01-22-2015 12:26 AM - edited 03-17-2019 01:41 AM
is there any cisco published be6k and be7k comparision chart? i don't find it online.
Solved! Go to Solution.
01-22-2015 01:02 AM
There is no cisco document i could find comparing the two, basically it would require checking the datasheet of both Products and comparing them. However, the following link pretty much covers what you are looking for
https://gkelegha.wordpress.com/2014/01/26/be6000-vs-be7000/
Manish
01-22-2015 01:02 AM
Manish
01-22-2015 01:11 AM
Hi Manish,
Thanks for your response. I did find the same link. However, it would have been good to have a certified doc from Cisco.
01-22-2015 06:19 AM
The main difference is the UCS platform type and sizing of the applications, all of which is documented on the data sheets.
