AutoAttendant CUE - call redirect problem
apapakons
Beginner
Beginner
Recently I have installed a cme and in addition I integrated a cue to  it. The problem is that when I call to the central AutoAttendant   number (10 digits number) the call redirection to external numbers fails  (I use customised script with  with "call-redirect" parameter  from aa  script editor .ie call-redirect external_number). On the contrary AA can  succesfully redirect all calls to internal  telephone numbers. I can show you the flow of a calll with a translations:
PROVIDER                                                        MY LAN
+30xxxxxxxxxxx  ------------------------------------------->  CME  ------------------------------------>CUE------>call redirect to  external number----->fails
country code                          translation                         10digits number                              10digits number
(+30) plus 10 digits                remove (+30)
number.
the dial-peers that I use are for AA are:
dial-peer voice 1002 voip
description **AA**
destination-pattern 2132144890
b2bua
session protocol sipv2
session target ipv4:"IP of CUE"
dtmf-relaysip-notify
codec g711ulaw
no vad
dial-peer voice 1003 voip
description ***incoming AA***
translation-profile incoming PSTN_INCOMING2    (removes +30 from the incoming calls from provider)
incoming called-number +302132144890
session target ipv4:195.167.16.153:5060
incoming called-number .
voice-class codec 1
dtmf-relay rtp-nte
no vad
Also:
telephony-service
           transfer-pattern 213214....
          call-forward pattern 213214....    (to allow call transfers and forwards to external numbers)
voice service voip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
Fianlly I have attached a log file of the command "debug ccsip messages" when I call the AA and trire to redirect my call.
May be I need an extra rule in dial-peer 1002, in order to add +30 to the extrenal number that the AA tries to reach and fails.The provider needs +30 (contry code) in front of each 10 digit number. I would really appreciate any help.
paolo bevilacqua
If provider needs country code, put country code.
First of all thanks Paolo for your help. The translation rule  that I used for my phones was
voice translation-rule 5
rule 1 /^\(..........\)$/ /+30\1/
voice translation-profile PSTN_OUTGOING
translate calling 5
So I added  +30 (area code) to the calling number of an outgoing call. In the case of Auto Attendant:
a)can I use the same translation profile? Do I translate the only the calling number which is the Auto Attendant 10 digit number (how should the translation rofile look like for AA)?
b)in which dial peer should I apply the dial-peer? in dial-peer 1002?
c)In the dial peer should I apply an outgoing or incoming translation profile?
Sorry for the question but I am a little bit confused.
I found a mistake in my custom aa script. I use the "call redirect" parameter to make the AA to redirect a call to an external number. I forgot  to add the digit '9' in front of the external number, so an outgoing dial-peer did not matched. Generally, I use 9 to get a dial tone for phones and the I remove it with translation rules.
After this change I tried to debug the dial peers to make sure the right outgoing dial-peer is used. Gladly I found out that the outgoing dial-peer for domestic calls was used:
voice translation-rule 1
rule 1 /^48\([012345].\)$/ /21321448\1/
rule 2 /^48\(6[12345]\)$/ /21321448\1/
rule 3 /^948\(..\)$/ /21321448\1/
rule 1 /^\(21321448[789].\)$/ /+30\1/
rule 2 /^\(213214486[56789]\)$/ /+30\1/
voice translation-rule 2
rule 1 /^9\(2.........\)$/ /\1/
rule 2 /^9\(.......\)$/ /210\1/
rule 3 /^9\(100\)$/ /100/
rule 4 /^9\(69........\)$/ /\1
translate calling 5
translate called 2
translate redirect-target 1
translate redirect-called 1
dial-peer voice 2 voip
corlist outgoing uselocal
description OUTGOING PSTN - ASTIKA
translation-profile outgoing PSTN_OUTGOING
destination-pattern 921........
session target ipv4:x.x.x.x
voice-class codec 1
dtmf-relay rtp-nte
no vad
This dial-peer works like a charm for all my phones, but it returns me a SIP ERROR 404 when the CUE AA redirects a call to an external number. The debug when AA redirects a call to an external number is:
May 27 13:03:58.048: //1420/03C74BD5ACBA/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:2132144813@X.X.16.153:5060 SIP/2.0
Via: SIP/2.0/UDP X.X.71.34:5060;branch=z9hG4bK325190B
Remote-Party-ID: <>2132144809@X.X.gr>;party=calling;screen=no;privacy=off
To: <2132144813>
Date: Mon, 27 May 2013 13:03:58 GMT
Call-ID: BA311B85-C60411E2-8CD8F11B-22DC6BD2@ims
namuseum_CUCME#X.X.gr
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 0063392725-3322221026-2897914903-3929223243
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1369659838
Contact: <2132144809>
Expires: 180
Allow-Events: telephone-event
Max-Forwards: 61
Alert-Info: <http://www.huawei.com/ring/>;info=pattern1
Content-T
namuseum_CUCME#undebug aype: application/sdp
Content-Disposition: session;handling=required
Content-Length: 246
v=0
o=CiscoSystemsSIP-GW-UserAgent 6555 109 IN IP4 X.X.71.34
s=SIP Call
c=IN IP4 X.X.71.34
t=0 0
m=audio 31284 RTP/AVP 8 101
c=IN IP4 X.X.71.34
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:20
May 27 13:03:58.064: //1420/03C74BD5ACBA/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
namuseum_CUCME#undebug allB
To: <2132144813>
Date: Mon, 27 May 2013 13:06:25 GMT
Call-ID: BA311B85-C60411E2-8CD8F11B-22DC6BD2@X.X.gr
CSeq: 101 INVITE
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Received:
SIP/2.0 404 Not Found
All possible debugging has been turned off
namuseum_CUCME#144809@X.X.gr>;tag=10CEAFC4-1376
To: <2132144813>;tag=7945F48C-1F29
CSeq: 101 INVITE
Reason: Q.850;cause=1
Content-Length: 0
May 27 13:03:58.064: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:2132144813@X.X.16.153:5060 SIP/2.0
namuseum_CUCME#60;branch=z9hG4bK325190B
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
How can the outgoing dial peer work for phones and fail for AA? Do I miss something?Thanks for any help.
