed Mar 20 09:28:39 2013: <191>166145: .Mar 20 09:28:38: //8164/867FF001B400/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:28:39 2013: <191>166146: Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:28:39 2013: <191>166147: Tone Direction=Network, Params=0x0, Call Id=8164
Wed Mar 20 09:28:39 2013: <191>166148: .Mar 20 09:28:38: //8164/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:28:39 2013: <191>166149: (confID=0x4BB01DB0, callID1=0x1FE4, callID2=0x1FE5, tag=0x0)
Wed Mar 20 09:28:39 2013: <191>166150: .Mar 20 09:28:38: //8164/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:28:39 2013: <191>166151: (confID=0x4BB01DB0, callID1=0x1FE4, gcid=867FF001-909011E2-B400DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:28:39 2013: <191>166152: .Mar 20 09:28:38: //8165/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:28:39 2013: <191>166153: (confID=0x4BB01DB0, callID2=0x1FE5, gcid=867FF001-909011E2-B400DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:28:39 2013: <191>166154: .Mar 20 09:28:38: //8164/867FF001B400/CCAPI/ccConferenceCreate:
Wed Mar 20 09:28:39 2013: <191>166155: Conference Id=0x4BB01DB0, Call Id1=8164, Call Id2=8165, Tag=0x0
Wed Mar 20 09:28:39 2013: <191>166156: .Mar 20 09:28:38: //8164/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:28:39 2013: <191>166157: Conference Id=0xE5F, Source Interface=0x498845E0, Source Call Id=8164,
Wed Mar 20 09:28:39 2013: <191>166158: Destination Call Id=8165, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:28:39 2013: <191>166159: .Mar 20 09:28:38: //8165/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Wed Mar 20 09:28:39 2013: <191>166160:
Wed Mar 20 09:28:39 2013: <191>166161: .Mar 20 09:28:38: cc_api_get_xcode_stream : 4534
Wed Mar 20 09:28:39 2013: <191>166162: .Mar 20 09:28:38: //8165/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:28:39 2013: <191>166163: Conference Id=0xE5F, Source Interface=0x48A4F728, Source Call Id=8165,
Wed Mar 20 09:28:39 2013: <191>166164: Destination Call Id=8164, Disposition=0x0, Tag=0x0
Wed Mar 20 09:28:39 2013: <191>166165: .Mar 20 09:28:38: //8164/867FF001B400/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:28:39 2013: <191>166166: Conference Id=0xE5F, Source Interface=0x48A4F728, Source Call Id=8165,
Wed Mar 20 09:28:39 2013: <191>166167: Destination Call Id=8164, Disposition=0x0, Tag=0x0
Wed Mar 20 09:28:39 2013: <191>166168: .Mar 20 09:28:38: //8164/867FF001B400/CCAPI/ccConferenceCreate:
Wed Mar 20 09:28:39 2013: <191>166169: Call Entry(Conference Id=0xE5F, Destination Call Id=8165)
Wed Mar 20 09:28:39 2013: <191>166170: .Mar 20 09:28:38: //8165/867FF001B400/CCAPI/ccConferenceCreate:
Wed Mar 20 09:28:39 2013: <191>166171: Call Entry(Conference Id=0xE5F, Destination Call Id=8164)
Wed Mar 20 09:28:39 2013: <191>166180: Conference Id=0xE5F, Call Id1=8164, Call Id2=8165
Wed Mar 20 09:28:39 2013: <191>166181: .Mar 20 09:28:38: //8165/867FF001B400/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:28:39 2013: <191>166182: Destination Interface=0x498845E0, Destination Call Id=8164, Source Call Id=8165,
Wed Mar 20 09:28:39 2013: <191>166191: Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:28:39 2013: <191>166192: Modem=ON(0x2), Codec Bytes=20, Signal Type=2, Seq Num Start=1162)
Wed Mar 20 09:28:39 2013: <191>166193: .Mar 20 09:28:38: //8164/867FF001B400/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:28:39 2013: <191>166194: Destination Interface=0x48A4F728, Destination Call Id=8165, Source Call Id=8164,
Wed Mar 20 09:28:39 2013: <191>166206: Call Entry(Context=0x4BA7A5A8)
Wed Mar 20 09:28:40 2013: <191>166211: Call Entry(Connected=TRUE, Responsed=TRUE)
Wed Mar 20 09:28:50 2013: <191>166212: .Mar 20 09:28:49: //8165/867FF001B400/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:28:50 2013: <191>166213: Interface=0x0, Call Id=8165
Wed Mar 20 09:28:50 2013: <191>166214: .Mar 20 09:28:49: //8165/867FF001B400/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:28:50 2013: <191>166215: Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:28:50 2013: <191>166216: .Mar 20 09:28:49: //8165/867FF001B400/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:28:50 2013: <191>166217: Interface=0x48A4F728, Signal Indication=NOT PRESENT(255)
Wed Mar 20 09:28:50 2013: <191>166218: .Mar 20 09:28:49: //8164/867FF001B400/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:28:50 2013: <191>166219: Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:28:50 2013: <191>166220: Tone Direction=Network, Params=0x0, Call Id=8164
Wed Mar 20 09:28:50 2013: <191>166221: .Mar 20 09:28:49: //8165/867FF001B400/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:28:50 2013: <191>166222: Interface=0x48A4F728, Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:28:50 2013: <191>166223: .Mar 20 09:28:49: //8164/867FF001B400/CCAPI/ccCallUserInfo:
Wed Mar 20 09:28:50 2013: <191>166224: Call Id=8164
Wed Mar 20 09:28:50 2013: <191>166225: .Mar 20 09:28:49: //8164/867FF001B400/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:28:50 2013: <191>166226: Stop Tone On Digit=FALSE, Tone=Ring Back,
Wed Mar 20 09:28:50 2013: <191>166227: Tone Direction=Network, Params=0x0, Call Id=8164
Wed Mar 20 09:28:50 2013: <191>166228: .Mar 20 09:28:49: //8165/867FF001B400/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:28:50 2013: <191>166229: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:28:50 2013: <191>166230: .Mar 20 09:28:49: //8165/867FF001B400/CCAPI/cc_api_call_notify:
Wed Mar 20 09:28:50 2013: <191>166231: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8165
Wed Mar 20 09:28:50 2013: <191>166232: .Mar 20 09:28:49: //8165/867FF001B400/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:28:50 2013: <191>166233: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:28:51 2013: <191>166234: .Mar 20 09:28:49: //8165/867FF001B400/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:28:51 2013: <191>166235: CallInfo(ccm detected=TRUE)
Wed Mar 20 09:28:51 2013: <191>166236: .Mar 20 09:28:49: //8164/867FF001B400/CCAPI/ccCallNotify:
Wed Mar 20 09:28:51 2013: <191>166237: Data Bitmask=0x5, Call Id=8164
Wed Mar 20 09:28:53 2013: <191>166238: .Mar 20 09:28:52: //8165/867FF001B400/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:28:53 2013: <191>166239: Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:28:53 2013: <191>166240: .Mar 20 09:28:52: //8165/867FF001B400/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:28:53 2013: <191>166241: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:28:53 2013: <191>166242: .Mar 20 09:28:52: //8165/867FF001B400/CCAPI/cc_api_call_notify:
Wed Mar 20 09:28:53 2013: <191>166243: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8165
Wed Mar 20 09:28:53 2013: <191>166244: .Mar 20 09:28:52: //8164/867FF001B400/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:28:53 2013: <191>166245: Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:28:53 2013: <191>166246: Tone Direction=Network, Params=0x0, Call Id=8164
Wed Mar 20 09:28:53 2013: <191>166247: .Mar 20 09:28:52: //8165/867FF001B400/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:28:53 2013: <191>166248: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:28:53 2013: <191>166249: .Mar 20 09:28:52: //8165/867FF001B400/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:28:53 2013: <191>166250: CallInfo(ccm detected=TRUE)
Wed Mar 20 09:28:53 2013: <191>166251: .Mar 20 09:28:52: //8164/867FF001B400/CCAPI/ccCallNotify:
Wed Mar 20 09:28:53 2013: <191>166252: Data Bitmask=0x5, Call Id=8164
Wed Mar 20 09:28:53 2013: <191>166253: .Mar 20 09:28:52: //8165/867FF001B400/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:28:53 2013: <191>166254: Destination Interface=0x498845E0, Destination Call Id=8164, Source Call Id=8165,
Wed Mar 20 09:28:53 2013: <191>166255: Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:28:53 2013: <191>166256: Modem=0x2, Codec Bytes=160, Signal Type=2)
Wed Mar 20 09:28:53 2013: <191>166257: .Mar 20 09:28:52: //8165/867FF001B400/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:28:53 2013: <191>166258: Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:28:53 2013: <191>166259: Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:28:53 2013: <191>166260: .Mar 20 09:28:52: //8165/867FF001B400/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:28:53 2013: <191>166261:
Wed Mar 20 09:28:53 2013: <191>166262: Destination Interface=0x498845E0, Destination Call Id=8164, Source Call Id=8165,
Wed Mar 20 09:28:53 2013: <191>166263: Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:28:53 2013: <191>166264: Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=1197)
Wed Mar 20 09:28:53 2013: <191>166265: .Mar 20 09:28:52: //8164/867FF001B400/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:28:53 2013: <191>166266: Destination Interface=0x48A4F728, Destination Call Id=8165, Source Call Id=8164,
Wed Mar 20 09:28:53 2013: <191>166267: Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:28:53 2013: <191>166268: Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=1197)
Wed Mar 20 09:28:53 2013: <191>166269: .Mar 20 09:28:52: //8164/867FF001B400/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:28:53 2013: <191>166270: Call Id=8164
Wed Mar 20 09:28:53 2013: <191>166271: .Mar 20 09:28:52: //8164/867FF001B400/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:28:53 2013: <191>166272:
Wed Mar 20 09:28:54 2013: <191>166273: Call Entry(Context=0x4BA7A5A8)
Wed Mar 20 09:29:46 2013: <191>166274: .Mar 20 09:29:45: //8165/867FF001B400/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:29:46 2013: <191>166276: .Mar 20 09:29:45: //8165/867FF001B400/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:29:46 2013: <191>166275: Interface=0x0, Call Id=8165
Wed Mar 20 09:29:46 2013: <191>166277: Destination Interface=0x498845E0, Destination Call Id=8164, Source Call Id=8165,
Wed Mar 20 09:29:46 2013: <191>166278: Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:29:46 2013: <191>166279: Modem=0x2, Codec Bytes=160, Signal Type=2)
Wed Mar 20 09:29:46 2013: <191>166280: .Mar 20 09:29:45: //8165/867FF001B400/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:29:46 2013: <191>166281: Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:29:46 2013: <191>166282: Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:29:46 2013: <191>166283: .Mar 20 09:29:45: //8165/867FF001B400/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:29:46 2013: <191>166284:
Wed Mar 20 09:29:46 2013: <191>166285: Destination Interface=0x498845E0, Destination Call Id=8164, Source Call Id=8165,
Wed Mar 20 09:29:46 2013: <191>166286: Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:29:46 2013: <191>166287: Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=1809)
Wed Mar 20 09:29:46 2013: <191>166288: .Mar 20 09:29:45: //8164/867FF001B400/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:29:46 2013: <191>166289: Destination Interface=0x48A4F728, Destination Call Id=8165, Source Call Id=8164,
Wed Mar 20 09:29:46 2013: <191>166290: Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:29:46 2013: <191>166291: Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=1809)
Wed Mar 20 09:29:46 2013: <191>166292: .Mar 20 09:29:45: //8164/867FF001B400/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:29:46 2013: <191>166293: Call Id=8164
Wed Mar 20 09:29:46 2013: <191>166294: .Mar 20 09:29:45: //8164/867FF001B400/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:29:46 2013: <191>166295:
Wed Mar 20 09:29:47 2013: <191>166296: Call Entry(Context=0x4BA7A5A8)
Wed Mar 20 09:29:50 2013: <191>166297: .Mar 20 09:29:48: //8165/867FF001B400/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:29:50 2013: <191>166298: Interface=0x0, Call Id=8165
Wed Mar 20 09:29:50 2013: <191>166299: .Mar 20 09:29:48: //8165/867FF001B400/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:29:50 2013: <191>166300: Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:29:50 2013: <191>166301: .Mar 20 09:29:48: //8164/867FF001B400/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:29:50 2013: <191>166302: Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:29:50 2013: <191>166303: Tone Direction=Network, Params=0x0, Call Id=8164
Wed Mar 20 09:29:50 2013: <191>166304: .Mar 20 09:29:48: //8165/867FF001B400/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:29:50 2013: <191>166305: Interface=0x48A4F728, Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:29:50 2013: <191>166306: .Mar 20 09:29:48: //8165/867FF001B400/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:29:50 2013: <191>166307: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:29:51 2013: <191>166308: .Mar 20 09:29:48: //8165/867FF001B400/CCAPI/cc_api_call_notify:
Wed Mar 20 09:29:51 2013: <191>166309: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8165
Wed Mar 20 09:29:51 2013: <191>166310: .Mar 20 09:29:48: //8164/867FF001B400/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:29:51 2013: <191>166311: Stop Tone On Digit=FALSE, Tone=Ring Back,
Wed Mar 20 09:29:51 2013: <191>166312: Tone Direction=Network, Params=0x0, Call Id=8164
Wed Mar 20 09:29:51 2013: <191>166313: .Mar 20 09:29:48: //8165/867FF001B400/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:29:51 2013: <191>166314: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:29:51 2013: <191>166315: .Mar 20 09:29:48: //8165/867FF001B400/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:29:51 2013: <191>166316: CallInfo(ccm detected=TRUE)
Wed Mar 20 09:29:51 2013: <191>166317: .Mar 20 09:29:48: //8164/867FF001B400/CCAPI/ccCallNotify:
Wed Mar 20 09:29:51 2013: <191>166318: Data Bitmask=0x5, Call Id=8164
Wed Mar 20 09:29:51 2013: <191>166319: .Mar 20 09:29:50: //8165/867FF001B400/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:29:51 2013: <191>166320: Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:29:51 2013: <191>166321: .Mar 20 09:29:50: //8164/867FF001B400/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:29:51 2013: <191>166322: Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:29:51 2013: <191>166323: Tone Direction=Network, Params=0x0, Call Id=8164
Wed Mar 20 09:29:51 2013: <191>166324: .Mar 20 09:29:50: //8165/867FF001B400/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:29:51 2013: <191>166325: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:29:51 2013: <191>166326: .Mar 20 09:29:50: //8165/867FF001B400/CCAPI/cc_api_call_notify:
Wed Mar 20 09:29:51 2013: <191>166327: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8165
Wed Mar 20 09:29:51 2013: <191>166328: .Mar 20 09:29:50: //8165/867FF001B400/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:29:51 2013: <191>166329: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:29:51 2013: <191>166330: .Mar 20 09:29:50: //8165/867FF001B400/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:29:51 2013: <191>166331: CallInfo(ccm detected=TRUE)
Wed Mar 20 09:29:51 2013: <191>166332: .Mar 20 09:29:50: //8164/867FF001B400/CCAPI/ccCallNotify:
Wed Mar 20 09:29:51 2013: <191>166333: Data Bitmask=0x5, Call Id=8164
Wed Mar 20 09:29:51 2013: <191>166334: .Mar 20 09:29:50: //8165/867FF001B400/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:29:51 2013: <191>166335: Destination Interface=0x498845E0, Destination Call Id=8164, Source Call Id=8165,
Wed Mar 20 09:29:51 2013: <191>166336: Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:29:51 2013: <191>166337: Modem=0x2, Codec Bytes=160, Signal Type=2)
Wed Mar 20 09:29:51 2013: <191>166338: .Mar 20 09:29:50: //8165/867FF001B400/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:29:51 2013: <191>166339: Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:29:51 2013: <191>166340: Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:29:51 2013: <191>166341: .Mar 20 09:29:50: //8165/867FF001B400/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:29:51 2013: <191>166342:
Wed Mar 20 09:29:51 2013: <191>166343: Destination Interface=0x498845E0, Destination Call Id=8164, Source Call Id=8165,
Wed Mar 20 09:29:51 2013: <191>166344: Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:29:51 2013: <191>166345: Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=1922)
Wed Mar 20 09:29:51 2013: <191>166346: .Mar 20 09:29:50: //8164/867FF001B400/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:29:51 2013: <191>166347: Destination Interface=0x48A4F728, Destination Call Id=8165, Source Call Id=8164,
Wed Mar 20 09:29:51 2013: <191>166348: Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:29:51 2013: <191>166349: Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=1922)
Wed Mar 20 09:29:51 2013: <191>166350: .Mar 20 09:29:50: //8164/867FF001B400/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:29:51 2013: <191>166351: Call Id=8164
Wed Mar 20 09:29:51 2013: <191>166352: .Mar 20 09:29:50: //8164/867FF001B400/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:29:51 2013: <191>166353:
Wed Mar 20 09:29:52 2013: <191>166354: Call Entry(Context=0x4BA7A5A8)
Wed Mar 20 09:33:44 2013: <191>166355: .Mar 20 09:33:43: //8165/867FF001B400/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:33:44 2013: <191>166356: Interface=0x0, Call Id=8165
Wed Mar 20 09:33:44 2013: <191>166357: .Mar 20 09:33:43: //8165/867FF001B400/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:33:44 2013: <191>166358: Cause Value=16, Interface=0x48A4F728, Call Id=8165
Wed Mar 20 09:33:44 2013: <191>166359: .Mar 20 09:33:43: //8165/867FF001B400/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:33:44 2013: <191>166360: Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:33:44 2013: <191>166361: .Mar 20 09:33:43: //8164/867FF001B400/CCAPI/ccConferenceDestroy:
Wed Mar 20 09:33:44 2013: <191>166362: Conference Id=0xE5F, Tag=0x0
Wed Mar 20 09:33:44 2013: <191>166363: .Mar 20 09:33:43: //8164/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:33:44 2013: <191>166364: Conference Id=0xE5F, Source Interface=0x498845E0, Source Call Id=8164,
Wed Mar 20 09:33:44 2013: <191>166365: Destination Call Id=8165, Disposition=0x0, Tag=0x0
Wed Mar 20 09:33:44 2013: <191>166366: .Mar 20 09:33:43: //8165/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:33:44 2013: <191>166367: Conference Id=0xE5F, Source Interface=0x48A4F728, Source Call Id=8165,
Wed Mar 20 09:33:44 2013: <191>166368: Destination Call Id=8164, Disposition=0x0, Tag=0x0
Wed Mar 20 09:33:44 2013: <191>166369: .Mar 20 09:33:43: //8164/867FF001B400/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:33:44 2013: <191>166370: Conference Id=0xE5F, Source Interface=0x48A4F728, Source Call Id=8165,
Wed Mar 20 09:33:44 2013: <191>166371: Destination Call Id=8164, Disposition=0x0, Tag=0x0
Wed Mar 20 09:33:44 2013: <191>166372: .Mar 20 09:33:43: //8164/867FF001B400/CCAPI/ccCallDisconnect:
Wed Mar 20 09:33:44 2013: <191>166373: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Wed Mar 20 09:33:44 2013: <191>166374: .Mar 20 09:33:43: //8164/867FF001B400/CCAPI/ccCallDisconnect:
Wed Mar 20 09:33:44 2013: <191>166375: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:33:44 2013: <191>166376: .Mar 20 09:33:43: //8164/867FF001B400/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:33:44 2013: <191>166377: Transfer Number Is Null
Wed Mar 20 09:33:44 2013: <191>166378: .Mar 20 09:33:43: //8165/867FF001B400/CCAPI/ccCallDisconnect:
Wed Mar 20 09:33:44 2013: <191>166379: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:33:44 2013: <191>166380: .Mar 20 09:33:43: //8165/867FF001B400/CCAPI/ccCallDisconnect:
Wed Mar 20 09:33:44 2013: <191>166381: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:33:44 2013: <191>166382: .Mar 20 09:33:43: //8165/867FF001B400/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:33:44 2013: <191>166383: Transfer Number Is Null
Wed Mar 20 09:33:44 2013: <191>166384: .Mar 20 09:33:43: //8165/867FF001B400/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:33:44 2013: <191>166385: Transfer Number Is Null
Wed Mar 20 09:33:44 2013: <191>166386: .Mar 20 09:33:43: //8165/867FF001B400/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:33:44 2013: <191>166387:
Wed Mar 20 09:33:44 2013: <191>166388: Disposition=0, Interface=0x48A4F728, Tag=0x0, Call Id=8165,
Wed Mar 20 09:33:44 2013: <191>166389: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:33:44 2013: <191>166390: .Mar 20 09:33:43: //8165/867FF001B400/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:33:44 2013: <191>166391: Call Disconnect Event Sent
Wed Mar 20 09:33:44 2013: <191>166392: .Mar 20 09:33:43: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:33:44 2013: <191>166393:
Wed Mar 20 09:33:44 2013: <191>166394: .Mar 20 09:33:43: :cc_free_feature_vsa freeing 47B93B40
Wed Mar 20 09:33:44 2013: <191>166395: .Mar 20 09:33:43: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:33:44 2013: <191>166396:
Wed Mar 20 09:33:45 2013: <191>166397: .Mar 20 09:33:43: vsacount in free is 3
Wed Mar 20 09:33:45 2013: <191>166398: .Mar 20 09:33:43: //8164/867FF001B400/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:33:45 2013: <191>166399: Disposition=0, Interface=0x498845E0, Tag=0x0, Call Id=8164,
Wed Mar 20 09:33:45 2013: <191>166400: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:33:45 2013: <191>166401: .Mar 20 09:33:43: //8164/867FF001B400/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:33:45 2013: <191>166402: Call Disconnect Event Sent
Wed Mar 20 09:33:45 2013: <191>166403: .Mar 20 09:33:43: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:33:45 2013: <191>166404:
Wed Mar 20 09:33:45 2013: <191>166405: .Mar 20 09:33:43: :cc_free_feature_vsa freeing 47B93C20
Wed Mar 20 09:33:45 2013: <191>166406: .Mar 20 09:33:43: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:33:45 2013: <191>166407:
Wed Mar 20 09:33:45 2013: <191>166408: .Mar 20 09:33:43: vsacount in free is 2
Wed Mar 20 09:38:02 2013: <191>166409: .Mar 20 09:38:00: //-1/D5F89820B405/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:38:02 2013: <191>166410: cc_api_call_setup_ind_common:
Wed Mar 20 09:38:02 2013: <191>166411: cisco-username=
Wed Mar 20 09:38:02 2013: <191>166412: ----- ccCallInfo IE subfields -----
Wed Mar 20 09:38:02 2013: <191>166413: cisco-ani=
Wed Mar 20 09:38:02 2013: <191>166414: cisco-anitype=0
Wed Mar 20 09:38:02 2013: <191>166415: cisco-aniplan=0
Wed Mar 20 09:38:02 2013: <191>166416: cisco-anipi=0
Wed Mar 20 09:38:02 2013: <191>166417: cisco-anisi=0
Wed Mar 20 09:38:02 2013: <191>166418: dest=1811032099
Wed Mar 20 09:38:02 2013: <191>166419: cisco-desttype=0
Wed Mar 20 09:38:02 2013: <191>166420: cisco-destplan=0
Wed Mar 20 09:38:02 2013: <191>166421: cisco-rdie=FFFFFFFF
Wed Mar 20 09:38:02 2013: <191>166422: cisco-rdn=
Wed Mar 20 09:38:02 2013: <191>166423: cisco-lastrdn=
Wed Mar 20 09:38:02 2013: <191>166424: cisco-rdntype=0
Wed Mar 20 09:38:02 2013: <191>166425: cisco-rdnplan=0
Wed Mar 20 09:38:02 2013: <191>166426: cisco-rdnpi=0
Wed Mar 20 09:38:02 2013: <191>166427: cisco-rdnsi=0
Wed Mar 20 09:38:02 2013: <191>166428: cisco-redirectreason=0 fwd_final_type =0
Wed Mar 20 09:38:02 2013: <191>166429: final_redirectNumber =
Wed Mar 20 09:38:02 2013: <191>166430: hunt_group_timeout =0
Wed Mar 20 09:38:02 2013: <191>166431:
Wed Mar 20 09:38:02 2013: <191>166432: .Mar 20 09:38:00: //-1/D5F89820B405/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:38:02 2013: <191>166433:
Wed Mar 20 09:38:02 2013: <191>166434: Interface=0x498845E0, Call Info(
Wed Mar 20 09:38:02 2013: <191>166435: Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:38:02 2013: <191>166436: Called Number=1811032099(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:38:02 2013: <191>166437: Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
Wed Mar 20 09:38:02 2013: <191>166438: Incoming Dial-peer=50, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
Wed Mar 20 09:38:02 2013: <191>166439: Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:38:02 2013: <191>166440: .Mar 20 09:38:00: //-1/D5F89820B405/CCAPI/ccCheckClipClir:
Wed Mar 20 09:38:02 2013: <191>166441: In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:38:02 2013: <191>166442: .Mar 20 09:38:00: //-1/D5F89820B405/CCAPI/ccCheckClipClir:
Wed Mar 20 09:38:02 2013: <191>166443: Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:38:02 2013: <191>166444: .Mar 20 09:38:00: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:38:02 2013: <191>166445:
Wed Mar 20 09:38:02 2013: <191>166446: .Mar 20 09:38:00: :cc_get_feature_vsa malloc success
Wed Mar 20 09:38:02 2013: <191>166447: .Mar 20 09:38:00: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:38:02 2013: <191>166448:
Wed Mar 20 09:38:02 2013: <191>166449: .Mar 20 09:38:00: cc_get_feature_vsa count is 3
Wed Mar 20 09:38:02 2013: <191>166450: .Mar 20 09:38:00: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:38:02 2013: <191>166451:
Wed Mar 20 09:38:02 2013: <191>166452: .Mar 20 09:38:00: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203321896,feature_id:8166
Wed Mar 20 09:38:02 2013: <191>166453: .Mar 20 09:38:00: //8166/D5F89820B405/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:38:02 2013: <191>166454:
Wed Mar 20 09:38:02 2013: <191>166455: Set Up Event Sent;
Wed Mar 20 09:38:02 2013: <191>166456: Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:38:02 2013: <191>166457: Called Number=1811032099(TON=Unknown, NPI=Unknown))
Wed Mar 20 09:38:02 2013: <191>166460: .Mar 20 09:38:00: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Wed Mar 20 09:38:02 2013: <191>166461: Try with the demoted called number 1811032099
Wed Mar 20 09:38:02 2013: <191>166465: >>>>CCAPI handed cid 8166 with tag 50 to app "_ManagedAppProcess_Default"
Wed Mar 20 09:38:02 2013: <191>166474: .Mar 20 09:38:00: //8166/D5F89820B405/CCAPI/ccCheckClipClir:
Wed Mar 20 09:38:02 2013: <191>166475: Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:38:02 2013: <191>166476: .Mar 20 09:38:00: //8166/D5F89820B405/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:38:02 2013: <191>166486: ccCallSetupRequest:
Wed Mar 20 09:38:02 2013: <191>166487: cisco-username=
Wed Mar 20 09:38:02 2013: <191>166488: ----- ccCallInfo IE subfields -----
Wed Mar 20 09:38:02 2013: <191>166492: cisco-anipi=0
Wed Mar 20 09:38:02 2013: <191>166494: cisco-anisi=0
Wed Mar 20 09:38:02 2013: <191>166497: cisco-destplan=0
Wed Mar 20 09:38:02 2013: <191>166498: cisco-rdie=FFFFFFFF
Wed Mar 20 09:38:02 2013: <191>166503: cisco-rdnpi=0
Wed Mar 20 09:38:02 2013: <191>166507: hunt_group_timeout =0
Wed Mar 20 09:38:02 2013: <191>166521: .Mar 20 09:38:00: cc_get_feature_vsa count is 4
Wed Mar 20 09:38:02 2013: <191>166522: .Mar 20 09:38:00: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:38:02 2013: <191>166523:
Wed Mar 20 09:38:02 2013: <191>166524: .Mar 20 09:38:00: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203321672,feature_id:8167
Wed Mar 20 09:38:02 2013: <191>166525: .Mar 20 09:38:00: //8167/D5F89820B405/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:38:02 2013: <191>166526: SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Wed Mar 20 09:38:02 2013: <191>166527: .Mar 20 09:38:00: //8167/D5F89820B405/CCAPI/ccCallSetContext:
Wed Mar 20 09:38:02 2013: <191>166528: Context=0x4BA68830
Wed Mar 20 09:38:02 2013: <191>166529: .Mar 20 09:38:00: //8166/D5F89820B405/CCAPI/ccSaveDialpeerTag:
Wed Mar 20 09:38:02 2013: <191>166530: Outgoing Dial-peer=3000
Wed Mar 20 09:38:02 2013: <191>166531: .Mar 20 09:38:01: //8167/D5F89820B405/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:38:02 2013: <191>166532: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:38:02 2013: <191>166533: .Mar 20 09:38:01: //8167/D5F89820B405/CCAPI/cc_api_call_proceeding:
Wed Mar 20 09:38:02 2013: <191>166534: Interface=0x48A4F728, Progress Indication=NULL(0)
Wed Mar 20 09:38:02 2013: <191>166535: .Mar 20 09:38:01: //8167/D5F89820B405/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:38:02 2013: <191>166536: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:38:02 2013: <191>166537: .Mar 20 09:38:01: //8167/D5F89820B405/CCAPI/cc_api_set_delay_xport:
Wed Mar 20 09:38:02 2013: <191>166538: CallInfo(delay xport=TRUE)
Wed Mar 20 09:38:02 2013: <191>166539: .Mar 20 09:38:01: //8167/D5F89820B405/CCAPI/cc_api_call_alert:
Wed Mar 20 09:38:02 2013: <191>166540: Interface=0x48A4F728, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:38:02 2013: <191>166541: .Mar 20 09:38:01: //8167/D5F89820B405/CCAPI/cc_api_call_alert:
Wed Mar 20 09:38:02 2013: <191>166542: Call Entry(Retry Count=0, Responsed=TRUE)
Wed Mar 20 09:38:02 2013: <191>166543: .Mar 20 09:38:01: //8166/D5F89820B405/CCAPI/ccCallAlert:
Wed Mar 20 09:38:02 2013: <191>166544:
Wed Mar 20 09:38:02 2013: <191>166545: Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:38:02 2013: <191>166546: .Mar 20 09:38:01: //8166/D5F89820B405/CCAPI/ccCallAlert:
Wed Mar 20 09:38:02 2013: <191>166547: Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Wed Mar 20 09:38:02 2013: <191>166548: .Mar 20 09:38:01: //8167/D5F89820B405/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:38:02 2013: <191>166549: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:38:02 2013: <191>166550: .Mar 20 09:38:01: //8167/D5F89820B405/CCAPI/cc_api_call_notify:
Wed Mar 20 09:38:02 2013: <191>166551: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8167
Wed Mar 20 09:38:02 2013: <191>166552: .Mar 20 09:38:01: //8167/D5F89820B405/CCAPI/ccIsInfoRingback:
Wed Mar 20 09:38:02 2013: <191>166553: Returning dpRingBack=0
Wed Mar 20 09:38:02 2013: <191>166554: .Mar 20 09:38:01: //8167/D5F89820B405/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:38:02 2013: <191>166555: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:38:02 2013: <191>166556: .Mar 20 09:38:01: //8167/D5F89820B405/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:38:02 2013: <191>166557: CallInfo(ccm detected=TRUE)
Wed Mar 20 09:38:02 2013: <191>166558: .Mar 20 09:38:01: //8166/D5F89820B405/CCAPI/ccCallNotify:
Wed Mar 20 09:38:02 2013: <191>166559: Data Bitmask=0x5, Call Id=8166
Wed Mar 20 09:38:02 2013: <191>166560: .Mar 20 09:38:01: //8167/D5F89820B405/CCAPI/cc_api_call_connected:
Wed Mar 20 09:38:02 2013: <191>166561: Interface=0x48A4F728, Data Bitmask=0x0, Progress Indication=NULL(0),
Wed Mar 20 09:38:02 2013: <191>166562: Connection Handle=0
Wed Mar 20 09:38:02 2013: <191>166563: .Mar 20 09:38:01: //8167/D5F89820B405/CCAPI/cc_api_call_connected:
Wed Mar 20 09:38:02 2013: <191>166564: Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Wed Mar 20 09:38:02 2013: <191>166565: .Mar 20 09:38:01: //8167/D5F89820B405/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:38:02 2013: <191>166566: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:38:02 2013: <191>166567: .Mar 20 09:38:01: //8167/D5F89820B405/CCAPI/cc_api_call_notify:
Wed Mar 20 09:38:02 2013: <191>166568:
Wed Mar 20 09:38:02 2013: <191>166569: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8167
Wed Mar 20 09:38:02 2013: <191>166570: .Mar 20 09:38:01: //8166/D5F89820B405/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:38:02 2013: <191>166571: Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:38:02 2013: <191>166572: Tone Direction=Network, Params=0x0, Call Id=8166
Wed Mar 20 09:38:02 2013: <191>166573: .Mar 20 09:38:01: //8166/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:38:02 2013: <191>166574: (confID=0x4BB021A0, callID1=0x1FE6, callID2=0x1FE7, tag=0x0)
Wed Mar 20 09:38:02 2013: <191>166575: .Mar 20 09:38:01: //8166/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:38:02 2013: <191>166576: (confID=0x4BB021A0, callID1=0x1FE6, gcid=D5F89820-909111E2-B405DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:38:02 2013: <191>166577: .Mar 20 09:38:01: //8167/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:38:02 2013: <191>166578: (confID=0x4BB021A0, callID2=0x1FE7, gcid=D5F89820-909111E2-B405DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:38:02 2013: <191>166579: .Mar 20 09:38:01: //8166/D5F89820B405/CCAPI/ccConferenceCreate:
Wed Mar 20 09:38:02 2013: <191>166580: Conference Id=0x4BB021A0, Call Id1=8166, Call Id2=8167, Tag=0x0
Wed Mar 20 09:38:02 2013: <191>166581: .Mar 20 09:38:01: //8166/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:38:02 2013: <191>166582: Conference Id=0xE60, Source Interface=0x498845E0, Source Call Id=8166,
Wed Mar 20 09:38:02 2013: <191>166583: Destination Call Id=8167, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:38:02 2013: <191>166584: .Mar 20 09:38:01: //8167/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Wed Mar 20 09:38:02 2013: <191>166585:
Wed Mar 20 09:38:02 2013: <191>166586: .Mar 20 09:38:01: cc_api_get_xcode_stream : 4534
Wed Mar 20 09:38:02 2013: <191>166587: .Mar 20 09:38:01: //8167/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:38:02 2013: <191>166588: Conference Id=0xE60, Source Interface=0x48A4F728, Source Call Id=8167,
Wed Mar 20 09:38:02 2013: <191>166589: Destination Call Id=8166, Disposition=0x0, Tag=0x0
Wed Mar 20 09:38:02 2013: <191>166590: .Mar 20 09:38:01: //8166/D5F89820B405/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:38:02 2013: <191>166591: Conference Id=0xE60, Source Interface=0x48A4F728, Source Call Id=8167,
Wed Mar 20 09:38:02 2013: <191>166593: .Mar 20 09:38:01: //8166/D5F89820B405/CCAPI/ccConferenceCreate:
Wed Mar 20 09:38:02 2013: <191>166595: .Mar 20 09:38:01: //8167/D5F89820B405/CCAPI/ccConferenceCreate:
Wed Mar 20 09:38:02 2013: <191>166596: Call Entry(Conference Id=0xE60, Destination Call Id=8166)
Wed Mar 20 09:38:02 2013: <191>166597: .Mar 20 09:38:01: //8166/D5F89820B405/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:38:02 2013: <191>166609: Modem=0x2, Codec Bytes=20, Signal Type=2)
Wed Mar 20 09:38:02 2013: <191>166610: .Mar 20 09:38:01: //8167/D5F89820B405/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:38:02 2013: <191>166611:
Wed Mar 20 09:38:02 2013: <191>166616: Caps(Codec=g729r8(0x4), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:38:02 2013: <191>166617: Modem=ON(0x2), Codec Bytes=20, Signal Type=2, Seq Num Start=3211)
Wed Mar 20 09:38:02 2013: <191>166618: .Mar 20 09:38:01: //8166/D5F89820B405/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:38:02 2013: <191>166631: Call Entry(Context=0x4BA74680)
Wed Mar 20 09:38:03 2013: <191>166636: Call Entry(Connected=TRUE, Responsed=TRUE)
Wed Mar 20 09:38:13 2013: <191>166637: .Mar 20 09:38:12: //8167/D5F89820B405/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:38:13 2013: <191>166638: Interface=0x0, Call Id=8167
Wed Mar 20 09:38:13 2013: <191>166639: .Mar 20 09:38:12: //8167/D5F89820B405/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:38:13 2013: <191>166640: Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:38:13 2013: <191>166641: .Mar 20 09:38:12: //8166/D5F89820B405/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:38:13 2013: <191>166642: Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:38:13 2013: <191>166643: Tone Direction=Network, Params=0x0, Call Id=8166
Wed Mar 20 09:38:13 2013: <191>166644: .Mar 20 09:38:12: //8167/D5F89820B405/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:38:13 2013: <191>166645: Interface=0x48A4F728, Signal Indication=NOT PRESENT(255)
Wed Mar 20 09:38:13 2013: <191>166646: .Mar 20 09:38:12: //8167/D5F89820B405/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:38:13 2013: <191>166647: Interface=0x48A4F728, Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:38:13 2013: <191>166648: .Mar 20 09:38:12: //8166/D5F89820B405/CCAPI/ccCallUserInfo:
Wed Mar 20 09:38:13 2013: <191>166649: Call Id=8166
Wed Mar 20 09:38:13 2013: <191>166650: .Mar 20 09:38:12: //8166/D5F89820B405/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:38:13 2013: <191>166651: Stop Tone On Digit=FALSE, Tone=Ring Back,
Wed Mar 20 09:38:13 2013: <191>166652: Tone Direction=Network, Params=0x0, Call Id=8166
Wed Mar 20 09:38:13 2013: <191>166653: .Mar 20 09:38:12: //8167/D5F89820B405/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:38:13 2013: <191>166654: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:38:13 2013: <191>166655: .Mar 20 09:38:12: //8167/D5F89820B405/CCAPI/cc_api_call_notify:
Wed Mar 20 09:38:13 2013: <191>166656: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8167
Wed Mar 20 09:38:13 2013: <191>166657: .Mar 20 09:38:12: //8167/D5F89820B405/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:38:13 2013: <191>166658: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:38:14 2013: <191>166659: .Mar 20 09:38:12: //8167/D5F89820B405/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:38:14 2013: <191>166660: CallInfo(ccm detected=TRUE)
Wed Mar 20 09:38:14 2013: <191>166661: .Mar 20 09:38:12: //8166/D5F89820B405/CCAPI/ccCallNotify:
Wed Mar 20 09:38:14 2013: <191>166662: Data Bitmask=0x5, Call Id=8166
Wed Mar 20 09:38:16 2013: <191>166663: .Mar 20 09:38:14: //8167/D5F89820B405/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:38:16 2013: <191>166664: Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:38:16 2013: <191>166665: .Mar 20 09:38:14: //8167/D5F89820B405/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:38:16 2013: <191>166666: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:38:16 2013: <191>166667: .Mar 20 09:38:14: //8167/D5F89820B405/CCAPI/cc_api_call_notify:
Wed Mar 20 09:38:16 2013: <191>166668: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8167
Wed Mar 20 09:38:16 2013: <191>166669: .Mar 20 09:38:14: //8166/D5F89820B405/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:38:16 2013: <191>166670: Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:38:16 2013: <191>166671: Tone Direction=Network, Params=0x0, Call Id=8166
Wed Mar 20 09:38:16 2013: <191>166672: .Mar 20 09:38:14: //8167/D5F89820B405/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:38:16 2013: <191>166673: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:38:16 2013: <191>166674: .Mar 20 09:38:14: //8167/D5F89820B405/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:38:16 2013: <191>166675: CallInfo(ccm detected=TRUE)
Wed Mar 20 09:38:16 2013: <191>166676: .Mar 20 09:38:14: //8166/D5F89820B405/CCAPI/ccCallNotify:
Wed Mar 20 09:38:16 2013: <191>166677: Data Bitmask=0x5, Call Id=8166
Wed Mar 20 09:38:16 2013: <191>166678: .Mar 20 09:38:15: //8167/D5F89820B405/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:38:16 2013: <191>166679: Destination Interface=0x498845E0, Destination Call Id=8166, Source Call Id=8167,
Wed Mar 20 09:38:16 2013: <191>166680: Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:38:16 2013: <191>166681: Modem=0x2, Codec Bytes=160, Signal Type=2)
Wed Mar 20 09:38:16 2013: <191>166682: .Mar 20 09:38:15: //8167/D5F89820B405/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:38:16 2013: <191>166683: Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:38:16 2013: <191>166684: Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:38:16 2013: <191>166685: .Mar 20 09:38:15: //8167/D5F89820B405/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:38:16 2013: <191>166686:
Wed Mar 20 09:38:16 2013: <191>166687: Destination Interface=0x498845E0, Destination Call Id=8166, Source Call Id=8167,
Wed Mar 20 09:38:16 2013: <191>166688: Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:38:16 2013: <191>166689: Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=3247)
Wed Mar 20 09:38:16 2013: <191>166690: .Mar 20 09:38:15: //8166/D5F89820B405/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:38:16 2013: <191>166691: Destination Interface=0x48A4F728, Destination Call Id=8167, Source Call Id=8166,
Wed Mar 20 09:38:16 2013: <191>166692: Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:38:16 2013: <191>166693: Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=3247)
Wed Mar 20 09:38:16 2013: <191>166694: .Mar 20 09:38:15: //8166/D5F89820B405/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:38:16 2013: <191>166695: Call Id=8166
Wed Mar 20 09:38:16 2013: <191>166696: .Mar 20 09:38:15: //8166/D5F89820B405/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:38:16 2013: <191>166697:
Wed Mar 20 09:38:17 2013: <191>166698: Call Entry(Context=0x4BA74680)
Wed Mar 20 09:39:06 2013: <191>166699: .Mar 20 09:39:04: //8162/8062BAA34206/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:39:06 2013: <191>166700: Cause Value=16, Interface=0x48A4F728, Call Id=8162
Wed Mar 20 09:39:06 2013: <191>166701: .Mar 20 09:39:04: //8162/8062BAA34206/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:39:06 2013: <191>166702: Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:39:06 2013: <191>166703: .Mar 20 09:39:04: //8162/8062BAA34206/CCAPI/ccConferenceDestroy:
Wed Mar 20 09:39:06 2013: <191>166704: Conference Id=0xE5E, Tag=0x0
Wed Mar 20 09:39:06 2013: <191>166705: .Mar 20 09:39:04: //8162/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:39:06 2013: <191>166706: Conference Id=0xE5E, Source Interface=0x48A4F728, Source Call Id=8162,
Wed Mar 20 09:39:06 2013: <191>166707: Destination Call Id=8163, Disposition=0x0, Tag=0x0
Wed Mar 20 09:39:06 2013: <191>166708: .Mar 20 09:39:04: //8163/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:39:06 2013: <191>166709:
Wed Mar 20 09:39:06 2013: <191>166710: Conference Id=0xE5E, Source Interface=0x4987FF98, Source Call Id=8163,
Wed Mar 20 09:39:06 2013: <191>166711: Destination Call Id=8162, Disposition=0x0, Tag=0x0
Wed Mar 20 09:39:06 2013: <191>166712: .Mar 20 09:39:04: //8162/8062BAA34206/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:39:06 2013: <191>166713: Conference Id=0xE5E, Source Interface=0x4987FF98, Source Call Id=8163,
Wed Mar 20 09:39:06 2013: <191>166714: Destination Call Id=8162, Disposition=0x0, Tag=0x0
Wed Mar 20 09:39:06 2013: <191>166715: .Mar 20 09:39:04: //8162/8062BAA34206/CCAPI/ccCallDisconnect:
Wed Mar 20 09:39:06 2013: <191>166716: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:39:06 2013: <191>166717: .Mar 20 09:39:04: //8162/8062BAA34206/CCAPI/ccCallDisconnect:
Wed Mar 20 09:39:06 2013: <191>166718: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:39:06 2013: <191>166719: .Mar 20 09:39:04: //8162/8062BAA34206/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:39:06 2013: <191>166720:
Wed Mar 20 09:39:06 2013: <191>166721: Transfer Number Is Null
Wed Mar 20 09:39:06 2013: <191>166722: .Mar 20 09:39:04: //8163/8062BAA34206/CCAPI/ccCallDisconnect:
Wed Mar 20 09:39:06 2013: <191>166723: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Wed Mar 20 09:39:06 2013: <191>166724: .Mar 20 09:39:04: //8163/8062BAA34206/CCAPI/ccCallDisconnect:
Wed Mar 20 09:39:06 2013: <191>166725: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:39:06 2013: <191>166726: .Mar 20 09:39:04: //8163/8062BAA34206/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:39:06 2013: <191>166727: Transfer Number Is Null
Wed Mar 20 09:39:06 2013: <191>166728: .Mar 20 09:39:04: //8162/8062BAA34206/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:39:06 2013: <191>166729: Transfer Number Is Null
Wed Mar 20 09:39:06 2013: <191>166730: .Mar 20 09:39:04: //8162/8062BAA34206/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:39:06 2013: <191>166731:
Wed Mar 20 09:39:06 2013: <191>166732: Disposition=0, Interface=0x48A4F728, Tag=0x0, Call Id=8162,
Wed Mar 20 09:39:06 2013: <191>166733: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:39:06 2013: <191>166734: .Mar 20 09:39:04: //8162/8062BAA34206/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:39:06 2013: <191>166735: Call Disconnect Event Sent
Wed Mar 20 09:39:06 2013: <191>166736: .Mar 20 09:39:04: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:39:06 2013: <191>166737:
Wed Mar 20 09:39:06 2013: <191>166738: .Mar 20 09:39:04: :cc_free_feature_vsa freeing 47B93DE0
Wed Mar 20 09:39:06 2013: <191>166739: .Mar 20 09:39:04: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:39:06 2013: <191>166740:
Wed Mar 20 09:39:06 2013: <191>166741: .Mar 20 09:39:04: vsacount in free is 3
Wed Mar 20 09:39:06 2013: <191>166742: .Mar 20 09:39:04: //8163/8062BAA34206/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:39:06 2013: <191>166743: Disposition=0, Interface=0x4987FF98, Tag=0x0, Call Id=8163,
Wed Mar 20 09:39:06 2013: <191>166744: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:39:07 2013: <191>166745: .Mar 20 09:39:04: //8163/8062BAA34206/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:39:07 2013: <191>166746: Call Disconnect Event Sent
Wed Mar 20 09:39:07 2013: <191>166747: .Mar 20 09:39:04: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:39:07 2013: <191>166748:
Wed Mar 20 09:39:07 2013: <191>166749: .Mar 20 09:39:04: :cc_free_feature_vsa freeing 47B93D00
Wed Mar 20 09:39:07 2013: <191>166750: .Mar 20 09:39:04: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:39:07 2013: <191>166751:
Wed Mar 20 09:39:07 2013: <191>166752: .Mar 20 09:39:04: vsacount in free is 2
Wed Mar 20 09:40:02 2013: <191>166753: .Mar 20 09:40:01: //8166/D5F89820B405/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:40:02 2013: <191>166754: Cause Value=86, Interface=0x498845E0, Call Id=8166
Wed Mar 20 09:40:02 2013: <191>166755: .Mar 20 09:40:01: //8166/D5F89820B405/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:40:02 2013: <191>166756: Call Entry(Responsed=TRUE, Cause Value=86, Retry Count=0)
Wed Mar 20 09:40:02 2013: <191>166757: .Mar 20 09:40:01: //8166/D5F89820B405/CCAPI/ccConferenceDestroy:
Wed Mar 20 09:40:02 2013: <191>166758: Conference Id=0xE60, Tag=0x0
Wed Mar 20 09:40:02 2013: <191>166759: .Mar 20 09:40:01: //8166/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:40:02 2013: <191>166760: Conference Id=0xE60, Source Interface=0x498845E0, Source Call Id=8166,
Wed Mar 20 09:40:02 2013: <191>166761: Destination Call Id=8167, Disposition=0x0, Tag=0x0
Wed Mar 20 09:40:02 2013: <191>166762: .Mar 20 09:40:01: //8167/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:40:02 2013: <191>166763:
Wed Mar 20 09:40:02 2013: <191>166764: Conference Id=0xE60, Source Interface=0x48A4F728, Source Call Id=8167,
Wed Mar 20 09:40:02 2013: <191>166765: Destination Call Id=8166, Disposition=0x0, Tag=0x0
Wed Mar 20 09:40:02 2013: <191>166766: .Mar 20 09:40:01: //8166/D5F89820B405/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:40:02 2013: <191>166767: Conference Id=0xE60, Source Interface=0x48A4F728, Source Call Id=8167,
Wed Mar 20 09:40:02 2013: <191>166768: Destination Call Id=8166, Disposition=0x0, Tag=0x0
Wed Mar 20 09:40:02 2013: <191>166769: .Mar 20 09:40:01: //8166/D5F89820B405/CCAPI/ccCallDisconnect:
Wed Mar 20 09:40:02 2013: <191>166770: Cause Value=86, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=86)
Wed Mar 20 09:40:02 2013: <191>166771: .Mar 20 09:40:01: //8166/D5F89820B405/CCAPI/ccCallDisconnect:
Wed Mar 20 09:40:02 2013: <191>166772: Cause Value=86, Call Entry(Responsed=TRUE, Cause Value=86)
Wed Mar 20 09:40:02 2013: <191>166773: .Mar 20 09:40:01: //8166/D5F89820B405/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:40:02 2013: <191>166774:
Wed Mar 20 09:40:02 2013: <191>166775: Transfer Number Is Null
Wed Mar 20 09:40:02 2013: <191>166776: .Mar 20 09:40:01: //8167/D5F89820B405/CCAPI/ccCallDisconnect:
Wed Mar 20 09:40:02 2013: <191>166777: Cause Value=86, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Wed Mar 20 09:40:02 2013: <191>166778: .Mar 20 09:40:01: //8167/D5F89820B405/CCAPI/ccCallDisconnect:
Wed Mar 20 09:40:02 2013: <191>166779: Cause Value=86, Call Entry(Responsed=TRUE, Cause Value=86)
Wed Mar 20 09:40:02 2013: <191>166780: .Mar 20 09:40:01: //8167/D5F89820B405/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:40:02 2013: <191>166781: Transfer Number Is Null
Wed Mar 20 09:40:02 2013: <191>166782: .Mar 20 09:40:01: //8167/D5F89820B405/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:40:02 2013: <191>166783: Transfer Number Is Null
Wed Mar 20 09:40:02 2013: <191>166784: .Mar 20 09:40:01: //8167/D5F89820B405/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:40:02 2013: <191>166785:
Wed Mar 20 09:40:02 2013: <191>166786: Disposition=0, Interface=0x48A4F728, Tag=0x0, Call Id=8167,
Wed Mar 20 09:40:02 2013: <191>166787: Call Entry(Disconnect Cause=86, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:40:02 2013: <191>166788: .Mar 20 09:40:01: //8167/D5F89820B405/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:40:02 2013: <191>166789: Call Disconnect Event Sent
Wed Mar 20 09:40:02 2013: <191>166790: .Mar 20 09:40:01: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:40:02 2013: <191>166791:
Wed Mar 20 09:40:02 2013: <191>166792: .Mar 20 09:40:01: :cc_free_feature_vsa freeing 47B93B40
Wed Mar 20 09:40:02 2013: <191>166793: .Mar 20 09:40:01: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:40:02 2013: <191>166794:
Wed Mar 20 09:40:02 2013: <191>166795: .Mar 20 09:40:01: vsacount in free is 1
Wed Mar 20 09:40:02 2013: <191>166796: .Mar 20 09:40:01: //8166/D5F89820B405/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:40:02 2013: <191>166797: Disposition=0, Interface=0x498845E0, Tag=0x0, Call Id=8166,
Wed Mar 20 09:40:02 2013: <191>166798: Call Entry(Disconnect Cause=86, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:40:03 2013: <191>166799: .Mar 20 09:40:01: //8166/D5F89820B405/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:40:03 2013: <191>166800: Call Disconnect Event Sent
Wed Mar 20 09:40:03 2013: <191>166801: .Mar 20 09:40:01: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:40:03 2013: <191>166802:
Wed Mar 20 09:40:03 2013: <191>166803: .Mar 20 09:40:01: :cc_free_feature_vsa freeing 47B93C20
Wed Mar 20 09:40:03 2013: <191>166804: .Mar 20 09:40:01: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:40:03 2013: <191>166805:
Wed Mar 20 09:40:03 2013: <191>166806: .Mar 20 09:40:01: vsacount in free is 0
Wed Mar 20 09:43:03 2013: <191>166807: .Mar 20 09:43:01: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode:
Wed Mar 20 09:43:03 2013: <191>166808: ccAppShutdownMode: remove it from the queue
Wed Mar 20 09:47:32 2013: <191>166809: .Mar 20 09:47:31: //-1/29DFEE4BB40A/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:47:32 2013: <191>166810: cc_api_call_setup_ind_common:
Wed Mar 20 09:47:32 2013: <191>166811: cisco-username=
Wed Mar 20 09:47:32 2013: <191>166812: ----- ccCallInfo IE subfields -----
Wed Mar 20 09:47:32 2013: <191>166813: cisco-ani=
Wed Mar 20 09:47:32 2013: <191>166814: cisco-anitype=0
Wed Mar 20 09:47:32 2013: <191>166815: cisco-aniplan=0
Wed Mar 20 09:47:32 2013: <191>166816: cisco-anipi=0
Wed Mar 20 09:47:32 2013: <191>166817: cisco-anisi=0
Wed Mar 20 09:47:32 2013: <191>166818: dest=1811032099
Wed Mar 20 09:47:32 2013: <191>166819: cisco-desttype=0
Wed Mar 20 09:47:32 2013: <191>166820: cisco-destplan=0
Wed Mar 20 09:47:32 2013: <191>166821: cisco-rdie=FFFFFFFF
Wed Mar 20 09:47:32 2013: <191>166822: cisco-rdn=
Wed Mar 20 09:47:32 2013: <191>166823: cisco-lastrdn=
Wed Mar 20 09:47:32 2013: <191>166824: cisco-rdntype=0
Wed Mar 20 09:47:32 2013: <191>166825: cisco-rdnplan=0
Wed Mar 20 09:47:32 2013: <191>166826: cisco-rdnpi=0
Wed Mar 20 09:47:32 2013: <191>166827: cisco-rdnsi=0
Wed Mar 20 09:47:32 2013: <191>166828: cisco-redirectreason=0 fwd_final_type =0
Wed Mar 20 09:47:32 2013: <191>166829: final_redirectNumber =
Wed Mar 20 09:47:32 2013: <191>166830: hunt_group_timeout =0
Wed Mar 20 09:47:32 2013: <191>166831:
Wed Mar 20 09:47:32 2013: <191>166832: .Mar 20 09:47:31: //-1/29DFEE4BB40A/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:47:32 2013: <191>166833:
Wed Mar 20 09:47:32 2013: <191>166834: Interface=0x498845E0, Call Info(
Wed Mar 20 09:47:32 2013: <191>166835: Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:47:32 2013: <191>166836: Called Number=1811032099(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:47:32 2013: <191>166837: Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
Wed Mar 20 09:47:32 2013: <191>166838: Incoming Dial-peer=50, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
Wed Mar 20 09:47:32 2013: <191>166839: Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:47:32 2013: <191>166840: .Mar 20 09:47:31: //-1/29DFEE4BB40A/CCAPI/ccCheckClipClir:
Wed Mar 20 09:47:32 2013: <191>166841: In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:47:32 2013: <191>166842: .Mar 20 09:47:31: //-1/29DFEE4BB40A/CCAPI/ccCheckClipClir:
Wed Mar 20 09:47:32 2013: <191>166843: Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:47:32 2013: <191>166844: .Mar 20 09:47:31: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:47:32 2013: <191>166845:
Wed Mar 20 09:47:32 2013: <191>166846: .Mar 20 09:47:31: :cc_get_feature_vsa malloc success
Wed Mar 20 09:47:32 2013: <191>166847: .Mar 20 09:47:31: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:47:32 2013: <191>166848:
Wed Mar 20 09:47:32 2013: <191>166849: .Mar 20 09:47:31: cc_get_feature_vsa count is 1
Wed Mar 20 09:47:32 2013: <191>166850: .Mar 20 09:47:31: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:47:32 2013: <191>166851:
Wed Mar 20 09:47:32 2013: <191>166852: .Mar 20 09:47:31: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203248360,feature_id:8168
Wed Mar 20 09:47:32 2013: <191>166853: .Mar 20 09:47:31: //8168/29DFEE4BB40A/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:47:32 2013: <191>166854:
Wed Mar 20 09:47:32 2013: <191>166855: Set Up Event Sent;
Wed Mar 20 09:47:32 2013: <191>166857: Called Number=1811032099(TON=Unknown, NPI=Unknown))
Wed Mar 20 09:47:32 2013: <191>166858: .Mar 20 09:47:31: //8168/29DFEE4BB40A/CCAPI/cc_process_call_setup_ind:
Wed Mar 20 09:47:32 2013: <191>166861: Try with the demoted called number 1811032099
Wed Mar 20 09:47:32 2013: <191>166862: .Mar 20 09:47:31: //8168/29DFEE4BB40A/CCAPI/ccCallSetContext:
Wed Mar 20 09:47:32 2013: <191>166867:
Wed Mar 20 09:47:32 2013: <191>166868: Progress Indication=NULL(0)
Wed Mar 20 09:47:32 2013: <191>166873: In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:47:32 2013: <191>166874: .Mar 20 09:47:31: //8168/29DFEE4BB40A/CCAPI/ccCheckClipClir:
Wed Mar 20 09:47:32 2013: <191>166875: Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:47:32 2013: <191>166876: .Mar 20 09:47:31: //8168/29DFEE4BB40A/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:47:32 2013: <191>166884: Guid=29DFEE4B-9093-11E2-B40A-DE08FC69A21F, Outgoing Dial-peer=3000
Wed Mar 20 09:47:32 2013: <191>166886: ccCallSetupRequest:
Wed Mar 20 09:47:32 2013: <191>166888: ----- ccCallInfo IE subfields -----
Wed Mar 20 09:47:32 2013: <191>166889: cisco-ani=
Wed Mar 20 09:47:32 2013: <191>166890: cisco-anitype=0
Wed Mar 20 09:47:32 2013: <191>166891: cisco-aniplan=0
Wed Mar 20 09:47:32 2013: <191>166892: cisco-anipi=0
Wed Mar 20 09:47:32 2013: <191>166894: cisco-anisi=0
Wed Mar 20 09:47:32 2013: <191>166899: cisco-rdn=
Wed Mar 20 09:47:32 2013: <191>166903: cisco-rdnpi=0
Wed Mar 20 09:47:32 2013: <191>166904: cisco-rdnsi=0
Wed Mar 20 09:47:32 2013: <191>166908:
Wed Mar 20 09:47:32 2013: <191>166921: .Mar 20 09:47:31: cc_get_feature_vsa count is 2
Wed Mar 20 09:47:32 2013: <191>166922: .Mar 20 09:47:31: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:47:32 2013: <191>166923:
Wed Mar 20 09:47:32 2013: <191>166924: .Mar 20 09:47:31: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203248136,feature_id:8169
Wed Mar 20 09:47:32 2013: <191>166925: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:47:32 2013: <191>166926: SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Wed Mar 20 09:47:32 2013: <191>166927: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/ccCallSetContext:
Wed Mar 20 09:47:32 2013: <191>166928: Context=0x4BA7CBB8
Wed Mar 20 09:47:32 2013: <191>166929: .Mar 20 09:47:31: //8168/29DFEE4BB40A/CCAPI/ccSaveDialpeerTag:
Wed Mar 20 09:47:32 2013: <191>166930: Outgoing Dial-peer=3000
Wed Mar 20 09:47:32 2013: <191>166931: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:47:32 2013: <191>166932: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:47:32 2013: <191>166933: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/cc_api_call_proceeding:
Wed Mar 20 09:47:32 2013: <191>166934: Interface=0x48A4F728, Progress Indication=NULL(0)
Wed Mar 20 09:47:32 2013: <191>166935: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:47:32 2013: <191>166936: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:47:32 2013: <191>166937: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/cc_api_set_delay_xport:
Wed Mar 20 09:47:32 2013: <191>166938: CallInfo(delay xport=TRUE)
Wed Mar 20 09:47:32 2013: <191>166939: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/cc_api_call_alert:
Wed Mar 20 09:47:32 2013: <191>166940: Interface=0x48A4F728, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:47:32 2013: <191>166941: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/cc_api_call_alert:
Wed Mar 20 09:47:32 2013: <191>166942: Call Entry(Retry Count=0, Responsed=TRUE)
Wed Mar 20 09:47:32 2013: <191>166943: .Mar 20 09:47:31: //8168/29DFEE4BB40A/CCAPI/ccCallAlert:
Wed Mar 20 09:47:32 2013: <191>166944:
Wed Mar 20 09:47:32 2013: <191>166945: Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:47:32 2013: <191>166946: .Mar 20 09:47:31: //8168/29DFEE4BB40A/CCAPI/ccCallAlert:
Wed Mar 20 09:47:32 2013: <191>166947: Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Wed Mar 20 09:47:32 2013: <191>166948: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:47:32 2013: <191>166949: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:47:32 2013: <191>166950: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/cc_api_call_notify:
Wed Mar 20 09:47:32 2013: <191>166951: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8169
Wed Mar 20 09:47:32 2013: <191>166952: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/ccIsInfoRingback:
Wed Mar 20 09:47:32 2013: <191>166953: Returning dpRingBack=0
Wed Mar 20 09:47:32 2013: <191>166954: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:47:32 2013: <191>166955: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:47:32 2013: <191>166956: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:47:32 2013: <191>166957: CallInfo(ccm detected=TRUE)
Wed Mar 20 09:47:32 2013: <191>166958: .Mar 20 09:47:31: //8168/29DFEE4BB40A/CCAPI/ccCallNotify:
Wed Mar 20 09:47:32 2013: <191>166959: Data Bitmask=0x5, Call Id=8168
Wed Mar 20 09:47:32 2013: <191>166960: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/cc_api_call_connected:
Wed Mar 20 09:47:32 2013: <191>166961: Interface=0x48A4F728, Data Bitmask=0x0, Progress Indication=NULL(0),
Wed Mar 20 09:47:32 2013: <191>166962: Connection Handle=0
Wed Mar 20 09:47:32 2013: <191>166963: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/cc_api_call_connected:
Wed Mar 20 09:47:32 2013: <191>166964: Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Wed Mar 20 09:47:32 2013: <191>166965: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:47:32 2013: <191>166966: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:47:32 2013: <191>166967: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/cc_api_call_notify:
Wed Mar 20 09:47:32 2013: <191>166968:
Wed Mar 20 09:47:32 2013: <191>166969: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8169
Wed Mar 20 09:47:32 2013: <191>166970: .Mar 20 09:47:31: //8168/29DFEE4BB40A/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:47:32 2013: <191>166971: Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:47:32 2013: <191>166972: Tone Direction=Network, Params=0x0, Call Id=8168
Wed Mar 20 09:47:32 2013: <191>166973: .Mar 20 09:47:31: //8168/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:47:32 2013: <191>166974: (confID=0x4BB01D20, callID1=0x1FE8, callID2=0x1FE9, tag=0x0)
Wed Mar 20 09:47:32 2013: <191>166975: .Mar 20 09:47:31: //8168/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:47:32 2013: <191>166976: (confID=0x4BB01D20, callID1=0x1FE8, gcid=29DFEE4B-909311E2-B40ADE08-FC69A21F, tag=0x0)
Wed Mar 20 09:47:32 2013: <191>166977: .Mar 20 09:47:31: //8169/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:47:32 2013: <191>166978: (confID=0x4BB01D20, callID2=0x1FE9, gcid=29DFEE4B-909311E2-B40ADE08-FC69A21F, tag=0x0)
Wed Mar 20 09:47:32 2013: <191>166979: .Mar 20 09:47:31: //8168/29DFEE4BB40A/CCAPI/ccConferenceCreate:
Wed Mar 20 09:47:32 2013: <191>166980: Conference Id=0x4BB01D20, Call Id1=8168, Call Id2=8169, Tag=0x0
Wed Mar 20 09:47:32 2013: <191>166981: .Mar 20 09:47:31: //8168/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:47:32 2013: <191>166982: Conference Id=0xE61, Source Interface=0x498845E0, Source Call Id=8168,
Wed Mar 20 09:47:32 2013: <191>166983: Destination Call Id=8169, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:47:32 2013: <191>166984: .Mar 20 09:47:31: //8169/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Wed Mar 20 09:47:32 2013: <191>166985:
Wed Mar 20 09:47:32 2013: <191>166986: .Mar 20 09:47:31: cc_api_get_xcode_stream : 4534
Wed Mar 20 09:47:32 2013: <191>166987: .Mar 20 09:47:31: //8169/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:47:32 2013: <191>166988: Conference Id=0xE61, Source Interface=0x48A4F728, Source Call Id=8169,
Wed Mar 20 09:47:32 2013: <191>166989: Destination Call Id=8168, Disposition=0x0, Tag=0x0
Wed Mar 20 09:47:32 2013: <191>166990: .Mar 20 09:47:31: //8168/29DFEE4BB40A/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:47:32 2013: <191>166991: Conference Id=0xE61, Source Interface=0x48A4F728, Source Call Id=8169,
Wed Mar 20 09:47:32 2013: <191>166992: Destination Call Id=8168, Disposition=0x0, Tag=0x0
Wed Mar 20 09:47:32 2013: <191>166993: .Mar 20 09:47:31: //8168/29DFEE4BB40A/CCAPI/ccConferenceCreate:
Wed Mar 20 09:47:32 2013: <191>166995: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/ccConferenceCreate:
Wed Mar 20 09:47:32 2013: <191>166997: .Mar 20 09:47:31: //8168/29DFEE4BB40A/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:47:32 2013: <191>167006: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:47:32 2013: <191>167013: Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:47:32 2013: <191>167014: .Mar 20 09:47:31: //8169/29DFEE4BB40A/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:47:32 2013: <191>167015: Destination Interface=0x498845E0, Destination Call Id=8168, Source Call Id=8169,
Wed Mar 20 09:47:32 2013: <191>167018: .Mar 20 09:47:31: //8168/29DFEE4BB40A/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:47:32 2013: <191>167019: Destination Interface=0x48A4F728, Destination Call Id=8169, Source Call Id=8168,
Wed Mar 20 09:47:32 2013: <191>167032: .Mar 20 09:47:31: //8168/29DFEE4BB40A/CCAPI/ccCallConnect:
Wed Mar 20 09:47:32 2013: <191>167033: Progress Indication=NULL(0), Data Bitmask=0x0
Wed Mar 20 09:47:32 2013: <191>167034: .Mar 20 09:47:31: //8168/29DFEE4BB40A/CCAPI/ccCallConnect:
Wed Mar 20 09:47:33 2013: <191>167036: Call Entry(Connected=TRUE, Responsed=TRUE)
Wed Mar 20 09:47:43 2013: <191>167037: .Mar 20 09:47:42: //8169/29DFEE4BB40A/CCAPI/cc_api_call_media_reset_ind:
Wed Mar 20 09:47:43 2013: <191>167038: Interface=0x0, Call Id=8169
Wed Mar 20 09:47:43 2013: <191>167039: .Mar 20 09:47:42: //8169/29DFEE4BB40A/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:47:43 2013: <191>167040: Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:47:43 2013: <191>167041: .Mar 20 09:47:42: //8168/29DFEE4BB40A/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:47:43 2013: <191>167042: Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:47:43 2013: <191>167043: Tone Direction=Network, Params=0x0, Call Id=8168
Wed Mar 20 09:47:43 2013: <191>167044: .Mar 20 09:47:42: //8169/29DFEE4BB40A/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:47:43 2013: <191>167045: Interface=0x48A4F728, Signal Indication=NOT PRESENT(255)
Wed Mar 20 09:47:43 2013: <191>167046: .Mar 20 09:47:42: //8169/29DFEE4BB40A/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:47:43 2013: <191>167047: Interface=0x48A4F728, Signal Indication=SIGNAL RINGBACK(1)
Wed Mar 20 09:47:43 2013: <191>167048: .Mar 20 09:47:42: //8168/29DFEE4BB40A/CCAPI/ccCallUserInfo:
Wed Mar 20 09:47:43 2013: <191>167049: Call Id=8168
Wed Mar 20 09:47:43 2013: <191>167050: .Mar 20 09:47:42: //8168/29DFEE4BB40A/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:47:43 2013: <191>167051: Stop Tone On Digit=FALSE, Tone=Ring Back,
Wed Mar 20 09:47:43 2013: <191>167052: Tone Direction=Network, Params=0x0, Call Id=8168
Wed Mar 20 09:47:43 2013: <191>167053: .Mar 20 09:47:42: //8169/29DFEE4BB40A/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:47:43 2013: <191>167054: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:47:43 2013: <191>167055: .Mar 20 09:47:42: //8169/29DFEE4BB40A/CCAPI/cc_api_call_notify:
Wed Mar 20 09:47:43 2013: <191>167056: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8169
Wed Mar 20 09:47:43 2013: <191>167057: .Mar 20 09:47:42: //8169/29DFEE4BB40A/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:47:43 2013: <191>167058: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:47:44 2013: <191>167059: .Mar 20 09:47:42: //8169/29DFEE4BB40A/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:47:44 2013: <191>167060: CallInfo(ccm detected=TRUE)
Wed Mar 20 09:47:44 2013: <191>167061: .Mar 20 09:47:42: //8168/29DFEE4BB40A/CCAPI/ccCallNotify:
Wed Mar 20 09:47:44 2013: <191>167062: Data Bitmask=0x5, Call Id=8168
Wed Mar 20 09:47:46 2013: <191>167063: .Mar 20 09:47:45: //8169/29DFEE4BB40A/CCAPI/cc_api_call_userinfo:
Wed Mar 20 09:47:46 2013: <191>167064: Interface=0x48A4F728, Signal Indication=TONES OFF(63)
Wed Mar 20 09:47:46 2013: <191>167065: .Mar 20 09:47:45: //8168/29DFEE4BB40A/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:47:46 2013: <191>167066: Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:47:46 2013: <191>167067: Tone Direction=Network, Params=0x0, Call Id=8168
Wed Mar 20 09:47:46 2013: <191>167068: .Mar 20 09:47:45: //8169/29DFEE4BB40A/CCAPI/cc_api_set_called_ccm_detected:
Wed Mar 20 09:47:46 2013: <191>167069: CallInfo(called ccm detected=TRUE ccmVersion 3)
Wed Mar 20 09:47:46 2013: <191>167070: .Mar 20 09:47:45: //8169/29DFEE4BB40A/CCAPI/cc_api_call_notify:
Wed Mar 20 09:47:46 2013: <191>167071: Data Bitmask=0x5, Interface=0x48A4F728, Call Id=8169
Wed Mar 20 09:47:46 2013: <191>167072: .Mar 20 09:47:45: //8169/29DFEE4BB40A/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Wed Mar 20 09:47:46 2013: <191>167073: CallInfo(ssCTreRoutingNotSupported=FALSE)
Wed Mar 20 09:47:46 2013: <191>167074: .Mar 20 09:47:45: //8169/29DFEE4BB40A/CCAPI/cc_api_get_ccm_detected:
Wed Mar 20 09:47:46 2013: <191>167075: CallInfo(ccm detected=TRUE)
Wed Mar 20 09:47:46 2013: <191>167076: .Mar 20 09:47:45: //8168/29DFEE4BB40A/CCAPI/ccCallNotify:
Wed Mar 20 09:47:46 2013: <191>167077: Data Bitmask=0x5, Call Id=8168
Wed Mar 20 09:47:46 2013: <191>167078: .Mar 20 09:47:45: //8169/29DFEE4BB40A/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:47:46 2013: <191>167079: Destination Interface=0x498845E0, Destination Call Id=8168, Source Call Id=8169,
Wed Mar 20 09:47:46 2013: <191>167080: Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:47:46 2013: <191>167081: Modem=0x2, Codec Bytes=160, Signal Type=2)
Wed Mar 20 09:47:46 2013: <191>167082: .Mar 20 09:47:45: //8169/29DFEE4BB40A/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:47:46 2013: <191>167083: Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:47:46 2013: <191>167084: Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:47:46 2013: <191>167085: .Mar 20 09:47:45: //8169/29DFEE4BB40A/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:47:46 2013: <191>167086:
Wed Mar 20 09:47:46 2013: <191>167087: Destination Interface=0x498845E0, Destination Call Id=8168, Source Call Id=8169,
Wed Mar 20 09:47:46 2013: <191>167088: Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:47:46 2013: <191>167089: Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=6796)
Wed Mar 20 09:47:46 2013: <191>167090: .Mar 20 09:47:45: //8168/29DFEE4BB40A/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:47:46 2013: <191>167091: Destination Interface=0x48A4F728, Destination Call Id=8169, Source Call Id=8168,
Wed Mar 20 09:47:46 2013: <191>167092: Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:47:46 2013: <191>167093: Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=6796)
Wed Mar 20 09:47:46 2013: <191>167094: .Mar 20 09:47:45: //8168/29DFEE4BB40A/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:47:46 2013: <191>167095: Call Id=8168
Wed Mar 20 09:47:46 2013: <191>167096: .Mar 20 09:47:45: //8168/29DFEE4BB40A/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:47:46 2013: <191>167097:
Wed Mar 20 09:47:47 2013: <191>167098: Call Entry(Context=0x4BA6AE40)
Wed Mar 20 09:49:53 2013: <191>167099: .Mar 20 09:49:52: //8169/29DFEE4BB40A/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:49:53 2013: <191>167100: Cause Value=16, Interface=0x48A4F728, Call Id=8169
Wed Mar 20 09:49:53 2013: <191>167101: .Mar 20 09:49:52: //8169/29DFEE4BB40A/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:49:53 2013: <191>167102: Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:49:53 2013: <191>167103: .Mar 20 09:49:52: //8168/29DFEE4BB40A/CCAPI/ccConferenceDestroy:
Wed Mar 20 09:49:53 2013: <191>167104: Conference Id=0xE61, Tag=0x0
Wed Mar 20 09:49:53 2013: <191>167105: .Mar 20 09:49:52: //8168/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:49:53 2013: <191>167106: Conference Id=0xE61, Source Interface=0x498845E0, Source Call Id=8168,
Wed Mar 20 09:49:53 2013: <191>167107: Destination Call Id=8169, Disposition=0x0, Tag=0x0
Wed Mar 20 09:49:53 2013: <191>167108: .Mar 20 09:49:52: //8169/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:49:53 2013: <191>167109:
Wed Mar 20 09:49:53 2013: <191>167110: Conference Id=0xE61, Source Interface=0x48A4F728, Source Call Id=8169,
Wed Mar 20 09:49:53 2013: <191>167111: Destination Call Id=8168, Disposition=0x0, Tag=0x0
Wed Mar 20 09:49:53 2013: <191>167112: .Mar 20 09:49:52: //8168/29DFEE4BB40A/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:49:53 2013: <191>167113: Conference Id=0xE61, Source Interface=0x48A4F728, Source Call Id=8169,
Wed Mar 20 09:49:53 2013: <191>167114: Destination Call Id=8168, Disposition=0x0, Tag=0x0
Wed Mar 20 09:49:53 2013: <191>167115: .Mar 20 09:49:52: //8168/29DFEE4BB40A/CCAPI/ccCallDisconnect:
Wed Mar 20 09:49:53 2013: <191>167116: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Wed Mar 20 09:49:53 2013: <191>167117: .Mar 20 09:49:52: //8168/29DFEE4BB40A/CCAPI/ccCallDisconnect:
Wed Mar 20 09:49:53 2013: <191>167118: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:49:53 2013: <191>167119: .Mar 20 09:49:52: //8168/29DFEE4BB40A/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:49:53 2013: <191>167120:
Wed Mar 20 09:49:53 2013: <191>167121: Transfer Number Is Null
Wed Mar 20 09:49:53 2013: <191>167122: .Mar 20 09:49:52: //8169/29DFEE4BB40A/CCAPI/ccCallDisconnect:
Wed Mar 20 09:49:53 2013: <191>167123: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:49:53 2013: <191>167124: .Mar 20 09:49:52: //8169/29DFEE4BB40A/CCAPI/ccCallDisconnect:
Wed Mar 20 09:49:53 2013: <191>167125: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:49:53 2013: <191>167126: .Mar 20 09:49:52: //8169/29DFEE4BB40A/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:49:53 2013: <191>167127: Transfer Number Is Null
Wed Mar 20 09:49:53 2013: <191>167128: .Mar 20 09:49:52: //8169/29DFEE4BB40A/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:49:53 2013: <191>167129: Transfer Number Is Null
Wed Mar 20 09:49:53 2013: <191>167130: .Mar 20 09:49:52: //8169/29DFEE4BB40A/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:49:53 2013: <191>167131:
Wed Mar 20 09:49:53 2013: <191>167132: Disposition=0, Interface=0x48A4F728, Tag=0x0, Call Id=8169,
Wed Mar 20 09:49:53 2013: <191>167133: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:49:53 2013: <191>167134: .Mar 20 09:49:52: //8169/29DFEE4BB40A/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:49:53 2013: <191>167135: Call Disconnect Event Sent
Wed Mar 20 09:49:53 2013: <191>167136: .Mar 20 09:49:52: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:49:53 2013: <191>167137:
Wed Mar 20 09:49:53 2013: <191>167138: .Mar 20 09:49:52: :cc_free_feature_vsa freeing 47B81C00
Wed Mar 20 09:49:53 2013: <191>167139: .Mar 20 09:49:52: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:49:53 2013: <191>167140:
Wed Mar 20 09:49:53 2013: <191>167141: .Mar 20 09:49:52: vsacount in free is 1
Wed Mar 20 09:49:53 2013: <191>167142: .Mar 20 09:49:52: //8168/29DFEE4BB40A/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:49:53 2013: <191>167143: Disposition=0, Interface=0x498845E0, Tag=0x0, Call Id=8168,
Wed Mar 20 09:49:53 2013: <191>167144: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:49:54 2013: <191>167145: .Mar 20 09:49:52: //8168/29DFEE4BB40A/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:49:54 2013: <191>167146: Call Disconnect Event Sent
Wed Mar 20 09:49:54 2013: <191>167147: .Mar 20 09:49:52: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:49:54 2013: <191>167148:
Wed Mar 20 09:49:54 2013: <191>167149: .Mar 20 09:49:52: :cc_free_feature_vsa freeing 47B81CE0
Wed Mar 20 09:49:54 2013: <191>167150: .Mar 20 09:49:52: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:49:54 2013: <191>167151:
Wed Mar 20 09:49:54 2013: <191>167152: .Mar 20 09:49:52: vsacount in free is 0
Wed Mar 20 09:51:52 2013: <190>167153: .Mar 20 09:51:50: %IPPHONE-6-REGISTER_NEW: ephone-5:SEP002699441E44 IP:10.229.64.32 Socket:5 DeviceType:Phone has registered.
Wed Mar 20 09:52:54 2013: <191>167154: .Mar 20 09:52:52: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode:
Wed Mar 20 09:52:54 2013: <191>167155: ccAppShutdownMode: remove it from the queue
Wed Mar 20 09:53:41 2013: <191>167156: .Mar 20 09:53:40: //-1/05FF2D55B40F/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:53:41 2013: <191>167157: cc_api_call_setup_ind_common:
Wed Mar 20 09:53:41 2013: <191>167159: ----- ccCallInfo IE subfields -----
Wed Mar 20 09:53:41 2013: <191>167158: cisco-username=
Wed Mar 20 09:53:41 2013: <191>167160: cisco-ani=1811032004
Wed Mar 20 09:53:41 2013: <191>167161: cisco-anitype=0
Wed Mar 20 09:53:41 2013: <191>167162: cisco-aniplan=0
Wed Mar 20 09:53:41 2013: <191>167163: cisco-anipi=0
Wed Mar 20 09:53:41 2013: <191>167164: cisco-anisi=0
Wed Mar 20 09:53:41 2013: <191>167165: dest=
Wed Mar 20 09:53:41 2013: <191>167166: cisco-desttype=0
Wed Mar 20 09:53:41 2013: <191>167167: cisco-destplan=0
Wed Mar 20 09:53:41 2013: <191>167168: cisco-rdie=FFFFFFFF
Wed Mar 20 09:53:41 2013: <191>167169: cisco-rdn=
Wed Mar 20 09:53:41 2013: <191>167170: cisco-lastrdn=
Wed Mar 20 09:53:41 2013: <191>167171: cisco-rdntype=0
Wed Mar 20 09:53:41 2013: <191>167172: cisco-rdnplan=0
Wed Mar 20 09:53:41 2013: <191>167173: cisco-rdnpi=0
Wed Mar 20 09:53:41 2013: <191>167174: cisco-rdnsi=0
Wed Mar 20 09:53:41 2013: <191>167175: cisco-redirectreason=0 fwd_final_type =0
Wed Mar 20 09:53:41 2013: <191>167176: final_redirectNumber =
Wed Mar 20 09:53:41 2013: <191>167177: hunt_group_timeout =0
Wed Mar 20 09:53:41 2013: <191>167178:
Wed Mar 20 09:53:41 2013: <191>167179: .Mar 20 09:53:40: //-1/05FF2D55B40F/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:53:41 2013: <191>167180:
Wed Mar 20 09:53:41 2013: <191>167181: Interface=0x4B806530, Call Info(
Wed Mar 20 09:53:41 2013: <191>167182: Calling Number=1811032004,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:53:41 2013: <191>167183: Called Number=(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:53:41 2013: <191>167184: Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Wed Mar 20 09:53:41 2013: <191>167185: Incoming Dial-peer=20009, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Wed Mar 20 09:53:41 2013: <191>167186: Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:53:41 2013: <191>167187: .Mar 20 09:53:40: //-1/05FF2D55B40F/CCAPI/ccCheckClipClir:
Wed Mar 20 09:53:41 2013: <191>167188: In: Calling Number=1811032004(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:53:41 2013: <191>167189: .Mar 20 09:53:40: //-1/05FF2D55B40F/CCAPI/ccCheckClipClir:
Wed Mar 20 09:53:41 2013: <191>167190: Out: Calling Number=1811032004(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:53:41 2013: <191>167191: .Mar 20 09:53:40: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:53:41 2013: <191>167192:
Wed Mar 20 09:53:41 2013: <191>167193: .Mar 20 09:53:40: :cc_get_feature_vsa malloc success
Wed Mar 20 09:53:41 2013: <191>167194: .Mar 20 09:53:40: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:53:41 2013: <191>167195:
Wed Mar 20 09:53:41 2013: <191>167196: .Mar 20 09:53:40: cc_get_feature_vsa count is 1
Wed Mar 20 09:53:41 2013: <191>167197: .Mar 20 09:53:40: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:53:41 2013: <191>167198:
Wed Mar 20 09:53:41 2013: <191>167199: .Mar 20 09:53:40: :FEATURE_VSA attributes are: feature_name:0,feature_time:1271880472,feature_id:8170
Wed Mar 20 09:53:41 2013: <191>167200: .Mar 20 09:53:40: //8170/05FF2D55B40F/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:53:41 2013: <191>167201:
Wed Mar 20 09:53:41 2013: <191>167202: Set Up Event Sent;
Wed Mar 20 09:53:41 2013: <191>167203: Call Info(Calling Number=1811032004(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:53:41 2013: <191>167205: .Mar 20 09:53:40: //8170/05FF2D55B40F/CCAPI/cc_process_call_setup_ind:
Wed Mar 20 09:53:41 2013: <191>167209: .Mar 20 09:53:40: //8170/05FF2D55B40F/CCAPI/cc_process_call_setup_ind:
Wed Mar 20 09:53:41 2013: <191>167213: .Mar 20 09:53:40: //8170/05FF2D55B40F/CCAPI/cc_api_set_transfer_info:
Wed Mar 20 09:53:41 2013: <191>167214:
Wed Mar 20 09:53:41 2013: <191>167215: Transfer Number=, Transfer Reason=0x0
Wed Mar 20 09:53:41 2013: <191>167216: .Mar 20 09:53:40: //8170/05FF2D55B40F/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:53:41 2013: <191>167223: .Mar 20 09:53:40: //8170/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
Wed Mar 20 09:53:41 2013: <191>167224: (callID=0x1FEA, digit_event=0x1, enable=TRUE, consume=FALSE)
Wed Mar 20 09:53:41 2013: <191>167225: .Mar 20 09:53:40: //8170/05FF2D55B40F/CCAPI/ccCallReportDigits:
Wed Mar 20 09:53:42 2013: <191>167227: Enabled=TRUE, Call Id=8170
Wed Mar 20 09:53:42 2013: <191>167228: .Mar 20 09:53:40: //8170/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:53:42 2013: <191>167229: (vdbPtr=0x4B806530, callID=0x1FEA, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Wed Mar 20 09:53:42 2013: <191>167230: .Mar 20 09:53:40: //8170/05FF2D55B40F/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:53:42 2013: <191>167231: Enabled=TRUE, Disposition=0x0, Interface=0x4B806530, Call Id=8170
Wed Mar 20 09:53:42 2013: <191>167232: .Mar 20 09:53:40: //8170/05FF2D55B40F/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:53:42 2013: <191>167233: Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=8000(ms))
Wed Mar 20 09:53:42 2013: <191>167234: .Mar 20 09:53:41: //8170/05FF2D55B40F/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:53:42 2013: <191>167235: Cause Value=16, Interface=0x4B806530, Call Id=8170
Wed Mar 20 09:53:42 2013: <191>167236: .Mar 20 09:53:41: //8170/05FF2D55B40F/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:53:42 2013: <191>167237: Call Entry(Responsed=FALSE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:53:42 2013: <191>167238: .Mar 20 09:53:41: //8170/05FF2D55B40F/CCAPI/ccCallDisconnect:
Wed Mar 20 09:53:42 2013: <191>167239: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:53:42 2013: <191>167240: .Mar 20 09:53:41: //8170/05FF2D55B40F/CCAPI/ccCallDisconnect:
Wed Mar 20 09:53:42 2013: <191>167241: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:53:42 2013: <191>167242: .Mar 20 09:53:41: //8170/05FF2D55B40F/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:53:42 2013: <191>167243: Transfer Number Is Null
Wed Mar 20 09:53:42 2013: <191>167244: .Mar 20 09:53:41: //8170/05FF2D55B40F/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:53:42 2013: <191>167245:
Wed Mar 20 09:53:43 2013: <191>167246: Disposition=0, Interface=0x4B806530, Tag=0x0, Call Id=8170,
Wed Mar 20 09:53:43 2013: <191>167247: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:53:43 2013: <191>167248: .Mar 20 09:53:41: //8170/05FF2D55B40F/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:53:43 2013: <191>167249: Call Disconnect Event Sent
Wed Mar 20 09:53:43 2013: <191>167250: .Mar 20 09:53:41: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:53:43 2013: <191>167251:
Wed Mar 20 09:53:43 2013: <191>167252: .Mar 20 09:53:41: :cc_free_feature_vsa freeing 4BCF5B10
Wed Mar 20 09:53:43 2013: <191>167253: .Mar 20 09:53:41: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:53:43 2013: <191>167254:
Wed Mar 20 09:53:43 2013: <191>167255: .Mar 20 09:53:41: vsacount in free is 0
Wed Mar 20 09:54:03 2013: <190>167256: .Mar 20 09:54:01: %IPPHONE-6-UNREGISTER_NORMAL: ephone-5:SEP002699441E44 IP:10.229.64.32 Socket:5 DeviceType:Phone has unregistered normally.
Wed Mar 20 09:54:15 2013: <190>167257: .Mar 20 09:54:12: %IPPHONE-6-REGISTER_NEW: ephone-5:SEP002699441E44 IP:10.229.64.32 Socket:5 DeviceType:Phone has registered.
Wed Mar 20 09:55:57 2013: <191>167259: cc_api_call_setup_ind_common:
Wed Mar 20 09:55:57 2013: <191>167258: .Mar 20 09:55:55: //-1/56C47A74B413/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:55:57 2013: <191>167260: cisco-username=
Wed Mar 20 09:55:57 2013: <191>167261: ----- ccCallInfo IE subfields -----
Wed Mar 20 09:55:57 2013: <191>167262: cisco-ani=1811032004
Wed Mar 20 09:55:57 2013: <191>167263: cisco-anitype=0
Wed Mar 20 09:55:57 2013: <191>167264: cisco-aniplan=0
Wed Mar 20 09:55:57 2013: <191>167265: cisco-anipi=0
Wed Mar 20 09:55:57 2013: <191>167266: cisco-anisi=0
Wed Mar 20 09:55:57 2013: <191>167267: dest=
Wed Mar 20 09:55:57 2013: <191>167268: cisco-desttype=0
Wed Mar 20 09:55:57 2013: <191>167269: cisco-destplan=0
Wed Mar 20 09:55:57 2013: <191>167270: cisco-rdie=FFFFFFFF
Wed Mar 20 09:55:57 2013: <191>167271: cisco-rdn=
Wed Mar 20 09:55:57 2013: <191>167272: cisco-lastrdn=
Wed Mar 20 09:55:57 2013: <191>167273: cisco-rdntype=0
Wed Mar 20 09:55:57 2013: <191>167274: cisco-rdnplan=0
Wed Mar 20 09:55:57 2013: <191>167275: cisco-rdnpi=0
Wed Mar 20 09:55:57 2013: <191>167276: cisco-rdnsi=0
Wed Mar 20 09:55:57 2013: <191>167277: cisco-redirectreason=0 fwd_final_type =0
Wed Mar 20 09:55:57 2013: <191>167278: final_redirectNumber =
Wed Mar 20 09:55:57 2013: <191>167279: hunt_group_timeout =0
Wed Mar 20 09:55:57 2013: <191>167280:
Wed Mar 20 09:55:57 2013: <191>167281: .Mar 20 09:55:55: //-1/56C47A74B413/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:55:57 2013: <191>167282:
Wed Mar 20 09:55:57 2013: <191>167283: Interface=0x4B806530, Call Info(
Wed Mar 20 09:55:57 2013: <191>167284: Calling Number=1811032004,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:55:57 2013: <191>167285: Called Number=(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:55:57 2013: <191>167286: Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Wed Mar 20 09:55:57 2013: <191>167287: Incoming Dial-peer=20009, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Wed Mar 20 09:55:57 2013: <191>167288: Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Wed Mar 20 09:55:57 2013: <191>167289: .Mar 20 09:55:55: //-1/56C47A74B413/CCAPI/ccCheckClipClir:
Wed Mar 20 09:55:57 2013: <191>167290: In: Calling Number=1811032004(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:55:57 2013: <191>167291: .Mar 20 09:55:55: //-1/56C47A74B413/CCAPI/ccCheckClipClir:
Wed Mar 20 09:55:57 2013: <191>167292: Out: Calling Number=1811032004(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:55:57 2013: <191>167293: .Mar 20 09:55:55: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:55:57 2013: <191>167294:
Wed Mar 20 09:55:57 2013: <191>167295: .Mar 20 09:55:55: :cc_get_feature_vsa malloc success
Wed Mar 20 09:55:57 2013: <191>167296: .Mar 20 09:55:55: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:55:57 2013: <191>167297:
Wed Mar 20 09:55:57 2013: <191>167298: .Mar 20 09:55:55: cc_get_feature_vsa count is 1
Wed Mar 20 09:55:57 2013: <191>167299: .Mar 20 09:55:55: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:55:57 2013: <191>167300:
Wed Mar 20 09:55:57 2013: <191>167301: .Mar 20 09:55:55: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203336000,feature_id:8171
Wed Mar 20 09:55:57 2013: <191>167302: .Mar 20 09:55:55: //8171/56C47A74B413/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:55:57 2013: <191>167304: Set Up Event Sent;
Wed Mar 20 09:55:57 2013: <191>167306: Called Number=(TON=Unknown, NPI=Unknown))
Wed Mar 20 09:55:57 2013: <191>167309: .Mar 20 09:55:55: //8171/56C47A74B413/CCAPI/ccCallSetContext:
Wed Mar 20 09:55:57 2013: <191>167310: Context=0x4BA67528
Wed Mar 20 09:55:57 2013: <191>167313: .Mar 20 09:55:55: //8171/56C47A74B413/CCAPI/ccCallSetupAck:
Wed Mar 20 09:55:57 2013: <191>167314: Call Id=8171
Wed Mar 20 09:55:57 2013: <191>167318: .Mar 20 09:55:55: //8171/56C47A74B413/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:55:57 2013: <191>167327: .Mar 20 09:55:55: //8171/56C47A74B413/CCAPI/ccCallReportDigits:
Wed Mar 20 09:55:57 2013: <191>167328:
Wed Mar 20 09:55:58 2013: <191>167329: Enabled=TRUE, Call Id=8171
Wed Mar 20 09:55:58 2013: <191>167330: .Mar 20 09:55:55: //8171/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:55:58 2013: <191>167331: (vdbPtr=0x4B806530, callID=0x1FEB, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Wed Mar 20 09:55:58 2013: <191>167332: .Mar 20 09:55:55: //8171/56C47A74B413/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:55:58 2013: <191>167333: Enabled=TRUE, Disposition=0x0, Interface=0x4B806530, Call Id=8171
Wed Mar 20 09:55:58 2013: <191>167334: .Mar 20 09:55:55: //8171/56C47A74B413/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:55:58 2013: <191>167335: Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=8000(ms))
Wed Mar 20 09:55:59 2013: <191>167336: .Mar 20 09:55:57: //8171/56C47A74B413/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:55:59 2013: <191>167337: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:55:59 2013: <191>167338: Source Call Id=8171, Digit=0, DigitBeginFlags=0x0,
Wed Mar 20 09:55:59 2013: <191>167339: Rtp Timestamp=0x3D18A0, Rtp Expiration=0x0
Wed Mar 20 09:55:59 2013: <191>167340: .Mar 20 09:55:57: //8171/56C47A74B413/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:55:59 2013: <191>167341: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:55:59 2013: <191>167342: Source Call Id=8171, Digit=0, Duration=100,
Wed Mar 20 09:55:59 2013: <191>167343: Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:55:59 2013: <191>167344: .Mar 20 09:55:57: //8171/56C47A74B413/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:55:59 2013: <191>167345: Call Entry(Handoff Depth=0)
Wed Mar 20 09:56:00 2013: <191>167346: .Mar 20 09:55:58: //8171/56C47A74B413/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:56:00 2013: <191>167347: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:56:00 2013: <191>167348: Source Call Id=8171, Digit=9, DigitBeginFlags=0x0,
Wed Mar 20 09:56:00 2013: <191>167349: Rtp Timestamp=0x3D95A0, Rtp Expiration=0x0
Wed Mar 20 09:56:00 2013: <191>167350: .Mar 20 09:55:58: //8171/56C47A74B413/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:56:00 2013: <191>167351: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:56:00 2013: <191>167352: Source Call Id=8171, Digit=9, Duration=100,
Wed Mar 20 09:56:00 2013: <191>167353: Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:56:00 2013: <191>167354: .Mar 20 09:55:58: //8171/56C47A74B413/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:56:00 2013: <191>167355: Call Entry(Handoff Depth=0)
Wed Mar 20 09:56:00 2013: <191>167356: .Mar 20 09:55:59: //8171/56C47A74B413/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:56:00 2013: <191>167357:
Wed Mar 20 09:56:01 2013: <191>167358: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:56:01 2013: <191>167359: Source Call Id=8171, Digit=7, DigitBeginFlags=0x0,
Wed Mar 20 09:56:01 2013: <191>167360: Rtp Timestamp=0x3E12A0, Rtp Expiration=0x0
Wed Mar 20 09:56:01 2013: <191>167361: .Mar 20 09:55:59: //8171/56C47A74B413/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:56:01 2013: <191>167362: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:56:01 2013: <191>167363: Source Call Id=8171, Digit=7, Duration=100,
Wed Mar 20 09:56:01 2013: <191>167364: Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:56:01 2013: <191>167365: .Mar 20 09:55:59: //8171/56C47A74B413/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:56:01 2013: <191>167366: Call Entry(Handoff Depth=0)
Wed Mar 20 09:56:01 2013: <191>167367: .Mar 20 09:56:00: //8171/56C47A74B413/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:56:01 2013: <191>167368:
Wed Mar 20 09:56:01 2013: <191>167369: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:56:01 2013: <191>167370: Source Call Id=8171, Digit=1, DigitBeginFlags=0x0,
Wed Mar 20 09:56:01 2013: <191>167371: Rtp Timestamp=0x3E8FA0, Rtp Expiration=0x0
Wed Mar 20 09:56:01 2013: <191>167372: .Mar 20 09:56:00: //8171/56C47A74B413/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:56:01 2013: <191>167373: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:56:01 2013: <191>167374: Source Call Id=8171, Digit=1, Duration=100,
Wed Mar 20 09:56:01 2013: <191>167375: Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:56:01 2013: <191>167376: .Mar 20 09:56:00: //8171/56C47A74B413/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:56:01 2013: <191>167377: Call Entry(Handoff Depth=0)
Wed Mar 20 09:56:01 2013: <191>167378: .Mar 20 09:56:00: //8171/56C47A74B413/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:56:01 2013: <191>167379:
Wed Mar 20 09:56:02 2013: <191>167380: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:56:02 2013: <191>167381: Source Call Id=8171, Digit=4, DigitBeginFlags=0x0,
Wed Mar 20 09:56:02 2013: <191>167382: Rtp Timestamp=0x3F0CA0, Rtp Expiration=0x0
Wed Mar 20 09:56:02 2013: <191>167383: .Mar 20 09:56:00: //8171/56C47A74B413/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:56:02 2013: <191>167384: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:56:02 2013: <191>167385: Source Call Id=8171, Digit=4, Duration=100,
Wed Mar 20 09:56:02 2013: <191>167386: Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:56:02 2013: <191>167387: .Mar 20 09:56:00: //8171/56C47A74B413/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:56:02 2013: <191>167388: Call Entry(Handoff Depth=0)
Wed Mar 20 09:56:02 2013: <191>167389: .Mar 20 09:56:00: //8171/56C47A74B413/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:56:02 2013: <191>167390:
Wed Mar 20 09:56:02 2013: <191>167391: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:56:02 2013: <191>167392: Source Call Id=8171, Digit=4, DigitBeginFlags=0x0,
Wed Mar 20 09:56:02 2013: <191>167393: Rtp Timestamp=0x3F89A0, Rtp Expiration=0x0
Wed Mar 20 09:56:02 2013: <191>167394: .Mar 20 09:56:00: //8171/56C47A74B413/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:56:02 2013: <191>167395: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:56:02 2013: <191>167396: Source Call Id=8171, Digit=4, Duration=100,
Wed Mar 20 09:56:02 2013: <191>167397: Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:56:02 2013: <191>167398: .Mar 20 09:56:00: //8171/56C47A74B413/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:56:02 2013: <191>167399: Call Entry(Handoff Depth=0)
Wed Mar 20 09:56:02 2013: <191>167400: .Mar 20 09:56:01: //8171/56C47A74B413/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:56:02 2013: <191>167401:
Wed Mar 20 09:56:02 2013: <191>167402: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:56:02 2013: <191>167403: Source Call Id=8171, Digit=8, DigitBeginFlags=0x0,
Wed Mar 20 09:56:02 2013: <191>167404: Rtp Timestamp=0x4006A0, Rtp Expiration=0x0
Wed Mar 20 09:56:02 2013: <191>167405: .Mar 20 09:56:01: //8171/56C47A74B413/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:56:02 2013: <191>167406: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:56:02 2013: <191>167407: Source Call Id=8171, Digit=8, Duration=100,
Wed Mar 20 09:56:02 2013: <191>167408: Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:56:02 2013: <191>167409: .Mar 20 09:56:01: //8171/56C47A74B413/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:56:02 2013: <191>167410: Call Entry(Handoff Depth=0)
Wed Mar 20 09:56:02 2013: <191>167411: .Mar 20 09:56:01: //8171/56C47A74B413/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:56:02 2013: <191>167412:
Wed Mar 20 09:56:02 2013: <191>167413: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:56:02 2013: <191>167414: Source Call Id=8171, Digit=6, DigitBeginFlags=0x0,
Wed Mar 20 09:56:02 2013: <191>167415: Rtp Timestamp=0x4083A0, Rtp Expiration=0x0
Wed Mar 20 09:56:02 2013: <191>167416: .Mar 20 09:56:01: //8171/56C47A74B413/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:56:03 2013: <191>167417: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:56:03 2013: <191>167418: Source Call Id=8171, Digit=6, Duration=100,
Wed Mar 20 09:56:03 2013: <191>167419: Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:56:03 2013: <191>167420: .Mar 20 09:56:01: //8171/56C47A74B413/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:56:03 2013: <191>167421: Call Entry(Handoff Depth=0)
Wed Mar 20 09:56:03 2013: <191>167422: .Mar 20 09:56:01: //8171/56C47A74B413/CCAPI/cc_api_call_digit_begin:
Wed Mar 20 09:56:03 2013: <191>167423:
Wed Mar 20 09:56:03 2013: <191>167424: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:56:03 2013: <191>167425: Source Call Id=8171, Digit=8, DigitBeginFlags=0x0,
Wed Mar 20 09:56:03 2013: <191>167426: Rtp Timestamp=0x4100A0, Rtp Expiration=0x0
Wed Mar 20 09:56:03 2013: <191>167427: .Mar 20 09:56:01: //8171/56C47A74B413/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:56:03 2013: <191>167428: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Wed Mar 20 09:56:04 2013: <191>167429: Source Call Id=8171, Digit=8, Duration=100,
Wed Mar 20 09:56:04 2013: <191>167430: Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Wed Mar 20 09:56:04 2013: <191>167431: .Mar 20 09:56:01: //8171/56C47A74B413/CCAPI/cc_api_call_digit_end:
Wed Mar 20 09:56:04 2013: <191>167432: Call Entry(Handoff Depth=0)
Wed Mar 20 09:56:11 2013: <191>167433: .Mar 20 09:56:09: //8171/56C47A74B413/CCAPI/cc_handle_inter_digit_timer:
Wed Mar 20 09:56:11 2013: <191>167434: Generate inter-digit timeout CC_EV_CALL_DIGIT_END event
Wed Mar 20 09:56:11 2013: <191>167435: .Mar 20 09:56:09: //8171/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
Wed Mar 20 09:56:11 2013: <191>167436: (callID=0x1FEB, digit_event=0x0, enable=FALSE, consume=FALSE)
Wed Mar 20 09:56:11 2013: <191>167437: .Mar 20 09:56:09: //8171/56C47A74B413/CCAPI/ccCallReportDigits:
Wed Mar 20 09:56:11 2013: <191>167438: Enabled=TRUE, Call Id=8171
Wed Mar 20 09:56:11 2013: <191>167439: .Mar 20 09:56:09: //8171/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:56:11 2013: <191>167440: (vdbPtr=0x4B806530, callID=0x1FEB, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Wed Mar 20 09:56:11 2013: <191>167441: .Mar 20 09:56:09: //8171/56C47A74B413/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:56:11 2013: <191>167442: Enabled=TRUE, Disposition=0x0, Interface=0x4B806530, Call Id=8171
Wed Mar 20 09:56:11 2013: <191>167443: .Mar 20 09:56:09: //8171/56C47A74B413/CCAPI/cc_api_call_report_digits_done:
Wed Mar 20 09:56:11 2013: <191>167444: Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=8000(ms))
Wed Mar 20 09:56:11 2013: <191>167445: .Mar 20 09:56:09: //8171/56C47A74B413/CCAPI/ccCallProceeding:
Wed Mar 20 09:56:11 2013: <191>167446: Progress Indication=NULL(0)
Wed Mar 20 09:56:11 2013: <191>167447: .Mar 20 09:56:09: //8171/56C47A74B413/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:56:11 2013: <191>167448: Destination=, Calling IE Present=TRUE, Mode=0,
Wed Mar 20 09:56:11 2013: <191>167449: Outgoing Dial-peer=20, Params=0x4BA6D4A0, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Wed Mar 20 09:56:11 2013: <191>167450: .Mar 20 09:56:09: //8171/56C47A74B413/CCAPI/ccCheckClipClir:
Wed Mar 20 09:56:11 2013: <191>167451: In: Calling Number=1811032004(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:56:11 2013: <191>167452: .Mar 20 09:56:09: //8171/56C47A74B413/CCAPI/ccCheckClipClir:
Wed Mar 20 09:56:11 2013: <191>167453: Out: Calling Number=1811032004(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Wed Mar 20 09:56:11 2013: <191>167454: .Mar 20 09:56:09: //8171/56C47A74B413/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:56:11 2013: <191>167455: Destination Pattern=09......T, Called Number=097144868, Digit Strip=TRUE
Wed Mar 20 09:56:11 2013: <191>167456: .Mar 20 09:56:09: //8171/56C47A74B413/CCAPI/ccCallSetupRequest:
Wed Mar 20 09:56:11 2013: <191>167457: Calling Number=1811032004(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Wed Mar 20 09:56:11 2013: <191>167458: Called Number=097144868(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:56:11 2013: <191>167459: Redirect Number=, Display Info=1811032004
Wed Mar 20 09:56:11 2013: <191>167460:
Wed Mar 20 09:56:11 2013: <191>167461: Account Number=, Final Destination Flag=FALSE,
Wed Mar 20 09:56:11 2013: <191>167462: Guid=56C47A74-9094-11E2-B413-DE08FC69A21F, Outgoing Dial-peer=20
Wed Mar 20 09:56:11 2013: <191>167463: .Mar 20 09:56:09: //8171/56C47A74B413/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:56:11 2013: <191>167464: ccCallSetupRequest:
Wed Mar 20 09:56:11 2013: <191>167465: cisco-username=
Wed Mar 20 09:56:11 2013: <191>167466: ----- ccCallInfo IE subfields -----
Wed Mar 20 09:56:11 2013: <191>167467: cisco-ani=1811032004
Wed Mar 20 09:56:11 2013: <191>167468: cisco-anitype=0
Wed Mar 20 09:56:11 2013: <191>167469: cisco-aniplan=0
Wed Mar 20 09:56:11 2013: <191>167470: cisco-anipi=0
Wed Mar 20 09:56:11 2013: <191>167472: dest=097144868
Wed Mar 20 09:56:11 2013: <191>167473: cisco-desttype=0
Wed Mar 20 09:56:11 2013: <191>167477: cisco-lastrdn=
Wed Mar 20 09:56:11 2013: <191>167479: cisco-rdnplan=0
Wed Mar 20 09:56:11 2013: <191>167480: cisco-rdnpi=0
Wed Mar 20 09:56:11 2013: <191>167490: Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=20, Call Count On=FALSE,
Wed Mar 20 09:56:11 2013: <191>167493:
Wed Mar 20 09:56:11 2013: <191>167504: Context=0x4BA6D450
Wed Mar 20 09:56:11 2013: <191>167505: .Mar 20 09:56:09: //8171/56C47A74B413/CCAPI/ccSaveDialpeerTag:
Wed Mar 20 09:56:12 2013: <191>167507: .Mar 20 09:56:09: //8172/56C47A74B413/CCAPI/cc_api_call_proceeding:
Wed Mar 20 09:56:12 2013: <191>167508: Interface=0x4987FF98, Progress Indication=NULL(0)
Wed Mar 20 09:56:13 2013: <191>167509: .Mar 20 09:56:12: //8172/56C47A74B413/CCAPI/cc_api_call_cut_progress:
Wed Mar 20 09:56:13 2013: <191>167510: Interface=0x4987FF98, Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2),
Wed Mar 20 09:56:13 2013: <191>167511: Cause Value=0
Wed Mar 20 09:56:13 2013: <191>167512: .Mar 20 09:56:12: //8172/56C47A74B413/CCAPI/cc_api_call_cut_progress:
Wed Mar 20 09:56:13 2013: <191>167513: Call Entry(Responsed=TRUE)
Wed Mar 20 09:56:13 2013: <191>167514: .Mar 20 09:56:12: //8171/56C47A74B413/CCAPI/ccCallCutProgress:
Wed Mar 20 09:56:13 2013: <191>167515: Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=0
Wed Mar 20 09:56:13 2013: <191>167516: Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
Wed Mar 20 09:56:13 2013: <191>167517: .Mar 20 09:56:12: //8171/56C47A74B413/CCAPI/ccCallCutProgress:
Wed Mar 20 09:56:13 2013: <191>167518: Call Entry(Responsed=TRUE)
Wed Mar 20 09:56:13 2013: <191>167519: .Mar 20 09:56:12: //8171/56C47A74B413/CCAPI/ccGenerateToneInfo:
Wed Mar 20 09:56:13 2013: <191>167520:
Wed Mar 20 09:56:14 2013: <191>167521: Stop Tone On Digit=FALSE, Tone=Null,
Wed Mar 20 09:56:14 2013: <191>167522: Tone Direction=Network, Params=0x0, Call Id=8171
Wed Mar 20 09:56:14 2013: <191>167523: .Mar 20 09:56:12: //8171/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:56:14 2013: <191>167524: (confID=0x4BB02038, callID1=0x1FEB, callID2=0x1FEC, tag=0x0)
Wed Mar 20 09:56:14 2013: <191>167525: .Mar 20 09:56:12: //8171/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:56:14 2013: <191>167526: (confID=0x4BB02038, callID1=0x1FEB, gcid=56C47A74-909411E2-B413DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:56:14 2013: <191>167527: .Mar 20 09:56:12: //8172/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:56:14 2013: <191>167528: (confID=0x4BB02038, callID2=0x1FEC, gcid=56C47A74-909411E2-B413DE08-FC69A21F, tag=0x0)
Wed Mar 20 09:56:14 2013: <191>167529: .Mar 20 09:56:12: //8171/56C47A74B413/CCAPI/ccConferenceCreate:
Wed Mar 20 09:56:14 2013: <191>167530: Conference Id=0x4BB02038, Call Id1=8171, Call Id2=8172, Tag=0x0
Wed Mar 20 09:56:14 2013: <191>167531: .Mar 20 09:56:12: //8171/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:56:14 2013: <191>167532: Conference Id=0xE62, Source Interface=0x4B806530, Source Call Id=8171,
Wed Mar 20 09:56:14 2013: <191>167533: Destination Call Id=8172, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:56:14 2013: <191>167534: .Mar 20 09:56:12: //8172/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:56:14 2013: <191>167535: Conference Id=0xE62, Source Interface=0x4987FF98, Source Call Id=8172,
Wed Mar 20 09:56:14 2013: <191>167536: Destination Call Id=8171, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:56:14 2013: <191>167537: .Mar 20 09:56:12: //8171/56C47A74B413/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:56:14 2013: <191>167538: Conference Id=0xE62, Source Interface=0x4987FF98, Source Call Id=8172,
Wed Mar 20 09:56:14 2013: <191>167539: Destination Call Id=8171, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:56:14 2013: <191>167540: .Mar 20 09:56:12: //8171/56C47A74B413/CCAPI/ccConferenceCreate:
Wed Mar 20 09:56:14 2013: <191>167541:
Wed Mar 20 09:56:14 2013: <191>167542: Call Entry(Conference Id=0xE62, Destination Call Id=8172)
Wed Mar 20 09:56:14 2013: <191>167543: .Mar 20 09:56:12: //8172/56C47A74B413/CCAPI/ccConferenceCreate:
Wed Mar 20 09:56:14 2013: <191>167544: Call Entry(Conference Id=0xE62, Destination Call Id=8171)
Wed Mar 20 09:56:14 2013: <191>167545: .Mar 20 09:56:12: //8171/56C47A74B413/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:56:14 2013: <191>167546: Destination Interface=0x4987FF98, Destination Call Id=8172, Source Call Id=8171,
Wed Mar 20 09:56:14 2013: <191>167549: .Mar 20 09:56:12: //8171/56C47A74B413/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:56:14 2013: <191>167552: .Mar 20 09:56:12: //8172/56C47A74B413/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:56:14 2013: <191>167553:
Wed Mar 20 09:56:14 2013: <191>167554: Destination Interface=0x4B806530, Destination Call Id=8171, Source Call Id=8172,
Wed Mar 20 09:56:14 2013: <191>167558: Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:56:14 2013: <191>167559: Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:56:14 2013: <191>167560: .Mar 20 09:56:12: //8172/56C47A74B413/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:56:14 2013: <191>167561: Destination Interface=0x4B806530, Destination Call Id=8171, Source Call Id=8172,
Wed Mar 20 09:56:14 2013: <191>167569: Call Id=8171
Wed Mar 20 09:56:14 2013: <191>167571: Call Entry(Context=0x4BA67528)
Wed Mar 20 09:56:14 2013: <191>167573: Conference Id=0xE62, Call Id1=8171, Call Id2=8172
Wed Mar 20 09:56:14 2013: <191>167574: .Mar 20 09:56:12: //8171/56C47A74B413/CCAPI/ccCallFeature:
Wed Mar 20 09:56:14 2013: <191>167575:
Wed Mar 20 09:56:14 2013: <191>167576: Feature Type=25, Call Id=8171
Wed Mar 20 09:56:14 2013: <191>167584: .Mar 20 09:56:12: //8172/56C47A74B413/CCAPI/cc_api_call_connected:
Wed Mar 20 09:56:14 2013: <191>167585: Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Wed Mar 20 09:56:14 2013: <191>167586: .Mar 20 09:56:12: //8171/56C47A74B413/CCAPI/ccCallConnect:
Wed Mar 20 09:56:14 2013: <191>167587: Progress Indication=DESTINATION IS NON ISDN(2), Data Bitmask=0x1
Wed Mar 20 09:56:14 2013: <191>167588: .Mar 20 09:56:12: //8171/56C47A74B413/CCAPI/ccCallConnect:
Wed Mar 20 09:56:14 2013: <191>167589: Call Entry(Connected=TRUE, Responsed=TRUE)
Wed Mar 20 09:56:14 2013: <191>167590: .Mar 20 09:56:12: //8171/56C47A74B413/CCAPI/ccCallFeature:
Wed Mar 20 09:56:14 2013: <191>167591: Feature Type=25, Call Id=8171
Wed Mar 20 09:57:27 2013: <191>167592: .Mar 20 09:57:26: //8171/56C47A74B413/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:57:27 2013: <191>167593: Cause Value=16, Interface=0x4B806530, Call Id=8171
Wed Mar 20 09:57:27 2013: <191>167594: .Mar 20 09:57:26: //8171/56C47A74B413/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:57:27 2013: <191>167595: Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:57:27 2013: <191>167596: .Mar 20 09:57:26: //8171/56C47A74B413/CCAPI/ccConferenceDestroy:
Wed Mar 20 09:57:27 2013: <191>167597: Conference Id=0xE62, Tag=0x0
Wed Mar 20 09:57:27 2013: <191>167598: .Mar 20 09:57:26: //8171/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:57:27 2013: <191>167599: Conference Id=0xE62, Source Interface=0x4B806530, Source Call Id=8171,
Wed Mar 20 09:57:27 2013: <191>167600: Destination Call Id=8172, Disposition=0x0, Tag=0x0
Wed Mar 20 09:57:27 2013: <191>167601: .Mar 20 09:57:26: //8172/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:57:27 2013: <191>167602:
Wed Mar 20 09:57:27 2013: <191>167603: Conference Id=0xE62, Source Interface=0x4987FF98, Source Call Id=8172,
Wed Mar 20 09:57:27 2013: <191>167604: Destination Call Id=8171, Disposition=0x0, Tag=0x0
Wed Mar 20 09:57:27 2013: <191>167605: .Mar 20 09:57:26: //8171/56C47A74B413/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:57:27 2013: <191>167606: Conference Id=0xE62, Source Interface=0x4987FF98, Source Call Id=8172,
Wed Mar 20 09:57:27 2013: <191>167607: Destination Call Id=8171, Disposition=0x0, Tag=0x0
Wed Mar 20 09:57:27 2013: <191>167608: .Mar 20 09:57:26: //8171/56C47A74B413/CCAPI/ccCallDisconnect:
Wed Mar 20 09:57:27 2013: <191>167609: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:57:27 2013: <191>167610: .Mar 20 09:57:26: //8171/56C47A74B413/CCAPI/ccCallDisconnect:
Wed Mar 20 09:57:27 2013: <191>167611: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:57:27 2013: <191>167612: .Mar 20 09:57:26: //8171/56C47A74B413/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:57:27 2013: <191>167613:
Wed Mar 20 09:57:27 2013: <191>167614: Transfer Number Is Null
Wed Mar 20 09:57:27 2013: <191>167615: .Mar 20 09:57:26: //8172/56C47A74B413/CCAPI/ccCallDisconnect:
Wed Mar 20 09:57:27 2013: <191>167616: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Wed Mar 20 09:57:27 2013: <191>167617: .Mar 20 09:57:26: //8172/56C47A74B413/CCAPI/ccCallDisconnect:
Wed Mar 20 09:57:27 2013: <191>167618: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:57:27 2013: <191>167619: .Mar 20 09:57:26: //8172/56C47A74B413/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:57:27 2013: <191>167620: Transfer Number Is Null
Wed Mar 20 09:57:27 2013: <191>167621: .Mar 20 09:57:26: //8171/56C47A74B413/CCAPI/cc_api_call_feature:
Wed Mar 20 09:57:27 2013: <191>167622: Feature Type=6, Interface=0x4B806530, Call Id=8171
Wed Mar 20 09:57:27 2013: <191>167623: .Mar 20 09:57:26: //8171/56C47A74B413/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:57:27 2013: <191>167624:
Wed Mar 20 09:57:27 2013: <191>167625: Disposition=0, Interface=0x4B806530, Tag=0x0, Call Id=8171,
Wed Mar 20 09:57:27 2013: <191>167626: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:57:27 2013: <191>167627: .Mar 20 09:57:26: //8171/56C47A74B413/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:57:27 2013: <191>167628: Call Disconnect Event Sent
Wed Mar 20 09:57:27 2013: <191>167629: .Mar 20 09:57:26: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:57:27 2013: <191>167630:
Wed Mar 20 09:57:27 2013: <191>167631: .Mar 20 09:57:26: :cc_free_feature_vsa freeing 47B97338
Wed Mar 20 09:57:27 2013: <191>167632: .Mar 20 09:57:26: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:57:27 2013: <191>167633:
Wed Mar 20 09:57:27 2013: <191>167634: .Mar 20 09:57:26: vsacount in free is 1
Wed Mar 20 09:57:27 2013: <191>167635: .Mar 20 09:57:26: //8172/56C47A74B413/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:57:27 2013: <191>167636: Disposition=0, Interface=0x4987FF98, Tag=0x0, Call Id=8172,
Wed Mar 20 09:57:27 2013: <191>167637: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:57:28 2013: <191>167638: .Mar 20 09:57:26: //8172/56C47A74B413/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:57:28 2013: <191>167639: Call Disconnect Event Sent
Wed Mar 20 09:57:28 2013: <191>167640: .Mar 20 09:57:26: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:57:28 2013: <191>167641:
Wed Mar 20 09:57:28 2013: <191>167642: .Mar 20 09:57:26: :cc_free_feature_vsa freeing 47B97258
Wed Mar 20 09:57:28 2013: <191>167643: .Mar 20 09:57:26: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:57:28 2013: <191>167644:
Wed Mar 20 09:57:28 2013: <191>167645: .Mar 20 09:57:26: vsacount in free is 0
Wed Mar 20 09:57:37 2013: <190>167646: .Mar 20 09:57:34: %IPPHONE-6-UNREGISTER_NORMAL: ephone-5:SEP002699441E44 IP:10.229.64.32 Socket:5 DeviceType:Phone has unregistered normally.
Wed Mar 20 09:58:32 2013: <191>167647: .Mar 20 09:58:31: //-1/80D1F4DC4306/CCAPI/cc_api_display_ie_subfields:
Wed Mar 20 09:58:32 2013: <191>167648: cc_api_call_setup_ind_common:
Wed Mar 20 09:58:32 2013: <191>167649: cisco-username=PF-Assis
Wed Mar 20 09:58:32 2013: <191>167650: ----- ccCallInfo IE subfields -----
Wed Mar 20 09:58:32 2013: <191>167651: cisco-ani=1811032004
Wed Mar 20 09:58:32 2013: <191>167652: cisco-anitype=0
Wed Mar 20 09:58:32 2013: <191>167653: cisco-aniplan=0
Wed Mar 20 09:58:32 2013: <191>167654: cisco-anipi=0
Wed Mar 20 09:58:32 2013: <191>167655: cisco-anisi=1
Wed Mar 20 09:58:32 2013: <191>167656: dest=097144868
Wed Mar 20 09:58:32 2013: <191>167657: cisco-desttype=0
Wed Mar 20 09:58:32 2013: <191>167658: cisco-destplan=0
Wed Mar 20 09:58:32 2013: <191>167659: cisco-rdie=FFFFFFFF
Wed Mar 20 09:58:32 2013: <191>167660: cisco-rdn=
Wed Mar 20 09:58:32 2013: <191>167661: cisco-lastrdn=
Wed Mar 20 09:58:32 2013: <191>167662: cisco-rdntype=-1
Wed Mar 20 09:58:32 2013: <191>167663: cisco-rdnplan=-1
Wed Mar 20 09:58:32 2013: <191>167664: cisco-rdnpi=-1
Wed Mar 20 09:58:32 2013: <191>167665: cisco-rdnsi=-1
Wed Mar 20 09:58:32 2013: <191>167666: cisco-redirectreason=-1 fwd_final_type =0
Wed Mar 20 09:58:32 2013: <191>167667: final_redirectNumber =
Wed Mar 20 09:58:32 2013: <191>167668: hunt_group_timeout =0
Wed Mar 20 09:58:32 2013: <191>167669:
Wed Mar 20 09:58:32 2013: <191>167670: .Mar 20 09:58:31: //-1/80D1F4DC4306/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:58:32 2013: <191>167671:
Wed Mar 20 09:58:32 2013: <191>167672: Interface=0x48A4F728, Call Info(
Wed Mar 20 09:58:32 2013: <191>167673: Calling Number=1811032004,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Wed Mar 20 09:58:32 2013: <191>167674: Called Number=097144868(TON=Unknown, NPI=Unknown),
Wed Mar 20 09:58:32 2013: <191>167675: Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Wed Mar 20 09:58:32 2013: <191>167676: Incoming Dial-peer=200, Progress Indication=NULL(0), Calling IE Present=TRUE,
Wed Mar 20 09:58:32 2013: <191>167677: Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=8173
Wed Mar 20 09:58:32 2013: <191>167678: .Mar 20 09:58:31: //-1/80D1F4DC4306/CCAPI/ccCheckClipClir:
Wed Mar 20 09:58:32 2013: <191>167679: In: Calling Number=1811032004(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Wed Mar 20 09:58:32 2013: <191>167680: .Mar 20 09:58:31: //-1/80D1F4DC4306/CCAPI/ccCheckClipClir:
Wed Mar 20 09:58:32 2013: <191>167681: Out: Calling Number=1811032004(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Wed Mar 20 09:58:32 2013: <191>167682: .Mar 20 09:58:31: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:58:32 2013: <191>167683:
Wed Mar 20 09:58:32 2013: <191>167684: .Mar 20 09:58:31: :cc_get_feature_vsa malloc success
Wed Mar 20 09:58:32 2013: <191>167685: .Mar 20 09:58:31: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:58:32 2013: <191>167686:
Wed Mar 20 09:58:32 2013: <191>167687: .Mar 20 09:58:31: cc_get_feature_vsa count is 1
Wed Mar 20 09:58:32 2013: <191>167688: .Mar 20 09:58:31: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:58:32 2013: <191>167689:
Wed Mar 20 09:58:32 2013: <191>167690: .Mar 20 09:58:31: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203248360,feature_id:8173
Wed Mar 20 09:58:32 2013: <191>167691: .Mar 20 09:58:31: //8173/80D1F4DC4306/CCAPI/cc_api_call_setup_ind_common:
Wed Mar 20 09:58:32 2013: <191>167692:
Wed Mar 20 09:58:32 2013: <191>167693: Set Up Event Sent;
Wed Mar 20 09:58:32 2013: <191>167695: Called Number=097144868(TON=Unknown, NPI=Unknown))
Wed Mar 20 09:58:32 2013: <191>167696: .Mar 20 09:58:31: //8173/80D1F4DC4306/CCAPI/cc_process_call_setup_ind:
Wed Mar 20 09:58:32 2013: <191>167699: Try with the demoted called number 097144868
Wed Mar 20 09:58:32 2013: <191>167700: .Mar 20 09:58:31: //8173/80D1F4DC4306/CCAPI/ccCallSetContext:
Wed Mar 20 09:58:32 2013: <191>167707: Destination=, Calling IE Present=TRUE, Mode=0,
Wed Mar 20 09:58:32 2013: <191>167708: Outgoing Dial-peer=20, Params=0x4BA733C8, Progress Indication=NULL(0)
Wed Mar 20 09:58:32 2013: <191>167725: ----- ccCallInfo IE subfields -----
Wed Mar 20 09:58:32 2013: <191>167726: cisco-ani=1811032004
Wed Mar 20 09:58:32 2013: <191>167730: cisco-anipi=0
Wed Mar 20 09:58:32 2013: <191>167732: dest=097144868
Wed Mar 20 09:58:32 2013: <191>167735: cisco-rdie=FFFFFFFF
Wed Mar 20 09:58:32 2013: <191>167745:
Wed Mar 20 09:58:32 2013: <191>167746: .Mar 20 09:58:31: //8173/80D1F4DC4306/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:58:33 2013: <191>167758: .Mar 20 09:58:31: cc_get_feature_vsa count is 2
Wed Mar 20 09:58:33 2013: <191>167759: .Mar 20 09:58:31: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Wed Mar 20 09:58:33 2013: <191>167760:
Wed Mar 20 09:58:33 2013: <191>167761: .Mar 20 09:58:31: :FEATURE_VSA attributes are: feature_name:0,feature_time:1203248136,feature_id:8174
Wed Mar 20 09:58:33 2013: <191>167762: .Mar 20 09:58:31: //8174/80D1F4DC4306/CCAPI/ccIFCallSetupRequestPrivate:
Wed Mar 20 09:58:33 2013: <191>167763: SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Wed Mar 20 09:58:33 2013: <191>167764: .Mar 20 09:58:31: //8174/80D1F4DC4306/CCAPI/ccCallSetContext:
Wed Mar 20 09:58:33 2013: <191>167765: Context=0x4BA73378
Wed Mar 20 09:58:33 2013: <191>167766: .Mar 20 09:58:31: //8173/80D1F4DC4306/CCAPI/ccSaveDialpeerTag:
Wed Mar 20 09:58:33 2013: <191>167767: Outgoing Dial-peer=20
Wed Mar 20 09:58:33 2013: <191>167768: .Mar 20 09:58:31: //8174/80D1F4DC4306/CCAPI/cc_api_call_proceeding:
Wed Mar 20 09:58:33 2013: <191>167769: Interface=0x4987FF98, Progress Indication=NULL(0)
Wed Mar 20 09:58:35 2013: <191>167770: .Mar 20 09:58:34: //8174/80D1F4DC4306/CCAPI/cc_api_call_cut_progress:
Wed Mar 20 09:58:35 2013: <191>167771: Interface=0x4987FF98, Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2),
Wed Mar 20 09:58:35 2013: <191>167772: Cause Value=0
Wed Mar 20 09:58:35 2013: <191>167773: .Mar 20 09:58:34: //8174/80D1F4DC4306/CCAPI/cc_api_call_cut_progress:
Wed Mar 20 09:58:35 2013: <191>167774: Call Entry(Responsed=TRUE)
Wed Mar 20 09:58:35 2013: <191>167775: .Mar 20 09:58:34: //8173/80D1F4DC4306/CCAPI/ccCallCutProgress:
Wed Mar 20 09:58:35 2013: <191>167776: Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=0
Wed Mar 20 09:58:35 2013: <191>167777: Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
Wed Mar 20 09:58:35 2013: <191>167778: .Mar 20 09:58:34: //8173/80D1F4DC4306/CCAPI/ccCallCutProgress:
Wed Mar 20 09:58:35 2013: <191>167779: Call Entry(Responsed=TRUE)
Wed Mar 20 09:58:35 2013: <191>167780: .Mar 20 09:58:34: //8174/80D1F4DC4306/CCAPI/cc_api_get_called_ccm_detected:
Wed Mar 20 09:58:35 2013: <191>167781: CallInfo(ccm detected=0)
Wed Mar 20 09:58:35 2013: <191>167782: .Mar 20 09:58:34: //8173/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:58:35 2013: <191>167783: (confID=0x4BB01C90, callID1=0x1FED, callID2=0x1FEE, tag=0x0)
Wed Mar 20 09:58:35 2013: <191>167784: .Mar 20 09:58:34: //8173/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:58:35 2013: <191>167785: (confID=0x4BB01C90, callID1=0x1FED, gcid=0-0-0-0, tag=0x0)
Wed Mar 20 09:58:35 2013: <191>167786: .Mar 20 09:58:34: //8174/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
Wed Mar 20 09:58:35 2013: <191>167787: (confID=0x4BB01C90, callID2=0x1FEE, gcid=0-0-0-0, tag=0x0)
Wed Mar 20 09:58:35 2013: <191>167788: .Mar 20 09:58:34: //8173/80D1F4DC4306/CCAPI/ccConferenceCreate:
Wed Mar 20 09:58:35 2013: <191>167789: Conference Id=0x4BB01C90, Call Id1=8173, Call Id2=8174, Tag=0x0
Wed Mar 20 09:58:35 2013: <191>167790: .Mar 20 09:58:34: //8173/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Wed Mar 20 09:58:35 2013: <191>167791:
Wed Mar 20 09:58:35 2013: <191>167792: .Mar 20 09:58:34: cc_api_get_xcode_stream : 4534
Wed Mar 20 09:58:35 2013: <191>167793: .Mar 20 09:58:34: //8173/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:58:35 2013: <191>167794: Conference Id=0xE63, Source Interface=0x48A4F728, Source Call Id=8173,
Wed Mar 20 09:58:35 2013: <191>167795: Destination Call Id=8174, Disposition=0x0, Tag=0x0
Wed Mar 20 09:58:35 2013: <191>167796: .Mar 20 09:58:34: //8174/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
Wed Mar 20 09:58:35 2013: <191>167797: Conference Id=0xE63, Source Interface=0x4987FF98, Source Call Id=8174,
Wed Mar 20 09:58:35 2013: <191>167798: Destination Call Id=8173, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:58:35 2013: <191>167799: .Mar 20 09:58:34: //8173/80D1F4DC4306/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:58:35 2013: <191>167800: Conference Id=0xE63, Source Interface=0x4987FF98, Source Call Id=8174,
Wed Mar 20 09:58:35 2013: <191>167801: Destination Call Id=8173, Disposition=0x0, Tag=0xFFFFFFFF
Wed Mar 20 09:58:35 2013: <191>167802: .Mar 20 09:58:34: //8173/80D1F4DC4306/CCAPI/ccConferenceCreate:
Wed Mar 20 09:58:35 2013: <191>167803:
Wed Mar 20 09:58:35 2013: <191>167804: Call Entry(Conference Id=0xE63, Destination Call Id=8174)
Wed Mar 20 09:58:35 2013: <191>167805: .Mar 20 09:58:34: //8174/80D1F4DC4306/CCAPI/ccConferenceCreate:
Wed Mar 20 09:58:35 2013: <191>167816: Conference Id=0xE63, Call Id1=8173, Call Id2=8174
Wed Mar 20 09:58:35 2013: <191>167817: .Mar 20 09:58:34: //8173/80D1F4DC4306/CCAPI/ccCallNotify:
Wed Mar 20 09:58:35 2013: <191>167818: Data Bitmask=0x7, Call Id=8173
Wed Mar 20 09:58:35 2013: <191>167819: .Mar 20 09:58:34: //8174/80D1F4DC4306/CCAPI/cc_api_get_called_ccm_detected:
Wed Mar 20 09:58:35 2013: <191>167820: CallInfo(ccm detected=0)
Wed Mar 20 09:58:35 2013: <191>167821: .Mar 20 09:58:34: //8173/80D1F4DC4306/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:58:35 2013: <191>167822: Destination Interface=0x4987FF98, Destination Call Id=8174, Source Call Id=8173,
Wed Mar 20 09:58:35 2013: <191>167823: Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
Wed Mar 20 09:58:35 2013: <191>167824: Modem=0x2, Codec Bytes=160, Signal Type=2)
Wed Mar 20 09:58:35 2013: <191>167825: .Mar 20 09:58:34: //8173/80D1F4DC4306/CCAPI/cc_api_caps_ind:
Wed Mar 20 09:58:35 2013: <191>167826: Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Wed Mar 20 09:58:35 2013: <191>167827: Playout Max=1000(ms), Fax Nom=300(ms))
Wed Mar 20 09:58:35 2013: <191>167828: .Mar 20 09:58:34: //8173/80D1F4DC4306/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:58:35 2013: <191>167829: Destination Interface=0x4987FF98, Destination Call Id=8174, Source Call Id=8173,
Wed Mar 20 09:58:35 2013: <191>167830: Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:58:35 2013: <191>167831: Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=1860)
Wed Mar 20 09:58:35 2013: <191>167832: .Mar 20 09:58:34: //8174/80D1F4DC4306/CCAPI/cc_api_caps_ack:
Wed Mar 20 09:58:35 2013: <191>167833: Destination Interface=0x48A4F728, Destination Call Id=8173, Source Call Id=8174,
Wed Mar 20 09:58:35 2013: <191>167834: Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
Wed Mar 20 09:58:35 2013: <191>167835: Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=1860)
Wed Mar 20 09:58:35 2013: <191>167836: .Mar 20 09:58:34: //8174/80D1F4DC4306/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:58:35 2013: <191>167837: Call Id=8174
Wed Mar 20 09:58:35 2013: <191>167838: .Mar 20 09:58:34: //8174/80D1F4DC4306/CCAPI/cc_api_voice_mode_event:
Wed Mar 20 09:58:35 2013: <191>167839: Call Entry(Context=0x4BA73378)
Wed Mar 20 09:58:35 2013: <191>167840: .Mar 20 09:58:34: //8174/80D1F4DC4306/CCAPI/cc_api_call_connected:
Wed Mar 20 09:58:35 2013: <191>167841: Interface=0x4987FF98, Data Bitmask=0x1, Progress Indication=DESTINATION IS NON ISDN(2),
Wed Mar 20 09:58:35 2013: <191>167842: Connection Handle=0
Wed Mar 20 09:58:35 2013: <191>167843: .Mar 20 09:58:34: //8174/80D1F4DC4306/CCAPI/cc_api_call_connected:
Wed Mar 20 09:58:35 2013: <191>167844: Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Wed Mar 20 09:58:35 2013: <191>167845: .Mar 20 09:58:34: //8173/80D1F4DC4306/CCAPI/ccCallConnect:
Wed Mar 20 09:58:35 2013: <191>167846: Progress Indication=DESTINATION IS NON ISDN(2), Data Bitmask=0x1
Wed Mar 20 09:58:35 2013: <191>167847: .Mar 20 09:58:34: //8174/80D1F4DC4306/CCAPI/cc_api_get_called_ccm_detected:
Wed Mar 20 09:58:35 2013: <191>167848: CallInfo(ccm detected=0)
Wed Mar 20 09:58:36 2013: <191>167849: .Mar 20 09:58:34: //8173/80D1F4DC4306/CCAPI/ccCallConnect:
Wed Mar 20 09:58:36 2013: <191>167850: Call Entry(Connected=TRUE, Responsed=TRUE)
Wed Mar 20 09:58:36 2013: <191>167851: .Mar 20 09:58:34: //8173/80D1F4DC4306/CCAPI/ccCallNotify:
Wed Mar 20 09:58:36 2013: <191>167852: Data Bitmask=0x7, Call Id=8173
Wed Mar 20 09:58:36 2013: <191>167853: .Mar 20 09:58:34: //8174/80D1F4DC4306/CCAPI/cc_api_get_called_ccm_detected:
Wed Mar 20 09:58:36 2013: <191>167854: CallInfo(ccm detected=0)
Wed Mar 20 09:59:10 2013: <191>167855: .Mar 20 09:59:09: //8173/80D1F4DC4306/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:59:10 2013: <191>167856: Cause Value=16, Interface=0x48A4F728, Call Id=8173
Wed Mar 20 09:59:10 2013: <191>167857: .Mar 20 09:59:09: //8173/80D1F4DC4306/CCAPI/cc_api_call_disconnected:
Wed Mar 20 09:59:10 2013: <191>167858: Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Wed Mar 20 09:59:10 2013: <191>167859: .Mar 20 09:59:09: //8173/80D1F4DC4306/CCAPI/ccConferenceDestroy:
Wed Mar 20 09:59:10 2013: <191>167860: Conference Id=0xE63, Tag=0x0
Wed Mar 20 09:59:10 2013: <191>167861: .Mar 20 09:59:09: //8173/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:59:10 2013: <191>167862: Conference Id=0xE63, Source Interface=0x48A4F728, Source Call Id=8173,
Wed Mar 20 09:59:10 2013: <191>167863: Destination Call Id=8174, Disposition=0x0, Tag=0x0
Wed Mar 20 09:59:10 2013: <191>167864: .Mar 20 09:59:09: //8174/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Wed Mar 20 09:59:10 2013: <191>167865:
Wed Mar 20 09:59:10 2013: <191>167866: Conference Id=0xE63, Source Interface=0x4987FF98, Source Call Id=8174,
Wed Mar 20 09:59:10 2013: <191>167867: Destination Call Id=8173, Disposition=0x0, Tag=0x0
Wed Mar 20 09:59:10 2013: <191>167868: .Mar 20 09:59:09: //8173/80D1F4DC4306/CCAPI/cc_generic_bridge_done:
Wed Mar 20 09:59:10 2013: <191>167869: Conference Id=0xE63, Source Interface=0x4987FF98, Source Call Id=8174,
Wed Mar 20 09:59:10 2013: <191>167870: Destination Call Id=8173, Disposition=0x0, Tag=0x0
Wed Mar 20 09:59:10 2013: <191>167871: .Mar 20 09:59:09: //8173/80D1F4DC4306/CCAPI/ccCallDisconnect:
Wed Mar 20 09:59:10 2013: <191>167872: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Wed Mar 20 09:59:10 2013: <191>167873: .Mar 20 09:59:09: //8173/80D1F4DC4306/CCAPI/ccCallDisconnect:
Wed Mar 20 09:59:10 2013: <191>167874: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:59:10 2013: <191>167875: .Mar 20 09:59:09: //8173/80D1F4DC4306/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:59:10 2013: <191>167876:
Wed Mar 20 09:59:10 2013: <191>167877: Transfer Number Is Null
Wed Mar 20 09:59:10 2013: <191>167878: .Mar 20 09:59:09: //8174/80D1F4DC4306/CCAPI/ccCallDisconnect:
Wed Mar 20 09:59:10 2013: <191>167879: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Wed Mar 20 09:59:10 2013: <191>167880: .Mar 20 09:59:09: //8174/80D1F4DC4306/CCAPI/ccCallDisconnect:
Wed Mar 20 09:59:10 2013: <191>167881: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Wed Mar 20 09:59:10 2013: <191>167882: .Mar 20 09:59:09: //8174/80D1F4DC4306/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:59:10 2013: <191>167883: Transfer Number Is Null
Wed Mar 20 09:59:10 2013: <191>167884: .Mar 20 09:59:09: //8173/80D1F4DC4306/CCAPI/cc_api_get_transfer_info:
Wed Mar 20 09:59:10 2013: <191>167885: Transfer Number Is Null
Wed Mar 20 09:59:10 2013: <191>167886: .Mar 20 09:59:09: //8173/80D1F4DC4306/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:59:10 2013: <191>167887:
Wed Mar 20 09:59:10 2013: <191>167888: Disposition=0, Interface=0x48A4F728, Tag=0x0, Call Id=8173,
Wed Mar 20 09:59:10 2013: <191>167889: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:59:10 2013: <191>167890: .Mar 20 09:59:09: //8173/80D1F4DC4306/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:59:10 2013: <191>167891: Call Disconnect Event Sent
Wed Mar 20 09:59:10 2013: <191>167892: .Mar 20 09:59:09: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:59:10 2013: <191>167893:
Wed Mar 20 09:59:10 2013: <191>167894: .Mar 20 09:59:09: :cc_free_feature_vsa freeing 47B81CE0
Wed Mar 20 09:59:10 2013: <191>167895: .Mar 20 09:59:09: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:59:10 2013: <191>167896:
Wed Mar 20 09:59:10 2013: <191>167897: .Mar 20 09:59:09: vsacount in free is 1
Wed Mar 20 09:59:10 2013: <191>167898: .Mar 20 09:59:09: //8174/80D1F4DC4306/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:59:10 2013: <191>167899: Disposition=0, Interface=0x4987FF98, Tag=0x0, Call Id=8174,
Wed Mar 20 09:59:10 2013: <191>167900: Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Wed Mar 20 09:59:11 2013: <191>167901: .Mar 20 09:59:09: //8174/80D1F4DC4306/CCAPI/cc_api_call_disconnect_done:
Wed Mar 20 09:59:11 2013: <191>167902: Call Disconnect Event Sent
Wed Mar 20 09:59:11 2013: <191>167903: .Mar 20 09:59:09: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:59:11 2013: <191>167904:
Wed Mar 20 09:59:11 2013: <191>167905: .Mar 20 09:59:09: :cc_free_feature_vsa freeing 47B81C00
Wed Mar 20 09:59:11 2013: <191>167906: .Mar 20 09:59:09: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Wed Mar 20 09:59:11 2013: <191>167907:
Wed Mar 20 09:59:11 2013: <191>167908: .Mar 20 09:59:09: vsacount in free is 0
Wed Mar 20 10:02:11 2013: <191>167909: .Mar 20 10:02:09: //-1/xxxxxxxxxxxx/CCAPI/ccAppShutdownMode:
Wed Mar 20 10:02:11 2013: <191>167910: ccAppShutdownMode: remove it from the queue
Wilson
03-20-2013 12:23 PM
try to create voice class code 1 and assign it to dial-peer voip pointing to the call manager.
kindly find the below thread
https://supportforums.cisco.com/thread/2098768
also i find the below link for H323 troubleshooting
Anas
don't forget to rate the helpful posts
