ccb->cc_disc_cause (38); ccb->sip_disc_cause(503) error via SIP trunk
Rajkumar Yadav
Level 4
Level 4
I have issue with sending the call to the Neogate GSM VOIP gateway via SIP Trunk.
I'm getting error as "Cannot get remote address for connector socket" and "ccb->cc_disc_cause (38); ccb->sip_disc_cause(503)"
I understand its 503 error, no response from the Neogate, but able to ping the CUCM IP address.
below is the log for failed call.
____________________________________________________________________________________________________________________
01759991.000 |17:02:12.497 |SdlSig   |SIPSPISignal                           |wait                           |SIPTcp(2,100,64,1)               |SIPHandler(2,100,72,1)           |2,100,13,1.364960^*^*                    |*TraceFlagOverrode
01759991.001 |17:02:12.497 |AppInfo  |SIPTcp - SIPSPI_EV_CREATE_CONNECTION: Addr=10.0.32.11, Port=5060, globalTCPInst=0xb4e0b6e0
01759992.000 |17:02:12.510 |NetError |                                       |                               |SdlTCPConnector(2,100,12,88414)  |                                 |2,100,13,1.364960^*^*                    |Cannot get remote address for connector socket.
01759993.000 |17:02:12.510 |NetError |                                       |                               |SdlTCPConnector(2,100,12,88414)  |                                 |2,100,13,1.364960^*^*                    |SdlConnectorBase::connectionError
01759994.000 |17:02:12.510 |SdlSig   |SIPSPISignal                           |wait                           |SIPHandler(2,100,72,1)           |SIPTcp(2,100,64,1)               |2,100,12,88414.1^*^*                     |*TraceFlagOverrode
01759994.001 |17:02:12.510 |AppInfo  |//SIP/SIPHandler/ccbId=0/scbId=0/sip_stop_timer: type=SIP_TIMER_WAIT_CONNECT value=5000 retries=0
01759995.000 |17:02:12.510 |SdlSig   |SIPConnControlInd                      |wait                           |SIPHandler(2,100,72,1)           |SIPTcp(2,100,64,1)               |2,100,12,88414.1^*^*                     |*TraceFlagOverrode
01759995.001 |17:02:12.510 |AppInfo  |//SIP/SIPHandler/ccbId=0/scbId=0/getRemoteAddrInfo: RemoteAddrInfo = 10.0.32.11:5060
01759996.000 |17:02:12.510 |SdlSig   |SIPSPISignal                           |wait                           |SIPTcp(2,100,64,1)               |SIPHandler(2,100,72,1)           |2,100,12,88414.1^*^*                     |*TraceFlagOverrode
01759996.001 |17:02:12.510 |AppInfo  |SIPTcp - Did not find table entry in Close Msg,Index = 4847
01759997.000 |17:02:12.510 |SdlSig   |SIPConnControlInd                      |restart0                       |SIPD(2,100,74,10)                |SIPHandler(2,100,72,1)           |2,100,12,88414.1^*^*                     |*TraceFlagOverrode
01759997.001 |17:02:12.510 |AppInfo  |SIPD(10) - restart0_SIPConnControlInd: mTsp.DeviceName[NGGSM1] - Rcvd ConnControl with operation = 1, connIdx = 4847, X.509 Name =
01759997.002 |17:02:12.510 |AppInfo  |SIPD(10) - restart0_SIPConnControlInd: mTsp.DeviceName[NGGSM1] - Cannot find TLSConnTbl entry, connIdx = 4847, X.509 Name =
01759998.000 |17:02:12.510 |SdlSig   |SIPSPISignal                           |wait                           |SIPHandler(2,100,72,1)           |SIPHandler(2,100,72,1)           |2,100,12,88414.1^*^*                     |*TraceFlagOverrode
01759998.001 |17:02:12.510 |AppInfo  |//SIP/SIPHandler/ccbId=1054241/scbId=0/ccsip_api_call_disconnected: ccb->cc_disc_cause (38); ccb->sip_disc_cause(503)
01759998.002 |17:02:12.510 |AppInfo  |//SIP/SIPHandler/ccbId=1054241/scbId=0/findDevicePID: Routed to SIPD by ccbId/scbId
01759999.000 |17:02:12.510 |SdlSig   |SIPDisconnInd                          |restart0                       |SIPD(2,100,74,10)                |SIPHandler(2,100,72,1)           |2,100,12,88414.1^*^*                     |*TraceFlagOverrode
01759999.001 |17:02:12.510 |AppInfo  |SIPD(10) - getKeyBasedOnCiAndBranch: AddressingElement branch is 0 and ci is 36734627  mapKey is 36734627
01759999.002 |17:02:12.510 |AppInfo  |SIPD(10) - getCdpcPidGivenCcbidAndCi: found Cdpc Pid (2,100,75,26275) for mapKey 36734627
01760000.000 |17:02:12.510 |SdlSig   |SIPDisconnInd                          |outCall_proceeding             |SIPCdpc(2,100,75,26275)          |SIPD(2,100,74,10)                |2,100,12,88414.1^*^*                     |*TraceFlagOverrode
01760000.001 |17:02:12.510 |AppInfo  |SIPCdpc(26275) - tryAnotherDynamicAddr: isDynamicTrunk 0
01760001.000 |17:02:12.510 |SdlSig   |CcRejInd                               |tcc_transit_call_proceeding5   |Cdcc(2,100,212,151551)           |Cc(2,100,213,1)                  |2,100,12,88414.1^*^*                     |*TraceFlagOverrode
01760001.001 |17:02:12.510 |AppInfo  |processCCMFeatureData: operationIeIdd=0
_________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________
9 Replies 9
Vivek Batra
To clarify, is it the call flow?
Phone -> CUCM -> SIP Trunk -> NeoGate GSM VoIP Gateway
Vivek
Hi Vivek
Is there any firewall between CUCM and the GSM voip Gateway ?
Can you verify port number 5060 is opened for communication ?
Aditya Gupta
The call flow is right as you mentioned, as what i discovered the VOIP GSM gateway does not accept the TCP stream and that's the reason it rejects, i changed the outgoing message as UDP in sip profile for sip trunk.
Also the disable the firewall functionality, port/ip address balck list.
Now i'm getting the error as  "ccsip_api_call_disconnected: ccb->cc_disc_cause (1); ccb->sip_disc_cause(404)"
Raaj.
Hi Raj,
404 Not found is generally sent by third party SIP gateway when there is no further route/destination to route the call. You can cross verify the dial plan is configured correctly in your gateway to route the call to desired destination.
One more point I would like you to take care about avoiding delay offer. Many third party SIP gateways either doesn't accept initial INVITE w/o offer or misbehave. By default, CUCM sends INVITE w/o SDP offer. You can control and change this behavior by enabling early offer under SIP Profile.
Vivek
Hi Aditya / Vivek,
Issue is resolved and attached is the reference snapshot to get more understanding.
I was missing the incoming called number in Neogate GSM voip Gateway and only thing which was not allowing call.
Thank you very much for helping here.
Raaj.
Hi Rajkumar
Is it possible to get sip messages from your GSM voip gateway ?
Please paste the output here
Aditya Gupta
Hi Aditya,
I will try to get the sip logs from there and post here.
(it will may little time as i have to visit at client site for this).
Raaj
Hi Aditya,
Just fyi, post was by Rajkumar Yadav :)
Vivek
Yep, noticed that later
My Fault :)
