08-04-2017 03:16 PM - edited 03-17-2019 10:57 AM
hello all my Cisco peps
We have a client with 4 pots lines from the carrier.
The carrier is moving to sip and the client does not want to buy a new phone system.
They have 4 inbound pots lines from the carrier.
I have set up a 2801 voice router and have 4 fxs ports.
I have the sip trunk up for inbound calls.
I cannot place outbound calls from the POTS FXS port.
I will be using the 2801 to do sip to pots lines hand off into the phone system.
Could someone help me with outbound calling on the fxs to the sip provider?
08-04-2017 04:05 PM
Take the analog out for a minute.
1. Can you place SIP calls to your ITSP?
2. Have you run a DNA to make sure the call is getting out of UCM and to your CUBEs or router?
08-04-2017 04:19 PM
This is a sip to POTS hand off. I am not able to make out bound call to the trunk provider. I can make inbound calls.
here is my dial peer config
dial-peer voice 100 pots
description INBOUND TO ANALONG PORT 0
destination-pattern .
port 0/1/0
forward-digits 0
dial-peer voice 1 voip
description **CCA*North American*10-Digit Local**
destination-pattern ..........
progress_ind setup enable 3
session protocol sipv2
session target ipv4:216.82.224.202
voice-class codec 1
dtmf-relay rtp-nte
clid network-number xxx-xxx-xxxx
no vad
