Cisco 7975G Display Problem (Black Circle)
rqualls
About 5 of our 10 Cisco 7975G Ip phones now have a black spot on the middle of the left had side of the screen. We do not have Hardware support on the handsets. Has anyone seen this issue, and if so, what are my options for repair? I figure since half of mine are having the issues, surely others have seen it.
clileikis
Level 7
Level 7
Hi Rob,
Sounds like the following bug, looks like RMA is the only option:
CSCtq57134
Defective 7975 LCD with Black Dot on Display
Symptom:
Cisco 7975 IP phone sometimes have a black dot on the display
Conditions:
There have been reports about some 7975 IP phones have a black dot on the display. Once there, it appears to be permantly.
Workaround:
None.
HTH,
Chris
Please rate helpful posts
6 Replies 6
clileikis
Level 7
Level 7
Hi Rob,
CSCtq57134
Symptom:
Conditions:
Workaround:
None.
HTH,
Chris
Joseph Martini
There is a defect for the LCD displays on those phones
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtq57134.  We'll have to RMA them if they're under contract/warranty.
Looks like we posted at the same time 5 stars for you Chris.
Thanks Joe same to you!
rqualls
Thanks Guys. Since I don't have active support on those, I guess I'm out of luck.
They still have 1 year warranty even if you don't have a support contract.
It just takes 10 business days to replace the phone, where as if you had a support you would get a next business day replacement.
