01-27-2016 09:13 AM - edited 03-17-2019 05:38 AM
I notice when placing a call from my cell to my Cisco Deskphone and if I disconnect before I answer or voicemail it picked up it does not report this call in CDR Reporting. Is this consider not to be a call since its still ringing or is this something more of a configuration issue or something I am overlooking or is it by design?
Resource I been reviewing
01-27-2016 09:26 AM
Hi James,
You are probably missing the "log calls with zero duration" flag;
Cheers!
Rob
01-27-2016 12:01 PM
Default if false I will turn this on. Do you know if this will pick up the missed calls that currently show on Cisco phones for call history or is there a query I can do against the database to pull call history for devices?
01-27-2016 07:38 PM
It will take effect for the missed calls that will happen after you turn this parameter to True. AS far as query is concerned, there might be one which can be created querying and joining the tables within DB, worth posting it at below forum:
http://www.ucguerrilla.com/2012/03/cucm-sql-queries-series.html
Deepak
