ā05-25-2012 04:22 AM - edited ā03-16-2019 11:20 AM
Hi all,
I have a call transfer problem with SIP IP Phones (8961 and 9971) : we have 2 Phones 8951 for secretariat and 1phone 9971, and sometimes call transfer don't proceed immediately !! the phones are associated with 3 lines PSTN using H323 GWs and CUCM 8.6.
Any help will be appreciated,
Best regards
ā05-25-2012 06:32 AM
Exactly what do you mean by that, explain the exact behavior you're seeing.
At least from what you're describing IDT comes to mind.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
ā05-25-2012 07:05 AM
The scenareo is like this:
the secretary recieve a call and he want transfer it to his chief (full-consult transfer) : the secretary click the transfer softkey, compose chief number, consult him, and when he press the transfer softkey in the second times the chief wait some time (5 to 10 seconds or more) to hear the other person (to receive the call).
Best regards.
ā05-25-2012 08:08 AM
Does this affect only calls from the PSTN? Do calls from internal phones transfer without the delay?
ā05-25-2012 08:18 AM
this affect PSTN calls and this phones don't receive internal calls
ā05-25-2012 08:25 AM
can we have a sh run of your config?
ā05-28-2012 02:59 AM
You can find gateway config. For your information we use switchs HP Procurve with Cisco IP Phones.
version 15.0
boot-start-marker
boot-end-marker
card type e1 0 0
logging buffered 51200 warnings
no aaa new-model
network-clock-participate wic 0
network-clock-participate wic 1
no ipv6 cef
ip source-route
ip cef
ip domain name yourdomain.com
isdn switch-type primary-net5
voice-card 0
voice call send-alert
voice call convert-discpi-to-prog
voice call carrier capacity active
voice service voip
allow-connections sip to sip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
h323
call preserve
voice class h323 1
h225 timeout tcp establish 3
voice class dualtone-detect-params 77
freq-max-deviation 30
voice class custom-cptone morocco
dualtone disconnect
frequency 435
cadence 500 500
voice translation-rule 10
rule 1 /^0/ /10/
voice translation-rule 20
rule 1 /^0/ /20/
voice translation-rule 30
rule 1 /^0/ /30/
voice translation-rule 40
rule 1 /^0/ /40/
voice translation-rule 50
rule 1 /^0/ /50/
voice translation-profile FXO10
translate called 10
voice translation-profile FXO20
translate called 20
voice translation-profile FXO30
translate called 30
voice translation-profile FXO40
translate called 40
voice translation-profile FXO50
translate called 50
license udi pid CISCO2911/K9 sn FGL155010TW
hw-module pvdm 0/0
hw-module pvdm 0/1
username admin privilege 15 secret 5 $1$cK.O$qQJMGLXCQ7d4DlXbkK6c41
redundancy
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31
controller E1 0/0/1
interface GigabitEthernet0/0
ip address 10.10.254.6 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.10.254.6
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface BRI0/1/0
no ip address
isdn switch-type basic-net3
isdn point-to-point-setup
interface BRI0/1/1
no ip address
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 10.10.254.1
control-plane
voice-port 0/0/0:15
voice-port 0/1/0
no vad
voice-port 0/1/1
voice-port 0/2/0
supervisory disconnect dualtone mid-call
supervisory custom-cptone morocco
supervisory dualtone-detect-params 77
no battery-reversal
no vad
timeouts initial 0
timeouts call-disconnect 0
timeouts ringing 100
timeouts wait-release 1
timing hookflash-out 50
connection plar opx 1900
caller-id enable
voice-port 0/2/1
no battery-reversal
no vad
timeouts wait-release 5
caller-id enable
voice-port 0/2/2
no battery-reversal
no vad
connection plar opx 103
caller-id enable
voice-port 0/2/3
no battery-reversal
no vad
connection plar opx 199
caller-id enable
voice-port 0/3/0
no battery-reversal
no vad
connection plar opx 1515
caller-id enable
voice-port 0/3/1
no battery-reversal
no vad
caller-id enable
voice-port 0/3/2
no battery-reversal
no vad
caller-id enable
voice-port 0/3/3
no battery-reversal
no vad
connection plar opx 1518
caller-id enable
dial-peer voice 100 pots
destination-pattern 00T
progress_ind setup enable 3
progress_ind alert enable 8
direct-inward-dial
port 0/0/0:15
forward-digits all
dial-peer voice 101 pots
destination-pattern 05T
direct-inward-dial
port 0/0/0:15
forward-digits all
dial-peer voice 102 pots
destination-pattern 06T
direct-inward-dial
port 0/0/0:15
forward-digits all
dial-peer voice 2 voip
destination-pattern 1...
session target ipv4:10.10.254.3
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 1 voip
preference 1
session target ipv4:10.10.254.2
codec g711ulaw
no vad
dial-peer voice 4 voip
codec g711ulaw
no vad
dial-peer voice 3 voip
preference 1
codec g711ulaw
no vad
dial-peer voice 200 pots
destination-pattern 10T
port 0/2/2
prefix 0
dial-peer voice 201 voip
translation-profile incoming FXO10
answer-address 103
dial-peer voice 202 pots
destination-pattern 20T
port 0/2/3
prefix 0
dial-peer voice 203 voip
translation-profile incoming FXO20
answer-address 199
dial-peer voice 300 pots
destination-pattern 90T
direct-inward-dial
port 0/3/0
prefix 0
dial-peer voice 301 pots
preference 1
direct-inward-dial
port 0/3/1
prefix 0
dial-peer voice 302 pots
preference 2
direct-inward-dial
port 0/3/2
prefix 0
dial-peer voice 204 pots
destination-pattern 30T
port 0/2/0
prefix 0
dial-peer voice 205 voip
translation-profile incoming FXO30
answer-address 1900
dial-peer voice 206 pots
destination-pattern 40T
port 0/2/1
prefix 0
dial-peer voice 207 voip
translation-profile incoming FXO40
answer-address 1901
dial-peer voice 208 pots
destination-pattern 50T
port 0/3/3
prefix 0
dial-peer voice 103 pots
description utliser pour les appels vers num 1XX
destination-pattern 91..
direct-inward-dial
port 0/2/2
forward-digits 3
dial-peer voice 104 pots
direct-inward-dial
port 0/2/3
forward-digits 3
dial-peer voice 210 voip
translation-profile incoming FXO50
answer-address 1518
dial-peer voice 5 voip
destination-pattern 7...
codec g711ulaw
no vad
dial-peer voice 6 voip
preference 1
codec g711ulaw
no vad
ā05-30-2012 04:22 AM
Hi there,
We are facing the exact same problem with one of our customer using this type of IP Phones. Same symptoms: Delay on transfer using sip phones .
If someone finds a solution , please share
ā05-30-2012 05:03 AM
Youssef,
What is your call scenario? Are you using cucm? What type of gateway do you have? Are you using PSTN or SIP trunks..
ā05-30-2012 06:19 AM
Hi all,
We have 2 IP Phones 8961 and one IP Phones 9971. The two 8961 IP Phones have two shared lines and they are associated to 2 PSTN lines, the scenario is like this:
we use :
cucm 8.6.2.20000-2
gateway : CISCO2911 version 15.0
we use PSTN trunks
ā05-30-2012 06:21 AM
Hi aokanlawon
Yes, i am using cucm 8.6 and 2911 gw h323 with a pri connection to pstn.
We are exepriencing the transfer delay even with internal ip calls. Gw not involved
The call scenario is as follow:
User A calls user B
User B do a consult transfer to user C
User B push the transfer softkey to complete the transfer.
The transfer is completed after 4 or 5 seconds of delay.
ā12-11-2012 11:17 AM
Has anyone found a fix to this? We are having the same exact issue involving 9971 phones at one of our sites. Other sites are not having the issue using the same phones in a nearly identical set up. We also found that the delay occurs when trying to conference and resuming from hold. We have a 6921 and a 7937 at the site that do not have the problem. Any help would be appreciated...
James
ā02-15-2013 06:43 AM
Found the issue after months of troubleshooting this... We were finding a ton of TCP retransmits for signalling packets in the packet captures meaning a lot of packets were being lost. It ended up being a QoS service policy set up by auto-qos on the switches that was set to drop signalling packets after 32K. We bumped it up to 128K and it cleared it up.
ā07-27-2020 11:29 PM
