06-25-2013 06:46 PM - edited 03-16-2019 06:04 PM
Hi guys,
I have been trying to get this working without any success and I really need some extra MTPs.
Not sure why, but cannot use my AS5400 as software or even hardware MTP for my CUCM 7.1.5.34900-7.
Same deal if I try it with another cluster with 8.5.1.
AS5400 is 15.1(3)T4 but also tried it with an old 12.4T image with same results.
Configuration is very simple:
dspfarm profile 8 mtp
codec g711ulaw
maximum sessions software 10
associate application SCCP
sccp ccm 10.198.161.86 identifier 6 version 7.0
sccp ccm group 4
associate ccm 6 priority 1
associate profile 8 register MTP-Prueba
Just trying to call a SIP phone internally with MTP required but the call fails everytime. If I would use the CUCM MTP, it works fine.
The error I get on the traces is:
19:08:00.995 |StationInit: (0000004) OpenReceiveChannelAck Status=1 (Error: Endpoint failed to open receive channel), IpAddr=IpAddr.type:1 ipAddr:0x00000000000000000000000000000000(::), Port=0, PartyID=16777219|1,100,50,1.196957^10.198.104.24^MTP-Prueba
19:08:00.996 |AgenaInterface(4)::sendErrorToMX, Audio Channel OLCAck with error recd|1,100,50,1.196957^10.198.104.24^MTP-Prueba
I want to know if someone has used such AS5400 as MTP, or if anyone knows a good reason why this just won't ever work.
07-10-2013 10:01 AM
Randall,
The AS5400 doesn't show up as a compatible MTP resource for Callmanager use:
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/admin/8_6_1/ccmsys/a05dsp.html#wp1044172
Hope that helps.
07-06-2014 11:02 PM
07-07-2014 08:04 AM
What does the OpenReceiveChannel message look like? Can you post the full CallManager traces?
Can you try adding codec-passthrough on the dspfarm profile as well and then run "no sccp/sccp"?
