08-27-2010 11:39 AM - edited 03-16-2019 12:30 AM
is there any easy way to search for all phone numbers that are assigned to a specific calling search space? I don't care if it's through a search or an export, I just need to verify what numbers are assigned to a particular calling search space
thanks
-Brian
Solved! Go to Solution.
08-28-2010 09:52 PM
Under related links, you can chose Dependancy Records. This will provide a list of DNs or patterns that
are associated with this CSS.
08-27-2010 12:09 PM
You can do an export all details using BAT and then just order by the CSS field in a spreadsheet editor.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
08-30-2010 05:34 AM
could you be a little more specific? on the 'bulk administration' tab, I didn't know where to go from there. Just to be clear I have phones profiles in CSS, ext. mobility profiles with lines in CSS, and phones with assigned lines in CSS.
08-27-2010 02:23 PM
Brian,
Just to confirm, you're interested to find directory numbers with a partiticular Calling Search Space assigned at the line/DN, not a list of DN/Partitions that are contained within a particular CSS.
If it is the former, the following sql query can be used to find DNs that have been assigned to CSS
run sql select dnorpattern from numplan n, callingsearchspace c where n.fkcallingsearchspace_sharedlineappear = c.pkid and c.name = '
This query should work in 6.x and above. You can change the name to match the CSS name of interest and give it a shot.
-jt
08-30-2010 05:43 AM
right, all directory numbers with a particular CSS
I have never issued sql commands to call manager, to do that, do I need to install a plugin? "application"-->"plugins" ?
08-30-2010 08:01 AM
Just connect to the server via SSH using Putty or a similar client, and paste in the 'run sql ...' line as a command. Set Putty to log printable output to a text file, and you can then import the text to Excel as a .tsv file for further manipulation.
Aaron
Please rate helpful posts...
08-28-2010 09:52 PM
