Callmanager 7 search
brianschaefer
is there any easy way to search for all phone numbers that are assigned to a specific calling search space? I don't care if it's through a search or an export, I just need to verify what numbers are assigned to a particular calling search space
thanks
-Brian
lfulgenzi
Level 7
Level 7
Under related links, you can chose Dependancy Records. This will provide a list of DNs or patterns that
are associated with this CSS.
6 Replies 6
Jaime Valencia
You can do an export all details using BAT and then just order by the CSS field in a spreadsheet editor.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
could you be a little more specific? on the 'bulk administration' tab, I didn't know where to go from there. Just to be clear I have phones profiles in CSS, ext. mobility profiles with lines in CSS, and phones with assigned lines in CSS.
jtesar
Brian,
Just to confirm, you're interested to find directory numbers with a partiticular Calling Search Space assigned at the line/DN, not a list of DN/Partitions that are contained within a particular CSS.
If it is the former, the following sql query can be used to find DNs that have been assigned to CSS :
run sql select dnorpattern from numplan n, callingsearchspace c where n.fkcallingsearchspace_sharedlineappear = c.pkid and c.name = ''
This query should work in 6.x and above.  You can change the name to match the CSS name of interest and give it a shot.
-jt
right, all directory numbers with a particular CSS
I have never issued sql commands to call manager, to do that, do I need to install a plugin? "application"-->"plugins" ?
Just connect to the server via SSH using Putty or a similar client, and paste in the 'run sql ...' line as a command. Set Putty to log printable output to a text file, and you can then import the text to Excel as a .tsv file for further manipulation.
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
lfulgenzi
Level 7
Level 7
