07-12-2011 04:57 AM - edited 03-16-2019 05:54 AM
Dear Team,
The BLF-SD light is always on one IP phone only. All the others are woking fine.
Tried rebooting/reseting/reconfiguring the IP Phone, still no avail.
Also the symbol on the IP Phone is a little different.
Usually the symbol is a Phone on top of the Speed Dial symbol.
Here its like - SpeedDial -> Phone -> and then there is "x" inside the phone.
Have any of you faced this issue before.
Shabeeb Mohammed
Solved! Go to Solution.
07-12-2011 07:31 AM
Do Not Disturb is turned on for that DN.
07-12-2011 07:31 AM
07-12-2011 10:19 PM
Dear Jonathan,
Thanks a ton.
Regars
Shabeeb
11-03-2017 02:04 AM
This is awesome. Thanks a lot
