IP Telephony and Phones
Labels
Hello,Have a setup with a fractional T1 (Voice PRI) dialing into and out of a 2811 running CME.Should we want to upgrade to CCM can i point the PRI on the 2811 to the CCM?  Or will i need a different kind of gateway?  ThanksJohn
jelkin001 by Level 1
  • 480 Views
  • 3 replies
Hello, we have a CME and what is needed is to host conferences; Participants from outside will call into a specific number then they will be prompted for a code to join the conference or get it started. Please advise what should be done or needed for...
wissamnad by Level 1
  • 675 Views
  • 3 replies
Hi,I not able to add more than two PRI's on my Cisco 3945 Gateway. As you can see in the below attached the configuration file the third controller is partially registered. Also you can see that both the transcoder and conference profiles are shut do...
Hi all,Having some issues with our VOIP system where, intermittenly, people will hear a buzz and then be disconnected. Phone calls can't be made or received for a few seconds (in this latest instance, about 26 seconds).Happens site-wide, but not othe...
Hi,I would like to make a lab with CUCM 9.1 installed in VMWare virtual environment for testing purposes.I see that I can request a DEMO license through http://cisco.com/license but where do I download the installation files from?Regards.
kasper123 by Level 4
  • 827 Views
  • 2 replies
Resolved! DX650 phone & CME?
Does CME currently support DX650?  I searched for some info and the only thing I was able to find was a documentation that only mentions certain functionality will not work when DX650 is configured under CME -Cisco Desktop Collaboration Experience an...
