10-08-2012 06:32 PM - edited 03-16-2019 01:34 PM
I have a Cisco 1861 Integrated Services Router using the voice service, with 3 VoIP phones.
At first, I made a configuration with a LAN voice 172.22.0.0/24, working everything OK.
I'm trying to make a second configuration, with a LAN voice 172.16.0.0/24 using the previous config, but this does not work.
I see how the DHCP service provides the correct IP address to each phone, but when I try to use the phone, is sounds a continous beep.
I attach the configuration config I made. May be I forgot something to execute, but as I told before, If i replace all 172.16.x.x to 172.22.x.x it works. That's driving me crazy.
Thank you.
Solved! Go to Solution.
10-09-2012 06:05 AM
Hi Alex
I´m assum that was working before with IP 172.22.x.x, right?
Anyway try reset the Phones to factory default and do a no create cnf-files and create cnf-files.
10-08-2012 07:21 PM
Hi Alex
Your question isn´t clear for me, I don´t understand your setup.
Please correct me if i´m wrong, you have a Voice network with IP 172.22.x.x/24 and is trying change that IP range to 172.16.x.x/24 right?
From your config i was unable to find the range 172.16.x.x/24, just found that 172.16.0.0/12. Check both the DHCP and Phone and confirm if the correct mask is assigned to.
If yes try change the command in the telephony-service session source ip source-address 172.16.x.1 port 2000.
I hope this help
10-09-2012 12:36 AM
Thank you for your reply. You're right, I'm trying to change the voice range from 172.22.0.0/24 to 172.16.0.0/24. Notice that the voice VLAN has no VRF. The range 172.16.0.0/12 you checked is a data range from one of the clients I have set up one VRF called green (Verde). As i told before, the phones receives the IP trhu DHCP, but can't finish the whole configuration
Well, I modified the config as I think it would be correct, I list the changes (The whole config is attached).
The last option I keep in mind is that may be have to rebuild any configuration that the IP Phones have to download.
Header 1 |
! ip dhcp pool VOICE network 172.16.0.0 255.255.255.0 default-router 172.16.0.1 domain-name Voice.com option 150 ip 172.16.0.1 ! interface FastEthernet0/0 description Interfaz MANAGEMENT ip address 1.1.1.1 255.255.255.0 secondary ip address 1.1.1.250 255.255.255.0 no ip redirects no ip proxy-arp load-interval 30 duplex auto speed auto ! interface Integrated-Service-Engine0/0 ip unnumbered FastEthernet0/0 shutdown service-module ip address 1.1.1.254 255.255.255.0 service-module ip default-gateway 1.1.1.250 ! interface FastEthernet0/1/0 description ** VoIP Ext.1** switchport access vlan 101 switchport voice vlan 75 no ip address ! interface FastEthernet0/1/1 description ** VoIP Ext.2** switchport access vlan 101 switchport voice vlan 75 no ip address ! interface FastEthernet0/1/2 description ** VoIP Ext.3** switchport access vlan 101 switchport voice vlan 75 no ip address ! interface Vlan75 description VLAN VOICE ip address 172.16.0.1 255.255.255.0 no ip redirects no ip proxy-arp load-interval 30 ! interface Vlan101 description VLAN DATA ip vrf forwarding azul ip address 10.10.10.1 255.255.255.0 no ip redirects no ip proxy-arp load-interval 30 ! ip route 1.1.1.254 255.255.255.255 Integrated-Service-Engine0/0 ! dial-peer voice 2 voip destination-pattern 2... session protocol sipv2 session target ipv4:1.1.1.254 dtmf-relay sip-notify codec g711ulaw no vad ! ! ! ! ephone-type 1 num-buttons 1 max-presentation 1 ! ! telephony-service max-ephones 6 max-dn 48 ip source-address 172.16.0.1 port 2000 system message Telefonia time-zone 2 voicemail 2000 max-conferences 4 gain -6 moh music-on-hold.au multicast moh 239.10.16.4 port 2000 web admin system name usal secret 5 $1$P9E2$SPpxQxCkMpfupefW7Fl6r. dn-webedit transfer-system full-consult ! ! ephone-dn 1 dual-line number 1101 name 1101 call-forward busy 2000 call-forward noan 2000 timeout 10 ! ! ephone-dn 2 dual-line number 1102 name 1102 call-forward busy 2000 call-forward noan 2000 timeout 10 ! ! ephone-dn 3 dual-line number 1103 name 1103 call-forward busy 2000 call-forward noan 2000 timeout 10 ! ! ephone-dn 14 number 8000.... mwi on ! ! ephone-dn 15 number 8001.... mwi off ! ! ephone 1 device-security-mode none mac-address 001D.70FC.984F max-calls-per-button 2 type 6911 button 1:1 ! ! ! ephone 2 device-security-mode none mac-address 001D.70FC.992E max-calls-per-button 2 type 6911 button 1:2 ! ! ! ephone 3 device-security-mode none mac-address 001D.70FC.98BC max-calls-per-button 2 type 6911 button 1:3 ! ! ! ephone 99 device-security-mode none description "Multicast Music On Hold" |
10-09-2012 06:05 AM
Hi Alex
10-09-2012 07:58 AM
Yes, the configuration works correcty if set 172.22.x.x as voice VLAN.
I'll try to rebuild the cnf-files, because it's the last thing i have to try.
I'm a little scared about rebuild this. Next monday I have to make a conference with the equipment, and don't want damage the actual working configuration.
Anyway, tonight i will try that. Thank you Bruno!
10-09-2012 03:34 PM
Problem solved. If I change the LAN range, i've to create the cnf files.
Thats a little bit disturbing, because my objective is to load different configs with the command
copy flash:configNEW.conf startup-config
and now I have to rebuild manually that files.
Edit: I forgot to add the command telephony-serivce > create cnf-files
Well, I had a last question, but i try to google it. sometimes when I create the cnf files, the router shows that message:
Cisco-1861VOZ(config-telephony)#create cnf-files
Creating CNF files
CNF-FILES: Clock is not set or synchronized, retaining old versionStamps
But the clock is up to date
Cisco-1861VOZ(config-telephony)#do show clock
*00:24:34.795 UTC Wed Oct 10 2012
Any ideas?
Thank you!
10-09-2012 03:57 PM
I reply to myself:
The following message:
Is due to i had no the specific clock configuration entered as configuration terminal mode.
In other words, setting up the clock is not enough, also its needed the following config:
Clock configuration |
router# config t router(config)#clock timezone ESPANA 1 0 (Spain as my country) router(config)#clock summer-time ESPANA recurring router(config)#clock calendar-valid router(config)#telephony-service (Now create the cnf files) router(config-telephony)#create cnf-files Creating CNF files router(config-telephony)# (created with no sync error!! Let's check it out) router(config-telephony)#do show run | i cnf create cnf-files version-stamp 7960 Oct 10 2012 00:45:35 router(config-telephony)# |
It's done, Bruno, so many thanks for your support!
10-09-2012 07:00 PM
Good Job Alex!!!
Thanks for the nice rating
