Call duration limitation
qazzaq201
Hi experts,
We faced a problem that some user don't hang up the call so there will have some ports be always occupied...
Is there any possibility to limit call duration on ISR 4431 or 3945?
Like if call duration exceed 1 hour, ISR will initiatively disconnect the call..
thanks in advance
Ratheesh Kumar
Service parameter configuration can help you achieving this. But its a global configuration and affects all calls, both internal and external.
This parameter specifies the minutes that a call can remain active before Cisco CallManager clears it. A value of zero disables the timer.
  This is a required field.
  Default:  720
  Minimum:  0
  Maximum:  35791
  Unit: min
You need to write down a TCL script. Please check out a similar post
https://supportforums.cisco.com/t5/ip-telephony/how-to-set-timer-to-force-disconnected-outgoing-incoming-call/td-p/1352838
Cheers
Rath!
***Please rate helpful posts***
R0g22
Nothing native on the IOS. You can use a TCL script. Open up a TAC case and see if they can provide you one. It is a generic template script that should work fine but is not TAC supported. Alternatively you can post at Cisco Developer Forums. Someone there should be able to help you.
Ratheesh Kumar
  Default:  720
  Minimum:  0
  Maximum:  35791
  Unit: min
Cheers
Rath!
Muhammad Yaseen
Hi i have a same concern of Call duration,
our requirment just littil bit change, we need to sagregate in 3 mode, User-1 just active for 5 min, User-2 just active for 10 min and User-3 active with long duration.
please help on this can we sagregate or not?
