Can't dial local numbers
Pete Matheson
We have an issue with a customers system where they can't dial local numbers in the same area code as them.
Any 901256xxxxxx numbers come back with a 'Number is not recognised' message.
We have the following config:
voice translation-rule 100
rule 1 /^.*/ /0\0/ type subscriber subscriber plan isdn isdn
rule 2 /^.*/ /00\0/ type national national plan isdn isdn
rule 3 /^.*/ /000\0/ type international international plan isdn isdn
voice translation-rule 101
rule 1 /^3934/ /4/
rule 2 /^7047/ /7/
voice translation-rule 102
rule 1 /^4\(.*\)/ /3934\1/ type any subscriber plan any isdn
rule 2 /^7\(.*\)/ /7047\1/ type any subscriber plan any isdn
voice translation-rule 103
rule 1 /^900\(.*\)/ /\1/ type unknown international plan any isdn
rule 2 /^90\(.*\)/ /\1/ type unknown national plan any isdn
rule 3 /^9\(.*\)/ /\1/ type unknown subscriber plan any isdn
voice translation-profile standard_incoming
translate calling 100
translate called 101
voice translation-profile standard_outgoing
translate calling 102
translate called 103
voice-port 0/0/0:15
translation-profile incoming standard_incoming
translation-profile outgoing standard_outgoing
cptone GB
dial-peer voice 1 pots
description ** Out TDM **
destination-pattern 9T
progress_ind setup enable 3
progress_ind alert enable 8
port 0/0/0:15
dial-peer voice 10 pots
description ** In TDM **
incoming called-number .
direct-inward-dial
dial-peer voice 11 voip
description ** In VoIP **
voice-class codec 1
dtmf-relay h245-alphanumeric
Pete,
Yes it is the rule..
The 103 is stripping off 90...
I believe this profile is for prefixing digits for missed calls..You should be applying it on the calling number not called
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
14 Replies 14
Ayodeji Okanlawon
Pete can you send a debug isdn q931 and debug voip ccapi inout
Apr 11 10:52:36.896: //-1/C1A844A5996F/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=447
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Apr 11 10:52:36.896: //-1/C1A844A5996F/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x49DE632C, Call Info(
   Calling Number=447,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
   Incoming Dial-peer=20018, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Apr 11 10:52:36.900: //-1/C1A844A5996F/CCAPI/ccCheckClipClir:
   In: Calling Number=447(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=447(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Apr 11 10:52:36.900: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr 11 10:52:36.900: :cc_get_feature_vsa malloc success
Apr 11 10:52:36.900:  cc_get_feature_vsa count is 3
Apr 11 10:52:36.900: :FEATURE_VSA attributes are: feature_name:0,feature_time:1185844616,feature_id:4146
Apr 11 10:52:36.900: //2263/C1A844A5996F/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=447(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown))
Apr 11 10:52:36.900: //2263/C1A844A5996F/CCAPI/cc_process_call_setup_ind:
   Event=0x483BAFE8
Apr 11 10:52:36.900: //2263/C1A844A5996F/CCAPI/ccCallSetContext:
   Context=0x4A386F78
   >>>>CCAPI handed cid 2263 with tag 20018 to app "_ManagedAppProcess_Default"
Apr 11 10:52:36.904: //2263/C1A844A5996F/CCAPI/ccCallSetupAck:
   Call Id=2263
Apr 11 10:52:36.904: //2263/C1A844A5996F/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
Apr 11 10:52:36.904: //2263/C1A844A5996F/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=TRUE, Tone=Dial Tone,
   Tone Direction=Network, Params=0x0, Call Id=2263
Apr 11 10:52:36.904: //2263/C1A844A5996F/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
   Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
Apr 11 10:52:36.904: //2263/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0x8D7, digit_event=0x1, enable=TRUE, consume=FALSE)
Apr 11 10:52:36.904: //2263/C1A844A5996F/CCAPI/ccCallReportDigits:
   Enabled=TRUE, Call Id=2263
Apr 11 10:52:36.904: //2263/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x49DE632C, callID=0x8D7, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Apr 11 10:52:36.904: //2263/C1A844A5996F/CCAPI/cc_api_call_report_digits_done:
   Enabled=TRUE, Disposition=0x0, Interface=0x49DE632C, Call Id=2263
   Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=4000(ms))
Apr 11 10:52:37.280: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_begin:
   Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
   Source Call Id=2263, Digit=9, DigitBeginFlags=0x0,
   Rtp Timestamp=0xF8AC28, Rtp Expiration=0x0
Apr 11 10:52:37.280: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_end:
   Source Call Id=2263, Digit=9, Duration=100,
   Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
   Call Entry(Handoff Depth=0)
Apr 11 10:52:37.444: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_begin:
   Source Call Id=2263, Digit=0, DigitBeginFlags=0x0,
   Rtp Timestamp=0xF92928, Rtp Expiration=0x0
Apr 11 10:52:37.444: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_end:
   Source Call Id=2263, Digit=0, Duration=100,
Apr 11 10:52:37.600: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_begin:
   Source Call Id=2263, Digit=2, DigitBeginFlags=0x0,
   Rtp Timestamp=0xF9A628, Rtp Expiration=0x0
Apr 11 10:52:37.600: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_end:
   Source Call Id=2263, Digit=2, Duration=100,
Apr 11 10:52:37.760: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0xFA2328, Rtp Expiration=0x0
Apr 11 10:52:37.760: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_end:
Apr 11 10:52:37.764: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_end:
Apr 11 10:52:37.920: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_begin:
   Source Call Id=2263, Digit=7, DigitBeginFlags=0x0,
   Rtp Timestamp=0xFAA028, Rtp Expiration=0x0
Apr 11 10:52:37.920: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_end:
   Source Call Id=2263, Digit=7, Duration=100,
Apr 11 10:52:38.096: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0xFB1D28, Rtp Expiration=0x0
Apr 11 10:52:38.096: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_end:
Apr 11 10:52:38.260: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0xFB9A28, Rtp Expiration=0x0
Apr 11 10:52:38.260: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_end:
Apr 11 10:52:38.420: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0xFC1728, Rtp Expiration=0x0
Apr 11 10:52:38.424: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_end:
Apr 11 10:52:38.580: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0xFC9428, Rtp Expiration=0x0
Apr 11 10:52:38.580: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_end:
Apr 11 10:52:38.744: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_begin:
   Source Call Id=2263, Digit=3, DigitBeginFlags=0x0,
   Rtp Timestamp=0xFD1128, Rtp Expiration=0x0
Apr 11 10:52:38.744: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_end:
   Source Call Id=2263, Digit=3, Duration=100,
Apr 11 10:52:38.900: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0xFD8E28, Rtp Expiration=0x0
Apr 11 10:52:38.900: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_end:
Apr 11 10:52:39.060: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0xFE0B28, Rtp Expiration=0x0
Apr 11 10:52:39.060: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_end:
Apr 11 10:52:39.064: //2263/C1A844A5996F/CCAPI/cc_api_call_digit_end:
Apr 11 10:52:40.860: //-1/C405269B9973/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=449
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Apr 11 10:52:40.864: //-1/C405269B9973/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x49E786A4, Call Info(
   Calling Number=449,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Incoming Dial-peer=20020, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Apr 11 10:52:40.864: //-1/C405269B9973/CCAPI/ccCheckClipClir:
   In: Calling Number=449(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=449(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Apr 11 10:52:40.864: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr 11 10:52:40.864: :cc_get_feature_vsa malloc success
Apr 11 10:52:40.864:  cc_get_feature_vsa count is 4
Apr 11 10:52:40.864: :FEATURE_VSA attributes are: feature_name:0,feature_time:1185844392,feature_id:4147
Apr 11 10:52:40.864: //2264/C405269B9973/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=449(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Apr 11 10:52:40.864: //2264/C405269B9973/CCAPI/cc_process_call_setup_ind:
   Event=0x483BAFE8
Apr 11 10:52:40.864: //2264/C405269B9973/CCAPI/ccCallSetContext:
   Context=0x4A382358
   >>>>CCAPI handed cid 2264 with tag 20020 to app "_ManagedAppProcess_Default"
Apr 11 10:52:40.868: //2264/C405269B9973/CCAPI/ccCallSetupAck:
   Call Id=2264
Apr 11 10:52:40.868: //2264/C405269B9973/CCAPI/cc_api_set_transfer_info:
Apr 11 10:52:40.868: //2264/C405269B9973/CCAPI/ccGenerateToneInfo:
   Tone Direction=Network, Params=0x0, Call Id=2264
Apr 11 10:52:40.868: //2264/C405269B9973/CCAPI/ccSetDigitTimeouts:
Apr 11 10:52:40.868: //2264/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0x8D8, digit_event=0x1, enable=TRUE, consume=FALSE)
Apr 11 10:52:40.868: //2264/C405269B9973/CCAPI/ccCallReportDigits:
   Enabled=TRUE, Call Id=2264
Apr 11 10:52:40.868: //2264/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x49E786A4, callID=0x8D8, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Apr 11 10:52:40.868: //2264/C405269B9973/CCAPI/cc_api_call_report_digits_done:
   Enabled=TRUE, Disposition=0x0, Interface=0x49E786A4, Call Id=2264
Apr 11 10:52:41.832: //2264/C405269B9973/CCAPI/cc_api_call_digit_begin:
   Source Call Id=2264, Digit=9, DigitBeginFlags=0x0,
   Rtp Timestamp=0x589F80, Rtp Expiration=0x0
Apr 11 10:52:41.832: //2264/C405269B9973/CCAPI/cc_api_call_digit_end:
   Source Call Id=2264, Digit=9, Duration=100,
Apr 11 10:52:42.032: //2264/C405269B9973/CCAPI/cc_api_call_digit_begin:
   Source Call Id=2264, Digit=0, DigitBeginFlags=0x0,
   Rtp Timestamp=0x591C80, Rtp Expiration=0x0
Apr 11 10:52:42.032: //2264/C405269B9973/CCAPI/cc_api_call_digit_end:
   Source Call Id=2264, Digit=0, Duration=100,
Apr 11 10:52:42.232: //2264/C405269B9973/CCAPI/cc_api_call_digit_begin:
   Source Call Id=2264, Digit=1, DigitBeginFlags=0x0,
   Rtp Timestamp=0x599980, Rtp Expiration=0x0
Apr 11 10:52:42.232: //2264/C405269B9973/CCAPI/cc_api_call_digit_end:
   Source Call Id=2264, Digit=1, Duration=100,
Apr 11 10:52:42.432: //2264/C405269B9973/CCAPI/cc_api_call_digit_begin:
   Source Call Id=2264, Digit=2, DigitBeginFlags=0x0,
   Rtp Timestamp=0x5A1680, Rtp Expiration=0x0
Apr 11 10:52:42.432: //2264/C405269B9973/CCAPI/cc_api_call_digit_end:
   Source Call Id=2264, Digit=2, Duration=100,
Apr 11 10:52:42.632: //2264/C405269B9973/CCAPI/cc_api_call_digit_begin:
   Source Call Id=2264, Digit=5, DigitBeginFlags=0x0,
   Rtp Timestamp=0x5A9380, Rtp Expiration=0x0
Apr 11 10:52:42.632: //2264/C405269B9973/CCAPI/cc_api_call_digit_end:
   Source Call Id=2264, Digit=5, Duration=100,
Apr 11 10:52:42.832: //2264/C405269B9973/CCAPI/cc_api_call_digit_begin:
   Source Call Id=2264, Digit=6, DigitBeginFlags=0x0,
   Rtp Timestamp=0x5B1080, Rtp Expiration=0x0
Apr 11 10:52:42.832: //2264/C405269B9973/CCAPI/cc_api_call_digit_end:
   Source Call Id=2264, Digit=6, Duration=100,
Apr 11 10:52:43.032: //2264/C405269B9973/CCAPI/cc_api_call_digit_begin:
   Source Call Id=2264, Digit=7, DigitBeginFlags=0x0,
   Rtp Timestamp=0x5B8D80, Rtp Expiration=0x0
Apr 11 10:52:43.032: //2264/C405269B9973/CCAPI/cc_api_call_digit_end:
   Source Call Id=2264, Digit=7, Duration=100,
Apr 11 10:52:43.064: //2263/C1A844A5996F/CCAPI/cc_handle_inter_digit_timer:
   Generate inter-digit timeout CC_EV_CALL_DIGIT_END event
Apr 11 10:52:43.064: //2263/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0x8D7, digit_event=0x0, enable=FALSE, consume=FALSE)
Apr 11 10:52:43.064: //2263/C1A844A5996F/CCAPI/ccCallReportDigits:
Apr 11 10:52:43.064: //2263/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x49DE632C, callID=0x8D7, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Apr 11 10:52:43.064: //2263/C1A844A5996F/CCAPI/cc_api_call_report_digits_done:
Apr 11 10:52:43.064: //2263/C1A844A5996F/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
Apr 11 10:52:43.068: //2263/C1A844A5996F/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=1, Params=0x4A3895D8, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Apr 11 10:52:43.068: //2263/C1A844A5996F/CCAPI/ccCheckClipClir:
   In: Calling Number=393447(TON=Subscriber, NPI=ISDN, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=393447(TON=Subscriber, NPI=ISDN, Screening=Not Screened, Presentation=Allowed)
   Destination Pattern=9T, Called Number=2079022320, Digit Strip=TRUE
   Calling Number=393447(TON=Subscriber, NPI=ISDN, Screening=Not Screened, Presentation=Allowed),
   Called Number=2079022320(TON=National, NPI=ISDN),
   Redirect Number=, Display Info=Pamela Vaughan
   Account Number=, Final Destination Flag=FALSE,
   Guid=C1A844A5-A1CC-11E2-996F-9D10B6883F86, Outgoing Dial-peer=1
Apr 11 10:52:43.068: //2263/C1A844A5996F/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=393447
   cisco-anitype=4
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=0
   dest=2079022320
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Apr 11 10:52:43.068: //2263/C1A844A5996F/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x48402CE4, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=393447,(Calling Name=Pamela Vaughan)(TON=Subscriber, NPI=ISDN, Screening=Not Screened, Presentation=Allowed),
   Called Number=2079022320(TON=National, NPI=ISDN), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=1, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Apr 11 10:52:43.068: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr 11 10:52:43.068: :cc_get_feature_vsa malloc success
Apr 11 10:52:43.068:  cc_get_feature_vsa count is 5
Apr 11 10:52:43.068: :FEATURE_VSA attributes are: feature_name:0,feature_time:1185844168,feature_id:4148
Apr 11 10:52:43.068: //2265/C1A844A5996F/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Apr 11 10:52:43.068: //2265/C1A844A5996F/CCAPI/ccCallSetContext:
   Context=0x4A389588
Apr 11 10:52:43.068: //2263/C1A844A5996F/CCAPI/ccSaveDialpeerTag:
Apr 11 10:52:43.072: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x4 0x1, Calling num 393447
Apr 11 10:52:43.076: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x01DB callID = 0x815C switch = primary-net5 interface = User
Apr 11 10:52:43.076: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x01DB
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98382
Exclusive, Channel 2
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x4180, '393447'
Plan:ISDN, Type:Subscriber(local)
Called Party Number i = 0xA1, '2079022320'
Plan:ISDN, Type:National
Apr 11 10:52:43.232: //2264/C405269B9973/CCAPI/cc_api_call_digit_begin:
   Source Call Id=2264, Digit=8, DigitBeginFlags=0x0,
   Rtp Timestamp=0x5C0A80, Rtp Expiration=0x0
Apr 11 10:52:43.232: //2264/C405269B9973/CCAPI/cc_api_call_digit_end:
   Source Call Id=2264, Digit=8, Duration=100,
Apr 11 10:52:43.316: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0x81DB
Progress Ind i = 0x8288 - In-band info or appropriate now available
Apr 11 10:52:43.320: //2265/C1A844A5996F/CCAPI/cc_api_call_cut_progress:
   Interface=0x48402CE4, Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2),
   Cause Value=0
   Call Entry(Responsed=TRUE)
Apr 11 10:52:43.320: //2263/C1A844A5996F/CCAPI/ccCallCutProgress:
   Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=0
   Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
Apr 11 10:52:43.320: //2263/C1A844A5996F/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
Apr 11 10:52:43.320: //2263/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x4A44C654, callID1=0x8D7, callID2=0x8D9, tag=0x0)
   (confID=0x4A44C654, callID1=0x8D7, gcid=C1A844A5-A1CC11E2-996F9D10-B6883F86, tag=0x0)
Apr 11 10:52:43.320: //2265/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x4A44C654, callID2=0x8D9, gcid=C1A844A5-A1CC11E2-996F9D10-B6883F86, tag=0x0)
Apr 11 10:52:43.320: //2263/C1A844A5996F/CCAPI/ccConferenceCreate:
   Conference Id=0x4A44C654, Call Id1=2263, Call Id2=2265, Tag=0x0
Apr 11 10:52:43.320: //2263/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x317, Source Interface=0x49DE632C, Source Call Id=2263,
   Destination Call Id=2265, Disposition=0x0, Tag=0xFFFFFFFF
Apr 11 10:52:43.324: //2265/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x317, Source Interface=0x48402CE4, Source Call Id=2265,
   Destination Call Id=2263, Disposition=0x0, Tag=0xFFFFFFFF
Apr 11 10:52:43.324: //2263/C1A844A5996F/CCAPI/cc_generic_bridge_done:
Apr 11 10:52:43.324: //2263/C1A844A5996F/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x317, Destination Call Id=2265)
Apr 11 10:52:43.324: //2265/C1A844A5996F/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x317, Destination Call Id=2263)
Apr 11 10:52:43.324: //2263/C1A844A5996F/CCAPI/cc_api_caps_ind:
   Destination Interface=0x48402CE4, Destination Call Id=2265, Source Call Id=2263,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x1,
   Modem=0x2, Codec Bytes=160, Signal Type=2)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
Apr 11 10:52:43.324: //2265/C1A844A5996F/CCAPI/cc_api_caps_ind:
   Destination Interface=0x49DE632C, Destination Call Id=2263, Source Call Id=2265,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
Apr 11 10:52:43.324: //2265/C1A844A5996F/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=7922)
Apr 11 10:52:43.324: //2263/C1A844A5996F/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_NONE(0x1), Vad=OFF(0x1),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=1709)
Apr 11 10:52:43.324: //2263/C1A844A5996F/CCAPI/cc_api_voice_mode_event:
   Call Id=2263
   Call Entry(Context=0x4A386F78)
Apr 11 10:52:43.328: //2263/C1A844A5996F/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x317, Call Id1=2263, Call Id2=2265
Apr 11 10:52:43.328: //2263/C1A844A5996F/CCAPI/ccCallFeature:
   Feature Type=25, Call Id=2263
Apr 11 10:52:43.328: //2265/C1A844A5996F/CCAPI/cc_api_voice_mode_event:
   Call Id=2265
   Call Entry(Context=0x4A389588)
Apr 11 10:52:43.432: //2264/C405269B9973/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0x5C8780, Rtp Expiration=0x0
Apr 11 10:52:43.432: //2264/C405269B9973/CCAPI/cc_api_call_digit_end:
Apr 11 10:52:43.632: //2264/C405269B9973/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0x5D0480, Rtp Expiration=0x0
Apr 11 10:52:43.632: //2264/C405269B9973/CCAPI/cc_api_call_digit_end:
Apr 11 10:52:43.809: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x81DB
Apr 11 10:52:43.813: //2265/C1A844A5996F/CCAPI/cc_api_call_proceeding:
   Interface=0x48402CE4, Progress Indication=NULL(0)
Apr 11 10:52:43.833: //2264/C405269B9973/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0x5D8180, Rtp Expiration=0x0
Apr 11 10:52:43.833: //2264/C405269B9973/CCAPI/cc_api_call_digit_end:
Apr 11 10:52:44.033: //2264/C405269B9973/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0x5DFE80, Rtp Expiration=0x0
Apr 11 10:52:44.033: //2264/C405269B9973/CCAPI/cc_api_call_digit_end:
Apr 11 10:52:44.201: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x81DB
Apr 11 10:52:44.205: //2265/C1A844A5996F/CCAPI/cc_api_call_alert:
   Interface=0x48402CE4, Progress Indication=NULL(0), Signal Indication=NOT PRESENT(255)
   Call Entry(Retry Count=0, Responsed=TRUE)
Apr 11 10:52:44.205: //2263/C1A844A5996F/CCAPI/ccCallAlert:
   Progress Indication=INBAND(8), Signal Indication=NOT PRESENT(255)
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Apr 11 10:52:48.033: //2264/C405269B9973/CCAPI/cc_handle_inter_digit_timer:
Apr 11 10:52:48.033: //2264/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0x8D8, digit_event=0x0, enable=FALSE, consume=FALSE)
Apr 11 10:52:48.033: //2264/C405269B9973/CCAPI/ccCallReportDigits:
Apr 11 10:52:48.033: //2264/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x49E786A4, callID=0x8D8, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Apr 11 10:52:48.033: //2264/C405269B9973/CCAPI/cc_api_call_report_digits_done:
Apr 11 10:52:48.033: //2264/C405269B9973/CCAPI/ccCallProceeding:
Apr 11 10:52:48.037: //2264/C405269B9973/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=1, Params=0x4A392E18, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Apr 11 10:52:48.037: //2264/C405269B9973/CCAPI/ccCheckClipClir:
   In: Calling Number=393449(TON=Subscriber, NPI=ISDN, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=393449(TON=Subscriber, NPI=ISDN, Screening=Not Screened, Presentation=Allowed)
   Destination Pattern=9T, Called Number=1256788016, Digit Strip=TRUE
   Calling Number=393449(TON=Subscriber, NPI=ISDN, Screening=Not Screened, Presentation=Allowed),
   Called Number=1256788016(TON=National, NPI=ISDN),
   Redirect Number=, Display Info=449
   Guid=C405269B-A1CC-11E2-9973-9D10B6883F86, Outgoing Dial-peer=1
Apr 11 10:52:48.037: //2264/C405269B9973/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=393449
   cisco-anitype=4
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=0
   dest=1256788016
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Apr 11 10:52:48.037: //2264/C405269B9973/CCAPI/ccIFCallSetupRequestPrivate:
   Call Params(Calling Number=393449,(Calling Name=449)(TON=Subscriber, NPI=ISDN, Screening=Not Screened, Presentation=Allowed),
   Called Number=1256788016(TON=National, NPI=ISDN), Calling Translated=FALSE,
Apr 11 10:52:48.037: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr 11 10:52:48.037: :cc_get_feature_vsa malloc success
Apr 11 10:52:48.037:  cc_get_feature_vsa count is 6
Apr 11 10:52:48.037: :FEATURE_VSA attributes are: feature_name:0,feature_time:1185843944,feature_id:4149
Apr 11 10:52:48.037: //2266/C405269B9973/CCAPI/ccIFCallSetupRequestPrivate:
Apr 11 10:52:48.037: //2266/C405269B9973/CCAPI/ccCallSetContext:
   Context=0x4A392DC8
Apr 11 10:52:48.037: //2264/C405269B9973/CCAPI/ccSaveDialpeerTag:
Apr 11 10:52:48.045: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x4 0x1, Calling num 393449
Apr 11 10:52:48.045: ISDN Se0/0/0:15 Q931: Sending SETUP  callref = 0x01DC callID = 0x815D switch = primary-net5 interface = User
Apr 11 10:52:48.045: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x01DC
Standard = CCITT
Channel ID i = 0xA98383
Exclusive, Channel 3
Calling Party Number i = 0x4180, '393449'
Called Party Number i = 0xA1, '1256788016'
Apr 11 10:52:48.313: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x81DC
Apr 11 10:52:48.317: //2266/C405269B9973/CCAPI/cc_api_call_proceeding:
Apr 11 10:52:49.689: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x81DC
Cause i = 0x8281 - Unallocated/unassigned number
Apr 11 10:52:49.689: ISDN Se0/0/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x815D
Apr 11 10:52:49.689: //2266/C405269B9973/CCAPI/cc_api_call_disc_prog_ind:
   Cause Value=1, Progress Indication=INBAND(8), Interface=0x48402CE4
   Event(Progress Indication=0x8), Call Entry(Responsed=TRUE)
Apr 11 10:52:49.689: //2264/C405269B9973/CCAPI/ccCallDiscProgInd:
   Call Entry(Responsed=TRUE, Disconnect Cause=1)
Apr 11 10:52:49.689: //2264/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x4A44C5C4, callID1=0x8D8, callID2=0x8DA, tag=0x0)
   (confID=0x4A44C5C4, callID1=0x8D8, gcid=C405269B-A1CC11E2-99739D10-B6883F86, tag=0x0)
Apr 11 10:52:49.689: //2266/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x4A44C5C4, callID2=0x8DA, gcid=C405269B-A1CC11E2-99739D10-B6883F86, tag=0x0)
Apr 11 10:52:49.689: //2264/C405269B9973/CCAPI/ccConferenceCreate:
   Conference Id=0x4A44C5C4, Call Id1=2264, Call Id2=2266, Tag=0x0
Apr 11 10:52:49.693: //2264/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x318, Source Interface=0x49E786A4, Source Call Id=2264,
   Destination Call Id=2266, Disposition=0x0, Tag=0xFFFFFFFF
Apr 11 10:52:49.693: //2266/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x318, Source Interface=0x48402CE4, Source Call Id=2266,
   Destination Call Id=2264, Disposition=0x0, Tag=0xFFFFFFFF
Apr 11 10:52:49.693: //2264/C405269B9973/CCAPI/cc_generic_bridge_done:
Apr 11 10:52:49.693: //2264/C405269B9973/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x318, Destination Call Id=2266)
Apr 11 10:52:49.693: //2266/C405269B9973/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x318, Destination Call Id=2264)
Apr 11 10:52:49.693: //2264/C405269B9973/CCAPI/cc_api_caps_ind:
   Destination Interface=0x48402CE4, Destination Call Id=2266, Source Call Id=2264,
Apr 11 10:52:49.693: //2266/C405269B9973/CCAPI/cc_api_caps_ind:
   Destination Interface=0x49E786A4, Destination Call Id=2264, Source Call Id=2266,
Apr 11 10:52:49.693: //2266/C405269B9973/CCAPI/cc_api_caps_ack:
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=4219)
Apr 11 10:52:49.693: //2264/C405269B9973/CCAPI/cc_api_caps_ack:
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=2071)
Apr 11 10:52:49.693: //2264/C405269B9973/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x318, Call Id1=2264, Call Id2=2266
Apr 11 10:52:49.693: //2264/C405269B9973/CCAPI/cc_api_voice_mode_event:
   Call Id=2264
Apr 11 10:52:49.697: //2264/C405269B9973/CCAPI/cc_api_voice_mode_event:
   Call Entry(Context=0x4A382358)
Apr 11 10:52:49.697: //2264/C405269B9973/CCAPI/ccCallFeature:
   Feature Type=25, Call Id=2264
Apr 11 10:52:49.701: //2266/C405269B9973/CCAPI/cc_api_voice_mode_event:
   Call Id=2266
   Call Entry(Context=0x4A392DC8)
Apr 11 10:52:51.373: //-1/CA49386D9979/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=455
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Apr 11 10:52:51.373: //-1/CA49386D9979/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x49EDD59C, Call Info(
   Calling Number=455,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Incoming Dial-peer=20026, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Apr 11 10:52:51.373: //-1/CA49386D9979/CCAPI/ccCheckClipClir:
   In: Calling Number=455(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=455(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Apr 11 10:52:51.373: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr 11 10:52:51.373: :cc_get_feature_vsa malloc success
Apr 11 10:52:51.373:  cc_get_feature_vsa count is 7
Apr 11 10:52:51.373: :FEATURE_VSA attributes are: feature_name:0,feature_time:1185843720,feature_id:4150
Apr 11 10:52:51.377: //2267/CA49386D9979/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=455(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Apr 11 10:52:51.377: //2267/CA49386D9979/CCAPI/cc_process_call_setup_ind:
   Event=0x483BAFE8
Apr 11 10:52:51.377: //2267/CA49386D9979/CCAPI/ccCallSetContext:
   Context=0x4A3966E0
   >>>>CCAPI handed cid 2267 with tag 20026 to app "_ManagedAppProcess_Default"
Apr 11 10:52:51.381: //2267/CA49386D9979/CCAPI/ccCallSetupAck:
   Call Id=2267
Apr 11 10:52:51.381: //2267/CA49386D9979/CCAPI/cc_api_set_transfer_info:
Apr 11 10:52:51.381: //2267/CA49386D9979/CCAPI/ccGenerateToneInfo:
   Tone Direction=Network, Params=0x0, Call Id=2267
Apr 11 10:52:51.381: //2267/CA49386D9979/CCAPI/ccSetDigitTimeouts:
Apr 11 10:52:51.381: //2267/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0x8DB, digit_event=0x1, enable=TRUE, consume=FALSE)
Apr 11 10:52:51.381: //2267/CA49386D9979/CCAPI/ccCallReportDigits:
   Enabled=TRUE, Call Id=2267
Apr 11 10:52:51.381: //2267/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x49EDD59C, callID=0x8DB, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Apr 11 10:52:51.381: //2267/CA49386D9979/CCAPI/cc_api_call_report_digits_done:
   Enabled=TRUE, Disposition=0x0, Interface=0x49EDD59C, Call Id=2267
Apr 11 10:52:52.493: //2267/CA49386D9979/CCAPI/cc_api_call_digit_begin:
   Source Call Id=2267, Digit=4, DigitBeginFlags=0x0,
   Rtp Timestamp=0x13ADD78, Rtp Expiration=0x0
Apr 11 10:52:52.493: //2267/CA49386D9979/CCAPI/cc_api_call_digit_end:
   Source Call Id=2267, Digit=4, Duration=100,
Apr 11 10:52:52.493: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x81DB
Apr 11 10:52:52.505: %ISDN-6-CONNECT: Interface Serial0/0/0:1 is now connected to 2079022320 N/A
Apr 11 10:52:52.505: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x01DB
Apr 11 10:52:52.509: //2267/CA49386D9979/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0x13B5A78, Rtp Expiration=0x0
Apr 11 10:52:52.509: //2267/CA49386D9979/CCAPI/cc_api_call_digit_end:
   Source Call Id=2267, Digit=5, DigitBeginFlags=0x0,
   Rtp Timestamp=0x13BD778, Rtp Expiration=0x0
   Source Call Id=2267, Digit=5, Duration=100,
Apr 11 10:52:52.513: //2267/CA49386D9979/CCAPI/cc_api_call_digit_end:
Apr 11 10:52:52.513: //2265/C1A844A5996F/CCAPI/cc_api_call_connected:
   Interface=0x48402CE4, Data Bitmask=0x1, Progress Indication=NULL(0),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Apr 11 10:52:52.521: //2267/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0x8DB, digit_event=0x0, enable=FALSE, consume=FALSE)
Apr 11 10:52:52.521: //2267/CA49386D9979/CCAPI/ccCallReportDigits:
Apr 11 10:52:52.521: //2267/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x49EDD59C, callID=0x8DB, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Apr 11 10:52:52.521: //2267/CA49386D9979/CCAPI/cc_api_call_report_digits_done:
Apr 11 10:52:52.521: //2263/C1A844A5996F/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x1
   Call Entry(Connected=TRUE, Responsed=TRUE)
Apr 11 10:52:52.521: //2263/C1A844A5996F/CCAPI/ccCallFeature:
Apr 11 10:52:52.529: //2267/CA49386D9979/CCAPI/ccCallProceeding:
Apr 11 10:52:52.529: //2267/CA49386D9979/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=20016, Params=0x4A38E1F8, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Apr 11 10:52:52.529: //2267/CA49386D9979/CCAPI/ccCheckClipClir:
Apr 11 10:52:52.533: //2267/CA49386D9979/CCAPI/ccCheckClipClir:
Apr 11 10:52:52.533: //2267/CA49386D9979/CCAPI/ccCallSetupRequest:
   Destination Pattern=445$, Called Number=445, Digit Strip=TRUE
   Called Number=445(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=455
   Guid=CA49386D-A1CC-11E2-9979-9D10B6883F86, Outgoing Dial-peer=20016
Apr 11 10:52:52.533: //2267/CA49386D9979/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=455
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=445
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Apr 11 10:52:52.533: //2267/CA49386D9979/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x49DE9FF8, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=455,(Calling Name=455)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=445(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=20016, Call Count On=FALSE,
Apr 11 10:52:52.533: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr 11 10:52:52.533: :cc_get_feature_vsa malloc success
Apr 11 10:52:52.533:  cc_get_feature_vsa count is 8
Apr 11 10:52:52.533: :FEATURE_VSA attributes are: feature_name:0,feature_time:1185843496,feature_id:4151
Apr 11 10:52:52.533: //2268/CA49386D9979/CCAPI/ccIFCallSetupRequestPrivate:
Apr 11 10:52:52.533: //2268/CA49386D9979/CCAPI/ccCallSetContext:
   Context=0x4A38E1A8
Apr 11 10:52:52.533: //2267/CA49386D9979/CCAPI/ccSaveDialpeerTag:
Apr 11 10:52:52.537: //2268/CA49386D9979/CCAPI/cc_api_update_call_info:
   Interface=0x49DE9FF8, Call Id=0x8DC
Apr 11 10:52:52.541: //2268/CA49386D9979/CCAPI/cc_api_call_proceeding:
   Interface=0x49DE9FF8, Progress Indication=NULL(0)
Apr 11 10:52:52.541: //2268/CA49386D9979/CCAPI/cc_api_call_alert:
   Interface=0x49DE9FF8, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Apr 11 10:52:52.545: //2267/CA49386D9979/CCAPI/ccCallAlert:
Apr 11 10:52:52.545: //2267/CA49386D9979/CCAPI/ccCallFeature:
   Feature Type=25, Call Id=2267
Apr 11 10:52:54.693: //2268/CA49386D9979/CCAPI/cc_api_call_connected:
   Interface=0x49DE9FF8, Data Bitmask=0x1, Progress Indication=NULL(0),
   Connection Handle=0
Apr 11 10:52:54.693: //2267/CA49386D9979/CCAPI/ccGenerateToneInfo:
Apr 11 10:52:54.693: //2267/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x4A44C45C, callID1=0x8DB, callID2=0x8DC, tag=0x0)
   (confID=0x4A44C45C, callID1=0x8DB, gcid=CA49386D-A1CC11E2-99799D10-B6883F86, tag=0x0)
Apr 11 10:52:54.693: //2268/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x4A44C45C, callID2=0x8DC, gcid=CA49386D-A1CC11E2-99799D10-B6883F86, tag=0x0)
Apr 11 10:52:54.693: //2267/CA49386D9979/CCAPI/ccConferenceCreate:
   Conference Id=0x4A44C45C, Call Id1=2267, Call Id2=2268, Tag=0x0
Apr 11 10:52:54.693: //2267/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x319, Source Interface=0x49EDD59C, Source Call Id=2267,
   Destination Call Id=2268, Disposition=0x0, Tag=0xFFFFFFFF
Apr 11 10:52:54.693: //2268/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x319, Source Interface=0x49DE9FF8, Source Call Id=2268,
   Destination Call Id=2267, Disposition=0x0, Tag=0xFFFFFFFF
Apr 11 10:52:54.693: //2267/CA49386D9979/CCAPI/cc_generic_bridge_done:
Apr 11 10:52:54.697: //2267/CA49386D9979/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x319, Destination Call Id=2268)
Apr 11 10:52:54.697: //2268/CA49386D9979/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x319, Destination Call Id=2267)
Apr 11 10:52:54.697: //2267/CA49386D9979/CCAPI/cc_api_caps_ind:
   Destination Interface=0x49DE9FF8, Destination Call Id=2268, Source Call Id=2267,
Apr 11 10:52:54.697: //2268/CA49386D9979/CCAPI/cc_api_caps_ind:
   Destination Interface=0x49EDD59C, Destination Call Id=2267, Source Call Id=2268,
Apr 11 10:52:54.697: //2268/CA49386D9979/CCAPI/cc_api_caps_ack:
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=4277)
Apr 11 10:52:54.697: //2267/CA49386D9979/CCAPI/cc_api_caps_ack:
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=7644)
Apr 11 10:52:54.697: //2268/CA49386D9979/CCAPI/cc_api_voice_mode_event:
   Call Id=2268
   Call Entry(Context=0x4A38E1A8)
Apr 11 10:52:54.701: //2267/CA49386D9979/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x319, Call Id1=2267, Call Id2=2268
Apr 11 10:52:54.701: //2267/CA49386D9979/CCAPI/ccCallConnect:
Apr 11 10:52:54.705: //2267/CA49386D9979/CCAPI/ccCallFeature:
Apr 11 10:52:54.705: //2267/CA49386D9979/CCAPI/cc_api_voice_mode_event:
   Call Id=2267
   Call Entry(Context=0x4A3966E0)
Apr 11 10:52:58.829: //2264/C405269B9973/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x49E786A4, Call Id=2264
   Call Entry(Responsed=TRUE, Cause Value=1, Retry Count=0)
Apr 11 10:52:58.829: //2264/C405269B9973/CCAPI/ccConferenceDestroy:
   Conference Id=0x318, Tag=0x0
Apr 11 10:52:58.829: //2264/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=2266, Disposition=0x0, Tag=0x0
Apr 11 10:52:58.829: //2266/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=2264, Disposition=0x0, Tag=0x0
Apr 11 10:52:58.829: //2264/C405269B9973/CCAPI/cc_generic_bridge_done:
Apr 11 10:52:58.829: //2266/C405269B9973/CCAPI/ccCallDisconnect:
   Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=1)
   Cause Value=1, Call Entry(Responsed=TRUE, Cause Value=1)
Apr 11 10:52:58.829: //2266/C405269B9973/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Apr 11 10:52:58.833: //2264/C405269B9973/CCAPI/ccCallDisconnect:
Apr 11 10:52:58.833: //2264/C405269B9973/CCAPI/cc_api_get_transfer_info:
Apr 11 10:52:58.833: //2264/C405269B9973/CCAPI/cc_api_call_disc_cause_update:
   Cause Value=1
   Call Entry(Disconnect Cause=1)
Apr 11 10:52:58.837: //2264/C405269B9973/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x49E786A4, Tag=0x0, Call Id=2264,
   Call Entry(Disconnect Cause=1, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Apr 11 10:52:58.837: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr 11 10:52:58.837: :cc_free_feature_vsa freeing 46AE8CA0
Apr 11 10:52:58.837:  vsacount in free is 7
Apr 11 10:52:58.853: //2266/C405269B9973/CCAPI/cc_api_call_disc_cause_update:
   Cause Value=1
Apr 11 10:52:58.853: //2266/C405269B9973/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x48402CE4, Tag=0x0, Call Id=2266,
Apr 11 10:52:58.857: //2266/C405269B9973/CCAPI/cc_api_call_disconnect_done:
Apr 11 10:52:58.857: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr 11 10:52:58.857: :cc_free_feature_vsa freeing 46AE8AE0
Apr 11 10:52:58.857:  vsacount in free is 6
Apr 11 10:52:58.857: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x01DC
Apr 11 10:52:59.553: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x81DC
Apr 11 10:53:22.414: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0001
Sending Complete
Standard = CCITT
Called Party Number i = 0x81, '704707'
Plan:ISDN, Type:Unknown
Apr 11 10:53:22.414: ISDN Se0/0/0:15 Q931: Received SETUP  callref = 0x8001 callID = 0x00B8 switch = primary-net5 interface = User
Apr 11 10:53:22.418: //-1/DCC9BD8D80B9/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=707
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
Apr 11 10:53:22.418: //-1/DCC9BD8D80B9/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x48402CE4, Call Info(
   Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=707(TON=Unknown, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=10, Progress Indication=NULL(0), Calling IE Present=FALSE,
Apr 11 10:53:22.418: //-1/DCC9BD8D80B9/CCAPI/ccCheckClipClir:
   In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Apr 11 10:53:22.418: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr 11 10:53:22.418: :cc_get_feature_vsa malloc success
Apr 11 10:53:22.418:  cc_get_feature_vsa count is 7
Apr 11 10:53:22.418: :FEATURE_VSA attributes are: feature_name:0,feature_time:1185843944,feature_id:4152
Apr 11 10:53:22.418: //2269/DCC9BD8D80B9/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=707(TON=Unknown, NPI=ISDN))
Apr 11 10:53:22.422: //2269/DCC9BD8D80B9/CCAPI/cc_process_call_setup_ind:
   Event=0x483B91D0
Apr 11 10:53:22.422: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 707
Apr 11 10:53:22.422: //2269/DCC9BD8D80B9/CCAPI/ccCallSetContext:
   Context=0x4A3953D8
   >>>>CCAPI handed cid 2269 with tag 10 to app "_ManagedAppProcess_Default"
Apr 11 10:53:22.422: //2269/DCC9BD8D80B9/CCAPI/ccCallProceeding:
Apr 11 10:53:22.426: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectingNumber:
   type=6 redirecting_number=707
Apr 11 10:53:22.426: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectNumber:
   type=6  Original Called Number=707, Called Number=707, Calling Number=, Calling DN=-1 Calling Id=2269,
   Redirect Number=455, Redirect Reason=15
Apr 11 10:53:22.426: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr 11 10:53:22.426: :cc_get_feature_vsa malloc success
Apr 11 10:53:22.426:  cc_get_feature_vsa count is 8
Apr 11 10:53:22.426: :FEATURE_VSA attributes are: feature_name:0,feature_time:1185844392,feature_id:4153
Apr 11 10:53:22.426: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Apr 11 10:53:22.426:  feature_vsa is 46AE8AE0,featname is 0
Apr 11 10:53:22.426:  cc_get_feature_vsa count is 9
Apr 11 10:53:22.426: :FEATURE_VSA attributes are: feature_name:0,feature_time:1185843272,feature_id:4154
Apr 11 10:53:22.426: : Generating new featurevsa,inserting it
Apr 11 10:53:22.426:  feature call forward featname is 1
Apr 11 10:53:22.426: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr 11 10:53:22.426: :cc_free_feature_vsa freeing 46AE8CA0
Apr 11 10:53:22.426:  vsacount in free is 8
Apr 11 10:53:22.430: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x8001
Apr 11 10:53:22.430: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr 11 10:53:22.430: :cc_get_feature_vsa malloc success
Apr 11 10:53:22.430:  cc_get_feature_vsa count is 9
Apr 11 10:53:22.430: :FEATURE_VSA attributes are: feature_name:0,feature_time:1185844392,feature_id:4155
Apr 11 10:53:22.430: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Apr 11 10:53:22.430:  feature call forward featname is 1
Apr 11 10:53:22.430: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr 11 10:53:22.430: :cc_free_feature_vsa freeing 46AE8CA0
Apr 11 10:53:22.430:  vsacount in free is 8
Apr 11 10:53:22.430: //2269/DCC9BD8D80B9/CCAPI/ccGetTBCTCap:
   TGRM TBCT Enabled; TBCT Capability=0
Apr 11 10:53:22.434: //2269/DCC9BD8D80B9/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=FALSE, Mode=0,
   Outgoing Dial-peer=20026, Params=0x4A38BBE8, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Apr 11 10:53:22.434: //2269/DCC9BD8D80B9/CCAPI/ccCheckClipClir:
   Destination Pattern=455$, Called Number=455, Digit Strip=TRUE
   Called Number=455(TON=Unknown, NPI=ISDN),
   Redirect Number=707, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=DCCC2EC5-A1CC-11E2-9982-9D10B6883F86, Outgoing Dial-peer=20026
Apr 11 10:53:22.434: //2269/DCC9BD8D80B9/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=455
   cisco-desttype=0
   cisco-destplan=1
   cisco-rdie=73
   cisco-rdn=707
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=15   fwd_final_type =0
Apr 11 10:53:22.434: //2269/DCC9BD8D80B9/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x49EDD59C, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=455(TON=Unknown, NPI=ISDN), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=20026, Call Count On=FALSE,
Apr 11 10:53:22.434: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr 11 10:53:22.434: :cc_get_feature_vsa malloc success
Apr 11 10:53:22.434:  cc_get_feature_vsa count is 9
Apr 11 10:53:22.434: :FEATURE_VSA attributes are: feature_name:0,feature_time:1185844392,feature_id:4156
Apr 11 10:53:22.434: //2270/DCC9BD8D80B9/CCAPI/ccIFCallSetupRequestPrivate:
Apr 11 10:53:22.434: //2270/DCC9BD8D80B9/CCAPI/ccCallSetContext:
   Context=0x4A38BB98
Apr 11 10:53:22.434: //2269/DCC9BD8D80B9/CCAPI/ccSaveDialpeerTag:
Apr 11 10:53:22.434: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Apr 11 10:53:22.434:  feature call forward featname is 1
Apr 11 10:53:22.434:  feature_vsa is 46AE8CA0,featname is 0
Apr 11 10:53:22.434:  cc_get_feature_vsa count is 10
Apr 11 10:53:22.434: :FEATURE_VSA attributes are: feature_name:0,feature_time:1185843048,feature_id:4157
Apr 11 10:53:22.434: : Generating new featurevsa,inserting it
Apr 11 10:53:22.438: //2270/DCC9BD8D80B9/CCAPI/cc_api_update_call_info:
   Interface=0x49EDD59C, Call Id=0x8DE
Apr 11 10:53:22.442: //2270/DCC9BD8D80B9/CCAPI/cc_api_call_proceeding:
   Interface=0x49EDD59C, Progress Indication=NULL(0)
Apr 11 10:53:22.442: //2270/DCC9BD8D80B9/CCAPI/cc_api_call_alert:
   Interface=0x49EDD59C, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
Apr 11 10:53:22.446: //2269/DCC9BD8D80B9/CCAPI/ccCallAlert:
Apr 11 10:53:22.446: //2269/DCC9BD8D80B9/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Ring Back,
   Tone Direction=Network, Params=0x0, Call Id=2269
Apr 11 10:53:22.446: //2270/DCC9BD8D80B9/CCAPI/ccCallFeature:
   Feature Type=25, Call Id=2270
Apr 11 10:53:22.450: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8  callref = 0x8001
Progress Ind i = 0x8188 - In-band info or appropriate now available
Pete,
You will need to speak to your Telco provider...They are disconnecting the call. Looks like they cant route these local numbers
Hi Pete,
Something doesn't tie up.  The output you posted shows the call using a Dial Peers that I can't see listed in your config.
Also noticed that further down it attempts to use Incoming Dial-peer=20020.
Can you post your Dial-Peer config?  It seems your router may be trying to send the numbers down the wrong dial peer.  Best to run a "debug voice ccapi inout" to find which Dial Peer it is definitely using.
I am certain this is a CCME setup..Thats why you see those dial-peers.
Incoming dial-peer 20020 is a different call and it is for xtension 449.
It's quite a busy system so it's likely there are other calls going on at the same time as my debug logs.
See below for full config, minus a few details stripped out:
version 12.4
service password-encryption
boot-start-marker
boot system flash c2800nm-spservicesk9-mz.124-24.T2.bin
boot-end-marker
card type e1 0 0
logging message-counter syslog
logging buffered 51200 warnings
enable password 7 13151601181B0B382F
no aaa new-model
clock timezone GMT 0
clock summer-time BST recurring last Sun Mar 1:00 last Sun Oct 1:00
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
dot11 syslog
ip source-route
ip cef
ip dhcp pool Voice
no ipv6 cef
isdn switch-type primary-net5
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
fax protocol cisco
h323
  h225 timeout setup 3
modem passthrough nse codec g711alaw
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
rule 1 /^3934/ /4/
rule 2 /^7047/ /7/
voice-card 0
username Administrator privilege 15 secret
archive
log config
  hidekeys
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31
no ip ftp passive
interface GigabitEthernet0/0
description ***LAN Interface***
ip address 172.16.2.230 255.255.255.0
           duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn overlap-receiving T302 6000
isdn incoming-voice voice
isdn send-alerting
isdn bchan-number-order ascending
no cdp enable
interface Integrated-Service-Engine1/0
ip unnumbered GigabitEthernet0/0
ip ospf network point-to-point
           service-module ip address 172.16.2.231 255.255.255.0
!Application: CUE Running on NME
service-module ip default-gateway 172.16.2.230
no keepalive
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 172.16.2.254
ip route 172.16.2.231 255.255.255.255 Integrated-Service-Engine1/0
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
tftp-server SCCP70.9-1-1SR1S.loads alias SCCP70.9-1-1SR1S.loads
tftp-server cmterm-7942_7962-sccp.8-3-2SR1/apps42.8-3-2SR1.sbn alias apps42.8-3-2SR1.sbn
tftp-server cmterm-7942_7962-sccp.8-3-2SR1/cnu42.8-3-2SR1.sbn alias cnu42.8-3-2SR1.sbn
          tftp-server cmterm-7942_7962-sccp.8-3-2SR1/cvm42sccp.8-3-2SR1.sbn alias cvm42sccp.8-3-2SR1.sbn
tftp-server cmterm-7942_7962-sccp.8-3-2SR1/dsp42.8-3-2SR1.sbn alias dsp42.8-3-2SR1.sbn
tftp-server cmterm-7942_7962-sccp.8-3-2SR1/jar42sccp.8-3-2SR1.sbn alias jar42sccp.8-3-2SR1.sbn
tftp-server cmterm-7942_7962-sccp.8-3-2SR1/SCCP42.8-3-2SR1S.loads alias SCCP42.8-3-2SR1S.loads
tftp-server cmterm-7942_7962-sccp.8-3-2SR1/term42.default.loads alias term42.default.loads
tftp-server cmterm-7942_7962-sccp.8-3-2SR1/term62.default.loads alias term62.default.loads
control-plane
voice-port 0/0/0:15
cptone GB
ccm-manager music-on-hold
port 0/0/0:15
direct-inward-dial
voice-class codec 1
dial-peer voice 801 voip
           description Voicemail
destination-pattern 801
session protocol sipv2
session target ipv4:172.16.2.231
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 999 pots
description ** Emergency calls **
destination-pattern 999
port 0/0/0:15
prefix 999
dial-peer voice 9990 pots
destination-pattern 9999
port 0/0/0:15
prefix 999
sip-ua
mwi-server ipv4:172.16.2.231 expires 3600 port 5060 transport udp unsolicited
telephony-service
authentication credential Administrator nbvuga
max-ephones 110
max-dn 288
ip source-address 172.16.2.230 port 2000
timeouts interdigit 4
url services http://172.16.2.230/voiceview/common/login.do
url authentication http://172.16.2.230/CCMCIP/authenticate.asp
cnf-file location flash:
load 7942 SCCP42.8-3-2SR1S
load 7970 SCCP70.9-1-1SR1S
time-zone 21
time-format 24
date-format dd-mm-yy
voicemail 801
max-conferences 8 gain -6
call-forward pattern .T
moh music-on-hold.au
multicast moh 239.1.1.1 port 16384
web admin system name Administrator secret 5 $1$oBGz$qGlAWDYs066Y4uafQ3l2n/
           dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
secondary-dialtone 9
create cnf-files version-stamp 7960 Apr 04 2013 22:48:59
ephone-hunt 1 sequential
pilot 01256000000
list 463, 439, 434, 437
line con 0
password 7 03145A1815182E5E4A
login
line aux 0
line 66
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
password 7
login
           transport input telnet ssh
line vty 5 15
password 7 021605481811003348
login
scheduler allocate 20000 1000
end
James Hawkins
Level 8
Level 8
It looks like you are stripping 90 rather than just 9 before sending the dialled digits to the ISDN switch - assume this is in Basingstoke UK? - the telco will not route the call if it is missing the leading zero
I did think that. Is that on the 103 rule?
Assuming we should be removing the rule 2 from here?
Pete,
James (+5) good spot..Didnt even realise this was a UK number
Removed rule 2, still the same issue.
Also tried removing rule 1 and again - the same issue.
Next ideas?
Ah, so should I be switching the translate calling / called around?
calling 103 and called 102?
Yes..
Please send a new debug isdn q931..so we can see what you are sending out
Fantastic, that's the winner!
Changing the translate calling / called around seems to have done the trick.
Massive thanks to all for your assistance.
