Hi experts,
We faced a problem that some user don't hang up the call so there will have some ports be always occupied...
Is there any possibility to limit call duration on ISR 4431 or 3945?
Like if call duration exceed 1 hour, ISR will initiatively disconnect the call..
thanks in advance
Solved! Go to Solution.
Service parameter configuration can help you achieving this. But its a global configuration and affects all calls, both internal and external.
This parameter specifies the minutes that a call can remain active before Cisco CallManager clears it. A value of zero disables the timer. | |
This is a required field. | |
Default: 720 | |
Minimum: 0 | |
Maximum: 35791 | |
Unit: min |
You need to write down a TCL script. Please check out a similar post
Cheers
Rath!
***Please rate helpful posts***
Default: 720 | |
Minimum: 0 | |
Maximum: 35791 | |
Unit: min |
Cheers
Rath!
