Can't change voice LAN on CME v8.6
Alex Deiwor
I have a Cisco 1861 Integrated Services Router using the voice service, with 3 VoIP phones.
At first, I made a  configuration with a LAN voice 172.22.0.0/24, working everything OK.
I'm trying to make a second configuration, with a LAN voice 172.16.0.0/24 using the previous config, but this does not work.
I see how the DHCP service provides the correct IP address to each phone, but when I try to use the phone, is sounds a continous beep.
I attach the configuration config I made. May be I forgot something to execute, but as I told before, If i replace all 172.16.x.x to 172.22.x.x it works. That's driving me crazy.
Thank you.
Hi Alex
I´m assum that was working before with IP 172.22.x.x, right?
Anyway try reset the Phones to factory default and do a no create cnf-files and create cnf-files.
Cheers
Bruno Rangel
Please remember to rate helpful responses using the star bellow and identify helpful or correct answers
7 Replies 7
Bruno Rangel
Hi Alex
Your question isn´t clear for me, I don´t understand your setup.
Please correct me if i´m wrong, you have a Voice network with IP 172.22.x.x/24 and is trying change that IP range to 172.16.x.x/24 right?
From your config i was unable to find the range 172.16.x.x/24, just found that 172.16.0.0/12. Check both the DHCP and Phone and confirm if the correct mask is assigned to.
If yes try change the command in the telephony-service session source ip source-address 172.16.x.1 port 2000.
I hope this help
Cheers
Bruno Rangel
Thank you for your reply. You're right, I'm trying to change the voice range from 172.22.0.0/24 to 172.16.0.0/24. Notice that the voice VLAN has no VRF. The range 172.16.0.0/12 you checked is a data range from one of the clients I have set up one VRF called green (Verde). As i told before, the phones receives the IP trhu DHCP, but can't finish the whole configuration
Well, I modified the config as I think it would be correct, I list the changes (The whole config is attached).
The last option I keep in mind is that may be have to rebuild any configuration that the IP Phones have to download.
Header 1
ip dhcp pool VOICE
network 172.16.0.0 255.255.255.0
default-router 172.16.0.1
domain-name Voice.com
option 150 ip 172.16.0.1
interface FastEthernet0/0
description Interfaz MANAGEMENT
ip address 1.1.1.1 255.255.255.0 secondary
ip address 1.1.1.250 255.255.255.0
no ip redirects
no ip proxy-arp
load-interval 30
duplex auto
speed auto
interface Integrated-Service-Engine0/0
ip unnumbered FastEthernet0/0
shutdown
service-module ip address 1.1.1.254 255.255.255.0
service-module ip default-gateway 1.1.1.250
interface FastEthernet0/1/0
description ** VoIP Ext.1**
switchport access vlan 101
switchport voice vlan 75
no ip address
interface FastEthernet0/1/1
description ** VoIP Ext.2**
no ip address
interface FastEthernet0/1/2
description ** VoIP Ext.3**
no ip address
interface Vlan75
description VLAN VOICE
ip address 172.16.0.1 255.255.255.0
no ip redirects
no ip proxy-arp
load-interval 30
interface Vlan101
description VLAN DATA
ip vrf forwarding azul
ip address 10.10.10.1 255.255.255.0
no ip redirects
no ip proxy-arp
load-interval 30
ip route 1.1.1.254 255.255.255.255 Integrated-Service-Engine0/0
dial-peer voice 2 voip
destination-pattern 2...
session protocol sipv2
session target ipv4:1.1.1.254
dtmf-relay sip-notify
codec g711ulaw
no vad
ephone-type 1
num-buttons 1
max-presentation 1
telephony-service
max-ephones 6
max-dn 48
ip source-address 172.16.0.1 port 2000
system message Telefonia
time-zone 2
voicemail 2000
max-conferences 4 gain -6
moh music-on-hold.au
multicast moh 239.10.16.4 port 2000
web admin system name usal secret 5 $1$P9E2$SPpxQxCkMpfupefW7Fl6r.
dn-webedit
transfer-system full-consult
ephone-dn  1  dual-line
number 1101
name 1101
call-forward busy 2000
call-forward noan 2000 timeout 10
ephone-dn  2  dual-line
number 1102
name 1102
ephone-dn  3  dual-line
number 1103
name 1103
ephone-dn  14
number 8000....
mwi on
ephone-dn  15
number 8001....
mwi off
ephone  1
device-security-mode none
mac-address 001D.70FC.984F
max-calls-per-button 2
type 6911
button  1:1
ephone  2
mac-address 001D.70FC.992E
type 6911
button  1:2
ephone  3
mac-address 001D.70FC.98BC
type 6911
button  1:3
ephone  99
description "Multicast Music On Hold"
Hi Alex
Cheers
Bruno Rangel
Yes, the configuration works correcty if set 172.22.x.x as voice VLAN.
I'll try to rebuild the cnf-files, because it's the last thing i have to try.
I'm a little scared about rebuild this. Next monday I have to make a conference with the equipment, and  don't want damage the actual working configuration.
Anyway, tonight i will try that. Thank you Bruno!
Problem solved. If I change the LAN range, i've to create the cnf files.
Thats a little bit disturbing, because my objective is to load different configs with the command
copy flash:configNEW.conf startup-config
and now I have to rebuild manually that files.
Edit: I forgot to add the command telephony-serivce > create cnf-files
Well, I had a last question, but i try to google it. sometimes when I create the cnf files, the router shows that message:
Cisco-1861VOZ(config-telephony)#create cnf-files
Creating CNF files
CNF-FILES: Clock is not set or synchronized, retaining old versionStamps
But the clock  is up to date
Cisco-1861VOZ(config-telephony)#do show clock
*00:24:34.795 UTC Wed Oct 10 2012
Any ideas?
Thank you!
I reply to myself:
The following message:
Is due to i had no the specific clock configuration entered as configuration terminal mode.
In other words, setting up the clock is not enough, also its needed the following config:
Clock configuration
router# config t
router(config)#clock timezone ESPANA 1 0 (Spain as my country)
router(config)#clock summer-time ESPANA recurring
router(config)#clock calendar-valid
router(config)#telephony-service (Now create the cnf files)
router(config-telephony)#create cnf-files
Creating CNF files
router(config-telephony)# (created with no sync error!! Let's check it out)
router(config-telephony)#do show run | i cnf
create cnf-files version-stamp 7960 Oct 10 2012 00:45:35
It's done, Bruno, so many thanks for your support!
Good Job Alex!!!
Thanks for the nice rating
Cheers
Bruno Rangel
