11-29-2009 09:29 PM - edited 03-18-2019 10:51 AM
Here is the steps I followed
CUCM version 7.1.3-10000-11
IP Phone- 7961 and also tried on 7945 same results
BLF does not work but speed dial is working! what am I missing here
Thanks for your help in advance
Solved! Go to Solution.
11-30-2009 06:56 AM
Check the configuration of the Device...
Go to "Protocol Specific Information" and under SUBSCRIBE Calling Search Space you need set a valid CSS to reach "Internal" number
Hope this help!
Alberto
11-29-2009 10:03 PM
have you checked that that Subscribe Calling Search Space on the phone or user is set and has the required access?
Paul
11-30-2009 06:30 AM
Thanks Paul
I did try putting the CSS on the user (I have css on the phone which has access to all partitions) which I didnot configure before and reset the phones but no change in BLF! still BLF is not woking!!
11-30-2009 06:56 AM
Hope this help!
Alberto
05-19-2013 08:26 AM
Hi.. It worked from me as well. But for me since I had extension mobility, I had to select the BLF presence Group under UserManagemet ---> end user. Also I had to select an appropriate value for SUBSCRIBE Calling Search Space in the End user page.
Bejoy Thomas
12-08-2015 08:39 AM
this corrected my issue on the 8851 models as well - forgot about this drop down option. Thanks for posting it.
02-28-2018 02:16 PM
This worked for me. Thanks!
07-09-2019 10:39 AM
This was the missing part to making the BLF light come on when that person is on the phone for me. I wouldn't have made the connection with SUBSCRIBE Calling Search Space for the BLF.
08-21-2019 04:38 AM
11-21-2019 05:00 AM
Thank you - Bang on fixed my problem :)
11-30-2009 07:53 AM
Bingo
Its working
Appreciated your help
09-05-2010 06:04 PM
Bingo from me, too!!!
ya the man!!
02-03-2015 01:31 PM
That worked, thank you.
