Showing results forĀ
Search instead forĀ
Did you mean:Ā
Callforward to VM
Ian Jones
Can anyone remind where where the setting is in CUCM or unity that says which mailbox is used when callforwarding into Unity i.e the origional called extension's  or the forward extensions voicemail box
thanks
Rob Huffman
Hi Ian,
This can be changed in Unity 5.X and above (below)
Route Forwarded Calls by the First or Last Redirecting Number
Cisco  Unity supports the option of routing calls based on either the first or  last redirecting number when a call is forwarded to Cisco Unity.
Note the following:
This option requires Cisco Unity-CM TSP 8.1(2) or later.
This option is not supported by integrations through PIMG units.
This option can be changed through the Advanced Settings Tool (AST), which is available in Tools Depot.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/release/notes/501curelnotes.html#wp507371
This is available in Unity Connection 7.x and above as well;
Via
Cisco Unity Connection Administration
Advanced (towards the bottom of the page)
Conversation Configuration
Use Last (Rather than First) Redirecting Number for Routing Incoming Call
Cheers!
Rob
"Clocks go slow in a place of work
Minutes drag and the hours jerk"
-The Clash
thanks for the info - as I am using SIP on the phones and SIP into unity there is no concept of first  / last re-directing number - just "re-directing number" can this be set anywhere else?
Hi Ian,
We use SCCP so I can't test this for you, but it does
show in the docs as supported
Table 10-1     Differences Between SCCP and SIP Integration Methods (Integration with Cisco Unified Communications Manager)
Feature
SCCP
SIP
Communication method
SCCP Protocol
SIP trunk
Cisco Unity Connection cluster (active/active high availability)
Supported
Supported
Use of SCCP and SIP phones
Supported
Supported
Support for Cisco Unified CM versions
Versions 4.1(x) and later
Versions 5.x and later
Cisco Unified CM authentication and encryption
Supported
Supported
First/last redirecting number
Supported
Supported
QOS
Supported
Supported
Supported IP addressing modes
IPv4, IPv6 or dual stack
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/design/guide/8xcucdg050.html#wp1094093
Cheers!
Rob
-The Clash
hmm, - wonder why its not working for me then, seems to only pickout the last number, even though in unity its set to use first re-direct number
