10-31-2012 10:01 AM - edited 03-16-2019 01:57 PM
I have multiple auto attendants running on version 8.6.1 of CUCM. They all pick up half way through the first ring. Could someone point me in the right direction for instructions on changing the pickup time so caller ID will show?
Thank you
10-31-2012 10:05 AM
Are your auto attendants built in Unity connection, UCCX, something else?
If UCXN is it SIP integration?
Chris
10-31-2012 10:07 AM
Unity connection
11-02-2012 05:18 AM
What's the PSTN connectivity? I'm guessing FXO if you're worried about caller ID showing after the first ring.
voice-port 0/0/0
caller-id enable
If that doesn't get it, there are additional commands here:
Please remember to rate helpful responses and identify helpful or correct answers.
11-02-2012 06:27 AM
Could explain wgmhy would a delay on the pickup cause caller id to show?
Generally speaking you cant impose a delay on a call handler from ansewering your call.
