Bug - Chrome no longer works for drop-down menus on CUCM admin page
voip7372
Level 4
Level 4
I saw there was already a bug listed for this on Cisco's bug site, but does anyone know of a workaround to make the drop-down menus work again with the Google Chrome browser?  For now, I've had to switch back to using Internet Explorer when I need to log into the CUCM admin page and make changes :-(
This was not working in the Firefox browser either, but this morning Firefox updated to 43.0 and the menus on the CUCM admin page work again.   Maybe there will be a Chrome update coming soon as well to fix this.  I hope.
2 Accepted Solutions
Rajan
Try these to see if that helps.
https://supportforums.cisco.com/discussion/11327381/cucm-86-and-chrome
Rajan
voip7372
Level 4
Level 4
FYI.   My Chrome browser updated to version 47.0.2526.111 m today and the drop-down menus in CUCM work again, without the need for the 'IE Tab' extension :-)
All is well and back to normal now.
6 Replies 6
Rajan
Rajan
Ok, so I guess for now I can use the IE Tab extension for Chrome and when Chrome is fixed, I can remove it.   Thanks
Jmeier,
Here's an article that explains how to do that.
Manish Gogna
Its because of the following bug which affects 9.x and higher versions
https://tools.cisco.com/bugsearch/bug/CSCuu82530/?reffering_site=dumpcr
There is a workaround available for Firefox but none for Chrome  is listed.
Manish
My Firefox browser updated to 43.0 this morning and it works fine again, with no add-ons or special extensions needed.  Chrome also updated this morning to a new version, but it still doesn't work unless I use the 'IE Tab' extension.  I can use it like this for now...
voip7372
Level 4
Level 4
