Cannot install CUCM subscriber?
samhopealpha
Level 2
Level 2
Dear Everybody,
I have installed the CUCM8.6 Publisher successfully and all phones are able to register
however, when start to install the CUCM8.6 subscriber,
it displays the following error after network connectivity check
Configuration validation with CUCM-PUB (10.10.10.1) failed.
Configured first node CUCM-PUB is not a First Node.
- Is CUCM-PUB entered correctly?
- Is CUCM-PUB the correct first node for this node?
I have checked:
1. I'm sure that the CUCM-PUB is the First-Node.
2. the server name has been changed from hostname to IP address
3. the CCM Node License show
- Units Authorized           : 1
- Units Used                    : 1
- Units Remaining          : 0
Is it because the node license is not enough for the subscriber?
Sam
yahsiel2004
Level 7
Level 7
Are you putting in the correct security password? If you're I would change the pubs hostname back into a name until you finish installing all your subs. In regards to the license it would not stop you from installing the sub but you will need to acquire a license for the sub to be Cisco compliant.
Yosh
HTH Regards, Yosh
5 Replies 5
yahsiel2004
Level 7
Level 7
Yosh
HTH Regards, Yosh
Rob Huffman
Hi Sam,
In addition to the great info from Yosh here (+5 Yosh )
You may be hitting this bug;
CSCub14050 - Unable to add a new subscriber to the CUCM Cluster
Description
Symptom:
Receive the following error after entering in the security password:
Connectivity check to  () failed.
Unable to connect to .
- Is the IP address and/or security password entered correctly?
- Is the IP address  correct for ?
- Is the security password correct for ?
- Is the network connection to  up?
- Is  powered on?
...may possibly also see...
Configuration validation with  () failed.
Configured first node  is not a First Node.
- Is  entered correctly?
- Is  the correct first node for this node?
....the aforementioned is *usually* an indication that the security password was erroneously entered or the pubname was wrong.
Conditions:
A  large banner size in combination with a small amount of allocated  memory may result in the inability to add a new subscriber to the CUCM  cluster.
After verifying that the security password is correct, i.e. that one is *not* fat fingering the password.
more /usr/local/platform/conf/platformConfig.xml
...followed by...
/usr/local/bin/base_scripts/InstallWizard -p
If the hash values are the same this shows customer is entering the password in correctly.
have  also eliminated that the default gateway is accessible, full network  connectivity is in place (packet capture at pub & sub verifying all  packets sent are received).
Workaround:
Reduce the number of characters in the banner.
The Banner can be modified under....
OS Admin -> Software Upgrades -> Customized Logon Message
Details
First Found in:                          (1)
8.6(2)
Status:
Fixed
Last Modified:
Jan 02,2013
Fixed in:                          (5)
9.1(1.10000.11),9.1(0.98000.3),9.1(0.98000.2)
8.6(4.98000.155),1.0(0.98000.42)
Product:
Cisco Unified Communications Manager (CallManager)
Platform:
Dependent
Severity:
3 - moderate
Cheers!
Rob
"Clocks go slow in a place of work
Minutes drag and the hours jerk"
-The Clash
Logon message change to empty, node licenes added , cucm publisher restarted
But it still not working...
Did you add the SUB into the System/Server before to start the installation of the SUB?
If yes then did you were able to finish the configuration?
Could you pls describe where you have stuck?
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
finally found that it's the security password incorrect, thanks for the help
