BRI activation
gabiulici
      Hii,
I want to activate BRI for a video Conference ( Athera Vega X5 ), any information/steps will be very helpful.
27 Replies 27
Hi Gabriel,
You do not need an extra license for activating BRI card. Did u try connecting straight cable ?
can u  share the show version and sh license feature /show license[for ISR G2] all from the router?
regds,
aman
Feature name             Enforcement  Evaluation  Subscription   Enabled  RightToUse
ipbasek9                 no           no          no             yes      no
securityk9               yes          yes         no             no       yes
uck9                     yes          yes         no             yes      yes
datak9                   yes          yes         no             no       yes
gatekeeper               yes          yes         no             no       yes
SSL_VPN                  yes          yes         no             no       yes
ios-ips-update           yes          yes         yes            no       yes
SNASw                    yes          yes         no             no       yes
hseck9                   yes          no          no             no       no
cme-srst                 yes          yes         no             no       yes
WAAS_Express             yes          yes         no             no       yes
UCVideo                  yes          yes         no             no       yes
Hi Gabriel,
there seems to be physical layer connectivity between NT1 [ISDN Terminal Device] and VIC-BRI  card.try connecting straight cable.As per the snapshot , u are using cross-over cable.
can u share the config of router ?
regds,
aman
White orange
White blue
Orange
blue
White green
White green
blue
White orange
White blue
orange
6
green
6
green
7
White brown
7
White brown
8
brown
8
brown
! Last configuration change at 15:20:26 UTC Fri Jan 17 2014
version 15.2
service password-encryption
hostname test
boot-start-marker
boot-end-marker
card type e1 0 0
logging buffered 51200 warnings
no aaa new-model
network-clock-participate wic 0
network-clock-participate wic 2
network-clock-select 1 E1 0/0/0
ip cef
ip dhcp excluded-address xxxxx
ip dhcp pool ccp-pool
import all
network xxxxx xxxxxxx
default-router xxxx
lease 0 2
no ipv6 cef
isdn switch-type primary-net5
crypto pki trustpoint TP-self-signed-xxxxxx
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-xxxxxxx
revocation-check none
rsakeypair TP-self-signed-xxxxxx
crypto pki certificate chain TP-self-signed-xxxxxxxx
certificate self-signed 01 nvram:IOS-Self-Sig#1.cer
voice-card 0
license udi pid xxxxxxx1/K9 sn xxxxxxx
hw-module pvdm 0/0
hw-module sm 1
username admin privilege 15 secret 4 xxxxxxxxxxxxxxxxxxxxxxxxxxxx2
redundancy
controller E1 0/0/0
pri-group timeslots 1-31 service mgcp
controller E1 0/0/1
controller E1 0/0/2
controller E1 0/0/3
pri-group timeslots 1-10,16 service mgcp
no ip rcmd domain-lookup
ip rcmd rsh-enable
ip rcmd remote-host admin xxxxx root enable
ip rcmd remote-host routeradmin xxxx admin
ip ssh version 2
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address x.x.x.x x.x.x.x
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface BRI0/2/0
no ip address
isdn switch-type basic-net3
isdn tei-negotiation first-call
isdn layer1-emulate network
isdn incoming-voice voice
isdn bind-l3 ccm-manager service mgcp
line-power
interface BRI0/2/1
no ip address
line-power
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 x.x.x.x
snmp-server community xxxxxxxx
snmp-server enable traps entity-sensor threshold
Hi Gabriel,
config seems to be OK.
Is Layer1 Status still showing Deactivated? If yes,please try changing the cable.
Did u ever try changing NT1 also?
regds,
aman
Hii GUys,
I change the cable, make a new one but the same. Maybe I have to bay a new cable because i don't understand what is wrong.....
Omerpal are you sure is the right patch ???
Hi Gabriel,
Cable could be one of the cause but u have already tried changing it .
Did u ever try changing NT1 ?
regds,
aman
No i don't tray NT1.
Hiii.
I find some information, on the router I have a ISDN BRI S/T 1  (2nd generation two port BRI voice interface daughtercard on Slot 0 SubSlot 2 )
and I find I need a ISDN BRI 0 NT1 in order to work with my video Conference Aethra Vega X5.
Maybe I need to buy a NT1 to put between my router and the videoconference, I change 10 times the cable but still not working.
I am not sure what card I need for Aethra Vega X5??????????
Th for help:)
http://www.cisco.com/en/US/prod/collateral/modules/ps5949/data_sheet_c78_439537.pdf
http://hw-server.com/constrc/atm_prog_lpt_shift/programmer.html
Hi Gabriel ,
If your ISDN service provider is giving U-interface , then, u do not need NT-1 , it can directly plug into device with U-interface.
If your router has S/T interfcae , then , u need NT1 for interface conversion.
regds,
aman
I have  2921 with 3 E1 lines and I have ISDN BRI S/T 1 and from Port 0   I want to connect directly to the Video Conference.
Stil working on this issues.
show interfaces BRI  0/2/0
BRI0/2/0 is up, line protocol is down (spoofing)
  Hardware is Voice NT or TE BRI
  MTU 1500 bytes, BW 64 Kbit/sec, DLY 20000 usec,
  Encapsulation VOICE, loopback not set
  Keepalive set (10 sec)
  Last input 4w3d, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     3 packets input, 19 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     16 packets output, 123 bytes, 0 underruns
     0 output errors, 0 collisions, 21 interface resets
     0 unknown protocol drops
     29 carrier transitions
show version
3 Gigabit Ethernet interfaces
104 Serial interfaces
2 ISDN Basic Rate interfaces
1 terminal line
4 Channelized E1/PRI ports
show controller bri 0/2/0
BRI unit 9:
layer 1 operating in LT-S mode.
Layer 1 is DEACTIVATED. (ISDN L1 State G1)
D Channel Information:
idb at 0x21B6BD70, driver data structure at 0x3C832C08
Infineon Chip Version 0x1
Infineon Registers:
Int. Status Register [ISTA]=0x00, Aux. Int. [AUXI]=0x00
D-channel: Int. Status Reg: [ISTAD]=0x00, Status. Reg: [STARD]=0x40
Mode Reg: [TR_MODE]=0x03
Transceiver Reg: [TR_CONF0]=0x00
Test mode Reg: [TMD]=0x00
IOM Control Reg: [IOM_CR]=0x08
Status Register [STAR]=0x40, Mode Register [MODED]=0xCA
Serial Data Strobe Control Reg: [SDS1_CR]=0x00, [SDS2_CR]=0x00
RX Buffer Descriptor is at 0x3C832F24, Buffer size 1524
pak=0x22BE0038 data_ptr=0xE25E654 partial_size=0x0
