Banner on cisco 7942G
saul.reyes
Can i change the banner from telephone cisco 7942 and erase the directory number?
Attached the image and red line show the DN that need to erase from display
Chris Deren
I am assuming you have CUCM, if so then the number observed in upper right corner comes from "External phone number mask" field on the DN. If the filed is blank then the DN is put there.  If you want it to show something else then overwrite the external phone number mask.  Keep in mind though that depending no your system configuration the filed may also be used to populate caller ID on outbound calls.
Manish Gogna
You need to edit the "Line Text Label" field on the Directory number page on cucm.
Manish
Chris Deren
+5 to Chris.
Just to add that on cucme you have to configure "description" under ephone-dn config to let the phone to show that "banner"
Carlo
Please rate all helpful posts "The more you help the more you learn"
thanks
the External phone number mask was a solution.
