11-09-2012 08:28 AM - edited 03-16-2019 02:06 PM
Hi all,
I have a Cisco Unity Express that have actually 8 ports, our Branch office grew up so we want The cue to catch more calls, but not buying anything for now.
This is what I have:
mail> show hardware
mail uptime is 2 weeks, 1 days, 0 hours, 14 minutes
CPU Model: Pentium III (Coppermine)
CPU Speed (MHz): 498.823
CPU Cache (KByte): 256
BogoMIPS: 985.08
SKU: Unavailable
Chassis Type: C3845
Chassis Serial: FTX
Module Type: NM
Module Serial: FOC
UDI Description: Cisco 2600/3700/ISR Module
Disk Drive: 40GB
SDRAM (MByte): 256
mail> show software lic
Installed license files:
- voicemail_lic.sig : 100 MAILBOX LICENSE
Core:
- Application mode: CCM
- Total usable system ports: 8
Voicemail/Auto Attendant:
- Max system mailbox capacity time: 6000
- Default # of general delivery mailboxes: 20
- Default # of personal mailboxes: 100
- Max # of configurable mailboxes: 120
Interactive Voice Response:
- Max # of IVR sessions: Not Available
Languages:
- Max installed languages: 1
- Max enabled languages: 1
I wanted to know if my cue could actually handle 16 ports with 256 RAM, and how incrment that number.
can it support it?
Ca I chage the 256 ram to 512 ram and then reupload the licences?
either way, I'm new on this, so I don't know how can do both things, I've found some links ont he internet.
http://www.cisco.com/en/US/docs/routers/access/2600/hardware/installation/notes/nmcuupgr.pdf (chage memory)
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_tech_note09186a0080222cbf.shtml (upload licences)
But I'm still down know if I can do that because the compatibility to hardware or where buy the memorys or where download new CTI port licenses.
Please kindly advise me!
kind regards.
Solved! Go to Solution.
11-09-2012 08:37 AM
NM-CUE supports a maximum of 8 calls, that cannot be expanded.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel7_0/rel_notes/rel_notes.html#wp223539
11-09-2012 08:37 AM
11-09-2012 08:43 AM
Hi Paolo,
I would like to think that is the answer,
But I have another router with 16 CTI ports numbers, it is also a NM-CUE the only difference is that is has 512MB SDRAM.
Here is the data.:
mail> Show hardware
se-10-252-111-2 uptime is 14 weeks, 4 days, 16 hours, 33 minutes
CPU Speed (MHz): 498.796
BogoMIPS: 985.08
SKU: Unavailable
Chassis Type: C3845
Chassis Serial: FTX0953****
Module Type: NM
Module Serial: FOC1116****
Disk Drive: 40GB
SDRAM (MByte): 512
mail> show software licenses
- voicemail_lic.sig : 250 MAILBOX LICENSE
Core:
- Total usable system ports: 16
- Max system mailbox capacity time: 18000
- Default # of general delivery mailboxes: 25
- Default # of personal mailboxes: 250
- Max # of configurable mailboxes: 275
Languages:
I think it is all about the licenses.
regards.
11-09-2012 08:54 AM
The other module that you have is likely an NM-CUE-EC with a limit of 16 ports, even if not identified as such in the show command.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel7_0/rel_notes/rel_notes.html#wp222365
Upgrade a NM-CUE to NM-CUE-EC (if technically possible at all) is not supported by Cisco.
11-09-2012 08:55 AM
I've found this on cisco
Thats my version of my CUE, I cannot download it! :S
regards.
11-09-2012 09:05 AM
Hi Juan,
I'm going with Paolo on this one His info is most correct. +5 "P"
In the link you pasted, note the second file is for 16 Voicemail Ports
rather than 16 IVR ports. You want the Voicemail Ports I'm pretty sure.
For the Network Module, Enhanced, (NME-CUE) only
Cheers!
Rob
"And if I should fall behind
Wait for me" - Springsteen
11-09-2012 09:16 AM
Both are right.
Ports
Only the NME-CUE supports port licensing. Install one base license and from 0-8 increment licenses
for 8, 10, 12, 14, 16, 18, 20, 22 or 24 ports. The following conditions apply:
• Installing a base license will replace any existing port license.
• You can install an increment license only if your system already has a base license.
• Installing an increment license will fail if your system already has a 24-port license.
• A system can have licenses only for 8, 10, 12, 14, 16, 18, 20, 22 or 24 ports.
• Installing or removing a base license will fail if the resulting number of ports is more than the
number of IVR sessions for which you have licenses plus two (2).
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel7_0/install/upglic.pdf
I just wanted to know why same hardware (just different ammount of memory) supports different characteristics, maybe the part number has a license packed preinstalled acording its capabilities.
Time to save money for a UCCX
5 stars both.
11-10-2012 11:18 AM
For a flexible and powerful AA/IVR solution that has no limits in terms of concurrent calls, requires no server and no additional hardware, you can look into using TCL/IVR scripts on the VG, these also support VXML and more.
Thank you for the nice rating and good luck!
