BLF SD... red light is always on!!!
shabeebmohammed
Dear Team,
The BLF-SD light is always on one IP phone only. All the others are woking fine.
Tried rebooting/reseting/reconfiguring the IP Phone, still no avail.
Also the symbol on the IP Phone is a little different.
Usually the symbol is a Phone on top of the Speed Dial symbol.
Here its like - SpeedDial -> Phone -> and then there is "x" inside the phone.
Have any of you faced this issue before.
Shabeeb Mohammed
Jonathan Schulenberg
Do Not Disturb is turned on for that DN.
Dear Jonathan,
Thanks a ton.
Regars
Shabeeb
This is awesome. Thanks a lot
