Can the CUBE & Gatekeeper exist on the same cisco ios router ?
chukkaedovia
Ill like to know if I can use the same router to host the cisco CUBE and Gatekeeper functionalities.
Thank you.
nitsinha
Level 4
Level 4
AFAIK we can use both on the same router. After all, CUBE will just be an IP-IP gateway that registers to the GK on the same box.
Nitesh
PS:Pl rate helpful posts
nitsinha
Level 4
Level 4
Nitesh
Thanks for this . I also have another scenerio where CCM is connected  to MGCP gateways and CUBE. My aim is to failover from my MGCP gateway (  connects my PSTN ) to my SIP trunk ( SIP PROVIDER) and vice versa.
Will configuring multiple route groups on the CCM( i.e  Route-Pattern ---- Route-List------ 2XRoute Groups) cater for this  failover scenerio ? The 2 route groups will be the CUBE and the MGCP  gateways respectively.
I am concerned how the call manager will know when the  sip trunk has failed on the CUBE ( SIP trunk to provider ) so that it  can change to the MGCP gateways ( PSTN ).
Thank you.
In cube in the dial-peer which is pointing to sip provider, you can configure the keep-alive mechanism using the below command.
voice-class sip options-keepalive.
You may also need you SIP Provider's help on this.
Configure the error-response code as 503 Service Unavailable, which should be huntable to next route.
You can refer the below link for more understanding on this
http://www.cisco.com/en/US/docs/ios/voice/cube/configuration/guide/vb-gw-sipsip.html#wp1381926
Senthil
