08-19-2013 01:11 AM - edited 03-16-2019 06:55 PM
Hi team.
It's possible configure a call pickup code in CUCM 8.6 for users of IP Phone 3905, 6921, 7942 and 7962 to capture calls that belong to a Call Pickup Group?.
This means that the user only enter a numeric code and automatically captures the call without having to press buttons on the phone?.
Thanks.
EG
Solved! Go to Solution.
08-19-2013 03:38 AM
Yes you can, by dialing the ringing phone's extension you can able to pickup that call.
08-19-2013 08:37 AM
Hi EG,
None of the Call Pickup methods in CUCM will work exactly as
you desire even with Auto Call Pickup enabled. The closest two
would be Group Call Pickup & Directed Call Pickup;
You can automate call pickup, group pickup, other group pickup, directed call pickup, and BLF call pickup by enabling the Auto Call Pickup Enabled service parameter.
When this parameter is enabled, Cisco Unified Communications Manager automatically connects users to the incoming call in their own pickup group, in another pickup group, or a pickup group that is associated with their own group after users press the appropriate softkey on the phone. This action requires only one keystroke.
Auto call pickup connects the user to an incoming call in the group of the user. When the user presses the PickUp softkey on the phone, Cisco Unified Communications Manager locates the incoming call in the group and completes the call connection. If automation is not enabled, the user must press the softkeys, PickUp and Answer, to make the call connection.
Auto group call pickup connects the user to an incoming call in another pickup group. The user presses the GPickUp softkey on the phone, then dials the group number of another pickup group. Upon receiving the pickup group number, Cisco Unified Communications Manager completes the call connection. If auto group call pickup is not enabled, the user must press the GPickUp softkey, dial the group number of another pickup group, and answer the call to make the connection.
Auto other group pickup connects the user to an incoming call in a group that is associated with the group of the user. The user presses the OPickUp softkey on the phone. Cisco Unified Communications Manager automatically searches for the incoming call in the associated groups in the sequence that the administrator enters in the Call Pickup Group Configuration window and completes the call connection after the call is found. If automation is not enabled, the user must press the softkeys, OPickUp and Answer, to make the call connection.
Auto directed call pickup connects the user to an incoming call in a group that is associated with the group of the user. The user presses the GPickUp softkey on the phone, then dials the DN of the ringing phone. Upon receiving the DN, Cisco Unified Communications Manager completes the call connection. If auto directed call pickup is not enabled, the user must press the GPickUp softkey, dial the DN of the ringing phone, and answer the call that will now ring on the user phone to make the connection.
From;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_6_1/ccmfeat/fscpickg.html#wp1054419
Cheers!
Rob
"A smile relieves a heart that grieves"
- Stones
08-19-2013 03:28 AM
Sorry, isn't dialing on keypad and dial button, same or more buttons as pressing a softkey ?
08-19-2013 03:38 AM
08-19-2013 07:27 AM
Hi Selvarathnam.
Thanks for your answer.
What is the process to configure and implement a basic Call Pickup for capture calls by code number?.
Regards.
EG
08-19-2013 09:04 AM
Hi EG,
Please, see the Rob's post.
08-19-2013 08:37 AM
Hi EG,
From;
Cheers!
Rob
- Stones
