07-14-2009 06:13 PM - edited 03-15-2019 06:58 PM
CME 7.1 with CUE 7.0.
The requirement is: 5 agents dynamically join/leave the hunt-group(use Hlog). when all the agents left the hunt-group, one agent can have the option to forward the hunt-pilot call to his cell phone. Each day different agent will setup the agent's personal different cell phone number.
I am wondering if anyone can provide me a hint for the above requirement.
Right now, I have a workaround is to configure the final destination to a spare physical phone first line, and from that phone, setup callforwardall to the cell phone on the fly. But this way will require a physical phone.
JJ
Solved! Go to Solution.
07-15-2009 03:52 AM
No, if you press the line button before, you can CfwdAll any line on a phone. Just make sure seized state had the softkey.
Of course you can also CFA from the user page that "owns" the DN.
07-15-2009 12:38 AM
Configure that DN on a second button of one or more multibutton phones.
Press it before CfwdAll.
Done.
07-15-2009 03:03 AM
cfwdall setting from phone interface only applies to the first button which is not our case (we configured the first button as the hunt-group member).
Not sure if end-user(not administrator) can setup phone button cfwd setting from end-user webpage of CUE. Will try that.
Any more idea?
JJ
07-15-2009 03:43 AM
Maybe I can try to configure the 2nd or 3rd button as shared line which is the final destination, and to see if SNR feature can work on the 2nd/3rd extension although CME 7.1 SNR says:
"Each IP phone supports only one SNR directory number. "---it didn't mention if it must be the primary button extension.
07-15-2009 03:52 AM
07-15-2009 04:42 AM
You are right!
Thanks for your pointing. Great!
07-15-2009 12:03 PM
You're welcome, thanks for the nice rating and good luck!
