06-28-2016 06:03 AM - edited 03-17-2019 07:22 AM
Deall All,
Since, I am poor at cucm basic optional features, I would like to know how/when does busy trigger feature help me. I referred a couple documents but not satisfied.
Thank you in advance
Solved! Go to Solution.
06-28-2016 07:30 AM
Just try to think that if there is no busy trigger parameter, how you will instruct CM to invoke call forward - busy?
- Vivek
06-28-2016 10:09 AM
Adding to what Vivek said, lets say you have a manager who does not want Call Waiting on his/her phone while talking to someone hence you will need to adjust the Busy Trigger to 1 for their device in this case.
Similarly, lets say you have a Receptionist working during holiday when there are no other staff so you would want to increase the Busy Trigger to something like 5 or 6 depending on the need so that callers do not go to voicemail or some other destination and kept on wait while the receptionist gets free from existing calls.
So think this setting as a way you want to treat the callers when the person they are trying to call is busy on an existing call be it forwarding their call to Voicemail, some other destination, or stay on wait etc.
Deepak
06-28-2016 06:16 AM
It's about simultaneous call capacity phone can handle (including incoming and outgoing call) at a time and once respective count triggers, you have an option to invoke Call Forward - Busy if configured.
- Vivek
06-28-2016 06:30 AM
Vivek, you're thinking about "maximum number of calls", not busy trigger. Busy trigger only affects INCOMING calls, not outgoing.
Maximum Number of Calls |
You can configure up to 200 calls for a line on a device, with the limiting factor being the total number of calls that are configured on the device. As you configure the number of calls for one line, the calls that are available for another line decrease. The default specifies 4. If the phone does not allow multiple calls for each line, the default specifies 2. For CTI route points, you can configure up to 10,000 calls for each port. The default specifies 5000 calls. Use this field in conjunction with the Busy Trigger field.
Busy Trigger |
This setting, which works in conjunction with Maximum Number of Calls and Call Forward Busy, determines the maximum number of calls to be presented at the line. If maximum number of calls is set for 50 and the busy trigger is set to 40, incoming call 41 gets rejected with a busy cause (and will get forwarded if Call Forward Busy is set). If this line is shared, all the lines must be busy before incoming calls get rejected. Use this field in conjunction with Maximum Number of Calls for CTI route points. The default specifies 4500 calls. |
06-28-2016 06:35 AM
Thanks JaVa, somehow I got it merged. Thanks for correcting the same.
- Vivek
06-28-2016 07:19 AM
Thank you Vivek & Jaime.
The above info talks about how it works & what it does, but can you guys help me why is it required?
06-28-2016 07:20 AM
A sample scenario would be appreciated..
06-28-2016 07:30 AM
- Vivek
06-28-2016 10:09 AM
Deepak
06-28-2016 10:25 AM
Thank you Vivek/Jaime/Deepak for details explanation.
Now it is very clear to me, apprecaited..
