02-05-2010 12:44 PM - edited 03-15-2019 09:20 PM
Hi Experts,
I’m having a big and rare issue.
When calling to some phones (like 2797901, 2797956, 2797978) from outside to inside the company, most of the calls connect ok, but some of them (like 20%) they just don’t have audio (neither I can listen something, nor the user on the other side).
What its pretty rare, is that it not only looks to be at random, but also, that if the guy at the opposite side of the phone push the buttons of the iphone, u can listen that sound clearly. :S
The voice gateway is a Cisco 2621XM using c2600-is-mz.122-8.T10
I’m adding the run config, and some outputus I took of the “sh voice call summary” and “sh voice call” while I was having the issue. My call is on the port 1/0:0.2 but I been checking and it also happens on other ports (like 1/0:0.5)
We are using teh controller E1 1/0, for those lines.
I’d been trying to figurate out the problem for a long time, but I don’t know to much about voice.
Please any help will be appreciated.
02-05-2010 02:07 PM
It sounds like a codec mismatch of some kind. The fact that you can hear the DTMF tone when the far-end presses a button isn't very suprising; It just means that the DTMF tones are being carried out-of-band and re-created on the far end. What kind of IP handsets are you using? If you are using a Cisco IP Phone, you can press the help button (it has a ? on it) twice during a call to see info about that call. It should tell you what codec the phone is sending, and what it thinks it's recieving, and how many packets are coming through.
02-05-2010 03:52 PM
Thanks for the response.
Here is the data from a call that its ok
RX Type: G.711u TX Type:G.711u
RX Size: 20ms TX Size:20ms
Avg Jtr: 1 Max Jtr: 12
Rx Dics 0000 Rx Lost: 0000
MOS LQK: 4.5000
Media MOS LQK: 4.4924
Min MOS LQK: 4.3828
Max MOS LQK: 4.5000
Version MOS LQK: 0.95
And here is the data from a failed call
Avg Jtr: 1 Max Jtr: 33
Rx Dics 0000 Rx Lost: 0001
MOS LQK: 4.5000
Media MOS LQK: 4.2163
Min MOS LQK: 2.7338
Max MOS LQK: 4.5000
02-05-2010 02:16 PM
If you reload the router, does it happen again ?
02-08-2010 08:21 AM
Does a reload should help?
I reload the router, without any change.
02-08-2010 10:51 AM
03-02-2010 03:46 PM
Looks we are hitting bug CSCdx66463. But can be fixed due to the devide is too old.
03-03-2010 12:28 AM
It is most likely a security issue
If you have a firewall, check that you have all RTP ports opened
If a call hit a closed port,no RTP will be passed
If it hit an opened port,RTP will be passed successfully
So you are finding this random behaviour
Wish this be helpful
