- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
10-29-2012 10:14 AM - edited 03-16-2019 01:55 PM
Hi, I'm parsing through docs and think I have the correct upgrade path, but I wanted to make sure it works in conjunction with Unity as well. Can someone clarify for me?
I have CCM 5.1.3 Publisher and Subscriber on HP phyiscal servers
-Upgrade both to 7.1.3
-Apply 7.1 licensing
-Then upgrade both to 8.6 (the HP servers are supported in 8.6 in bridged mode only)
-Apply 8.6 licensing
-Then install 8.6 cluster on VM
-Perform DRS backup on physical, restore onto virtual
Here's my questions:
1. Could I take a DRS backup of my 5.1 data, then install 8.6 fresh on VM's, then just restore? Or does DRS not support that big if a version mismatch?
2. I want to upgrade Unity 4.3 to Unity Connection 8.x during this process. Should I do it before CUCM, during CUCM, or after the CUCM upgrade?
Thanks all-
Tim
Solved! Go to Solution.
- Labels:
CUCM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-29-2012 11:51 AM
Hi Tim,
I just wanted to add a couple of references to the great info from Roger & Java (+5 each )
The tool is now deprecated but still useful;
Unified Communications Manager (CallManager) Upgrade Tool
Release Information
- CUCM 7.1(3b) was originally released on December 15, 2009.
- The full version number is 7.1.3.30000-1.
Download Information
- If the files required for this upgrade are not available for download on cisco.com you may open a TAC service request and ask that they be posted for you.
- Otherwise the files will be provided on the media you receive as part of the upgrade kit required for this upgrade.
Special Notes for 5.1(3) to 7.x Upgrades via SFTP
If your current version is 5.1.3.4111-1 or lower:
- You must install a special patch to allow the upgrade file to be detected on the SFTP server.
- You must raise a TAC service request and ask for the ciscocm.5x_ftp_fix.cop.sgn file to be posted for you.
If your current version is 5.1(3e) or 5.1.3.6xxx-y:
- You must download and install the ciscocm.5.13e_upgrade.cop.sgn file from the CUCM Software Center prior to attempting the upgrade.
- For more information reference the CUCM 7.1(2) Operating System Administraion Guide.
Maintaining your inactive partition
- You can upgrade to this version directly from your current version and maintain your current version in the inactive partition.
- CUCM 5.x installs create disk partitions using a fixed size, regardless of actual disk size. In CUCM 6 we began using percentages of disk size for partition sizing.
- Upgrading from CUCM 5 to CUCM 6 or 7 will not resize your partitions. This can cause upgrade failures and RTMT alerts post-upgrade due to low available space on the active partition, particularly on systems with multiple CUCM locales installed.
- Cisco recommends after any 5.x to 6 or 7 upgrade you take a backup, reinstall the server from scratch at the new version to take advantage of the new partition sizes, and then restore from backup.
When you see the info for the Bridge Upgrade, you may see that a separate MCS server
built with a copy of 7.1(3) may be necessary to be able to keep things running in production;
Bridge Upgrade
The bridge upgrade provides a migration path for customers who want to migrate from discontinued Cisco Unified Communications Manager server to a server that supports the newest release of Cisco Unified Communications Manager.
Servers that are no longer supported, but are permitted to function as bridge upgrade servers, can upgrade and boot but will not allow Cisco Unified Communications Manager to function.
When you attempt to upgrade your Cisco Unified Communications Manager version on a discontinued server model, Cisco Unified Communications Manager inserts a message into the upgrade log. The upgrade log is displayed on the web browser when the upgrade is initiated through the Cisco Unified Communications Operating System Administration window, or you can view it through CLI if you used CLI to perform the upgrade. This message notes that you can only use the new version to obtain a DRS backup. The warning message in the log is followed by a delay that allows you to cancel the upgrade if you do not want to do a bridge upgrade.
When the system boots the new Cisco Unified Communications Manager version, a warning appears on the console that tells you that the only thing you can do with the new Cisco Unified Communications Manager version is to perform a DRS backup ("This hardware has limited functionality. Backup and Restore is the only supported functionality."). Because of the restricted visibility of the console, the warning displays during both CLI and GUI sessions.
Use the following procedure to perform a bridge upgrade:
Procedure
Step 1 Perform an upgrade to the new Cisco Unified Communications Manager version on your discontinued first node (publisher) server. Refer to the preceding sections in this chapter that describe the kind of upgrade you want to do. Observe the warning on the console that tells you that the only thing you can do with the new Cisco Unified Communications Manager version is to perform a DRS backup ("This hardware has limited functionality. Backup and Restore is the only supported functionality.").
Step 2 Perform an upgrade to the new Cisco Unified Communications Manager version on your subsequent node (subscriber) servers. Refer to the preceding sections in this chapter that describe the kind of upgrade you want to do.
Step 3 Verify database synchronization between all nodes. You can use the CLI commands utils dbreplication runtimestate and utils dbreplication status. For more information, refer to the Command Line Interface Reference Guide for Cisco Unifed Communications Solutions.
Step 4 Using the new Cisco Unified Communications Manager version on your discontinued first node server, perform a DRS backup. The DRS backups are encrypted using the cluster security password provided at install time. You must remember this security password as the "old" password, because you may be prompted to enter this "old" password at the time of restore. Refer to the Disaster Recovery System Administration Guide.
Step 5 Disconnect your discontinued server from the network.
Step 6 Install the new Cisco Unified Communications Manager version on your new supported first node server. You must obtain and install a new license on this server. Refer to the guide Installing Cisco Unified Communications Manager. You will be prompted to enter a "new" security password, a password that is different from the "old" password you noted in Step 4. The guide Installing Cisco Unified Communications Manager describes the requirements of a "new" security password that Cisco Unified Communications Manager will accept. You must remember this "new" security password.
Step 7 Using the new Cisco Unified Communications Manager version on your new supported first node server, perform the Disaster Recovery System Administration Guide procedure "Restoring the First Node only (Rebuilding the Publisher Alone)". First, select only select the first node for restore. You can only select the subsequent nodes for restore after the completion of first node restore. Use the discontinued server's backup file that you created in Step 4. You will be prompted for the "old" security password that you noted in Step 4. For further details, refer to the Disaster Recovery System Administration Guide.
Step 8 On your new supported first node server, reactivate all services that used to be active on your discontinued first node server before the bridge upgrade. Refer to the Administration Guide for Cisco Unity Connection Serviceability.
Step 9 Verify database synchronization between all nodes. You can use the CLI commands utils dbreplication runtimestate and utils dbreplication status. For more information, refer to the Command Line Interface Reference Guide for Cisco Unifed Communications Solutions.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/8_0_2/cucos/iptpch7.html#wp1058411
As for the Unity to Unity connection migration, you'll definitely want to treat this as a completely
different project. I would probably do this after the CUCM migration
Cheers!
Rob
"And if I should fall behind
Wait for me" - Springsteen
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-29-2012 11:10 AM
DRS only support same version backup/restore.
About Unity, that's more or less a matter of personal preference. If you plan to keep the same IPs on the new CUCM 8.6 VM system I think I would do it after the upgrade of CUCM.
Please remember to rate all useful posts.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-29-2012 11:17 AM
The official supported path is you go to at least 8.0(2) (if your HW supports a higher version, you can go as high as you can) on MCS and then, do the DRS backup to restore on UC on UCS fresh CUCM install.
As for Unity to CUC, you use COBRAS
Upgrade Guide for Cisco Unity Connection Release 8.x
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/upgrade/guide/8xcucrugx.html
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-29-2012 11:51 AM
Hi Tim,
Release Information
Bridge Upgrade
Procedure
Cheers!
Rob
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-29-2012 12:05 PM
Great post Rob (+5) :)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-29-2012 02:38 PM
Thanks Rob, wish I could award +15! Thanks for clearing up Unity, I was under the impression that 8.x CUCM wasn't compatible with Unity 4.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-30-2012 08:16 AM
Hi Tim,
You should have given me a -15 as I really need to reverse
my stance on the Unity portion of the migration. It looks like
you may need to do it first rather than last The minimum
Unity version that is supported all the way through to CUCM 8.6
would be Unity 5.0;
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/compatibility/matrix/cutspmtx.html
I would do the migration to Unity Connection as a FIRST step. Sorry for the bad
info my friend!
Supported Version Combinations for Cisco Unity Connection and Cisco Unified Communications Manager
Cisco Unity Connection 2.x and Later
Any version of Cisco Unity Connection 2.x or later is supported for use with any version of Cisco Unified CM 4.1(3) or later.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/compatibility/matrix/cucsccpmtx.html
Cheers!
Rob
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-31-2012 03:25 PM
Thanks Rob. I actually ran across that guide right about the time you mentioned it, so no harm done!
