c1760 - No output for voice port summary cmd
rkishanb
Hello & Greetings.
I am using an older c1760 router. When I run the cmd, sh voice port summ, I get no output. Also, while trying to cfg pri-group timeslots, I am getting err msg. Please see the following cmds / output and help me understand. Thanks!
Kishan
CME#sh voice port summary
IN OUT
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
CME(config-controller)#pri-group timeslots 1-24
%Configure Controller tdm clock first
Hardware Info:
WIC/VIC Slot 0:
T1 (1 port) Multi-Flex Trunk WAN daughter card
Hardware revision 1.0 Board revision B0
Serial number 0035050460 Part number 800-03568-04
FRU Part Number VWIC-1MFT-T1=
WIC/VIC Slot 1:
Dual FXO M1 Voice Interface Card
Serial number 0027350431 Part number 800-05298-01
FRU Part Number VIC-2FXO-M1=
Rajan
Can you configure clocking for the vwic card as per the below document and then try to configure PRI.
http://www.cisco.com/c/en/us/support/docs/routers/2600-series-multiservice-platforms/48567-clocking.html#v
Rajan
Rajan
You can refer the below document for the complete config:
http://www.compucanjes.com/drivers/Condiguracion.pdf
sreeharikt
Before configuring channel-groups, under controller configuration, try "clock source line" command.
For Example:
Router(config)# controller t1 0
Router(config-controller)# clock source line primary
Router(config)# controller t1 1
Router(config-controller)# clock source line secondary
