06-18-2017 02:28 AM - edited 03-17-2019 10:36 AM
Dear All,
As the subject say, I have cucm deployed in my company when the users calls numbers that has IVR the digits is not working. Example:
User dialed a number and the IVR answers for support click 1 >> user click one nothing happens.
I dialed this number from my mobile and the IVR working so I'm sure there's something wrong with my system.
thanks in advance.
06-18-2017 05:48 AM
how you are using ur setup
can you running config of gw
07-02-2017 08:05 AM
Change the following on your dial-peers:
dtmf-relay sip-notify rtp-nte
to:
dtmf-relay rtp-nte sip-kpml
06-18-2017 07:06 AM
So, you have issues with DTMF recognition, you need to give us more details. Please describe the call flow listing all components, i.e.
mobile phone --> Cisco GW/CUBE --> SIP/H323/MGCP --> CUCM --> IVR (what is the IVR platform), etc.
then provide "show run" from your GW/CUBE along with number being dialed, we will then prompt for additional debug commands once we understand protocols involved.
07-01-2017 04:32 PM
08-05-2017 09:14 AM
I am facing the same kind of issue once dial outside some other company IVR; not accepting digits.
Call flow : Cisco SIP phone -> cucm --> SIP --> CUBE --> SIPTrunk --> ITSP --> IVR
- When i uncheck "MTP required" option in cucm sip trunk , incoming call on CUC AutoAttendant and then transfer to end user on DID or NonDID number fails. But, dialing to any other company IVR works well.
- When i check "MTP required" option and select g711alaw on CUCM sip trunk, incoming call on CUC works but dialing to any other company IVR don't accept digits.
Run config as attached
