Showing results forĀ
Search instead forĀ
Did you mean:Ā
cant make international conference call on Cisco phone by putting conference code
amralrazzaz
Level 5
Level 5
hi
i have Cisco phones at office , my problem is i received a conference call we conference code by email as invitation
i dial the international number (Holland for example) normally and then the answer machine requesting me to put the conference code , so the local answer machine (Egypt) said this number is wrong please check number .etc
why i cant put the conference code to join the call and  the local answer machine reply this number is number and the international call is already on hold waiting for conference code to join
Note: i dont have landline , im using Vodafone sim card on our ip central system because we dont have landline infra and boxes in our building
thanks
amr alrazzaz
71 Replies 71
Enable the following and collect the logs after reproducing the issue -
debug ccsip message
debug ccsip error
debug ccsip non-call
debug voice ccapi inout
debug voip vtsp all
debug vpm signal
Hi there
debug ccsip messages could be the best one to troubleshoot further. Do a test call and get those
Just want you to try these. Since you already changed the dtmf relay, just wondering did you do a do a create profile under voice register global.
Also try switching it to dtmf-relay rtp-nte or dtmf-relay sip-kpml sip-notify. Do a  create profile under voice register global.
Hope this helps!
Cheers
Rath!
***Please rate helpful posts***
yes already create profile
now to track the calls u said debug ccsip
which one should i choose and when should i do this (*when im calling)
Router#debug ccsip ?
all Enable all SIP debugging traces
calls Enable CCSIP SPI calls debugging trace
dhcp Enable SIP-DHCP debugging trace
error Enable SIP error debugging trace
events Enable SIP events debugging trace
feature Enable feature level debugging
function Enable SIP function debugging trace
info Enable SIP info debugging trace
level Enable info level
media Enable SIP media debugging trace
messages Enable CCSIP SPI messages debugging trace
non-call Enable Non-Call-Context trace (OPTIONS, SUBSCRIBE etc)
preauth Enable SIP preauth debugging traces
states Enable CCSIP SPI states debugging trace
translate Enable SIP translation debugging trace
transport Enable SIP transport debugging traces
verbose Enable verbose mode
amr alrazzaz
You probably need to enable logging first.
conf t
logging buffered 4096
logging monitor
logging monitor debug
end
term mon
Try to make a test call amd post the output
Carlo
Please rate all helpful posts "The more you help the more you learn"
thanks but sorry there is nothing after enable logging and no errors found or i dont know no output found
any how i cant put the conference code after dialing international number to join the conference
the screen of cisco phone doesnot show the digits when i type during the international calling to join the conference
amr alrazzaz
After logging enabled did you activate the debug ccsip messages and than the command "term mon"?
Did it show something?
If yes, please post the output.
And yes.. after the call is established with the conference bridge, the phone does not display further digits.
Please let me know
Carlo
dear please check the o/p of the call
just to tell u again many thanks for helping me
amr alrazzaz
You are most welcome!
Can you please also share your actual configuration?
Carlo
Hi there
I suspect this could be a phone issue. I assume you are using 7821 with 10.1.1 firmware. There are some DTMF related bugs with 7821/10.1.1. Please give a shot to upgrade the firmware to one of the fixed versions and see the behavior. Some fixes, you might need to open up a TAC.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCup15348
Hope this helps!
Cheers
Rath!
so the update fix this issue and ill be allow next time to put conference code during international call following with hash ???
thanks
another thing the link u sent has two verison which one should i choose i downloaded both
cmterm-78xx.12-1-1-12.k3.cop.sgn
cmterm-78xx.12-1-1-12.zip
also the upgrade will erase the phone profiles and configurations or just overwrite ?
how also to upgrade by the way ? steps
amr alrazzaz
can i also upgrade only one ip cisco phone manually through tftp by choosing the destination (ip address of phone) or what ?
did the upgrade will effect on the router configurations ? or it will erase data or something loss?
amr alrazzaz
xmldefault.cnf.xml for 7821 not exist sip78xx.12-1-1-12  so how can i download this firmware to phone directly only one phone to test the issue by using alternative tftp server ?
amr alrazzaz
Hi there,
My bad. The bugs which I sent was for CUCM. For CME you can download the zip files and it contains all the files and load. The procedure is outlined in the below link
https://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-express/68244-PhoneLoadUpgradeCCME.html#configs
I dont think you can individually upgrade one phone on CME. You can refer to some workarounds mentioned on this post.
https://supportforums.cisco.com/t5/ip-telephony/single-phone-firmware-upgrade-in-cme/td-p/2924145
Hope this helps!
Cheers
Rath!
thanks alot boss . now
1- i cant upgrade only one phone for testing (using tftp alternative)
2- if i upgrade the cisco phone to new firmware on router using tftp , what about the old one which       already installed on router ? it will over write ? and which time should i upgrade ? during working hours ? so users doesnt effected with normal internet connection ?
3- also it will not erase any of my router configuration ? just need to make sure
4- about the latest firmware of cp 7821 with cmterm-78xx.12-1-1-12 i dont have the XMLDefault.cnf.xml included with the same model inside the file ?
5- last things need steps of how to upgrade on router 2911 ?
thanks alot for great helping
amr alrazzaz
Hi there
I dont think you can upgrade the firmware for a single phone in CME, however you could try this
  1. Download the 7821 firmware to the flash
  2. Configure tftp-server flash: <filename>.ext  under config mode.
  3. Under Telephony-service define the load for the phone type. (without .loads)
  4. Reset the 7821 phone
  5. Once the phone load is upgraded successfully, revert to old config
  6. Once testing you can reset the phones and it goes to old firmware
Firmware upgrade neither wipe off the router config not overwrite the current firmware. You can get a backup and do this. If the sites are really critical get a maintenance window period for the activity.
How to upgrade firmware CME
Hope this helps!
Cheers
Rath!
