11-01-2013 07:26 AM - edited 03-16-2019 08:11 PM
I have a CCME router (2951) with a PRI connected to the telco.
I would like to translate incoming calls to the internal extension number 5000, so i created an incoming pots dial peer for the PRI and bound a translation profile to it:
dial-peer voice 1 pots
description **Incoming PRI**
translation-profile incoming INCOMING
incoming called-number .T
port 0/0/0:15
no sip-register
voice translation-rule 1
rule 1 /.*/ /5000/
voice translation-profile INCOMING
translate called 1
interface Serial0/0/0:15
no ip address
encapsulation ppp
isdn switch-type primary-net5
isdn overlap-receiving T302 2000
isdn incoming-voice voice
isdn send-alerting
isdn bchan-number-order ascending
isdn sending-complete
When I did incoming calls to the PRI I noticed, that the dial-peer 1 is never been chosen, so the incoming
digit translation of course is not working as well.
My current solution is binding the incoming profile directly to the voice-port of the PRI:
voice-port 0/0/0:15
which is working fine.
However, my questions now are the following:
1) Why is the dial-peer 1 not chosen for incoming PRI calls, although it contains the port 0/0/0:15 statement?
2) What are the best practices for placing incoming translation profiles? Should they be placed on the dial peers
or directly on the voice-ports?
Heinz
Solved! Go to Solution.
11-01-2013 10:21 AM
Can you change dial-peer 1 to :
and try again?
Chris
11-01-2013 07:40 AM
Hi Heinz,
First of all, you have a mistake. The translation profile command is incomplete, you're missing the Translation Rule. it shoud be:
translate called
Are you sure call is not hitting Dial-Peer 1? Please send: debug voice ccapi inout
Please remember to rate useful posts clicking on the stars below.
Favor calificar todos las respuestas útiles dando click en las estrellas de mas abajo.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
11-01-2013 08:31 AM
Heinz had correct profile.
To answer the question, there is no best practice where to apply translations, it is up to you to decide.
As to why it did not work please post "debug voice dialpeer" output from the call, perhaps you are matching another inbound dialpeer, posting full config would be helpful as well.
HTH,
Chris
11-01-2013 08:58 AM
a "debug voice dialpeer" shows, that this (voip) dial peer is being chosen when there is an incoming call over the PRI:
dial-peer voice 1001 voip
destination-pattern [1-9]...
session protocol sipv2
session target ipv4:10.1.1.1
session transport tcp
It´s an internal dial peer which points to a different CCME system. I dont understand why this is beeing chosen when there is a call coming in from the PRI.
Debug output:
001828: Nov 1 19:53:11.256 GST: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=00446935350, Called Number=9993803, Voice-Interface=0x13D99B2C,
Timeout=FALSE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
001829: Nov 1 19:53:11.256 GST: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=101
001830: Nov 1 19:53:11.256 GST: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
001831: Nov 1 19:53:11.256 GST: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=00446935350, Called Number=9993803, Voice-Interface=0x0,
Peer Info Type=DIALPEER_INFO_FAX
001832: Nov 1 19:53:11.256 GST: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=NO_MATCH(-1) After All Match Rules Attempt
001833: Nov 1 19:53:11.256 GST: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
001834: Nov 1 19:53:13.260 GST: //-1/8B3E1EA4801A/DPM/dpMatchPeersCore:
Calling Number=, Called Number=9993803T, Peer Info Type=DIALPEER_INFO_SPEECH
001835: Nov 1 19:53:13.260 GST: //-1/8B3E1EA4801A/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=9993803T
001836: Nov 1 19:53:13.260 GST: //-1/8B3E1EA4801A/DPM/dpMatchPeersCore:
Result=Success(0) after DP_MATCH_DEST
001837: Nov 1 19:53:13.260 GST: //-1/8B3E1EA4801A/DPM/dpMatchSafModulePlugin:
dialstring=9993803T, saf_enabled=1, saf_dndb_lookup=0, dp_result=0
001838: Nov 1 19:53:13.260 GST: //-1/8B3E1EA4801A/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=1001
001839: Nov 1 19:53:13.260 GST: //-1/8B3E1EA4801A/DPM/dpMatchPeersCore:
Calling Number=, Called Number=9993803, Peer Info Type=DIALPEER_INFO_SPEECH
001840: Nov 1 19:53:13.260 GST: //-1/8B3E1EA4801A/DPM/dpMatchPeersCore:
001841: Nov 1 19:53:13.260 GST: //-1/8B3E1EA4801A/DPM/dpMatchPeersCore:
001842: Nov 1 19:53:13.260 GST: //-1/8B3E1EA4801A/DPM/dpMatchSafModulePlugin:
dialstring=9993803, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
001843: Nov 1 19:53:13.260 GST: //-1/8B3E1EA4801A/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
001844: Nov 1 19:53:13.260 GST: //-1/8B3E1EA4801A/DPM/dpMatchPeersCore:
001845: Nov 1 19:53:13.260 GST: //-1/8B3E1EA4801A/DPM/dpMatchPeersCore:
001846: Nov 1 19:53:13.260 GST: //-1/8B3E1EA4801A/DPM/dpMatchPeersCore:
001847: Nov 1 19:53:13.260 GST: //-1/8B3E1EA4801A/DPM/dpMatchSafModulePlugin:
001848: Nov 1 19:53:13.260 GST: //-1/8B3E1EA4801A/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
001849: Nov 1 19:53:13.260 GST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=9993803, Called Number=9993803, Peer Info Type=DIALPEER_INFO_SPEECH
001850: Nov 1 19:53:13.260 GST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
001851: Nov 1 19:53:13.260 GST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
001852: Nov 1 19:53:13.260 GST: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
001853: Nov 1 19:53:13.260 GST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
001854: Nov 1 19:53:13.260 GST: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=9993803, Called Number=, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
001855: Nov 1 19:53:13.260 GST: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=1001
001856: Nov 1 19:53:13.260 GST: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
001857: Nov 1 19:53:13.260 GST: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
001858: Nov 1 19:53:13.260 GST: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
001859: Nov 1 19:53:13.260 GST: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
001860: Nov 1 19:53:13.260 GST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
001861: Nov 1 19:53:13.260 GST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
001862: Nov 1 19:53:13.260 GST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
001863: Nov 1 19:53:13.260 GST: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
001864: Nov 1 19:53:13.260 GST: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
001865: Nov 1 19:53:13.260 GST: //-1/8B3E1EA4801A/DPM/dpMatchPeersCore:
001866: Nov 1 19:53:13.260 GST: //-1/8B3E1EA4801A/DPM/dpMatchPeersCore:
001867: Nov 1 19:53:13.264 GST: //-1/8B3E1EA4801A/DPM/dpMatchPeersCore:
001868: Nov 1 19:53:13.264 GST: //-1/8B3E1EA4801A/DPM/dpMatchSafModulePlugin:
dialstring=9993803, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
001869: Nov 1 19:53:13.264 GST: //-1/8B3E1EA4801A/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
The dialed number is: 9993803
Any ideas?
11-01-2013 09:03 AM
I was sure the traslation-profile was incomplete :
translate called
Maybe I'm tired
11-01-2013 09:12 AM
Can you post dial peer 101?
11-01-2013 09:56 AM
Dial-Peer 101 is the Outgoing-Dialpeer for the PRI:
dial-peer voice 101 pots
description **Outgoing Dial Peer**
translation-profile outgoing OUTGOING
destination-pattern 0T
port 0/0/0:15
no sip-register
and dial-peer 1 shoud act as the incoming one:
description **Incoming Dial Peer PRI**
port 0/0/0:15
no sip-register
Maybe there is a conflict because I use "port 0/0/0:15" on both dial-peers?
11-01-2013 10:21 AM
and try again?
Chris
11-01-2013 10:54 AM
Hi Chris,
that did the trick. Many thanks!
Have a good one
Heinz
