10-20-2009 09:14 AM - edited 03-15-2019 08:09 PM
cm version 5.1 - Anyone have any tools or advice to import Route Patterns?
10-22-2009 05:00 AM
To export route patterns, use route plan
report.
To import route patterns, it is not yet supported till version 6.1, however is supported in
version 7.x.
11-30-2010 12:54 PM
I need to updated 800 Route Patterns. I have exported them to .csv and am trying to find a way to import them (hopefully) after I update them in Excel.
I am running CCM 7.1.3. I could not find anything in BAT.
11-30-2010 04:15 PM
what fields need updating?
I know where to get a tool to update/insert via csv, saschamonteiro@hotmail.com
11-30-2010 07:00 PM
You need to use the import/export option
12-01-2010 08:41 AM
Great information! I found the doc, Selected Export, Selected Route Patterns, checked the dependencies box and exported it. After un-tarring the file with 7-Zip I found the routepattern.csv with the information I needed. I will be editing the gateway and then running the tar routine again and importing.
Thanks so much for the help.
08-04-2014 12:54 PM
I need to update 300 route patterns. I am facing an issue when I try to import the file. No erros are recorded but the rp are not updated.
Luis.
