ā06-20-2018 10:32 AM - edited ā03-17-2019 01:03 PM
I am just deploying a BE4000 (ISR4321).
1. We make the https://be4000.cisco.com/deploy settings on Cloud > users > phones > extensions > T1 > ISP send digits .., bar bar bar
2. Generate the code on Cisco Smart Account
3. Connect the g0/0 port to Internet
4. Enter the code and enter the Serial Number of BE4000 device
5. The Cloud can recognize the BE4000 and pushing the configurations to the BE4000.
6. Got the error check on PVDM <--- Any idea?
(That is the bundle hardware with T1 card with PVDM 64M)
Solved! Go to Solution.
ā06-20-2018 11:07 AM - edited ā06-20-2018 11:09 AM
Have you made sure that the NIM card has the PVDM installed on it ?
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvi58820/?reffering_site=dumpcr
ā06-20-2018 11:16 AM
ā06-21-2018 01:29 AM
ā06-20-2018 10:36 AM
ā06-20-2018 10:55 AM
ā06-20-2018 10:57 AM
Here you are
ā06-20-2018 11:14 AM
Sure, I can see the PVDM 64 during my console on booting up the BE4000 and the light is correct, just the Cloud cloud not detect my bundle PVDM-64 of T1 card
ā06-21-2018 12:28 AM
Yes, the PVDM is on the appliance motherboard. It have, but is cloud not verify on the Cloud processing ...
ā06-21-2018 07:53 AM
Actually, the on-borad pvdm-64 is enough for the T1, less conference & less transcode.
1. Can I skip the deploy check and use the on-board pvdm for the T1 too?
2. I use the BE4000 for replacement of CME. Can use the ISR4Kās PVDM4 on BE4000? Same?
ā06-21-2018 08:02 AM
ā06-20-2018 11:03 AM
Hi there
Could you power-cycle the BE4000 and issue the "Restart Deployment" action ?
Hope this helps!
Cheers
Rath!
***Please rate helpful posts***
ā06-20-2018 10:37 AM
Hi there
Can you share the screenshot of error message ?
Hope this helps!
Cheers
Rath!
