Call Transfer Mask
chuck47172
CUCM/Unity 12.5
I have a Unity call handler that is configure to play a greeting and then transfer the caller to extension 1234.
When the transfer takes place, I can see on my display that I'm ringing to extension 1234.
How can I mask that so I will not see the 1234 number or have it change to a different number like 5678?
I don't want the calling party to see the number the are being transferred to. Otherwise they may note the number and start calling it directly and bypassing Unity. Anyway, I figured it out.
Connected Party Transformations is the trick. I have unity transferring to a translation pattern that transforms to the number I ultimately want to reach. Restricting "connected party transformations" on the translation pattern will display the word "private" rather than 1234.
when some one call 1234 it should show that its  ringing 1234. what's the use case ?
Response Signature
