01-23-2012 07:58 AM - edited 03-16-2019 09:09 AM
Hi all, I would like to associate a name to an incoming caller ID from a mobile phone. I have about 20 mobile phone numbers that when they call in I would like to see a name instead of a number displayed on the Cisco phone. I believe using mobility with SNR would be one way of setting this up, though I have not tried it yet.
Does anyone have any suggestions?
01-23-2012 08:07 AM
Jonathan,
Yes, Cisco Mobile Connect (SNR) would give you this ability, basically the call would appear on other phones as it is coming from internal destination. There is no other way of adjusting the name.
HTH,
Chris
01-23-2012 08:50 AM
You can use my script number 2 name for the purpose. It can pull names from a flat file, or http server. Full details are at
www.ciscoscripts.com
