Bind username to incoming caller ID (CLI from Mobile phones)
Hi all, I would like to associate a name to an incoming caller ID from a mobile phone. I have about 20 mobile phone numbers that when they call in I would like to see a name instead of  a number  displayed on the Cisco phone. I believe using mobility with SNR would be one way of setting this up, though I have not tried it yet.
Does anyone have any suggestions?
Chris Deren
Jonathan,
Yes, Cisco Mobile Connect (SNR) would give you this ability, basically the call would appear on other phones as it is coming from internal destination. There is no other way of adjusting the name.
HTH,
Chris
paolo bevilacqua
You can use my script number 2 name for the purpose. It can pull names from a flat file, or http server. Full details are at
www.ciscoscripts.com
