BRI trunk-group failover
Youssef Aoufi
Level 3
Level 3
Hi there,
I have 4 BRI ports on two Vwic cards.
I put all the bri interfaces on a single trunk-group without a hunt scheme.
When all BRI are connected everything's working ok. When a BRI is busy, the outbound call is directly routed through another port.
The problem is when one BRI is disconnected (unplugged) or there is a telco problem, the call stucks is this port and the call doesn't failover to the second BRI.
trunk group 1
description TRUNK for BRI 0/0/1 0/1/0 0/1/1
interface BRI0/0/1
no ip address
isdn switch-type basic-net3
isdn point-to-point-setup
isdn incoming-voice voice
isdn static-tei 0
trunk-group 1
interface BRI0/1/0
no ip address
isdn static-tei 0
trunk-group 1
interface BRI0/1/1
no ip address
isdn static-tei 0
trunk-group 1
dial-peer voice 10 pots
trunkgroup 1
description utliser pour les appels vers FIXE BELGIQUE
translation-profile outgoing APPELS_SORTANTS
destination-pattern 0........$
progress_ind setup enable 3
progress_ind alert enable 8
direct-inward-dial
forward-digits all
Thank you in advance
12 Replies 12
Chris Deren
Use cable-detect
To enable cable polling on an analog Foreign eXchange Office (FXO) voice port, use the cable-detect command in voice port configuration mode. To disable cable polling, use the no form of this command.
cable-detect
no cable-detect
Syntax Description
This command has no arguments or keywords.
Command Default
Cable polling on an analog FXO voice port is disabled.
Command Modes
Command History
Release
Modification
15.1(1)T
This command was introduced.
Usage Guidelines
The FXO port is in the busyout state if the Digital Signal Processor (DSP) detects that no cable is connected between the analog Foreign eXchange Subscriber (FXS) and FXO ports. If you have configured the no cable-detect command and the analog FXO voice port is in busyout state because no cable is connected, the Cisco IOS software stops polling the cable connection. The analog FXO voice port remains in the busyout state until you use the shutdownand no shutdowncommands to switch the analog FXO voice port to the idle state. The cable-detect command supports loop start and Central Automatic Message Accounting (CAMA) signaling.
The cable-detect command can be configured on the following analog FXO voice interface cards (VICs):
  • VIC2-4FXO
  • EM-HDA-6FXO
  • EM-HDA-3FXS-4FXO
  • EM-HDA-4FXO
Examples
The following example shows how to enable cable polling on an FXO voice port:
Router> enable
Router# configure terminal
Router(config)# voice-port 1/2/3
Router(config-voiceport)# cable-detect
Chris
Thanks Chris for your answer ,
I'm not using FXO ports, but BRI ports.
paolo bevilacqua
In the past, someone had posted a solution for this issue, that very intuitively involved configuring custom cause codes.
I did not have a chance to test it, but I think you can still find the post using a search.
In the meanwhile I think the best approach is to obtain solid service from telco.
Thanks Paolo,
I can assure you that i have searched the web and the cisco forum befor posting this question, but i haven't found a solution yet.
regards
How about removing trunk group and building multiple dial peers with preferences, does that result in the same issue?
Chris
Hi chris,
I think using multiple dial-peers with different preferences in conjunction with the command : no dial-peer outbound status-check pots resolves the problem.
But i have a large number of dial-peers and using this we lose the benefit of trunk-groups.
regards
Hi Paolo ,
My IOS is:
Version 15.2(3)T, RELEASE SOFTWARE (fc1)
Have you configured voice class cause code ?
hi,
No, and i don't know why and how to use it.
regards
Look int the config poste in the thread referenced.
Youssef,
This is the command I have used in the past....try it
trunk group XXXX
max-retry 4
voice-class cause-code 34
hunt-scheme round-robin both down
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
