Call forwarding to external number SIP SRST no sound
Jakub Stroinski
Level 4
Level 4
Below is the current config
Call comes in, goes to 2000 (auto-attendant UCCX trigger in CUCM)
When CUCM is down, 2000 doesnt exti, calls go to 2339 and if no answer to 2340 under SRST mode
All of this works
Now, if I replace 2340 with a mobile number i.e. 95145551234, the mobile phone rings, but when answered, there is no sound (either direction) and the call is disconnected after 60 seconds.
Ideas gentlemen?
boot system flash:c2800nm-adventerprisek9-mz.151-4.M10.bin
ip dhcp excluded-address 172.16.16.1 172.16.16.20
ip dhcp pool voice
 import all
 network 172.16.16.0 255.255.255.0
 default-router 172.16.16.1
 option 150 ip 172.16.16.4
 dns-server 10.10.0.5
 lease 0 2
voice service voip
 ip address trusted list
  ipv4 72.55.168.18
  ipv4 172.10.10.0 255.255.255.0
  ipv4 172.16.16.0 255.255.255.0
 ip address trusted call-block cause not-in-cug
 gcid
 clid substitute name
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 no supplementary-service sip moved-temporarily
 no supplementary-service sip refer
 sip
  e911
  registrar server expires max 600 min 60
  transport switch udp tcp
  asserted-id ppi
  midcall-signaling passthru
  no call service stop
voice class sip-profiles 1
 request INVITE sip-header From modify "From: (.*<)(.*>)" "From: \"Cisco Lab\" <\2"
voice register global
 timeouts interdigit 5
 system message SRST active
 max-dn 20
 max-pool 20
voice register pool  1
 translation-profile outgoing SRST
 id network 172.16.16.0 mask 255.255.255.0
 alias 1 2000 to 2339
 dtmf-relay rtp-nte cisco-rtp
 call-forward b2bua noan 2340 timeout 15
 codec g711ulaw
voice translation-rule 1
 rule 1 /.*/ /2000/
voice translation-rule 2
 rule 1 /.*/ /5143605555/
voice translation-rule 3
 rule 1 /^9\(.*\)/ /\1/
voice translation-rule 4
 rule 1 /2000/ /2339/
voice translation-profile INCOMING
 translate called 1
voice translation-profile OUTGOING
 translate calling 2
 translate called 3
voice translation-profile SRST
 translate called 4
license udi pid CISCO2811 sn FTX1126AXXX
interface FastEthernet0/0
 description DHCPVoIP
 ip address 172.16.16.2 255.255.255.0
 duplex auto
 speed auto
interface FastEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 172.16.16.1
access-list 23 permit 172.16.16.0 0.0.0.255
access-list 23 permit 172.10.10.0 0.0.0.255
access-list 23 permit 10.10.0.0 0.0.0.255
dial-peer voice 1 voip
 translation-profile incoming INCOMING
 session protocol sipv2
 session target ipv4:172.16.16.4
 incoming called-number 12345678
 dtmf-relay cisco-rtp rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 3 voip
 translation-profile outgoing OUTGOING
 destination-pattern 9[2-9]..[2-9]......
 session target ipv4:72.55.168.18
 no voice-class sip early-offer forced
 voice-class sip profiles 1
 dtmf-relay rtp-nte cisco-rtp sip-kpml sip-notify
 codec g711ulaw
 no vad
dial-peer voice 4 voip
 destination-pattern 2...
 codec g711ulaw
 no vad
sip-ua
 credentials username 12345678 password 7 XXXXX realm montreal3.voip.ms
 authentication username 12345678 password 7 XXXXX realm montreal3.voip.ms
 registrar 1 dns:montreal3.voip.ms expires 300
 registrar 2 ipv4:172.16.16.2 expires 3600
call-manager-fallback
 max-conferences 8 gain -6
 transfer-system full-consult
 ip source-address 172.16.16.2 port 2000
 max-ephones 1
 max-dn 1 octo-line
40 Replies 40
Sorry about that
No Inactive Message Discriminator.
Console logging: disabled
Monitor logging: disabled
Buffer logging: level debugging, 5123 messages logged, xml disabled,
filtering disabled
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
Persistent logging: disabled
No active filter modules.
Trap logging: level informational, 49 message lines logged
Log Buffer (30000000 bytes):
003586: Dec 5 23:24:00.877: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceHandleConnAgeing: Holder=0x4AAA07D4 Connection=0x4AACDA48, addr=172.16.16.22, port=5060, connid=3 has been REFRESHED
003587: Dec 5 23:24:00.877: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportSetAgeingTimer: Aging timer initiated for holder=0x4AAA07D4,addr=172.16.16.22
003588: Dec 5 23:24:02.793: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [72.55.168.18]:5060, local_address:[ - ]
003589: Dec 5 23:24:02.793: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
003590: Dec 5 23:24:02.793: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x4AACC054
003591: Dec 5 23:24:02.793: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x4AACC054, addr=72.55.168.18, port=5060, local_addr=, connid=4, transport=UDP
003592: Dec 5 23:24:02.793: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:12345678@172.16.16.2:5060 SIP/2.0
Via: SIP/2.0/UDP 72.55.168.18:5060;branch=z9hG4bK61ccf8f1;rport
Max-Forwards: 70
From: "Jakub Stroinski" <sip:5147221234@72.55.168.18>;tag=as2898aaf9
To: <sip:12345678@172.16.16.2:5060>
Contact: <sip:5147221234@72.55.168.18:5060>
Call-ID: 6b86e46b0f1b34bc5887abbf5851c960@72.55.168.18:5060
CSeq: 102 INVITE
User-Agent: voip.ms
Date: Sat, 05 Dec 2015 23:24:02 GMT
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH
Supported: replaces, timer
Remote-Party-ID: "Jakub Stroinski" <sip:5147221234@72.55.168.18>;party=calling;privacy=off;screen=no
Content-Type: application/sdp
Content-Length: 270
v=0
o=root 1739324761 1739324761 IN IP4 72.55.168.18
s=voip.ms
c=IN IP4 72.55.168.18
t=0 0
m=audio 16010 RTP/AVP 0 18 101
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
003593: Dec 5 23:24:02.793: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
003594: Dec 5 23:24:02.797: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x4D195650) with key=[244] to table
003595: Dec 5 23:24:02.797: //-1/000000000000/SIP/Info/sipSPI_ipip_vcc_Initialization: Entry...
003596: Dec 5 23:24:02.797: //-1/000000000000/SIP/Info/ccsip_offer_ans_init:
003597: Dec 5 23:24:02.797: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 72.55.168.18,Port 5060, Transport 1, SentBy Port 5060
003598: Dec 5 23:24:02.797: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling reg_invoke_ip_first_hop()
003599: Dec 5 23:24:02.797: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling ip_best_local_address()
003600: Dec 5 23:24:02.797: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: return addr 172.16.16.2
003601: Dec 5 23:24:02.797: //-1/1AD0BA3880F0/SIP/State/sipSPIChangeState: 0x4D195650 : State change from (STATE_NONE, SUBSTATE_NONE) to (STATE_IDLE, SUBSTATE_NONE)
003602: Dec 5 23:24:02.797: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 72.55.168.18,Port 5060, Transport 1, SentBy Port 5060
003603: Dec 5 23:24:02.797: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone EST to SIP default timezone = GMT
003604: Dec 5 23:24:02.797: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 72.55.168.18,Port 5060, Transport 1, SentBy Port 5060
003605: Dec 5 23:24:02.797: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling reg_invoke_ip_first_hop()
003606: Dec 5 23:24:02.801: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling ip_best_local_address()
003607: Dec 5 23:24:02.801: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: return addr 172.16.16.2
003608: Dec 5 23:24:02.801: //-1/1AD0BA3880F0/SIP/Info/sipSPICheckAssertedIdConfig: Dialpeer match is not yet done
003609: Dec 5 23:24:02.801: //-1/1AD0BA3880F0/SIP/Info/sipSPISetInfoFromRpid: Received current remote name: Jakub Stroinski, current remote number: 5147221234
003610: Dec 5 23:24:02.801: //-1/1AD0BA3880F0/SIP/Info/sipSPISetInfoFromRpid: Received ;screen=no ;privacy=off -> Setting Octet3A 0x80, extended_privacy 0x00
003611: Dec 5 23:24:02.801: //-1/1AD0BA3880F0/SIP/Info/sipSPICheckAssertedIdConfig: Dialpeer match is not yet done
003612: Dec 5 23:24:02.801: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
003613: Dec 5 23:24:02.801: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentCSTA: No CSTA found in inbound container
003614: Dec 5 23:24:02.801: //-1/1AD0BA3880F0/SIP/Info/sipSPIUaddCcbToUASReqTable: ****Adding to UAS Request table.
003615: Dec 5 23:24:02.801: //-1/1AD0BA3880F0/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x4D195650 key=6b86e46b0f1b34bc5887abbf5851c960@72.55.168.18:506012345678
003616: Dec 5 23:24:02.801: //-1/1AD0BA3880F0/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on carrier id
003617: Dec 5 23:24:02.801: //-1/1AD0BA3880F0/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on Incoming called number: 12345678
003618: Dec 5 23:24:02.801: //-1/1AD0BA3880F0/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on destination pattern: 5147221234
003619: Dec 5 23:24:02.805: //-1/1AD0BA3880F0/SIP/Info/ccsipUpdateIncomingCallParams: ccCallInfo: Calling name Jakub Stroinski, number 5147221234, Calling oct3 0x00, oct_3a 0x80, Called number 12345678
003620: Dec 5 23:24:02.805: //-1/1AD0BA3880F0/SIP/Info/sipSPIGetViaHostInURLFormat: VIA URL:sip:72.55.168.18:5060, Host:72.55.168.18
003621: Dec 5 23:24:02.805: //-1/1AD0BA3880F0/SIP/Info/sipSPIGetShrlPeer: Try match incoming dialpeer for Calling number: : 5147221234
003622: Dec 5 23:24:02.805: //-1/1AD0BA3880F0/SIP/Info/sipSPIGetFromCalledPartyId: P-Called-Party-ID header not found
003623: Dec 5 23:24:02.805: //-1/1AD0BA3880F0/SIP/Info/sipSPIGetPeerByCalledPartyId: P-Called-Party-ID not found or parse error
003624: Dec 5 23:24:02.805: //-1/1AD0BA3880F0/SIP/Info/sipSPIGetCallConfig: No match found for P-Called-Party-ID
003625: Dec 5 23:24:02.805: //-1/1AD0BA3880F0/SIP/Info/sipSPIGetCallConfig: Peer tag 1 matched for incoming call
003626: Dec 5 23:24:02.805: //-1/1AD0BA3880F0/SIP/Info/sipSPIGetCallConfig: Precondition tag absent in Require/Supported header
003627: Dec 5 23:24:02.809: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling reg_invoke_ip_first_hop()
003628: Dec 5 23:24:02.809: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling ip_best_local_address()
003629: Dec 5 23:24:02.809: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: return addr 172.16.16.2
003630: Dec 5 23:24:02.809: //-1/1AD0BA3880F0/SIP/Info/sipSPIGetCallConfig: This call is being treated for E911
003631: Dec 5 23:24:02.809: //-1/1AD0BA3880F0/SIP/Info/sipSPIGetCallConfig: Precondition tag absent in Require/Supported header
003632: Dec 5 23:24:02.809: //-1/1AD0BA3880F0/SIP/Info/sipSPIGetCallConfig: Media Antitrombone disabled
003633: Dec 5 23:24:02.809: //-1/1AD0BA3880F0/SIP/Info/sipSPISetMediaFlowMode: Storing the configured mode as FLOW-THROUGH
003634: Dec 5 23:24:02.809: //-1/1AD0BA3880F0/SIP/Info/sipSPISetMediaFlowMode: xcoder high-density disabled
003635: Dec 5 23:24:02.809: //-1/1AD0BA3880F0/SIP/Info/sipSPISetMediaFlowMode: Flow Mode set to FLOW_THROUGH
003636: Dec 5 23:24:02.809: //-1/1AD0BA3880F0/SIP/Info/sipSPIGetCallConfig: Checking Video Type Rate=-1 video_codec_allowed=1F
003637: Dec 5 23:24:02.809: //-1/1AD0BA3880F0/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabled
003638: Dec 5 23:24:02.809: //-1/1AD0BA3880F0/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=0
003639: Dec 5 23:24:02.809: //-1/1AD0BA3880F0/SIP/Info/sipSPIGetCallConfig: Media forking disabled
003640: Dec 5 23:24:02.809: //-1/1AD0BA3880F0/SIP/Info/sipSPISetOverlapConfiguration: Overlap signaling: FALSE: Endpt: SIP Trunk
003641: Dec 5 23:24:02.809: //-1/1AD0BA3880F0/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
003642: Dec 5 23:24:02.809: //-1/1AD0BA3880F0/SIP/Info/sipSPI_ipip_GetCopyListCfg: Copy-list config:2 tag:0
003643: Dec 5 23:24:02.809: //-1/1AD0BA3880F0/SIP/Info/sipSPI_ipip_build_consolidated_header_list: Both passthru and copylist are disabled
003644: Dec 5 23:24:02.809: //-1/1AD0BA3880F0/SIP/Info/sipSPIContinueNewMsgInvite: Calling name Jakub Stroinski, number 5147221234, Calling oct3 0x00, oct_3a 0x80, ext_priv 0x00, Called number 12345678, oct3 0x00
003645: Dec 5 23:24:02.809: //-1/1AD0BA3880F0/SIP/Info/sipSPIContinueNewMsgInvite: Carrier id code , prev_cid NONE, next_cid NONE, prev_tgrp NONE, next_tgrp NONE
003646: Dec 5 23:24:02.809: //-1/1AD0BA3880F0/SIP/Info/sipSPIValidateRequestUri: Not Enabled
003647: Dec 5 23:24:02.809: //-1/1AD0BA3880F0/SIP/Info/sipSPIRscmsmAvail: Value returned by check is = 0
003648: Dec 5 23:24:02.813: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_IsSDPPassthruEnabled: - 0
003649: Dec 5 23:24:02.813: //276/1AD0BA3880F0/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
003650: Dec 5 23:24:02.813: //276/1AD0BA3880F0/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:0, container:4E598334
003651: Dec 5 23:24:02.813: //276/1AD0BA3880F0/SIP/Info/Session-Timer/sipSTSLExtractSessionExpiresHdr: Not received session expires header
003652: Dec 5 23:24:02.813: //276/1AD0BA3880F0/SIP/Info/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_INITIAL_SR_REQ
003653: Dec 5 23:24:02.813: //276/1AD0BA3880F0/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:2001
003654: Dec 5 23:24:02.813: //276/1AD0BA3880F0/SIP/Info/Session-Timer/sipSTSLMain:
SE: 0;refresher:none peer refresher:none, flags:2001, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
Configured SE:1800, Configured Min-SE:1800
003655: Dec 5 23:24:02.813: //276/1AD0BA3880F0/SIP/Info/sipSPIProcessHistoryInfoHeader: No HI headers recvd from app container
003656: Dec 5 23:24:02.813: //276/1AD0BA3880F0/SIP/Info/sipSPIProcessDiversionHeader: No diversion headers recvd from app container
003657: Dec 5 23:24:02.813: //276/1AD0BA3880F0/SIP/Info/sipSPIProcessReplacesHeader: No replaces hdr found
003658: Dec 5 23:24:02.813: //276/1AD0BA3880F0/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
003659: Dec 5 23:24:02.813: //276/1AD0BA3880F0/SIP/Info/sipSPIValidateConnectionAddress: Dest port = 16010
SIP: (276) Attribute mid, level 1 instance 1 not found.
003660: Dec 5 23:24:02.813: //-1/xxxxxxxxxxxx/SIP/Info/resolve_media_ip_address_to_bind: calling reg_invoke_ip_first_hop()
003661: Dec 5 23:24:02.813: //-1/xxxxxxxxxxxx/SIP/Info/resolve_media_ip_address_to_bind: calling ip_best_local_address()
003662: Dec 5 23:24:02.813: //-1/xxxxxxxxxxxx/SIP/Info/resolve_media_ip_address_to_bind: return addr 172.16.16.2
003663: Dec 5 23:24:02.817: //276/1AD0BA3880F0/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 172.16.16.2
003664: Dec 5 23:24:02.817: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec No Codec
003665: Dec 5 23:24:02.817: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 96
003666: Dec 5 23:24:02.817: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) could not be reserved
as its in use by other codec No Codec
003667: Dec 5 23:24:02.817: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPT: Requested payload-Type (101) is reserved by another application
003668: Dec 5 23:24:02.817: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
003669: Dec 5 23:24:02.817: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 101
003670: Dec 5 23:24:02.817: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAllocateFreeDynamicPT: Allocating free Dynamic Payload : 98 for Codec:
003671: Dec 5 23:24:02.817: //276/1AD0BA3880F0/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711ulaw) Negotiation Successful on Static Payload for m-line 1
003672: Dec 5 23:24:02.817: //276/1AD0BA3880F0/SIP/Info/sipSPIDoPtimeNegotiation: One ptime attribute found - value:20
003673: Dec 5 23:24:02.817: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g711ulaw ptime :20, codecbytes: 160
003674: Dec 5 23:24:02.817: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
003675: Dec 5 23:24:02.817: //276/1AD0BA3880F0/SIP/Media/sipSPIDoPtimeNegotiation: Offered ptime:20, Negotiated ptime:20 Negotiated codec bytes: 160 for codec g711ulaw
003676: Dec 5 23:24:02.817: //276/1AD0BA3880F0/SIP/Info/sipSPISetFaxFlags: FAX_PASSTHROUGH = 0, END_FAX_PASSTHROUGH = 0
003677: Dec 5 23:24:02.817: //276/1AD0BA3880F0/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
003678: Dec 5 23:24:02.817: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec
003679: Dec 5 23:24:02.817: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec
003680: Dec 5 23:24:02.817: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
003681: Dec 5 23:24:02.817: //276/1AD0BA3880F0/SIP/Info/sipSPIReserveRtpNtePayload: Reserved the payload type 101 for RTP-NTE
003682: Dec 5 23:24:02.817: //276/1AD0BA3880F0/SIP/Info/sipSPIDoDTMFRelayNegotiation: RTP-NTE DTMF relay option
003683: Dec 5 23:24:02.817: //276/1AD0BA3880F0/SIP/Info/sipSPIDoDTMFRelayNegotiation: Case of full named event(NE) match in fmtp list of events.
003684: Dec 5 23:24:02.817: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: V150 NSE payload = 0, SSE payload = 0, SPRT payload=0
003685: Dec 5 23:24:02.817: //276/1AD0BA3880F0/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
003686: Dec 5 23:24:02.817: //276/1AD0BA3880F0/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
003687: Dec 5 23:24:02.817: //276/1AD0BA3880F0/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
payload_type=0, codec_bytes=160, codec=g711ulaw, dtmf_relay=rtp-nte
stream_type=voice+dtmf (1), dest_ip_address=72.55.168.18, dest_port=16010
003688: Dec 5 23:24:02.817: //276/1AD0BA3880F0/SIP/State/sipSPIChangeStreamState: Stream (callid = -1) State changed from (STREAM_DEAD) to (STREAM_ADDING)
003689: Dec 5 23:24:02.817: //276/1AD0BA3880F0/SIP/Media/sipSPIUpdCallWithSdpInfo:
Preferred Codec : g711ulaw, bytes :160
Preferred DTMF relay : cisco-rtp
Preferred NTE payload : 101
Early Media : No
Delayed Media : No
Bridge Done : No
New Media : No
DSP DNLD Reqd : No
003690: Dec 5 23:24:02.817: //276/1AD0BA3880F0/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
003691: Dec 5 23:24:02.817: //276/1AD0BA3880F0/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 172.16.16.2
003692: Dec 5 23:24:02.821: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 276 peer 0 flags 0x201 state STATE_IDLE
003693: Dec 5 23:24:02.821: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_vcc_ProcessXcoderNeeded: xcoder_attached not yet initialised for this call.
003694: Dec 5 23:24:02.821: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_report_media_to_peer: Xcoder not yet used for the call
003695: Dec 5 23:24:02.821: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CallID 276, Peer CallID 0, sdp 0x4AD2A100 channels 0x4D196BEC
003696: Dec 5 23:24:02.821: //276/1AD0BA3880F0/SIP/Info/copy_channels:
callId 276 size 0 ptr 0x4E6E8F04)
003697: Dec 5 23:24:02.821: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: stream_callid = 276
003698: Dec 5 23:24:02.821: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: reset the switch..
003699: Dec 5 23:24:02.821: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Hndl ptype 0 mline 1
003700: Dec 5 23:24:02.821: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711ulaw
003701: Dec 5 23:24:02.821: //276/1AD0BA3880F0/SIP/Info/codec_found:
Codec to be matched: 5
003702: Dec 5 23:24:02.821: //276/1AD0BA3880F0/SIP/Info/codec_found: codecs[i] = 5 & codec = 5 are same..
003703: Dec 5 23:24:02.821: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: ADD AUDIO CODEC 5
003704: Dec 5 23:24:02.821: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
003705: Dec 5 23:24:02.821: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation done: stream->negotiated_ptime=20,stream->negotiated_codec_bytes=160, coverted ptime=20 stream->mline_index=1, media_ndx=1
003706: Dec 5 23:24:02.821: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
failed to update call entry
003707: Dec 5 23:24:02.821: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Adding codec 5 ptype 0 time 20, bytes 160 as channel 0 mline 1 ss 1 72.55.168.18:16010
003708: Dec 5 23:24:02.821: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Hndl ptype 18 mline 1
003709: Dec 5 23:24:02.821: //276/1AD0BA3880F0/SIP/Media/sipSPISelectCodecVersion: Codec (g729r8) is not in preferred list
003710: Dec 5 23:24:02.821: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: An exact codec match not configured, using interoperable codec g729r8 pre-ietf
003711: Dec 5 23:24:02.821: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g729r8 pre-ietf
003712: Dec 5 23:24:02.821: //276/1AD0BA3880F0/SIP/Info/codec_found:
Codec to be matched: 0
003713: Dec 5 23:24:02.821: //276/1AD0BA3880F0/SIP/Info/codec_found: No match for the codecs found..
003714: Dec 5 23:24:02.821: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Hndl ptype 101 mline 1
003715: Dec 5 23:24:02.821: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: setting ipip_caps DTMF to RFC2833: callid = 276, dtmf = 6
003716: Dec 5 23:24:02.821: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = 5
003717: Dec 5 23:24:02.821: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = -1
003718: Dec 5 23:24:02.821: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 276 flags 0x10000100 state STATE_IDLE
003719: Dec 5 23:24:02.821: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_report_media_to_peer:
Report initial call media
003720: Dec 5 23:24:02.821: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_report_media_to_peer: ccb->flags 0xC, ccb->pld.flags_ipip 0x201
003721: Dec 5 23:24:02.821: //276/1AD0BA3880F0/SIP/Info/copy_channels:
callId 276 size 240 ptr 0x499F3D1C)
003722: Dec 5 23:24:02.821: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_report_media_to_peer:
CCSIP: Unable to report channel ind
003723: Dec 5 23:24:02.821: //276/1AD0BA3880F0/SIP/Info/ccsip_update_srtp_caps: 7419: Posting Remote SRTP caps to other callleg.
003724: Dec 5 23:24:02.821: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_report_media_to_peer: do cc_api_caps_ind()
003725: Dec 5 23:24:02.825: //276/1AD0BA3880F0/SIP/Media/sipSPIUpdCallWithSdpInfo:
Stream type : voice+dtmf
Media line : 1
State : STREAM_ADDING (2)
Stream address type : 1
Callid : 276
Negotiated Codec : g711ulaw, bytes :160
Nego. Codec payload : 0 (tx), 0 (rx)
Negotiated DTMF relay : rtp-nte
Negotiated NTE payload : 101 (tx), 101 (rx)
Negotiated CN payload : 0
Media Srce Addr/Port : [172.16.16.2]:0
Media Dest Addr/Port : [72.55.168.18]:16010
003726: Dec 5 23:24:02.825: //276/1AD0BA3880F0/SIP/Info/sipSPIHandleInviteMedia:
Preferred DTMF relay 1 : 1
Preferred DTMF relay 2 : 6
Negotiated DTMF relay : 6
Preferred and Negotiated NTE payloads: 101 101
Preferred and Negotiated NSE payloads: 100 0
Preferred and Negotiated Modem Relay: 0 0
Preferred and Negotiated V150.1 Modem Passthrough: 0 0
Preferred and Negotiated V150.1 Modem Relay: 0 0
Preferred and Negotiated Modem Relay GwXid: 1 0
003727: Dec 5 23:24:02.825: //276/1AD0BA3880F0/SIP/Info/sipSPIDoQoSNegotiationWithMediaLine: QOS negotiation for mline_index 1
003728: Dec 5 23:24:02.825: //276/1AD0BA3880F0/SIP/Info/sipSPIDoStreamQoSNegotiation: Best effort
003729: Dec 5 23:24:02.825: //276/1AD0BA3880F0/SIP/Info/sipSPICanSetFallbackFlag: Local Fallback is not active
003730: Dec 5 23:24:02.825: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 17836 for stream 1
003731: Dec 5 23:24:02.825: //276/1AD0BA3880F0/SIP/Info/sipSPIUpdateSrcSdpFixedPart: Reserving rtp port for stream 1, src_port=17836
003732: Dec 5 23:24:02.825: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
003733: Dec 5 23:24:02.825: //276/1AD0BA3880F0/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Setting stream 1 portnum to 17836
003734: Dec 5 23:24:02.825: //276/1AD0BA3880F0/SIP/Info/sipSPIUpdateSrcSdpVariablePart:
SIP update src sdp, negoitated codec 5, payload type 0
003735: Dec 5 23:24:02.825: //276/1AD0BA3880F0/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Negotiated method of dtmf relayand pyld: 6 101
003736: Dec 5 23:24:02.825: //276/1AD0BA3880F0/SIP/Info/sipSPIUpdateSrcSdpVariablePart: max_event 16
003737: Dec 5 23:24:02.825: //276/1AD0BA3880F0/SIP/Info/sipSPIAddBillingInfoToCcb: sipCallId for billing records = 6b86e46b0f1b34bc5887abbf5851c960@72.55.168.18:5060
003738: Dec 5 23:24:02.825: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentCPA: No CPA found in inbound container
003739: Dec 5 23:24:02.825: //276/1AD0BA3880F0/SIP/Info/sipSPIProcessCPA: No x-cisco-cpa content found
003740: Dec 5 23:24:02.825: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
003741: Dec 5 23:24:02.825: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
003742: Dec 5 23:24:02.825: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled: - 0
003743: Dec 5 23:24:02.825: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
003744: Dec 5 23:24:02.829: //276/1AD0BA3880F0/SIP/Info/ccsip_api_call_setup_ind: Unable to add unsupp headers to container
003745: Dec 5 23:24:02.829: //276/1AD0BA3880F0/SIP/Info/ccsip_api_call_setup_ind: Set Protocol information
003746: Dec 5 23:24:02.829: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
003747: Dec 5 23:24:02.829: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
003748: Dec 5 23:24:02.829: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_store_channel_info: Store channelInfo in CallInfo
003749: Dec 5 23:24:02.829: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_store_channel_info: dtmf negotiation done, storing negotiated dtmf = 6,
003750: Dec 5 23:24:02.829: //276/1AD0BA3880F0/SIP/Info/sipSPIShrlCall: Check peer: 1 for Shared-Line call, callid: 276
003751: Dec 5 23:24:02.829: //276/1AD0BA3880F0/SIP/Info/ccsip_set_bearer_capability:
Bearer Capability: Speech (0x00)
003752: Dec 5 23:24:02.829: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
003753: Dec 5 23:24:02.829: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
003754: Dec 5 23:24:02.829: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateNewRawMsg: No Data to form The Raw Message
003755: Dec 5 23:24:02.829: //276/1AD0BA3880F0/SIP/Info/sipSPIContinueNewMsgInvite: ccsip_api_call_setup_ind returned: SIP_SUCCESS
003756: Dec 5 23:24:02.829: //276/1AD0BA3880F0/SIP/Info/sipSPIUaddccCallIdToTable: Adding call id 114 to table
003757: Dec 5 23:24:02.829: //276/1AD0BA3880F0/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
003758: Dec 5 23:24:02.829: //276/1AD0BA3880F0/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:100, container:4E596EEC
003759: Dec 5 23:24:02.829: //276/1AD0BA3880F0/SIP/Info/Session-Timer/sipSTSLValidateSessRefreshMsg: Ignoring 1xx response for session timer processing
003760: Dec 5 23:24:02.833: //276/1AD0BA3880F0/SIP/Info/sipSPISendInviteResponse: Associated container=0x4E596EEC to Invite Response 100
003761: Dec 5 23:24:02.833: //276/1AD0BA3880F0/SIP/Transport/sipSPITransportSendMessage: msg=0x4AAA0C50, addr=72.55.168.18, port=5060, sentBy_port=5060, local_addr=, is_req=0, transport=1, switch=0, callBack=0x0
003762: Dec 5 23:24:02.833: //276/1AD0BA3880F0/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
003763: Dec 5 23:24:02.833: //276/1AD0BA3880F0/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
003764: Dec 5 23:24:02.833: //276/1AD0BA3880F0/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x4AAA0C50 to default port=5060
003765: Dec 5 23:24:02.833: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:72.55.168.18, rport:5060 with laddr:
003766: Dec 5 23:24:02.833: //276/1AD0BA3880F0/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x4AAA0C50
003767: Dec 5 23:24:02.833: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4AAA0C50, addr=72.55.168.18, port=5060, local_addr=, connId=4 for UDP
003768: Dec 5 23:24:02.833: //276/1AD0BA3880F0/SIP/State/sipSPIChangeState: 0x4D195650 : State change from (STATE_IDLE, SUBSTATE_NONE) to (STATE_RECD_INVITE, SUBSTATE_NONE)
003769: Dec 5 23:24:02.833: //276/1AD0BA3880F0/SIP/Info/sipSPIProcessContactInfo: Previous Hop 72.55.168.18:5060
003770: Dec 5 23:24:02.837: //276/1AD0BA3880F0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 102 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
003771: Dec 5 23:24:02.841: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_PROCEEDING
003772: Dec 5 23:24:02.845: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x4D1A05E0) with key=[245] to table
003773: Dec 5 23:24:02.845: //-1/000000000000/SIP/Info/sipSPI_ipip_vcc_Initialization: Entry...
003774: Dec 5 23:24:02.845: //-1/000000000000/SIP/Info/ccsip_offer_ans_init:
003775: Dec 5 23:24:02.845: //277/000000000000/SIP/State/sipSPIChangeState: 0x4D1A05E0 : State change from (STATE_NONE, SUBSTATE_NONE) to (STATE_IDLE, SUBSTATE_NONE)
003776: Dec 5 23:24:02.845: //277/000000000000/SIP/Info/ccsip_call_setup_request: Set Protocol information
003777: Dec 5 23:24:02.845: //277/000000000000/SIP/Info/ccsip_call_setup_request: Before processing SETUP REQccb->pld.flags_ipip = 200
003778: Dec 5 23:24:02.845: //277/000000000000/SIP/Info/ccsip_call_setup_request:
This a IPIP call: Chan 0, codec 5 channel 16010, ip 72.55.168.18:16010 params 0x4E5D1F84 caps 0x48E37E48
003779: Dec 5 23:24:02.845: //277/000000000000/SIP/Info/ccsip_gw_set_sipspi_mode: Setting SPI mode to SIP-SIP
003780: Dec 5 23:24:02.845: //277/000000000000/SIP/Info/ccsip_call_setup_request: After processing SETUP REQccb->pld.flags_ipip = 400000
003781: Dec 5 23:24:02.849: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetOutboundHostAndDestHostPrivate: CCSIP: target_host : 172.16.16.21 target_port : 5060
003782: Dec 5 23:24:02.849: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
003783: Dec 5 23:24:02.849: //277/1AD0BA3880F0/SIP/Info/ccsip_call_setup_request: Incrementing call counter to [1] in dial-peer [40004]
003784: Dec 5 23:24:02.849: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: switch(ev.ev_id: 174)
003785: Dec 5 23:24:02.849: //276/1AD0BA3880F0/SIP/Info/ccsip_event_handler:
ccsip_event_handler: peer ID 277 chans 0x48E53020 event 174 flags 0x40001C 0x10000100 0x601 data 0x48E53020
003786: Dec 5 23:24:02.849: //276/1AD0BA3880F0/SIP/Info/ccsip_event_handler:
ccsip_event_handler: CC_EV_H245_SET_MODE: peer ID 277 chans 0x48E53020 event 174 flags 0x40001C 0x10000100 0x603 data 0x48E53020, type = 1
003787: Dec 5 23:24:02.849: //276/1AD0BA3880F0/SIP/Info/ccsip_event_handler: Current mode is SIP-TDM
003788: Dec 5 23:24:02.849: //276/1AD0BA3880F0/SIP/Info/ccsip_gw_set_sipspi_mode: Setting SPI mode to SIP-SIP
003789: Dec 5 23:24:02.849: //276/1AD0BA3880F0/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SET_MODE
003790: Dec 5 23:24:02.849: //276/1AD0BA3880F0/SIP/Info/Session-Timer/sipSTSLMain:
003791: Dec 5 23:24:02.849: //276/1AD0BA3880F0/SIP/Info/ccsip_event_handler:
Changing the flow mode due to SET_MODE
003792: Dec 5 23:24:02.849: //276/1AD0BA3880F0/SIP/Info/sipSPIHandleMediaFlowModeChange:
003793: Dec 5 23:24:02.849: //276/1AD0BA3880F0/SIP/Info/sipSPIHandleMediaFlowModeChange: current media flow mode is 1, desired media flow mode is 1
003794: Dec 5 23:24:02.849: //276/1AD0BA3880F0/SIP/Info/sipSPIHandleMediaFlowModeChange: current flow mode is same as desired flow mode
003795: Dec 5 23:24:02.849: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: CC_R_SUCCESS_WITH_CONFIRMED
003796: Dec 5 23:24:02.849: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 3
003797: Dec 5 23:24:02.849: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 2
003798: Dec 5 23:24:02.849: //277/1AD0BA3880F0/SIP/Info/sipSPIUaddccCallIdToTable: Adding call id 115 to table
003799: Dec 5 23:24:02.849: //277/1AD0BA3880F0/SIP/Info/sipSPIGetCallConfig: preferred_codec set[0] type :No Codec bytes: 0
003800: Dec 5 23:24:02.849: //277/1AD0BA3880F0/SIP/Info/sipSPIGetCallConfig: Media forking disabled
003801: Dec 5 23:24:02.849: //277/1AD0BA3880F0/SIP/Info/sipSPIGetCallConfig: Media Antitrombone disabled
003802: Dec 5 23:24:02.849: //277/1AD0BA3880F0/SIP/Info/sipSPICanSetFallbackFlag: Local Fallback is not active
003803: Dec 5 23:24:02.849: //277/1AD0BA3880F0/SIP/Info/sipSPISetMediaFlowMode: Storing the configured mode as FLOW-THROUGH
003804: Dec 5 23:24:02.849: //277/1AD0BA3880F0/SIP/Info/sipSPISetMediaFlowMode: xcoder high-density disabled
003805: Dec 5 23:24:02.849: //277/1AD0BA3880F0/SIP/Info/sipSPISetMediaFlowMode: Flow Mode set to FLOW_THROUGH
003806: Dec 5 23:24:02.853: //277/1AD0BA3880F0/SIP/Info/sipSPIGetCallConfig: Checking Video Type Rate=-1 video_codec_allowed=1F
003807: Dec 5 23:24:02.853: //277/1AD0BA3880F0/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabled
003808: Dec 5 23:24:02.853: //277/1AD0BA3880F0/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=276
003809: Dec 5 23:24:02.853: //277/1AD0BA3880F0/SIP/Info/sipSPIGetCallConfig: Media forking disabled
003810: Dec 5 23:24:02.853: //277/1AD0BA3880F0/SIP/Info/sipSPISetOverlapConfiguration: Overlap signaling: FALSE: Endpt: SIP Line
003811: Dec 5 23:24:02.853: //277/1AD0BA3880F0/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
003812: Dec 5 23:24:02.853: //277/1AD0BA3880F0/SIP/Info/sipSPI_ipip_GetCopyListCfg: Copy-list config:2 tag:0
003813: Dec 5 23:24:02.853: //277/1AD0BA3880F0/SIP/Info/sipSPI_ipip_build_consolidated_header_list: Both passthru and copylist are disabled
003814: Dec 5 23:24:02.853: //277/1AD0BA3880F0/SIP/Info/sipSPIValidateAndCopyOutboundHost: CCSIP: copy target_host to outbound_host
003815: Dec 5 23:24:02.853: //277/1AD0BA3880F0/SIP/Info/preprocessSetup:
This is a not a SIGO Call -, could be DM call
003816: Dec 5 23:24:02.853: //277/1AD0BA3880F0/SIP/Info/sipSPI_ipip_copy_peer_channelInfo_to_sdp: Valid peer channels available!!
003817: Dec 5 23:24:02.853: //277/1AD0BA3880F0/SIP/Info/sipSPI_ipip_copy_peer_channelInfo_to_sdp: No video caps posted by peer
003818: Dec 5 23:24:02.853: //277/1AD0BA3880F0/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp:
callid 277, channels 0x4E6EDAEC caps 0x48E37E48
003819: Dec 5 23:24:02.853: //277/1AD0BA3880F0/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: Peer cap provided: callid = 277, peer dtmf = 6peer t38 version = 0 peer t38 maxBitRate = 0
003820: Dec 5 23:24:02.853: //277/1AD0BA3880F0/SIP/Info/sipSPIDtmfTranscoder: Return upon SCCP version 0
003821: Dec 5 23:24:02.853: //277/1AD0BA3880F0/SIP/Info/sipSPISrtpTranscoder:
Checking if transcoder is needed for SRTP-RTP
003822: Dec 5 23:24:02.853: //277/1AD0BA3880F0/SIP/Info/sipSPIAudioLevelAdjustmentTranscoder: Entry..
003823: Dec 5 23:24:02.853: //277/1AD0BA3880F0/SIP/Info/sipSPIAudioLevelAdjustmentTranscoder: AudioLevelAdjustment do not need xcoder
003824: Dec 5 23:24:02.853: //277/1AD0BA3880F0/SIP/Info/sipSPI_ipip_codec_byte_transrating: tranrating not enabled on peers, return FALSE
003825: Dec 5 23:24:02.853: //277/1AD0BA3880F0/SIP/Info/sipSPICodecTranscoder: No body else needs xcoder. OFFER_ALL is intact
003826: Dec 5 23:24:02.853: //277/1AD0BA3880F0/SIP/Info/sipSPI_ipip_vcc_CheckVoiceClassCodecConfiguration: None of the call leg supports Voice Class Codec..
003827: Dec 5 23:24:02.853: //277/1AD0BA3880F0/SIP/Info/sipSPICodecTranscoder: Static codec or Equalset or Subset w/o offer-all. For DO call, offer-all is NO-OP..
003828: Dec 5 23:24:02.853: //277/1AD0BA3880F0/SIP/Info/codec_found:
003829: Dec 5 23:24:02.853: //277/1AD0BA3880F0/SIP/Info/codec_found: codecs[i] = 5 & codec = 5 are same..
003830: Dec 5 23:24:02.853: //277/1AD0BA3880F0/SIP/Info/sipSPIUpdatePreferredCodec: num_chans = 1
003831: Dec 5 23:24:02.853: //277/1AD0BA3880F0/SIP/Info/sipSPICheckAndReserveTranscoder: Xcoder is not needed
003832: Dec 5 23:24:02.853: //277/1AD0BA3880F0/SIP/Info/sipSPISrtpTranscoder:
003833: Dec 5 23:24:02.853: //277/1AD0BA3880F0/SIP/Info/sipSPI_ipip_setOptionTagInfo: Option Tag Rel1xx value is 0
003834: Dec 5 23:24:02.853: //-1/xxxxxxxxxxxx/SIP/Info/resolve_media_ip_address_to_bind: calling reg_invoke_ip_first_hop()
003835: Dec 5 23:24:02.853: //-1/xxxxxxxxxxxx/SIP/Info/resolve_media_ip_address_to_bind: calling ip_best_local_address()
003836: Dec 5 23:24:02.857: //-1/xxxxxxxxxxxx/SIP/Info/resolve_media_ip_address_to_bind: return addr 172.16.16.2
003837: Dec 5 23:24:02.857: //277/1AD0BA3880F0/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 172.16.16.2
003838: Dec 5 23:24:02.857: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling reg_invoke_ip_first_hop()
003839: Dec 5 23:24:02.857: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling ip_best_local_address()
003840: Dec 5 23:24:02.857: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: return addr 172.16.16.2
003841: Dec 5 23:24:02.857: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 18858 for stream 1
003842: Dec 5 23:24:02.857: //277/1AD0BA3880F0/SIP/Media/sipSPIAddSDPMediaPayload: Preferred method of dtmf relay is: 6, with payload: 101
003843: Dec 5 23:24:02.857: //277/1AD0BA3880F0/SIP/Media/sipSPIAddSDPMediaPayload: Preferred method of dtmf relay is: 1, with payload: 121
003844: Dec 5 23:24:02.857: //277/1AD0BA3880F0/SIP/Info/sipSPIAddSDPPayloadAttributes:
max_event 16
003845: Dec 5 23:24:02.857: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
003846: Dec 5 23:24:02.857: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
003847: Dec 5 23:24:02.857: //277/1AD0BA3880F0/SIP/Info/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
003848: Dec 5 23:24:02.857: //277/1AD0BA3880F0/SIP/Info/sipSPIOutgoingCallSDP: Creating recv-only stream for outbound call
003849: Dec 5 23:24:02.857: //277/1AD0BA3880F0/SIP/Media/sipSPIProcessRtpSessions: No active streams.
003850: Dec 5 23:24:02.861: //277/1AD0BA3880F0/SIP/Info/sip_gw_pre_setup_add_sdp_container: SDP container added
003851: Dec 5 23:24:02.861: //277/1AD0BA3880F0/SIP/Info/sipSPIAddMLPPServicesInfo: No MLP Info available on incoming leg
003852: Dec 5 23:24:02.861: //277/1AD0BA3880F0/SIP/Info/sipSPIPreprocessUriFormat: Url cfg for 1: 2,phone-ctxt=FALSE
003853: Dec 5 23:24:02.861: //277/1AD0BA3880F0/SIP/Info/sipSPIAddPrivacyandIdentityInfo: Using globally configured ppi header
003854: Dec 5 23:24:02.861: //277/1AD0BA3880F0/SIP/Info/sipSPICompareHistoryInfoWithMatchedDialpeer: call-route history-info CLI not enabled
003855: Dec 5 23:24:02.861: //277/1AD0BA3880F0/SIP/Info/sipSPI_ipip_set_history_info_header: No HI header recvd from container
003856: Dec 5 23:24:02.861: //277/1AD0BA3880F0/SIP/Info/sipSPI_ipip_set_diversion_header: No diversion header recvd from container
003857: Dec 5 23:24:02.861: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling reg_invoke_ip_first_hop()
003858: Dec 5 23:24:02.861: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling ip_best_local_address()
003859: Dec 5 23:24:02.861: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: return addr 172.16.16.2
003860: Dec 5 23:24:02.861: //277/1AD0BA3880F0/SIP/Info/sipSPIRscmsmAvail: Value returned by check is = 0
003861: Dec 5 23:24:02.861: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling reg_invoke_ip_first_hop()
003862: Dec 5 23:24:02.861: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling ip_best_local_address()
003863: Dec 5 23:24:02.861: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: return addr 172.16.16.2
003864: Dec 5 23:24:02.861: //277/1AD0BA3880F0/SIP/Info/sipSPIUaddCcbToUACTable: ****Adding to UAC table.
003865: Dec 5 23:24:02.861: //277/1AD0BA3880F0/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x4D1A05E0 key=1ADA7DE8-9ADE11E5-80F6DB8C-E7BAB034@172.16.16.2
003866: Dec 5 23:24:02.861: //277/1AD0BA3880F0/SIP/Info/sipSPIUsetBillingProfile: sipCallId for billing records = 1ADA7DE8-9ADE11E5-80F6DB8C-E7BAB034@172.16.16.2
003867: Dec 5 23:24:02.861: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 172.16.16.21,Port 5060, Transport 1, SentBy Port 5060
003868: Dec 5 23:24:02.861: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone EST to SIP default timezone = GMT
003869: Dec 5 23:24:02.861: //277/1AD0BA3880F0/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
003870: Dec 5 23:24:02.865: //277/1AD0BA3880F0/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:4E598494
003871: Dec 5 23:24:02.865: //277/1AD0BA3880F0/SIP/Info/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_INITIAL_SR_REQ
003872: Dec 5 23:24:02.865: //277/1AD0BA3880F0/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:2001
003873: Dec 5 23:24:02.865: //277/1AD0BA3880F0/SIP/Info/Session-Timer/sipSTSLMain:
SE: 0;refresher:none peer refresher:none, flags:2100, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
003874: Dec 5 23:24:02.865: //277/1AD0BA3880F0/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 0 event
003875: Dec 5 23:24:02.865: //277/1AD0BA3880F0/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer: Could not get any elements from TD Container
003876: Dec 5 23:24:02.865: //277/1AD0BA3880F0/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer: Could not get any elements from TD Container
003877: Dec 5 23:24:02.865: //277/1AD0BA3880F0/SIP/Info/sipSPIgetRegistrarHost: multiple registrar mode, host name is 172.16.16.2
003878: Dec 5 23:24:02.865: //277/1AD0BA3880F0/SIP/Info/sipSPISendInvite: Associated container=0x4E598494 to Invite
003879: Dec 5 23:24:02.865: //277/1AD0BA3880F0/SIP/Transport/sipSPISendInvite: Sending Invite to the transport layer
003880: Dec 5 23:24:02.865: //277/1AD0BA3880F0/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Dial peer configuration, Switch Transport is FALSE
003881: Dec 5 23:24:02.865: //277/1AD0BA3880F0/SIP/Transport/sipSPITransportSendMessage: msg=0x4E78A294, addr=172.16.16.21, port=5060, sentBy_port=0, local_addr=, is_req=1, transport=1, switch=0, callBack=0x41BD5E20
003882: Dec 5 23:24:02.865: //277/1AD0BA3880F0/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
003883: Dec 5 23:24:02.865: //277/1AD0BA3880F0/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
003884: Dec 5 23:24:02.865: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:172.16.16.21, rport:5060 with laddr:
003885: Dec 5 23:24:02.865: //277/1AD0BA3880F0/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x4E78A294
003886: Dec 5 23:24:02.869: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4E78A294, addr=172.16.16.21, port=5060, local_addr=, connId=7 for UDP
003887: Dec 5 23:24:02.869: //277/1AD0BA3880F0/SIP/Info/sentInviteRequest: Sent Invite in state STATE_IDLE
003888: Dec 5 23:24:02.869: //-1/xxxxxxxxxxxx/SIP/Info/sentInviteRequest: Transaction active. Facilities will be queued.
003889: Dec 5 23:24:02.869: //277/1AD0BA3880F0/SIP/State/sipSPIChangeState: 0x4D1A05E0 : State change from (STATE_IDLE, SUBSTATE_NONE) to (STATE_SENT_INVITE, SUBSTATE_NONE)
003890: Dec 5 23:24:02.869: //277/1AD0BA3880F0/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 277) to the VOIP RTP library
003891: Dec 5 23:24:02.869: //277/1AD0BA3880F0/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
003892: Dec 5 23:24:02.869: //277/1AD0BA3880F0/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 172.16.16.2
003893: Dec 5 23:24:02.869: //277/1AD0BA3880F0/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
003894: Dec 5 23:24:02.869: //277/1AD0BA3880F0/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
laddr = 172.16.16.2, lport = 18858, raddr = 0.0.0.0, rport=0, do_rtcp=FALSE
src_callid = 277, dest_callid = -1, stream type = voice+dtmf, stream direction = RECVONLY
media_ip_addr = - , vrf tableid = 0 media_addr_type = 1
003895: Dec 5 23:24:02.869: //277/1AD0BA3880F0/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
003896: Dec 5 23:24:02.869: //277/1AD0BA3880F0/SIP/Info/sipSPICreateRtpSession: sess: 48DECA38 do_rtcp:0
003897: Dec 5 23:24:02.869: //276/1AD0BA3880F0/SIP/Info/ccsip_update_peer_caps: Stream is NULL
003898: Dec 5 23:24:02.869: //276/1AD0BA3880F0/SIP/Info/ccsip_update_peer_caps: gccb/stream is NULL, not updating now !!
003899: Dec 5 23:24:02.869: //277/1AD0BA3880F0/SIP/Info/sipSPIUpdateGccb: Failure from the peer leg so no updations now!!
003900: Dec 5 23:24:02.869: //277/1AD0BA3880F0/SIP/Media/sipSPICreateRtpSession: stun is disabled
003901: Dec 5 23:24:02.869: //277/1AD0BA3880F0/SIP/State/sipSPIChangeStreamState: Stream (callid = 277) State changed from (STREAM_ADDING) to (STREAM_ACTIVE)
003902: Dec 5 23:24:02.873: //277/1AD0BA3880F0/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:2339@172.16.16.21:5060 SIP/2.0
Via: SIP/2.0/UDP 172.16.16.2:5060;branch=z9hG4bK8580
From: "Jakub Stroinski" <sip:5147221234@172.16.16.2>;tag=52CA4C-1B2E
To: <sip:2339@172.16.16.21>
Call-ID: 1ADA7DE8-9ADE11E5-80F6DB8C-E7BAB034@172.16.16.2
Supported: 100rel,timer,resource-priority,replaces
Min-SE: 1800
Cisco-Guid: 0449886776-2598244837-2163268492-3887771700
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1449357842
Contact: <sip:5147221234@172.16.16.2:5060>
Expires: 180
Max-Forwards: 69
Cisco-Gcid: 1AD32B70-9ADE-11E5-80F3-DB8CE7BAB034
P-Preferred-Identity: "Jakub Stroinski" <sip:5147221234@172.16.16.2>
Content-Disposition: session;handling=required
Content-Length: 324
v=0
o=CiscoSystemsSIP-GW-UserAgent 599 1676 IN IP4 172.16.16.2
s=SIP Call
c=IN IP4 172.16.16.2
t=0 0
m=audio 18858 RTP/AVP 0 101 121 19
a=fmtp:101 0-16
a=rtpmap:121 frf-dialed-digit/8000
a=fmtp:121 0-15
a=rtpmap:19 CN/8000
a=ptime:20
003903: Dec 5 23:24:02.885: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [172.16.16.21]:50681, local_address:[ - ]
003904: Dec 5 23:24:02.885: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
003905: Dec 5 23:24:02.885: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
003906: Dec 5 23:24:02.885: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
003907: Dec 5 23:24:02.885: //277/1AD0BA3880F0/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Server: Cisco-CP7975G/9.4.2
Contact: <sip:60037a2b-e0b4-7c3f-dd9f-4eca6b99ccd4@172.16.16.21:5060;transport=udp>
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE,INFO
Supported: replaces,join,sdp-anat,norefersub,resource-priority,X-cisco-srtp-fallback,X-cisco-xsi-8.5.1
Allow-Events: kpml,dialog
Content-Length: 0
003908: Dec 5 23:24:02.889: //277/1AD0BA3880F0/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
003909: Dec 5 23:24:02.889: //277/1AD0BA3880F0/SIP/State/sipSPIChangeState: 0x4D1A05E0 : State change from (STATE_SENT_INVITE, SUBSTATE_NONE) to (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)
003910: Dec 5 23:24:03.333: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [172.16.16.21]:50681, local_address:[ - ]
003911: Dec 5 23:24:03.333: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
003912: Dec 5 23:24:03.333: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
003913: Dec 5 23:24:03.333: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
003914: Dec 5 23:24:03.337: //277/1AD0BA3880F0/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:2339@172.16.16.21>;tag=44e4d945122b032a4a7d1f62-b4520944
Date: Sat, 05 Dec 2015 23:24:03 GMT
CSeq: 101 INVITE
Remote-Party-ID: "Jakub Stroinski" <sip:2339@172.16.16.2>;party=called;id-type=subscriber;privacy=off;screen=yes
Content-Length: 0
003915: Dec 5 23:24:03.337: //277/1AD0BA3880F0/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
003916: Dec 5 23:24:03.337: //277/1AD0BA3880F0/SIP/Info/sipSPISetInfoFromRpid: Received current remote name: Jakub Stroinski, current remote number: 2339
003917: Dec 5 23:24:03.337: //277/1AD0BA3880F0/SIP/Info/sipSPISetInfoFromRpid: Received ;screen=yes ;privacy=off -> Setting Octet3A 0x81, extended_privacy 0x00
003918: Dec 5 23:24:03.337: //277/1AD0BA3880F0/SIP/Info/ccsip_api_update_allowed: UPDATE(1) allowed
003919: Dec 5 23:24:03.337: //277/1AD0BA3880F0/SIP/Info/ccsip_offer_ans_handle_update_allowed:
003920: Dec 5 23:24:03.337: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
003921: Dec 5 23:24:03.337: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentSDP: No SDP found in inbound container
003922: Dec 5 23:24:03.337: //277/1AD0BA3880F0/SIP/Info/ccsip_api_call_alert: SDP Body either absent or ignored in 180 RINGING:- will wait for 200 OK to do negotiation.
003923: Dec 5 23:24:03.337: //277/1AD0BA3880F0/SIP/Info/sipSPIProcessHistoryInfoHeader: No HI headers recvd from app container
003924: Dec 5 23:24:03.337: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
003925: Dec 5 23:24:03.337: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
003926: Dec 5 23:24:03.341: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateNewRawMsg: No Data to form The Raw Message
003927: Dec 5 23:24:03.341: //277/1AD0BA3880F0/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
003928: Dec 5 23:24:03.341: //277/1AD0BA3880F0/SIP/Info/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
003929: Dec 5 23:24:03.341: //277/1AD0BA3880F0/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled: - 0
003930: Dec 5 23:24:03.341: //277/1AD0BA3880F0/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
003931: Dec 5 23:24:03.341: //277/1AD0BA3880F0/SIP/Error/ccsip_alert_parent_or_child: Unable to add unsupported
hdrs to container
003932: Dec 5 23:24:03.341: //277/1AD0BA3880F0/SIP/Info/HandleSIP1xxRinging: ccsip_api_call_alert returned: SIP_SUCCESS
003933: Dec 5 23:24:03.341: //277/1AD0BA3880F0/SIP/State/sipSPIChangeState: 0x4D1A05E0 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING) to (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)
003934: Dec 5 23:24:03.341: //277/1AD0BA3880F0/SIP/Info/HandleSIP1xxRinging: Transaction Complete. Lock on Facilities released.
003935: Dec 5 23:24:03.341: //276/1AD0BA3880F0/SIP/Info/ccsip_call_alert: CCSIP_CALL_ALERT: app_diaplay_name[Jakub Stroinski] app_display_num[2339]
003936: Dec 5 23:24:03.341: //276/1AD0BA3880F0/SIP/Info/ccsip_call_alert: CCSIP_CALL_ALERT : KPML_CONFIGURED[FALSE] collect_digits[2000] calledNumber[12345678] display_name[Jakub Stroinski] display_num[2339]
003937: Dec 5 23:24:03.341: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_ALERTING
003938: Dec 5 23:24:03.341: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 5
003939: Dec 5 23:24:03.341: //276/1AD0BA3880F0/SIP/Info/sipSPIAddCiscoGcid: Fatal Error in parsing CCB/Msg
003940: Dec 5 23:24:03.341: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIStoreTunnelData: Container /RawMessage Absent
003941: Dec 5 23:24:03.345: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_set_history_info_header: No HI header recvd from container
003942: Dec 5 23:24:03.345: //276/1AD0BA3880F0/SIP/Info/sipSPIUaddCcbToUASRespTable: ****Adding to UAS Response table.
003943: Dec 5 23:24:03.345: //276/1AD0BA3880F0/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x4D195650 key=6b86e46b0f1b34bc5887abbf5851c960@72.55.168.18:506052CC2C-269B
003944: Dec 5 23:24:03.345: //276/1AD0BA3880F0/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
003945: Dec 5 23:24:03.345: //276/1AD0BA3880F0/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:180, container:4E59885C
003946: Dec 5 23:24:03.345: //276/1AD0BA3880F0/SIP/Info/Session-Timer/sipSTSLValidateSessRefreshMsg: Ignoring 1xx response for session timer processing
003947: Dec 5 23:24:03.345: //276/1AD0BA3880F0/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 9 event
003948: Dec 5 23:24:03.345: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer: Could not get any elements from TD Container
003949: Dec 5 23:24:03.345: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer: Could not get any elements from TD Container
003950: Dec 5 23:24:03.345: //276/1AD0BA3880F0/SIP/Event/sipSPICreateRpid: Received Octet3A=0x80 -> Setting ;screen=no ;privacy=off
003951: Dec 5 23:24:03.345: //276/1AD0BA3880F0/SIP/Info/sipSPISendInviteResponse: Associated container=0x4E59885C to Invite Response 180
003952: Dec 5 23:24:03.345: //276/1AD0BA3880F0/SIP/Transport/sipSPISendInviteResponse: Sending 180 Response to the Transport Layer
003953: Dec 5 23:24:03.345: //276/1AD0BA3880F0/SIP/Transport/sipSPITransportSendMessage: msg=0x48DEBDD8, addr=72.55.168.18, port=5060, sentBy_port=5060, local_addr=, is_req=0, transport=1, switch=0, callBack=0x41BD6C98
003954: Dec 5 23:24:03.345: //276/1AD0BA3880F0/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
003955: Dec 5 23:24:03.345: //276/1AD0BA3880F0/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
003956: Dec 5 23:24:03.345: //276/1AD0BA3880F0/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x48DEBDD8 to default port=5060
003957: Dec 5 23:24:03.345: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:72.55.168.18, rport:5060 with laddr:
003958: Dec 5 23:24:03.345: //276/1AD0BA3880F0/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x48DEBDD8
003959: Dec 5 23:24:03.345: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x48DEBDD8, addr=72.55.168.18, port=5060, local_addr=, connId=4 for UDP
003960: Dec 5 23:24:03.349: //276/1AD0BA3880F0/SIP/Info/sentInviteResponse18x: Sent a 18x Response
003961: Dec 5 23:24:03.349: //276/1AD0BA3880F0/SIP/State/sipSPIChangeState: 0x4D195650 : State change from (STATE_RECD_INVITE, SUBSTATE_NONE) to (STATE_SENT_ALERTING, SUBSTATE_NONE)
003962: Dec 5 23:24:03.349: //276/1AD0BA3880F0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <sip:12345678@172.16.16.2:5060>;tag=52CC2C-269B
CSeq: 102 INVITE
Remote-Party-ID: "Jakub Stroinski" <sip:2339@172.16.16.2>;party=called;screen=no;privacy=off
Contact: <sip:60037a2b-e0b4-7c3f-dd9f-4eca6b99@172.16.16.2:5060>
Content-Length: 0
003963: Dec 5 23:24:18.341: //277/1AD0BA3880F0/SIP/Info/ccsip_call_statistics: Requesting stats for callid=277
003964: Dec 5 23:24:18.341: //277/1AD0BA3880F0/SIP/Info/ccsip_call_statistics: Stats request failed for callid=277, dstCallID=-1, rc=-7
003965: Dec 5 23:24:18.341: //277/1AD0BA3880F0/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
003966: Dec 5 23:24:18.341: //277/1AD0BA3880F0/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
003967: Dec 5 23:24:18.341: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
003968: Dec 5 23:24:18.341: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_codec_byte_transrating: tranrating not enabled on peers, return FALSE
003969: Dec 5 23:24:18.345: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 8
003970: Dec 5 23:24:18.345: //277/1AD0BA3880F0/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 3 event
003971: Dec 5 23:24:18.345: //277/1AD0BA3880F0/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer: Could not get any elements from TD Container
003972: Dec 5 23:24:18.345: //277/1AD0BA3880F0/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer: Could not get any elements from TD Container
003973: Dec 5 23:24:18.345: //277/1AD0BA3880F0/SIP/Info/sipSPISendCancel: Associated container=0x4E598A6C to Cancel
003974: Dec 5 23:24:18.345: //277/1AD0BA3880F0/SIP/Transport/sipSPISendCancel: Sending CANCEL to the transport layer
003975: Dec 5 23:24:18.345: //277/1AD0BA3880F0/SIP/Transport/sipSPITransportSendMessage: msg=0x48DEBDD8, addr=172.16.16.21, port=5060, sentBy_port=0, local_addr=, is_req=1, transport=1, switch=0, callBack=0x41BD7784
003976: Dec 5 23:24:18.345: //277/1AD0BA3880F0/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
003977: Dec 5 23:24:18.345: //277/1AD0BA3880F0/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
003978: Dec 5 23:24:18.345: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:172.16.16.21, rport:5060 with laddr:
003979: Dec 5 23:24:18.345: //277/1AD0BA3880F0/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x48DEBDD8
003980: Dec 5 23:24:18.345: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x48DEBDD8, addr=172.16.16.21, port=5060, local_addr=, connId=7 for UDP
003981: Dec 5 23:24:18.345: //277/1AD0BA3880F0/SIP/Info/sentCancelDisconnecting: Sent Cancel Request, starting CancelWaitResponseTimer
003982: Dec 5 23:24:18.345: //277/1AD0BA3880F0/SIP/State/sipSPIChangeState: 0x4D1A05E0 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING) to (STATE_DISCONNECTING, SUBSTATE_NONE)
003983: Dec 5 23:24:18.349: //277/1AD0BA3880F0/SIP/Msg/ccsipDisplayMsg:
Sent:
CANCEL sip:2339@172.16.16.21:5060 SIP/2.0
CSeq: 101 CANCEL
Max-Forwards: 70
Timestamp: 1449357858
Reason: Q.850;cause=16
Content-Length: 0
003984: Dec 5 23:24:18.357: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [172.16.16.21]:50681, local_address:[ - ]
003985: Dec 5 23:24:18.357: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
003986: Dec 5 23:24:18.357: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
003987: Dec 5 23:24:18.357: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
003988: Dec 5 23:24:18.357: //277/1AD0BA3880F0/SIP/Info/sipSPIMatchRespToReqTran: removing unneeded z9hG4bK8580 from via branch list
003989: Dec 5 23:24:18.357: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIRemoveBranchName: invalid ccb, bName or branch list for sipSPIRemoveBranchName
003990: Dec 5 23:24:18.361: //277/1AD0BA3880F0/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Date: Sat, 05 Dec 2015 23:24:18 GMT
CSeq: 101 CANCEL
Content-Length: 0
003991: Dec 5 23:24:18.361: //277/1AD0BA3880F0/SIP/Info/sipSPICheckResponseExt: non-INVITE response with no RSEQ - do not disable IS_REL1XX
003992: Dec 5 23:24:18.361: //277/1AD0BA3880F0/SIP/Info/sipSPIIcpifUpdate: CallState: 2 Playout: 0 DiscTime:544123 ConnTime 0
003993: Dec 5 23:24:18.361: //277/1AD0BA3880F0/SIP/Media/sipSPIDestroyRtpSession: stream:4AAA0C50
003994: Dec 5 23:24:18.369: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x4D1A5DA8) with key=[246] to table
003995: Dec 5 23:24:18.369: //-1/000000000000/SIP/Info/sipSPI_ipip_vcc_Initialization: Entry...
003996: Dec 5 23:24:18.369: //-1/000000000000/SIP/Info/ccsip_offer_ans_init:
003997: Dec 5 23:24:18.369: //278/000000000000/SIP/State/sipSPIChangeState: 0x4D1A5DA8 : State change from (STATE_NONE, SUBSTATE_NONE) to (STATE_IDLE, SUBSTATE_NONE)
003998: Dec 5 23:24:18.369: //278/000000000000/SIP/Info/ccsip_call_setup_request: Set Protocol information
003999: Dec 5 23:24:18.369: //278/000000000000/SIP/Info/ccsip_call_setup_request: Before processing SETUP REQccb->pld.flags_ipip = 200
004000: Dec 5 23:24:18.369: //278/000000000000/SIP/Info/ccsip_call_setup_request:
004001: Dec 5 23:24:18.369: //278/000000000000/SIP/Info/ccsip_gw_set_sipspi_mode: Setting SPI mode to SIP-SIP
004002: Dec 5 23:24:18.369: //278/000000000000/SIP/Info/ccsip_call_setup_request: After processing SETUP REQccb->pld.flags_ipip = 400000
004003: Dec 5 23:24:18.369: //278/000000000000/SIP/Info/ccsip_call_setup_request: Copy over rediectNumber from call info
004004: Dec 5 23:24:18.369: //278/000000000000/SIP/Info/ccsip_call_setup_request: Copied the OrigRedirectNumber () from call info
004005: Dec 5 23:24:18.369: //278/24183DC980F7/SIP/Info/ccsip_call_setup_request: Copy over rediectNumber from ssInfo
004006: Dec 5 23:24:18.369: //278/24183DC980F7/SIP/Info/ccsip_call_setup_request: ccb->call_info.origRedirectNumber = 2339
004007: Dec 5 23:24:18.373: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetOutboundHostAndDestHostPrivate: CCSIP: target_host : 72.55.168.18 target_port : 5060
004008: Dec 5 23:24:18.373: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
004009: Dec 5 23:24:18.373: //278/24183DC980F7/SIP/Info/ccsip_call_setup_request: Incrementing call counter to [1] in dial-peer [3]
004010: Dec 5 23:24:18.373: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: switch(ev.ev_id: 174)
004011: Dec 5 23:24:18.373: //276/1AD0BA3880F0/SIP/Info/ccsip_event_handler:
ccsip_event_handler: peer ID 278 chans 0x48E53118 event 174 flags 0xC0001C 0x10000100 0x400403 data 0x48E53118
004012: Dec 5 23:24:18.373: //276/1AD0BA3880F0/SIP/Info/ccsip_event_handler:
ccsip_event_handler: CC_EV_H245_SET_MODE: peer ID 278 chans 0x48E53118 event 174 flags 0xC0001C 0x10000100 0x400403 data 0x48E53118, type = 1
004013: Dec 5 23:24:18.373: //276/1AD0BA3880F0/SIP/Info/ccsip_gw_set_sipspi_mode: Setting SPI mode to SIP-SIP
004014: Dec 5 23:24:18.373: //276/1AD0BA3880F0/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SET_MODE
004015: Dec 5 23:24:18.373: //276/1AD0BA3880F0/SIP/Info/Session-Timer/sipSTSLMain:
004016: Dec 5 23:24:18.373: //276/1AD0BA3880F0/SIP/Info/ccsip_event_handler:
004017: Dec 5 23:24:18.373: //276/1AD0BA3880F0/SIP/Info/sipSPIHandleMediaFlowModeChange:
004018: Dec 5 23:24:18.373: //276/1AD0BA3880F0/SIP/Info/sipSPIHandleMediaFlowModeChange: current media flow mode is 1, desired media flow mode is 1
004019: Dec 5 23:24:18.373: //276/1AD0BA3880F0/SIP/Info/sipSPIHandleMediaFlowModeChange: current flow mode is same as desired flow mode
004020: Dec 5 23:24:18.373: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: CC_R_SUCCESS_WITH_CONFIRMED
004021: Dec 5 23:24:18.373: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 2
004022: Dec 5 23:24:18.373: //278/24183DC980F7/SIP/Info/sipSPIUaddccCallIdToTable: Adding call id 116 to table
004023: Dec 5 23:24:18.373: //278/24183DC980F7/SIP/Info/sipSPIGetCallConfig: preferred_codec set[0] type :No Codec bytes: 0
004024: Dec 5 23:24:18.373: //278/24183DC980F7/SIP/Info/sipSPIGetCallConfig: Media forking disabled
004025: Dec 5 23:24:18.377: //278/24183DC980F7/SIP/Info/sipSPIGetCallConfig: Media Antitrombone disabled
004026: Dec 5 23:24:18.377: //278/24183DC980F7/SIP/Info/sipSPICanSetFallbackFlag: Local Fallback is not active
004027: Dec 5 23:24:18.377: //278/24183DC980F7/SIP/Info/sipSPISetMediaFlowMode: Storing the configured mode as FLOW-THROUGH
004028: Dec 5 23:24:18.377: //278/24183DC980F7/SIP/Info/sipSPISetMediaFlowMode: xcoder high-density disabled
004029: Dec 5 23:24:18.377: //278/24183DC980F7/SIP/Info/sipSPISetMediaFlowMode: Flow Mode set to FLOW_THROUGH
004030: Dec 5 23:24:18.377: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetSipProfilesTag: voice class SIP Profiles tag is set : 1
004031: Dec 5 23:24:18.377: //278/24183DC980F7/SIP/Info/sipSPIGetCallConfig: Checking Video Type Rate=-1 video_codec_allowed=1F
004032: Dec 5 23:24:18.377: //278/24183DC980F7/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabled
004033: Dec 5 23:24:18.377: //278/24183DC980F7/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=276
004034: Dec 5 23:24:18.377: //278/24183DC980F7/SIP/Info/sipSPIGetCallConfig: Media forking disabled
004035: Dec 5 23:24:18.377: //278/24183DC980F7/SIP/Info/sipSPISetOverlapConfiguration: Overlap signaling: FALSE: Endpt: SIP Trunk
004036: Dec 5 23:24:18.377: //278/24183DC980F7/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
004037: Dec 5 23:24:18.377: //278/24183DC980F7/SIP/Info/sipSPI_ipip_GetCopyListCfg: Copy-list config:2 tag:0
004038: Dec 5 23:24:18.377: //278/24183DC980F7/SIP/Info/sipSPI_ipip_build_consolidated_header_list: Both passthru and copylist are disabled
004039: Dec 5 23:24:18.377: //278/24183DC980F7/SIP/Info/sipSPIValidateAndCopyOutboundHost: CCSIP: copy target_host to outbound_host
004040: Dec 5 23:24:18.377: //278/24183DC980F7/SIP/Info/preprocessSetup:
004041: Dec 5 23:24:18.377: //278/24183DC980F7/SIP/Info/sipSPI_ipip_copy_peer_channelInfo_to_sdp: Valid peer channels available!!
004042: Dec 5 23:24:18.377: //278/24183DC980F7/SIP/Info/sipSPI_ipip_copy_peer_channelInfo_to_sdp: No video caps posted by peer
004043: Dec 5 23:24:18.377: //278/24183DC980F7/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp:
callid 278, channels 0x4E6EDAEC caps 0x48E37E48
004044: Dec 5 23:24:18.377: //278/24183DC980F7/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: Peer cap provided: callid = 278, peer dtmf = 6peer t38 version = 0 peer t38 maxBitRate = 0
004045: Dec 5 23:24:18.377: //278/24183DC980F7/SIP/Info/sipSPIDtmfTranscoder: Return upon SCCP version 0
004046: Dec 5 23:24:18.377: //278/24183DC980F7/SIP/Info/sipSPISrtpTranscoder:
004047: Dec 5 23:24:18.377: //278/24183DC980F7/SIP/Info/sipSPIAudioLevelAdjustmentTranscoder: Entry..
004048: Dec 5 23:24:18.377: //278/24183DC980F7/SIP/Info/sipSPIAudioLevelAdjustmentTranscoder: AudioLevelAdjustment do not need xcoder
004049: Dec 5 23:24:18.377: //278/24183DC980F7/SIP/Info/sipSPI_ipip_codec_byte_transrating: tranrating not enabled on peers, return FALSE
004050: Dec 5 23:24:18.377: //278/24183DC980F7/SIP/Info/sipSPICodecTranscoder: No body else needs xcoder. OFFER_ALL is intact
004051: Dec 5 23:24:18.377: //278/24183DC980F7/SIP/Info/sipSPI_ipip_vcc_CheckVoiceClassCodecConfiguration: None of the call leg supports Voice Class Codec..
004052: Dec 5 23:24:18.377: //278/24183DC980F7/SIP/Info/sipSPICodecTranscoder: Static codec or Equalset or Subset w/o offer-all. For DO call, offer-all is NO-OP..
004053: Dec 5 23:24:18.377: //278/24183DC980F7/SIP/Info/codec_found:
004054: Dec 5 23:24:18.377: //278/24183DC980F7/SIP/Info/codec_found: codecs[i] = 5 & codec = 5 are same..
004055: Dec 5 23:24:18.381: //278/24183DC980F7/SIP/Info/sipSPIUpdatePreferredCodec: num_chans = 1
004056: Dec 5 23:24:18.381: //278/24183DC980F7/SIP/Info/sipSPICheckAndReserveTranscoder: Xcoder is not needed
004057: Dec 5 23:24:18.381: //278/24183DC980F7/SIP/Info/sipSPISrtpTranscoder:
004058: Dec 5 23:24:18.381: //278/24183DC980F7/SIP/Info/sipSPI_ipip_setOptionTagInfo: Option Tag Rel1xx value is 0
004059: Dec 5 23:24:18.381: //-1/xxxxxxxxxxxx/SIP/Info/resolve_media_ip_address_to_bind: calling reg_invoke_ip_first_hop()
004060: Dec 5 23:24:18.381: //-1/xxxxxxxxxxxx/SIP/Info/resolve_media_ip_address_to_bind: calling ip_best_local_address()
004061: Dec 5 23:24:18.381: //-1/xxxxxxxxxxxx/SIP/Info/resolve_media_ip_address_to_bind: return addr 172.16.16.2
004062: Dec 5 23:24:18.381: //278/24183DC980F7/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 172.16.16.2
004063: Dec 5 23:24:18.381: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling reg_invoke_ip_first_hop()
004064: Dec 5 23:24:18.381: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling ip_best_local_address()
004065: Dec 5 23:24:18.381: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: return addr 172.16.16.2
004066: Dec 5 23:24:18.381: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 16766 for stream 1
004067: Dec 5 23:24:18.381: //278/24183DC980F7/SIP/Media/sipSPIAddSDPMediaPayload: Preferred method of dtmf relay is: 6, with payload: 101
004068: Dec 5 23:24:18.381: //278/24183DC980F7/SIP/Media/sipSPIAddSDPMediaPayload: Preferred method of dtmf relay is: 1, with payload: 121
004069: Dec 5 23:24:18.381: //278/24183DC980F7/SIP/Info/sipSPIAddSDPPayloadAttributes:
max_event 16
004070: Dec 5 23:24:18.381: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
004071: Dec 5 23:24:18.381: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
004072: Dec 5 23:24:18.381: //278/24183DC980F7/SIP/Info/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
004073: Dec 5 23:24:18.381: //278/24183DC980F7/SIP/Info/sipSPIOutgoingCallSDP: Creating recv-only stream for outbound call
004074: Dec 5 23:24:18.385: //278/24183DC980F7/SIP/Media/sipSPIProcessRtpSessions: No active streams.
004075: Dec 5 23:24:18.385: //278/24183DC980F7/SIP/Info/sip_gw_pre_setup_add_sdp_container: SDP container added
004076: Dec 5 23:24:18.385: //278/24183DC980F7/SIP/Info/sipSPIValidateGtd: Signal Forward disabled
004077: Dec 5 23:24:18.385: //278/24183DC980F7/SIP/Info/sipSPIValidateTunnelData: RawMsg/QSIG Tunneling Not Enabled
004078: Dec 5 23:24:18.385: //278/24183DC980F7/SIP/Info/sipSPIAddMLPPServicesInfo: No MLP Info available on incoming leg
004079: Dec 5 23:24:18.385: //278/24183DC980F7/SIP/Info/sipSPIPreprocessUriFormat: Url cfg for 1: 2,phone-ctxt=FALSE
004080: Dec 5 23:24:18.385: //278/24183DC980F7/SIP/Info/sipSPIAddPrivacyandIdentityInfo: Using globally configured ppi header
004081: Dec 5 23:24:18.385: //278/24183DC980F7/SIP/Info/sipSPICompareHistoryInfoWithMatchedDialpeer: call-route history-info CLI not enabled
004082: Dec 5 23:24:18.385: //278/24183DC980F7/SIP/Info/sipSPI_ipip_set_history_info_header: No HI header recvd from container
004083: Dec 5 23:24:18.385: //278/24183DC980F7/SIP/Info/sipSPI_ipip_set_diversion_header: No diversion header recvd from container
004084: Dec 5 23:24:18.385: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling reg_invoke_ip_first_hop()
004085: Dec 5 23:24:18.389: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling ip_best_local_address()
004086: Dec 5 23:24:18.389: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: return addr 172.16.16.2
004087: Dec 5 23:24:18.389: //278/24183DC980F7/SIP/Info/sipSPIRscmsmAvail: Value returned by check is = 0
004088: Dec 5 23:24:18.389: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling reg_invoke_ip_first_hop()
004089: Dec 5 23:24:18.389: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling ip_best_local_address()
004090: Dec 5 23:24:18.389: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: return addr 172.16.16.2
004091: Dec 5 23:24:18.389: //278/24183DC980F7/SIP/Info/sipSPIUaddCcbToUACTable: ****Adding to UAC table.
004092: Dec 5 23:24:18.389: //278/24183DC980F7/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x4D1A5DA8 key=241BE751-9ADE11E5-80FBDB8C-E7BAB034@172.16.16.2
004093: Dec 5 23:24:18.389: //278/24183DC980F7/SIP/Info/sipSPIUsetBillingProfile: sipCallId for billing records = 241BE751-9ADE11E5-80FBDB8C-E7BAB034@172.16.16.2
004094: Dec 5 23:24:18.389: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 72.55.168.18,Port 5060, Transport 1, SentBy Port 5060
004095: Dec 5 23:24:18.389: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone EST to SIP default timezone = GMT
004096: Dec 5 23:24:18.389: //278/24183DC980F7/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
004097: Dec 5 23:24:18.389: //278/24183DC980F7/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:4E596B24
004098: Dec 5 23:24:18.389: //278/24183DC980F7/SIP/Info/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_INITIAL_SR_REQ
004099: Dec 5 23:24:18.389: //278/24183DC980F7/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:2001
004100: Dec 5 23:24:18.389: //278/24183DC980F7/SIP/Info/Session-Timer/sipSTSLMain:
Configured SE:1800, Configured Min-SE:1800
004101: Dec 5 23:24:18.389: //278/24183DC980F7/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 0 event
004102: Dec 5 23:24:18.389: //278/24183DC980F7/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer: Could not get any elements from TD Container
004103: Dec 5 23:24:18.389: //278/24183DC980F7/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer: Could not get any elements from TD Container
004104: Dec 5 23:24:18.389: //278/24183DC980F7/SIP/Info/sipSPIgetRegistrarHost: multiple registrar mode, host name is 172.16.16.2
SIP: (278) Group (a= group line) attribute, level 65535 instance 1 not found.
004105: Dec 5 23:24:18.393: //278/24183DC980F7/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp dont have anat
004106: Dec 5 23:24:18.393: //278/24183DC980F7/SIP/Info/sipSPIAddDiversionHeaders: Build local diversion for last redirection
004107: Dec 5 23:24:18.393: //278/24183DC980F7/SIP/Info/addAllowHeaderKpml: KPML Subscriptions allowed.
004108: Dec 5 23:24:18.393: //278/24183DC980F7/SIP/Info/sipSPISendInvite: Associated container=0x4E596B24 to Invite
004109: Dec 5 23:24:18.393: //278/24183DC980F7/SIP/Transport/sipSPISendInvite: Sending Invite to the transport layer
004110: Dec 5 23:24:18.393: //278/24183DC980F7/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Dial peer configuration, Switch Transport is FALSE
004111: Dec 5 23:24:18.393: //278/24183DC980F7/SIP/Transport/sipSPITransportSendMessage: msg=0x499F2A34, addr=72.55.168.18, port=5060, sentBy_port=0, local_addr=, is_req=1, transport=1, switch=0, callBack=0x41BD5E20
004112: Dec 5 23:24:18.393: //-1/xxxxxxxxxxxx/SIP/Info/sip_profiles_application_modify_remove_header: Header before modification : From: "Jakub Stroinski" <sip:5143601234@172.16.16.2>;tag=5306F0-138A
004113: Dec 5 23:24:18.393: //278/24183DC980F7/SIP/Info/sip_profiles_check_and_get_variables_in_replace_pattern: substituted_replace_pattern : From: "Cisco Lab" <\
004114: Dec 5 23:24:18.393: //278/24183DC980F7/SIP/Info/sip_profiles_check_and_get_variables_in_replace_pattern: configured_replace_pattern : 2
004115: Dec 5 23:24:18.393: //-1/xxxxxxxxxxxx/SIP/Info/sip_profiles_application_modify_remove_header: Header after modification : From: "Cisco Lab" <sip:5143601234@172.16.16.2>;tag=5306F0-138A
004116: Dec 5 23:24:18.393: //-1/xxxxxxxxxxxx/SIP/Info/sip_profiles_application_modify_remove_header: Header before modification : Diversion: <sip:2339@172.16.16.2>;privacy=off;reason=no-answer;counter=1;screen=no
004117: Dec 5 23:24:18.393: //278/24183DC980F7/SIP/Info/sip_profiles_check_and_get_variables_in_replace_pattern: substituted_replace_pattern : <sip:5143601234@\
004118: Dec 5 23:24:18.393: //278/24183DC980F7/SIP/Info/sip_profiles_check_and_get_variables_in_replace_pattern: configured_replace_pattern : 1>
004119: Dec 5 23:24:18.397: //-1/xxxxxxxxxxxx/SIP/Info/sip_profiles_application_modify_remove_header: Header after modification : Diversion: <sip:5143601234@172.16.16.2>;privacy=off;reason=no-answer;counter=1;screen=no
004120: Dec 5 23:24:18.397: //278/24183DC980F7/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
004121: Dec 5 23:24:18.397: //278/24183DC980F7/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
004122: Dec 5 23:24:18.397: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:72.55.168.18, rport:5060 with laddr:
004123: Dec 5 23:24:18.397: //278/24183DC980F7/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x499F2A34
004124: Dec 5 23:24:18.397: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x499F2A34, addr=72.55.168.18, port=5060, local_addr=, connId=4 for UDP
004125: Dec 5 23:24:18.397: //278/24183DC980F7/SIP/Info/sentInviteRequest: Sent Invite in state STATE_IDLE
004126: Dec 5 23:24:18.397: //-1/xxxxxxxxxxxx/SIP/Info/sentInviteRequest: Transaction active. Facilities will be queued.
004127: Dec 5 23:24:18.397: //278/24183DC980F7/SIP/State/sipSPIChangeState: 0x4D1A5DA8 : State change from (STATE_IDLE, SUBSTATE_NONE) to (STATE_SENT_INVITE, SUBSTATE_NONE)
004128: Dec 5 23:24:18.397: //278/24183DC980F7/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 278) to the VOIP RTP library
004129: Dec 5 23:24:18.397: //278/24183DC980F7/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
004130: Dec 5 23:24:18.397: //278/24183DC980F7/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 172.16.16.2
004131: Dec 5 23:24:18.397: //278/24183DC980F7/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
004132: Dec 5 23:24:18.397: //278/24183DC980F7/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
laddr = 172.16.16.2, lport = 16766, raddr = 0.0.0.0, rport=0, do_rtcp=FALSE
src_callid = 278, dest_callid = -1, stream type = voice+dtmf, stream direction = RECVONLY
004133: Dec 5 23:24:18.397: //278/24183DC980F7/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
004134: Dec 5 23:24:18.397: //278/24183DC980F7/SIP/Info/sipSPICreateRtpSession: sess: 499F3114 do_rtcp:0
004135: Dec 5 23:24:18.397: //276/1AD0BA3880F0/SIP/Info/ccsip_update_peer_caps: Stream is NULL
004136: Dec 5 23:24:18.397: //276/1AD0BA3880F0/SIP/Info/ccsip_update_peer_caps: gccb/stream is NULL, not updating now !!
004137: Dec 5 23:24:18.397: //278/24183DC980F7/SIP/Info/sipSPIUpdateGccb: Failure from the peer leg so no updations now!!
004138: Dec 5 23:24:18.397: //278/24183DC980F7/SIP/Media/sipSPICreateRtpSession: stun is disabled
004139: Dec 5 23:24:18.397: //278/24183DC980F7/SIP/State/sipSPIChangeStreamState: Stream (callid = 278) State changed from (STREAM_ADDING) to (STREAM_ACTIVE)
004140: Dec 5 23:24:18.401: //278/24183DC980F7/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:5148121234@72.55.168.18:5060 SIP/2.0
Via: SIP/2.0/UDP 172.16.16.2:5060;branch=z9hG4bK8613BE
To: <sip:5148121234@72.55.168.18>
Call-ID: 241BE751-9ADE11E5-80FBDB8C-E7BAB034@172.16.16.2
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 0605568457-2598244837-2163727244-3887771700
CSeq: 101 INVITE
Contact: <sip:5143601234@172.16.16.2:5060>
Call-Info: <sip:172.16.16.2:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Expires: 180
Allow-Events: kpml, telephone-event
Max-Forwards: 69
P-Preferred-Identity: "Jakub Stroinski" <sip:5143601234@172.16.16.2>
Content-Type: application/sdp
Content-Length: 301
v=0
o=CiscoSystemsSIP-GW-UserAgent 1183 7933 IN IP4 172.16.16.2
s=SIP Call
t=0 0
m=audio 16766 RTP/AVP 0 101 121
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=fmtp:121 0-15
a=ptime:20
004141: Dec 5 23:24:18.401: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [172.16.16.21]:50681, local_address:[ - ]
004142: Dec 5 23:24:18.405: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
004143: Dec 5 23:24:18.405: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
004144: Dec 5 23:24:18.405: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
004145: Dec 5 23:24:18.405: //277/1AD0BA3880F0/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 487 Request Cancelled
CSeq: 101 INVITE
Content-Length: 0
004146: Dec 5 23:24:18.405: //277/1AD0BA3880F0/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
004147: Dec 5 23:24:18.405: //277/1AD0BA3880F0/SIP/Info/sipSPISetInfoFromRpid: Received current remote name: Jakub Stroinski, current remote number: 2339
004148: Dec 5 23:24:18.405: //277/1AD0BA3880F0/SIP/Info/sipSPISetInfoFromRpid: Received ;screen=yes ;privacy=off -> Setting Octet3A 0x81, extended_privacy 0x00
004149: Dec 5 23:24:18.409: //277/1AD0BA3880F0/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 1 event
004150: Dec 5 23:24:18.409: //277/1AD0BA3880F0/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer: Could not get any elements from TD Container
004151: Dec 5 23:24:18.409: //277/1AD0BA3880F0/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer: Could not get any elements from TD Container
004152: Dec 5 23:24:18.409: //277/1AD0BA3880F0/SIP/Info/sipSPISendAck: Associated container=0x4E597154 to Ack
004153: Dec 5 23:24:18.409: //277/1AD0BA3880F0/SIP/Transport/sipSPISendAck: Sending ACK to the transport layer
004154: Dec 5 23:24:18.409: //277/1AD0BA3880F0/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Dial peer configuration, Switch Transport is FALSE
004155: Dec 5 23:24:18.409: //277/1AD0BA3880F0/SIP/Transport/sipSPITransportSendMessage: msg=0x4E77B280, addr=172.16.16.21, port=5060, sentBy_port=0, local_addr=, is_req=1, transport=1, switch=0, callBack=0x41BD7A94
004156: Dec 5 23:24:18.409: //277/1AD0BA3880F0/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
004157: Dec 5 23:24:18.409: //277/1AD0BA3880F0/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
004158: Dec 5 23:24:18.409: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:172.16.16.21, rport:5060 with laddr:
004159: Dec 5 23:24:18.409: //277/1AD0BA3880F0/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x4E77B280
004160: Dec 5 23:24:18.409: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4E77B280, addr=172.16.16.21, port=5060, local_addr=, connId=7 for UDP
004161: Dec 5 23:24:18.409: //277/1AD0BA3880F0/SIP/Info/sentErrorResponseCallClose: Sent Error Response since the Gw is Shutdown
004162: Dec 5 23:24:18.409: //277/1AD0BA3880F0/SIP/State/sipSPIChangeState: 0x4D1A05E0 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE) to (STATE_DEAD, SUBSTATE_NONE)
004163: Dec 5 23:24:18.409: //277/1AD0BA3880F0/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x4D1A05E0
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number : 5147221234
Called Number : 2339
Source IP Address (Sig ): 172.16.16.2
Destn SIP Req Addr:Port : 172.16.16.21:5060
Destn SIP Resp Addr:Port : 172.16.16.21:5060
Destination Name : 172.16.16.21
004164: Dec 5 23:24:18.409: //277/1AD0BA3880F0/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream : 1
Negotiated Codec : No Codec
Negotiated Codec Bytes : 0
Nego. Codec payload : 255 (tx), 255 (rx)
Negotiated Dtmf-relay : 0
Dtmf-relay Payload : 0 (tx), 0 (rx)
Source IP Address (Media): 172.16.16.2
Source IP Port (Media): 18858
Destn IP Address (Media): -
Destn IP Port (Media): 0
Orig Destn IP Address:Port (Media): [ - ]:0
004165: Dec 5 23:24:18.409: //277/1AD0BA3880F0/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC) : 16
Disconnect Cause (SIP) : 487
004166: Dec 5 23:24:18.409: //277/1AD0BA3880F0/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 115
004167: Dec 5 23:24:18.413: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:2339@172.16.16.21:5060 SIP/2.0
Date: Sat, 05 Dec 2015 23:24:02 GMT
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
004168: Dec 5 23:24:18.413: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [72.55.168.18]:5060, local_address:[ - ]
004169: Dec 5 23:24:18.413: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
004170: Dec 5 23:24:18.413: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x4AACC054
004171: Dec 5 23:24:18.413: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x4AACC054, addr=72.55.168.18, port=5060, local_addr=, connid=4, transport=UDP
004172: Dec 5 23:24:18.413: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
004173: Dec 5 23:24:18.417: //278/24183DC980F7/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP 172.16.16.2:5060;branch=z9hG4bK8613BE;received=66.11.41.90;rport=50744
To: <sip:5148121234@72.55.168.18>;tag=as2925a76a
CSeq: 101 INVITE
Server: voip.ms
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH
Supported: replaces, timer
WWW-Authenticate: Digest algorithm=MD5, realm="montreal3.voip.ms", nonce="07337ca9"
Content-Length: 0
004174: Dec 5 23:24:18.417: //278/24183DC980F7/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
004175: Dec 5 23:24:18.417: //278/24183DC980F7/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 1 event
004176: Dec 5 23:24:18.417: //278/24183DC980F7/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer: Could not get any elements from TD Container
004177: Dec 5 23:24:18.417: //278/24183DC980F7/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer: Could not get any elements from TD Container
004178: Dec 5 23:24:18.417: //278/24183DC980F7/SIP/Info/sipSPISendAck: Associated container=0x4E5986A4 to Ack
004179: Dec 5 23:24:18.417: //278/24183DC980F7/SIP/Transport/sipSPISendAck: Sending ACK to the transport layer
004180: Dec 5 23:24:18.417: //278/24183DC980F7/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Dial peer configuration, Switch Transport is FALSE
004181: Dec 5 23:24:18.417: //278/24183DC980F7/SIP/Transport/sipSPITransportSendMessage: msg=0x4E77B0DC, addr=72.55.168.18, port=5060, sentBy_port=0, local_addr=, is_req=1, transport=1, switch=0, callBack=0x0
004182: Dec 5 23:24:18.417: //278/24183DC980F7/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
004183: Dec 5 23:24:18.417: //278/24183DC980F7/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
004184: Dec 5 23:24:18.421: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:72.55.168.18, rport:5060 with laddr:
004185: Dec 5 23:24:18.421: //278/24183DC980F7/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x4E77B0DC
004186: Dec 5 23:24:18.421: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4E77B0DC, addr=72.55.168.18, port=5060, local_addr=, connId=4 for UDP
004187: Dec 5 23:24:18.421: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
004188: Dec 5 23:24:18.421: //278/24183DC980F7/SIP/Info/sipSPIGenerateAuthorizationResponse: HA1 is: 2036dec35aff8c54d564b52267c30fc7
004189: Dec 5 23:24:18.421: //278/24183DC980F7/SIP/State/sipSPIChangeState: 0x4D1A5DA8 : State change from (STATE_SENT_INVITE, SUBSTATE_NONE) to (STATE_IDLE, SUBSTATE_NONE)
004190: Dec 5 23:24:18.421: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone EST to SIP default timezone = GMT
004191: Dec 5 23:24:18.421: //278/24183DC980F7/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
004192: Dec 5 23:24:18.421: //278/24183DC980F7/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:4E596B24
004193: Dec 5 23:24:18.421: //278/24183DC980F7/SIP/Info/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_INITIAL_SR_REQ
004194: Dec 5 23:24:18.421: //278/24183DC980F7/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_LEG_BY_LEG, SE Value:0, SE Refresher:none, Min-SE Value:1800, flags:2001
004195: Dec 5 23:24:18.421: //278/24183DC980F7/SIP/Info/Session-Timer/sipSTSLMain:
004196: Dec 5 23:24:18.421: //278/24183DC980F7/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 0 event
004197: Dec 5 23:24:18.421: //278/24183DC980F7/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer: Could not get any elements from TD Container
004198: Dec 5 23:24:18.421: //278/24183DC980F7/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer: Could not get any elements from TD Container
004199: Dec 5 23:24:18.421: //278/24183DC980F7/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp dont have anat
004200: Dec 5 23:24:18.425: //278/24183DC980F7/SIP/Info/sipSPIAddDiversionHeaders: Build local diversion for last redirection
004201: Dec 5 23:24:18.425: //278/24183DC980F7/SIP/Info/sipSPISendInvite: Associated container=0x4E596B24 to Invite
004202: Dec 5 23:24:18.425: //278/24183DC980F7/SIP/Transport/sipSPISendInvite: Sending Invite to the transport layer
004203: Dec 5 23:24:18.425: //278/24183DC980F7/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Dial peer configuration, Switch Transport is FALSE
004204: Dec 5 23:24:18.425: //278/24183DC980F7/SIP/Transport/sipSPITransportSendMessage: msg=0x4E77B6B4, addr=72.55.168.18, port=5060, sentBy_port=0, local_addr=, is_req=1, transport=1, switch=0, callBack=0x41BD5E20
004205: Dec 5 23:24:18.425: //-1/xxxxxxxxxxxx/SIP/Info/sip_profiles_application_modify_remove_header: Header before modification : From: "Jakub Stroinski" <sip:5143601234@172.16.16.2>;tag=5306F0-138A
004206: Dec 5 23:24:18.425: //278/24183DC980F7/SIP/Info/sip_profiles_check_and_get_variables_in_replace_pattern: substituted_replace_pattern : From: "Cisco Lab" <\
004207: Dec 5 23:24:18.425: //278/24183DC980F7/SIP/Info/sip_profiles_check_and_get_variables_in_replace_pattern: configured_replace_pattern : 2
004208: Dec 5 23:24:18.425: //-1/xxxxxxxxxxxx/SIP/Info/sip_profiles_application_modify_remove_header: Header after modification : From: "Cisco Lab" <sip:5143601234@172.16.16.2>;tag=5306F0-138A
004209: Dec 5 23:24:18.425: //-1/xxxxxxxxxxxx/SIP/Info/sip_profiles_application_modify_remove_header: Header before modification : Diversion: <sip:2339@172.16.16.2>;privacy=off;reason=no-answer;counter=1;screen=no
004210: Dec 5 23:24:18.425: //278/24183DC980F7/SIP/Info/sip_profiles_check_and_get_variables_in_replace_pattern: substituted_replace_pattern : <sip:5143601234@\
004211: Dec 5 23:24:18.425: //278/24183DC980F7/SIP/Info/sip_profiles_check_and_get_variables_in_replace_pattern: configured_replace_pattern : 1>
004212: Dec 5 23:24:18.425: //-1/xxxxxxxxxxxx/SIP/Info/sip_profiles_application_modify_remove_header: Header after modification : Diversion: <sip:5143601234@172.16.16.2>;privacy=off;reason=no-answer;counter=1;screen=no
004213: Dec 5 23:24:18.425: //278/24183DC980F7/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
004214: Dec 5 23:24:18.425: //278/24183DC980F7/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
004215: Dec 5 23:24:18.429: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:72.55.168.18, rport:5060 with laddr:
004216: Dec 5 23:24:18.429: //278/24183DC980F7/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x4E77B6B4
004217: Dec 5 23:24:18.429: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4E77B6B4, addr=72.55.168.18, port=5060, local_addr=, connId=4 for UDP
004218: Dec 5 23:24:18.429: //278/24183DC980F7/SIP/Info/sentInviteRequest: Sent Invite in state STATE_IDLE
004219: Dec 5 23:24:18.429: //-1/xxxxxxxxxxxx/SIP/Info/sentInviteRequest: Transaction active. Facilities will be queued.
004220: Dec 5 23:24:18.429: //278/24183DC980F7/SIP/State/sipSPIChangeState: 0x4D1A5DA8 : State change from (STATE_IDLE, SUBSTATE_NONE) to (STATE_SENT_INVITE, SUBSTATE_NONE)
004221: Dec 5 23:24:18.429: //278/24183DC980F7/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 278) to the VOIP RTP library
004222: Dec 5 23:24:18.429: //278/24183DC980F7/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
004223: Dec 5 23:24:18.429: //278/24183DC980F7/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 172.16.16.2
004224: Dec 5 23:24:18.429: //278/24183DC980F7/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
004225: Dec 5 23:24:18.429: //278/24183DC980F7/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
004226: Dec 5 23:24:18.429: //278/24183DC980F7/SIP/Media/sipSPIUpdateRtcpSession: RTP session already created - update
004227: Dec 5 23:24:18.429: //276/1AD0BA3880F0/SIP/Info/ccsip_update_peer_caps: Stream is NULL
004228: Dec 5 23:24:18.429: //276/1AD0BA3880F0/SIP/Info/ccsip_update_peer_caps: gccb/stream is NULL, not updating now !!
004229: Dec 5 23:24:18.429: //278/24183DC980F7/SIP/Info/sipSPIUpdateGccb: Failure from the peer leg so no updations now!!
004230: Dec 5 23:24:18.429: //278/24183DC980F7/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:48DEBE48
004231: Dec 5 23:24:18.429: //278/24183DC980F7/SIP/State/sipSPIChangeStreamState: Stream (callid = 278) State changed from (STREAM_ADDING) to (STREAM_ACTIVE)
004232: Dec 5 23:24:18.429: //278/24183DC980F7/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:5148121234@72.55.168.18:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
004233: Dec 5 23:24:18.433: //278/24183DC980F7/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.16.16.2:5060;branch=z9hG4bK87546
Min-SE: 1800
CSeq: 102 INVITE
Expires: 180
Authorization: Digest username="12345678",realm="montreal3.voip.ms",uri="sip:5148121234@72.55.168.18:5060",response="c29851ed4956b091b15770ab1960afb3",nonce="07337ca9",algorithm=MD5
Max-Forwards: 69
Content-Length: 301
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=fmtp:121 0-15
a=ptime:20
004234: Dec 5 23:24:18.441: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [72.55.168.18]:5060, local_address:[ - ]
004235: Dec 5 23:24:18.441: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
004236: Dec 5 23:24:18.441: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x4AACC054
004237: Dec 5 23:24:18.441: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x4AACC054, addr=72.55.168.18, port=5060, local_addr=, connid=4, transport=UDP
004238: Dec 5 23:24:18.441: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
004239: Dec 5 23:24:18.445: //278/24183DC980F7/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 172.16.16.2:5060;branch=z9hG4bK87546;received=66.11.41.90;rport=50744
CSeq: 102 INVITE
Server: voip.ms
Session-Expires: 1800;refresher=uas
Contact: <sip:5148121234@72.55.168.18:5060>
Content-Length: 0
004240: Dec 5 23:24:18.445: //278/24183DC980F7/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
004241: Dec 5 23:24:18.445: //278/24183DC980F7/SIP/State/sipSPIChangeState: 0x4D1A5DA8 : State change from (STATE_SENT_INVITE, SUBSTATE_NONE) to (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)
004242: Dec 5 23:24:19.333: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [72.55.168.18]:5060, local_address:[ - ]
004243: Dec 5 23:24:19.333: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
004244: Dec 5 23:24:19.333: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x4AACC054
004245: Dec 5 23:24:19.333: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x4AACC054, addr=72.55.168.18, port=5060, local_addr=, connid=4, transport=UDP
004246: Dec 5 23:24:19.333: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
004247: Dec 5 23:24:19.337: //278/24183DC980F7/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
To: <sip:5148121234@72.55.168.18>;tag=as21595864
CSeq: 102 INVITE
Server: voip.ms
Require: timer
Content-Length: 223
v=0
o=root 1156775742 1156775742 IN IP4 72.55.168.18
s=voip.ms
c=IN IP4 72.55.168.18
t=0 0
m=audio 17972 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
004248: Dec 5 23:24:19.337: //278/24183DC980F7/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
004249: Dec 5 23:24:19.337: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
004250: Dec 5 23:24:19.337: //278/24183DC980F7/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
004251: Dec 5 23:24:19.337: //278/24183DC980F7/SIP/Info/sipSPIValidateConnectionAddress: Dest port = 17972
SIP: Attribute mid, level 1 instance 1 not found.
004252: Dec 5 23:24:19.341: //278/24183DC980F7/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
004253: Dec 5 23:24:19.341: //278/24183DC980F7/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 172.16.16.2
004254: Dec 5 23:24:19.341: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec No Codec
004255: Dec 5 23:24:19.341: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 96
004256: Dec 5 23:24:19.341: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) could not be reserved
as its in use by other codec No Codec
004257: Dec 5 23:24:19.341: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPT: Requested payload-Type (101) is reserved by another application
004258: Dec 5 23:24:19.341: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
004259: Dec 5 23:24:19.341: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 101
004260: Dec 5 23:24:19.341: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAllocateFreeDynamicPT: Allocating free Dynamic Payload : 98 for Codec:
004261: Dec 5 23:24:19.341: //278/24183DC980F7/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711ulaw) Negotiation Successful on Static Payload for m-line 1
004262: Dec 5 23:24:19.341: //278/24183DC980F7/SIP/Info/sipSPIDoPtimeNegotiation: One ptime attribute found - value:20
004263: Dec 5 23:24:19.341: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g711ulaw ptime :20, codecbytes: 160
004264: Dec 5 23:24:19.341: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
004265: Dec 5 23:24:19.341: //278/24183DC980F7/SIP/Media/sipSPIDoPtimeNegotiation: Offered ptime:20, Negotiated ptime:20 Negotiated codec bytes: 160 for codec g711ulaw
004266: Dec 5 23:24:19.341: //278/24183DC980F7/SIP/Info/sipSPISetFaxFlags: FAX_PASSTHROUGH = 0, END_FAX_PASSTHROUGH = 0
004267: Dec 5 23:24:19.341: //278/24183DC980F7/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
004268: Dec 5 23:24:19.341: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec
004269: Dec 5 23:24:19.341: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec
004270: Dec 5 23:24:19.341: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
004271: Dec 5 23:24:19.341: //278/24183DC980F7/SIP/Info/sipSPIReserveRtpNtePayload: Reserved the payload type 101 for RTP-NTE
004272: Dec 5 23:24:19.341: //278/24183DC980F7/SIP/Info/sipSPIDoDTMFRelayNegotiation: RTP-NTE DTMF relay option
004273: Dec 5 23:24:19.341: //278/24183DC980F7/SIP/Info/sipSPIDoDTMFRelayNegotiation: Case of full named event(NE) match in fmtp list of events.
004274: Dec 5 23:24:19.341: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: V150 NSE payload = 0, SSE payload = 0, SPRT payload=0
004275: Dec 5 23:24:19.341: //278/24183DC980F7/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
004276: Dec 5 23:24:19.341: //278/24183DC980F7/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
004277: Dec 5 23:24:19.341: //278/24183DC980F7/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
payload_type=0, codec_bytes=160, codec=g711ulaw, dtmf_relay=rtp-nte
stream_type=voice+dtmf (1), dest_ip_address=72.55.168.18, dest_port=17972
004278: Dec 5 23:24:19.341: //278/24183DC980F7/SIP/State/sipSPIChangeStreamState: Stream (callid = -1) State changed from (STREAM_DEAD) to (STREAM_ADDING)
004279: Dec 5 23:24:19.345: //278/24183DC980F7/SIP/Media/sipSPIReplaceSDP: Main stream got changed & it's Flow Around
004280: Dec 5 23:24:19.345: //278/24183DC980F7/SIP/Media/sipSPIUpdCallWithSdpInfo:
Preferred Codec : g711ulaw, bytes :160
Preferred DTMF relay : rtp-nte
Preferred NTE payload : 101
Early Media : No
Delayed Media : No
Bridge Done : No
New Media : No
DSP DNLD Reqd : No
004281: Dec 5 23:24:19.345: //278/24183DC980F7/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
004282: Dec 5 23:24:19.345: //278/24183DC980F7/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 172.16.16.2
004283: Dec 5 23:24:19.345: //278/24183DC980F7/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 278 peer 276 flags 0x400005 state STATE_RECD_PROCEEDING
004284: Dec 5 23:24:19.345: //278/24183DC980F7/SIP/Info/sipSPI_ipip_vcc_ProcessXcoderNeeded: xcoder_attached not yet initialised for this call.
004285: Dec 5 23:24:19.345: //278/24183DC980F7/SIP/Info/sipSPI_ipip_report_media_to_peer: Xcoder not yet used for the call
004286: Dec 5 23:24:19.345: //278/24183DC980F7/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
004287: Dec 5 23:24:19.345: //278/24183DC980F7/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
004288: Dec 5 23:24:19.345: //278/24183DC980F7/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CallID 278, Peer CallID 276, sdp 0x4E78A380 channels 0x4D1A7344
004289: Dec 5 23:24:19.345: //278/24183DC980F7/SIP/Info/copy_channels:
callId 278 size 240 ptr 0x48DEBE48)
004290: Dec 5 23:24:19.345: //278/24183DC980F7/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: stream_callid = 278
004291: Dec 5 23:24:19.345: //278/24183DC980F7/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: reset the switch..
004292: Dec 5 23:24:19.345: //278/24183DC980F7/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Hndl ptype 0 mline 1
004293: Dec 5 23:24:19.345: //278/24183DC980F7/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711ulaw
004294: Dec 5 23:24:19.345: //278/24183DC980F7/SIP/Info/codec_found:
Codec to be matched: 5
004295: Dec 5 23:24:19.345: //278/24183DC980F7/SIP/Info/codec_found: codecs[i] = 5 & codec = 5 are same..
004296: Dec 5 23:24:19.345: //278/24183DC980F7/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: ADD AUDIO CODEC 5
004297: Dec 5 23:24:19.345: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
004298: Dec 5 23:24:19.345: //278/24183DC980F7/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation done: stream->negotiated_ptime=20,stream->negotiated_codec_bytes=160, coverted ptime=20 stream->mline_index=1, media_ndx=1
004299: Dec 5 23:24:19.345: //278/24183DC980F7/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Adding codec 5 ptype 0 time 20, bytes 160 as channel 0 mline 1 ss 1 72.55.168.18:17972
004300: Dec 5 23:24:19.345: //278/24183DC980F7/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
Hndl ptype 101 mline 1
004301: Dec 5 23:24:19.345: //278/24183DC980F7/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: setting ipip_caps DTMF to RFC2833: callid = 278, dtmf = 6
004302: Dec 5 23:24:19.345: //278/24183DC980F7/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = 5
004303: Dec 5 23:24:19.345: //278/24183DC980F7/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = -1
004304: Dec 5 23:24:19.345: //278/24183DC980F7/SIP/Info/sipSPI_ipip_report_media_to_peer: Updating tagdata..
004305: Dec 5 23:24:19.349: //278/24183DC980F7/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 278 flags 0x10000100 state STATE_RECD_PROCEEDING
004306: Dec 5 23:24:19.349: //278/24183DC980F7/SIP/Info/sipSPI_ipip_report_media_to_peer: Reporting media in Substate SUBSTATE_PROCEEDING_PROCEEDING
004307: Dec 5 23:24:19.349: //278/24183DC980F7/SIP/Info/sipSPI_ipip_report_media_to_peer:
Report initial call media
004308: Dec 5 23:24:19.349: //278/24183DC980F7/SIP/Info/sipSPI_ipip_report_media_to_peer: ccb->flags 0x400018, ccb->pld.flags_ipip 0x400005
004309: Dec 5 23:24:19.349: //278/24183DC980F7/SIP/Info/sipSPI_ipip_report_media_to_peer: Updating the negotiated codec bytes
004310: Dec 5 23:24:19.349: //278/24183DC980F7/SIP/Info/sipSPI_ipip_report_media_to_peer: Post CAPS to peer.
004311: Dec 5 23:24:19.349: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_caps_ind_internal:
destCallID=276, srcCallID=278,
peer_ccb->call_info.currentLocalName=Jakub Stroinski,
peer_ccb->call_info.currentRemoteName=,
ccb->call_info.currentRemoteName=Jakub Stroinski
004312: Dec 5 23:24:19.349: //276/1AD0BA3880F0/SIP/Info/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=276, current_seq_num=0x598
004313: Dec 5 23:24:19.349: //276/1AD0BA3880F0/SIP/Info/ccsip_get_rtcp_session_parameters: NEW VALUES: stream_callid=276, current_seq_num=0x0
004314: Dec 5 23:24:19.349: //276/1AD0BA3880F0/SIP/Info/ccsip_update_stream_negotiated_codec: Codec that peer call leg has indicated is same what this call leg is already using.. Do nothing..
004315: Dec 5 23:24:19.349: //276/1AD0BA3880F0/SIP/Info/ccsip_caps_ind_internal: Load DSP with negotiated codec: g711ulaw, Bytes=160
004316: Dec 5 23:24:19.349: //276/1AD0BA3880F0/SIP/Info/ccsip_caps_ind_internal: Set forking flag to 0x0
004317: Dec 5 23:24:19.349: //276/1AD0BA3880F0/SIP/Info/sipSPISetDTMFRelayMode: Set DSP for dtmf-relay = CC_CAP_DTMF_RELAY_NTE_AND_OOB with rx payload = 101, tx payload = 101
004318: Dec 5 23:24:19.349: //276/1AD0BA3880F0/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=0, from CLI config=0
004319: Dec 5 23:24:19.349: //276/1AD0BA3880F0/SIP/Info/sipSPIGetModemInfoPerCall: peer_callID=278
004320: Dec 5 23:24:19.349: //276/1AD0BA3880F0/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
004321: Dec 5 23:24:19.349: //276/1AD0BA3880F0/SIP/Info/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
004322: Dec 5 23:24:19.349: //276/1AD0BA3880F0/SIP/Info/sip_set_modem_caps: Negotiation already Done. Set negotiated Modem caps and generate SDP Xcap list
004323: Dec 5 23:24:19.349: //276/1AD0BA3880F0/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
004324: Dec 5 23:24:19.349: //276/1AD0BA3880F0/SIP/Info/sip_set_modem_caps: nse payload = 0, ptru mode = 0, ptru-codec=0, redundancy=0, xid=0, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
004325: Dec 5 23:24:19.349: //276/1AD0BA3880F0/SIP/Media/sipSPISetStreamInfo: 0 Active Streams
004326: Dec 5 23:24:19.349: //276/1AD0BA3880F0/SIP/Media/sipSPISetStreamInfo: Number of active streams is zero (0)!
004327: Dec 5 23:24:19.349: //276/1AD0BA3880F0/SIP/Media/sipSPISetStreamInfo:
caps.stream_count=0,caps.stream[0].stream_type=0xFFFF, caps.stream_list.xmitFunc=
004328: Dec 5 23:24:19.349: //276/1AD0BA3880F0/SIP/Media/sipSPISetStreamInfo: ??unknown??, caps.stream_list.context=
004329: Dec 5 23:24:19.349: //276/1AD0BA3880F0/SIP/Media/sipSPISetStreamInfo: 0x0 (gccb)
004330: Dec 5 23:24:19.349: //276/1AD0BA3880F0/SIP/Info/ccsip_caps_ind_internal: Load DSP with codec : g711ulaw, Bytes=160, payload = 0
004331: Dec 5 23:24:19.349: //276/1AD0BA3880F0/SIP/Info/ccsip_caps_ind_internal: ccsip_caps_ind: ccb->pld.flags_ipip = 0x400403
004332: Dec 5 23:24:19.349: //276/1AD0BA3880F0/SIP/Info/sipSPISrtpTranscoder:
Checking if transcoder is needed for SRTP-RTP
004333: Dec 5 23:24:19.349: //276/1AD0BA3880F0/SIP/Info/ccsip_caps_ind_internal: No video caps detected in the caps posted by peer leg
004334: Dec 5 23:24:19.353: //276/1AD0BA3880F0/SIP/Info/ccsip_caps_ind_internal: Calling cc_api_caps_ack()
004335: Dec 5 23:24:19.353: //278/24183DC980F7/SIP/Info/ccsip_caps_ack_internal: Set forking flag to 0x0
004336: Dec 5 23:24:19.353: //278/24183DC980F7/SIP/Info/sipSPI_ipip_report_media_to_peer: ccb->flags 0x400018, ccb->pld.flags_ipip 0x400005
004337: Dec 5 23:24:19.353: //278/24183DC980F7/SIP/Info/copy_channels:
004338: Dec 5 23:24:19.353: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: switch(ev.ev_id: 168)
004339: Dec 5 23:24:19.353: //276/1AD0BA3880F0/SIP/Info/ccsip_event_handler:
ccsip_event_handler: peer ID 278 chans 0x48DEBE48 event 168 flags 0xC0001C 0x10000100 0x400403 data 0x48DEBE48
004340: Dec 5 23:24:19.353: //276/1AD0BA3880F0/SIP/Info/ccsip_event_handler:
ccsip_event_handler: CC_EV_H245_OPEN_CHANNEL_IND: peer ID 278 chans 0x48DEBE48 event 168 flags 0xC0001C 0x10000100 0x400403 data 0x48DEBE48
004341: Dec 5 23:24:19.353: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_NEW_MEDIA
004342: Dec 5 23:24:19.353: //276/1AD0BA3880F0/SIP/Info/ccsip_event_handler:
ccsip_event_handler: set event->type = SIPSPI_EV_CC_NEW_MEDIA!: peer ID 278 chans 0x48DEBE48 event 168 flags 0xC0001C 0x10000100 0x400403 data 0x48DEBE48 Media Trigger 0
004343: Dec 5 23:24:19.353: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: CC_R_SUCCESS_WITH_CONFIRMED
004344: Dec 5 23:24:19.353: //278/24183DC980F7/SIP/Info/sipSPI_ipip_report_media_to_peer: SIP2SIP, posting channel_ind to peer.
004345: Dec 5 23:24:19.353: //278/24183DC980F7/SIP/Info/ccsip_update_srtp_caps: 7396: Not Sending NULL SRTP CAPS to SIP LEG
004346: Dec 5 23:24:19.353: //278/24183DC980F7/SIP/Media/sipSPIUpdCallWithSdpInfo:
Stream type : voice+dtmf
Media line : 1
State : STREAM_ADDING (2)
Stream address type : 1
Callid : 278
Negotiated Codec : g711ulaw, bytes :160
Nego. Codec payload : 0 (tx), 0 (rx)
Negotiated DTMF relay : rtp-nte
Negotiated NTE payload : 101 (tx), 101 (rx)
Negotiated CN payload : 0
Media Srce Addr/Port : [172.16.16.2]:16766
Media Dest Addr/Port : [72.55.168.18]:17972
004347: Dec 5 23:24:19.353: //278/24183DC980F7/SIP/Info/sipSPIProcessHistoryInfoHeader: No HI headers recvd from app container
004348: Dec 5 23:24:19.353: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
004349: Dec 5 23:24:19.353: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
004350: Dec 5 23:24:19.353: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateNewRawMsg: No Data to form The Raw Message
004351: Dec 5 23:24:19.353: //278/24183DC980F7/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
004352: Dec 5 23:24:19.353: //278/24183DC980F7/SIP/Info/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
004353: Dec 5 23:24:19.353: //278/24183DC980F7/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled: - 0
004354: Dec 5 23:24:19.353: //278/24183DC980F7/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
004355: Dec 5 23:24:19.353: //278/24183DC980F7/SIP/Info/ccsip_api_call_cut_progress: Unable to add headers into container
004356: Dec 5 23:24:19.353: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: switch(ev.ev_id: 100)
004357: Dec 5 23:24:19.353: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_event_handler: CC_R_SUCCESS_WITH_CONFIRMED
004358: Dec 5 23:24:19.353: //278/24183DC980F7/SIP/Info/HandleSIP1xxSessionProgress: ccsip_api_call_cut_progress returned: SIP_SUCCESS
004359: Dec 5 23:24:19.353: //278/24183DC980F7/SIP/State/sipSPIChangeState: 0x4D1A5DA8 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING) to (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)
004360: Dec 5 23:24:19.353: //278/24183DC980F7/SIP/Info/HandleSIP1xxSessionProgress: Transaction Complete. Lock on Facilities released.
004361: Dec 5 23:24:19.353: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 27
004362: Dec 5 23:24:19.357: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_handle_channel_info:
CCSIP:callID 276 ft: 1, inc 4, 72.55.168.18:17972, codec 5
004363: Dec 5 23:24:19.357: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_handle_channel_info:
CCSIP:callid 276 state STATE_SENT_ALERTING
004364: Dec 5 23:24:19.357: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_handle_channel_info: Reset FAX_PASSTHROUGH
004365: Dec 5 23:24:19.357: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_handle_channel_info: Reset IS_FAX_TO_VOICE_SWITCH..
004366: Dec 5 23:24:19.357: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp:
callid 276, channels 0x48DEBE48 caps 0x4CFA9758
004367: Dec 5 23:24:19.357: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: Peer cap provided: callid = 276, peer dtmf = 6peer t38 version = 0 peer t38 maxBitRate = 0
004368: Dec 5 23:24:19.357: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_vcc_ResponseFilterCodecs: codec copied to reference_codec_list = 5
004369: Dec 5 23:24:19.357: //276/1AD0BA3880F0/SIP/Info/codec_found:
004370: Dec 5 23:24:19.357: //276/1AD0BA3880F0/SIP/Info/codec_found: codecs[i] = 5 & codec = 5 are same..
004371: Dec 5 23:24:19.357: //276/1AD0BA3880F0/SIP/Info/sipSPIUpdatePreferredCodec: num_chans = 1
004372: Dec 5 23:24:19.357: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_vcc_ResponseFilterCodecs: Static-codec/Equalset/ Subset(with common codec) case..
004373: Dec 5 23:24:19.357: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp:
nego mline 1 dtmf 101 ss 1 ret 12
004374: Dec 5 23:24:19.357: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: Reset IS_FAX_TO_VOICE_SWITCH
004375: Dec 5 23:24:19.357: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: CCB->pld.flags_ipip 0x400403
004376: Dec 5 23:24:19.357: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_copy_channelInfo_to_sdp: channel_ind/ack payload type 0
004377: Dec 5 23:24:19.357: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
004378: Dec 5 23:24:19.357: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_handle_channel_info: audio channel_ind
004379: Dec 5 23:24:19.357: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
004380: Dec 5 23:24:19.357: //276/1AD0BA3880F0/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Setting stream 1 portnum to 17836
004381: Dec 5 23:24:19.357: //276/1AD0BA3880F0/SIP/Info/sipSPIUpdateSrcSdpVariablePart:
SIP update src sdp, negoitated codec 5, payload type 0
004382: Dec 5 23:24:19.357: //276/1AD0BA3880F0/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Negotiated method of dtmf relayand pyld: 6 101
004383: Dec 5 23:24:19.357: //276/1AD0BA3880F0/SIP/Info/sipSPIUpdateSrcSdpVariablePart: max_event 16
004384: Dec 5 23:24:19.357: //276/1AD0BA3880F0/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
004385: Dec 5 23:24:19.357: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
004386: Dec 5 23:24:19.357: //276/1AD0BA3880F0/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Setting stream 1 portnum to 17836
004387: Dec 5 23:24:19.357: //276/1AD0BA3880F0/SIP/Info/sipSPIUpdateSrcSdpVariablePart:
004388: Dec 5 23:24:19.361: //276/1AD0BA3880F0/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Negotiated method of dtmf relayand pyld: 6 101
004389: Dec 5 23:24:19.361: //276/1AD0BA3880F0/SIP/Info/sipSPIUpdateSrcSdpVariablePart: max_event 16
004390: Dec 5 23:24:19.361: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_PROGRESS
004391: Dec 5 23:24:19.361: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_codec_byte_transrating: tranrating not enabled on peers, return FALSE
004392: Dec 5 23:24:19.361: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_codec_byte_transrating: tranrating not enabled on peers, return FALSE
004393: Dec 5 23:24:19.361: //278/24183DC980F7/SIP/Info/sipSPI_ipip_codec_byte_transrating: tranrating not enabled on peers, return FALSE
004394: Dec 5 23:24:19.361: //276/1AD0BA3880F0/SIP/Info/ccsip_query_force_association: REINVITE_NEEDED is FALSE. return FALSE
004395: Dec 5 23:24:19.361: //278/24183DC980F7/SIP/Info/ccsip_query_force_association: REINVITE_NEEDED is FALSE. return FALSE
004396: Dec 5 23:24:19.361: //276/1AD0BA3880F0/SIP/Info/ccsip_bridge: confID = 10, srcCallID = 276, dstCallID = 278
004397: Dec 5 23:24:19.361: //276/1AD0BA3880F0/SIP/Info/sipSPIUupdateCcCallIds: Old src/dest ccCallids: -1/-1, new src/dest ccCallids: 276/278
004398: Dec 5 23:24:19.361: //276/1AD0BA3880F0/SIP/Info/sipSPIUupdateCcCallIds: Old streamcallid=276, new streamcallid=276
004399: Dec 5 23:24:19.361: //276/1AD0BA3880F0/SIP/Info/ccsip_gw_set_sipspi_mode: Setting SPI mode to SIP-SIP
004400: Dec 5 23:24:19.361: //276/1AD0BA3880F0/SIP/Info/ccsip_bridge: xcoder_attached = 0, xmitFunc = 1140117880, ccb xmitFunc = 1140117880
004401: Dec 5 23:24:19.361: //276/1AD0BA3880F0/SIP/Info/ccsip_spi_check_call_locally_held: CCSIP: call is locally noton-hold
004402: Dec 5 23:24:19.361: //276/1AD0BA3880F0/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 276) to the VOIP RTP library
004403: Dec 5 23:24:19.361: //276/1AD0BA3880F0/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
004404: Dec 5 23:24:19.361: //276/1AD0BA3880F0/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 172.16.16.2
004405: Dec 5 23:24:19.365: //276/1AD0BA3880F0/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
004406: Dec 5 23:24:19.365: //276/1AD0BA3880F0/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
laddr = 172.16.16.2, lport = 17836, raddr = 72.55.168.18, rport=16010, do_rtcp=TRUE
src_callid = 276, dest_callid = 278, stream type = voice+dtmf, stream direction = SENDRECV
media_ip_addr = 72.55.168.18, vrf tableid = 0 media_addr_type = 1
004407: Dec 5 23:24:19.365: //276/1AD0BA3880F0/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
004408: Dec 5 23:24:19.365: //276/1AD0BA3880F0/SIP/Info/sipSPICreateRtpSession: sess: 48DEE454 do_rtcp:1
004409: Dec 5 23:24:19.365: //278/24183DC980F7/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
004410: Dec 5 23:24:19.365: //278/24183DC980F7/SIP/Info/updateGccbTxRxValues: No interworking required for nte
004411: Dec 5 23:24:19.365: //278/24183DC980F7/SIP/Info/updateGccbTxRxValues: No interworking required for nse
004412: Dec 5 23:24:19.365: //276/1AD0BA3880F0/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
004413: Dec 5 23:24:19.365: //276/1AD0BA3880F0/SIP/Info/updateGccbTxRxValues: No interworking required for nte
004414: Dec 5 23:24:19.365: //276/1AD0BA3880F0/SIP/Info/updateGccbTxRxValues: No interworking required for nse
004415: Dec 5 23:24:19.365: //276/1AD0BA3880F0/SIP/Media/sipSPICreateRtpSession: stun is disabled
004416: Dec 5 23:24:19.365: //276/1AD0BA3880F0/SIP/Info/sipSPICreateAndStartRtpTimer: Media Inactivity Timer is disabled.
004417: Dec 5 23:24:19.365: //276/1AD0BA3880F0/SIP/Media/sipSPIGetNewLocalMediaDirection:
New Remote Media Direction = SENDRECV
Present Local Media Direction = SENDRECV
New Local Media Direction = SENDRECV
retVal = 0
004418: Dec 5 23:24:19.365: //276/1AD0BA3880F0/SIP/State/sipSPIChangeStreamState: Stream (callid = 276) State changed from (STREAM_ADDING) to (STREAM_ACTIVE)
004419: Dec 5 23:24:19.365: //278/24183DC980F7/SIP/Info/ccsip_bridge: confID = 10, srcCallID = 278, dstCallID = 276
004420: Dec 5 23:24:19.365: //278/24183DC980F7/SIP/Info/sipSPIUupdateCcCallIds: Old src/dest ccCallids: -1/-1, new src/dest ccCallids: 278/276
004421: Dec 5 23:24:19.365: //278/24183DC980F7/SIP/Info/sipSPIUupdateCcCallIds: Old streamcallid=278, new streamcallid=278
004422: Dec 5 23:24:19.365: //278/24183DC980F7/SIP/Info/ccsip_gw_set_sipspi_mode: Setting SPI mode to SIP-SIP
004423: Dec 5 23:24:19.365: //278/24183DC980F7/SIP/Info/ccsip_bridge: xcoder_attached = 0, xmitFunc = 1140117880, ccb xmitFunc = 1140117880
004424: Dec 5 23:24:19.365: //278/24183DC980F7/SIP/Info/ccsip_spi_check_call_locally_held: CCSIP: call is locally noton-hold
004425: Dec 5 23:24:19.365: //278/24183DC980F7/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 278) to the VOIP RTP library
004426: Dec 5 23:24:19.365: //278/24183DC980F7/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
004427: Dec 5 23:24:19.365: //278/24183DC980F7/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 172.16.16.2
004428: Dec 5 23:24:19.365: //278/24183DC980F7/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
004429: Dec 5 23:24:19.365: //278/24183DC980F7/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
laddr = 172.16.16.2, lport = 16766, raddr = 72.55.168.18, rport=17972, do_rtcp=TRUE
src_callid = 278, dest_callid = 276, stream type = voice+dtmf, stream direction = SENDRECV
004430: Dec 5 23:24:19.365: //278/24183DC980F7/SIP/Media/sipSPIUpdateRtcpSession: RTP session already created - update
004431: Dec 5 23:24:19.369: //276/1AD0BA3880F0/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
004432: Dec 5 23:24:19.369: //276/1AD0BA3880F0/SIP/Info/updateGccbTxRxValues: No interworking required for nte
004433: Dec 5 23:24:19.369: //276/1AD0BA3880F0/SIP/Info/updateGccbTxRxValues: No interworking required for nse
004434: Dec 5 23:24:19.369: //278/24183DC980F7/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
004435: Dec 5 23:24:19.369: //278/24183DC980F7/SIP/Info/updateGccbTxRxValues: No interworking required for nte
004436: Dec 5 23:24:19.369: //278/24183DC980F7/SIP/Info/updateGccbTxRxValues: No interworking required for nse
004437: Dec 5 23:24:19.369: //278/24183DC980F7/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:499F2C90
004438: Dec 5 23:24:19.369: //278/24183DC980F7/SIP/Info/sipSPICreateAndStartRtpTimer: Media Inactivity Timer is disabled.
004439: Dec 5 23:24:19.369: //278/24183DC980F7/SIP/Media/sipSPIGetNewLocalMediaDirection:
retVal = 0
004440: Dec 5 23:24:19.369: //278/24183DC980F7/SIP/State/sipSPIChangeStreamState: Stream (callid = 278) State changed from (STREAM_ADDING) to (STREAM_ACTIVE)
004441: Dec 5 23:24:19.369: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 4
004442: Dec 5 23:24:19.369: //276/1AD0BA3880F0/SIP/Info/sipSPIAddCiscoGcid: Fatal Error in parsing CCB/Msg
004443: Dec 5 23:24:19.373: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIStoreTunnelData: Container /RawMessage Absent
004444: Dec 5 23:24:19.373: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_set_history_info_header: No HI header recvd from container
004445: Dec 5 23:24:19.373: //276/1AD0BA3880F0/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
004446: Dec 5 23:24:19.373: //276/1AD0BA3880F0/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:183, container:4E5983E4
004447: Dec 5 23:24:19.373: //276/1AD0BA3880F0/SIP/Info/Session-Timer/sipSTSLValidateSessRefreshMsg: Ignoring 1xx response for session timer processing
004448: Dec 5 23:24:19.373: //276/1AD0BA3880F0/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 10 event
004449: Dec 5 23:24:19.373: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer: Could not get any elements from TD Container
004450: Dec 5 23:24:19.373: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer: Could not get any elements from TD Container
004451: Dec 5 23:24:19.373: //276/1AD0BA3880F0/SIP/Event/sipSPICreateRpid: Received Octet3A=0x80 -> Setting ;screen=no ;privacy=off
SIP: (276) Group (a= group line) attribute, level 65535 instance 1 not found.
004452: Dec 5 23:24:19.373: //276/1AD0BA3880F0/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp and dest_sdp available, should be a midcall request
004453: Dec 5 23:24:19.373: //276/1AD0BA3880F0/SIP/Info/sipSPISendInviteResponse: Associated container=0x4E5983E4 to Invite Response 183
004454: Dec 5 23:24:19.373: //276/1AD0BA3880F0/SIP/Transport/sipSPISendInviteResponse: Sending 183 Response to the Transport Layer
004455: Dec 5 23:24:19.373: //276/1AD0BA3880F0/SIP/Transport/sipSPITransportSendMessage: msg=0x4E6E5204, addr=72.55.168.18, port=5060, sentBy_port=5060, local_addr=, is_req=0, transport=1, switch=0, callBack=0x41BD6C98
004456: Dec 5 23:24:19.373: //276/1AD0BA3880F0/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
004457: Dec 5 23:24:19.373: //276/1AD0BA3880F0/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
004458: Dec 5 23:24:19.373: //276/1AD0BA3880F0/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x4E6E5204 to default port=5060
004459: Dec 5 23:24:19.373: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:72.55.168.18, rport:5060 with laddr:
004460: Dec 5 23:24:19.373: //276/1AD0BA3880F0/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x4E6E5204
004461: Dec 5 23:24:19.377: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4E6E5204, addr=72.55.168.18, port=5060, local_addr=, connId=4 for UDP
004462: Dec 5 23:24:19.377: //276/1AD0BA3880F0/SIP/Info/sentInviteResponse18x: Sent a 18x Response
004463: Dec 5 23:24:19.377: //276/1AD0BA3880F0/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 72.55.168.18:5060;branch=z9hG4bK61ccf8f1;rport
From: "Jakub Stroinski" <sip:5147221234@72.55.168.18>;tag=as2898aaf9
To: <sip:12345678@172.16.16.2:5060>;tag=52CC2C-269B
Call-ID: 6b86e46b0f1b34bc5887abbf5851c960@72.55.168.18:5060
CSeq: 102 INVITE
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Allow-Events: telephone-event
Remote-Party-ID: <sip:5148121234@172.16.16.2>;party=called;screen=no;privacy=off
Contact: <sip:60037a2b-e0b4-7c3f-dd9f-4eca6b99@172.16.16.2:5060>
Supported: sdp-anat
Server: Cisco-SIPGateway/IOS-12.x
Content-Disposition: session;handling=required
Content-Length: 243
v=0
o=CiscoSystemsSIP-GW-UserAgent 2165 405 IN IP4 172.16.16.2
s=SIP Call
c=IN IP4 172.16.16.2
t=0 0
m=audio 17836 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
004464: Dec 5 23:24:24.257: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceHandleConnAgeing: Holder=0x49EB30FC Connection=0x4AACD244, addr=172.16.16.2, port=5060, connid=2 has been REFRESHED
004465: Dec 5 23:24:24.257: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportSetAgeingTimer: Aging timer initiated for holder=0x49EB30FC,addr=172.16.16.2
004466: Dec 5 23:24:24.285: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [72.55.168.18]:5060, local_address:[ - ]
004467: Dec 5 23:24:24.285: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
004468: Dec 5 23:24:24.285: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x4AACC054
004469: Dec 5 23:24:24.285: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x4AACC054, addr=72.55.168.18, port=5060, local_addr=, connid=4, transport=UDP
004470: Dec 5 23:24:24.285: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
004471: Dec 5 23:24:24.289: //278/24183DC980F7/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 INVITE
Server: voip.ms
Require: timer
Content-Length: 223
v=0
o=root 1156775742 1156775743 IN IP4 72.55.168.18
s=voip.ms
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
004472: Dec 5 23:24:24.289: //278/24183DC980F7/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
004473: Dec 5 23:24:24.289: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
004474: Dec 5 23:24:24.289: //278/24183DC980F7/SIP/Info/sipSPIhandle200OKInvite: Transaction active. Facilities will be queued.
004475: Dec 5 23:24:24.289: //278/24183DC980F7/SIP/Info/sipSPIhandle200OKInvite: *** This ccb is the parent
004476: Dec 5 23:24:24.289: //276/1AD0BA3880F0/SIP/Info/sipSPIUupdateCcCallIds: Old src/dest ccCallids: 276/278, new src/dest ccCallids: 276/278
004477: Dec 5 23:24:24.289: //276/1AD0BA3880F0/SIP/Info/sipSPIUupdateCcCallIds: Old streamcallid=276, new streamcallid=276
004478: Dec 5 23:24:24.293: //278/24183DC980F7/SIP/Info/sipSPIProcessNotifyCallInfoHeader: Call-Info header with for Unsolicited Notify Absent,Disabling Unsolicited Notifies
004479: Dec 5 23:24:24.293: //278/24183DC980F7/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
004480: Dec 5 23:24:24.293: //278/24183DC980F7/SIP/Event/Session-Timer/sipSTSLMain: dir:2, method:102, resp_code:200, container:4E5979EC
004481: Dec 5 23:24:24.293: //278/24183DC980F7/SIP/Info/Session-Timer/sipSTSLExtractSessionExpiresHdr:
Session-Expires value: 1800 refresher: uas
004482: Dec 5 23:24:24.293: //278/24183DC980F7/SIP/Info/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_INITIAL_SR_RESP
004483: Dec 5 23:24:24.293: //278/24183DC980F7/SIP/Info/Session-Timer/sipSTSLInitialSRRespWithSEPeerEventGen: Session refresh and expiry has to be started by the endpoints
004484: Dec 5 23:24:24.293: //278/24183DC980F7/SIP/Info/Session-Timer/sipSTSLProcessPassPeerEvent: session timer negotiated end to end
004485: Dec 5 23:24:24.293: //278/24183DC980F7/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_PASS_ST_PARAMS, SE Value:1800, SE Refresher:uas, Min-SE Value:1800, flags:121
004486: Dec 5 23:24:24.293: //278/24183DC980F7/SIP/Info/Session-Timer/sipSTSLMain:
SE: 1800;refresher:uas peer refresher:uas, flags:121, posted event:E_STSL_INVALID_PEER_EVENT, reason:4
004487: Dec 5 23:24:24.293: //278/24183DC980F7/SIP/Info/sipSPIProcessHistoryInfoHeader: No HI headers recvd from app container
004488: Dec 5 23:24:24.293: //278/24183DC980F7/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
004489: Dec 5 23:24:24.293: //278/24183DC980F7/SIP/Info/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
004490: Dec 5 23:24:24.293: //278/24183DC980F7/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled: - 0
004491: Dec 5 23:24:24.293: //278/24183DC980F7/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
004492: Dec 5 23:24:24.293: //278/24183DC980F7/SIP/Info/ccsip_api_call_connect_media: Unable to add headers into container
004493: Dec 5 23:24:24.293: //278/24183DC980F7/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
004494: Dec 5 23:24:24.293: //278/24183DC980F7/SIP/Info/sipSPIValidateConnectionAddress: Dest port = 17972
004495: Dec 5 23:24:24.293: //278/24183DC980F7/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
004496: Dec 5 23:24:24.293: //278/24183DC980F7/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 172.16.16.2
004497: Dec 5 23:24:24.293: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) could not be reserved
004498: Dec 5 23:24:24.293: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPT: Requested payload-Type (101) is reserved by another application
004499: Dec 5 23:24:24.293: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 96
004500: Dec 5 23:24:24.293: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 101
004501: Dec 5 23:24:24.293: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAllocateFreeDynamicPT: Allocating free Dynamic Payload : 96 for Codec:
004502: Dec 5 23:24:24.297: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) could not be reserved
004503: Dec 5 23:24:24.297: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPT: Requested payload-Type (101) is reserved by another application
004504: Dec 5 23:24:24.297: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
004505: Dec 5 23:24:24.297: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 101
004506: Dec 5 23:24:24.297: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAllocateFreeDynamicPT: Allocating free Dynamic Payload : 98 for Codec:
004507: Dec 5 23:24:24.297: //278/24183DC980F7/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711ulaw) Negotiation Successful on Static Payload for m-line 1
004508: Dec 5 23:24:24.297: //278/24183DC980F7/SIP/Info/sipSPIDoPtimeNegotiation: One ptime attribute found - value:20
004509: Dec 5 23:24:24.297: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g711ulaw ptime :20, codecbytes: 160
004510: Dec 5 23:24:24.297: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
004511: Dec 5 23:24:24.297: //278/24183DC980F7/SIP/Media/sipSPIDoPtimeNegotiation: Offered ptime:20, Negotiated ptime:20 Negotiated codec bytes: 160 for codec g711ulaw
004512: Dec 5 23:24:24.297: //278/24183DC980F7/SIP/Info/sipSPISetFaxFlags: FAX_PASSTHROUGH = 0, END_FAX_PASSTHROUGH = 0
004513: Dec 5 23:24:24.297: //278/24183DC980F7/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
004514: Dec 5 23:24:24.297: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec
004515: Dec 5 23:24:24.297: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 96
004516: Dec 5 23:24:24.297: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) reserved for codec
004517: Dec 5 23:24:24.297: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateDynamicPayloadunused: Unreserving dynamic payload type 98
004518: Dec 5 23:24:24.297: //278/24183DC980F7/SIP/Info/sipSPIReserveRtpNtePayload: Reserved the payload type 101 for RTP-NTE
004519: Dec 5 23:24:24.297: //278/24183DC980F7/SIP/Info/sipSPIDoDTMFRelayNegotiation: RTP-NTE DTMF relay option
004520: Dec 5 23:24:24.297: //278/24183DC980F7/SIP/Info/sipSPIDoDTMFRelayNegotiation: Case of full named event(NE) match in fmtp list of events.
004521: Dec 5 23:24:24.297: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: V150 NSE payload = 0, SSE payload = 0, SPRT payload=0
004522: Dec 5 23:24:24.297: //278/24183DC980F7/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
004523: Dec 5 23:24:24.297: //278/24183DC980F7/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
004524: Dec 5 23:24:24.297: //278/24183DC980F7/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
004525: Dec 5 23:24:24.297: //278/24183DC980F7/SIP/State/sipSPIChangeStreamState: Stream (callid = -1) State changed from (STREAM_DEAD) to (STREAM_ADDING)
004526: Dec 5 23:24:24.297: //278/24183DC980F7/SIP/Media/sipSPICompareStreams: stream 1 dest_port: old=17972 new=17972
004527: Dec 5 23:24:24.297: //278/24183DC980F7/SIP/Media/sipSPIGetNewLocalMediaDirection:
retVal = 0
004528: Dec 5 23:24:24.297: //278/24183DC980F7/SIP/Media/sipSPICompareStreams: Flags set for stream 1: RTP_CHANGE=No CAPS_CHANGE=No RSVP_ADDR_CHANGE=No RSVP_MEDIA_CHANGE=No
004529: Dec 5 23:24:24.297: //278/24183DC980F7/SIP/Media/sipSPICompareSDP: Flags set for call: NEW_MEDIA=No DSPDNLD_REQD=No IPIP_MEDIA=No
004530: Dec 5 23:24:24.301: //278/24183DC980F7/SIP/Media/sipSPIReplaceSDP: Main stream got changed & it's Flow Around
004531: Dec 5 23:24:24.301: //278/24183DC980F7/SIP/Media/sipSPIUpdCallWithSdpInfo:
Early Media : No
Delayed Media : No
Bridge Done : Yes
New Media : No
DSP DNLD Reqd : No
004532: Dec 5 23:24:24.301: //278/24183DC980F7/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
004533: Dec 5 23:24:24.301: //278/24183DC980F7/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 172.16.16.2
004534: Dec 5 23:24:24.301: //278/24183DC980F7/SIP/Info/sipSPI_ipip_report_media_to_peer:
callId 278 peer 276 flags 0x400405 state STATE_RECD_PROCEEDING
004535: Dec 5 23:24:24.301: //278/24183DC980F7/SIP/Info/sipSPI_ipip_vcc_ProcessXcoderNeeded: xcoder_attached not yet initialised for this call.
004536: Dec 5 23:24:24.301: //278/24183DC980F7/SIP/Info/sipSPI_ipip_report_media_to_peer: Xcoder not yet used for the call
004537: Dec 5 23:24:24.301: //278/24183DC980F7/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
004538: Dec 5 23:24:24.301: //278/24183DC980F7/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
004539: Dec 5 23:24:24.301: //278/24183DC980F7/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CallID 278, Peer CallID 276, sdp 0x4E6E8A44 channels 0x4D1A7344
004540: Dec 5 23:24:24.301: //278/24183DC980F7/SIP/Info/copy_channels:
callId 278 size 240 ptr 0x499F2BB4)
004541: Dec 5 23:24:24.301: //278/24183DC980F7/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: stream_callid = 278
004542: Dec 5 23:24:24.301: //278/24183DC980F7/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: reset the switch..
004543: Dec 5 23:24:24.301: //278/24183DC980F7/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
004544: Dec 5 23:24:24.301: //278/24183DC980F7/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711ulaw
004545: Dec 5 23:24:24.301: //278/24183DC980F7/SIP/Info/codec_found:
004546: Dec 5 23:24:24.301: //278/24183DC980F7/SIP/Info/codec_found: codecs[i] = 5 & codec = 5 are same..
004547: Dec 5 23:24:24.301: //278/24183DC980F7/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: ADD AUDIO CODEC 5
004548: Dec 5 23:24:24.301: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
004549: Dec 5 23:24:24.301: //278/24183DC980F7/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation done: stream->negotiated_ptime=20,stream->negotiated_codec_bytes=160, coverted ptime=20 stream->mline_index=1, media_ndx=1
004550: Dec 5 23:24:24.301: //278/24183DC980F7/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
004551: Dec 5 23:24:24.301: //278/24183DC980F7/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
004552: Dec 5 23:24:24.301: //278/24183DC980F7/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: setting ipip_caps DTMF to RFC2833: callid = 278, dtmf = 6
004553: Dec 5 23:24:24.301: //278/24183DC980F7/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = 5
004554: Dec 5 23:24:24.301: //278/24183DC980F7/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = -1
004555: Dec 5 23:24:24.305: //278/24183DC980F7/SIP/Info/sipSPI_ipip_report_media_to_peer: tagdata already updated. Do no-op
004556: Dec 5 23:24:24.305: //278/24183DC980F7/SIP/Info/sipSPI_ipip_report_media_to_peer:
004557: Dec 5 23:24:24.305: //278/24183DC980F7/SIP/Info/sipSPI_ipip_report_media_to_peer: Reporting media in Substate SUBSTATE_PROCEEDING_PROCEEDING
004558: Dec 5 23:24:24.305: //278/24183DC980F7/SIP/Info/ccsip_update_srtp_caps: 7396: Not Sending NULL SRTP CAPS to SIP LEG
004559: Dec 5 23:24:24.305: //278/24183DC980F7/SIP/Media/sipSPIUpdCallWithSdpInfo:
Media line : 1
State : STREAM_ACTIVE (5)
Callid : 278
004560: Dec 5 23:24:24.305: //278/24183DC980F7/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
004561: Dec 5 23:24:24.305: //278/24183DC980F7/SIP/Info/sipSPIhandle200OKInvite: ccsip_api_call_connect_media returned: SIP_SUCCESS
004562: Dec 5 23:24:24.305: //278/24183DC980F7/SIP/State/sipSPIChangeState: 0x4D1A5DA8 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING) to (STATE_RECD_PROCEEDING, SUBSTATE_NONE)
004563: Dec 5 23:24:24.305: //278/24183DC980F7/SIP/Info/sipSPIQoSRevertBW: Entry
004564: Dec 5 23:24:24.305: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
004565: Dec 5 23:24:24.305: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
004566: Dec 5 23:24:24.305: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateNewRawMsg: No Data to form The Raw Message
004567: Dec 5 23:24:24.305: //278/24183DC980F7/SIP/Info/sipSPIShrlCall: Check peer: 3 for Shared-Line call, callid: 278
004568: Dec 5 23:24:24.305: //276/1AD0BA3880F0/SIP/Info/sipSPIShrlCall: Check peer: 1 for Shared-Line call, callid: 276
004569: Dec 5 23:24:24.305: //278/24183DC980F7/SIP/Info/sipSPIOptionsPing: Session Timer negotiated, not doing Options Ping
004570: Dec 5 23:24:24.305: //278/24183DC980F7/SIP/Info/sipSPICreateAndStartRtpTimer: Media Inactivity Timer is disabled.
004571: Dec 5 23:24:24.305: //278/24183DC980F7/SIP/Info/sipSPIhandle200OKInvite: ccsip_api_call_connected returned: SIP_SUCCESS
004572: Dec 5 23:24:24.305: //278/24183DC980F7/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 1 event
004573: Dec 5 23:24:24.305: //278/24183DC980F7/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer: Could not get any elements from TD Container
004574: Dec 5 23:24:24.305: //278/24183DC980F7/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer: Could not get any elements from TD Container
004575: Dec 5 23:24:24.309: //278/24183DC980F7/SIP/Info/sipSPISendAck: Associated container=0x4E597D5C to Ack
004576: Dec 5 23:24:24.309: //278/24183DC980F7/SIP/Transport/sipSPISendAck: Sending ACK to the transport layer
004577: Dec 5 23:24:24.309: //278/24183DC980F7/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Dial peer configuration, Switch Transport is FALSE
004578: Dec 5 23:24:24.309: //278/24183DC980F7/SIP/Transport/sipSPITransportSendMessage: msg=0x499F2BB4, addr=72.55.168.18, port=5060, sentBy_port=0, local_addr=, is_req=1, transport=1, switch=0, callBack=0x41BD7EB0
004579: Dec 5 23:24:24.309: //278/24183DC980F7/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
004580: Dec 5 23:24:24.309: //278/24183DC980F7/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
004581: Dec 5 23:24:24.309: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:72.55.168.18, rport:5060 with laddr:
004582: Dec 5 23:24:24.309: //278/24183DC980F7/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x499F2BB4
004583: Dec 5 23:24:24.309: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x499F2BB4, addr=72.55.168.18, port=5060, local_addr=, connId=4 for UDP
004584: Dec 5 23:24:24.309: //278/24183DC980F7/SIP/State/sipSPIChangeState: 0x4D1A5DA8 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_NONE) to (STATE_ACTIVE, SUBSTATE_NONE)
004585: Dec 5 23:24:24.309: //278/24183DC980F7/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x4D1A5DA8
State of The Call : STATE_ACTIVE
TCP Sockets Used : NO
Calling Number : 5143601234
Called Number : 5148121234
Source IP Address (Sig ): 172.16.16.2
Destn SIP Req Addr:Port : 72.55.168.18:5060
Destn SIP Resp Addr:Port : 72.55.168.18:5060
Destination Name : 72.55.168.18
004586: Dec 5 23:24:24.309: //278/24183DC980F7/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream : 1
Negotiated Codec Bytes : 160
Negotiated Dtmf-relay : 6
Dtmf-relay Payload : 101 (tx), 101 (rx)
Source IP Address (Media): 172.16.16.2
Source IP Port (Media): 16766
Destn IP Address (Media): 72.55.168.18
Destn IP Port (Media): 17972
Orig Destn IP Address:Port (Media): [ - ]:0
004587: Dec 5 23:24:24.309: //278/24183DC980F7/SIP/Info/sipSPICallActive: Transaction Complete. Lock on Facilities released.
004588: Dec 5 23:24:24.309: //278/24183DC980F7/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
004589: Dec 5 23:24:24.309: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_call_connect: CCSIP_CALL_CONNECT: ccb ptr 4D195650
004590: Dec 5 23:24:24.309: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_call_connect: CCSIP_CALL_CONNECT: app_diaplay_name[] app_display_num[5148121234]
004591: Dec 5 23:24:24.309: //276/1AD0BA3880F0/SIP/Info/ccsip_call_connect: CCSIP_CALL_CONNECT : KPML_CONFIGURED[FALSE] collect_digits[2000] calledNumber[12345678] display_name[] display_num[5148121234]
004592: Dec 5 23:24:24.313: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_CONNECT
004593: Dec 5 23:24:24.313: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 7
004594: Dec 5 23:24:24.313: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_set_history_info_header: No HI header recvd from container
004595: Dec 5 23:24:24.313: //276/1AD0BA3880F0/SIP/Info/sipSPIQoSRevertBW: Entry
004596: Dec 5 23:24:24.313: //276/1AD0BA3880F0/SIP/Info/preprocessConnect: Write sdp_info into msg_body
004597: Dec 5 23:24:24.317: //276/1AD0BA3880F0/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
004598: Dec 5 23:24:24.317: //276/1AD0BA3880F0/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:200, container:4E5969C4
004599: Dec 5 23:24:24.317: //276/1AD0BA3880F0/SIP/Info/Session-Timer/sipSTSLGetInternalSREvent: E_STSL_INITIAL_SR_RESP
004600: Dec 5 23:24:24.317: //276/1AD0BA3880F0/SIP/Event/Session-Timer/sipSTSLPrintTDContainer: Peer-Event: E_STSL_PASS_ST_PARAMS, SE Value:1800, SE Refresher:uas, Min-SE Value:1800, flags:121
004601: Dec 5 23:24:24.317: //276/1AD0BA3880F0/SIP/Info/Session-Timer/sipSTSLSRRespPassPeerEventHndlr: Adding session expires header with values received from peer leg
004602: Dec 5 23:24:24.317: //276/1AD0BA3880F0/SIP/Info/Session-Timer/sipSTSLSRRespPassPeerEventHndlr: session timer negotiated end to end
004603: Dec 5 23:24:24.317: //276/1AD0BA3880F0/SIP/Info/Session-Timer/sipSTSLMain:
Configured SE:1800, Configured Min-SE:1800
004604: Dec 5 23:24:24.317: //276/1AD0BA3880F0/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 8 event
004605: Dec 5 23:24:24.317: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer: Could not get any elements from TD Container
004606: Dec 5 23:24:24.317: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer: Could not get any elements from TD Container
004607: Dec 5 23:24:24.317: //276/1AD0BA3880F0/SIP/Info/sipSPIPushSubsqTransMsgContainerIntoHolder: Response Container Holder is above threshold...trimming
004608: Dec 5 23:24:24.321: //276/1AD0BA3880F0/SIP/Event/sipSPICreateRpid: Received Octet3A=0x00 -> Setting ;screen=no ;privacy=off
004609: Dec 5 23:24:24.321: //276/1AD0BA3880F0/SIP/Info/sipSPIAppAddCallInfoUI: callinfo UI update request for callid: 276
004610: Dec 5 23:24:24.321: //276/1AD0BA3880F0/SIP/Info/sipSPISendInviteResponse: Transaction active. Facilities will be queued.
004611: Dec 5 23:24:24.321: //276/1AD0BA3880F0/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp and dest_sdp available, should be a midcall request
004612: Dec 5 23:24:24.321: //276/1AD0BA3880F0/SIP/Info/sipSPISendInviteResponse: Associated container=0x4E5969C4 to Invite Response 200
004613: Dec 5 23:24:24.321: //276/1AD0BA3880F0/SIP/Transport/sipSPISendInviteResponse: Sending 200OK Response to the Transport Layer
004614: Dec 5 23:24:24.321: //276/1AD0BA3880F0/SIP/Transport/sipSPITransportSendMessage: msg=0x4E6C1AF8, addr=72.55.168.18, port=5060, sentBy_port=5060, local_addr=, is_req=0, transport=1, switch=0, callBack=0x41BD70B0
004615: Dec 5 23:24:24.321: //276/1AD0BA3880F0/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
004616: Dec 5 23:24:24.321: //276/1AD0BA3880F0/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
004617: Dec 5 23:24:24.321: //276/1AD0BA3880F0/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x4E6C1AF8 to default port=5060
004618: Dec 5 23:24:24.321: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:72.55.168.18, rport:5060 with laddr:
004619: Dec 5 23:24:24.321: //276/1AD0BA3880F0/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x4E6C1AF8
004620: Dec 5 23:24:24.321: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4E6C1AF8, addr=72.55.168.18, port=5060, local_addr=, connId=4 for UDP
004621: Dec 5 23:24:24.321: //276/1AD0BA3880F0/SIP/Info/sentInviteResponse200: Sent 200Ok for Invite in state STATE_SENT_ALERTING
004622: Dec 5 23:24:24.321: //-1/xxxxxxxxxxxx/SIP/Info/sentInviteResponse200: Transaction active. Facilities will be queued.
004623: Dec 5 23:24:24.321: //276/1AD0BA3880F0/SIP/State/sipSPIChangeState: 0x4D195650 : State change from (STATE_SENT_ALERTING, SUBSTATE_NONE) to (STATE_SENT_SUCCESS, SUBSTATE_NONE)
004624: Dec 5 23:24:24.325: //278/24183DC980F7/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 172.16.16.2:5060;branch=z9hG4bK881780
Date: Sat, 05 Dec 2015 23:24:18 GMT
Call-ID: 241BE751-9ADE11E5-80FBDB8C-E7BAB034@172.16.16.2
Max-Forwards: 70
CSeq: 102 ACK
Allow-Events: kpml, telephone-event
Content-Length: 0
004625: Dec 5 23:24:24.325: //276/1AD0BA3880F0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Sat, 05 Dec 2015 23:24:02 GMT
CSeq: 102 INVITE
Contact: <sip:5148121234@172.16.16.2:5060>
Supported: replaces
Supported: sdp-anat
Cisco-Gcid: 1AD32B70-9ADE-11E5-80F3-DB8CE7BAB034
Require: timer
Supported: timer
Content-Type: application/sdp
Content-Length: 243
v=0
s=SIP Call
t=0 0
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
004626: Dec 5 23:24:24.329: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [72.55.168.18]:5060, local_address:[ - ]
004627: Dec 5 23:24:24.329: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
004628: Dec 5 23:24:24.329: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x4AACC054
004629: Dec 5 23:24:24.329: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x4AACC054, addr=72.55.168.18, port=5060, local_addr=, connid=4, transport=UDP
004630: Dec 5 23:24:24.329: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:5148121234@172.16.16.2:5060 SIP/2.0
Via: SIP/2.0/UDP 72.55.168.18:5060;branch=z9hG4bK5bce3770;rport
Max-Forwards: 70
Contact: <sip:5147221234@72.55.168.18:5060>
CSeq: 102 ACK
User-Agent: voip.ms
Content-Length: 0
004631: Dec 5 23:24:24.329: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
004632: Dec 5 23:24:24.333: //276/1AD0BA3880F0/SIP/Info/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x4D195650
004633: Dec 5 23:24:24.333: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 72.55.168.18,Port 5060, Transport 1, SentBy Port 5060
004634: Dec 5 23:24:24.333: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone EST to SIP default timezone = GMT
004635: Dec 5 23:24:24.333: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 72.55.168.18,Port 5060, Transport 1, SentBy Port 5060
004636: Dec 5 23:24:24.333: //276/1AD0BA3880F0/SIP/Info/act_sentsucc_new_message_request: Transaction Complete. Lock on Facilities released.
004637: Dec 5 23:24:24.333: //276/1AD0BA3880F0/SIP/State/sipSPIChangeState: 0x4D195650 : State change from (STATE_SENT_SUCCESS, SUBSTATE_NONE) to (STATE_ACTIVE, SUBSTATE_NONE)
004638: Dec 5 23:24:24.333: //276/1AD0BA3880F0/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x4D195650
Calling Number : 5147221234
Called Number : 12345678
004639: Dec 5 23:24:24.333: //276/1AD0BA3880F0/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
Source IP Port (Media): 17836
Destn IP Port (Media): 16010
004640: Dec 5 23:24:24.333: //276/1AD0BA3880F0/SIP/Info/sipSPICreateAndStartRtpTimer: Media Inactivity Timer is disabled.
004641: Dec 5 23:24:24.333: //276/1AD0BA3880F0/SIP/Info/sipSPIProcessHoldTimerForCall: Media IP Addr 72.55.168.18, RTCP Type 3
004642: Dec 5 23:24:24.333: //276/1AD0BA3880F0/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
004643: Dec 5 23:24:24.333: //276/1AD0BA3880F0/SIP/Info/sipSPIOptionsPing: Session Timer negotiated, not doing Options Ping
004644: Dec 5 23:24:24.925: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x4D18A6C0) with key=[247] to table
004645: Dec 5 23:24:24.925: //-1/000000000000/SIP/Info/sipSPI_ipip_vcc_Initialization: Entry...
004646: Dec 5 23:24:24.925: //-1/000000000000/SIP/Info/ccsip_offer_ans_init:
004647: Dec 5 23:24:24.925: //-1/000000000000/SIP/Info/ccsipRegisterSetTargetInfo: p2p mode with Registrar Server = ipv4:172.16.16.2
004648: Dec 5 23:24:24.925: //-1/000000000000/SIP/Info/ccsipRegisterSetTargetInfo: Parsing The Registrar Address
004649: Dec 5 23:24:24.925: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetOutboundHostAndDestHostPrivate: CCSIP: target_host : 172.16.16.2 target_port : 5060
004650: Dec 5 23:24:24.925: //-1/000000000000/SIP/Info/sipSPIValidateAndCopyOutboundHost: CCSIP: copy target_host to outbound_host
004651: Dec 5 23:24:24.925: //-1/000000000000/SIP/Info/sipSPIOutboundProxyReuse: Do not reuse Outbound Proxy IP adress and Port
004652: Dec 5 23:24:24.925: //-1/000000000000/SIP/State/sipSPIChangeState: 0x4D18A6C0 : State change from (STATE_NONE, SUBSTATE_NONE) to (STATE_IDLE, SUBSTATE_NONE)
004653: Dec 5 23:24:24.925: //-1/000000000000/SIP/Info/ccsip_spi_registrar_add_expires_header: Inside ccsip_spi_registrar_add_expires_header for Expires
004654: Dec 5 23:24:24.925: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
004655: Dec 5 23:24:24.925: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIIncrementOverloadCount: Local 1 Global 1
004656: Dec 5 23:24:24.925: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 42
004657: Dec 5 23:24:24.925: //-1/000000000000/SIP/Info/act_idle_outgoing_register: In act_idle_outgoing_register
004658: Dec 5 23:24:24.925: //279/000000000000/SIP/Info/act_idle_outgoing_register: Send REGISTER to 172.16.16.2:5060
004659: Dec 5 23:24:24.925: //279/000000000000/SIP/Info/sipSPIUaddCcbToUACTable: ****Adding to UAC table.
004660: Dec 5 23:24:24.929: //279/000000000000/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x4D18A6C0 key=90208111-9AD111E5-8003DB8C-E7BAB034
004661: Dec 5 23:24:24.929: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling reg_invoke_ip_first_hop()
004662: Dec 5 23:24:24.929: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling ip_best_local_address()
004663: Dec 5 23:24:24.929: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: return addr 172.16.16.2
004664: Dec 5 23:24:24.929: //279/000000000000/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 7 event
004665: Dec 5 23:24:24.929: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIRetrieveOutgoingPassThruData: Retrieving Data from RCB
004666: Dec 5 23:24:24.929: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIRetrieveOutgoingPassThruData: Retrieving Data from RCB
004667: Dec 5 23:24:24.929: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone EST to SIP default timezone = GMT
004668: Dec 5 23:24:24.929: //279/000000000000/SIP/Info/sipSPISendRegister: Associated container=0x4E59822C to Register
004669: Dec 5 23:24:24.929: //279/000000000000/SIP/Transport/sipSPISendRegister: Sending REGISTER to the transport layer
004670: Dec 5 23:24:24.929: //279/000000000000/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Global configuration, Switch Transport is TRUE
004671: Dec 5 23:24:24.929: //279/000000000000/SIP/Transport/sipSPITransportSendMessage: msg=0x4E6C1AF8, addr=172.16.16.2, port=5060, sentBy_port=0, local_addr=, is_req=1, transport=1, switch=1, callBack=0x41BDA784
004672: Dec 5 23:24:24.929: //279/000000000000/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
004673: Dec 5 23:24:24.929: //279/000000000000/SIP/Transport/sipTransportLogicSendMsg: switch transport is 1
004674: Dec 5 23:24:24.929: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportGetInterfaceMtuSize: MTU size for remote address 172.16.16.2 is 1500
004675: Dec 5 23:24:24.929: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportVerifyMsgForMTUThreshold: Interface MTU Size 1500, Msg Size 448
004676: Dec 5 23:24:24.929: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:172.16.16.2, rport:5060 with laddr:
004677: Dec 5 23:24:24.929: //279/000000000000/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x4E6C1AF8
004678: Dec 5 23:24:24.933: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4E6C1AF8, addr=172.16.16.2, port=5060, local_addr=, connId=2 for UDP
004679: Dec 5 23:24:24.933: //279/000000000000/SIP/State/sipSPIChangeState: 0x4D18A6C0 : State change from (STATE_IDLE, SUBSTATE_NONE) to (SIP_STATE_OUTGOING_REGISTER, SUBSTATE_NONE)
004680: Dec 5 23:24:24.933: //279/000000000000/SIP/State/sipSPIChangeState: 0x4D18A6C0 : State change from (SIP_STATE_OUTGOING_REGISTER, SUBSTATE_NONE) to (SIP_STATE_OUTGOING_REGISTER, SUBSTATE_NONE)
004681: Dec 5 23:24:24.933: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:172.16.16.2:5060 SIP/2.0
Via: SIP/2.0/UDP 172.16.16.2:5060;branch=z9hG4bK8921CC
To: <sip:12345678@172.16.16.2>
Date: Sat, 05 Dec 2015 23:24:24 GMT
Call-ID: 90208111-9AD111E5-8003DB8C-E7BAB034
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1449357864
CSeq: 32 REGISTER
Contact: <sip:12345678@172.16.16.2:5060>
Expires: 3600
Supported: path
Content-Length: 0
004682: Dec 5 23:24:24.933: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [172.16.16.2]:57441, local_address:[ - ]
004683: Dec 5 23:24:24.937: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
004684: Dec 5 23:24:24.937: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
004685: Dec 5 23:24:24.937: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 32 REGISTER
Expires: 3600
Supported: path
Content-Length: 0
004686: Dec 5 23:24:24.937: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
004687: Dec 5 23:24:24.937: //279/000000000000/SIP/Info/sipSPICheckFromToRequest: Trying with child CCB 0x0 index 0 curr_child 0
004688: Dec 5 23:24:24.937: //279/000000000000/SIP/Error/sipSPICheckFromToRequest:
Failed FROM/TO Request check - IGNORE IF HAIRPIN CALL
old_from: <sip:12345678@172.16.16.2>;tag=53207C-D44
old_to: <sip:12345678@172.16.16.2>
new_from: <sip:12345678@172.16.16.2>;tag=53207C-D44
new_to: <sip:12345678@172.16.16.2>
004689: Dec 5 23:24:24.937: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x4D19AE18) with key=[248] to table
004690: Dec 5 23:24:24.937: //-1/000000000000/SIP/Info/sipSPI_ipip_vcc_Initialization: Entry...
004691: Dec 5 23:24:24.937: //-1/000000000000/SIP/Info/ccsip_offer_ans_init:
004692: Dec 5 23:24:24.937: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 172.16.16.2,Port 5060, Transport 1, SentBy Port 5060
004693: Dec 5 23:24:24.937: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling reg_invoke_ip_first_hop()
004694: Dec 5 23:24:24.937: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: calling ip_best_local_address()
004695: Dec 5 23:24:24.937: //-1/xxxxxxxxxxxx/SIP/Info/resolve_sig_ip_address_to_bind: return addr 172.16.16.2
004696: Dec 5 23:24:24.937: //-1/28030E0280FC/SIP/State/sipSPIChangeState: 0x4D19AE18 : State change from (STATE_NONE, SUBSTATE_NONE) to (STATE_IDLE, SUBSTATE_NONE)
004697: Dec 5 23:24:24.941: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 172.16.16.2,Port 57441, Transport 1, SentBy Port 5060
004698: Dec 5 23:24:24.941: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone EST to SIP default timezone = GMT
004699: Dec 5 23:24:24.941: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 172.16.16.2,Port 57441, Transport 1, SentBy Port 5060
004700: Dec 5 23:24:24.941: //-1/28030E0280FC/SIP/Transport/sipSPISendResponse: Sending INFO Response to the transport layer
004701: Dec 5 23:24:24.941: //-1/28030E0280FC/SIP/Transport/sipSPITransportSendMessage: msg=0x4E6C1AF8, addr=172.16.16.2, port=57441, sentBy_port=5060, local_addr=, is_req=0, transport=1, switch=0, callBack=0x0
004702: Dec 5 23:24:24.941: //-1/28030E0280FC/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
004703: Dec 5 23:24:24.941: //-1/28030E0280FC/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
004704: Dec 5 23:24:24.941: //-1/28030E0280FC/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x4E6C1AF8 to default port=5060
004705: Dec 5 23:24:24.941: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:172.16.16.2, rport:5060 with laddr:
004706: Dec 5 23:24:24.941: //-1/28030E0280FC/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x4E6C1AF8
004707: Dec 5 23:24:24.941: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4E6C1AF8, addr=172.16.16.2, port=5060, local_addr=, connId=2 for UDP
004708: Dec 5 23:24:24.945: //-1/28030E0280FC/SIP/Info/sipSPIUaddCcbToUASReqTable: ****Adding to UAS Request table.
004709: Dec 5 23:24:24.945: //-1/28030E0280FC/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x4D19AE18 key=90208111-9AD111E5-8003DB8C-E7BAB0341234567853207C-D44
004710: Dec 5 23:24:24.945: //280/28030E0280FC/SIP/Event/sact_idle_new_message_register:
ccsip_api_register_ind return value : SIP_SUCCESS
004711: Dec 5 23:24:24.945: //280/28030E0280FC/SIP/Info/sipSPIUaddccCallIdToTable: Adding call id 118 to table
004712: Dec 5 23:24:24.945: //280/28030E0280FC/SIP/State/sipSPIChangeState: 0x4D19AE18 : State change from (STATE_IDLE, SUBSTATE_NONE) to (SIP_STATE_INCOMING_REGISTER, SUBSTATE_NONE)
004713: Dec 5 23:24:24.945: //280/28030E0280FC/SIP/Info/ccsip_register_process_incoming_register: CCSIP_REGISTER:: REGISTER request
004714: Dec 5 23:24:24.945: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_call_id_table: No entry found in sipCallID Table
004715: Dec 5 23:24:24.945: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_registration_passthrough: RCB Pointer : [0x0]
004716: Dec 5 23:24:24.945: //280/28030E0280FC/SIP/Info/sipSPIGetViaHostInURLFormat: VIA URL:sip:172.16.16.2:5060, Host:172.16.16.2
004717: Dec 5 23:24:24.949: //280/28030E0280FC/SIP/Info/sipSPIGetRegisterConfig: Using Global Config
004718: Dec 5 23:24:24.949: //280/28030E0280FC/SIP/Info/sipSPIGetRegisterConfig: Peer-Tag = 1, Reg-Pthru = Disable
004719: Dec 5 23:24:24.949: //280/28030E0280FC/SIP/Info/ccsip_process_registration_passthrough: Register not for passthrough, Try CME
004720: Dec 5 23:24:24.949: //280/28030E0280FC/SIP/Info/ccsip_spi_register_incoming_registration: Register for CME case
004721: Dec 5 23:24:24.949: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_register_get_rcb: Getting New RCB [0x4D4702EC]
004722: Dec 5 23:24:24.949: //280/28030E0280FC/SIP/Info/ccsip_spi_update_cc_callid: ccCallId for RCB is 281
004723: Dec 5 23:24:24.949: //280/28030E0280FC/SIP/Error/ccsip_spi_register_incoming_registration: CCSIP_REGISTER:: contact address matches own ip address
004724: Dec 5 23:24:24.949: //280/28030E0280FC/SIP/Info/ccsip_spi_registration_failed: Sending Register Response 404
004725: Dec 5 23:24:24.949: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_REGISTER_RESP
004726: Dec 5 23:24:24.949: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreePthruDataFromRPCBorRCB: RCB =[0x4D4702EC].. RPCB =[0x0]
004727: Dec 5 23:24:24.949: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIPassThruHdrContainerFreeHelper: Data -->[0x0]
004728: Dec 5 23:24:24.949: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_ipip_PassthruContentContainerFreeHelper: Null ContentQ - Exit
004729: Dec 5 23:24:24.949: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_register_free_rcb: Freeing rcb [0x4D4702EC]
004730: Dec 5 23:24:24.949: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 43
004731: Dec 5 23:24:24.949: //280/28030E0280FC/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 13 event
004732: Dec 5 23:24:24.949: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIRetrieveOutgoingPassThruData: Retrieving Data from RCB
004733: Dec 5 23:24:24.949: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIRetrieveOutgoingPassThruData: Retrieving Data from RCB
004734: Dec 5 23:24:24.949: //280/28030E0280FC/SIP/Info/sipSPISendResponse: Associated container=0x4E59628C to REGISTER Response 404
004735: Dec 5 23:24:24.953: //280/28030E0280FC/SIP/Transport/sipSPISendResponse: Sending INFO Response to the transport layer
004736: Dec 5 23:24:24.953: //280/28030E0280FC/SIP/Transport/sipSPITransportSendMessage: msg=0x4E781FD4, addr=172.16.16.2, port=57441, sentBy_port=5060, local_addr=, is_req=0, transport=1, switch=0, callBack=0x41BDA6B0
004737: Dec 5 23:24:24.953: //280/28030E0280FC/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
004738: Dec 5 23:24:24.953: //280/28030E0280FC/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
004739: Dec 5 23:24:24.953: //280/28030E0280FC/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x4E781FD4 to default port=5060
004740: Dec 5 23:24:24.953: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:172.16.16.2, rport:5060 with laddr:
004741: Dec 5 23:24:24.953: //280/28030E0280FC/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x4E781FD4
004742: Dec 5 23:24:24.953: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4E781FD4, addr=172.16.16.2, port=5060, local_addr=, connId=2 for UDP
004743: Dec 5 23:24:24.953: //280/28030E0280FC/SIP/State/sipSPIChangeState: 0x4D19AE18 : State change from (SIP_STATE_INCOMING_REGISTER, SUBSTATE_NONE) to (STATE_IDLE, SUBSTATE_NONE)
004744: Dec 5 23:24:24.953: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 32 REGISTER
Content-Length: 0
004745: Dec 5 23:24:24.957: //280/28030E0280FC/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 404 Not Found
To: <sip:12345678@172.16.16.2>;tag=532088-147E
CSeq: 32 REGISTER
Content-Length: 0
004746: Dec 5 23:24:24.957: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [172.16.16.2]:57441, local_address:[ - ]
004747: Dec 5 23:24:24.957: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [172.16.16.2]:57441, local_address:[ - ]
004748: Dec 5 23:24:24.957: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
004749: Dec 5 23:24:24.957: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
004750: Dec 5 23:24:24.957: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
004751: Dec 5 23:24:24.961: //279/000000000000/SIP/Info/sipSPIMatchRespToReqTran: removing unneeded z9hG4bK8921CC from via branch list
004752: Dec 5 23:24:24.961: //279/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 32 REGISTER
Content-Length: 0
004753: Dec 5 23:24:24.961: //279/000000000000/SIP/Info/sipSPICheckResponseExt: non-INVITE response with no RSEQ - do not disable IS_REL1XX
004754: Dec 5 23:24:24.961: //279/000000000000/SIP/Info/sipSPICheckResponseExt: Received 1XX_TRYING response for REGISTER
004755: Dec 5 23:24:24.961: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
004756: Dec 5 23:24:24.961: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
004757: Dec 5 23:24:24.961: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
004758: Dec 5 23:24:24.961: //279/000000000000/SIP/Info/sipSPIMatchRespToReqTran: removing unneeded z9hG4bK8921CC from via branch list
004759: Dec 5 23:24:24.965: //279/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 32 REGISTER
Content-Length: 0
004760: Dec 5 23:24:24.965: //279/000000000000/SIP/Info/sipSPICheckResponseExt: non-INVITE response with no RSEQ - do not disable IS_REL1XX
004761: Dec 5 23:24:24.965: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDecrementOverloadCount: Count:Local 0 Global 0
004762: Dec 5 23:24:24.965: //279/000000000000/SIP/Error/ccsip_api_register_result_ind: Message Code Class 4xx Method Code 100 received for REGISTER
004763: Dec 5 23:24:24.965: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_register_reset_dns_cache: CCSIP_REGISTER:: registrar 1 DNS resolved addr reset
004764: Dec 5 23:24:24.965: //279/000000000000/SIP/Info/sipSPIRegPthruProcessResponse: Processing response w/ resp code == 404
004765: Dec 5 23:24:24.965: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetRPCBFromRCB: Retreiving RCB [0x4D450960] from RPCB [0x0]
004766: Dec 5 23:24:24.965: //279/000000000000/SIP/Error/sipSPIRegPthruProcessResponse: Error NO RPCB
004767: Dec 5 23:24:24.965: //-1/xxxxxxxxxxxx/SIP/Info/ccsipRegisterStartRCBTimer: Starting timer for pattern 12345678 for 180 seconds
004768: Dec 5 23:24:24.965: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[247] removed.
004769: Dec 5 23:24:24.965: //279/000000000000/SIP/Info/sipSPIUdeleteCcbFromUACTable: ****Deleting from UAC table.
004770: Dec 5 23:24:24.965: //279/000000000000/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x4D18A6C0 key=90208111-9AD111E5-8003DB8C-E7BAB034
004771: Dec 5 23:24:24.965: //279/000000000000/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
004772: Dec 5 23:24:24.965: //279/000000000000/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
004773: Dec 5 23:24:24.965: //279/000000000000/SIP/Info/ccsip_offer_ans_delete:
004774: Dec 5 23:24:24.965: //279/000000000000/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 4D18A6C0
004775: Dec 5 23:24:24.965: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContextFromTable: NO context for key[247]
004776: Dec 5 23:24:35.209: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceHandleConnAgeing: Holder=0x4B101850 Connection=0x4AACDB2C, addr=172.16.16.27, port=5060, connid=6 has been REFRESHED
004777: Dec 5 23:24:35.209: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportSetAgeingTimer: Aging timer initiated for holder=0x4B101850,addr=172.16.16.27
004778: Dec 5 23:24:42.473: //-1/xxxxxxxxxxxx/SIP/Transport/sipInstanceHandleConnAgeing: Holder=0x49D4BFF8 Connection=0x4AACD40C, addr=72.55.168.18, port=5060, connid=4 has been REFRESHED
004779: Dec 5 23:24:42.473: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportSetAgeingTimer: Aging timer initiated for holder=0x49D4BFF8,addr=72.55.168.18
004780: Dec 5 23:24:50.409: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[245] removed.
004781: Dec 5 23:24:50.409: //277/1AD0BA3880F0/SIP/Info/sipSPIUdeleteCcbFromUACTable: ****Deleting from UAC table.
004782: Dec 5 23:24:50.409: //277/1AD0BA3880F0/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x4D1A05E0 key=1ADA7DE8-9ADE11E5-80F6DB8C-E7BAB034@172.16.16.2
004783: Dec 5 23:24:50.409: //277/1AD0BA3880F0/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
004784: Dec 5 23:24:50.409: //277/1AD0BA3880F0/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
004785: Dec 5 23:24:50.409: //277/1AD0BA3880F0/SIP/Info/ccsip_offer_ans_delete:
004786: Dec 5 23:24:50.409: //277/1AD0BA3880F0/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 4D1A05E0
004787: Dec 5 23:24:56.953: //280/28030E0280FC/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 118
004788: Dec 5 23:24:56.953: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[248] removed.
004789: Dec 5 23:24:56.953: //280/28030E0280FC/SIP/Info/sipSPIUdeleteCcbFromUASReqTable: ****Deleting from UAS Request table.
004790: Dec 5 23:24:56.953: //280/28030E0280FC/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x4D19AE18 key=90208111-9AD111E5-8003DB8C-E7BAB0341234567853207C-D44
004791: Dec 5 23:24:56.953: //280/28030E0280FC/SIP/Info/sipSPIUdeleteCcbFromUASRespTable: ****Deleting from UAS Response table.
004792: Dec 5 23:24:56.953: //280/28030E0280FC/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
004793: Dec 5 23:24:56.953: //280/28030E0280FC/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
004794: Dec 5 23:24:56.953: //280/28030E0280FC/SIP/Info/ccsip_offer_ans_delete:
004795: Dec 5 23:24:56.953: //280/28030E0280FC/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 4D19AE18
004796: Dec 5 23:25:25.002: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [72.55.168.18]:5060, local_address:[ - ]
004797: Dec 5 23:25:25.002: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpIPv4SocketReads: Msg enqueued for SPI with IP addr: [72.55.168.18]:5060, local_address:[ - ]
004798: Dec 5 23:25:25.006: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
004799: Dec 5 23:25:25.006: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x4AACC054
004800: Dec 5 23:25:25.006: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x4AACC054, addr=72.55.168.18, port=5060, local_addr=, connid=4, transport=UDP
004801: Dec 5 23:25:25.006: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:5148121234@172.16.16.2:5060 SIP/2.0
Via: SIP/2.0/UDP 72.55.168.18:5060;branch=z9hG4bK0855ad6d;rport
Max-Forwards: 70
CSeq: 103 BYE
User-Agent: voip.ms
X-Asterisk-HangupCause: Normal Clearing
X-Asterisk-HangupCauseCode: 16
Content-Length: 0
004802: Dec 5 23:25:25.006: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
004803: Dec 5 23:25:25.006: //276/1AD0BA3880F0/SIP/Info/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x4D195650
004804: Dec 5 23:25:25.006: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 72.55.168.18,Port 5060, Transport 1, SentBy Port 5060
004805: Dec 5 23:25:25.006: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone EST to SIP default timezone = GMT
004806: Dec 5 23:25:25.006: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 72.55.168.18,Port 5060, Transport 1, SentBy Port 5060
004807: Dec 5 23:25:25.010: //276/1AD0BA3880F0/SIP/Info/ccsip_set_release_source_for_peer: ownCallId[276], src[2]
004808: Dec 5 23:25:25.010: //276/1AD0BA3880F0/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
004809: Dec 5 23:25:25.010: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
004810: Dec 5 23:25:25.010: //276/1AD0BA3880F0/SIP/Info/sipSPIInitiateDisconnect: Initiate call disconnect(16) for incoming call
004811: Dec 5 23:25:25.010: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
004812: Dec 5 23:25:25.010: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
004813: Dec 5 23:25:25.010: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
004814: Dec 5 23:25:25.010: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
004815: Dec 5 23:25:25.010: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
004816: Dec 5 23:25:25.010: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
004817: Dec 5 23:25:25.010: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled: - 0
004818: Dec 5 23:25:25.010: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
004819: Dec 5 23:25:25.010: //276/1AD0BA3880F0/SIP/Info/sipAddSipContainerToCallEntry: Unable to add passthru hdrs to container
004820: Dec 5 23:25:25.010: //276/1AD0BA3880F0/SIP/State/sipSPIChangeState: 0x4D195650 : State change from (STATE_ACTIVE, SUBSTATE_NONE) to (STATE_DISCONNECTING, SUBSTATE_NONE)
004821: Dec 5 23:25:25.010: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
004822: Dec 5 23:25:25.010: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x4AACC054
004823: Dec 5 23:25:25.010: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x4AACC054, addr=72.55.168.18, port=5060, local_addr=, connid=4, transport=UDP
004824: Dec 5 23:25:25.010: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:5143601234@172.16.16.2:5060 SIP/2.0
Via: SIP/2.0/UDP 72.55.168.18:5060;branch=z9hG4bK024f2c00;rport
Max-Forwards: 70
To: "Cisco Lab" <sip:5143601234@172.16.16.2>;tag=5306F0-138A
CSeq: 102 BYE
User-Agent: voip.ms
Proxy-Authorization: Digest username="12345678", realm="montreal3.voip.ms", algorithm=MD5, uri="sip:72.55.168.18", nonce="07337ca9", response="83d17d42c837801aff194b98b86ae7f5"
Content-Length: 0
004825: Dec 5 23:25:25.010: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
004826: Dec 5 23:25:25.014: //278/24183DC980F7/SIP/Info/sipSPICheckFromToRequest: Found matching CB 4D1A5DA8
004827: Dec 5 23:25:25.014: //278/24183DC980F7/SIP/Info/sipSPILocateInviteDialogCCB: ****Found CCB in UAC table
004828: Dec 5 23:25:25.014: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 72.55.168.18,Port 5060, Transport 1, SentBy Port 5060
004829: Dec 5 23:25:25.014: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone EST to SIP default timezone = GMT
004830: Dec 5 23:25:25.014: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 72.55.168.18,Port 5060, Transport 1, SentBy Port 5060
004831: Dec 5 23:25:25.014: //278/24183DC980F7/SIP/Info/ccsip_set_release_source_for_peer: ownCallId[278], src[4]
004832: Dec 5 23:25:25.014: //278/24183DC980F7/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
004833: Dec 5 23:25:25.014: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
004834: Dec 5 23:25:25.014: //278/24183DC980F7/SIP/Info/sipSPIInitiateDisconnect: Initiate call disconnect(16) for outgoing call
004835: Dec 5 23:25:25.014: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
004836: Dec 5 23:25:25.014: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
004837: Dec 5 23:25:25.014: //278/24183DC980F7/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
004838: Dec 5 23:25:25.014: //278/24183DC980F7/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
004839: Dec 5 23:25:25.014: //278/24183DC980F7/SIP/Info/sipSPI_ipip_GetHdrPassthruCfg: Hdr passthrough config:1 tag:0
004840: Dec 5 23:25:25.014: //278/24183DC980F7/SIP/Info/sipSPI_ipip_ExtractPassthruCopyListHdrsFromSipContainer: Unsupported header passthru is not configured and no headers are present in hdr_hash_queue
004841: Dec 5 23:25:25.014: //278/24183DC980F7/SIP/Info/sipSPI_ipip_IsContentPassthruEnabled: - 0
004842: Dec 5 23:25:25.014: //278/24183DC980F7/SIP/Info/sipSPI_ipip_ExtractPassthruContentFromSipContainer: Passthru Content Not Enabled
004843: Dec 5 23:25:25.014: //278/24183DC980F7/SIP/Info/sipAddSipContainerToCallEntry: Unable to add passthru hdrs to container
004844: Dec 5 23:25:25.018: //278/24183DC980F7/SIP/State/sipSPIChangeState: 0x4D1A5DA8 : State change from (STATE_ACTIVE, SUBSTATE_NONE) to (STATE_DISCONNECTING, SUBSTATE_NONE)
004845: Dec 5 23:25:25.018: //278/24183DC980F7/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
004846: Dec 5 23:25:25.018: //278/24183DC980F7/SIP/Info/updateGccbTxRxValues: No interworking required for nte
004847: Dec 5 23:25:25.018: //278/24183DC980F7/SIP/Info/updateGccbTxRxValues: No interworking required for nse
004848: Dec 5 23:25:25.018: //276/1AD0BA3880F0/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
004849: Dec 5 23:25:25.018: //276/1AD0BA3880F0/SIP/Info/updateGccbTxRxValues: No interworking required for nte
004850: Dec 5 23:25:25.018: //276/1AD0BA3880F0/SIP/Info/updateGccbTxRxValues: No interworking required for nse
004851: Dec 5 23:25:25.018: //276/1AD0BA3880F0/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:48DEA3B4
004852: Dec 5 23:25:25.018: //276/1AD0BA3880F0/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 0
004853: Dec 5 23:25:25.018: //276/1AD0BA3880F0/SIP/Info/updateGccbTxRxValues: No interworking required for nte
004854: Dec 5 23:25:25.018: //276/1AD0BA3880F0/SIP/Info/updateGccbTxRxValues: No interworking required for nse
004855: Dec 5 23:25:25.018: //278/24183DC980F7/SIP/Info/updateGccbTxRxValues: No interworking required for stream type 1
004856: Dec 5 23:25:25.018: //278/24183DC980F7/SIP/Info/updateGccbTxRxValues: No interworking required for nte
004857: Dec 5 23:25:25.018: //278/24183DC980F7/SIP/Info/updateGccbTxRxValues: No interworking required for nse
004858: Dec 5 23:25:25.018: //278/24183DC980F7/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:546E9C38
004859: Dec 5 23:25:25.022: //276/1AD0BA3880F0/SIP/Info/ccsip_call_statistics: Stats are not supported for IPIP call.
004860: Dec 5 23:25:25.022: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
004861: Dec 5 23:25:25.022: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
004862: Dec 5 23:25:25.022: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
004863: Dec 5 23:25:25.022: //278/24183DC980F7/SIP/Info/ccsip_call_statistics: Stats are not supported for IPIP call.
004864: Dec 5 23:25:25.022: //278/24183DC980F7/SIP/Info/sipSPI_ipip_antiTrombone: Entered Antitrombone service
004865: Dec 5 23:25:25.022: //278/24183DC980F7/SIP/Info/sipSPI_ipip_antiTrombone: Antitrombone service not configured
004866: Dec 5 23:25:25.022: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
004867: Dec 5 23:25:25.022: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 8
004868: Dec 5 23:25:25.022: //276/1AD0BA3880F0/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 3 event
004869: Dec 5 23:25:25.022: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer: Could not get any elements from TD Container
004870: Dec 5 23:25:25.022: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer: Could not get any elements from TD Container
004871: Dec 5 23:25:25.026: //276/1AD0BA3880F0/SIP/Info/sipSPISendByeResponse: Associated container=0x4E5979EC to Bye Response
004872: Dec 5 23:25:25.026: //276/1AD0BA3880F0/SIP/Transport/sipSPISendByeResponse: Sending BYE Response to the transport layer
004873: Dec 5 23:25:25.026: //276/1AD0BA3880F0/SIP/Transport/sipSPITransportSendMessage: msg=0x48E2C0FC, addr=72.55.168.18, port=5060, sentBy_port=5060, local_addr=, is_req=0, transport=1, switch=0, callBack=0x41BD7894
004874: Dec 5 23:25:25.026: //276/1AD0BA3880F0/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
004875: Dec 5 23:25:25.026: //276/1AD0BA3880F0/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
004876: Dec 5 23:25:25.026: //276/1AD0BA3880F0/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x48E2C0FC to default port=5060
004877: Dec 5 23:25:25.026: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:72.55.168.18, rport:5060 with laddr:
004878: Dec 5 23:25:25.026: //276/1AD0BA3880F0/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x48E2C0FC
004879: Dec 5 23:25:25.026: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x48E2C0FC, addr=72.55.168.18, port=5060, local_addr=, connId=4 for UDP
004880: Dec 5 23:25:25.026: //276/1AD0BA3880F0/SIP/Info/sentByeResponse: Sent 200ok to the BYE, tearing down the call
004881: Dec 5 23:25:25.026: //276/1AD0BA3880F0/SIP/Info/sipSPIIcpifUpdate: CallState: 4 Playout: 0 DiscTime:550790 ConnTime 544719
004882: Dec 5 23:25:25.026: //276/1AD0BA3880F0/SIP/Media/sipSPIDestroyRtpSession: stream:48DEA3B4
004883: Dec 5 23:25:25.030: //276/1AD0BA3880F0/SIP/State/sipSPIChangeState: 0x4D195650 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE) to (STATE_DEAD, SUBSTATE_NONE)
004884: Dec 5 23:25:25.030: //276/1AD0BA3880F0/SIP/Call/sipSPICallInfo:
State of The Call : STATE_DEAD
004885: Dec 5 23:25:25.030: //276/1AD0BA3880F0/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
Negotiated Codec : g711ulaw
Nego. Codec payload : 0 (tx), 0 (rx)
004886: Dec 5 23:25:25.030: //276/1AD0BA3880F0/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC) : 16
Disconnect Cause (SIP) : 200
004887: Dec 5 23:25:25.030: //276/1AD0BA3880F0/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 114
004888: Dec 5 23:25:25.030: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 8
004889: Dec 5 23:25:25.030: //278/24183DC980F7/SIP/Info/sipSPIPresendProcessing: Presend Processing called for 3 event
004890: Dec 5 23:25:25.030: //278/24183DC980F7/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer: Could not get any elements from TD Container
004891: Dec 5 23:25:25.030: //278/24183DC980F7/SIP/Info/sipSPI_ipip_GetPassthruCopyListDataFromTdContainer: Could not get any elements from TD Container
004892: Dec 5 23:25:25.030: //278/24183DC980F7/SIP/Info/sipSPISendByeResponse: Associated container=0x4E5975CC to Bye Response
004893: Dec 5 23:25:25.030: //278/24183DC980F7/SIP/Transport/sipSPISendByeResponse: Sending BYE Response to the transport layer
004894: Dec 5 23:25:25.030: //278/24183DC980F7/SIP/Transport/sipSPITransportSendMessage: msg=0x4E6C1AF8, addr=72.55.168.18, port=5060, sentBy_port=5060, local_addr=, is_req=0, transport=1, switch=0, callBack=0x41BD7894
004895: Dec 5 23:25:25.030: //278/24183DC980F7/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
004896: Dec 5 23:25:25.030: //278/24183DC980F7/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
004897: Dec 5 23:25:25.030: //278/24183DC980F7/SIP/Transport/sipTransportLogicSendMsg: Trying to send resp=0x4E6C1AF8 to default port=5060
004898: Dec 5 23:25:25.030: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerGetConnection: connection required for raddr:72.55.168.18, rport:5060 with laddr:
004899: Dec 5 23:25:25.034: //278/24183DC980F7/SIP/Transport/sipTransportLogicSendMsg: Connection obtained...sending msg=0x4E6C1AF8
004900: Dec 5 23:25:25.034: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x4E6C1AF8, addr=72.55.168.18, port=5060, local_addr=, connId=4 for UDP
004901: Dec 5 23:25:25.034: //278/24183DC980F7/SIP/Info/sentByeResponse: Sent 200ok to the BYE, tearing down the call
004902: Dec 5 23:25:25.034: //278/24183DC980F7/SIP/Info/sipSPIIcpifUpdate: CallState: 4 Playout: 0 DiscTime:550790 ConnTime 544718
004903: Dec 5 23:25:25.034: //278/24183DC980F7/SIP/Media/sipSPIDestroyRtpSession: stream:546E9C38
004904: Dec 5 23:25:25.034: //278/24183DC980F7/SIP/State/sipSPIChangeState: 0x4D1A5DA8 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE) to (STATE_DEAD, SUBSTATE_NONE)
004905: Dec 5 23:25:25.034: //278/24183DC980F7/SIP/Call/sipSPICallInfo:
004906: Dec 5 23:25:25.034: //278/24183DC980F7/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
004907: Dec 5 23:25:25.034: //278/24183DC980F7/SIP/Call/sipSPICallInfo:
004908: Dec 5 23:25:25.034: //278/24183DC980F7/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 116
004909: Dec 5 23:25:25.038: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
From: "Jakub Stroinski" <sip:5147221234@72.55.168.18>;tag=as2898aaf9
To: <sip:12345678@172.16.16.2:5060>;tag=52CC2C-269B
Date: Sat, 05 Dec 2015 23:25:25 GMT
Call-ID: 6b86e46b0f1b34bc5887abbf5851c960@72.55.168.18:5060
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 103 BYE
Reason: Q.850;cause=16
P-RTP-Stat: PS=0,OS=0,PR=0,OR=0,PL=0,JI=0,LA=0,DU=60
Content-Length: 0
004910: Dec 5 23:25:25.038: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: "Jakub Stroinski" <sip:5143601234@172.16.16.2>;tag=5306F0-138A
CSeq: 102 BYE
Content-Length: 0
004911: Dec 5 23:25:57.030: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[244] removed.
004912: Dec 5 23:25:57.030: //276/1AD0BA3880F0/SIP/Info/sipSPIUdeleteCcbFromUASReqTable: ****Deleting from UAS Request table.
004913: Dec 5 23:25:57.030: //276/1AD0BA3880F0/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x4D195650 key=6b86e46b0f1b34bc5887abbf5851c960@72.55.168.18:506012345678
004914: Dec 5 23:25:57.030: //276/1AD0BA3880F0/SIP/Info/sipSPIUdeleteCcbFromUASRespTable: ****Deleting from UAS Response table.
004915: Dec 5 23:25:57.030: //276/1AD0BA3880F0/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x4D195650 key=6b86e46b0f1b34bc5887abbf5851c960@72.55.168.18:506052CC2C-269B
004916: Dec 5 23:25:57.030: //276/1AD0BA3880F0/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
004917: Dec 5 23:25:57.030: //276/1AD0BA3880F0/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
004918: Dec 5 23:25:57.030: //276/1AD0BA3880F0/SIP/Info/ccsip_offer_ans_delete:
004919: Dec 5 23:25:57.030: //276/1AD0BA3880F0/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 4D195650
004920: Dec 5 23:25:57.034: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[246] removed.
004921: Dec 5 23:25:57.034: //278/24183DC980F7/SIP/Info/sipSPIUfreeOneCCB: free ccb->call_info.origRedirectNumber
004922: Dec 5 23:25:57.034: //278/24183DC980F7/SIP/Info/sipSPIUdeleteCcbFromUACTable: ****Deleting from UAC table.
004923: Dec 5 23:25:57.034: //278/24183DC980F7/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x4D1A5DA8 key=241BE751-9ADE11E5-80FBDB8C-E7BAB034@172.16.16.2
004924: Dec 5 23:25:57.034: //278/24183DC980F7/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
004925: Dec 5 23:25:57.034: //278/24183DC980F7/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
004926: Dec 5 23:25:57.034: //278/24183DC980F7/SIP/Info/ccsip_offer_ans_delete:
004927: Dec 5 23:25:57.034: //278/24183DC980F7/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 4D1A5DA8
Please add these commands and test again. I will review the logs later.
Voice service voip
sip
supplementary-service sip moved-temporarily
 supplementary-service sip referer
Please rate all useful posts
I tried. On the transfer I get a fast busy
If I put just moved-temporarily then I get a fast busy on transfer
If I put just sip refer then same behaviour as before
Looks like it doesn't work with those commands
I've been doing some digging on the internet and it seems like Im not the only one to experience this issue. Problem is that no one posts a solution:
https://supportforums.cisco.com/discussion/11569176/cme-inbound-sip-call-forwarded-or-diverted-has-no-audio-either-direction
https://supportforums.cisco.com/discussion/12567696/call-forwarded-back-sip-trunk-has-no-audio-both-ways
https://supportforums.cisco.com/document/113041/no-voice-when-calls-accross-sip-trunk
Jakub,
I have gone through the logs and I dont see anything out of place. I assume this is a CFNA. Can you test a CFWDALL scenario for me. So please set a cfwdall to external number. Please send me debug ccsip message.
This one I cant test until next week unfortunately. Im out of country and cannot forward the calls to my foreign number from this account. I will try to update as soon as I can
Is it possible that the router is just not connecting the streams together?
Dec  5 18:47:07.803: //96997/6241A6179B7E/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x4B512228
Called Number            : 2339
Destn SIP Req Addr:Port  : 172.16.16.23:5060
Destn SIP Resp Addr:Port : 172.16.16.23:5060
Destination Name         : 172.16.16.23
Dec  5 18:47:07.803: //96997/6241A6179B7E/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Negotiated Codec         : No Codec
Negotiated Codec Bytes   : 0
Nego. Codec payload      : 255 (tx), 255 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Port    (Media): 16978
Destn  IP Address (Media):  -
Destn  IP Port    (Media): 0
Disconnect Cause (SIP)   : 487
Dec  5 18:47:20.999: //96998/6B7EC8FB9B85/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x4B523010
Dec  5 18:47:20.999: //96998/6B7EC8FB9B85/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Source IP Port    (Media): 17480
Destn  IP Port    (Media): 14104
Dec  5 18:47:21.015: //96996/6241A6179B7E/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x4B50C830
Dec  5 18:47:21.015: //96996/6241A6179B7E/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Source IP Port    (Media): 18742
Destn  IP Port    (Media): 14400
Dec  5 18:48:21.024: //96998/6B7EC8FB9B85/SIP/Call/sipSPICallInfo:
Dec  5 18:48:21.024: //96998/6B7EC8FB9B85/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Dec  5 18:48:21.032: //96996/6241A6179B7E/SIP/Call/sipSPICallInfo:
Dec  5 18:48:21.032: //96996/6241A6179B7E/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
collect the logs in buffer, also please post complete show run from GW.
Enable this debug ccsip message and debug voice ccapi inout.
Br,
Nadeem
Br, Nadeem Please rate all useful post.
LabDOMAIN1#clear logging
Clear logging buffer [confirm]
LabDOMAIN1#
LabDOMAIN1#
LabDOMAIN1#debug voice ccapi inout
voip ccapi inout debugging is on
LabDOMAIN1#show logging
Syslog logging: enabled (5 messages dropped, 3 messages rate-limited, 2119 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: level debugging, 72495 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level debugging, 69925 messages logged, xml disabled,
                    filtering disabled
    Exception Logging: size (4096 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
No active filter modules.
    Trap logging: level informational, 97 message lines logged
        Logging Source-Interface:       VRF Name:
Log Buffer (4096 bytes):
c  4 22:00:34.205: //93774/1080CDAF931E/CCAPI/cc_generic_bridge_done:
   Conference Id=0x64, Source Interface=0x49C67A38, Source Call Id=93781,
   Destination Call Id=93774, Disposition=0x0, Tag=0x0
Dec  4 22:00:34.209: //93774/1080CDAF931E/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Dec  4 22:00:34.209: //93781/1080CDAF931E/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Dec  4 22:00:34.213: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 72.55.168.18:5060;branch=z9hG4bK69291e54;rport
Max-Forwards: 70
To: "Cisco Lab" <sip:5143601234@172.16.16.2>;tag=96DE01F4-1A66
Call-ID: 198BE407-9A0911E5-932EBE77-FFDD325D@172.16.16.2
CSeq: 102 BYE
User-Agent: voip.ms
Proxy-Authorization: Digest username="12345678", realm="montreal3.voip.ms", algorithm=MD5, uri="sip:72.55.168.18", nonce="7a72b766", response="2dc6aeb758aba1282d3789335fe34738"
Content-Length: 0
Dec  4 22:00:34.213: //93781/1080CDAF931E/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x49C67A38, Call Id=93781
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Dec  4 22:00:34.217: //93774/1080CDAF931E/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x49C67A38, Tag=0x0, Call Id=93774,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Dec  4 22:00:34.217: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Dec  4 22:00:34.217: :cc_free_feature_vsa freeing 48F46E80
Dec  4 22:00:34.217:  vsacount in free is 3
Dec  4 22:00:34.217:  vsacount in free is 2
Dec  4 22:00:34.221: //93781/1080CDAF931E/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x49C67A38, Tag=0x0, Call Id=93781,
Dec  4 22:00:34.221: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Dec  4 22:00:34.221: :cc_free_feature_vsa freeing 48F479E0
Dec  4 22:00:34.221:  vsacount in free is 1
Dec  4 22:00:34.221:  vsacount in free is 0
Dec  4 22:00:34.225: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 72.55.168.18:5060;branch=z9hG4bK04e7fd7d;rport
From: "DOMAIN" <sip:5147221234@72.55.168.18>;tag=as00d24a0e
To: <sip:12345678@172.16.16.2:5060>;tag=96DDC730-1D6
Date: Fri, 04 Dec 2015 22:00:34 GMT
Call-ID: 43527773203075545690395c47e3fac3@72.55.168.18:5060
CSeq: 103 BYE
Content-Length: 0
Sent:
SIP/2.0 200 OK
To: "DOMAIN" <sip:5143601234@172.16.16.2>;tag=96DE01F4-1A66
CSeq: 102 BYE
Content-Length: 0
Config:
LabDOMAIN1#sh run
Building configuration...
Current configuration : 5431 bytes
! Last configuration change at 08:14:44 EST Wed Dec 2 2015 by voipDOMAIN
! NVRAM config last updated at 15:00:06 EST Tue Dec 1 2015 by voipDOMAIN
version 15.1
hostname LabDOMAIN1
boot-start-marker
boot system flash:c2800nm-adventerprisek9-mz.151-4.M10.bin
boot-end-marker
logging buffered 4096
no aaa new-model
clock timezone EST -5 0
clock summer-time EDT recurring
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 172.16.16.1 172.16.16.20
ip dhcp pool voice
 import all
 network 172.16.16.0 255.255.255.0
 default-router 172.16.16.1
 option 150 ip 172.16.16.4
 dns-server 10.10.0.5
 lease 0 2
ip domain name lab.DOMAIN.com
ip name-server 172.16.16.1
ip name-server 10.10.0.5
no ipv6 cef
voice service voip
 ip address trusted list
  ipv4 72.55.168.18
  ipv4 172.10.10.0 255.255.255.0
  ipv4 172.16.16.0 255.255.255.0
 ip address trusted call-block cause not-in-cug
 gcid
 clid substitute name
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 no supplementary-service sip moved-temporarily
 no supplementary-service sip refer
 sip
  e911
  registrar server expires max 600 min 60
  transport switch udp tcp
  asserted-id ppi
  midcall-signaling passthru
  no call service stop
voice class sip-profiles 1
 request INVITE sip-header From modify "From: (.*<)(.*>)" "From: \"Cisco Lab\" <\2"
voice register global
 timeouts interdigit 5
 system message SRST active
 max-dn 20
 max-pool 20
voice register pool  1
 translation-profile outgoing SRST
 id network 172.16.16.0 mask 255.255.255.0
 alias 1 2000 to 2339
 dtmf-relay rtp-nte cisco-rtp
 call-forward b2bua noan 95148121234 timeout 15
 codec g711ulaw
voice translation-rule 1
 rule 1 /.*/ /2000/
voice translation-rule 2
 rule 1 /.*/ /5143601234/
voice translation-rule 3
 rule 1 /^9\(.*\)/ /\1/
voice translation-rule 4
 rule 1 /2000/ /2339/
voice translation-profile INCOMING
 translate called 1
voice translation-profile OUTGOING
 translate calling 2
 translate called 3
voice translation-profile SRST
 translate called 4
voice-card 0
crypto pki trustpoint TP-self-signed-910207751
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-910207751
 revocation-check none
 rsakeypair TP-self-signed-910207751
license udi pid CISCO2811 sn FTX112$$$$$$$$$$
archive
 log config
  hidekeys
username voipDOMAIN privilege 15 secret 5 $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
redundancy
interface FastEthernet0/0
 description DHCPVoIP
 ip address 172.16.16.2 255.255.255.0
 duplex auto
 speed auto
interface FastEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 172.16.16.1
access-list 23 permit 172.16.16.0 0.0.0.255
access-list 23 permit 172.10.10.0 0.0.0.255
access-list 23 permit 10.10.0.0 0.0.0.255
tftp-server flash:apps75.9-4-2ES9.sbn
tftp-server flash:cnu75.9-4-2ES9.sbn
tftp-server flash:cvm75sccp.9-4-2ES9.sbn
tftp-server flash:dsp75.9-4-2ES9.sbn
tftp-server flash:jar75sccp.9-4-2ES9.sbn
tftp-server flash:SCCP75.9-4-2SR1-1S.loads
tftp-server flash:term75.default.loads
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:Desktops/320x216x16/DOMAIN.png
tftp-server flash:Desktops/320x216x16/TN-DOMAIN.png
tftp-server flash:Desktops/320x196x4/List.xml
tftp-server flash:Desktops/320x196x4/DOMAINBW.png
tftp-server flash:Desktops/320x196x4/TN-DOMAINBW.png
control-plane
mgcp profile default
dial-peer voice 1 voip
 translation-profile incoming INCOMING
 session protocol sipv2
 session target ipv4:172.16.16.4
 incoming called-number 12345678
 dtmf-relay cisco-rtp rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 3 voip
 translation-profile outgoing OUTGOING
 destination-pattern 9[2-9]..[2-9]......
 session target ipv4:72.55.168.18
 no voice-class sip early-offer forced
 voice-class sip profiles 1
 dtmf-relay rtp-nte cisco-rtp sip-kpml sip-notify
 codec g711ulaw
 no vad
dial-peer voice 4 voip
 destination-pattern 2...
 codec g711ulaw
 no vad
sip-ua
 credentials username 12345678 password 7 $$$$$$$$$$$$$$$$$$$$$$ realm montreal3.voip.ms
 authentication username 12345678 password 7 $$$$$$$$$$$$$$$$$$$$$$ realm montreal3.voip.ms
 registrar 1 dns:montreal3.voip.ms expires 300
 registrar 2 ipv4:172.16.16.2 expires 3600
call-manager-fallback
 max-conferences 8 gain -6
 transfer-system full-consult
 ip source-address 172.16.16.2 port 2000
 max-ephones 1
 max-dn 1 octo-line
banner exec ^C
Authorized access only. This system is the property of DOMAIN. Disconnect IMMEDIATELY if you are not an authorized user!
^C
banner login ^C
^C
line con 0
 login local
line aux 0
line vty 0 4
 access-class 23 in
 privilege level 15
 login local
 transport input ssh
scheduler allocate 20000 1000
ntp update-calendar
ntp server 192.67.222.4
end
LabDOMAIN1#
Hi Jakub,
Wondering if you ever got this solved.  Running into something quite similar.
Thanks!
Marie
Try enabling media flow-around
Enable Media Flow Mode on SIP Trunks
Restriction:
If any media service (like transcoding and conferencing) is needed for SIP to SIP trunk call, at least one of the SIP trunks must be placed in flow through mode.
If media needs to flow through Cisco Unified CME for voicemail calls, the SIP trunk going towards the voicemail must be in flow through mode.
SUMMARY STEPS
1. enable
2. configure terminal
3. voice service voip
4. media [flow around | flow through]
5. exit
6. dial-peer voice tag voip
7. media {[flow-around | flow-through] forking}
8. exit
9. voice class media tag
10. media {[flow-around | flow-through] forking}
11. end
