Call Recording with CUCM ver12
Samer R. Saleem
Level 4
Level 4
I have Speechlog server that is connected to CUCM v12
currently the calls are logged on the record server, but there is no sound on any call
can anyone advise what the problem could be?
thanks
George Sotiropoulos
Hi!
Was it working  before, have you changed anything on your configuration? \
If you have upgraded to CUCM v12 you may need (if you havent done already) to contact Speechlog Support Team and check if there is a need for software update on the system.
George
Hope the above helps,
gsotirop
